AIO3399J开发板上调试MCP2518FD,SPI时钟无输出
各位同学,本人在AIO3399J开发板上调试MCP2518FD,DTS配制了SPI2,但SPI2时钟只输出一个高电平。
用SPI2_TEST测试程序,SPI2读写又是正常的。请问这个时钟要怎么设置?拜托各位大神了。
&spi2 {
status = “okay”;
//max-frequency = <48000000>;
can0: can@0 {
	compatible = "microchip,mcp2515";
    pinctrl-name = "default";
	pinctrl-0 = <&can0_pins>;
	reg = <0>;
	clocks = <&clk16m>;
	spi-max-frequency = <10000000>;
	interrupt-parent = <&gpio4>;
	interrupts = <28 IRQ_TYPE_EDGE_FALLING>;
    can0_pins: can0-pins {
        rockchip,pins = <4 28 RK_FUNC_GPIO &pcfg_pull_none>;
    clk16m: clk16m {
        compatible = "fixed-clock";
	    #clock-cells = <0>;
	    clock-frequency = <16000000>;
  • sp_test@00 {
  •  compatible = "rockchip,spi_test_bus0_cs0";
  • id = <0>;
  • reg = <0>;
  • spi-max-frequency = <4000000>;
  • status = "okay";
  • sp_test@01 {
  •  compatible = "rockchip,spi_test_bus0_cs1";
  • id = <1>;
  • reg = <1>;
请教以下,你的问题后来是怎么解决的,我是用SPI2接MCP2515,但是设备一直没找到,报了以下三句,复位的时候用示波器抓不到波形
[ 1.703279] rockchip-spi ff1e0000.spi: Failed to request TX DMA channel
[ 1.703299] rockchip-spi ff1e0000.spi: Failed to request RX DMA channel
[ 1.703310] rockchip-spi ff1e0000.spi: no high_speed pinctrl state
