报错提示 Jack server failed to (re)start
[ 30% 5156/17130] Ensure Jack server is installed and started
FAILED: /bin/bash -c “(prebuilts/sdk/tools/jack-admin install-server prebuilts/sdk/tools/jack-launcher.jar prebuilts/sdk/tools/jack-server-4.8.ALPHA.jar 2>&1 || (exit 0) ) && (JACK_SERVER_VM_ARGUMENTS="-Dfile.encoding=UTF-8 -XX:+TieredCompilation" prebuilts/sdk/tools/jack-admin start-server 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update server prebuilts/sdk/tools/jack-server-4.8.ALPHA.jar 4.8.ALPHA 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-2.28.RELEASE.jar 2.28.RELEASE || exit 47; prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-3.36.CANDIDATE.jar 3.36.CANDIDATE || exit 47; prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-4.7.BETA.jar 4.7.BETA || exit 47 )”
Writing client settings in /home/lyl/.jack-settings
Installing jack server in “/home/lyl/.jack-server”
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using “keytool -importkeystore -srckeystore /home/lyl/.jack-server/server.jks -destkeystore /home/lyl/.jack-server/server.jks -deststoretype pkcs12”.
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using “keytool -importkeystore -srckeystore /home/lyl/.jack-server/client.jks -destkeystore /home/lyl/.jack-server/client.jks -deststoretype pkcs12”.
Launching Jack server java -XX:MaxJavaStackTraceDepth=-1 -Djava.io.tmpdir=/tmp -Dfile.encoding=UTF-8 -XX:+TieredCompilation -Xmx4096M -cp /home/lyl/.jack-server/launcher.jar com.android.jack.launcher.ServerLauncher
Jack server failed to (re)start, try ‘jack-diagnose’ or see Jack server log
SSL error when connecting to the Jack server. Try ‘jack-diagnose’
编译指令
./FFTools/make.sh -d rk3399-roc-pc-plus-mipi101 -l rk3399_roc_pc_plus_mipi-userdebug -j16;./FFTools/mkupdate/mkupdate.sh -l rk3399_roc_pc_plus_mipi-userdebug
尝试过的解决方法:
(1)诊断
./prebuilts/sdk/tools/jack-diagnose
如果端口被占用
netstat -ap | grep 8076
kill -9 pid(找到用端口的进程id)
sudo chmod 755 $HOME/.jack-server/config.properties
Restart the jack server:
./prebuilts/sdk/tools/jack-admin kill-server
./prebuilts/sdk/tools/jack-admin start-server
(2)修改网络套接字端口为没有被使用的
(3)重新安装jack服务
cd prebuilts/sdk/tools
jack-admin uninstall-server
touch jack
mm -j32 showcommands &> mm.out
./jack-admin install-server jack-launcher.jar jack-server-4.8.ALPHA.jar
