核心板+底板,安装上4G模块ec20,插入SIM卡,天线接上,如下所示:
启动后提示如下所示:(提示:ec20 det false)
查看4G模组及加载情况如下:
AT命令反馈信息:
/etc/路径下看不到ppp0或者ppp,不能上网。
那接下来该如何通过4G上网,
怎样让板子能开机自动通过4G模块上网呢?
查看4G模组及加载情况如下:
AT命令反馈信息:
那接下来该如何通过4G上网,
需要将文件夹的/ec20-armhf/usr/share/udhcpc/default.script替换掉系统的/usr/share/udhcpc/default.script
结果如下:
[root@RV1126_RV1109:/userdata/ec20-armhf]# quectel-CM &
[root@RV1126_RV1109:/userdata/ec20-armhf]# [04-20_14:27:04:405] Quectel_Linux_ConnectManager_SR01A01V21
[04-20_14:27:04:406] quectel-CM profile[1] = (null)/(null)/(null)/0, pincode = (null)
[04-20_14:27:04:407] Find qmichannel = /dev/cdc-wdm0
[04-20_14:27:04:407] Find usbnet_adapter = wwan0
[04-20_14:27:04:422] cdc_wdm_fd = 7
[04-20_14:27:05:422] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 2 (No such file or directory)
[04-20_14:27:06:520] Get clientWDS = 19
[04-20_14:27:06:552] Get clientDMS = 1
[04-20_14:27:06:584] Get clientNAS = 3
[04-20_14:27:06:617] Get clientUIM = 1
[04-20_14:27:06:648] Get clientWDA = 1
[04-20_14:27:06:681] requestBaseBandVersion EC20CFDR02A07M4G 1 [Nov 10 2016 17:00:00]
[04-20_14:27:06:743] requestGetSIMStatus SIMStatus: SIM_READY
[04-20_14:27:06:777] requestGetProfile[1] cmnet///0
[04-20_14:27:06:808] requestRegistrationState2 MCC: 460, MNC: 0, PS: Attached, DataCap: LTE
[04-20_14:27:06:839] requestQueryDataCall ConnectionStatus: DISCONNECTED
[04-20_14:27:06:904] requestRegistrationState2 MCC: 460, MNC: 0, PS: Attached, DataCap: LTE
[04-20_14:27:07:447] requestSetupDataCall WdsConnectionIPv4Handle: 0x87205120
[04-20_14:27:07:513] requestQueryDataCall ConnectionStatus: CONNECTED
udhcpc: started, v1.27.2
Failed to kill daemon: No such file or directory
udhcpc: sending discover
udhcpc: sending select for 10.154.101.71
udhcpc: lease of 10.154.101.71 obtained, lease time 7200
[04-20_14:27:07:729] deleting routers
[04-20_14:27:07:772] adding dns 221.179.38.7
[04-20_14:27:07:772] adding dns 120.196.165.7
[root@RV1126_RV1109:/userdata/ec20-armhf]#ifconfig wwan0
wwan0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.154.101.71 P-t-P:10.154.101.71 Mask:255.255.255.240
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:612 (612.0 B) TX bytes:656 (656.0 B)
ec20-armhf.tar.gz (60 KB)
开机自启只需要自行添加自启动脚本即可,自启动目录:/etc/init.d/
参考该目录其他自启动文件自行添加。
你好,按照上面说明配置后,执行 quectel-CM & 显示如下信息:
(requestGetSIMStatus SIMStatus: SIM_ABSENT)SIM卡没找到?
相关文件所在位置:
试了三种4G的SIM卡,
运行后结果是一样的提示,找不到SIM卡。
不插4G卡再试一次,结果仍然是requestGetSIMStatus SIMStatus: SIM_ABSENT。
看起来是没有识别到4G的SIM卡。
底板硬件需要特别跳线配置吗?或者需要特别的SIM卡驱动?
或者还有其他什么情况需要注意的呢?
你SIM卡插的方向好像错了。仔细看下板子的丝印。有刻着怎么插入卡的。
用脚本测试一下是否能测试出SIM卡的卡号。
test4G.zip (454 Bytes)
谢谢提醒,是方向插反了,有斜边缺口的那一侧应该朝向卡槽的外面。{:4_112:}
转过来能识别到SIM卡,运行quectel-CM &之后能够识别到ip了。
但目前是隔一段时间会自动打印一些log信息,这个能去掉吗?
试一下这个
quectel-CM.zip (48.7 KB)
这个可以了,谢谢!{:4_167:}
学习
你好,我的固件怎么提示没有这个文件;quectel-CM &
要怎么操作
要怎么操作
你看一下论坛啊,都有附件发出来的。下载,按照要求操作。{:4_89:}
学习。。
学习
参考该目录其他自启动文件自行添加。
这个有相关具体教程吗?
楼主你好,你解决开机自启了吗?
wx__CL2UeY 发表于 2022-7-9 14:12
楼主你好,你解决开机自启了吗?
目录下全都是脚本,参考一两个脚本写就行了
你好,请问如果是debian下呢?
wx__CL2UeY 发表于 2022-7-9 18:43
你好,请问如果是debian下呢?
debian烧写的时候只替换了部分镜像,但之前我问淘宝客服这个问题,他说更换了debian,就是全换掉了,所以我这个问题似乎没有任何价值。
你好,请问如果是debian下呢?
debian是用 systemctl 控制的。可以了解下系统相关的知识。
