插入u盘后 内核已经识别了u盘,但是没有生成/dev/block/vold/8:0 这个节点 3.10 的内核
用哪个固件?把完整的log贴出来
谢谢已经弄好了
楼主是如何弄好的?我也出现了同样的问题。
log如下:
shell@rk3288:/ $ [ 1291.907666] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[ 1292.180002] usb 3-1.4: new high-speed USB device number 18 using usb20_host
[ 1292.280945] usb 3-1.4: New USB device found, idVendor=14cd, idProduct=1212
[ 1292.281148] usb 3-1.4: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[ 1292.281269] usb 3-1.4: Product: Mass Storage Device
[ 1292.281370] usb 3-1.4: Manufacturer: Generic
[ 1292.281467] usb 3-1.4: SerialNumber: 121220130416
[ 1292.291224] usb-storage 3-1.4:1.0: USB Mass Storage device detected
[ 1292.292489] scsi11 : usb-storage 3-1.4:1.0
[ 1293.274575] scsi 11:0:0:0: Direct-Access Mass Storage Device 1.00 PQ: 0 ANSI: 0 CCS
[ 1293.283902] sd 11:0:0:0: Attached scsi generic sg0 type 0
[ 1293.541408] sd 11:0:0:0: [sda] 30318592 512-byte logical blocks: (15.5 GB/14.4 GiB)
[ 1293.542713] sd 11:0:0:0: [sda] Write Protect is off
[ 1293.544061] sd 11:0:0:0: [sda] No Caching mode page found
[ 1293.544158] sd 11:0:0:0: [sda] Assuming drive cache: write through
[ 1293.553116] sd 11:0:0:0: [sda] No Caching mode page found
[ 1293.553222] sd 11:0:0:0: [sda] Assuming drive cache: write through
[ 1293.555234] sda: sda1
[ 1293.560067] sd 11:0:0:0: [sda] No Caching mode page found
[ 1293.560092] sd 11:0:0:0: [sda] Assuming drive cache: write through
[ 1293.560113] sd 11:0:0:0: [sda] Attached SCSI removable disk
楼主怎么好的,我的U盘为什么不能自动挂载
楼主解决了么 我也碰上这个问题了
