android平板刷Ubuntu启动停在initramfs
3288的平板想刷成Ubuntu系统,在Firefly-RK3288的内核上进行定制,挂载不上linux文件系统,请问有哪位有解决方法,主要log如下,机器不是用esmmc的,是用flash的:
[ 6.488568] rockchip-hdmi-spdif rockchip-hdmi-spdif.28: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
[ 6.499870] #0: RK_ES8323
[ 6.502628] #1: RK-HDMI-SPDIF
[ 6.505811] 2, baud is:115200
[ 6.509643] Freeing unused kernel memory: 2364K (c0a7d000 - c0ccc000)
Loading, please wait…
[ 6.534379] udevd[137]: starting version 175
Begin: Loading essential drivers … FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
done.
Begin: Running /scripts/init-premount … ls: /sys/class/mtd/mtd[0-[ 6.570795] usb 3-1: new high-speed USB device number 2 using usb20_host
9]/name: No such file or directory
done.
Begin: Mounting root[ 6.583257] Indeed it is in host mode hprt0 = 00001101
file system … Begin: Running /scripts/local-top … done.
[ 6.788429] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 6.795124] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.802465] usb 3-1: Product: USB 2.0 Hub
[ 6.808710] hub 3-1:1.0: USB hub found
[ 6.812566] hub 3-1:1.0: 4 ports detected
[ 19.619255] vbus detect
Gave up waiting for root device. Common problems:
  • Boot args (cat /proc/cmdline)
    • Check rootdelay= (did the system wait long enough?)
    • Check root= (did the system wait for the right device?)
  • Missing modules (cat /proc/modules; ls /dev)
    ALERT! /dev/block/mtd/by-name/linuxroot does not exist. Dropping to a shell!
    /bin/sh: can’t access tty; job control turned off
    (initramfs)
    (initramfs)
    (initramfs)
    (initramfs)
    logboot.zip (13.6 KB)
帅哥,我遇到了和你一抹一眼样的问题,请问你是怎么解决的?我是编译pad版内核,然后挂载ubuntu文件系统就出现了和你一样的问题,你怎么解决的
qiyei2009 发表于 2015-7-28 20:47
帅哥,我遇到了和你一抹一眼样的问题,请问你是怎么解决的?我是编译pad版内核,然后挂载ubuntu文件系统就 …
还没解决
我想这个问题应该是内核没有认识出FLASH
我怀疑是内核驱动的问题,但是不知道从哪里下手呢
试试将parameter中的root=/dev/block/mtd/by-name/linuxroot改为root=/dev/mmcblk0p5,感觉是挂载时候没找到名字,具体再怎么解决,找斑竹们吧。我试了ok的。
把文件系统放在SD卡中,将parameter中的root=/dev/block/mtd/by-name/linuxroot改为root=/dev/mmcblk0p2 可以了如下:
Ubuntu 14.04.2 LTS firefly ttyFIQ0
firefly login: root (automatic login)
Last login: Thu Jan 1 00:22:00 UTC 2015 on ttyFIQ0
Welcome to Ubuntu 14.04.2 LTS (GNU/Linux 3.10.0 armv7l)
0 packages can be updated.
0 updates are security updates.
root@firefly:~#
就是HDMI没有显示
HDMI有显示嘛,可以又显嘛?
通过串口输入:startX HDMI有图形界面出来了:D
