ubuntu18.04 apt --fix-broken install error
apt-get update
apt-get install cmake qt5-default qtcreator
add
firefly-rk3399-repo bionic main
to sources.list> https://dev.t-firefly.com/thread-100755-1-1.html
root@firefly:~#
root@firefly:~# apt autoremove
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 libegl1 : Depends: libglvnd0 (= 1.0.0-2ubuntu2.2) but 1.0.0-2ubuntu2.3 is installed
 libgl1-mesa-dev : Depends: mesa-common-dev (= 20.0.8-0ubuntu1~18.04.1) but 18.0.5-0ubuntu0~18.04.1 is installed
                   Depends: libglvnd-dev but it is not installed
 libgles2 : Depends: libglvnd0 (= 1.0.0-2ubuntu2.2) but 1.0.0-2ubuntu2.3 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
arm64
