log如下:
DDR Version 1.24 20191016
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 337
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68414
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT 0x3335db8 signature is wrong
recovery gpt…
recovery gpt fail!
Trust Addr:0x4000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x87154
RunBL31 0x40000 @ 94327 us
NOTICE: BL31: v1.3(release):af49f67
NOTICE: BL31: Built : 16:55:08, May 19 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1191): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-256-gebb61ff5 #4 Wed Apr 22 01:34:02 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Apr 14 2021 - 18:15:57)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
rockusb key: key_rockusb.key.adc.keyValueLow = 0, key_rockusb.key.adc.keyValueHigh = 30
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=975000,pwm_value=58
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 2021-04-14#1.26
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find panel driver
no fuel gauge found
Monitor has basic audio support
drm_rk_selete_output; fail get baseparameter
rk lcdc - 0 dclk set: dclk = 148500000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
CEA mode used vic=16
dw_hdmi_setup HDMI mode
rockchip_panel_enable: failed to find panel prepare funcs
failed to display kernel logo
load fdt from resouce.
hwversion: disabled!
Secure Boot state: 0
kernel @ 0x00280000 (0x01377808)
ramdisk @ 0x04bf0000 (0x001e7864)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004616f30 … OK
Add bank:000000000a200000, 0000000075e00000
[ 0.000000] Linux version 4.4.126 (user@spd) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP PREEMPT Sun Apr 11 15:28:21 HKT 2021
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef7000 s45592 r8192 d32232 u86016
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00300000@0x000C4000(system),0x00100000@0x003C4000(oem),0x00008000@0x004C4000(metadata),0x00000040@0x004CC000(verity_mode),0x00002000@0x004CC040(reserved),0x00000400@0x004CE040(frp),-@0x004CE440(userdata) storagemedia=emmc androidboot.oem_unlocked=0 uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2021-04-14_18:15:57 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7eeae000-0x7eeee000] (0MB) mapped at [ffffffc07eeae000-ffffffc07eeedfff]
[ 0.000000] Memory: 1985880K/2064384K available (11518K kernel code, 1758K rwdata, 5760K rodata, 832K init, 2390K bss, 62120K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009170000 - 0xffffff8009240000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bc0000 ( 11520 KB)
[ 0.000000] .rodata : 0xffffff8008bc0000 - 0xffffff8009170000 ( 5824 KB)
[ 0.000000] .data : 0xffffff8009240000 - 0xffffff80093f7808 ( 1759 KB)
[ 0.001846] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002797] pid_max: default: 32768 minimum: 301
[ 0.003279] Security Framework initialized
[ 0.003661] SELinux: Initializing.
[ 0.004084] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004706] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006084] Initializing cgroup subsys memory
[ 0.006511] Initializing cgroup subsys freezer
[ 0.007760] sched-energy: Sched-energy-costs installed from DT
[ 0.008300] CPU0: update cpu_capacity 401
[ 0.008742] ASID allocator initialised with 32768 entries
[ 0.025598] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.026784] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.038988] Detected VIPT I-cache on CPU1
[ 0.039016] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039048] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039085] CPU1: update cpu_capacity 401
[ 0.039089] CPU1: Booted secondary processor [410fd034]
[ 0.048978] Detected VIPT I-cache on CPU2
[ 0.048997] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049029] CPU2: using LPI pending table @0x000000007c020000
[ 0.049053] CPU2: update cpu_capacity 401
[ 0.049057] CPU2: Booted secondary processor [410fd034]
[ 0.059012] Detected VIPT I-cache on CPU3
[ 0.059030] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059061] CPU3: using LPI pending table @0x000000007c060000
[ 0.059084] CPU3: update cpu_capacity 401
[ 0.059087] CPU3: Booted secondary processor [410fd034]
[ 0.069058] Detected PIPT I-cache on CPU4
[ 0.069082] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069115] CPU4: using LPI pending table @0x000000007c0b0000
[ 0.069149] CPU4: update cpu_capacity 1024
[ 0.069152] CPU4: Booted secondary processor [410fd082]
[ 0.079087] Detected PIPT I-cache on CPU5
[ 0.079104] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079135] CPU5: using LPI pending table @0x000000007c0e0000
[ 0.079160] CPU5: update cpu_capacity 1024
[ 0.079163] CPU5: Booted secondary processor [410fd082]
[ 0.079242] Brought up 6 CPUs
[ 0.091195] SMP: Total of 6 processors activated.
[ 0.091630] CPU features: detected feature: GIC system register CPU interface
[ 0.092292] CPU: All CPU(s) started at EL2
[ 0.092705] alternatives: patching kernel code
[ 0.094989] devtmpfs: initialized
[ 0.115244] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116201] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117470] pinctrl core: initialized pinctrl subsystem
[ 0.119454] Failed to find legacy iommu devices
[ 0.120251] NET: Registered protocol family 16
[ 0.121087] schedtune: init normalization constants…
[ 0.121583] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.122208] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.122832] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123467] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124091] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.124716] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125339] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.125962] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.126585] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127215] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.127945] schedtune: verify normalization constants…
[ 0.128453] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.128985] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.129517] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130049] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.130587] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131119] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.131651] schedtune: configured to support 5 boost groups
[ 0.140628] cpuidle: using governor ladder
[ 0.150628] cpuidle: using governor menu
[ 0.151018] Registered FIQ tty driver
[ 0.151754] vdso: 2 pages (1 code @ ffffff8008bc6000, 1 data @ ffffff8009244000)
[ 0.152479] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.154037] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.174240] console [pstore-1] enabled
[ 0.174829] pstore: Registered ramoops as persistent store backend
[ 0.175424] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.178417] fiq debugger fiq mode enabled
[[ 0.179063] console [ttyFIQ0] enabled
[ 0.179757] bootconsole [uart0] disabled
[ 0.180326] Registered fiq debugger ttyFIQ0
[ 0.213360] reg_fixed_voltage_probe vcc5v0_host sys/camera_test/vcc5v0_dbg
[ 0.215462] iommu: Adding device ff650000.vpu_service to group 0
[ 0.215534] iommu: Adding device ff660000.rkvdec to group 1
[ 0.215597] iommu: Adding device ff670000.iep to group 2
[ 0.215683] iommu: Adding device ff8f0000.vop to group 3
[ 0.215751] iommu: Adding device ff900000.vop to group 4
[ 0.215851] iommu: Adding device ff910000.isp to group 5
[ 0.215922] iommu: Adding device ff920000.isp to group 6
[ 0.216597] rk_iommu ff670800.iommu: can’t get aclk
[ 0.216611] rk_iommu ff670800.iommu: can’t get hclk
[ 0.217451] SCSI subsystem initialized
[ 0.222875] usbcore: registered new interface driver usbfs
[ 0.222921] usbcore: registered new interface driver hub
[ 0.222994] usbcore: registered new device driver usb
[ 0.223357] media: Linux media interface: v0.10
[ 0.223393] Linux video capture interface: v2.00
[ 0.223557] pps_core: LinuxPPS API ver. 1 registered
[ 0.223566] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.223584] PTP clock support registered
[ 0.230284] Advanced Linux Sound Architecture Driver Initialized.
[ 0.230749] Bluetooth: Core ver 2.21
[ 0.230782] NET: Registered protocol family 31
[ 0.230790] Bluetooth: HCI device and connection manager initialized
[ 0.230802] Bluetooth: HCI socket layer initialized
[ 0.230813] Bluetooth: L2CAP socket layer initialized
[ 0.230837] Bluetooth: SCO socket layer initialized
[ 0.231470] rockchip-cpuinfo cpuinfo: Serial : 8ed4ada1cbe0f445
[ 0.231994] clocksource: Switched to clocksource arch_sys_counter
[ 0.275678] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.275879] NET: Registered protocol family 2
[ 0.276288] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.276430] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.276708] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.276777] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.276835] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.277001] NET: Registered protocol family 1
[ 0.277820] Trying to unpack rootfs image as initramfs…
[ 0.375793] Freeing initrd memory: 1948K
[ 0.376354] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.376439] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.378758] audit: initializing netlink subsys (disabled)
[ 0.378817] audit: type=2000 audit(0.376:1): initialized
[ 0.387131] VFS: Disk quotas dquot_6.6.0
[ 0.387254] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.388290] Registering sdcardfs 0.1
[ 0.392192] fuse init (API version 7.23)
[ 0.393233]
[ 0.393233] TEE Core Framework initialization (ver 1:0.1)
[ 0.393258] TEE armv7 Driver initialization
[ 0.393605] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.393620] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.393794] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.396867] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.396890] io scheduler noop registered
[ 0.397050] io scheduler cfq registered (default)
[ 0.399434] phy phy-ff770000.syscon:usb2-phy@e460.2: Failed to get VBUS supply regulator
[ 0.402510] ace test_init function.
[ 0.402660] ace test_init end.ret=0
[ 0.402996] radar end.ret=0
[ 0.405148] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.405171] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.448683] rockchip-pcie f8000000.pcie: invalid power supply
[ 0.948736] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.948982] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.949913] iep: failed to find iep power down clock source.
[ 0.950519] IEP Power ON
[ 0.950758] IEP Power OFF
[ 0.950897] IEP Driver loaded succesfully
[ 0.951209] Module initialized.
[ 0.951592] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.951842] rk-vcodec ff650000.vpu_service: probe device
[ 0.952094] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.952655] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.952681] rk-vcodec ff650000.vpu_service: init success
[ 0.952920] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.953380] rk-vcodec ff660000.rkvdec: probe device
[ 0.953579] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.953980] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.954000] rk-vcodec ff660000.rkvdec: init success
[ 0.955887] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.955907] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.957236] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.957253] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.959074] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.959592] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 0.960024] [drm] Initialized drm 1.1.0 20060810
[ 0.963313] [drm] Rockchip DRM driver version: v1.0.0
[ 0.963611] rockchip-drm display-subsystem: defer getting devfreq
[ 0.963880] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.964125] rockchip-vop ff900000.vop: unable to request PWM
[ 0.964153] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.964191] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.964363] rockchip-vop ff8f0000.vop: unable to request PWM
[ 0.964382] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.964605] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.964624] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.964723] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.965401] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.965413] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.965438] [drm] No driver support for vblank timestamp query.
[ 1.826792] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.842338] mali ff9a0000.gpu: Failed to get regulator
[ 1.842376] mali ff9a0000.gpu: Power control initialization failed
[ 1.842677] Unable to detect cache hierarchy for CPU 0
[ 1.860245] brd: module loaded
[ 1.865051] loop: module loaded
[ 1.865624] zram: Added device: zram0
[ 1.866297] Loading dl1825 driver
[ 1.866731] SCSI Media Changer driver v0.25
[ 1.867560] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.867577] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.867588] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.868357] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 2.038717] wk2xxx_serial_init()
[ 2.038731] wk2xxx_request_port
[ 2.038743] ttysWK0 at I/O 0x1 (irq = 101, base_baud = 460800) is a wk2xxx
[ 2.038940] uart_add_one_port success for line i:= 0 with right 0
[ 2.038952] wk2xxx_request_port
[ 2.038962] ttysWK1 at I/O 0x2 (irq = 101, base_baud = 460800) is a wk2xxx
[ 2.039144] uart_add_one_port success for line i:= 1 with right 0
[ 2.039156] wk2xxx_request_port
[ 2.039165] ttysWK2 at I/O 0x3 (irq = 101, base_baud = 460800) is a wk2xxx
[ 2.039346] uart_add_one_port success for line i:= 2 with right 0
[ 2.039356] wk2xxx_request_port
[ 2.039366] ttysWK3 at I/O 0x4 (irq = 101, base_baud = 460800) is a wk2xxx
[ 2.039542] uart_add_one_port success for line i:= 3 with right 0
[ 2.039553] uart_add_one_port = 0x0
[ 2.039577] register spi return v = :0
[ 2.039613] register firefly_spi_init spi return v = :0
[ 2.039671] tun: Universal TUN/TAP device driver, 1.6
[ 2.039681] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.040540] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 2.040646] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 2.040664] rk_gmac-dwmac fe300000.ethernet: TX delay(0x31).
[ 2.040675] rk_gmac-dwmac fe300000.ethernet: RX delay(0x24).
[ 2.040699] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 2.040866] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 2.040879] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 2.045893] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 2.046009] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.046020] Ring mode enabled
[ 2.046027] DMA HW capability register supported
[ 2.046034] Normal descriptors
[ 2.046043] RX Checksum Offload Engine supported (type 2)
[ 2.046049] Wake-Up On Lan supported
[ 2.046086] Enable RX Mitigation via HW Watchdog Timer
[ 2.122160] libphy: stmmac: probed
[ 2.122211] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 2.122226] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 2.122238] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 2.122250] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 2.122285] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 2.122296] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 2.122306] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 2.122316] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 2.122327] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 2.122337] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 2.122348] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 2.122358] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 2.122369] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 2.122379] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 2.122389] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 2.122400] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 2.122411] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 2.122421] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 2.122431] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 2.122441] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 2.122453] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 2.122464] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 2.122500] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 2.122511] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 2.122521] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 2.122532] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 2.122543] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 2.122553] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 2.122563] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 2.122574] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 2.122584] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 2.122594] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 2.124055] PPP generic driver version 2.4.2
[ 2.124324] PPP BSD Compression module registered
[ 2.124364] PPP Deflate Compression module registered
[ 2.124399] PPP MPPE Compression module registered
[ 2.124426] NET: Registered protocol family 24
[ 2.124502] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 2.124512] CSLIP: code copyright 1989 Regents of the University of California.
[ 2.124610] usbcore: registered new interface driver mt7601u
[ 2.124630] Rockchip WiFi SYS interface (V1.00) …
[ 2.124717] usbcore: registered new interface driver catc
[ 2.124797] usbcore: registered new interface driver kaweth
[ 2.124816] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.124866] usbcore: registered new interface driver pegasus
[ 2.124945] usbcore: registered new interface driver rtl8150
[ 2.125015] usbcore: registered new interface driver r8152
[ 2.125032] hso: drivers/net/usb/hso.c: Option Wireless
[ 2.125111] usbcore: registered new interface driver hso
[ 2.125197] usbcore: registered new interface driver asix
[ 2.125255] usbcore: registered new interface driver ax88179_178a
[ 2.125341] usbcore: registered new interface driver cdc_ether
[ 2.125424] usbcore: registered new interface driver cdc_eem
[ 2.125481] usbcore: registered new interface driver dm9601
[ 2.125552] usbcore: registered new interface driver smsc75xx
[ 2.125641] usbcore: registered new interface driver smsc95xx
[ 2.125705] usbcore: registered new interface driver gl620a
[ 2.125766] usbcore: registered new interface driver net1080
[ 2.125846] usbcore: registered new interface driver plusb
[ 2.125903] usbcore: registered new interface driver rndis_host
[ 2.125963] usbcore: registered new interface driver cdc_subset
[ 2.126042] usbcore: registered new interface driver zaurus
[ 2.126105] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.126189] usbcore: registered new interface driver int51x1
[ 2.126270] usbcore: registered new interface driver kalmia
[ 2.126327] usbcore: registered new interface driver ipheth
[ 2.126388] usbcore: registered new interface driver sierra_net
[ 2.126489] usbcore: registered new interface driver cx82310_eth
[ 2.126558] usbcore: registered new interface driver cdc_ncm
[ 2.126618] usbcore: registered new interface driver qmi_wwan
[ 2.126700] usbcore: registered new interface driver cdc_mbim
[ 2.133480] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[ 2.139669] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 2.141292] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.141338] ehci-pci: EHCI PCI platform driver
[ 2.141428] ehci-platform: EHCI generic platform driver
[ 2.145177] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.145464] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 2.145703] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.155376] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.155584] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.155631] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.155644] usb usb1: Product: EHCI Host Controller
[ 2.155656] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 2.155668] usb usb1: SerialNumber: fe380000.usb
[ 2.156301] hub 1-0:1.0: USB hub found
[ 2.156350] hub 1-0:1.0: 1 port detected
[ 2.160432] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.160693] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 2.160931] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.168703] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.168892] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.168929] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.168942] usb usb2: Product: EHCI Host Controller
[ 2.168954] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[ 2.168966] usb usb2: SerialNumber: fe3c0000.usb
[ 2.169537] hub 2-0:1.0: USB hub found
[ 2.169596] hub 2-0:1.0: 1 port detected
[ 2.170375] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.170432] ohci-platform: OHCI generic platform driver
[ 2.170838] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.171100] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 2.171301] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.226187] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.226225] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.226241] usb usb3: Product: Generic Platform OHCI controller
[ 2.226254] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[ 2.226267] usb usb3: SerialNumber: fe3a0000.usb
[ 2.226869] hub 3-0:1.0: USB hub found
[ 2.226931] hub 3-0:1.0: 1 port detected
[ 2.227583] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.227841] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 2.228018] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.282844] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.282882] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.282897] usb usb4: Product: Generic Platform OHCI controller
[ 2.282910] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[ 2.282923] usb usb4: SerialNumber: fe3e0000.usb
[ 2.283525] hub 4-0:1.0: USB hub found
[ 2.283585] hub 4-0:1.0: 1 port detected
[ 2.284939] usbcore: registered new interface driver cdc_acm
[ 2.284973] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.285050] usbcore: registered new interface driver usblp
[ 2.285114] usbcore: registered new interface driver cdc_wdm
[ 2.285181] usbcore: registered new interface driver uas
[ 2.285356] usbcore: registered new interface driver usb-storage
[ 2.285456] usbcore: registered new interface driver ums-alauda
[ 2.285511] usbcore: registered new interface driver ums-cypress
[ 2.285568] usbcore: registered new interface driver ums-datafab
[ 2.285653] usbcore: registered new interface driver ums_eneub6250
[ 2.285710] usbcore: registered new interface driver ums-freecom
[ 2.285765] usbcore: registered new interface driver ums-isd200
[ 2.285821] usbcore: registered new interface driver ums-jumpshot
[ 2.285897] usbcore: registered new interface driver ums-karma
[ 2.285950] usbcore: registered new interface driver ums-onetouch
[ 2.286007] usbcore: registered new interface driver ums-sddr09
[ 2.286093] usbcore: registered new interface driver ums-sddr55
[ 2.286147] usbcore: registered new interface driver ums-usbat
[ 2.286264] usbcore: registered new interface driver usbserial
[ 2.286337] usbcore: registered new interface driver usbserial_generic
[ 2.286375] usbserial: USB Serial support registered for generic
[ 2.286433] usbcore: registered new interface driver option
[ 2.286472] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.286754] usbcore: registered new interface driver trancevibrator
[ 2.286791] usb20_otg: version 3.10a 21-DEC-2012
[ 2.287079] usb20_host: version 3.10a 21-DEC-2012
[ 2.287549] usbip_core: USB/IP Core v1.0.0
[ 2.288010] mousedev: PS/2 mouse device common for all mice
[ 2.288365] usbcore: registered new interface driver xpad
[ 2.288458] usbcore: registered new interface driver usb_acecad
[ 2.288547] usbcore: registered new interface driver aiptek
[ 2.288610] usbcore: registered new interface driver gtco
[ 2.288698] usbcore: registered new interface driver hanwang
[ 2.288782] usbcore: registered new interface driver kbtab
[ 2.289212] usbcore: registered new interface driver usbtouchscreen
[ 2.289912] .. rk pwm remotectl v1.1 init
[ 2.290243] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.290789] sensor_register_slave:mma8452,id=17
[ 2.290822] sensor_register_slave:lis3dh,id=7
[ 2.290840] sensor_register_slave:mma7660,id=18
[ 2.290883] sensor_register_slave:lsm303d,id=22
[ 2.290898] sensor_register_slave:gs_mc3230,id=23
[ 2.290906] [Gsensor] gsensor_init
[ 2.290921] sensor_register_slave:mpu6880_acc,id=24
[ 2.290936] sensor_register_slave:mpu6500_acc,id=25
[ 2.290951] sensor_register_slave:lsm330_acc,id=26
[ 2.290966] sensor_register_slave:bma2xx_acc,id=27
[ 2.290981] sensor_register_slave:akm8975,id=30
[ 2.290996] sensor_register_slave:akm8963,id=31
[ 2.291011] sensor_register_slave:l3g4200d,id=45
[ 2.291025] sensor_register_slave:l3g20d,id=46
[ 2.291040] sensor_register_slave:ewtsa,id=47
[ 2.291057] sensor_register_slave:lsm330_gyro,id=51
[ 2.291099] sensor_register_slave:cm3217,id=53
[ 2.291115] sensor_register_slave:cm3218,id=54
[ 2.291130] sensor_register_slave:ls_stk3410,id=62
[ 2.291145] sensor_register_slave:ps_stk3410,id=67
[ 2.292243] i2c /dev entries driver
[ 2.293972] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.294089] fan53555-reg: supplied by vcc5v0_sys
[ 2.297206] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.297295] fan53555-reg: supplied by vcc5v0_sys
[ 2.299523] rockchip-pinctrl pinctrl: pin gpio1-18 already requested by 0-0040; cannot claim for 0-001b
[ 2.299562] rockchip-pinctrl pinctrl: pin-50 (0-001b) status -22
[ 2.299577] rockchip-pinctrl pinctrl: could not request pin 50 (gpio1-18) from group pmic-dvs2 on device rockchip-pinctrl
[ 2.299590] rk808 0-001b: Error applying setting, reverse things back
[ 2.300042] rk808 0-001b: Pmic Chip id: 0x0
[ 2.303715] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.303819] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.303960] DCDC_REG1: supplied by vcc3v3_sys
[ 2.304831] DCDC_REG2: supplied by vcc3v3_sys
[ 2.305529] DCDC_REG3: supplied by vcc3v3_sys
[ 2.305878] DCDC_REG4: supplied by vcc3v3_sys
[ 2.306430] LDO_REG1: supplied by vcc3v3_sys
[ 2.307666] LDO_REG2: supplied by vcc3v3_sys
[ 2.308795] LDO_REG3: supplied by vcc3v3_sys
[ 2.309889] LDO_REG4: supplied by vcc3v3_sys
[ 2.310791] vcc_sd: Failed to create debugfs directory
[ 2.310912] LDO_REG5: supplied by vcc3v3_sys
[ 2.311973] LDO_REG6: supplied by vcc3v3_sys
[ 2.313084] LDO_REG7: supplied by vcc3v3_sys
[ 2.314164] LDO_REG8: supplied by vcc3v3_sys
[ 2.315264] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.315665] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.316205] firefly_hwversion_in_range PS{\C0\FF\FF\FF: hwversion in range(0 conditions)
[ 2.319581] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.320214] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009ada000
[ 2.321128] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009adc000
[ 2.321837] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009ade000
[ 2.323196] IR NEC protocol handler initialized
[ 2.323237] IR RC5(x/sz) protocol handler initialized
[ 2.323254] IR RC6 protocol handler initialized
[ 2.323270] IR JVC protocol handler initialized
[ 2.323286] IR Sony protocol handler initialized
[ 2.323303] IR SANYO protocol handler initialized
[ 2.323320] IR Sharp protocol handler initialized
[ 2.323336] IR MCE Keyboard/mouse protocol handler initialized
[ 2.323353] IR XMP protocol handler initialized
[ 2.323659] usbcore: registered new interface driver uvcvideo
[ 2.323700] USB Video Class driver (1.1.1)
[ 2.323722] CamSys driver version: v0.48.2, CamSys head file version: v1.0.0
[ 2.329481] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 2.329671] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 2.330019] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.330181] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 2.334095] rk_tsadcv2_temp_to_code: Invalid temp(2147483647), set temp to =125000
[ 2.335003] device-mapper: uevent: version 1.0.3
[ 2.335455] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.335667] Bluetooth: HCI UART driver ver 2.3
[ 2.335701] Bluetooth: HCI UART protocol H4 registered
[ 2.335711] Bluetooth: HCI UART protocol LL registered
[ 2.335726] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.335734] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.335742] rtk_btusb: Register usb char device interface for BT driver
[ 2.336016] usbcore: registered new interface driver rtk_btusb
[ 2.336620] cpu cpu0: bin=1
[ 2.336711] cpu cpu0: leakage=26
[ 2.348885] cpu cpu0: temp=34444, pvtm=147732 (148537 + -805)
[ 2.349277] cpu cpu0: pvtm-volt-sel=1
[ 2.349377] cpu cpu0: bin-scale=34
[ 2.349736] cpu cpu4: bin=1
[ 2.349807] cpu cpu4: leakage=49
[ 2.362047] cpu cpu4: temp=34444, pvtm=154635 (155132 + -497)
[ 2.362205] cpu cpu4: pvtm-volt-sel=1
[ 2.362292] cpu cpu4: bin-scale=17
[ 2.363674] cpu cpu0: avs=0, target-scale=34
[ 2.363802] cpu cpu0: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.365649] cpu cpu4: avs=0, target-scale=17
[ 2.365777] cpu cpu4: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.368209] sdhci: Secure Digital Host Controller Interface driver
[ 2.368243] sdhci: Copyright(c) Pierre Ossman
[ 2.368261] Synopsys Designware Multimedia Card Interface Driver
[ 2.369432] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.369579] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.369622] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.369675] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.369700] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.369759] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.369799] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.370814] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.370904] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.370922] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.370983] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.371028] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.371606] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.371772] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.382177] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.396491] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.396944] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.398874] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.398912] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.425448] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.429083] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.431201] usbcore: registered new interface driver usbhid
[ 2.431214] usbhid: USB HID core driver
[ 2.431333] inv_mpu_iio: inv_mpu_init:746
[ 2.431902] ashmem: initialized
[ 2.433220] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 2.437658] rknandbase v1.1 2016-11-08
[ 2.438423] usbcore: registered new interface driver snd-usb-audio
[ 2.440836] rt5640 1-001c: Can not read property hp-con-gpio
[ 2.448405] gpiod_direction_output: invalid GPIO
[ 2.448424] gpiod_direction_output: invalid GPIO
[ 2.448434] gpiod_direction_output: invalid GPIO
[ 2.459599] tc358749x 1-000f: tc358749x_i2c_probe success
[ 2.463035] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 2.464954] u32 classifier
[ 2.464999] Actions configured
[ 2.465233] Netfilter messages via NETLINK v0.30.
[ 2.465485] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.465912] mmc1: MAN_BKOPS_EN bit is not set
[ 2.466167] ctnetlink v0.93: registering with nfnetlink.
[ 2.466991] xt_time: kernel timezone is -0000
[ 2.467577] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.467896] arp_tables: (C) 2002 David S. Miller
[ 2.468486] Initializing XFRM netlink socket
[ 2.468882] NET: Registered protocol family 10
[ 2.469775] mip6: Mobile IPv6
[ 2.469894] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.471123] sit: IPv6 over IPv4 tunneling driver
[ 2.471550] NET: Registered protocol family 17
[ 2.471634] NET: Registered protocol family 15
[ 2.471847] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.472676] Bridge firewalling registered
[ 2.472785] Ebtables v2.0 registered
[ 2.473200] Bluetooth: RFCOMM TTY layer initialized
[ 2.473242] Bluetooth: RFCOMM socket layer initialized
[ 2.473476] Bluetooth: RFCOMM ver 1.11
[ 2.473699] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.473889] Bluetooth: BNEP filters: protocol multicast
[ 2.474110] Bluetooth: BNEP socket layer initialized
[ 2.474327] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.474542] Bluetooth: HIDP socket layer initialized
[ 2.474782] l2tp_core: L2TP core driver, V2.0
[ 2.474982] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.475194] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.475358] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.475794] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.475917] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.476078] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.476296] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.476572] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.476729] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.476948] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.477207] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.477420] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.478032] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.478081] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.478093] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 2.478114] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.478146] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.478437] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 2.478466] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.478505] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 2.478518] [BT_RFKILL]: ** disable irq
[ 2.478613] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 2.478629] [BT_RFKILL]: bt_default device registered.
[ 2.478833] sensor_register_slave:mpu6500_gyro,id=49
[ 2.479007] sensor_register_slave:mpu6880_gyro,id=50
[ 2.479029] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 2.479963] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.479992] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 2.480039] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 2.480061] resource: 0x001000000 – 0x002000000 (16 MB)
[ 2.480082] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 2.480103] boot: 0x003800000 – 0x005800000 (32 MB)
[ 2.480124] recovery: 0x005800000 – 0x009800000 (64 MB)
[ 2.480145] backup: 0x009800000 – 0x010800000 (112 MB)
[ 2.480166] cache: 0x010800000 – 0x018800000 (128 MB)
[ 2.480187] system: 0x018800000 – 0x078800000 (1536 MB)
[ 2.480209] oem: 0x078800000 – 0x098800000 (512 MB)
[ 2.480261] metadata: 0x098800000 – 0x099800000 (16 MB)
[ 2.480283] verity_mode: 0x099800000 – 0x099808000 (0 MB)
[ 2.480296] Registered cp15_barrier emulation handler
[ 2.480321] reserved: 0x099808000 – 0x099c08000 (4 MB)
[ 2.480343] frp: 0x099c08000 – 0x099c88000 (0 MB)
[ 2.480364] userdata: 0x099c88000 – 0x3a3a00000 (12445 MB)
[ 2.480411] Registered setend emulation handler
[ 2.480529] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 2.481217] registered taskstats version 1
[ 2.481816] rockchip ion idev is NULL
[ 2.481830] rga2 ff680000.rga: rga ion client create success!
[ 2.482087] rga2: Driver loaded successfully ver:3.02
[ 2.482348] rga2: Module initialized.
[ 2.482972] mali ff9a0000.gpu: leakage=32
[ 2.506746] mali ff9a0000.gpu: temp=34444, pvtm=124952 (125274 + -322)
[ 2.507614] mali ff9a0000.gpu: pvtm-volt-sel=1
[ 2.508821] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.509060] mali ff9a0000.gpu: Protected mode not available
[ 2.509493] mali ff9a0000.gpu: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.509565] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 2.509705] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.510281] mali ff9a0000.gpu: Probed as mali0
[ 2.514734] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.514981] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[ 2.515263] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.515363] xhci-hcd xhci-hcd.10.auto: irq 235, io mem 0xfe800000
[ 2.515610] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.515641] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.515652] usb usb5: Product: xHCI Host Controller
[ 2.515662] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.515672] usb usb5: SerialNumber: xhci-hcd.10.auto
[ 2.516168] hub 5-0:1.0: USB hub found
[ 2.516224] hub 5-0:1.0: 1 port detected
[ 2.516495] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.516698] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[ 2.516781] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.516889] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.516919] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.516929] usb usb6: Product: xHCI Host Controller
[ 2.516939] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.516949] usb usb6: SerialNumber: xhci-hcd.10.auto
[ 2.517454] hub 6-0:1.0: USB hub found
[ 2.517502] hub 6-0:1.0: 1 port detected
[ 2.519143] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.519194] usb usb6: USB disconnect, device number 1
[ 2.535877] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 2.535908] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 2.537158] xhci-hcd xhci-hcd.10.auto: USB bus 6 deregistered
[ 2.537692] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.537836] usb usb5: USB disconnect, device number 1
[ 2.539254] xhci-hcd xhci-hcd.10.auto: USB bus 5 deregistered
[ 2.540220] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.540596] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 5
[ 2.540846] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.540905] xhci-hcd xhci-hcd.11.auto: irq 236, io mem 0xfe900000
[ 2.541112] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.541138] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.541147] usb usb5: Product: xHCI Host Controller
[ 2.541156] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.541164] usb usb5: SerialNumber: xhci-hcd.11.auto
[ 2.541664] hub 5-0:1.0: USB hub found
[ 2.541696] hub 5-0:1.0: 1 port detected
[ 2.541957] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.542313] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 6
[ 2.542406] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.542504] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.542515] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.542523] usb usb6: Product: xHCI Host Controller
[ 2.542532] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.542540] usb usb6: SerialNumber: xhci-hcd.11.auto
[ 2.543109] hub 6-0:1.0: USB hub found
[ 2.543150] hub 6-0:1.0: 1 port detected
[ 2.544443] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.544588] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.544618] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.544647] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.544666] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.544713] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.544739] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.545034] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.555400] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.568734] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.569442] rockchip-dmc dmc: Failed to get leakage
[ 2.569508] rockchip-dmc dmc: Failed to get pvtm
[ 2.569925] rockchip-dmc dmc: could not find power_model node
[ 2.572546] devfreq dmc: Couldn’t update frequency transition information.
[ 2.579042] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 2.579507] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.579577] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.579600] ALSA pcmC1D1c,0:: cannot preallocate for size 32768
[ 2.579616] asoc-simple-card rt5640-sound: rt5640-aif2 ↔ ff890000.i2s mapping ok
[ 2.579809] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.579877] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.579887] ALSA pcmC1D2p,0:: cannot preallocate for size 32768
[ 2.579947] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.579998] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[ 2.580007] ALSA pcmC1D2c,0:: cannot preallocate for size 32768
[ 2.580023] asoc-simple-card rt5640-sound: tc358749x-audio ↔ ff890000.i2s mapping ok
[ 2.584946] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[ 2.587403] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:04 UTC (1358499004)
[ 2.588895] It doesn’t contain Rogue gpu
[ 2.599398] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.599475] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.599496] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 2.600632] hub 2-1:1.0: USB hub found
[ 2.600888] hub 2-1:1.0: 7 ports detected
[ 2.613224] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.614841] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.616478] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.619382] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.622923] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.625709] vdd3v3_pcie: disabling
[ 2.625750] vcc_sd: disabling
[ 2.625759] vcc_otg_vbus: disabling
[ 2.626672] ret 1024
[ 2.627260] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-7fc8869’, rk_ko_ver is ‘5’, built at ‘15:25:33’, on ‘Apr 11 2021’.
[ 2.627774] Mali: Mali device driver loaded
[ 2.628347] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[ 2.629672] ALSA device list:
[ 2.629686] #0: rk-hdmi-dp-sound
[ 2.629695] #1: rockchip,rt5640-codec
[ 2.630159] Freeing unused kernel memory: 832K
[ 2.633916] init: init first stage started!
[ 2.675003] mmc_host mmc2: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 2.681247] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 110
[ 2.682787] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.682850] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.716072] audit: type=1403 audit(1358499004.626:2): policy loaded auid=4294967295 ses=4294967295
[ 2.716770] init: (Initializing SELinux non-enforcing took 0.08s.)
[ 2.727681] init: init second stage started!
[ 2.732451] init: Setting ro.rk.soc=rk3399
[ 2.732632] init: OK,EMMC DRIVERS INIT OK
[ 2.732751] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 2.733033] init: property_set(“ro.hardware”, “rk30board”) failed
[ 2.735249] init: Running restorecon…
[ 2.811366] init: waitpid failed: No child processes
[ 2.811752] init: (Loading properties from /default.prop took 0.00s.)
[ 2.813775] init: (Parsing /init.environ.rc took 0.00s.)
[ 2.814180] init: (Parsing /init.usb.rc took 0.00s.)
[ 2.815254] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 2.816049] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 2.816135] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 2.816256] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 2.816444] init: (Parsing /init.logs.rc took 0.00s.)
[ 2.816553] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 2.816656] init: (Parsing /init.coredump.rc took 0.00s.)
[ 2.816720] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 2.816786] init: (Parsing /init.kernel.rc took 0.00s.)
[ 2.816924] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 2.816944] init: (Parsing /init.debug.rc took 0.00s.)
[ 2.816962] init: (Parsing init.rockchip.rc took 0.00s.)
[ 2.817402] init: (Parsing init.connectivity.rc took 0.00s.)
[ 2.817458] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 2.817582] init: (Parsing init.rk3399.rc took 0.00s.)
[ 2.817695] init: init.tablet.rc: 23: invalid keyword ‘ioprio’
[ 2.817753] init: (Parsing init.tablet.rc took 0.00s.)
[ 2.817787] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 2.817827] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 2.817842] init: (Parsing /init.rk30board.rc took 0.00s.)
[ 2.818378] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 2.818488] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 2.818504] init: (Parsing /init.rc took 0.01s.)
[ 2.818949] init: Starting service ‘ueventd’…
[ 2.820811] ueventd: ueventd started!
[ 2.821486] ueventd: invalid gid ‘trace’
[ 2.823959] audit: type=1400 audit(1358499004.733:3): avc: denied { getattr } for pid=1 comm=“init” path=“/sys/kernel/debug/tracing/trace_marker” dev=“tracefs” ino=3200 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[ 2.845429] usb 5-1: new low-speed USB device number 2 using xhci-hcd
[ 2.969542] usb 5-1: New USB device found, idVendor=093a, idProduct=2510
[ 2.969612] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.969639] usb 5-1: Product: USB Optical Mouse
[ 2.969662] usb 5-1: Manufacturer: PixArt
[ 2.971073] usb 5-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2.978880] input: PixArt USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1:1.0/0003:093A:2510.0001/input/input3
[ 2.980571] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-xhci-hcd.11.auto-1/input0
[ 2.997941] vendor storage:20160801 ret = 0
[ 3.015241] audit: type=1400 audit(1358499004.923:4): avc: denied { relabelfrom } for pid=215 comm=“ueventd” name=“event3” dev=“tmpfs” ino=17173 scontext=u:r:ueventd:s0 tcontext=u:object_r:input_device:s0 tclass=chr_file permissive=1
[ 3.015277] audit: type=1400 audit(1358499004.923:5): avc: denied { relabelto } for pid=215 comm=“ueventd” name=“event3” dev=“tmpfs” ino=17173 scontext=u:r:ueventd:s0 tcontext=u:object_r:input_device:s0 tclass=chr_file permissive=1
[ 3.027060] ueventd: Coldboot took 0.20s.
[ 3.057078] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 3.057118] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 3.057147] init: Waiting for /dev/.coldboot_done…
[ 3.057197] init: Waiting for /dev/.coldboot_done took 0.00s.
[ 3.057226] init: /dev/hw_random not found
[ 3.057716] keychord: using input dev ff420030.pwm for fevent
[ 3.057725] keychord: using input dev rk29-keypad for fevent
[ 3.066162] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 3.073311] audit: type=1400 audit(1358499004.983:6): avc: denied { relabelto } for pid=1 comm=“init” name=“oem” dev=“rootfs” ino=9220 scontext=u:r:init:s0 tcontext=u:object_r:oemfs:s0 tclass=dir permissive=1
[ 3.073351] audit: type=1400 audit(1358499004.983:7): avc: denied { associate } for pid=1 comm=“init” name=“oem” dev=“rootfs” ino=9220 scontext=u:object_r:oemfs:s0 tcontext=u:object_r:rootfs:s0 tclass=filesystem permissive=1
[ 3.073465] audit: type=1400 audit(1358499004.983:8): avc: denied { mounton } for pid=1 comm=“init” path=“/oem” dev=“rootfs” ino=9220 scontext=u:r:init:s0 tcontext=u:object_r:oemfs:s0 tclass=dir permissive=1
[ 3.073924] EXT4-fs (mmcblk1p11): VFS: Can’t find ext4 filesystem
[ 3.074009] Registered swp emulation handler
[ 3.074164] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 3.074871] fs_mgr: Warning: unknown flag resize
[ 3.074946] init: /dev/hw_random not found
[ 3.075022] init: write_file: Unable to open ‘/sys/block/mmcblk0/bdi/read_ahead_kb’: No such file or directory
[ 3.075513] fs_mgr: Warning: unknown flag resize
[ 3.077302] EXT4-fs (mmcblk1p10): VFS: Can’t find ext4 filesystem
[ 3.077353] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=-1
[ 3.077674] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/platform/fe330000.sdhci/by-name/system at /system options: noauto_da_alloc error: Invalid argument
[ 3.078955] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 3.078985] fs_mgr: Not running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache (executable not in system image)
[ 3.085058] EXT4-fs (mmcblk1p9): recovery complete
[ 3.085460] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.085535] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 3.087148] EXT4-fs (mmcblk1p12): Ignoring removed nomblk_io_submit option
[ 3.088959] EXT4-fs (mmcblk1p12): warning: maximal mount count reached, running e2fsck is recommended
[ 3.089723] EXT4-fs (mmcblk1p12): recovery complete
[ 3.089744] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 3.089829] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 3.103367] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 3.103400] fs_mgr: Not running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata (executable not in system image)
[ 3.106531] EXT4-fs (mmcblk1p12): warning: maximal mount count reached, running e2fsck is recommended
[ 3.107032] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.107092] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 3.107991] EXT4-fs (mmcblk1p16): Ignoring removed nomblk_io_submit option
[ 3.117698] EXT4-fs (mmcblk1p16): recovery complete
[ 3.118076] EXT4-fs (mmcblk1p16): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 3.118169] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/userdata,/data,ext4)=0: Success
[ 3.141499] fs_mgr: check_fs(): unmount(/data) succeeded
[ 3.141591] fs_mgr: Not running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/userdata (executable not in system image)
[ 3.145807] EXT4-fs (mmcblk1p16): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 3.145988] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=ext4)=0
[ 3.147572] init: fs_mgr_mount_all returned an error
[ 3.148468] init: fs_mgr_mount_all returned unexpected error 255
[ 3.148733] init: do_start: Service logd not found
[ 3.154113] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/rk29-ipp.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 3.156196] zram0: detected capacity change from 0 to 533413888
[ 3.157921] Unable to find swap-space signature
[ 3.157996] fs_mgr: swapon failed for /dev/block/zram0
[ 3.158246] init: (Loading properties from /system/build.prop took 0.00s.)
[ 3.158287] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 3.158329] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 3.158445] fs_mgr: Warning: unknown flag resize
[ 3.158553] init: /recovery not specified in fstab
[ 3.158967] init: do_start: Service debuggerd not found
[ 3.159002] init: do_start: Service debuggerd64 not found
[ 3.159025] init: do_start: Service vold not found
[ 3.160213] init: Not bootcharting.
[ 3.192959] init: cannot find ‘/system/bin/tzdatacheck’ (No such file or directory), disabling ‘exec 1 (/system/bin/tzdatacheck)’
[ 3.195612] audit: type=1400 audit(1358499005.106:9): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“mmcblk1p16” ino=186945 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[ 3.197370] EXT4-fs (mmcblk1p16): Unrecognized mount option “background_gc=on” or missing value
[ 3.201244] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 3.201480] init: (Loading properties from /data/local.prop took 0.00s.)
[ 3.201863] init: do_start: Service logd not found
[ 3.201903] init: do_start: Service logd-reinit not found
[ 3.202704] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 3.204877] init: Starting service ‘healthd’…
[ 3.205599] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 3.205695] init: cannot find ‘/system/vendor/bin/elogs.sh’ (No such file or directory), disabling ‘earlylogs’
[ 3.206061] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 3.208168] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 3.210849] init: cannot find ‘/system/bin/busybox’ (No such file or directory), disabling ‘exec 2 (/system/bin/busybox)’
[ 3.210873] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 3.212820] audit: type=1400 audit(1358499005.123:10): avc: denied { relabelto } for pid=1 comm=“init” name=“recovery” dev=“tmpfs” ino=17206 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block_device:s0 tclass=lnk_file permissive=1
[ 3.213880] init: SELinux: Could not get canonical path for /system/bin/tee-supplicant restorecon: No such file or directory.
[ 3.213964] init: SELinux: Could not get canonical path for /system/bin/rk_store_keybox restorecon: No such file or directory.
[ 3.214309] init: cannot find ‘/system/xbin/fsu’ (No such file or directory), disabling ‘fsud’
[ 3.214377] init: cannot find ‘/system/xbin/vm’ (No such file or directory), disabling ‘vm_daemon’
[ 3.216605] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.216663] init: write: cannot expand ‘${ro.serialno}’
[ 3.216723] init: property ‘ro.product.manufacturer’ doesn’t exist while expanding ‘${ro.product.manufacturer}’
[ 3.216743] init: write: cannot expand ‘${ro.product.manufacturer}’
[ 3.216773] init: property ‘ro.product.model’ doesn’t exist while expanding ‘${ro.product.model}’
[ 3.216792] init: write: cannot expand ‘${ro.product.model}’
[ 3.218779] file system registered
[ 3.220530] using random self ethernet address
[ 3.220569] using random host ethernet address
[ 3.220650] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 3.230515] init: cannot find ‘/system/bin/sh’ (No such file or directory), disabling ‘console’
[ 3.230681] init: Starting service ‘adbd’…
[ 3.351324] phy phy-ff770000.syscon:usb2-phy@e450.0: charger = USB_SDP_CHARGER
[ 3.353870] rockchip-dwc3 usb@fe800000: USB peripheral connected
[ 4.211258] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 5.211700] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 6.212136] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 7.212570] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 8.213006] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 9.213446] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 10.213880] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 11.214311] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 12.214745] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 13.215185] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 13.455013] read descriptors
[ 13.455108] read strings
[ 13.800494] android_work: did not send uevent (0 0 (null))
[ 13.984977] android_work: sent uevent USB_STATE=CONNECTED
[ 13.986482] configfs-gadget gadget: high-speed config #1: b
[ 13.986742] android_work: sent uevent USB_STATE=CONFIGURED
[ 14.215626] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 15.215935] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 16.216198] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 17.216591] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 18.217025] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 19.217465] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 20.217899] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 20.405595] random: nonblocking pool is initialized
[ 21.218339] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 22.218776] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 23.219216] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 24.219653] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 25.220093] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 26.220528] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 27.220968] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 28.221405] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
[ 29.221844] binder: 231:231 transaction failed 29189/-22, size 0-0 line 2948
