结果是屏幕没有任何输出显示。我也抓了一些开机的log,也没有关于edid的信息,看看大家有啥好的建议。
第二个办法是:我想把分辨率白名单中的一个分辨率修改指定的分辨率,不知道这样是否可以行
log如下
rk3399_firefly_aio:/ $
rk3399_firefly_aio:/ $ DDR Version 1.24 20191016
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 337
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68437
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT 0x3335db8 signature is wrong
recovery gpt…
recovery gpt fail!
Trust Addr:0x4000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x87104
RunBL31 0x40000 @ 93968 us
NOTICE: BL31: v1.3(release):af49f67
NOTICE: BL31: Built : 16:55:08, May 19 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1191): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-256-gebb61ff5 #4 Wed Apr 22 01:34:02 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Nov 09 2020 - 17:33:59)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
no rockusb key node
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=975000,pwm_value=58
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 2020-11-09#1.26
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find panel driver
no fuel gauge found
rockchip_panel_deinit: failed to find panel deinit funcs
failed to display kernel logo
load fdt from resouce.
hwversion: disabled!
Secure Boot state: 0
kernel @ 0x00280000 (0x01376808)
ramdisk @ 0x04bf0000 (0x001e7860)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004616f30 … OK
Add bank:000000000a200000, 0000000075e00000
[ 0.000000] Linux version 4.4.126 (ruanjg@tchipserver2) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #3 SMP PREEMPT Mon Nov 9 17:35:10 CST 2020
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef7000 s45592 r8192 d32232 u86016
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00300000@0x000C4000(system),0x00100000@0x003C4000(oem),0x00008000@0x004C4000(metadata),0x00000040@0x004CC000(verity_mode),0x00002000@0x004CC040(reserved),0x00000400@0x004CE040(frp),-@0x004CE440(userdata) storagemedia=emmc androidboot.oem_unlocked=0 uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2020-11-09_17:33:59 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7eeae000-0x7eeee000] (0MB) mapped at [ffffffc07eeae000-ffffffc07eeedfff]
[ 0.000000] Memory: 1985884K/2064384K available (11518K kernel code, 1754K rwdata, 5752K rodata, 832K init, 2390K bss, 62116K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009170000 - 0xffffff8009240000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bc0000 ( 11520 KB)
[ 0.000000] .rodata : 0xffffff8008bc0000 - 0xffffff8009170000 ( 5824 KB)
[ 0.000000] .data : 0xffffff8009240000 - 0xffffff80093f6808 ( 1755 KB)
[ 0.001846] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002791] pid_max: default: 32768 minimum: 301
[ 0.003273] Security Framework initialized
[ 0.003655] SELinux: Initializing.
[ 0.004076] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004696] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006071] Initializing cgroup subsys memory
[ 0.006495] Initializing cgroup subsys freezer
[ 0.007740] sched-energy: Sched-energy-costs installed from DT
[ 0.008280] CPU0: update cpu_capacity 401
[ 0.008727] ASID allocator initialised with 32768 entries
[ 0.025592] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.026771] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.038975] Detected VIPT I-cache on CPU1
[ 0.039003] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039037] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039073] CPU1: update cpu_capacity 401
[ 0.039077] CPU1: Booted secondary processor [410fd034]
[ 0.048967] Detected VIPT I-cache on CPU2
[ 0.048986] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049017] CPU2: using LPI pending table @0x000000007c020000
[ 0.049041] CPU2: update cpu_capacity 401
[ 0.049044] CPU2: Booted secondary processor [410fd034]
[ 0.059000] Detected VIPT I-cache on CPU3
[ 0.059019] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059049] CPU3: using LPI pending table @0x000000007c060000
[ 0.059072] CPU3: update cpu_capacity 401
[ 0.059076] CPU3: Booted secondary processor [410fd034]
[ 0.069048] Detected PIPT I-cache on CPU4
[ 0.069072] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069104] CPU4: using LPI pending table @0x000000007c0b0000
[ 0.069139] CPU4: update cpu_capacity 1024
[ 0.069142] CPU4: Booted secondary processor [410fd082]
[ 0.079074] Detected PIPT I-cache on CPU5
[ 0.079091] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079121] CPU5: using LPI pending table @0x000000007c0e0000
[ 0.079145] CPU5: update cpu_capacity 1024
[ 0.079148] CPU5: Booted secondary processor [410fd082]
[ 0.079227] Brought up 6 CPUs
[ 0.091119] SMP: Total of 6 processors activated.
[ 0.091555] CPU features: detected feature: GIC system register CPU interface
[ 0.092215] CPU: All CPU(s) started at EL2
[ 0.092627] alternatives: patching kernel code
[ 0.094905] devtmpfs: initialized
[ 0.115278] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116233] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117494] pinctrl core: initialized pinctrl subsystem
[ 0.119468] Failed to find legacy iommu devices
[ 0.120272] NET: Registered protocol family 16
[ 0.121104] schedtune: init normalization constants…
[ 0.121598] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.122221] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.122843] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123477] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124099] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.124722] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125344] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.125965] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.126586] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127214] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.127940] schedtune: verify normalization constants…
[ 0.128447] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.128978] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.129508] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130039] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.130575] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131106] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.131637] schedtune: configured to support 5 boost groups
[ 0.140615] cpuidle: using governor ladder
[ 0.150617] cpuidle: using governor menu
[ 0.151004] Registered FIQ tty driver
[ 0.151739] vdso: 2 pages (1 code @ ffffff8008bc6000, 1 data @ ffffff8009244000)
[ 0.152465] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.154019] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.175838] console [pstore-1] enabled
[ 0.176424] pstore: Registered ramoops as persistent store backend
[ 0.177016] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.180003] fiq debugger fiq mode enabled
[[ 0.180640] console [ttyFIQ0] enabled
[ 0.181344] bootconsole [uart0] disabled
[ 0.181913] Registered fiq debugger ttyFIQ0
[ 0.213956] reg_fixed_voltage_probe vcc5v0_host sys/camera_test/vcc5v0_dbg
[ 0.216109] iommu: Adding device ff650000.vpu_service to group 0
[ 0.216198] iommu: Adding device ff660000.rkvdec to group 1
[ 0.216259] iommu: Adding device ff670000.iep to group 2
[ 0.216344] iommu: Adding device ff8f0000.vop to group 3
[ 0.216414] iommu: Adding device ff900000.vop to group 4
[ 0.216517] iommu: Adding device ff910000.isp to group 5
[ 0.216590] iommu: Adding device ff920000.isp to group 6
[ 0.217244] rk_iommu ff670800.iommu: can’t get aclk
[ 0.217261] rk_iommu ff670800.iommu: can’t get hclk
[ 0.218139] SCSI subsystem initialized
[ 0.218451] usbcore: registered new interface driver usbfs
[ 0.218493] usbcore: registered new interface driver hub
[ 0.218564] usbcore: registered new device driver usb
[ 0.218928] media: Linux media interface: v0.10
[ 0.218969] Linux video capture interface: v2.00
[ 0.219134] pps_core: LinuxPPS API ver. 1 registered
[ 0.219143] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.219163] PTP clock support registered
[ 0.220694] Advanced Linux Sound Architecture Driver Initialized.
[ 0.221146] Bluetooth: Core ver 2.21
[ 0.221175] NET: Registered protocol family 31
[ 0.221183] Bluetooth: HCI device and connection manager initialized
[ 0.221195] Bluetooth: HCI socket layer initialized
[ 0.221207] Bluetooth: L2CAP socket layer initialized
[ 0.221231] Bluetooth: SCO socket layer initialized
[ 0.221926] rockchip-cpuinfo cpuinfo: Serial : 8ed4ada1cbe0f445
[ 0.222450] clocksource: Switched to clocksource arch_sys_counter
[ 0.266204] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.266428] NET: Registered protocol family 2
[ 0.266837] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.266978] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.267252] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.267319] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.267378] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.267550] NET: Registered protocol family 1
[ 0.268375] Trying to unpack rootfs image as initramfs…
[ 0.366289] Freeing initrd memory: 1948K
[ 0.366852] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.366938] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.369663] audit: initializing netlink subsys (disabled)
[ 0.369721] audit: type=2000 audit(0.366:1): initialized
[ 0.374667] VFS: Disk quotas dquot_6.6.0
[ 0.374787] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.375754] Registering sdcardfs 0.1
[ 0.376330] fuse init (API version 7.23)
[ 0.377359]
[ 0.377359] TEE Core Framework initialization (ver 1:0.1)
[ 0.377388] TEE armv7 Driver initialization
[ 0.377731] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.377745] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.377912] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.381281] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.381306] io scheduler noop registered
[ 0.381466] io scheduler cfq registered (default)
[ 0.383835] phy phy-ff770000.syscon:usb2-phy@e460.2: Failed to get VBUS supply regulator
[ 0.386905] ace test_init function.
[ 0.387053] ace test_init end.ret=0
[ 0.387378] radar end.ret=0
[ 0.389589] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.389611] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.435809] rockchip-pcie f8000000.pcie: invalid power supply
[ 0.935882] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.936092] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.936913] iep: failed to find iep power down clock source.
[ 0.937456] IEP Power ON
[ 0.937680] IEP Power OFF
[ 0.937801] IEP Driver loaded succesfully
[ 0.938028] Module initialized.
[ 0.938405] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.938641] rk-vcodec ff650000.vpu_service: probe device
[ 0.938848] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.939371] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.939386] rk-vcodec ff650000.vpu_service: init success
[ 0.939607] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.940004] rk-vcodec ff660000.rkvdec: probe device
[ 0.940172] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.940540] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.940555] rk-vcodec ff660000.rkvdec: init success
[ 0.942125] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.942144] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.943468] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.943481] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.945213] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.945716] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 0.946157] [drm] Initialized drm 1.1.0 20060810
[ 0.949382] [drm] Rockchip DRM driver version: v1.0.0
[ 0.949685] rockchip-drm display-subsystem: defer getting devfreq
[ 0.949960] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.950202] rockchip-vop ff900000.vop: unable to request PWM
[ 0.950228] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.950272] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.950440] rockchip-vop ff8f0000.vop: unable to request PWM
[ 0.950459] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.950688] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.950707] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.950806] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.951519] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.951535] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.951542] [drm] No driver support for vblank timestamp query.
[ 1.351325] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.351381] rockchip-drm display-subsystem: failed to show loader logo
[ 1.351471] Freeing drm_logo memory: 488K
[ 1.762891] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.779412] mali ff9a0000.gpu: Failed to get regulator
[ 1.779449] mali ff9a0000.gpu: Power control initialization failed
[ 1.779763] Unable to detect cache hierarchy for CPU 0
[ 1.787380] brd: module loaded
[ 1.791938] loop: module loaded
[ 1.792478] zram: Added device: zram0
[ 1.796472] Loading dl1825 driver
[ 1.796914] SCSI Media Changer driver v0.25
[ 1.801033] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.801051] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.801062] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.801820] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.972123] wk2xxx_serial_init()
[ 1.972134] wk2xxx_request_port
[ 1.972146] ttysWK0 at I/O 0x1 (irq = 101, base_baud = 460800) is a wk2xxx
[ 1.972353] uart_add_one_port success for line i:= 0 with right 0
[ 1.972364] wk2xxx_request_port
[ 1.972375] ttysWK1 at I/O 0x2 (irq = 101, base_baud = 460800) is a wk2xxx
[ 1.972576] uart_add_one_port success for line i:= 1 with right 0
[ 1.972587] wk2xxx_request_port
[ 1.972597] ttysWK2 at I/O 0x3 (irq = 101, base_baud = 460800) is a wk2xxx
[ 1.972776] uart_add_one_port success for line i:= 2 with right 0
[ 1.972787] wk2xxx_request_port
[ 1.972797] ttysWK3 at I/O 0x4 (irq = 101, base_baud = 460800) is a wk2xxx
[ 1.972975] uart_add_one_port success for line i:= 3 with right 0
[ 1.972985] uart_add_one_port = 0x0
[ 1.973009] register spi return v = :0
[ 1.973046] register firefly_spi_init spi return v = :0
[ 1.973097] tun: Universal TUN/TAP device driver, 1.6
[ 1.973107] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.973972] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.974062] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.974081] rk_gmac-dwmac fe300000.ethernet: TX delay(0x31).
[ 1.974091] rk_gmac-dwmac fe300000.ethernet: RX delay(0x24).
[ 1.974115] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.974279] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.974291] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.979305] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.979420] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.979431] Ring mode enabled
[ 1.979438] DMA HW capability register supported
[ 1.979445] Normal descriptors
[ 1.979454] RX Checksum Offload Engine supported (type 2)
[ 1.979461] Wake-Up On Lan supported
[ 1.979498] Enable RX Mitigation via HW Watchdog Timer
[ 2.056072] libphy: stmmac: probed
[ 2.056120] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 2.056135] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 2.056147] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 2.056158] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 2.056193] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 2.056205] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 2.056215] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 2.056226] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 2.056236] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 2.056247] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 2.056257] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 2.056267] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 2.056277] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 2.056288] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 2.056298] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 2.056309] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 2.056319] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 2.056330] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 2.056340] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 2.056351] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 2.056361] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 2.056373] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 2.056411] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 2.056422] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 2.056432] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 2.056442] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 2.056453] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 2.056463] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 2.056473] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 2.056484] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 2.056494] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 2.056504] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 2.057961] PPP generic driver version 2.4.2
[ 2.058228] PPP BSD Compression module registered
[ 2.058265] PPP Deflate Compression module registered
[ 2.058298] PPP MPPE Compression module registered
[ 2.058317] NET: Registered protocol family 24
[ 2.058366] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 2.058396] CSLIP: code copyright 1989 Regents of the University of California.
[ 2.058486] usbcore: registered new interface driver mt7601u
[ 2.058503] Rockchip WiFi SYS interface (V1.00) …
[ 2.058589] usbcore: registered new interface driver catc
[ 2.058671] usbcore: registered new interface driver kaweth
[ 2.058688] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.058735] usbcore: registered new interface driver pegasus
[ 2.058794] usbcore: registered new interface driver rtl8150
[ 2.058879] usbcore: registered new interface driver r8152
[ 2.058894] hso: drivers/net/usb/hso.c: Option Wireless
[ 2.058962] usbcore: registered new interface driver hso
[ 2.059031] usbcore: registered new interface driver asix
[ 2.059154] usbcore: registered new interface driver ax88179_178a
[ 2.059214] usbcore: registered new interface driver cdc_ether
[ 2.059292] usbcore: registered new interface driver cdc_eem
[ 2.059346] usbcore: registered new interface driver dm9601
[ 2.059416] usbcore: registered new interface driver smsc75xx
[ 2.059483] usbcore: registered new interface driver smsc95xx
[ 2.059564] usbcore: registered new interface driver gl620a
[ 2.059619] usbcore: registered new interface driver net1080
[ 2.059676] usbcore: registered new interface driver plusb
[ 2.059757] usbcore: registered new interface driver rndis_host
[ 2.059812] usbcore: registered new interface driver cdc_subset
[ 2.059870] usbcore: registered new interface driver zaurus
[ 2.059950] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.060027] usbcore: registered new interface driver int51x1
[ 2.060089] usbcore: registered new interface driver kalmia
[ 2.060168] usbcore: registered new interface driver ipheth
[ 2.060224] usbcore: registered new interface driver sierra_net
[ 2.060280] usbcore: registered new interface driver cx82310_eth
[ 2.060349] usbcore: registered new interface driver cdc_ncm
[ 2.060440] usbcore: registered new interface driver qmi_wwan
[ 2.060496] usbcore: registered new interface driver cdc_mbim
[ 2.067148] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[ 2.073805] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 2.075425] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.075447] ehci-pci: EHCI PCI platform driver
[ 2.075537] ehci-platform: EHCI generic platform driver
[ 2.079151] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.079436] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 2.079676] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.089156] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.089361] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.089398] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.089411] usb usb1: Product: EHCI Host Controller
[ 2.089423] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 2.089435] usb usb1: SerialNumber: fe380000.usb
[ 2.090071] hub 1-0:1.0: USB hub found
[ 2.090132] hub 1-0:1.0: 1 port detected
[ 2.094191] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.094450] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 2.094692] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.102480] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.102677] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.102714] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.102727] usb usb2: Product: EHCI Host Controller
[ 2.102740] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[ 2.102751] usb usb2: SerialNumber: fe3c0000.usb
[ 2.103321] hub 2-0:1.0: USB hub found
[ 2.103380] hub 2-0:1.0: 1 port detected
[ 2.104165] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.104219] ohci-platform: OHCI generic platform driver
[ 2.104622] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.104882] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 2.105085] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.159983] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.160020] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.160036] usb usb3: Product: Generic Platform OHCI controller
[ 2.160050] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[ 2.160063] usb usb3: SerialNumber: fe3a0000.usb
[ 2.160669] hub 3-0:1.0: USB hub found
[ 2.160730] hub 3-0:1.0: 1 port detected
[ 2.161378] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.161631] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 2.161807] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.216633] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.216671] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.216686] usb usb4: Product: Generic Platform OHCI controller
[ 2.216699] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[ 2.216712] usb usb4: SerialNumber: fe3e0000.usb
[ 2.217312] hub 4-0:1.0: USB hub found
[ 2.217372] hub 4-0:1.0: 1 port detected
[ 2.218750] usbcore: registered new interface driver cdc_acm
[ 2.218785] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.218864] usbcore: registered new interface driver usblp
[ 2.218928] usbcore: registered new interface driver cdc_wdm
[ 2.219020] usbcore: registered new interface driver uas
[ 2.219179] usbcore: registered new interface driver usb-storage
[ 2.219261] usbcore: registered new interface driver ums-alauda
[ 2.219317] usbcore: registered new interface driver ums-cypress
[ 2.219379] usbcore: registered new interface driver ums-datafab
[ 2.219457] usbcore: registered new interface driver ums_eneub6250
[ 2.219512] usbcore: registered new interface driver ums-freecom
[ 2.219570] usbcore: registered new interface driver ums-isd200
[ 2.219628] usbcore: registered new interface driver ums-jumpshot
[ 2.219705] usbcore: registered new interface driver ums-karma
[ 2.219765] usbcore: registered new interface driver ums-onetouch
[ 2.219827] usbcore: registered new interface driver ums-sddr09
[ 2.219905] usbcore: registered new interface driver ums-sddr55
[ 2.219961] usbcore: registered new interface driver ums-usbat
[ 2.220076] usbcore: registered new interface driver usbserial
[ 2.220148] usbcore: registered new interface driver usbserial_generic
[ 2.220190] usbserial: USB Serial support registered for generic
[ 2.220254] usbcore: registered new interface driver option
[ 2.220313] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.220575] usbcore: registered new interface driver trancevibrator
[ 2.220614] usb20_otg: version 3.10a 21-DEC-2012
[ 2.220904] usb20_host: version 3.10a 21-DEC-2012
[ 2.221665] usbcore: registered new interface driver xpad
[ 2.221757] usbcore: registered new interface driver usb_acecad
[ 2.221824] usbcore: registered new interface driver aiptek
[ 2.221910] usbcore: registered new interface driver gtco
[ 2.221977] usbcore: registered new interface driver hanwang
[ 2.222041] usbcore: registered new interface driver kbtab
[ 2.223092] .. rk pwm remotectl v1.1 init
[ 2.223427] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.223985] sensor_register_slave:mma8452,id=17
[ 2.224035] sensor_register_slave:lis3dh,id=7
[ 2.224053] sensor_register_slave:mma7660,id=18
[ 2.224070] sensor_register_slave:lsm303d,id=22
[ 2.224086] sensor_register_slave:gs_mc3230,id=23
[ 2.224094] [Gsensor] gsensor_init
[ 2.224111] sensor_register_slave:mpu6880_acc,id=24
[ 2.224127] sensor_register_slave:mpu6500_acc,id=25
[ 2.224144] sensor_register_slave:lsm330_acc,id=26
[ 2.224161] sensor_register_slave:bma2xx_acc,id=27
[ 2.224178] sensor_register_slave:akm8975,id=30
[ 2.224198] sensor_register_slave:akm8963,id=31
[ 2.224216] sensor_register_slave:l3g4200d,id=45
[ 2.224253] sensor_register_slave:l3g20d,id=46
[ 2.224271] sensor_register_slave:ewtsa,id=47
[ 2.224287] sensor_register_slave:lsm330_gyro,id=51
[ 2.224304] sensor_register_slave:cm3217,id=53
[ 2.224321] sensor_register_slave:cm3218,id=54
[ 2.224338] sensor_register_slave:ls_stk3410,id=62
[ 2.224355] sensor_register_slave:ps_stk3410,id=67
[ 2.225481] i2c /dev entries driver
[ 2.227253] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.227366] fan53555-reg: supplied by vcc5v0_sys
[ 2.230413] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.230499] fan53555-reg: supplied by vcc5v0_sys
[ 2.232752] rockchip-pinctrl pinctrl: pin gpio1-18 already requested by 0-0040; cannot claim for 0-001b
[ 2.232792] rockchip-pinctrl pinctrl: pin-50 (0-001b) status -22
[ 2.232809] rockchip-pinctrl pinctrl: could not request pin 50 (gpio1-18) from group pmic-dvs2 on device rockchip-pinctrl
[ 2.232846] rk808 0-001b: Error applying setting, reverse things back
[ 2.233314] rk808 0-001b: Pmic Chip id: 0x0
[ 2.236932] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.237036] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.237158] DCDC_REG1: supplied by vcc3v3_sys
[ 2.238016] DCDC_REG2: supplied by vcc3v3_sys
[ 2.238695] DCDC_REG3: supplied by vcc3v3_sys
[ 2.239040] DCDC_REG4: supplied by vcc3v3_sys
[ 2.239622] LDO_REG1: supplied by vcc3v3_sys
[ 2.240872] LDO_REG2: supplied by vcc3v3_sys
[ 2.241942] LDO_REG3: supplied by vcc3v3_sys
[ 2.243029] LDO_REG4: supplied by vcc3v3_sys
[ 2.243937] vcc_sd: Failed to create debugfs directory
[ 2.244058] LDO_REG5: supplied by vcc3v3_sys
[ 2.245138] LDO_REG6: supplied by vcc3v3_sys
[ 2.246247] LDO_REG7: supplied by vcc3v3_sys
[ 2.247314] LDO_REG8: supplied by vcc3v3_sys
[ 2.248428] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.248819] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.249399] firefly_hwversion_in_range Xs{\C0\FF\FF\FF\C0SJ{\C0\FF\FF\FF: hwversion in range(0 conditions)
[ 2.252786] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.253437] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009ade000
[ 2.254361] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009af2000
[ 2.255068] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009af4000
[ 2.256260] IR NEC protocol handler initialized
[ 2.256278] IR RC5(x/sz) protocol handler initialized
[ 2.256315] IR RC6 protocol handler initialized
[ 2.256329] IR JVC protocol handler initialized
[ 2.256344] IR Sony protocol handler initialized
[ 2.256358] IR SANYO protocol handler initialized
[ 2.256372] IR Sharp protocol handler initialized
[ 2.256386] IR MCE Keyboard/mouse protocol handler initialized
[ 2.256400] IR XMP protocol handler initialized
[ 2.256698] usbcore: registered new interface driver uvcvideo
[ 2.256720] USB Video Class driver (1.1.1)
[ 2.256742] CamSys driver version: v0.48.2, CamSys head file version: v1.0.0
[ 2.262592] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 2.262785] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 2.263133] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 63288] __power_supply_register: Expected proper parent device foest_usb’
[ 2.267254] rk_tsadcv2_temp_to_code: Invalid temp(2147483647), set temp to =125000
[ 2.268198] device-mapper: ut: version 1.0.3
[ 2.268628] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.268846etooth: HCI UART driver ver 2.3
[ 2.268880] Bluetooth: HCI UART protocol H4 registered
[ 2.268890] Bluetooth: HCI UART protocol LL registered
[ 2.268905] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.268914] rtk_btusb: Realtek uetooth USB driver module init, version 4.1.2
[ 2.268922] rtister usb char device interface for BT driver
[ 2.269235] uscore: registered new interface driver rtk_btusb
[ 2.269856] u0: bin=1
[ 2.269954] cpu cpu0: leakage=26
[ 2.282130] cpu cpu0: temp=51111, pvtm=147992 (147332 + 660)
[ 2.282555] cpu cpu0: pvtm-volt-sel=1
[ 2.282653] cpu cpu0: bin-scale=34
[ 2.283013] cpu cpu4: bin=1
[ 2.283103] cpu cpu4: leakage=49
[ 2.295382] cpu cpu4: temp=50555, pvtm=154831 (154516 + 315)
[ 2.295534] cpu cpu4: pvtm-volt-sel=1
[ 2.295620] cpu cpu4: bin-scale=17
[ 2.297012] cpu cpu0: avs=0, target-scale=34
[ 2.297141] cpu cpu0: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.298926] cpu cpu4: avs=0, target-scale=17
[ 2.299058] cpu cpu4: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.301553] sdhci: Secure Digital Host Controller Interface driver
[ 2.301588] sdhci: Copyright(c) Pierre Ossman
[ 2.301608] Synopsys Designware Multimedia Card Interface Driver
[ 2.302788] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.302944] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.302986] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.303041] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.303067] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.303125] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.303159] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.304188] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.304288] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.304307] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.304364] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.304411] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.304943] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.305111] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.315992] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.330281] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.330744] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.332694] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.332732] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.359210] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.360744] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.363415] usbcore: registered new interface driver usbhid
[ 2.363430] usbhid: USB HID core driver
[ 2.363533] inv_mpu_iio: inv_mpu_init:746
[ 2.364126] ashmem: initialized
[ 2.365267] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 2.369685] rknandbase v1.1 2016-11-08
[ 2.370442] usbcore: registered new interface driver snd-usb-audio
[ 2.371687] rt5640 1-001c: Can not read property hp-con-gpio
[ 2.376854] gpiod_direction_output: invalid GPIO
[ 2.376865] gpiod_direction_output: invalid GPIO
[ 2.376876] gpiod_direction_output: invalid GPIO
[ 2.387980] tc358749x 1-000f: tc358749x_i2c_probe success
[ 2.390797] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 2.392310] u32 classifier
[ 2.392341] Actions configured
[ 2.392368] Netfilter messages via NETLINK v0.30.
[ 2.392423] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.392754] ctnetlink v0.93: registering with nfnetlink.
[ 2.393241] xt_time: kernel timezone is -0000
[ 2.393827] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.394005] arp_tables: (C) 2002 David S. Miller
[ 2.394275] Initializing XFRM netlink socket
[ 2.394627] NET: Registered protocol family 10
[ 2.395392] mip6: Mobile IPv6
[ 2.395441] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.396211] sit: IPv6 over IPv4 tunneling driver
[ 2.396602] NET: Registered protocol family 17
[ 2.396627] NET: Registered protocol family 15
[ 2.396679] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.397052] Bridge firewalling registered
[ 2.397065] Ebtables v2.0 registered
[ 2.397273] Bluetooth: RFCOMM TTY layer initialized
[ 2.397295] Bluetooth: RFCOMM socket layer initialized
[ 2.397335] Bluetooth: RFCOMM ver 1.11
[ 2.397352] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.397358] Bluetooth: BNEP filters: protocol multicast
[ 2.397368] Bluetooth: BNEP socket layer initialized
[ 2.397376] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.397384] Bluetooth: HIDP socket layer initialized
[ 2.397411] l2tp_core: L2TP core driver, V2.0
[ 2.397424] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.397436] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.397725] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.397779] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.397789] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.397795] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.397854] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.397859] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.397867] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.397914] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.398238] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.398275] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.398297] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.398320] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.398648] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.398678] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 2.398692] [BT_RFKILL]: ** disable irq
[ 2.398799] [BT_RFKILL]: bt_default device registered.
[ 2.398945] sensor_register_slave:mpu6500_gyro,id=49
[ 2.398960] sensor_register_slave:mpu6880_gyro,id=50
[ 2.399835] mmc1: MAN_BKOPS_EN bit is not set
[ 2.401409] Registered cp15_barrier emulation handler
[ 2.401442] Registered setend emulation handler
[ 2.402887] registered taskstats version 1
[ 2.403991] rockchip ion idev is NULL
[ 2.404019] rga2 ff680000.rga: rga ion client create success!
[ 2.404399] rga2: Driver loaded successfully ver:3.02
[ 2.404608] rga2: Module initialized.
[ 2.405265] mali ff9a0000.gpu: leakage=32
[ 2.411733] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.412301] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 2.412487] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.412535] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 2.412766] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 2.412973] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 2.413423] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.413440] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 2.413450] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 2.413459] resource: 0x001000000 – 0x002000000 (16 MB)
[ 2.413467] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 2.413476] boot: 0x003800000 – 0x005800000 (32 MB)
[ 2.413485] recovery: 0x005800000 – 0x009800000 (64 MB)
[ 2.413494] backup: 0x009800000 – 0x010800000 (112 MB)
[ 2.413502] cache: 0x010800000 – 0x018800000 (128 MB)
[ 2.413511] system: 0x018800000 – 0x078800000 (1536 MB)
[ 2.413520] oem: 0x078800000 – 0x098800000 (512 MB)
[ 2.413529] metadata: 0x098800000 – 0x099800000 (16 MB)
[ 2.413538] verity_mode: 0x099800000 – 0x099808000 (0 MB)
[ 2.413546] reserved: 0x099808000 – 0x099c08000 (4 MB)
[ 2.413555] frp: 0x099c08000 – 0x099c88000 (0 MB)
[ 2.413564] userdata: 0x099c88000 – 0x3a3a00000 (12445 MB)
[ 2.413631] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 2.417737] mali ff9a0000.gpu: temp=50555, pvtm=125097 (124989 + 108)
[ 2.418543] mali ff9a0000.gpu: pvtm-volt-sel=1
[ 2.422884] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.423094] mali ff9a0000.gpu: Protected mode not available
[ 2.423600] mali ff9a0000.gpu: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.423688] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 2.423798] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.424464] mali ff9a0000.gpu: Probed as mali0
[ 2.428931] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.429142] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[ 2.429362] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.429416] xhci-hcd xhci-hcd.10.auto: irq 235, io mem 0xfe800000
[ 2.429623] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.429639] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.429650] usb usb5: Product: xHCI Host Controller
[ 2.429660] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.429669] usb usb5: SerialNumber: xhci-hcd.10.auto
[ 2.430123] hub 5-0:1.0: USB hub found
[ 2.430159] hub 5-0:1.0: 1 port detected
[ 2.430421] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.430580] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[ 2.430643] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.430732] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.430746] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.430756] usb usb6: Product: xHCI Host Controller
[ 2.430765] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.430774] usb usb6: SerialNumber: xhci-hcd.10.auto
[ 2.431195] hub 6-0:1.0: USB hub found
[ 2.431230] hub 6-0:1.0: 1 port detected
[ 2.432690] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.432739] usb usb6: USB disconnect, device number 1
[ 2.437926] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.438119] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 7
[ 2.438397] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.438467] xhci-hcd xhci-hcd.11.auto: irq 236, io mem 0xfe900000
[ 2.438708] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.438738] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.438749] usb usb7: Product: xHCI Host Controller
[ 2.438759] usb usb7: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.438768] usb usb7: SerialNumber: xhci-hcd.11.auto
[ 2.439250] hub 7-0:1.0: USB hub found
[ 2.439303] hub 7-0:1.0: 1 port detected
[ 2.439572] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.439732] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 8
[ 2.439840] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.439958] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.439970] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.439980] usb usb8: Product: xHCI Host Controller
[ 2.439990] usb usb8: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.439999] usb usb8: SerialNumber: xhci-hcd.11.auto
[ 2.440420] hub 8-0:1.0: USB hub found
[ 2.440468] hub 8-0:1.0: 1 port detected
[ 2.441875] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.441986] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.442005] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.442056] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.442077] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.442123] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.442133] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.442486] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.449372] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 2.449400] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 2.449508] xhci-hcd xhci-hcd.10.auto: USB bus 6 deregistered
[ 2.449871] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.449899] usb usb5: USB disconnect, device number 1
[ 2.450529] xhci-hcd xhci-hcd.10.auto: USB bus 5 deregistered
[ 2.455854] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.469205] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.470528] rockchip-dmc dmc: Failed to get leakage
[ 2.470628] rockchip-dmc dmc: Failed to get pvtm
[ 2.471040] rockchip-dmc dmc: could not find power_model node
[ 2.474505] devfreq dmc: Couldn’t update frequency transition information.
[ 2.478573] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 2.478928] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.478991] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.479000] ALSA pcmC1D1c,0:: cannot preallocate for size 32768
[ 2.479012] asoc-simple-card rt5640-sound: rt5640-aif2 ↔ ff890000.i2s mapping ok
[ 2.479193] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.479260] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.479268] ALSA pcmC1D2p,0:: cannot preallocate for size 32768
[ 2.479319] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.479364] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.479387] ALSA pcmC1D2c,0:: cannot preallocate for size 32768
[ 2.479400] asoc-simple-card rt5640-sound: tc358749x-audio ↔ ff890000.i2s mapping ok
[ 2.482605] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[ 2.483915] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:04 UTC (1358499004)
[ 2.484958] It doesn’t contain Rogue gpu
[ 2.502175] vdd3v3_pcie: disabling
[ 2.502266] vcc_sd: disabling
[ 2.502473] vcc_otg_vbus: disabling
[ 2.503421] ret 1024
[ 2.503822] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-c55b2bd’, rk_ko_ver is ‘5’, built at ‘17:34:50’, on ‘Nov 9 2020’.
[ 2.504208] Mali: Mali device driver loaded
[ 2.504973] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 2.505999] ALSA device list:
[ 2.506213] #0: rk-hdmi-dp-sound
[ 2.506429] #1: rockchip,rt5640-codec
[ 2.507013] Freeing unused kernel memory: 832K
[ 2.509321] init: init first stage started!
[ 2.513129] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.514838] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.516528] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.519287] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.522699] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.538844] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.538914] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.538937] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 2.540543] hub 2-1:1.0: USB hub found
[ 2.541190] hub 2-1:1.0: 7 ports detected
[ 2.566065] audit: type=1403 audit(1358499004.580:2): policy loaded auid=4294967295 ses=4294967295
[ 2.566615] init: (Initializing SELinux non-enforcing took 0.06s.)
[ 2.569537] init: init second stage started!
[ 2.573509] init: Setting ro.rk.soc=rk3399
[ 2.573633] init: OK,EMMC DRIVERS INIT OK
[ 2.573670] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 2.573728] init: property_set(“ro.hardware”, “rk30board”) failed
[ 2.573826] mmc_host mmc2: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 2.575623] init: Running restorecon…
[ 2.650659] init: waitpid failed: No child processes
[ 2.650992] init: (Loading properties from /default.prop took 0.00s.)
[ 2.652769] init: (Parsing /init.environ.rc took 0.00s.)
[ 2.653108] init: (Parsing /init.usb.rc took 0.00s.)
[ 2.654009] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 2.654623] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 2.654707] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 2.654783] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 2.654951] init: (Parsing /init.logs.rc took 0.00s.)
[ 2.655057] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 2.655132] init: (Parsing /init.coredump.rc took 0.00s.)
[ 2.655188] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 2.655257] init: (Parsing /init.kernel.rc took 0.00s.)
[ 2.655345] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 2.655361] init: (Parsing /init.debug.rc took 0.00s.)
[ 2.655377] init: (Parsing init.rockchip.rc took 0.00s.)
[ 2.655731] init: (Parsing init.connectivity.rc took 0.00s.)
[ 2.655797] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 2.655919] init: (Parsing init.rk3399.rc took 0.00s.)
[ 2.656010] init: init.tablet.rc: 23: invalid keyword ‘ioprio’
[ 2.656079] init: (Parsing init.tablet.rc took 0.00s.)
[ 2.656112] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 2.656142] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 2.656157] init: (Parsing /init.rk30board.rc took 0.00s.)
[ 2.656709] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 2.656814] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 2.656830] init: (Parsing /init.rc took 0.01s.)
[ 2.657244] init: Starting service ‘ueventd’…
[ 2.659211] ueventd: ueventd started!
[ 2.659887] ueventd: invalid gid ‘trace’
[ 2.662262] audit: type=1400 audit(1358499004.673:3): avc: denied { getattr } for pid=1 comm=“init” path=“/sys/kernel/debug/tracing/trace_marker” dev=“tracefs” ino=2209 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[ 2.745988] usb 7-1: new low-speed USB device number 2 using xhci-hcd
[ 2.826016] usb 2-1.7: new full-speed USB device number 3 using ehci-platform
[ 2.855280] ueventd: Coldboot took 0.19s.
[ 2.870504] usb 7-1: New USB device found, idVendor=093a, idProduct=2510
[ 2.870565] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.870591] usb 7-1: Product: USB Optical Mouse
[ 2.870613] usb 7-1: Manufacturer: PixArt
[ 2.871928] usb 7-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.884626] input: PixArt USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.dwc3/xhci-hcd.11.auto/usb7/7-1/7-1:1.0/0003:093A:2510.0001/input/input3
[ 2.885856] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-xhci-hcd.11.auto-1/input0
[ 2.892628] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 2.892675] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 2.892705] init: Waiting for /dev/.coldboot_done…
[ 2.892754] init: Waiting for /dev/.coldboot_done took 0.00s.
[ 2.892784] init: /dev/hw_random not found
[ 2.893263] keychord: using input dev ff420030.pwm for fevent
[ 2.893276] keychord: using input dev rk29-keypad for fevent
[ 2.901867] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 2.909223] audit: type=1400 audit(1358499004.923:4): avc: denied { relabelto } for pid=1 comm=“init” name=“oem” dev=“rootfs” ino=8229 scontext=u:r:init:s0 tcontext=u:object_r:oemfs:s0 tclass=dir permissive=1
[ 2.909272] audit: type=1400 audit(1358499004.923:5): avc: denied { associate } for pid=1 comm=“init” name=“oem” dev=“rootfs” ino=8229 scontext=u:object_r:oemfs:s0 tcontext=u:object_r:rootfs:s0 tclass=filesystem permissive=1
[ 2.909398] audit: type=1400 audit(1358499004.923:6): avc: denied { mounton } for pid=1 comm=“init” path=“/oem” dev=“rootfs” ino=8229 scontext=u:r:init:s0 tcontext=u:object_r:oemfs:s0 tclass=dir permissive=1
[ 2.915075] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: (null)
[ 2.915192] Registered swp emulation handler
[ 2.915376] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 2.916120] fs_mgr: Warning: unknown flag resize
[ 2.916202] init: /dev/hw_random not found
[ 2.916279] init: write_file: Unable to open ‘/sys/block/mmcblk0/bdi/read_ahead_kb’: No such file or directory
[ 2.916744] fs_mgr: Warning: unknown flag resize
[ 2.920744] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.920827] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[ 2.922156] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 2.922838] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 2.924704] usb 2-1.7: config 1 interface 0 altsetting 0 has 2 endpoint descriptors, different from the interface descriptor’s value: 1
[ 2.924749] vendor storage:20160801 ret = 0
[ 2.925729] usb 2-1.7: New USB device found, idVendor=29bd, idProduct=4103
[ 2.925776] usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.925840] usb 2-1.7: Product: Royole Multi-touch
[ 2.925906] usb 2-1.7: Manufacturer: Royole Corporation
[ 2.928801] random: e2fsck: uninitialized urandom read (40 bytes read, 47 bits of entropy available)
[ 2.934091] input: Royole Corporation Royole Multi-touch as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.7/2-1.7:1.0/0003:29BD:4103.0002/input/input4
[ 2.942536] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 138
[ 2.944110] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.944138] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.963171] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.963171]
[ 2.963265] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[ 2.963265]
[ 2.963281] e2fsck: Superblock last mount time is in the future.
[ 2.963281]
[ 2.963296] e2fsck: (by less than a day, probably due to the hardware clock being incorrectly set) Fix? yes
[ 2.963296]
[ 2.963311] e2fsck:
[ 2.963311]
[ 2.963326] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 22/8192 files, 1594/32768 blocks (check in 4 mounts)
[ 2.963326]
[ 2.966181] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.966305] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 2.967122] EXT4-fs (mmcblk1p12): Ignoring removed nomblk_io_submit option
[ 2.968800] EXT4-fs (mmcblk1p12): recovery complete
[ 2.968867] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.969145] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 2.984046] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 2.984116] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 2.985668] random: e2fsck: uninitialized urandom read (40 bytes read, 54 bits of entropy available)
[ 2.992144] hid-multitouch 0003:29BD:4103.0002: input,hiddev0,hidraw1: USB HID v1.00 Mouse [Royole Corporation Royole Multi-touch] on usb-fe3c0000.usb-1.7/input0
[ 2.998297] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.998297]
[ 2.998472] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.998472]
[ 3.002988] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.003203] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 3.005144] EXT4-fs (mmcblk1p16): Ignoring removed nomblk_io_submit option
[ 3.202781] EXT4-fs (mmcblk1p16): recovery complete
[ 3.203454] EXT4-fs (mmcblk1p16): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 3.203765] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/userdata,/data,ext4)=0: Success
[ 3.231243] fs_mgr: check_fs(): unmount(/data) succeeded
[ 3.231449] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 3.234671] random: e2fsck: uninitialized urandom read (40 bytes read, 76 bits of entropy available)
[ 3.287964] phy phy-ff770000.syscon:usb2-phy@e450.0: charger = USB_SDP_CHARGER
[ 3.289329] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 3.709385] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 3.709385]
[ 3.709461] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/userdata has been mounted 10 times without being checked, check forced.
[ 3.709461]
[ 3.709475] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 3.709475]
[ 3.709488] e2fsck: Pass 2: Checking directory structure
[ 3.709488]
[ 3.709500] e2fsck: Pass 3: Checking directory connectivity
[ 3.709500]
[ 3.709512] e2fsck: Pass 4: Checking reference counts
[ 3.709512]
[ 3.709563] e2fsck: Pass 5: Checking group summary information
[ 3.709563]
[ 3.709577] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/userdata: 2497/796544 files (10.1% non-contiguous), 280693/3186040 blocks
[ 3.709577]
[ 3.714716] EXT4-fs (mmcblk1p16): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 3.714931] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=ext4)=0
[ 3.721058] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 3.721335] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 3.721569] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 3.721935] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 3.722236] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 3.722488] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 3.722718] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 3.722938] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 3.723359] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 3.723682] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 3.723971] init: (Parsing /system/etc/init/gtinpu.rc took 0.00s.)
[ 3.724432] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 3.724836] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 3.725077] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 3.725356] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 3.726093] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 3.726555] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 3.726991] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 3.727447] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 3.727871] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 3.728093] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 3.728441] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 3.728882] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 3.729322] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 3.729526] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 3.729834] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 3.730307] init: ignored duplicate definition of service ‘ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 3.730590] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 3.730858] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 3.731149] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 3.731600] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 3.732080] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 3.734633] init: Starting service ‘logd’…
[ 3.739641] random: logd: uninitialized urandom read (40 bytes read, 100 bits of entropy available)
[ 3.745760] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directory
[ 3.771225] logd.auditd: start
[ 3.771313] logd.klogd: 3768867855
[ 3.820705] midgard_kbase: disagrees about version of symbol module_layout
[ 3.822988] init: finit_module for “/system/lib/modules/mali_kbase.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 3.827392] zram0: detected capacity change from 0 to 533413888
[ 3.830957] random: mkswap: uninitialized urandom read (40 bytes read, 106 bits of entropy available)
[ 3.846140] random: mkswap: uninitialized urandom read (16 bytes read, 107 bits of entropy available)
[ 3.847385] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.849801] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 3.850198] init: property_set(“ro.rk.screenoff_time”, “60000”) failed
[ 3.850357] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 3.850477] init: (Loading properties from /system/build.prop took 0.00s.)
[ 3.850532] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 3.850569] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 3.850668] fs_mgr: Warning: unknown flag resize
[ 3.850749] init: /recovery not specified in fstab
[ 3.851188] init: Starting service ‘debuggerd’…
[ 3.851906] init: Starting service ‘debuggerd64’…
[ 3.852940] init: Starting service ‘vold’…
[ 3.854557] random: debuggerd64: uninitialized urandom read (40 bytes read, 107 bits of entropy available)
[ 3.855176] init: Not bootcharting.
[ 3.860993] random: debuggerd: uninitialized urandom read (40 bytes read, 108 bits of entropy available)
[ 3.863038] random: vold: uninitialized urandom read (40 bytes read, 108 bits of entropy available)
[ 3.897528] random: vdc: uninitialized urandom read (40 bytes read, 112 bits of entropy available)
[ 3.953731] fs_mgr: Warning: unknown flag resize
[ 3.984017] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 3.994651] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 254) exited with status 0
[ 3.998420] type=1400 audit(1358499006.010:7): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“mmcblk1p16” ino=186945 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=
[ 4.002048] EXT4-fs (mmcblk1p16): Unrecognized mount option “background_gc=on” or missing value
[ 4.005112] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 4.005523] init: (Loading properties from /data/local.prop took 0.00s.)
[ 4.096614] init: Starting service ‘logd-reinit’…
[ 4.097635] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 4.099396] init: Starting service ‘healthd’…
[ 4.099924] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 4.100350] init: Starting service ‘earlylogs’…
[ 4.101248] init: Starting service ‘lmkd’…
[ 4.102158] init: Starting service ‘servicemanager’…
[ 4.105012] binder: 257:257 transaction failed 29189/-22, size 0-0 line 2948
[ 4.105378] init: Starting service ‘surfaceflinger’…
[ 4.107819] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 4.109442] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 4.111731] init: Starting service ‘exec 2 (/system/bin/busybox)’…
[ 4.112703] init: Service ‘earlylogs’ (pid 258) exited with status 0
[ 4.122906] init: Service ‘exec 2 (/system/bin/busybox)’ (pid 262) exited with status 0
[ 4.126207] init: Starting service ‘fsud’…
[ 4.126762] init: Starting service ‘vm_daemon’…
[ 4.128610] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 4.128653] init: write: cannot expand ‘${ro.serialno}’
[ 4.130521] file system registered
[ 4.134363] random: nonblocking pool is initialized
[ 4.135346] using random self ethernet address
[ 4.135412] using random host ethernet address
[ 4.136253] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 4.138965] type=1400 audit(1358499006.133:8): avc: denied { read } for pid=262 comm=“busybox” name=“ttysWK1” dev=“tmpfs” ino=8343 scontext=u:r
s0 tcontext=u:object_r:device:s0 tclass=chr_f
[ 4.145871] logd.daemon: reinit
[ 4.146756] type=1400 audit(1358499006.133:9): avc: denied { open } for pid=262 comm=“busybox” path=“/dev/ttysWK1” dev=“tmpfs” ino=8343 scontext=u:r
[ 4.146968] type=1400 audit(1358499006.133:10): avc: denied { ioctl } for pid=262 comm=“busybox” path=“/dev/ttysWK1” dev=“tmpfs” ino=8343 ioctlcmd=5401 scontext=u:r
[ 4.147149] type=1400 audit(1358499006.136:11): avc: denied { relabelto } for pid=1 comm=“init” name=“recovery” dev=“tmpfs” ino=8468 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block_device:s0 tclass=lnk_f
[ 4.147249] type=1400 audit(1358499006.136:12): avc: denied { relabelto } for pid=1 comm=“init” name=“boot” dev=“tmpfs” ino=8464 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:s0 tclass=lnk_f
[ 4.147321] type=1400 audit(1358499006.140:13): avc: denied { getattr } for pid=1 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk1p10” ino=2876 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 4.147431] type=1400 audit(1358499006.140:14): avc: denied { execute } for pid=264 comm=“init” name=“fsu” dev=“mmcblk1p10” ino=2876 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 4.147737] type=1400 audit(1358499006.140:15): avc: denied { read open } for pid=264 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk1p10” ino=2876 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 4.147841] type=1400 audit(1358499006.140:16): avc: denied { transition } for pid=264 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk1p10” ino=2876 scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=proc
[ 4.147913] type=1400 audit(1358499006.140:17): avc: denied { entrypoint } for pid=264 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk1p10” ino=2876 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 4.148000] type=1400 audit(1358499006.140:20): avc: denied { rlimitinh } for pid=264 comm=“fsu” scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=proc
[ 4.148095] type=1400 audit(1358499006.140:21): avc: denied { siginh } for pid=264 comm=“fsu” scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=proc
[ 4.148165] type=1400 audit(1358499006.140:22): avc: denied { noatsecure } for pid=264 comm=“fsu” scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=proc
[ 4.148236] type=1400 audit(1358499006.146:26): avc: denied { read } for pid=264 comm=“fsu” path=“/system/xbin/fsu” dev=“mmcblk1p10” ino=2876 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 4.148334] type=1400 audit(1358499006.146:27): avc: denied { write } for pid=264 comm=“fsu” name=“/” dev=“tmpfs” ino=16068 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:device:s0 tclass=
[ 4.148404] type=1400 audit(1358499006.146:28): avc: denied { add_name } for pid=264 comm=“fsu” name=“com.koushikdutta.superuser.daemon” scontext=u:r:systemdaemon:s0 tcontext=u:object_r:device:s0 tclass=
[ 4.148500] type=1400 audit(1358499006.146:29): avc: denied { create } for pid=264 comm=“fsu” name=“com.koushikdutta.superuser.daemon” scontext=u:r:systemdaemon:s0 tcontext=u:object_r:device:s0 tclass=
[ 4.148571] type=1400 audit(1358499006.146:30): avc: denied { create } for pid=264 comm=“fsu” name=“server” scontext=u:r:systemdaemon:s0 tcontext=u:object_r:device:s0 tclass=sock_f
[ 4.148642] type=1400 audit(1358499006.146:31): avc: denied { setattr } for pid=264 comm=“fsu” name=“com.koushikdutta.superuser.daemon” dev=“tmpfs” ino=9833 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:device:s0 tclass=
[ 4.148738] type=1400 audit(1358499006.146:32): avc: denied { setattr } for pid=264 comm=“fsu” name=“server” dev=“tmpfs” ino=9834 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:device:s0 tclass=sock_f
[ 4.150480] init: Service ‘logd-reinit’ (pid 256) exited with status 0
[ 4.155089] type=1400 audit(1358499006.166:41): avc: denied { setattr } for pid=1 comm=“init” name=“mmcblk1p13” dev=“tmpfs” ino=8497 scontext=u:r:init:s0 tcontext=u:object_r:block_device:s0 tclass=blk_f
[ 4.155224] type=1400 audit(1358499006.166:42): avc: denied { setattr } for pid=1 comm=“init” name=“mmcblk1p13” dev=“tmpfs” ino=8500 scontext=u:r:init:s0 tcontext=u:object_r:block_device:s0 tclass=lnk_f
[ 4.160846] init: Starting service ‘console’…
[ 4.162063] init: Starting service ‘adbd’…
[ 4.169925] init: Starting service ‘ap_log_srv’…
[ 4.170837] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 3 (/system/bin/update_verifier)’
[ 4.171364] init: Starting service ‘ril-daemon’…
[ 4.171966] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 4.172512] init: Starting service ‘drmservice’…
[ 4.173258] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 4.174996] init: Starting service ‘up_eth0’…
[ 4.175518] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 4.176056] init: Starting service ‘akmd’…
[ 4.177029] init: Starting service ‘zygote’…
[ 4.177889] init: Starting service ‘zygote_secondary’…
[ 4.178801] init: Starting service ‘audioserver’…
[ 4.179820] init: Starting service ‘cameraserver’…
[ 4.181052] init: Starting service ‘drm’…
[ 4.182088] init: Starting service ‘installd’…
[ 4.182819] audit: audit_lost=1 audit_rate_limit=20 audit_backlog_limit=64
[ 4.183002] type=rk3399_firefly_aio:/ $ 1400 audit(1358499006.196:43): avc: denied { create } for pid=273 comm=“busybox” scontext=u:r
s0 tcontext=u:r
s0 tclass=udp_soc
[ 4.183045] audit: rate limit exceeded
[ 4.183594] type=1400 audit(1358499006.196:44): avc: denied { net_raw } for pid=273 comm=“busybox” capability=13 scontext=u:r
s0 tcontext=u:r
s0 tclass=capabil
[ 4.183703] type=1400 audit(1358499006.196:45): avc: denied { ioctl } for pid=273 comm=“busybox” path=“socket:[9867]” dev=“sockfs” ino=9867 ioctlcmd=8913 scontext=u:r
s0 tcontext=u:r
s0 tclass=udp_soc
[ 4.183731] init: Starting service ‘keystore’…
[ 4.184692] init: Starting service ‘mediacodec’…
[ 4.186452] init: Starting service ‘mediadrm’…
[ 4.187177] init: couldn’t write 278 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 4.187296] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: a6:93:80:ba:94:ff
[ 4.187311] eth0: device MAC address a6:93:80:ba:94:ff
[ 4.187629] init: Starting service ‘mediaextractor’…
[ 4.188767] init: Starting service ‘media’…
[ 4.192158] init: Starting service ‘netd’…
[ 4.192951] init: Starting service ‘crashlogd’…
[ 4.193582] init: Starting service ‘log-watch’…
[ 4.194345] init: Starting service ‘gatekeeperd’…
[ 4.195430] init: Starting service ‘perfprofd’…
[ 4.199033] init: Service ‘up_eth0’ (pid 273) exited with status 0
[ 4.291938] ret = ffffffffffffffff
[ 4.304011] init: Service ‘akmd’ (pid 274) exited with status 254
[ 4.304415] init: avc: denied { set } for property=telephony.lteOnCdmaDevice pid=271 uid=0 gid=1001 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 4.304757] init: Starting service ‘apk_logfs’…
[ 4.305530] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sys.serialno}’
[ 4.305547] init: setprop: cannot expand ‘${sys.serialno}’
[ 4.313992] init: Service ‘ap_log_srv’ (pid 269) exited with status 0
[ 4.315512] init: Service ‘drmservice’ (pid 272) exited with status 0
[ 4.371500] read descriptors
[ 4.371535] read strings
[ 4.520081] init: Untracked pid 342 exited with status 0
[ 4.586975] init: Untracked pid 355 exited with status 0
[ 4.633186] E:camsys_i2c_write(84): i2c write dev(addr:0x36) failed!,err = -6
[ 4.633272] E:camsys_i2c_write(84): i2c write dev(addr:0x80) failed!,err = -6
[ 4.633546] init: Untracked pid 369 exited with status 0
[ 4.649086] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 4.649099] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 4.649158] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.654410] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 4.654437] E:camsys_mrv_iomux_cb(128): pinctrl_select_state failed!
[ 4.669914] E:camsys_i2c_write(84): i2c write dev(addr:0x46) failed!,err = -6
[ 4.669996] E:camsys_i2c_write(84): i2c write dev(addr:0x80) failed!,err = -6
[ 4.680703] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 4.680719] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 4.680725] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.680730] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 4.680735] E:camsys_mrv_iomux_cb(128): pinctrl_select_state failed!
[ 4.691407] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.691487] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.712546] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 4.712650] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 4.719410] init: Untracked pid 380 exited with status 0
[ 4.727483] android_work: did not send uevent (0 0 (null))
[ 4.734313] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.734410] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.781802] E:camsys_i2c_write(84): i2c write dev(addr:0x36) failed!,err = -6
[ 4.781941] E:camsys_i2c_write(84): i2c write dev(addr:0x80) failed!,err = -6
[ 4.792335] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 4.792356] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 4.792366] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.792374] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 4.792380] E:camsys_mrv_iomux_cb(128): pinctrl_select_state failed!
[ 4.803431] E:camsys_i2c_write(84): i2c write dev(addr:0x46) failed!,err = -6
[ 4.803532] E:camsys_i2c_write(84): i2c write dev(addr:0x80) failed!,err = -6
[ 4.824728] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.824825] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.833489] W:camsys_extdev_deregister(334): Extdev(dev_id: 0x2000000) isn’t registered in camsys_marvin1!
[ 4.845615] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 4.845714] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 4.852397] android_work: sent uevent USB_STATE=CONNECTED
[ 4.853363] configfs-gadget gadget: high-speed config #1: b
[ 4.853450] android_work: sent uevent USB_STATE=CONFIGURED
[ 4.854417] W:camsys_extdev_deregister(334): Extdev(dev_id: 0x1000000) isn’t registered in camsys_marvin!
[ 4.868548] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.868643] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.881582] W:camsys_extdev_deregister(334): Extdev(dev_id: 0x1000000) isn’t registered in camsys_marvin!
[ 4.919828] E:camsys_i2c_write(84): i2c write dev(addr:0x36) failed!,err = -6
[ 4.919928] E:camsys_i2c_write(84): i2c write dev(addr:0x80) failed!,err = -6
[ 4.931271] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 4.931296] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 4.931305] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.931314] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 4.931321] E:camsys_mrv_iomux_cb(128): pinctrl_select_state failed!
[ 4.942089] E:camsys_i2c_write(84): i2c write dev(addr:0x46) failed!,err = -6
[ 4.942173] E:camsys_i2c_write(84): i2c write dev(addr:0x80) failed!,err = -6
[ 4.964828] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.964914] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.973547] W:camsys_extdev_deregister(334): Extdev(dev_id: 0x2000000) isn’t registered in camsys_marvin1!
[ 4.985129] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 4.985220] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 4.993960] W:camsys_extdev_deregister(334): Extdev(dev_id: 0x1000000) isn’t registered in camsys_marvin!
[ 5.005655] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 5.005818] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 5.014570] W:camsys_extdev_deregister(334): Extdev(dev_id: 0x1000000) isn’t registered in camsys_marvin!
[ 5.106930] healthd: BatteryCurrentNowPath not found
[ 5.106952] healthd: BatteryCycleCountPath not found
[ 5.410997] init: Starting service ‘bootanim’…
[ 5.413420] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1280x720p60, type: 11
[ 5.568841] audit: audit_lost=41 audit_rate_limit=20 audit_backlog_limit=64
[ 5.568858] audit: rate limit exceeded
[ 5.810044] init: Untracked pid 372 exited with status 1
[ 5.810619] init: Untracked pid 384 exited with status 1
[ 5.813297] init: Untracked pid 345 exited with status 1
[ 5.814582] init: Untracked pid 360 exited with status 1
[ 6.015561] capability: warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 9.224841] acc_open
[ 9.224885] acc_release
[ 10.331307] type=1400 audit(1358499012.343:120): avc: denied { search } for pid=286 comm=“Binder:286_1” name=“505” dev=“proc” ino=17897 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=
[ 10.331545] type=1400 audit(1358499012.343:121): avc: denied { read } for pid=286 comm=“Binder:286_1” name=“cmdline” dev=“proc” ino=11783 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=f
[ 10.331690] type=1400 audit(1358499012.343:122): avc: denied { open } for pid=286 comm=“Binder:286_1” path=“/proc/505/cmdline” dev=“proc” ino=11783 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=f
[ 10.446969] sdcardfs version 2.0
[ 10.447066] sdcardfs: dev_name → /data/media
[ 10.447081] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,mask=6,userid=0,gid=1015
[ 10.447088] sdcardfs: mnt → ffffffc00a30ce20
[ 10.447268] sdcardfs: mounted on top of /data/media type ext4
[ 10.448059] sdcardfs version 2.0
[ 10.448231] sdcardfs: dev_name → /data/media
[ 10.448245] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,mask=23,userid=0,gid=9997
[ 10.448252] sdcardfs: mnt → ffffffc05081c560
[ 10.448296] sdcardfs: mounted on top of /data/media type ext4
[ 10.448982] sdcardfs version 2.0
[ 10.449012] sdcardfs: dev_name → /data/media
[ 10.449018] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,mask=7,userid=0,gid=9997
[ 10.449026] sdcardfs: mnt → ffffffc05081d360
[ 10.449068] sdcardfs: mounted on top of /data/media type ext4
[ 10.935751] type=1400 audit(1358499012.946:123): avc: denied { execute } for pid=1019 comm=“ActivityManager” name=“sh” dev=“mmcblk1p10” ino=428 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 10.936635] type=1400 audit(1358499012.946:124): avc: denied { read open } for pid=1019 comm=“ActivityManager” path=“/system/bin/sh” dev=“mmcblk1p10” ino=428 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 10.936809] type=1400 audit(1358499012.946:125): avc: denied { execute_no_trans } for pid=1019 comm=“ActivityManager” path=“/system/bin/sh” dev=“mmcblk1p10” ino=428 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 10.937170] type=1400 audit(1358499012.950:126): avc: denied { getattr } for pid=1019 comm=“sh” path=“/system/bin/sh” dev=“mmcblk1p10” ino=428 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 10.954203] audit: audit_lost=55 audit_rate_limit=20 audit_backlog_limit=64
[ 10.954227] audit: rate limit exceeded
[ 10.980298] init: Untracked pid 1025 exited with status 0
[ 11.028260] init: Untracked pid 1037 exited with status 0
[ 11.550702] init: Untracked pid 1028 exited with status 0
[ 11.688244] E:camsys_i2c_write(84): i2c write dev(addr:0x36) failed!,err = -6
[ 11.688325] E:camsys_i2c_write(84): i2c write dev(addr:0x80) failed!,err = -6
[ 11.698724] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 11.698814] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 11.699022] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 11.699037] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 11.699045] E:camsys_mrv_iomux_cb(128): pinctrl_select_state failed!
[ 11.710118] E:camsys_i2c_write(84): i2c write dev(addr:0x46) failed!,err = -6
[ 11.710197] E:camsys_i2c_write(84): i2c write dev(addr:0x80) failed!,err = -6
[ 11.728159] init: Untracked pid 1040 exited with status 0
[ 11.732777] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 11.733164] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 11.741884] W:camsys_extdev_deregister(334): Extdev(dev_id: 0x2000000) isn’t registered in camsys_marvin1!
[ 11.753879] E:camsys_i2c_write(84): i2c write dev(addr:0x1f) failed!,err = -6
[ 11.753976] E:camsys_i2c_write(84): i2c write dev(addr:0x3f) failed!,err = -6
[ 11.762649] W:camsys_extdev_deregister(334): Extdev(dev_id: 0x1000000) isn’t registered in camsys_marvin!
[ 11.774840] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 11.774928] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 11.783604] W:camsys_extdev_deregister(334): Extdev(dev_id: 0x1000000) isn’t registered in camsys_marvin!
[ 12.253081] init: cannot find ‘/system/bin/glgps’ (No such file or directory), disabling ‘gpsd’
[ 12.253192] init: Starting service ‘mode_switch’…
[ 12.253785] init: Starting service ‘tp_mode_switch’…
[ 12.254062] audit: audit_lost=87 audit_rate_limit=20 audit_backlog_limit=64
[ 12.254072] audit: rate limit exceeded
[ 12.254553] init: Starting service ‘exec 4 (/system/bin/gti_npu_permission.sh)’…
[ 12.281606] init: Service ‘tp_mode_switch’ (pid 1174) exited with status 1
[ 12.431260] init: Service ‘exec 4 (/system/bin/gti_npu_permission.sh)’ (pid 1175) exited with status 0
[ 12.431652] init: Starting service ‘exec 5 (/system/bin/bootstat)’…
[ 12.449799] init: Service ‘exec 5 (/system/bin/bootstat)’ (pid 1213) exited with status 0
[ 12.450036] init: Starting service ‘exec 6 (/system/bin/bootstat)’…
[ 12.463742] init: Service ‘exec 6 (/system/bin/bootstat)’ (pid 1214) exited with status 0
[ 12.464195] init: Starting service ‘exec 7 (/system/bin/bootstat)’…
[ 12.475864] rockchip-dwc3 usb@fe800000: Peripheral disconnect exception
[ 12.476121] dwc3 fe800000.dwc3: dwc3 gadget stop timeout
[ 12.476184] android_work: sent uevent USB_STATE=DISCONNECTED
[ 12.476200] android_work: did not send uevent (0 0 (null))
[ 12.476212] rockchip-dwc3 usb@fe800000: USB unconnected
[ 12.480394] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 12.480429] rockchip-dwc3 usb@fe800000: set new mode successfully
[ 12.480746] rockchip-dwc3 usb@fe900000: Not support set mode!
[ 12.481504] init: Service ‘mode_switch’ (pid 1173) exited with status 1
[ 12.485619] type=1400 audit(1358499014.493:228): avc: denied { getattr } for pid=1173 comm=“usb_mode_switch” path=“/sys/devices/platform/usb@fe900000/dwc3_mode” dev=“sysfs” ino=21434 scontext=u:r:mode_switch:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 12.488582] type=1400 audit(1358499014.493:229): avc: denied { write } for pid=1173 comm=“usb_mode_switch” name=“dwc3_mode” dev=“sysfs” ino=21434 scontext=u:r:mode_switch:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 12.488843] init: Service ‘exec 7 (/system/bin/bootstat)’ (pid 1216) exited with status 0
[ 12.489378] init: Starting service ‘exec 8 (/system/bin/bootstat)’…
[ 12.492610] type=1400 audit(1358499014.493:230): avc: denied { open } for pid=1173 comm=“usb_mode_switch” path=“/sys/devices/platform/usb@fe900000/dwc3_mode” dev=“sysfs” ino=21434 scontext=u:r:mode_switch:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 12.500406] init: Service ‘exec 8 (/system/bin/bootstat)’ (pid 1236) exited with status 0
[ 12.501848] android_work: did not send uevent (0 0 (null))
[ 12.501916] configfs-gadget gadget: unbind function ‘mtp’/ffffffc07a365000
[ 12.502144] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc07a3d9438
[ 12.847536] android_work: did not send uevent (0 0 (null))
[ 12.972122] android_work: sent uevent USB_STATE=CONNECTED
[ 12.973096] configfs-gadget gadget: high-speed config #1: b
[ 12.973684] android_work: sent uevent USB_STATE=CONFIGURED
[ 13.231328] mtp_open
[ 13.337967] type=1400 audit(1358499015.350:231): avc: denied { open } for pid=1429 comm=“getprop” path=“/dev/properties/u:object_r:secureboot_prop:s0” dev=“tmpfs” ino=16076 scontext=u:r
s0 tcontext=u:object_r:secureboot_prop:s0 tclass=f
[ 13.338474] type=1400 audit(1358499015.350:232): avc: denied { getattr } for pid=1429 comm=“getprop” path=“/dev/properties/u:object_r:secureboot_prop:s0” dev=“tmpfs” ino=16076 scontext=u:r
[ 13.338583] type=1400 audit(1358499015.350:233): avc: denied { open } for pid=1429 comm=“getprop” path=“/dev/properties/u:object_r:pppoe_prop:s0” dev=“tmpfs” ino=16077 scontext=u:r
s0 tcontext=u:object_r:pppoe_prop:s0 tclass=f
[ 13.338707] type=1400 audit(1358499015.350:234): avc: denied { getattr } for pid=1429 comm=“getprop” path=“/dev/properties/u:object_r:pppoe_prop:s0” dev=“tmpfs” ino=16077 scontext=u:r
[ 14.423403] type=1400 audit(1358499016.436:235): avc: granted { search } for pid=1368 comm=“.update.service” name=“recovery” dev=“mmcblk1p9” ino=12 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:cache_recovery_fi
[ 15.051518] init: Untracked pid 1514 exited with status 0
[ 15.080093] init: Untracked pid 1522 exited with status 0
[ 15.103598] init: avc: denied { set } for property=devicetest.bootcomplete pid=1436 uid=1000 gid=1000 scontext=u:r:system_app:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 15.376851] audit: audit_lost=123 audit_rate_limit=20 audit_backlog_limit=64
[ 15.376870] audit: rate limit exceeded
[ 15.497676] init: Service ‘bootanim’ is being killed…
[ 15.535535] init: Service ‘bootanim’ (pid 441) killed by signal 9
[ 16.061803] init: Untracked pid 1525 exited with status 0
[ 16.063123] init: Untracked pid 1517 exited with status 0
