DDR Version 1.24 20191016
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 MHz, current 856MHz
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 346
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 69373
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x2000, size:0x2000
GPT part: 1, name: trust, start:0x4000, size:0x2000
GPT part: 2, name: misc, start:0x6000, size:0x2000
GPT part: 3, name: dtbo, start:0xc000, size:0x2000
GPT part: 4, name: vbmeta, start:0xe000, size:0x800
GPT part: 5, name: resource, start:0x8000, size:0x8000
GPT part: 6, name: kernel, start:0x10000, size:0xc000
GPT part: 7, name: boot, start:0xe800, size:0x10000
GPT part: 8, name: recovery, start:0x1e800, size:0x30000
GPT part: 9, name: backup, start:0x4e800, size:0x38000
GPT part: 10, name: security, start:0x86800, size:0x2000
GPT part: 11, name: cache, start:0x88800, size:0xc0000
GPT part: 12, name: metadata, start:0x148800, size:0x8000
GPT part: 13, name: frp, start:0x150800, size:0x400
GPT part: 14, name: super, start:0x150c00, size:0x714000
GPT part: 15, name: oem, start:0x864c00, size:0x100000
GPT part: 16, name: userdata, start:0x964c00, size:0x52b3df
find part:uboot OK. first_lba:0x2000.
find part:trust OK. first_lba:0x4000.
Trust Addr:0x4000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xfb1c8
RunBL31 0x40000 @ 117026 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #1 Mon Aug 17 09:23:30 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Aug 31 2021 - 17:48:37 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbc8000, fdt: 7bdbc358
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
Android 10.0, Build 2020.11
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
ANDROID: fdt overlay OK
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1000000 uV
Model: ROC-RK3399-PC-PLUS HDMI+DP(Android)
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
optee api revision: 2.0
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_slot_verify.c:757: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
get image from preloaded partition…
Could not find “system” partition
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 25789 KiB
RAM disk load addr 0x0a200000 size 7949 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
Using Device Tree in place at 0000000008300000, end 000000000831da47
Total: 753.264 ms
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.111 (le@le-desktop) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #5 SMP PREEMPT Fri Sep 10 15:18:21 CST 2021
[ 0.000000] Machine model: ROC-RK3399-PC-PLUS HDMI+DP(Android)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff1a0000 (options ‘’)
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘stb-devinfo@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 23 pages/cpu s57304 r8192 d28712 u94208
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 507912
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtbo_idx=0 androidboot.verifiedbootstate=orange androidboot.slot_suffix= androidboot.serialno=WUH5KZZ0G9 console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.wificountrycode=US androidboot.veritymode=enforcing androidboot.hardware=rk30board androidboot.console=ttyFIQ0 firmware_class.path=/vendor/etc/firmware init=/init root=PARTUUID=af01642c-9b84-11e8-9b2a-234eb5e198a0 earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m androidboot.boot_devices=fe330000.sdhci,fe320000.dwmmc
[ 0.000000] Memory: 1972684K/2064384K available (14334K kernel code, 1788K rwdata, 5664K rodata, 3968K init, 2243K bss, 75316K reserved, 16384K cma-reserved)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @7b880000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007b820000
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] CPU0: using LPI pending table @0x000000007b830000
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x4ec with crng_init=0
[ 0.002034] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003019] pid_max: default: 32768 minimum: 301
[ 0.003583] Security Framework initialized
[ 0.003977] SELinux: Initializing.
[ 0.004439] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005083] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.007327] ASID allocator initialised with 32768 entries
[ 0.007952] rcu: Hierarchical SRCU implementation.
[ 0.008822] Platform MSI: interrupt-controller@fee20000 domain created
[ 0.009965] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.011619] smp: Bringing up secondary CPUs …
[ 0.012684] Detected VIPT I-cache on CPU1
[ 0.012720] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.012758] CPU1: using LPI pending table @0x000000007ba10000
[ 0.012803] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.013691] Detected VIPT I-cache on CPU2
[ 0.013726] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.013764] CPU2: using LPI pending table @0x000000007ba70000
[ 0.013808] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.014629] Detected VIPT I-cache on CPU3
[ 0.014662] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.014700] CPU3: using LPI pending table @0x000000007ba80000
[ 0.014743] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.015603] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.015609] CPU features: enabling workaround for EL2 vector hardening
[ 0.015618] Detected PIPT I-cache on CPU4
[ 0.015643] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.015693] CPU4: using LPI pending table @0x000000007bae0000
[ 0.015722] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[ 0.016439] Detected PIPT I-cache on CPU5
[ 0.016466] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.016517] CPU5: using LPI pending table @0x000000007baf0000
[ 0.016546] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.016655] smp: Brought up 1 node, 6 CPUs
[ 0.029265] SMP: Total of 6 processors activated.
[ 0.029715] CPU features: detected: GIC system register CPU interface
[ 0.030339] CPU features: detected: 32-bit EL0 Support
[ 0.037015] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.037821] CPU: All CPU(s) started at EL2
[ 0.038255] alternatives: patching kernel code
[ 0.040173] devtmpfs: initialized
[ 0.054591] Trying to unpack rootfs image as initramfs…
[ 0.055108] Registered cp15_barrier emulation handler
[ 0.055122] Registered setend emulation handler
[ 0.055477] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.056939] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.057923] pinctrl core: initialized pinctrl subsystem
[ 0.059030] NET: Registered protocol family 16
[ 0.060162] schedtune: configured to support 6 boost groups
[ 0.060917] audit: initializing netlink subsys (disabled)
[ 0.062125] audit: type=2000 audit(0.055:1): state=initialized audit_enabled=0 res=1
[ 0.062885] cpuidle: using governor menu
[ 0.063272] Registered FIQ tty driver
[ 0.064070] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.072800] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.075194] console [pstore-1] enabled
[ 0.075673] pstore: Registered ramoops as persistent store backend
[ 0.076266] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.106694] cryptd: max_cpu_qlen set to 1000
[ 0.107864] fiq debugger fiq mode enabled
[[ 0.108459] console [ttyFIQ0] enabled
[ 0.109149] bootconsole [uart8250] disabled
[ 0.109756] Registered fiq debugger ttyFIQ0
[ 0.111062] vcc_sys: supplied by dc_12v
[ 0.113352] rk_iommu ff650800.iommu: version = 1
[ 0.113786] rk_iommu ff660480.iommu: version = 1
[ 0.114050] rk_iommu ff670800.iommu: version = 1
[ 0.114344] rk_iommu ff8f3f00.iommu: version = 1
[ 0.114580] rk_iommu ff903f00.iommu: version = 1
[ 0.114820] rk_iommu ff914000.iommu: version = 1
[ 0.115071] rk_iommu ff924000.iommu: version = 1
[ 0.115603] SCSI subsystem initialized
[ 0.115956] usbcore: registered new interface driver usbfs
[ 0.116019] usbcore: registered new interface driver hub
[ 0.116104] usbcore: registered new device driver usb
[ 0.116363] media: Linux media interface: v0.10
[ 0.116397] videodev: Linux video capture interface: v2.00
[ 0.116451] pps_core: LinuxPPS API ver. 1 registered
[ 0.116465] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.116485] PTP clock support registered
[ 0.118213] Advanced Linux Sound Architecture Driver Initialized.
[ 0.118544] Bluetooth: Core ver 2.22
[ 0.118583] NET: Registered protocol family 31
[ 0.118618] Bluetooth: HCI device and connection manager initialized
[ 0.118637] Bluetooth: HCI socket layer initialized
[ 0.118650] Bluetooth: L2CAP socket layer initialized
[ 0.118681] Bluetooth: SCO socket layer initialized
[ 0.119046] rockchip-cpuinfo cpuinfo: SoC : 0
[ 0.119065] rockchip-cpuinfo cpuinfo: Serial : 7d9418e5de243167
[ 0.119588] clocksource: Switched to clocksource arch_sys_counter
[ 0.173980] VFS: Disk quotas dquot_6.6.0
[ 0.174056] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.175203] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.183749] NET: Registered protocol family 2
[ 0.184190] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[ 0.184235] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.184373] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.184645] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.184762] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.184820] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.184974] NET: Registered protocol family 1
[ 0.187045] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.187320] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.188797] Initialise system trusted keyrings
[ 0.188969] workingset: timestamp_bits=45 max_order=19 bucket_order=0
[ 0.192749] Registering sdcardfs 0.1
[ 0.193643] fuse init (API version 7.27)
[ 0.194803]
[ 0.194803] TEE Core Framework initialization (ver 1:0.1)
[ 0.194831] TEE armv7 Driver initialization
[ 0.195197] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.195214] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.195383] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.196502] Key type asymmetric registered
[ 0.196518] Asymmetric key parser ‘x509’ registered
[ 0.196554] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.196564] io scheduler noop registered
[ 0.196679] io scheduler cfq registered (default)
[ 0.196692] io scheduler mq-deadline registered
[ 0.196700] io scheduler kyber registered
[ 0.196775] io scheduler bfq registered
[ 0.198445] phy phy-ff770000.syscon:usb2-phy@e460.1: Linked as a consumer to regulator.4
[ 0.198850] phy phy-ff770000.syscon:usb2-phy@e460.2: Failed to get VBUS supply regulator
[ 0.200190] rockchip-mipi-dphy-rx ff770000.syscon:mipi-dphy-rx0: invalid resource
[ 0.203352] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 0.203484] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[ 0.203554] rockchip-pcie f8000000.pcie: Linked as a consumer to regulator.8
[ 0.203597] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.203619] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.203654] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[ 0.203679] rockchip-pcie f8000000.pcie: MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 0.203697] rockchip-pcie f8000000.pcie: IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 0.415108] Freeing initrd memory: 7948K
[ 1.215595] phy phy-ff770000.syscon:pcie-phy.3: pll lock timeout!
[ 1.215616] phy phy-ff770000.syscon:pcie-phy.3: phy poweron failed → -22
[ 1.215630] rockchip-pcie f8000000.pcie: power on phy0 err -22
[ 1.215647] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.215762] rockchip-pcie f8000000.pcie: Dropping the link to regulator.8
[ 1.215858] rockchip-pcie: probe of f8000000.pcie failed with error -22
[ 1.216440] iommu: Adding device ff670000.iep to group 2
[ 1.216462] iep ff670000.iep: Linked as a consumer to ff670800.iommu
[ 1.216677] iep: failed to find iep power down clock source.
[ 1.217062] iep: IEP Power ON
[ 1.217102] iep: IEP Power OFF
[ 1.217121] iep: IEP Driver loaded succesfully
[ 1.217267] iep: Module initialized.
[ 1.217389] mpp_service mpp-srv: probe start
[ 1.217766] iommu: Adding device ff660000.rkvdec to group 1
[ 1.217788] mpp_rkvdec ff660000.rkvdec: Linked as a consumer to ff660480.iommu
[ 1.217961] mpp_rkvdec ff660000.rkvdec: probing start
[ 1.218301] rkvdec_init:1178: failed on clk_get clk_hevc_cabac
[ 1.218366] mpp_rkvdec ff660000.rkvdec: shared_video_hevc_cabac is not found!
[ 1.218374] rkvdec_init:1206: No hevc cabac reset resource define
[ 1.218565] mpp_rkvdec ff660000.rkvdec: probing finish
[ 1.219389] iommu: Adding device ff650400.vdpu to group 0
[ 1.219423] mpp_vdpu2 ff650400.vdpu: Linked as a consumer to ff650800.iommu
[ 1.219610] mpp_vdpu2 ff650400.vdpu: probe device
[ 1.219935] mpp_vdpu2 ff650400.vdpu: reset_group->rw_sem_on=0
[ 1.219960] mpp_vdpu2 ff650400.vdpu: reset_group->rw_sem_on=0
[ 1.220127] mpp_vdpu2 ff650400.vdpu: probing finish
[ 1.220484] iommu: Adding device ff650000.vepu to group 0
[ 1.220513] mpp_vepu2 ff650000.vepu: Linked as a consumer to ff650800.iommu
[ 1.220558] mpp_vepu2 ff650000.vepu: probe device
[ 1.220903] mpp_vepu2 ff650000.vepu: reset_group->rw_sem_on=0
[ 1.220932] mpp_vepu2 ff650000.vepu: reset_group->rw_sem_on=0
[ 1.221081] mpp_vepu2 ff650000.vepu: probing finish
[ 1.221263] mpp_service mpp-srv: probe success
[ 1.223796] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.223820] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.224849] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.224870] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.225932] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.226312] pwm-regulator: supplied by regulator-dummy
[ 1.226852] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.227336] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.229007] random: fast init done
[ 1.229153] iommu: Adding device ff8f0000.vop to group 3
[ 1.229183] rockchip-vop ff8f0000.vop: Linked as a consumer to ff8f3f00.iommu
[ 1.229323] random: crng init done
[ 1.229519] iommu: Adding device ff900000.vop to group 4
[ 1.229547] rockchip-vop ff900000.vop: Linked as a consumer to ff903f00.iommu
[ 1.232605] rockchip-drm display-subsystem: Linked as a consumer to ff8f0000.vop
[ 1.232642] rockchip-drm display-subsystem: Linked as a consumer to ff900000.vop
[ 1.233254] rockchip-drm display-subsystem: Linked as a consumer to fec00000.dp
[ 1.233561] rockchip-drm display-subsystem: Linked as a consumer to ff940000.hdmi
[ 1.237607] mali ff9a0000.gpu: Failed to get regulator
[ 1.237623] mali ff9a0000.gpu: Power control initialization failed
[ 1.237898] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.243277] brd: module loaded
[ 1.255448] loop: module loaded
[ 1.255809] zram: Added device: zram0
[ 1.256375] SCSI Media Changer driver v0.25
[ 1.257451] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.257471] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.257482] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.257830] rockchip-spi ff1d0000.spi: chipselect 0 already in use
[ 1.257847] spi_master spi0: spi_device register error /spi@ff1d0000/spi_wk2xxx@00
[ 1.257862] spi_master spi0: Failed to create SPI device for /spi@ff1d0000/spi_wk2xxx@00
[ 1.258309] register firefly_spi_init spi return v = :0
[ 1.258502] libphy: Fixed MDIO Bus: probed
[ 1.258533] tun: Universal TUN/TAP device driver, 1.6
[ 1.259128] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.259154] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[ 1.259233] rk_gmac-dwmac fe300000.ethernet: Linked as a consumer to regulator.6
[ 1.259251] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.259269] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2e).
[ 1.259280] rk_gmac-dwmac fe300000.ethernet: RX delay(0x23).
[ 1.259294] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.259340] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.259352] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.264398] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.264584] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[ 1.264601] rk_gmac-dwmac fe300000.ethernet: DWMAC1000
[ 1.264611] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[ 1.264623] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[ 1.264632] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[ 1.264643] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[ 1.264672] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[ 1.264684] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[ 1.264693] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.336146] libphy: stmmac: probed
[ 1.336168] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 1.336178] mdio_bus stmmac-0:01: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 1.337054] PPP generic driver version 2.4.2
[ 1.337192] PPP BSD Compression module registered
[ 1.337208] PPP Deflate Compression module registered
[ 1.337242] PPP MPPE Compression module registered
[ 1.337256] NET: Registered protocol family 24
[ 1.337278] PPTP driver version 0.8.5
[ 1.337551] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.337564] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.337646] usbcore: registered new interface driver catc
[ 1.337691] usbcore: registered new interface driver kaweth
[ 1.337705] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.337738] usbcore: registered new interface driver pegasus
[ 1.337774] usbcore: registered new interface driver rtl8150
[ 1.337815] usbcore: registered new interface driver r8152
[ 1.337828] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.337880] usbcore: registered new interface driver hso
[ 1.337913] usbcore: registered new interface driver asix
[ 1.337949] usbcore: registered new interface driver ax88179_178a
[ 1.337984] usbcore: registered new interface driver cdc_ether
[ 1.338018] usbcore: registered new interface driver cdc_eem
[ 1.338056] usbcore: registered new interface driver dm9601
[ 1.338097] usbcore: registered new interface driver smsc75xx
[ 1.338132] usbcore: registered new interface driver smsc95xx
[ 1.338166] usbcore: registered new interface driver gl620a
[ 1.338203] usbcore: registered new interface driver net1080
[ 1.338238] usbcore: registered new interface driver plusb
[ 1.338272] usbcore: registered new interface driver rndis_host
[ 1.338307] usbcore: registered new interface driver cdc_subset
[ 1.338342] usbcore: registered new interface driver zaurus
[ 1.338374] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.338412] usbcore: registered new interface driver int51x1
[ 1.338449] usbcore: registered new interface driver kalmia
[ 1.338483] usbcore: registered new interface driver ipheth
[ 1.338521] usbcore: registered new interface driver sierra_net
[ 1.338557] usbcore: registered new interface driver cx82310_eth
[ 1.338612] usbcore: registered new interface driver cdc_ncm
[ 1.338649] usbcore: registered new interface driver qmi_wwan
[ 1.338683] usbcore: registered new interface driver cdc_mbim
[ 1.339631] dwc3 fe900000.dwc3: Failed to get clk ‘ref’: -2
[ 1.344186] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.344203] ehci-pci: EHCI PCI platform driver
[ 1.344255] ehci-platform: EHCI generic platform driver
[ 1.346556] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.346704] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.346963] ehci-platform fe3c0000.usb: irq 33, io mem 0xfe3c0000
[ 1.353590] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.353723] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.353740] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.353754] usb usb1: Product: EHCI Host Controller
[ 1.353766] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[ 1.353778] usb usb1: SerialNumber: fe3c0000.usb
[ 1.354134] hub 1-0:1.0: USB hub found
[ 1.354173] hub 1-0:1.0: 1 port detected
[ 1.354708] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.354728] ohci-platform: OHCI generic platform driver
[ 1.355003] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.355138] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.355364] ohci-platform fe3e0000.usb: irq 34, io mem 0xfe3e0000
[ 1.410728] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.410746] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.410756] usb usb2: Product: Generic Platform OHCI controller
[ 1.410765] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[ 1.410774] usb usb2: SerialNumber: fe3e0000.usb
[ 1.411122] hub 2-0:1.0: USB hub found
[ 1.411161] hub 2-0:1.0: 1 port detected
[ 1.412184] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.412339] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[ 1.412781] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000005002030010
[ 1.412827] xhci-hcd xhci-hcd.0.auto: irq 72, io mem 0xfe900000
[ 1.413086] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.413102] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.413115] usb usb3: Product: xHCI Host Controller
[ 1.413127] usb usb3: Manufacturer: Linux 4.19.111 xhci-hcd
[ 1.413139] usb usb3: SerialNumber: xhci-hcd.0.auto
[ 1.413487] hub 3-0:1.0: USB hub found
[ 1.413528] hub 3-0:1.0: 1 port detected
[ 1.413784] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.413920] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[ 1.413936] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 1.413995] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.414091] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.414106] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.414118] usb usb4: Product: xHCI Host Controller
[ 1.414129] usb usb4: Manufacturer: Linux 4.19.111 xhci-hcd
[ 1.414141] usb usb4: SerialNumber: xhci-hcd.0.auto
[ 1.414461] hub 4-0:1.0: USB hub found
[ 1.414500] hub 4-0:1.0: 1 port detected
[ 1.414838] usbcore: registered new interface driver cdc_acm
[ 1.414853] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.414901] usbcore: registered new interface driver usblp
[ 1.414941] usbcore: registered new interface driver cdc_wdm
[ 1.414984] usbcore: registered new interface driver uas
[ 1.415060] usbcore: registered new interface driver usb-storage
[ 1.415100] usbcore: registered new interface driver ums-alauda
[ 1.415138] usbcore: registered new interface driver ums-cypress
[ 1.415176] usbcore: registered new interface driver ums-datafab
[ 1.415211] usbcore: registered new interface driver ums_eneub6250
[ 1.415248] usbcore: registered new interface driver ums-freecom
[ 1.415285] usbcore: registered new interface driver ums-isd200
[ 1.415323] usbcore: registered new interface driver ums-jumpshot
[ 1.415360] usbcore: registered new interface driver ums-karma
[ 1.415392] usbcore: registered new interface driver ums-onetouch
[ 1.415429] usbcore: registered new interface driver ums-sddr09
[ 1.415466] usbcore: registered new interface driver ums-sddr55
[ 1.415502] usbcore: registered new interface driver ums-usbat
[ 1.415591] usbcore: registered new interface driver usbserial_generic
[ 1.415613] usbserial: USB Serial support registered for generic
[ 1.415651] usbcore: registered new interface driver option
[ 1.415676] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.415816] usbcore: registered new interface driver trancevibrator
[ 1.416159] usbcore: registered new interface driver xpad
[ 1.416203] usbcore: registered new interface driver usb_acecad
[ 1.416244] usbcore: registered new interface driver aiptek
[ 1.416284] usbcore: registered new interface driver gtco
[ 1.416323] usbcore: registered new interface driver hanwang
[ 1.416361] usbcore: registered new interface driver kbtab
[ 1.416927] .. rk pwm remotectl v1.1 init
[ 1.417115] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.417497] sensor_register_slave:kxtj9,id=11
[ 1.417513] sensor_register_slave:mma8452,id=17
[ 1.417524] sensor_register_slave:lis3dh,id=7
[ 1.417535] sensor_register_slave:mma7660,id=18
[ 1.417543] sensor_register_slave:gs_mxc6655xa,id=24
[ 1.417550] sensor_register_slave:lsm303d,id=26
[ 1.417558] sensor_register_slave:gs_mc3230,id=27
[ 1.417586] [Gsensor] gsensor_init
[ 1.417599] sensor_register_slave:mpu6880_acc,id=28
[ 1.417611] sensor_register_slave:mpu6500_acc,id=29
[ 1.417622] sensor_register_slave:lsm330_acc,id=30
[ 1.417632] sensor_register_slave:bma2xx_acc,id=31
[ 1.417644] sensor_register_slave:akm8975,id=35
[ 1.417654] sensor_register_slave:akm8963,id=36
[ 1.417665] sensor_register_slave:l3g4200d,id=50
[ 1.417676] sensor_register_slave:l3g20d,id=51
[ 1.417687] sensor_register_slave:ewtsa,id=52
[ 1.417699] sensor_register_slave:lsm330_gyro,id=56
[ 1.417710] sensor_register_slave:cm3217,id=58
[ 1.417721] sensor_register_slave:cm3218,id=59
[ 1.417732] sensor_register_slave:ls_stk3410,id=67
[ 1.417743] sensor_register_slave:ps_stk3410,id=72
[ 1.418312] i2c /dev entries driver
[ 1.419385] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.419414] fan53555-reg: supplied by vcc_sys
[ 1.421063] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.421089] fan53555-reg: supplied by vcc5v0_sys
[ 1.422678] rk808 0-001b: chip id: 0x0
[ 1.426139] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.426198] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.426249] DCDC_REG1: supplied by vcc3v3_sys
[ 1.427130] DCDC_REG2: supplied by vcc3v3_sys
[ 1.427727] DCDC_REG3: supplied by vcc3v3_sys
[ 1.427966] DCDC_REG4: supplied by vcc3v3_sys
[ 1.428450] LDO_REG1: supplied by vcc3v3_sys
[ 1.429186] LDO_REG2: supplied by vcc3v3_sys
[ 1.429680] LDO_REG3: supplied by vcc3v3_sys
[ 1.430287] LDO_REG4: supplied by vcc3v3_sys
[ 1.430904] LDO_REG5: supplied by vcc3v3_sys
[ 1.431391] LDO_REG6: supplied by vcc3v3_sys
[ 1.431998] LDO_REG7: supplied by vcc3v3_sys
[ 1.432480] LDO_REG8: supplied by vcc3v3_sys
[ 1.433092] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.433419] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.433891] rk808-rtc rk808-rtc: device is disabled
[ 1.433915] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.434155] rtc-hym8563 0-0051: could not init device, -6
[ 1.435385] usbcore: registered new interface driver uvcvideo
[ 1.435402] USB Video Class driver (1.1.1)
[ 1.435719] rockchip-iodomain ff320000.syscon:io-domains: Linked as a consumer to regulator.26
[ 1.435933] rockchip-iodomain ff770000.syscon:io-domains: Linked as a consumer to regulator.26
[ 1.435997] rockchip-iodomain ff770000.syscon:io-domains: Linked as a consumer to regulator.25
[ 1.436059] rockchip-iodomain ff770000.syscon:io-domains: Linked as a consumer to regulator.22
[ 1.436876] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.437005] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.437185] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.437257] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.438813] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 1.439320] device-mapper: uevent: version 1.0.3
[ 1.439546] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 1.439744] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 1.439760] Bluetooth: HCI UART driver ver 2.3
[ 1.439773] Bluetooth: HCI UART protocol H4 registered
[ 1.439785] rtk_btusb: RTKBT_RELEASE_NAME: 20200330_BT_ANDROID_10.0
[ 1.439795] rtk_btusb: Realtek Bluetooth USB driver module init, version 5.2.1
[ 1.439805] rtk_btusb: Register usb char device interface for BT driver
[ 1.439987] usbcore: registered new interface driver rtk_btusb
[ 1.440202] cpu cpu0: bin=1
[ 1.440235] cpu cpu0: leakage=28
[ 1.440316] cpu cpu0: Linked as a consumer to regulator.16
[ 1.452103] cpu cpu0: temp=34444, pvtm=151537 (152342 + -805)
[ 1.452281] cpu cpu0: pvtm-volt-sel=2
[ 1.452331] cpu cpu0: Dropping the link to regulator.16
[ 1.452356] cpu cpu0: bin-scale=34
[ 1.452407] cpu cpu4: bin=1
[ 1.452436] cpu cpu4: leakage=50
[ 1.452524] cpu cpu4: Linked as a consumer to regulator.13
[ 1.464470] cpu cpu4: temp=33888, pvtm=155597 (156165 + -568)
[ 1.464565] cpu cpu4: pvtm-volt-sel=2
[ 1.464621] cpu cpu4: Dropping the link to regulator.13
[ 1.464649] cpu cpu4: bin-scale=17
[ 1.464879] cpu cpu0: Linked as a consumer to regulator.16
[ 1.464921] cpu cpu0: Dropping the link to regulator.16
[ 1.465031] cpu cpu0: Linked as a consumer to regulator.16
[ 1.465531] cpu cpu0: avs=0
[ 1.465756] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.466316] cpu cpu0: failed to find power_model node
[ 1.466454] cpu cpu4: Linked as a consumer to regulator.13
[ 1.467140] cpu cpu4: avs=0
[ 1.467187] energy_model: pd4: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[ 1.467383] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.469120] cpu cpu4: failed to find power_model node
[ 1.470350] sdhci: Secure Digital Host Controller Interface driver
[ 1.470370] sdhci: Copyright(c) Pierre Ossman
[ 1.470381] Synopsys Designware Multimedia Card Interface Driver
[ 1.471048] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.471257] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.471285] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.471342] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[ 1.471486] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.471505] mmc_host mmc0: card is non-removable.
[ 1.484702] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.498178] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.498748] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.498780] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.498831] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 1.498931] dwmmc_rockchip fe320000.dwmmc: Linked as a consumer to regulator.9
[ 1.498994] dwmmc_rockchip fe320000.dwmmc: Linked as a consumer to regulator.22
[ 1.512486] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.520000] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.522676] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.525675] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.526374] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.530105] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.553678] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.554953] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.557653] usbcore: registered new interface driver usbhid
[ 1.557677] usbhid: USB HID core driver
[ 1.558500] ashmem: initialized
[ 1.561382] rockchip-saradc ff100000.saradc: Linked as a consumer to regulator.7
[ 1.562146] optee: probing for conduit method from DT.
[ 1.562172] optee: revision 1.1
[ 1.562518] optee: initialized driver
[ 1.562535] rknandbase v1.2 2018-05-08
[ 1.562977] usbcore: registered new interface driver snd-usb-audio
[ 1.568364] netem: version 1.3
[ 1.568391] u32 classifier
[ 1.568401] Actions configured
[ 1.569239] xt_time: kernel timezone is -0000
[ 1.569388] gre: GRE over IPv4 demultiplexor driver
[ 1.569399] IPv4 over IPsec tunneling driver
[ 1.570284] Initializing XFRM netlink socket
[ 1.570321] IPsec XFRM device driver
[ 1.570748] NET: Registered protocol family 10
[ 1.571828] Segment Routing with IPv6
[ 1.571933] mip6: Mobile IPv6
[ 1.572714] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.573602] NET: Registered protocol family 17
[ 1.573633] NET: Registered protocol family 15
[ 1.573695] Bridge firewalling registered
[ 1.574032] Bluetooth: RFCOMM TTY layer initialized
[ 1.574054] Bluetooth: RFCOMM socket layer initialized
[ 1.574092] Bluetooth: RFCOMM ver 1.11
[ 1.574113] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.574126] Bluetooth: BNEP filters: protocol multicast
[ 1.574141] Bluetooth: BNEP socket layer initialized
[ 1.574151] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.574164] Bluetooth: HIDP socket layer initialized
[ 1.574211] l2tp_core: L2TP core driver, V2.0
[ 1.574230] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.574242] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.574252] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.574653] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.574676] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8723du
[ 1.574689] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.574701] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.574771] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.574783] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.574796] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.575254] sensor_register_slave:mpu6500_gyro,id=54
[ 1.575269] sensor_register_slave:mpu6880_gyro,id=55
[ 1.576903] registered taskstats version 1
[ 1.576920] Loading compiled-in X.509 certificates
[ 1.577181] Key type ._fscrypt registered
[ 1.577201] Key type .fscrypt registered
[ 1.577217] Key type fscrypt-provisioning registered
[ 1.577531] pstore: Using compression: deflate
[ 1.578464] rga2: Driver loaded successfully ver:3.02
[ 1.578737] rga2: Module initialized.
[ 1.590754] mmc2: new HS400 MMC card at address 0001
[ 1.592062] mmcblk2: mmc2:0001 MMC8GB 7.28 GiB
[ 1.592844] mmcblk2boot0: mmc2:0001 MMC8GB partition 1 4.00 MiB
[ 1.593621] mmcblk2boot1: mmc2:0001 MMC8GB partition 2 4.00 MiB
[ 1.593954] mmcblk2rpmb: mmc2:0001 MMC8GB partition 3 4.00 MiB, chardev (237:0)
[ 1.599899] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 1.618510] mali ff9a0000.gpu: Linked as a consumer to regulator.14
[ 1.618614] mali ff9a0000.gpu: leakage=40
[ 1.633160] mali ff9a0000.gpu: temp=33333, pvtm=127995 (128363 + -368)
[ 1.634740] mali ff9a0000.gpu: pvtm-volt-sel=2
[ 1.635321] mali ff9a0000.gpu: avs=0
[ 1.636209] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.636610] mali ff9a0000.gpu: Protected mode not available
[ 1.637056] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.637168] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 1.637292] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 417; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.638143] mali ff9a0000.gpu: Probed as mali0
[ 1.639383] rockchip-dmc dmc: Linked as a consumer to regulator.15
[ 1.639499] rockchip-dmc dmc: Failed to get leakage
[ 1.639547] rockchip-dmc dmc: Failed to get pvtm
[ 1.639980] rockchip-dmc dmc: avs=0
[ 1.640178] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.640210] rockchip-dmc dmc: could not find power_model node
[ 1.646510] hctosys: unable to open rtc device (rtc0)
[ 1.647471] It doesn’t contain Rogue gpu
[ 1.647964] rockchip_headset rk-headset: Can not read property hook_gpio
[ 1.647993] rockchip_headset rk-headset: headset have hook adc mode
[ 1.648242] input: rk-headset as /devices/platform/rk-headset/input/input1
[ 1.652022] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.654011] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.654642] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘15:32:09’, on ‘Sep 9 2021’.
[ 1.655054] Mali:
[ 1.655056] Mali device driver loaded
[ 1.655435] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 1.655702] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.655721] cfg80211: failed to load regulatory.db
uρ 1.667553]
[ 1.667908] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.674796] mmc0: new high speed SDIO card at address 0001
