RK3568 编译烧录后起不来
刚接触RK 系列芯片, 不知道哪一步出错了,请指教,谢谢。
LOG 如下:
DDR Version V1.09 20210630
out
U-Boot SPL board init
U-Boot SPL 2017.09-ga1f6fc00a0-210413 #ldq (Apr 13 2021 - 11:35:00)
Trying to boot from MMC2
mmc_init: -95, time 10
Trying to boot from MMC1
MMC error: The cmd index is 0, ret is -110
mmc_init: -110, time 5
spl: mmc init failed with error: -110
Trying to boot from MTD2
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256+ OK
## Checking uboot 0x00a00000 … sha256+ OK
## Checking fdt 0x00b1ded0 … sha256+ OK
## Checking atf-2 0xfdcc9000 … sha256+ OK
## Checking atf-3 0xfdcd0000 … sha256+ OK
## Checking optee 0x08400000 … sha256+ OK
Total: 534.610 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-152-g4e725b15f:cl
NOTICE: BL31: Built : 10:51:13, Jul 15 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/TC:
I/TC: Start rockchip platform init
I/TC: Rockchip release version: 1.0
I/TC: OP-TEE version: 3.6.0-307-g0b06ae94 #1 Fri May 7 01:52:27 UTC 2021 aarch64
I/TC: Initialized
INFO: SPSR = 0x3c9
U-Boot 2017.09-g1f7d2c1f6b #jerry (Aug 27 2021 - 18:26:19 +0800)
Model: Firefly RK3568 Board
PreSerial: 2, raw, 0xfe660000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: ed35b000
Relocation fdt: eb9f8bb0 - eb9fece0
CR: M/C/I
SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 32 MiB
Bootdev(atags): mtd 2
PartType: EFI
boot mode: recovery (misc)
FIT: No fdt blob
No resource partition
Failed to load DTB, ret=-19
Failed to get kernel dtb, ret=-19
io-domain: OK
rockchip_set_ethaddr: vendor_storage_write failed -5
rockchip_set_serialno: could not find efuse/otp device
apll 816000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 24000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 100000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 50000 KHz
aclk_top_high 300000 KHz
aclk_top_low 200000 KHz
hclk_top 150000 KHz
pclk_top 50000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 50000 KHz
Net: No ethernet found.
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
optee api revision: 2.0
Not AVB images, AVB skip
No valid android hdr
Android image load failed
no mmc device at slot 1
no mmc device at slot 0
starting USB…
Bus dwc3@fcc00000: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus dwc3@fd000000: usb maximum-speed not found
USB XHCI 1.10
scanning bus dwc3@fcc00000 for devices… 1 USB Device(s) found
scanning bus dwc3@fd000000 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/000000hernet found.
Retrieving file: pxelinux.cfg/0000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
贴个LOG 老说我内容违规
已解决,见首页精华贴
很有价值
您好,我也遇到了同样的问题 您是怎么解决的呢
我也遇到过, 但按照精华帖里面的操作,还是不行
jerrycui 发表于 2021-8-30 10:46
已解决,见首页精华贴
哪个帖子 解决方法是什么,可以提供下资料吗
哪个帖子? 没有看到哦
精华帖再那个地方了
可以用新的办法解决
https://wiki.t-firefly.com/zh_CN/ROC-RK3568-PC-SE/03-upgrade_firmware_with_flash.html#fang-fa-yi-firefly
