nfs启动 启动卡死
uboot环境配置如下:
setenv ipaddr 128.224.162.220
setenv serverip 128.224.162.214
setenv bootargs2 “console=ttyFIQ0,1500000 earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 rw nfsroot=128.224.162.214:/home/jmiao1/project/IT/setup/rootfs-rk3399/,v3,tcp ip=128.224.162.220:128.224.162.214:128.224.162.1:255.255.255.0::eth0:off”
setenv bootcmd “echo Booting from network … …; setenv autoload no; tftp 0x00280000 Image; run bootargs2; tftp 0x08300000 rk3399-firefly.dtb; booti 0x00280000 - 0x08300000”
启动log:
DDR Version 1.24 20191016
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 337
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68417
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x419200
GPT part: 7, name: userdata, start:0x473200, size:0x18abddf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
Trust Addr:0x6000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd9788
RunBL31 0x40000 @ 107762 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #1 Mon Aug 17 09:23:30 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc56bc3a030-dirty #jmiao1 (Sep 08 2021 - 16:32:37 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbea000, fdt: 7bdde4d8
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
Android header version 0
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1100000 uV
In: serial
Out: serial
Err: serial
Model: Firefly-RK3399 Board (Linux Opensource)
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
ethernet@fe300000 Waiting for PHY auto negotiation to complete.. done
Speed: 1000, full duplex
Using ethernet@fe300000 device
TFTP from server 128.224.162.214; our IP address is 128.224.162.220
Filename ‘Image’.
Load address: 0x280000
Loading: #################################################################
#################################################T ################
1.4 MiB/s
done
Bytes transferred = 22943752 (15e1808 hex)
Unknown command ‘console=ttyFIQ0,1500000’ - try ‘help’
Filename ‘rk3399-firefly.dtb’.
Load address: 0x8300000
Loading: ########
2.7 MiB/s
done
Bytes transferred = 103263 (1935f hex)
Fdt Ramdisk skip relocation
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
Using Device Tree in place at 0000000008300000, end 000000000831c35e
No file: logo_kernel.bmp
Total: 21150.881 ms
[ 0.000000] Linux version 4.4.194+ (jmiao1@pek-jmiao1-u16) (firefly: 021a2d9d5f486891ae334300b94bf05ef55e2b1b) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP W1
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee1000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: console=ttyFIQ0 earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 rw nfsroot=128.224.162.214:/home/jmiao1/project/IT/setup/rootfs-rk3399/,v3,tcp 1
[ 0.000000] software IO TLB: mapped [mem 0x7fe98000-0x7fed8000] (0MB)
[ 0.000000] Memory: 2001896K/2064384K available (14014K kernel code, 1798K rwdata, 5320K rodata, 1216K init, 2010K bss, 62488K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009370000 - 0xffffff80094a0000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008e30000 ( 14016 KB)
[ 0.000000] .rodata : 0xffffff8008e30000 - 0xffffff8009370000 ( 5376 KB)
[ 0.000000] .data : 0xffffff80094a0000 - 0xffffff8009661808 ( 1799 KB)
[ 0.000000] ITS: allocated 65536 Devices @a280000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a210000
[ 0.000000] CPU0: using LPI pending table @0x000000000a220000
[ 0.002166] Console: colour dummy device 80x25
[ 0.002607] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003594] pid_max: default: 32768 minimum: 301
[ 0.004114] Security Framework initialized
[ 0.004575] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005215] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006559] Initializing cgroup subsys io
[ 0.006965] Initializing cgroup subsys memory
[ 0.007404] Initializing cgroup subsys devices
[ 0.007835] Initializing cgroup subsys freezer
[ 0.008275] Initializing cgroup subsys perf_event
[ 0.008729] Initializing cgroup subsys net_prio
[ 0.009166] Initializing cgroup subsys pids
[ 0.009596] ftrace: allocating 50687 entries in 198 pages
[ 0.131198] sched-energy: Sched-energy-costs installed from DT
[ 0.131763] CPU0: update cpu_capacity 401
[ 0.132206] ASID allocator initialised with 32768 entries
[ 0.135848] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.137167] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.139355] Detected VIPT I-cache on CPU1
[ 0.139385] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.139409] CPU1: using LPI pending table @0x000000007d0c0000
[ 0.139447] CPU1: update cpu_capacity 401
[ 0.139451] CPU1: Booted secondary processor [410fd034]
[ 0.139986] Detected VIPT I-cache on CPU2
[ 0.140007] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.140029] CPU2: using LPI pending table @0x000000007d0f0000
[ 0.140054] CPU2: update cpu_capacity 401
[ 0.140057] CPU2: Booted secondary processor [410fd034]
[ 0.140594] Detected VIPT I-cache on CPU3
[ 0.140614] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.140636] CPU3: using LPI pending table @0x000000007d140000
[ 0.140661] CPU3: update cpu_capacity 401
[ 0.140664] CPU3: Booted secondary processor [410fd034]
[ 0.141202] Detected PIPT I-cache on CPU4
[ 0.141226] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.141259] CPU4: using LPI pending table @0x000000007d170000
[ 0.141294] CPU4: update cpu_capacity 1024
[ 0.141297] CPU4: Booted secondary processor [410fd082]
[ 0.141832] Detected PIPT I-cache on CPU5
[ 0.141850] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.141881] CPU5: using LPI pending table @0x000000007d1b0000
[ 0.141906] CPU5: update cpu_capacity 1024
[ 0.141910] CPU5: Booted secondary processor [410fd082]
[ 0.141992] Brought up 6 CPUs
[ 0.154338] SMP: Total of 6 processors activated.
[ 0.154788] CPU features: detected feature: GIC system register CPU interface
[ 0.155476] CPU features: detected feature: 32-bit EL0 Support
[ 0.156035] CPU: All CPU(s) started at EL2
[ 0.156459] alternatives: patching kernel code
[ 0.158227] devtmpfs: initialized
[ 0.176450] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.177393] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.178415] xor: measuring software checksum speed
[ 0.188203] 8regs : 2856.000 MB/sec
[ 0.198256] 8regs_prefetch: 2552.000 MB/sec
[ 0.208309] 32regs : 3204.000 MB/sec
[ 0.218362] 32regs_prefetch: 2848.000 MB/sec
[ 0.218804] xor: using function: 32regs (3204.000 MB/sec)
[ 0.219342] pinctrl core: initialized pinctrl subsystem
[ 0.221509] Failed to find legacy iommu devices
[ 0.222296] NET: Registered protocol family 16
[ 0.227877] cpuidle: using governor ladder
[ 0.231885] cpuidle: using governor menu
[ 0.232278] Registered FIQ tty driver
[ 0.233109] vdso: 2 pages (1 code @ ffffff8008e36000, 1 data @ ffffff80094a4000)
[ 0.233834] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.234898] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.259161] console [pstore-1] enabled
[ 0.259523] pstore: Registered ramoops as persistent store backend
[ 0.260121] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.263173] console [ttyFIQ0] enabled
[ 0.263851] bootconsole [uart0] disabled
[ 0.264782] Registered fiq debugger ttyFIQ0
[ 0.312954] raid6: int64x1 gen() 468 MB/s
[ 0.330007] raid6: int64x1 xor() 410 MB/s
[ 0.347139] raid6: int64x2 gen() 675 MB/s
[ 0.364200] raid6: int64x2 xor() 595 MB/s
[ 0.381254] raid6: int64x4 gen() 976 MB/s
[ 0.398374] raid6: int64x4 xor() 666 MB/s
[ 0.415494] raid6: int64x8 gen() 781 MB/s
[ 0.432518] raid6: int64x8 xor() 630 MB/s
[ 0.449644] raid6: neonx1 gen() 964 MB/s
[ 0.466712] raid6: neonx1 xor() 664 MB/s
[ 0.483797] raid6: neonx2 gen() 1273 MB/s
[ 0.500892] raid6: neonx2 xor() 998 MB/s
[ 0.517973] raid6: neonx4 gen() 1726 MB/s
[ 0.535077] raid6: neonx4 xor() 1197 MB/s
[ 0.552175] raid6: neonx8 gen() 1695 MB/s
[ 0.569252] raid6: neonx8 xor() 1259 MB/s
[ 0.569636] raid6: using algorithm neonx4 gen() 1726 MB/s
[ 0.570118] raid6: … xor() 1197 MB/s, rmw enabled
[ 0.570559] raid6: using intx1 recovery algorithm
[ 0.575782] iommu: Adding device ff650000.vpu_service to group 0
[ 0.576402] iommu: Adding device ff660000.rkvdec to group 1
[ 0.577004] iommu: Adding device ff8f0000.vop to group 2
[ 0.577573] iommu: Adding device ff900000.vop to group 3
[ 0.578134] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.578727] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.579707] rk_iommu ff650800.iommu: can’t get sclk
[ 0.580384] rk_iommu ff660480.iommu: can’t get sclk
[ 0.581032] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.581622] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.582221] rk_iommu ff914000.iommu: can’t get sclk
[ 0.582814] rk_iommu ff924000.iommu: can’t get sclk
[ 0.583614] SCSI subsystem initialized
[ 0.584302] usbcore: registered new interface driver usbfs
[ 0.584827] usbcore: registered new interface driver hub
[ 0.585388] usbcore: registered new device driver usb
[ 0.585903] media: Linux media interface: v0.10
[ 0.586349] Linux video capture interface: v2.00
[ 0.586832] pps_core: LinuxPPS API ver. 1 registered
[ 0.587274] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.588100] PTP clock support registered
[ 0.589576] Advanced Linux Sound Architecture Driver Initialized.
[ 0.590576] Bluetooth: Core ver 2.21
[ 0.590923] NET: Registered protocol family 31
[ 0.591329] Bluetooth: HCI device and connection manager initialized
[ 0.591903] Bluetooth: HCI socket layer initialized
[ 0.592347] Bluetooth: L2CAP socket layer initialized
[ 0.592817] Bluetooth: SCO socket layer initialized
[ 0.593744] nfc: nfc_init: NFC Core ver 0.1
[ 0.594151] NET: Registered protocol family 39
[ 0.594663] rockchip-cpuinfo cpuinfo: Serial : 8872ea202ee31427
[ 0.595942] clocksource: Switched to clocksource arch_sys_counter
[ 0.647188] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.648098] NET: Registered protocol family 2
[ 0.648879] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.649663] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.650711] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.651366] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.651992] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.652806] NET: Registered protocol family 1
[ 0.653478] RPC: Registered named UNIX socket transport module.
[ 0.654017] RPC: Registered udp transport module.
[ 0.654436] RPC: Registered tcp transport module.
[ 0.654854] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.656664] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.657487] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.660987] audit: initializing netlink subsys (disabled)
[ 0.661488] audit: type=2000 audit(0.573:1): initialized
[ 0.662366] Initialise system trusted keyring
[ 0.670690] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.672029] NFS: Registering the id_resolver key type
[ 0.672500] Key type id_resolver registered
[ 0.672874] Key type id_legacy registered
[ 0.673262] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.674548] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.675329] fuse init (API version 7.23)
[ 0.676032] SGI XFS with security attributes, no debug enabled
[ 0.681886] NET: Registered protocol family 38
[ 0.682316] Key type asymmetric registered
[ 0.682684] Asymmetric key parser ‘x509’ registered
[ 0.683278] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.684077] io scheduler noop registered
[ 0.684434] io scheduler deadline registered
[ 0.684849] io scheduler cfq registered (default)
[ 0.686788] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 0.692011] ace test_init function.
[ 0.692500] ace test_init end.ret=0
[ 0.693194] radar end.ret=0
[ 0.695910] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.696520] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.697123] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.697692] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 0.698307] PCI host bridge /pcie@f8000000 ranges:
[ 0.698750] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 0.699215] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 1.240997] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.241610] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.242366] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.243853] Module initialized.
[ 1.244606] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.245469] rk-vcodec ff650000.vpu_service: probe device
[ 1.246197] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.247327] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.247962] rk-vcodec ff650000.vpu_service: init success
[ 1.248716] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.249656] rk-vcodec ff660000.rkvdec: probe device
[ 1.250284] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.251233] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.251814] rk-vcodec ff660000.rkvdec: init success
[ 1.253668] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.254357] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.256630] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.257330] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.259168] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.260377] pwm-regulator: supplied by vcc5v0_sys
[ 1.261485] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.262644] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.263955] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.266413] [drm] Initialized drm 1.1.0 20060810
[ 1.270760] [drm] Rockchip DRM driver version: v1.0.1
[ 1.273369] mali ff9a0000.gpu: Failed to get regulator
[ 1.273824] mali ff9a0000.gpu: Power control initialization failed
[ 1.274725] Unable to detect cache hierarchy for CPU 0
[ 1.275991] brd: module loaded
[ 1.281536] loop: module loaded
[ 1.282391] zram: Added device: zram0
[ 1.283008] lkdtm: No crash points registered, enable through debugfs
[ 1.283943] Loading dl1825 driver
[ 1.285834] register spi return v = :0
[ 1.286669] tun: Universal TUN/TAP device driver, 1.6
[ 1.287136] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.288636] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.289357] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.289997] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.290499] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.291020] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.291729] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.292351] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.297903] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.298524] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.298986] Ring mode enabled
[ 1.299267] DMA HW capability register supported
[ 1.299673] Normal descriptors
[ 1.299985] RX Checksum Offload Engine supported (type 2)
[ 1.300472] Wake-Up On Lan supported
[ 1.300830] Enable RX Mitigation via HW Watchdog Timer
[ 1.366220] libphy: stmmac: probed
[ 1.366530] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.367135] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.368954] usbcore: registered new interface driver rtl8192cu
[ 1.369525] usbcore: registered new interface driver rndis_wlan
[ 1.370293] usbcore: registered new interface driver mt7601u
[ 1.370844] Rockchip WiFi SYS interface (V1.00) …
[ 1.371363] usbcore: registered new interface driver rtl8150
[ 1.371900] usbcore: registered new interface driver r8152
[ 1.372437] usbcore: registered new interface driver asix
[ 1.372955] usbcore: registered new interface driver ax88179_178a
[ 1.373534] usbcore: registered new interface driver cdc_ether
[ 1.374103] usbcore: registered new interface driver rndis_host
[ 1.374678] usbcore: registered new interface driver cdc_ncm
[ 1.375222] usbcore: registered new interface driver qmi_wwan
[ 1.375764] usbcore: registered new interface driver cdc_mbim
[ 1.377626] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.382437] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 1.384145] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.384736] ehci-pci: EHCI PCI platform driver
[ 1.385199] ehci-platform: EHCI generic platform driver
[ 1.389506] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.390202] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.391007] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.396962] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.397654] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.398273] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.398912] usb usb1: Product: EHCI Host Controller
[ 1.399354] usb usb1: Manufacturer: Linux 4.4.194+ ehci_hcd
[ 1.399854] usb usb1: SerialNumber: fe3c0000.usb
[ 1.400748] hub 1-0:1.0: USB hub found
[ 1.401130] hub 1-0:1.0: 1 port detected
[ 1.402031] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.402589] ohci-platform: OHCI generic platform driver
[ 1.403542] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.404317] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.405118] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.460108] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.460713] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.461363] usb usb2: Product: Generic Platform OHCI controller
[ 1.461887] usb usb2: Manufacturer: Linux 4.4.194+ ohci_hcd
[ 1.462394] usb usb2: SerialNumber: fe3e0000.usb
[ 1.463246] hub 2-0:1.0: USB hub found
[ 1.463609] hub 2-0:1.0: 1 port detected
[ 1.464908] usbcore: registered new interface driver cdc_acm
[ 1.465426] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.466179] usbcore: registered new interface driver cdc_wdm
[ 1.466716] usbcore: registered new interface driver uas
[ 1.467273] usbcore: registered new interface driver usb-storage
[ 1.467881] usbcore: registered new interface driver usbserial
[ 1.468444] usbcore: registered new interface driver usbserial_generic
[ 1.469056] usbserial: USB Serial support registered for generic
[ 1.469624] usbcore: registered new interface driver ch341
[ 1.470143] usbserial: USB Serial support registered for ch341-uart
[ 1.470732] usbcore: registered new interface driver cp210x
[ 1.471263] usbserial: USB Serial support registered for cp210x
[ 1.471833] usbcore: registered new interface driver ftdi_sio
[ 1.472376] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.473116] usbcore: registered new interface driver keyspan
[ 1.473636] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.474361] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.475039] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.475706] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.476402] usbcore: registered new interface driver option
[ 1.476921] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.477652] usbcore: registered new interface driver oti6858
[ 1.478184] usbserial: USB Serial support registered for oti6858
[ 1.478751] usbcore: registered new interface driver pl2303
[ 1.479280] usbserial: USB Serial support registered for pl2303
[ 1.479841] usbcore: registered new interface driver qcserial
[ 1.480386] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.481054] usbcore: registered new interface driver sierra
[ 1.481573] usbserial: USB Serial support registered for Sierra USB modem
[ 1.483239] usbcore: registered new interface driver usbtouchscreen
[ 1.484100] .. rk pwm remotectl v1.1 init
[ 1.484692] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.485738] sensor_register_slave:mma8452,id=17
[ 1.486169] sensor_register_slave:lis3dh,id=7
[ 1.486559] sensor_register_slave:mma7660,id=18
[ 1.486979] sensor_register_slave:lsm303d,id=22
[ 1.487389] sensor_register_slave:gs_mc3230,id=23
[ 1.487807] [Gsensor] gsensor_init
[ 1.488139] sensor_register_slave:mpu6880_acc,id=24
[ 1.488575] sensor_register_slave:mpu6500_acc,id=25
[ 1.489018] sensor_register_slave:lsm330_acc,id=26
[ 1.489452] sensor_register_slave:akm8975,id=30
[ 1.489863] sensor_register_slave:akm8963,id=31
[ 1.490281] sensor_register_slave:l3g4200d,id=45
[ 1.490693] sensor_register_slave:l3g20d,id=46
[ 1.491102] sensor_register_slave:ewtsa,id=47
[ 1.491490] sensor_register_slave:lsm330_gyro,id=51
[ 1.491925] sensor_register_slave:cm3217,id=53
[ 1.492333] sensor_register_slave:cm3218,id=54
[ 1.493202] i2c /dev entries driver
[ 1.494730] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.495414] fan53555-reg: supplied by vcc5v0_sys
[ 1.497924] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.498629] fan53555-reg: supplied by vcc5v0_sys
[ 1.501219] rk808 0-001b: Pmic Chip id: 0x0
[ 1.504626] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.505246] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.505878] DCDC_REG1: supplied by vcc3v3_sys
[ 1.507027] DCDC_REG2: supplied by vcc3v3_sys
[ 1.507996] DCDC_REG3: supplied by vcc3v3_sys
[ 1.508666] DCDC_REG4: supplied by vcc3v3_sys
[ 1.509516] LDO_REG1: supplied by vcc3v3_sys
[ 1.511053] LDO_REG2: supplied by vcc3v3_sys
[ 1.512420] LDO_REG3: supplied by vcc3v3_sys
[ 1.513788] LDO_REG4: supplied by vcc3v3_sys
[ 1.515185] LDO_REG5: supplied by vcc3v3_sys
[ 1.516550] LDO_REG6: supplied by vcc3v3_sys
[ 1.517926] LDO_REG7: supplied by vcc3v3_sys
[ 1.519312] LDO_REG8: supplied by vcc3v3_sys
[ 1.520682] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.521404] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.525142] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.526248] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009af2000
[ 1.527710] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009af4000
[ 1.529572] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 1.539330] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.540282] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input1
[ 1.541206] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009af6000
[ 1.543111] IR NEC protocol handler initialized
[ 1.544311] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 1.544898] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 1.546967] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.05
[ 1.547553] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 1.549502] usbcore: registered new interface driver npu_acm
[ 1.550088] usbcore: registered new interface driver uvcvideo
[ 1.550598] USB Video Class driver (1.1.1)
[ 1.552809] Boot mode: normal
[ 1.554581] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.555523] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 1.557127] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.558049] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.a2fd257.20190430-133301
[ 1.558721] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 1.559188] rtk_btcoex: create workqueue
[ 1.559537] rtk_btcoex: Coex over UDP
[ 1.560135] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 1.560721] usbcore: registered new interface driver rtk_btusb
[ 1.561260] Bluetooth: Virtual HCI driver ver 1.5
[ 1.561795] Bluetooth: HCI UART driver ver 2.3
[ 1.562207] Bluetooth: HCI UART protocol H4 registered
[ 1.562661] Bluetooth: HCI UART protocol LL registered
[ 1.563122] Bluetooth: HCI UART protocol ATH3K registered
[ 1.563645] usbcore: registered new interface driver bfusb
[ 1.564201] usbcore: registered new interface driver btusb
[ 1.565161] cpu cpu0: bin=1
[ 1.565469] cpu cpu0: leakage=14
[ 1.577864] cpu cpu0: temp=48750, pvtm=136872 (136410 + 462)
[ 1.578603] cpu cpu0: pvtm-volt-sel=0
[ 1.578998] cpu cpu0: bin-scale=34
[ 1.579575] cpu cpu4: bin=1
[ 1.579882] cpu cpu4: leakage=24
[ 1.593033] cpu cpu4: temp=46875, pvtm=142872 (142697 + 175)
[ 1.594622] cpu cpu4: pvtm-volt-sel=0
[ 1.595012] cpu cpu4: bin-scale=17
[ 1.596407] cpu cpu0: avs=0
[ 1.596762] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.597921] cpu cpu0: failed to find power_model node
[ 1.599312] cpu cpu4: avs=0
[ 1.599667] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.601134] cpu cpu4: failed to find power_model node
[ 1.602430] sdhci: Secure Digital Host Controller Interface driver
[ 1.603001] sdhci: Copyright(c) Pierre Ossman
[ 1.603391] Synopsys Designware Multimedia Card Interface Driver
[ 1.604771] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.605448] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.606066] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.606618] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.607505] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.608312] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.608858] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.610322] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.610992] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.611600] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.612152] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.613025] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.614180] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.614987] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.628203] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.641880] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.643060] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.645771] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.646321] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.675134] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.677028] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.677899] usbcore: registered new interface driver usbhid
[ 1.678421] usbhid: USB HID core driver
[ 1.678904] inv_mpu_iio: inv_mpu_init:746
[ 1.682861] usbcore: registered new interface driver snd-usb-audio
[ 1.684830] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.685472] rt5640 1-001c: Can not read property hp_det_gpio
[ 1.685983] rt5640 1-001c: Can not read property: linein-mute.
[ 1.702985] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.704643] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 1.705355] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 1.706320] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.707414] IPVS: Registered protocols (TCP, UDP)
[ 1.707875] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 1.708660] IPVS: Creating netns size=2104 id=0
[ 1.709122] IPVS: ipvs loaded.
[ 1.709413] IPVS: [rr] scheduler registered.
[ 1.710211] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.710791] Initializing XFRM netlink socket
[ 1.712096] NET: Registered protocol family 10
[ 1.713581] NET: Registered protocol family 17
[ 1.714031] NET: Registered protocol family 15
[ 1.714466] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.715793] Bridge firewalling registered
[ 1.716390] Bluetooth: RFCOMM socket layer initialized
[ 1.716921] Bluetooth: RFCOMM ver 1.11
[ 1.717295] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.717824] Bluetooth: HIDP socket layer initialized
[ 1.718344] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.719300] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.719831] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.720473] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.721145] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.721908] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.722754] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.723475] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.723965] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.724502] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.725696] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property wifi-bt-power-toggle.
[ 1.726492] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.727324] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 115.
[ 1.728108] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.728847] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.729593] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.730789] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.731387] [BT_RFKILL]: ** disable irq
[ 1.731417] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.732526] [BT_RFKILL]: bt_default device registered.
[ 1.732600] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 1.733552] Key type dns_resolver registered
[ 1.733566] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 1.734350] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 1.735220] sensor_register_slave:mpu6880_gyro,id=50
[ 1.735229] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 1.736865] ov13850 1-0036: driver version: 00.01.03
[ 1.740132] ov13850 1-0036: write SCCB_ID failed
[ 1.740485] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 1.741167] ov13850: probe of 1-0036 failed with error -5
[ 1.742138] ov13850 1-0046: driver version: 00.01.03
[ 1.745804] ov13850 1-0046: write SCCB_ID failed
[ 1.746449] ov13850: probe of 1-0046 failed with error -5
[ 1.748066] Registered cp15_barrier emulation handler
[ 1.748601] Registered setend emulation handler
[ 1.749890] Loading compiled-in X.509 certificates
[ 1.753094] Btrfs loaded
[ 1.754989] rga2: Driver loaded successfully ver:3.02
[ 1.755932] rga2: Module initialized.
[ 1.758051] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator
[ 1.762064] rockchip-drm display-subsystem: dmc is disabled
[ 1.763155] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.764223] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008ef40f0)
[ 1.765034] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.765987] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008ef40f0)
[ 1.767513] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.768197] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.769124] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.773204] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ee8948)
[ 1.774640] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 1.775789] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008ee9978)
[ 1.776531] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.777133] [drm] No driver support for vblank timestamp query.
[ 1.778000] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.778734] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.779399] rockchip-drm display-subsystem: failed to show loader logo
[ 1.779706] fusb302 4-0022: CC connected in CC1 as UFP
[ 1.780660] Freeing drm_logo memory: 616K
[ 1.781067] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.781775] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.795616] Console: switching to colour frame buffer device 128x48
[ 1.802229] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.808830] mali ff9a0000.gpu: leakage=17
[ 1.817655] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.818282] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.818920] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.820026] hub 1-1:1.0: USB hub found
[ 1.820463] hub 1-1:1.0: 7 ports detected
[ 1.822442] mali ff9a0000.gpu: temp=46875, pvtm=116661 (116601 + 60)
[ 1.824072] mali ff9a0000.gpu: pvtm-volt-sel=0
[ 1.825178] mali ff9a0000.gpu: avs=0
[ 1.826310] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.827295] mali ff9a0000.gpu: Protected mode not available
[ 1.828536] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.829286] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 1.830416] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.832407] mali ff9a0000.gpu: Probed as mali0
[ 1.838033] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.838755] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 1.839607] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.840445] xhci-hcd xhci-hcd.10.auto: irq 229, io mem 0xfe800000
[ 1.841279] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.841886] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.842545] usb usb3: Product: xHCI Host Controller
[ 1.842993] usb usb3: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 1.843494] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 1.844528] hub 3-0:1.0: USB hub found
[ 1.844902] hub 3-0:1.0: 1 port detected
[ 1.845697] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.846388] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 1.847167] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.848081] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.848688] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.849345] usb usb4: Product: xHCI Host Controller
[ 1.849779] usb usb4: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 1.850293] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 1.851321] hub 4-0:1.0: USB hub found
[ 1.851692] hub 4-0:1.0: 1 port detected
[ 1.853880] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.854399] usb usb4: USB disconnect, device number 1
[ 1.858364] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.859122] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 5
[ 1.859974] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.860798] xhci-hcd xhci-hcd.11.auto: irq 230, io mem 0xfe900000
[ 1.861652] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.862276] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.862915] usb usb5: Product: xHCI Host Controller
[ 1.863361] usb usb5: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 1.863862] usb usb5: SerialNumber: xhci-hcd.11.auto
[ 1.864906] hub 5-0:1.0: USB hub found
[ 1.865294] hub 5-0:1.0: 1 port detected
[ 1.866023] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.866721] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 6
[ 1.867498] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.868382] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.869003] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.869641] usb usb6: Product: xHCI Host Controller
[ 1.870095] usb usb6: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 1.870593] usb usb6: SerialNumber: xhci-hcd.11.auto
[ 1.871540] hub 6-0:1.0: USB hub found
[ 1.871621] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 1.871627] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 1.871697] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[ 1.873748] hub 6-0:1.0: 1 port detected
[ 1.874720] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.875229] usb usb3: USB disconnect, device number 1
[ 1.876346] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[ 1.877002] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.877675] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 3
[ 1.878492] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.884960] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.885691] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.886307] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.886952] usb usb3: Product: EHCI Host Controller
[ 1.887393] usb usb3: Manufacturer: Linux 4.4.194+ ehci_hcd
[ 1.887890] usb usb3: SerialNumber: fe380000.usb
[ 1.888805] hub 3-0:1.0: USB hub found
[ 1.889226] hub 3-0:1.0: 1 port detected
[ 1.890467] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.891256] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 4
[ 1.892062] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.947309] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.947920] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.948569] usb usb4: Product: Generic Platform OHCI controller
[ 1.949111] usb usb4: Manufacturer: Linux 4.4.194+ ohci_hcd
[ 1.949609] usb usb4: SerialNumber: fe3a0000.usb
[ 1.950624] hub 4-0:1.0: USB hub found
[ 1.951044] hub 4-0:1.0: 1 port detected
[ 1.952886] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.953567] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.954185] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.954716] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.955611] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.956427] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.956991] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.957926] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.971372] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.985116] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.987093] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 2.001724] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 2.007751] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input2
[ 2.010908] rockchip-cdndp-sound dp-sound: spdif-hifi ↔ ff870000.spdif mapping ok
[ 2.011680] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 2.013722] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card2/input3
[ 2.015743]
[ 2.015755] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 2.015763] ======== dhd_wlan_init_plat_data ========
[ 2.015768] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.015781] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=70, oob_irq_flags=0x414
[ 2.015785] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 2.015789] dhd_wifi_platform_load: Enter
[ 2.015834] Power-up adapter ‘DHD generic adapter’
[ 2.015896] wifi_platform_set_power = 1
[ 2.015901] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.015907] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.015913] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.021131] =======================================================
[ 2.021698] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.022285] =======================================================
[ 2.022852] Realtek 8723DU USB WiFi driver (Powered by Rockchip) init.
[ 2.023535] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.023994] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.024423] RTW: module init start
[ 2.024739] RTW: rtl8723du v5.6.5.1_34252.20190703_COEX20181130-2e2e
[ 2.025330] RTW: build time: Sep 8 2021 15:53:43
[ 2.025760] RTW: rtl8723du BT-Coex version = COEX20181130-2e2e
[ 2.026794] usbcore: registered new interface driver rtl8723du
[ 2.027387] RTW: module init ret=0
[ 2.029723] input: gpio-keys as /devices/platform/gpio-keys/input/input4
[ 2.044300] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.046463] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.048655] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.052756] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.057424] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.059366] phy phy-ff770000.syscon:usb2-phy@e450.7: charger = USB_CDP_CHARGER
[ 2.063909] rockchip-dwc3 usb0: USB peripheral connected
[ 2.100041] usb 1-1.2: new low-speed USB device number 3 using ehci-platform
[ 2.114354] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 2.116718] ==gsl_ts_init==
[ 2.117362] ret=0
[ 2.119335] rk808-rtc rk808-rtc: setting system clock to 2021-09-10 07:19:12 UTC (1631258352)
[ 2.158085] vcc_sd: disabling
[ 2.158370] vcc_mipi: disabling
[ 2.158652] dvdd_1v2: disabling
[ 2.159645] ret 1024
[ 2.160611] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_.
[ 2.162818] Mali: Mali device driver loaded
[ 2.163448] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 2.164610] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 2.165178] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 2.165730] rkisp1: update sensor failed
[ 2.166093] rkisp1 ff920000.rkisp1: clear unready subdev num: 1
[ 2.167221] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 2.167774] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 2.168330] rkisp1: update sensor failed
[ 2.169280] ALSA device list:
[ 2.169551] #0: rockchip,hdmi
[ 2.169830] #1: rockchip,rt5640-codec
[ 2.170191] #2: rockchip-cdndp-sound
[ 2.170779] Waiting for root device PARTLABEL=rootfs…
[ 2.202739] usb 1-1.2: New USB device found, idVendor=413c, idProduct=2105
[ 2.203422] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.204095] usb 1-1.2: Product: Dell USB Keyboard
[ 2.204522] usb 1-1.2: Manufacturer: Dell
[ 2.223977] input: Dell Dell USB Keyboard as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:413C:2105.0001/input/input5
[ 2.239454] vendor storage:20190527 ret = 0
[ 2.259270] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 210
[ 2.268422] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.268985] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.277922] hid-generic 0003:413C:2105.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-fe3c0000.usb-1.2/input0
[ 2.317030] wifi_platform_bus_enumerate device present 1
[ 2.317512] ======== Card detection to detect SDIO card! ========
[ 2.318114] mmc2:mmc host rescan start!
[ 2.334612] bcmsdh_register: register client driver
[ 2.335595] bcmsdh_sdmmc_probe: Enter num=1
[ 2.336303] bcmsdh_sdmmc_probe: Enter num=2
[ 2.336694] bus num (host idx)=2, slot num (rca)=1
[ 2.337184] found adapter info ‘DHD generic adapter’
[ 2.337715] sdioh_attach: set sd_f2_blocksize 256
[ 2.338221] sdioh_attach: sd clock rate = 0
[ 2.338885] dhdsdio_probe : no mutex held. set lock
[ 2.339482] F1 signature read @0x18000000=0x17224356
[ 2.345081] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 2.346395] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.347155] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 2.348108] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 2.350017] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 2.350908] wl_escan_attach: Enter
[ 2.351296] wl_escan_init: Enter
[ 2.352370] wl_create_event_handler(): thread:wl_escan_handler:ac started
[ 2.353310] tsk Enter, tsk = 0xffffffc07ac901b0
[ 2.353826] dhd_attach(): thread:dhd_watchdog_thread:ad started
[ 2.355099] dhd_attach(): thread:dhd_dpc:ae started
[ 2.356266] dhd_attach(): thread:dhd_rxf:af started
[ 2.356736] dhd_deferred_work_init: work queue initialized
[ 2.357344] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 2.357991] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 2.358714] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[ 2.367618] Dongle Host Driver, version 1.579.77.41.10 (r)
[ 2.369025] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[ 2.369523] Register interface [wlan0] MAC: d4:12:43:c2:f3:e0
[ 2.369523]
[ 2.370477] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 2.371094] dhd_wl_ioctl: returning as busstate=0
[ 2.371518] dhd_dbg_detach_pkt_monitor, 2204
[ 2.371906] dhd_bus_devreset: == Power OFF ==
[ 2.372546] bcmsdh_oob_intr_unregister: Enter
[ 2.372996] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.373518] dhd_txglom_enable: enable 0
[ 2.373872] dhd_conf_set_txglom_params: txglom_mode=copy
[ 2.374370] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 2.374979] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[ 2.375584] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[ 2.376214] dhd_bus_devreset: WLAN OFF DONE
[ 2.376662] wifi_platform_set_power = 0
[ 2.377098] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.377566] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.378043] [WLAN_RFKILL]: wifi shut off power.
[ 2.378454] dhdsdio_probe : the lock is released.
[ 2.378982] dhd_module_init: Exit err=0
[ 17.404179] random: nonblocking pool is initialized
是网络起不来?
