怎么我只是替换rootfs,从buildroot换成debian,跑步起来呢,要跑debian需要改哪些...
log如下:
[175033][ 1.230038] #1: rockchip,nvp6188-sound
[175033][ 1.230053] #7: Loopback 1
[175033][ 1.231053] dwmmc_rockchip ffc50000.dwmmc: error -110 requesting status
[175033][ 1.231142] mmc0: cache flush error -110
[175033][ 1.244527] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[175033][ 1.311018] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[175033][ 1.311128] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 180
[175033][ 1.322346] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[175033][ 1.322457] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[175033][ 1.339441] devtmpfs: mounted
[175033][ 1.341664] Freeing unused kernel memory: 1024K
[175033][ 1.342005] Run /sbin/init as init process
[175033][ 1.478578] vendor storage:20190527 ret = 0
[175033][ 1.658396] systemd[1]: Failed to lookup module alias ‘autofs4’: Function not implemented
[175033][ 1.660277] systemd[1]: Failed to mount tmpfs at /sys/fs/cgroup: No such file or directory
[175033][ 1.661070] systemd[1]: Failed to mount cgroup at /sys/fs/cgroup/systemd: No such file or directory
[175033][ 1.667937] systemd[1]: Freezing execution.
[175033][ 1.894638] phy phy-ff4c0000.usb2-phy.1: charger = USB_CDP_CHARGER
分区表改了吗
799959745 发表于 2021-9-14 09:01
分区表改了吗
改了。
参考:https://wiki.t-firefly.com/zh_CN/CORE-1126-JD4/Debian10.html
晕!
同问
楼主成功了吗?同问
刷机的详细步骤请看这个帖子: https://dev.t-firefly.com/thread-123755-1-1.html
