请问一下,烧写了最新的SDK编译出来的固件无法启动是什么原因
DDR Version 1.24 20191016
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 337
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68505
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: oem, start:0x3a000, size:0x20000
GPT part: 7, name: rootfs, start:0x5a000, size:0x180800
GPT part: 8, name: userdata, start:0x1da800, size:0x1b447df
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
Trust Addr:0x6000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xfac30
RunBL31 0x40000 @ 111124 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #1 Mon Aug 17 09:23:30 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc56bc3a030 #meakboo (Aug 21 2021 - 09:23:01 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 3.8 GiB
Sysmem: init
Relocation Offset: f5bc9000, fdt: f3dbd358
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
Android header version 0
I2c0 speed: 400000Hz
rk8xx_read: read reg 0xed failed, ret=-121
Model: Rockchip RK3399 EVB IND LPDDR4 Board edp (Linux)
Using display timing dts
Detailed mode clock 200000 kHz, flags[a]
H: 1536 1548 1564 1612
V: 2048 2056 2060 2068
bus_format: 100e
AUX CH command reply failed!
AUX CH error happens: 2
failed to get Rx Max Link Rate
failed to init training
unable to do link train
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 200000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 133333 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
mmc_init: -95, time 26
failed to read ca head from misc
Could not read from misc partition
WARNING: Unable to load the BCB.
ERR TEE-CORE:main_tee_entry_fast:229: optee api revision mismatch with u-boot/kernel, panic
PANIC: main_tee_entry_fast core/arch/arm/plat-rockchip/main.c:230
烧写流程肯定是没错的
编译的话,就直接运行的build.sh
还需要什么特殊的操作么
meakboo 发表于 2021-8-21 11:46
烧写流程肯定是没错的
编译的话,就直接运行的build.sh
还需要什么特殊的操作么
可以先确认sdk是否同步最新提交,再进行编译
这是我刚编译后的启动log的你自己对比下不同:
soft reset
SRX
256B stride
CPUId = 0x0
ChipType = 0x10, 427
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68973
SecureMode = 0
GPT part: 6, name: rootfs, start:0x5a000, size:0x3c6000
GPT part: 7, name: userdata, start:0x420000, size:0x18fefdf
No find bl30.bin
Load OK, addr=0x200000, size=0xd8cb8
RunBL31 0x40000 @ 111466 us
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc56bc3a030 #jmiao1 (Aug 16 2021 - 16:38:58 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbeb000, fdt: 7bddf4d8
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: normal
Found DTB in boot part
DTB: rk-kernel.dtb
HASH(c): OK
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1100000 uV
In: serial
Out: serial
Err: serial
Model: Firefly-RK3399 Board (Linux Opensource)
xfer: num: 2, addr: 0x50
Monitor has basic audio support
mode:3840x2160
Detailed mode clock 594000 kHz, flags[5]
H: 3840 4016 4104 4400
V: 2160 2168 2178 2250
bus_format: 100a
CEA mode used vic=97
final pixclk = 594000000 tmdsclk = 594000000
xfer: num: 2, addr: 0x54
xfer: num: 1, addr: 0x54
[dw_hdmi_i2c_write] write offset 03 success
[dw_hdmi_i2c_write] write offset 21 success
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=594.000MHz N=10240 cts=990000
aplll 816000 KHz
apllb 816000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 594000 KHz
hclk_perilp1 100000 KHz
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 22407 KiB
RAM disk load addr 0x0a200000 size 8657 KiB
Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
Using Device Tree in place at 0000000008300000, end 000000000831c317
No file: logo_kernel.bmp
Total: 3172.664 ms
[ 0.000000] Linux version 4.4.194+ (jmiao1@pek-jmiao1-u16) (firefly: 021a2d9d5f486891ae334300b94bf05ef55e2b1b) (gcc version 6.3.1 20170404 (L1
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee1000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboo1
[ 0.000000] software IO TLB: mapped [mem 0x7fe98000-0x7fed8000] (0MB)
[ 0.000000] Memory: 1993232K/2064384K available (14014K kernel code, 1798K rwdata, 5320K rodata, 1216K init, 2010K bss, 71152K reserved, 0K c)
[ 0.000000] .init : 0xffffff8009370000 - 0xffffff80094a0000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008e30000 ( 14016 KB)
[ 0.000000] .rodata : 0xffffff8008e30000 - 0xffffff8009370000 ( 5376 KB)
[ 0.000000] .data : 0xffffff80094a0000 - 0xffffff8009661808 ( 1799 KB)
[ 0.000000] ITS: allocated 65536 Devices @7d480000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007d410000
[ 0.000000] CPU0: using LPI pending table @0x000000007d420000
[ 0.002189] Console: colour dummy device 80x25
[ 0.002629] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003614] pid_max: default: 32768 minimum: 301
[ 0.004132] Security Framework initialized
[ 0.004592] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005232] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006572] Initializing cgroup subsys io
[ 0.006979] Initializing cgroup subsys memory
[ 0.007418] Initializing cgroup subsys devices
[ 0.007848] Initializing cgroup subsys freezer
[ 0.008287] Initializing cgroup subsys perf_event
[ 0.008741] Initializing cgroup subsys net_prio
[ 0.009178] Initializing cgroup subsys pids
[ 0.009608] ftrace: allocating 50687 entries in 198 pages
[ 0.131375] sched-energy: Sched-energy-costs installed from DT
[ 0.131939] CPU0: update cpu_capacity 401
[ 0.132381] ASID allocator initialised with 32768 entries
[ 0.136027] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.137367] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.139568] Detected VIPT I-cache on CPU1
[ 0.139597] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.139621] CPU1: using LPI pending table @0x000000007d6c0000
[ 0.139659] CPU1: update cpu_capacity 401
[ 0.139663] CPU1: Booted secondary processor [410fd034]
[ 0.140198] Detected VIPT I-cache on CPU2
[ 0.140218] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.140240] CPU2: using LPI pending table @0x000000007d6f0000
[ 0.140265] CPU2: update cpu_capacity 401
[ 0.140269] CPU2: Booted secondary processor [410fd034]
[ 0.140797] Detected VIPT I-cache on CPU3
[ 0.140817] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.140840] CPU3: using LPI pending table @0x000000007d740000
[ 0.140865] CPU3: update cpu_capacity 401
[ 0.140868] CPU3: Booted secondary processor [410fd034]
[ 0.141407] Detected PIPT I-cache on CPU4
[ 0.141431] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.141464] CPU4: using LPI pending table @0x000000007d770000
[ 0.141499] CPU4: update cpu_capacity 1024
[ 0.141502] CPU4: Booted secondary processor [410fd082]
[ 0.142040] Detected PIPT I-cache on CPU5
[ 0.142059] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.142090] CPU5: using LPI pending table @0x000000007d7b0000
[ 0.142115] CPU5: update cpu_capacity 1024
[ 0.142118] CPU5: Booted secondary processor [410fd082]
[ 0.142200] Brought up 6 CPUs
[ 0.154537] SMP: Total of 6 processors activated.
[ 0.154987] CPU features: detected feature: GIC system register CPU interface
[ 0.155674] CPU features: detected feature: 32-bit EL0 Support
[ 0.156232] CPU: All CPU(s) started at EL2
[ 0.156657] alternatives: patching kernel code
[ 0.158421] devtmpfs: initialized
[ 0.176769] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.177720] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.178740] xor: measuring software checksum speed
[ 0.188390] 8regs : 2856.000 MB/sec
[ 0.198445] 8regs_prefetch: 2556.000 MB/sec
[ 0.208496] 32regs : 3204.000 MB/sec
[ 0.218551] 32regs_prefetch: 2848.000 MB/sec
[ 0.218998] xor: using function: 32regs (3204.000 MB/sec)
[ 0.219530] pinctrl core: initialized pinctrl subsystem
[ 0.221715] Failed to find legacy iommu devices
[ 0.222502] NET: Registered protocol family 16
[ 0.228153] cpuidle: using governor ladder
[ 0.232161] cpuidle: using governor menu
[ 0.232554] Registered FIQ tty driver
[ 0.233445] vdso: 2 pages (1 code @ ffffff8008e36000, 1 data @ ffffff80094a4000)
[ 0.234179] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.235236] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.259553] console [pstore-1] enabled
[ 0.259914] pstore: Registered ramoops as persistent store backend
[ 0.260511] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.263574] console [ttyFIQ0] enabled
[ 0.264251] bootconsole [uart0] disabled
[ 0.265181] Registered fiq debugger ttyFIQ0
[ 0.315171] raid6: int64x1 gen() 468 MB/s
[ 0.332232] raid6: int64x1 xor() 414 MB/s
[ 0.349323] raid6: int64x2 gen() 675 MB/s
[ 0.366376] raid6: int64x2 xor() 605 MB/s
[ 0.383494] raid6: int64x4 gen() 972 MB/s
[ 0.400540] raid6: int64x4 xor() 675 MB/s
[ 0.417692] raid6: int64x8 gen() 781 MB/s
[ 0.434715] raid6: int64x8 xor() 630 MB/s
[ 0.451798] raid6: neonx1 gen() 960 MB/s
[ 0.468926] raid6: neonx1 xor() 675 MB/s
[ 0.486000] raid6: neonx2 gen() 1273 MB/s
[ 0.503082] raid6: neonx2 xor() 970 MB/s
[ 0.520165] raid6: neonx4 gen() 1726 MB/s
[ 0.537254] raid6: neonx4 xor() 1175 MB/s
[ 0.554366] raid6: neonx8 gen() 1695 MB/s
[ 0.571448] raid6: neonx8 xor() 1236 MB/s
[ 0.571838] raid6: using algorithm neonx4 gen() 1726 MB/s
[ 0.572314] raid6: … xor() 1175 MB/s, rmw enabled
[ 0.572755] raid6: using intx1 recovery algorithm
[ 0.578010] iommu: Adding device ff650000.vpu_service to group 0
[ 0.578634] iommu: Adding device ff660000.rkvdec to group 1
[ 0.579240] iommu: Adding device ff8f0000.vop to group 2
[ 0.579810] iommu: Adding device ff900000.vop to group 3
[ 0.580376] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.580970] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.581944] rk_iommu ff650800.iommu: can’t get sclk
[ 0.582620] rk_iommu ff660480.iommu: can’t get sclk
[ 0.583267] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.583856] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.584459] rk_iommu ff914000.iommu: can’t get sclk
[ 0.585047] rk_iommu ff924000.iommu: can’t get sclk
[ 0.585845] SCSI subsystem initialized
[ 0.586535] usbcore: registered new interface driver usbfs
[ 0.587060] usbcore: registered new interface driver hub
[ 0.587625] usbcore: registered new device driver usb
[ 0.588141] media: Linux media interface: v0.10
[ 0.588589] Linux video capture interface: v2.00
[ 0.589075] pps_core: LinuxPPS API ver. 1 registered
[ 0.589517] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.590343] PTP clock support registered
[ 0.591842] Advanced Linux Sound Architecture Driver Initialized.
[ 0.592840] Bluetooth: Core ver 2.21
[ 0.593190] NET: Registered protocol family 31
[ 0.593597] Bluetooth: HCI device and connection manager initialized
[ 0.594170] Bluetooth: HCI socket layer initialized
[ 0.594611] Bluetooth: L2CAP socket layer initialized
[ 0.595085] Bluetooth: SCO socket layer initialized
[ 0.596023] nfc: nfc_init: NFC Core ver 0.1
[ 0.596430] NET: Registered protocol family 39
[ 0.596941] rockchip-cpuinfo cpuinfo: Serial : 8872ea202ee31427
[ 0.598283] clocksource: Switched to clocksource arch_sys_counter
[ 0.648885] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.649795] NET: Registered protocol family 2
[ 0.650593] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.651374] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.652418] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.653063] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.653686] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.654516] NET: Registered protocol family 1
[ 0.655173] RPC: Registered named UNIX socket transport module.
[ 0.655712] RPC: Registered udp transport module.
[ 0.656132] RPC: Registered tcp transport module.
[ 0.656558] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.657799] Trying to unpack rootfs image as initramfs…
[ 1.070534] Freeing initrd memory: 8656K
[ 1.071599] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.072422] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.075963] audit: initializing netlink subsys (disabled)
[ 1.076489] audit: type=2000 audit(0.988:1): initialized
[ 1.077382] Initialise system trusted keyring
[ 1.085647] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.086957] NFS: Registering the id_resolver key type
[ 1.087443] Key type id_resolver registered
[ 1.087818] Key type id_legacy registered
[ 1.088193] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.089488] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.090247] fuse init (API version 7.23)
[ 1.090947] SGI XFS with security attributes, no debug enabled
[ 1.096874] NET: Registered protocol family 38
[ 1.097304] Key type asymmetric registered
[ 1.097671] Asymmetric key parser ‘x509’ registered
[ 1.098248] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.099041] io scheduler noop registered
[ 1.099412] io scheduler deadline registered
[ 1.099828] io scheduler cfq registered (default)
[ 1.101764] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 1.106892] ace test_init function.
[ 1.107393] ace test_init end.ret=0
[ 1.108080] radar end.ret=0
[ 1.110831] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.111440] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.112034] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.112602] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 1.113211] PCI host bridge /pcie@f8000000 ranges:
[ 1.113768] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 1.114226] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 1.656339] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.656952] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.657692] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.659230] Module initialized.
[ 1.659990] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.660852] rk-vcodec ff650000.vpu_service: probe device
[ 1.661587] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.662746] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.663380] rk-vcodec ff650000.vpu_service: init success
[ 1.664090] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.665033] rk-vcodec ff660000.rkvdec: probe device
[ 1.665679] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.666632] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.667214] rk-vcodec ff660000.rkvdec: init success
[ 1.669107] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.669796] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.672031] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.672717] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.674554] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.675759] pwm-regulator: supplied by vcc5v0_sys
[ 1.676859] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.678006] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.679328] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.681843] [drm] Initialized drm 1.1.0 20060810
[ 1.686238] [drm] Rockchip DRM driver version: v1.0.1
[ 1.688911] mali ff9a0000.gpu: Failed to get regulator
[ 1.689379] mali ff9a0000.gpu: Power control initialization failed
[ 1.690271] Unable to detect cache hierarchy for CPU 0
[ 1.691572] brd: module loaded
[ 1.697085] loop: module loaded
[ 1.697916] zram: Added device: zram0
[ 1.698533] lkdtm: No crash points registered, enable through debugfs
[ 1.699481] Loading dl1825 driver
[ 1.701396] register spi return v = :0
[ 1.702228] tun: Universal TUN/TAP device driver, 1.6
[ 1.702697] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.704216] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.704937] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.705576] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.706079] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.706601] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.707320] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.707935] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.713494] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.714104] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.714565] Ring mode enabled
[ 1.714847] DMA HW capability register supported
[ 1.715252] Normal descriptors
[ 1.715565] RX Checksum Offload Engine supported (type 2)
[ 1.716051] Wake-Up On Lan supported
[ 1.716419] Enable RX Mitigation via HW Watchdog Timer
[ 1.786373] libphy: stmmac: probed
[ 1.786686] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.787255] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.789125] usbcore: registered new interface driver rtl8192cu
[ 1.789712] usbcore: registered new interface driver rndis_wlan
[ 1.790558] usbcore: registered new interface driver mt7601u
[ 1.791175] Rockchip WiFi SYS interface (V1.00) …
[ 1.791726] usbcore: registered new interface driver rtl8150
[ 1.792297] usbcore: registered new interface driver r8152
[ 1.792845] usbcore: registered new interface driver asix
[ 1.793380] usbcore: registered new interface driver ax88179_178a
[ 1.793968] usbcore: registered new interface driver cdc_ether
[ 1.794584] usbcore: registered new interface driver rndis_host
[ 1.795177] usbcore: registered new interface driver cdc_ncm
[ 1.795729] usbcore: registered new interface driver qmi_wwan
[ 1.796288] usbcore: registered new interface driver cdc_mbim
[ 1.798205] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.802768] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 1.804499] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.805090] ehci-pci: EHCI PCI platform driver
[ 1.805552] ehci-platform: EHCI generic platform driver
[ 1.809863] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.810557] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.811362] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.817306] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.817998] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.818617] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.819255] usb usb1: Product: EHCI Host Controller
[ 1.819696] usb usb1: Manufacturer: Linux 4.4.194+ ehci_hcd
[ 1.820196] usb usb1: SerialNumber: fe3c0000.usb
[ 1.821069] hub 1-0:1.0: USB hub found
[ 1.821448] hub 1-0:1.0: 1 port detected
[ 1.822366] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.822924] ohci-platform: OHCI generic platform driver
[ 1.823870] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.824649] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.825436] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.880516] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.881126] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.881779] usb usb2: Product: Generic Platform OHCI controller
[ 1.882316] usb usb2: Manufacturer: Linux 4.4.194+ ohci_hcd
[ 1.882817] usb usb2: SerialNumber: fe3e0000.usb
[ 1.883884] hub 2-0:1.0: USB hub found
[ 1.884257] hub 2-0:1.0: 1 port detected
[ 1.886024] usbcore: registered new interface driver cdc_acm
[ 1.886539] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.887309] usbcore: registered new interface driver cdc_wdm
[ 1.887861] usbcore: registered new interface driver uas
[ 1.888462] usbcore: registered new interface driver usb-storage
[ 1.889093] usbcore: registered new interface driver usbserial
[ 1.889672] usbcore: registered new interface driver usbserial_generic
[ 1.890296] usbserial: USB Serial support registered for generic
[ 1.890876] usbcore: registered new interface driver ch341
[ 1.891412] usbserial: USB Serial support registered for ch341-uart
[ 1.892014] usbcore: registered new interface driver cp210x
[ 1.892562] usbserial: USB Serial support registered for cp210x
[ 1.893155] usbcore: registered new interface driver ftdi_sio
[ 1.893709] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.894520] usbcore: registered new interface driver keyspan
[ 1.895049] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.895787] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.896476] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.897152] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.897870] usbcore: registered new interface driver option
[ 1.898415] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.899219] usbcore: registered new interface driver oti6858
[ 1.899762] usbserial: USB Serial support registered for oti6858
[ 1.900359] usbcore: registered new interface driver pl2303
[ 1.900886] usbserial: USB Serial support registered for pl2303
[ 1.901477] usbcore: registered new interface driver qcserial
[ 1.902022] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.902711] usbcore: registered new interface driver sierra
[ 1.903240] usbserial: USB Serial support registered for Sierra USB modem
[ 1.905321] usbcore: registered new interface driver usbtouchscreen
[ 1.906333] .. rk pwm remotectl v1.1 init
[ 1.907014] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.908195] sensor_register_slave:mma8452,id=17
[ 1.908632] sensor_register_slave:lis3dh,id=7
[ 1.909035] sensor_register_slave:mma7660,id=18
[ 1.909461] sensor_register_slave:lsm303d,id=22
[ 1.909875] sensor_register_slave:gs_mc3230,id=23
[ 1.910304] [Gsensor] gsensor_init
[ 1.910639] sensor_register_slave:mpu6880_acc,id=24
[ 1.911076] sensor_register_slave:mpu6500_acc,id=25
[ 1.911524] sensor_register_slave:lsm330_acc,id=26
[ 1.911961] sensor_register_slave:akm8975,id=30
[ 1.912385] sensor_register_slave:akm8963,id=31
[ 1.912799] sensor_register_slave:l3g4200d,id=45
[ 1.913213] sensor_register_slave:l3g20d,id=46
[ 1.913626] sensor_register_slave:ewtsa,id=47
[ 1.914019] sensor_register_slave:lsm330_gyro,id=51
[ 1.914476] sensor_register_slave:cm3217,id=53
[ 1.914879] sensor_register_slave:cm3218,id=54
[ 1.915879] i2c /dev entries driver
[ 1.917880] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.918616] fan53555-reg: supplied by vcc5v0_sys
[ 1.921452] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.922141] fan53555-reg: supplied by vcc5v0_sys
[ 1.925085] rk808 0-001b: Pmic Chip id: 0x0
[ 1.928516] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.929137] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.929833] DCDC_REG1: supplied by vcc3v3_sys
[ 1.931133] DCDC_REG2: supplied by vcc3v3_sys
[ 1.932236] DCDC_REG3: supplied by vcc3v3_sys
[ 1.933020] DCDC_REG4: supplied by vcc3v3_sys
[ 1.934012] LDO_REG1: supplied by vcc3v3_sys
[ 1.935679] LDO_REG2: supplied by vcc3v3_sys
[ 1.937179] LDO_REG3: supplied by vcc3v3_sys
[ 1.938712] LDO_REG4: supplied by vcc3v3_sys
[ 1.940243] LDO_REG5: supplied by vcc3v3_sys
[ 1.941752] LDO_REG6: supplied by vcc3v3_sys
[ 1.943294] LDO_REG7: supplied by vcc3v3_sys
[ 1.944817] LDO_REG8: supplied by vcc3v3_sys
[ 1.946351] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.947171] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.951363] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.952568] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009af2000
[ 1.954388] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009af4000
[ 1.956749] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 1.966729] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.967735] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input1
[ 1.968763] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009af6000
[ 1.971174] IR NEC protocol handler initialized
[ 1.972709] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 1.973312] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 1.976632] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.05
[ 1.977241] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 1.980002] usbcore: registered new interface driver npu_acm
[ 1.980659] usbcore: registered new interface driver uvcvideo
[ 1.981176] USB Video Class driver (1.1.1)
[ 1.984674] Boot mode: normal
[ 1.987167] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.988201] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 1.990391] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.991424] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.a2fd257.20190430-133301
[ 1.992107] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 1.992577] rtk_btcoex: create workqueue
[ 1.992927] rtk_btcoex: Coex over UDP
[ 1.993576] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 1.994190] usbcore: registered new interface driver rtk_btusb
[ 1.994745] Bluetooth: Virtual HCI driver ver 1.5
[ 1.995307] Bluetooth: HCI UART driver ver 2.3
[ 1.995706] Bluetooth: HCI UART protocol H4 registered
[ 1.996160] Bluetooth: HCI UART protocol LL registered
[ 1.996631] Bluetooth: HCI UART protocol ATH3K registered
[ 1.997174] usbcore: registered new interface driver bfusb
[ 1.997746] usbcore: registered new interface driver btusb
[ 1.998912] cpu cpu0: bin=1
[ 1.999239] cpu cpu0: leakage=14
[ 2.012168] cpu cpu0: temp=53888, pvtm=136706 (135914 + 792)
[ 2.013062] cpu cpu0: pvtm-volt-sel=0
[ 2.013483] cpu cpu0: bin-scale=34
[ 2.014203] cpu cpu4: bin=1
[ 2.014602] cpu cpu4: leakage=24
[ 2.027380] cpu cpu4: temp=52777, pvtm=142864 (142479 + 385)
[ 2.028779] cpu cpu4: pvtm-volt-sel=0
[ 2.029172] cpu cpu4: bin-scale=17
[ 2.031119] cpu cpu0: avs=0
[ 2.031534] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.032985] cpu cpu0: failed to find power_model node
[ 2.034827] cpu cpu4: avs=0
[ 2.035226] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.037451] cpu cpu4: failed to find power_model node
[ 2.039037] sdhci: Secure Digital Host Controller Interface driver
[ 2.039612] sdhci: Copyright(c) Pierre Ossman
[ 2.040015] Synopsys Designware Multimedia Card Interface Driver
[ 2.041824] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.042504] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.043116] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.043687] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.044577] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.045416] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.045963] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.047971] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.048653] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.049263] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.049833] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.050718] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.052083] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.052793] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.066038] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.079635] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.080747] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.083243] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.083797] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.114814] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.117023] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.118112] usbcore: registered new interface driver usbhid
[ 2.118635] usbhid: USB HID core driver
[ 2.119110] inv_mpu_iio: inv_mpu_init:746
[ 2.123126] usbcore: registered new interface driver snd-usb-audio
[ 2.123322] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 2.125765] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 2.126411] rt5640 1-001c: Can not read property hp_det_gpio
[ 2.126912] rt5640 1-001c: Can not read property: linein-mute.
[ 2.142969] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 2.143673] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 2.144569] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.145557] IPVS: Registered protocols (TCP, UDP)
[ 2.146015] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 2.146774] IPVS: Creating netns size=2104 id=0
[ 2.147205] IPVS: ipvs loaded.
[ 2.147504] IPVS: [rr] scheduler registered.
[ 2.148166] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.148733] Initializing XFRM netlink socket
[ 2.149754] NET: Registered protocol family 10
[ 2.151061] NET: Registered protocol family 17
[ 2.151507] NET: Registered protocol family 15
[ 2.151936] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.153076] Bridge firewalling registered
[ 2.153896] Bluetooth: RFCOMM socket layer initialized
[ 2.154403] Bluetooth: RFCOMM ver 1.11
[ 2.154764] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.155305] Bluetooth: HIDP socket layer initialized
[ 2.155810] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.156546] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.157015] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.157639] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.158264] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.158990] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.159802] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.160459] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.160926] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.161404] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.162155] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.162923] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.163653] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.164387] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.165585] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.166164] [BT_RFKILL]: ** disable irq
[ 2.166890] [BT_RFKILL]: bt_default device registered.
[ 2.167534] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.167556] Key type dns_resolver registered
[ 2.167867] sensor_register_slave:mpu6880_gyro,id=50
[ 2.168776] ov13850 1-0036: driver version: 00.01.03
[ 2.171485] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 2.172722] ov13850 1-0036: write SCCB_ID failed
[ 2.172937] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 2.173900] ov13850: probe of 1-0036 failed with error -5
[ 2.174019] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 2.175028] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 2.175486] ov13850 1-0046: driver version: 00.01.03
[ 2.178189] ov13850 1-0046: write SCCB_ID failed
[ 2.178821] ov13850: probe of 1-0046 failed with error -5
[ 2.180485] Registered cp15_barrier emulation handler
[ 2.180629] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.181437] Registered setend emulation handler
[ 2.182951] Loading compiled-in X.509 certificates
[ 2.186771] Btrfs loaded
[ 2.188263] rga2: Driver loaded successfully ver:3.02
[ 2.189090] rga2: Module initialized.
[ 2.191687] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator
[ 2.197415] rockchip-drm display-subsystem: dmc is disabled
[ 2.198829] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 2.200381] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008ef40f0)
[ 2.201320] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 2.202033] fusb302 4-0022: CC connected in CC1 as UFP
[ 2.203015] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008ef40f0)
[ 2.205152] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 2.205867] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.206866] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.211483] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ee8948)
[ 2.213584] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 2.215241] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008ee9978)
[ 2.216096] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.216722] [drm] No driver support for vblank timestamp query.
[ 2.238783] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.239416] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.240054] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 2.241420] hub 1-1:1.0: USB hub found
[ 2.242029] hub 1-1:1.0: 7 ports detected
[ 2.526532] usb 1-1.2: new low-speed USB device number 3 using ehci-platform
[ 2.633765] usb 1-1.2: New USB device found, idVendor=413c, idProduct=2105
[ 2.634441] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.635097] usb 1-1.2: Product: Dell USB Keyboard
[ 2.635559] usb 1-1.2: Manufacturer: Dell
[ 2.656670] input: Dell Dell USB Keyboard as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:413C:2105.0001/input/input2
[ 2.672532] vendor storage:20190527 ret = 0
[ 2.710675] hid-generic 0003:413C:2105.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-fe3c0000.usb-1.2/input0
[ 2.765995] Freeing drm_logo memory: 616K
[ 2.913617] Console: switching to colour frame buffer device 480x135
[ 3.032946] rockchip-drm display-subsystem: fb0: frame buffer device
[ 3.040027] mali ff9a0000.gpu: leakage=17
[ 3.052598] mali ff9a0000.gpu: temp=52777, pvtm=116399 (116267 + 132)
[ 3.053907] mali ff9a0000.gpu: pvtm-volt-sel=0
[ 3.054700] mali ff9a0000.gpu: avs=0
[ 3.055625] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 3.056416] mali ff9a0000.gpu: Protected mode not available
[ 3.057390] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 3.058073] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 3.059174] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initi.
[ 3.061277] mali ff9a0000.gpu: Probed as mali0
[ 3.067566] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 3.068439] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 3.069247] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 3.070070] xhci-hcd xhci-hcd.10.auto: irq 229, io mem 0xfe800000
[ 3.070795] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.071401] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.072040] usb usb3: Product: xHCI Host Controller
[ 3.072485] usb usb3: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 3.072978] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 3.074005] hub 3-0:1.0: USB hub found
[ 3.074418] hub 3-0:1.0: 1 port detected
[ 3.074994] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 3.075714] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 3.076456] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.077233] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.077870] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.078526] usb usb4: Product: xHCI Host Controller
[ 3.078998] usb usb4: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 3.079509] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 3.080453] hub 4-0:1.0: USB hub found
[ 3.080806] hub 4-0:1.0: 1 port detected
[ 3.082414] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 3.082925] usb usb4: USB disconnect, device number 1
[ 3.086863] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 3.100342] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 3.101009] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 3.101788] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[ 3.102683] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 3.102688] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 5
[ 3.102818] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 3.102856] xhci-hcd xhci-hcd.11.auto: irq 230, io mem 0xfe900000
[ 3.103058] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.103062] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.103066] usb usb5: Product: xHCI Host Controller
[ 3.103070] usb usb5: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 3.103073] usb usb5: SerialNumber: xhci-hcd.11.auto
[ 3.108207] hub 5-0:1.0: USB hub found
[ 3.108615] hub 5-0:1.0: 1 port detected
[ 3.109212] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 3.109835] usb usb3: USB disconnect, device number 1
[ 3.110580] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 3.111527] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[ 3.112147] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.113048] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.113655] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.114302] usb usb4: Product: xHCI Host Controller
[ 3.114739] usb usb4: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 3.115233] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 3.116133] hub 4-0:1.0: USB hub found
[ 3.116504] hub 4-0:1.0: 1 port detected
[ 3.121189] ehci-platform fe380000.usb: EHCI Host Controller
[ 3.122079] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 3
[ 3.122878] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 3.129537] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 3.130362] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.130960] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.131609] usb usb3: Product: EHCI Host Controller
[ 3.132047] usb usb3: Manufacturer: Linux 4.4.194+ ehci_hcd
[ 3.132548] usb usb3: SerialNumber: fe380000.usb
[ 3.133739] hub 3-0:1.0: USB hub found
[ 3.134094] hub 3-0:1.0: 1 port detected
[ 3.135240] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 3.136148] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 3.136941] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 3.192713] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.193338] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.193974] usb usb6: Product: Generic Platform OHCI controller
[ 3.194516] usb usb6: Manufacturer: Linux 4.4.194+ ohci_hcd
[ 3.195013] usb usb6: SerialNumber: fe3a0000.usb
[ 3.196619] hub 6-0:1.0: USB hub found
[ 3.197001] hub 6-0:1.0: 1 port detected
[ 3.198868] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.199552] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 3.200159] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 3.200707] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 3.201588] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.202407] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 3.202961] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 3.203911] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 3.217473] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.231046] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 3.233012] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 3.248636] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 3.254617] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input3
[ 3.257537] rockchip-cdndp-sound dp-sound: spdif-hifi ↔ ff870000.spdif mapping ok
[ 3.258272] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 3.260513] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card2/input4
[ 3.263047]
[ 3.263197] =======================================================
[ 3.263790] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 3.264370] =======================================================
[ 3.264931] Realtek 8723DU USB WiFi driver (Powered by Rockchip) init.
[ 3.265534] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.265968] [WLAN_RFKILL]: wifi turn on power. -1
[ 3.266415] RTW: module init start
[ 3.266728] RTW: rtl8723du v5.6.5.1_34252.20190703_COEX20181130-2e2e
[ 3.267318] RTW: build time: Aug 15 2021 13:04:32
[ 3.267749] RTW: rtl8723du BT-Coex version = COEX20181130-2e2e
[ 3.268510] usbcore: registered new interface driver rtl8723du
[ 3.269038] RTW: module init ret=0
[ 3.270647] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[ 3.271748] ==gsl_ts_init==
[ 3.272108] ret=0
[ 3.272604] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 3.273265] ======== dhd_wlan_init_plat_data ========
[ 3.273745] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 3.274255] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=70, oob_irq_flags=0x414
[ 3.274939] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 3.275364] dhd_wifi_platform_load: Enter
[ 3.275790] Power-up adapter ‘DHD generic adapter’
[ 3.276257] wifi_platform_set_power = 1
[ 3.276618] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.277077] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.277511] [WLAN_RFKILL]: wifi turn on power. -1
[ 3.289983] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.292201] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.294401] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.294564] phy phy-ff770000.syscon:usb2-phy@e450.7: charger = USB_CDP_CHARGER
[ 3.298330] rockchip-dwc3 usb0: USB peripheral connected
[ 3.298868] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.303331] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 3.359554] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 3.378680] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 10:35:47 UTC (1358505347)
[ 3.396834] vcc_sd: disabling
[ 3.397113] vcc_mipi: disabling
[ 3.397412] dvdd_1v2: disabling
[ 3.401379] ret 1024
[ 3.402805] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_fr.
[ 3.405621] Mali: Mali device driver loaded
[ 3.406624] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 3.408411] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 3.408974] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 3.409575] rkisp1: update sensor failed
[ 3.409949] rkisp1 ff920000.rkisp1: clear unready subdev num: 1
[ 3.411536] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 3.412098] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 3.412690] rkisp1: update sensor failed
[ 3.414311] ALSA device list:
[ 3.414597] #0: rockchip,hdmi
[ 3.414890] #1: rockchip,rt5640-codec
[ 3.415240] #2: rockchip-cdndp-sound
[ 3.416875] Freeing unused kernel memory: 1216K
Loading, please wait…
/dev/console is Ok
starting version 237
[ 3.499646] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 212
[ 3.507007] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.507571] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 3.578323] wifi_platform_bus_enumerate device present 1
[ 3.578804] ======== Card detection to detect SDIO card! ========
[ 3.579403] mmc2:mmc host rescan start!
[ 3.595352] bcmsdh_register: register client driver
[ 3.596073] bcmsdh_sdmmc_probe: Enter num=1
[ 3.596738] bcmsdh_sdmmc_probe: Enter num=2
[ 3.597129] bus num (host idx)=2, slot num (rca)=1
[ 3.597601] found adapter info ‘DHD generic adapter’
[ 3.598118] sdioh_attach: set sd_f2_blocksize 256
[ 3.598620] sdioh_attach: sd clock rate = 0
[ 3.599349] dhdsdio_probe : no mutex held. set lock
[ 3.599923] F1 signature read @0x18000000=0x17224356
[ 3.605593] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 3.607060] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.607829] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 3.608687] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 3.610593] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 3.612368] wl_escan_attach: Enter
[ 3.612736] wl_escan_init: Enter
[ 3.613249] wl_create_event_handler(): thread:wl_escan_handler:d7 started
[ 3.613266] tsk Enter, tsk = 0xffffffc0783101b0
[ 3.614623] dhd_attach(): thread:dhd_watchdog_thread:d8 started
[ 3.615381] dhd_attach(): thread:dhd_dpc:d9 started
[ 3.615995] dhd_attach(): thread:dhd_rxf:da started
[ 3.616524] dhd_deferred_work_init: work queue initialized
[ 3.617027] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 3.617673] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 3.618423] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[ 3.628144] Dongle Host Driver, version 1.579.77.41.10 (r)
[ 3.629767] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[ 3.630269] Register interface [wlan0] MAC: d4:12:43:c2:f3:e0
[ 3.630269]
[ 3.631043] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 3.631663] dhd_wl_ioctl: returning as busstate=0
[ 3.632088] dhd_dbg_detach_pkt_monitor, 2204
[ 3.632494] dhd_bus_devreset: == Power OFF ==
[ 3.633418] bcmsdh_oob_intr_unregister: Enter
[ 3.633811] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.634385] dhd_txglom_enable: enable 0
[ 3.634742] dhd_conf_set_txglom_params: txglom_mode=copy
[ 3.635222] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 3.635834] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[ 3.636455] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[ 3.637072] dhd_bus_devreset: WLAN OFF DONE
[ 3.637648] wifi_platform_set_power = 0
[ 3.638008] ======== PULL WL_REG_ON(-1) LOW! ========
[ 3.638481] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.638915] [WLAN_RFKILL]: wifi shut off power.
[ 3.639338] dhdsdio_probe : the lock is released.
[ 3.639881] dhd_module_init: Exit err=0
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 4.615956] EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts='dev=PARTLABEL=userdae
[ 4.842880] EXT4-fs (mmcblk1p8): recovery complete
[ 4.844019] EXT4-fs (mmcblk1p8): mounted filesystem with ordered data mode. Opts: (null)
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/4.4.194+ in initramfs.
done.
[ 5.113384] systemd[1]: System time before build time, advancing clock.
[ 5.118560] cgroup: cgroup2: unknown option “nsdelegate”
[ 5.129649] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA
