AIO-3399J 4.4.194内核 UBUNTU 无法启动
现阶段使用核心板和AIO3399J底板,官方固件和自己正常编译的固件运行到文件系统前会卡死。
调试中发现关闭内核设备树sdhci节点,EMMC不进行初始化系统能进入buildroot,从SD卡启动不使能EMMC则可以正常启动进入UBUNTU,此时运行DDR测试正常。
怀疑是EMMC问题,更换多种不同型号仍没有解决,而且固件的烧录与UBOOT的启动没有问题。
DDR Version 1.26 20210628
soft reset
SRX
Channel 0: DDR3, 800MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: DDR3, 800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C172C1, stride = 0xD
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 428
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 69317
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x46c200
GPT part: 7, name: userdata, start:0x4c6200, size:0x9c9ddf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
Trust Addr:0x6000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xf83b8
RunBL31 0x40000 @ 113814 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #1 Mon Aug 17 09:23:30 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-gd67a144e2f #jincheng (Sep 15 2021 - 11:09:53 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 3.8 GiB
Sysmem: init
Relocation Offset: f5bcb000, fdt: f3dbf4d8
Bootdev(atags): mmc 0
MMC0: HS400, 50Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
Android header version 0
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1100000 uV
In: serial
Out: serial
Err: serial
Model: AIO-3399J Board (Linux Opensource)
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 22483 KiB
RAM disk load addr 0x0a200000 size 8513 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
Using Device Tree in place at 0000000008300000, end 000000000831c626
No file: logo_kernel.bmp
Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000)
Total: 2942.270 ms
[ 0.000000] Linux version 4.4.194+ (jincheng@jincheng-PC) (local/internal-gitlab/rk3399/firefly: 44a8d8fabe4b94d62ed24e19b7946084a0a5fe29) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #3 SMP Thu Sep 9 14:41:07 CST 2021
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ecb000 s46312 r8192 d31512 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal recovery androidboot.slot_suffix= androidboot.serialno=67788ad2eb252a1b ro rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0xf7e82000-0xf7ec2000] (0MB)
[ 0.000000] Memory: 3922832K/4030464K available (14078K kernel code, 1810K rwdata, 5340K rodata, 1216K init, 2013K bss, 107632K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009380000 - 0xffffff80094b0000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008e40000 ( 14080 KB)
[ 0.000000] .rodata : 0xffffff8008e40000 - 0xffffff8009380000 ( 5376 KB)
[ 0.000000] .data : 0xffffff80094b0000 - 0xffffff8009674808 ( 1811 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @f2c80000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000f2c10000
[ 0.000000] CPU0: using LPI pending table @0x00000000f2c20000
[ 0.002210] Console: colour dummy device 80x25
[ 0.002651] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003637] pid_max: default: 32768 minimum: 301
[ 0.004156] Security Framework initialized
[ 0.004618] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005259] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006667] Initializing cgroup subsys io
[ 0.007073] Initializing cgroup subsys memory
[ 0.007511] Initializing cgroup subsys devices
[ 0.007942] Initializing cgroup subsys freezer
[ 0.008382] Initializing cgroup subsys perf_event
[ 0.008837] Initializing cgroup subsys net_prio
[ 0.009275] Initializing cgroup subsys pids
[ 0.009705] ftrace: allocating 51031 entries in 200 pages
[ 0.132507] sched-energy: Sched-energy-costs installed from DT
[ 0.133071] CPU0: update cpu_capacity 401
[ 0.133509] ASID allocator initialised with 32768 entries
[ 0.137191] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.138533] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.140730] Detected VIPT I-cache on CPU1
[ 0.140760] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.140783] CPU1: using LPI pending table @0x00000000f2ed0000
[ 0.140822] CPU1: update cpu_capacity 401
[ 0.140826] CPU1: Booted secondary processor [410fd034]
[ 0.141350] Detected VIPT I-cache on CPU2
[ 0.141370] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.141392] CPU2: using LPI pending table @0x00000000f2f00000
[ 0.141417] CPU2: update cpu_capacity 401
[ 0.141421] CPU2: Booted secondary processor [410fd034]
[ 0.141947] Detected VIPT I-cache on CPU3
[ 0.141966] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.141988] CPU3: using LPI pending table @0x00000000f2f50000
[ 0.142013] CPU3: update cpu_capacity 401
[ 0.142017] CPU3: Booted secondary processor [410fd034]
[ 0.142547] Detected PIPT I-cache on CPU4
[ 0.142570] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.142604] CPU4: using LPI pending table @0x00000000f2f80000
[ 0.142639] CPU4: update cpu_capacity 1024
[ 0.142642] CPU4: Booted secondary processor [410fd082]
[ 0.143171] Detected PIPT I-cache on CPU5
[ 0.143189] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.143220] CPU5: using LPI pending table @0x00000000f2fc0000
[ 0.143245] CPU5: update cpu_capacity 1024
[ 0.143249] CPU5: Booted secondary processor [410fd082]
[ 0.143331] Brought up 6 CPUs
[ 0.155674] SMP: Total of 6 processors activated.
[ 0.156124] CPU features: detected feature: GIC system register CPU interface
[ 0.156811] CPU features: detected feature: 32-bit EL0 Support
[ 0.157369] CPU: All CPU(s) started at EL2
[ 0.157795] alternatives: patching kernel code
[ 0.159562] devtmpfs: initialized
[ 0.178314] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.179268] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.180297] xor: measuring software checksum speed
[ 0.190533] 8regs : 2860.000 MB/sec
[ 0.200588] 8regs_prefetch: 2556.000 MB/sec
[ 0.210640] 32regs : 3208.000 MB/sec
[ 0.220693] 32regs_prefetch: 2848.000 MB/sec
[ 0.221136] xor: using function: 32regs (3208.000 MB/sec)
[ 0.221669] pinctrl core: initialized pinctrl subsystem
[ 0.223862] Failed to find legacy iommu devices
[ 0.224668] NET: Registered protocol family 16
[ 0.230338] cpuidle: using governor ladder
[ 0.234347] cpuidle: using governor menu
[ 0.234736] Registered FIQ tty driver
[ 0.235623] vdso: 2 pages (1 code @ ffffff8008e46000, 1 data @ ffffff80094b4000)
[ 0.236358] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.237420] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.261257] console [pstore-1] enabled
[ 0.261630] pstore: Registered ramoops as persistent store backend
[ 0.262223] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.265187] console [ttyFIQ0] enabled
[ 0.265875] bootconsole [uart0] disabled
[ 0.266804] Registered fiq debugger ttyFIQ0
[ 0.317309] raid6: int64x1 gen() 468 MB/s
[ 0.334336] raid6: int64x1 xor() 410 MB/s
[ 0.351476] raid6: int64x2 gen() 675 MB/s
[ 0.368502] raid6: int64x2 xor() 593 MB/s
[ 0.385646] raid6: int64x4 gen() 972 MB/s
[ 0.402707] raid6: int64x4 xor() 666 MB/s
[ 0.419832] raid6: int64x8 gen() 785 MB/s
[ 0.436869] raid6: int64x8 xor() 630 MB/s
[ 0.454004] raid6: neonx1 gen() 964 MB/s
[ 0.471072] raid6: neonx1 xor() 669 MB/s
[ 0.488124] raid6: neonx2 gen() 1273 MB/s
[ 0.505230] raid6: neonx2 xor() 1000 MB/s
[ 0.522304] raid6: neonx4 gen() 1726 MB/s
[ 0.539398] raid6: neonx4 xor() 1195 MB/s
[ 0.556495] raid6: neonx8 gen() 1691 MB/s
[ 0.573584] raid6: neonx8 xor() 1261 MB/s
[ 0.573974] raid6: using algorithm neonx4 gen() 1726 MB/s
[ 0.574450] raid6: … xor() 1195 MB/s, rmw enabled
[ 0.574891] raid6: using intx1 recovery algorithm
[ 0.579829] iommu: Adding device ff650000.vpu_service to group 0
[ 0.580455] iommu: Adding device ff660000.rkvdec to group 1
[ 0.581057] iommu: Adding device ff8f0000.vop to group 2
[ 0.581627] iommu: Adding device ff900000.vop to group 3
[ 0.582188] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.582784] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.583759] rk_iommu ff650800.iommu: can’t get sclk
[ 0.584433] rk_iommu ff660480.iommu: can’t get sclk
[ 0.585085] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.585674] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.586277] rk_iommu ff914000.iommu: can’t get sclk
[ 0.586869] rk_iommu ff924000.iommu: can’t get sclk
[ 0.587667] SCSI subsystem initialized
[ 0.588370] usbcore: registered new interface driver usbfs
[ 0.588895] usbcore: registered new interface driver hub
[ 0.589459] usbcore: registered new device driver usb
[ 0.589982] media: Linux media interface: v0.10
[ 0.590435] Linux video capture interface: v2.00
[ 0.590917] pps_core: LinuxPPS API ver. 1 registered
[ 0.591359] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.592189] PTP clock support registered
[ 0.593661] Advanced Linux Sound Architecture Driver Initialized.
[ 0.594683] Bluetooth: Core ver 2.21
[ 0.595021] NET: Registered protocol family 31
[ 0.595428] Bluetooth: HCI device and connection manager initialized
[ 0.596001] Bluetooth: HCI socket layer initialized
[ 0.596442] Bluetooth: L2CAP socket layer initialized
[ 0.596914] Bluetooth: SCO socket layer initialized
[ 0.597844] nfc: nfc_init: NFC Core ver 0.1
[ 0.598252] NET: Registered protocol family 39
[ 0.598769] rockchip-cpuinfo cpuinfo: Serial : 67788ad2eb252a1b
[ 0.600134] clocksource: Switched to clocksource arch_sys_counter
[ 0.651409] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.652331] NET: Registered protocol family 2
[ 0.653117] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.654026] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.655524] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.656211] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.656908] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.657836] NET: Registered protocol family 1
[ 0.658515] RPC: Registered named UNIX socket transport module.
[ 0.659039] RPC: Registered udp transport module.
[ 0.659473] RPC: Registered tcp transport module.
[ 0.659891] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.661115] Trying to unpack rootfs image as initramfs…
[ 1.112997] Freeing initrd memory: 8512K
[ 1.114088] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.114915] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.118367] audit: initializing netlink subsys (disabled)
[ 1.118873] audit: type=2000 audit(1.030:1): initialized
[ 1.119759] Initialise system trusted keyring
[ 1.128259] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.129551] NFS: Registering the id_resolver key type
[ 1.130020] Key type id_resolver registered
[ 1.130409] Key type id_legacy registered
[ 1.130783] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.132053] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.132832] fuse init (API version 7.23)
[ 1.133531] SGI XFS with security attributes, no debug enabled
[ 1.139456] NET: Registered protocol family 38
[ 1.139878] Key type asymmetric registered
[ 1.140270] Asymmetric key parser ‘x509’ registered
[ 1.140869] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.141768] io scheduler noop registered
[ 1.142143] io scheduler deadline registered
[ 1.142563] io scheduler cfq registered (default)
[ 1.144518] phy phy-ff770000.syscon:usb2-phy@e450.1: Failed to get VBUS supply regulator
[ 1.146099] phy phy-ff770000.syscon:usb2-phy@e460.3: Failed to get VBUS supply regulator
[ 1.151451] ace test_init function.
[ 1.151939] ace test_init end.ret=0
[ 1.152637] radar end.ret=0
[ 1.155382] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.155977] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.156587] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.157166] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 1.157774] PCI host bridge /pcie@f8000000 ranges:
[ 1.158225] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 1.158683] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 1.701191] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.701804] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.702535] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.704098] Module initialized.
[ 1.704862] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.705729] rk-vcodec ff650000.vpu_service: probe device
[ 1.706447] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.707594] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.708225] rk-vcodec ff650000.vpu_service: init success
[ 1.708988] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.709926] rk-vcodec ff660000.rkvdec: probe device
[ 1.710582] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.711557] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.712154] rk-vcodec ff660000.rkvdec: init success
[ 1.714054] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.714745] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.717004] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.717692] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.719539] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.720753] pwm-regulator: supplied by vcc5v0_sys
[ 1.721865] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.723025] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 1.725593] [drm] Initialized drm 1.1.0 20060810
[ 1.729757] [drm] Rockchip DRM driver version: v1.0.1
[ 1.730534] rockchip-drm display-subsystem: dmc is disabled
[ 1.731338] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.732177] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008f040f0)
[ 1.732919] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.733667] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008f040f0)
[ 1.734620] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.735252] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.736036] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.737706] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ef8948)
[ 1.738464] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.739044] [drm] No driver support for vblank timestamp query.
[ 1.739827] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.740550] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.741195] rockchip-drm display-subsystem: failed to show loader logo
[ 1.742058] Freeing drm_logo memory: 1236K
[ 1.742443] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.743159] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.754149] Console: switching to colour frame buffer device 128x48
[ 1.760742] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.769703] mali ff9a0000.gpu: Failed to get regulator
[ 1.770176] mali ff9a0000.gpu: Power control initialization failed
[ 1.771101] Unable to detect cache hierarchy for CPU 0
[ 1.772364] brd: module loaded
[ 1.777881] loop: module loaded
[ 1.778712] zram: Added device: zram0
[ 1.779322] lkdtm: No crash points registered, enable through debugfs
[ 1.780260] Loading dl1825 driver
[ 1.782087] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.783499] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.954456] wk2xxx_serial_init()
[ 1.954751] wk2xxx_request_port
[ 1.955037] ttysWK0 at I/O 0x1 (irq = 100, base_baud = 460800) is a wk2xxx
[ 1.955877] uart_add_one_port success for line i:= 0 with right 0
[ 1.956426] wk2xxx_request_port
[ 1.956711] ttysWK1 at I/O 0x2 (irq = 100, base_baud = 460800) is a wk2xxx
[ 1.957498] uart_add_one_port success for line i:= 1 with right 0
[ 1.958032] wk2xxx_request_port
[ 1.958331] ttysWK2 at I/O 0x3 (irq = 100, base_baud = 460800) is a wk2xxx
[ 1.959107] uart_add_one_port success for line i:= 2 with right 0
[ 1.959664] wk2xxx_request_port
[ 1.959949] ttysWK3 at I/O 0x4 (irq = 100, base_baud = 460800) is a wk2xxx
[ 1.960731] uart_add_one_port success for line i:= 3 with right 0
[ 1.961289] uart_add_one_port = 0x0
[ 1.961626] register spi return v = :0
[ 1.962456] tun: Universal TUN/TAP device driver, 1.6
[ 1.962910] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.964386] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.965079] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.965720] rk_gmac-dwmac fe300000.ethernet: TX delay(0x31).
[ 1.966230] rk_gmac-dwmac fe300000.ethernet: RX delay(0x24).
[ 1.966745] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.967467] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.968081] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.973640] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.974257] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.974710] Ring mode enabled
[ 1.974990] DMA HW capability register supported
[ 1.975405] Normal descriptors
[ 1.975711] RX Checksum Offload Engine supported (type 2)
[ 1.976204] Wake-Up On Lan supported
[ 1.976561] Enable RX Mitigation via HW Watchdog Timer
[ 2.045736] libphy: stmmac: probed
[ 2.046049] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 2.046630] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 2.049199] usbcore: registered new interface driver rtl8192cu
[ 2.049787] usbcore: registered new interface driver rndis_wlan
[ 2.050593] usbcore: registered new interface driver mt7601u
[ 2.051188] Rockchip WiFi SYS interface (V1.00) …
[ 2.051711] usbcore: registered new interface driver rtl8150
[ 2.052284] usbcore: registered new interface driver r8152
[ 2.052832] usbcore: registered new interface driver asix
[ 2.053370] usbcore: registered new interface driver ax88179_178a
[ 2.053963] usbcore: registered new interface driver cdc_ether
[ 2.054545] usbcore: registered new interface driver rndis_host
[ 2.055160] usbcore: registered new interface driver cdc_ncm
[ 2.055710] usbcore: registered new interface driver qmi_wwan
[ 2.056282] usbcore: registered new interface driver cdc_mbim
[ 2.062201] rockchip-dwc3 usb0: fail to get drvdata hcd
[ 2.067811] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 2.070082] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.070696] ehci-pci: EHCI PCI platform driver
[ 2.071172] ehci-platform: EHCI generic platform driver
[ 2.075460] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.076307] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 2.077121] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.083185] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.083952] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.084575] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.085227] usb usb1: Product: EHCI Host Controller
[ 2.085661] usb usb1: Manufacturer: Linux 4.4.194+ ehci_hcd
[ 2.086173] usb usb1: SerialNumber: fe380000.usb
[ 2.087210] hub 1-0:1.0: USB hub found
[ 2.087584] hub 1-0:1.0: 1 port detected
[ 2.092119] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.092813] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 2.093628] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.100155] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.100847] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.101467] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.102105] usb usb2: Product: EHCI Host Controller
[ 2.102546] usb usb2: Manufacturer: Linux 4.4.194+ ehci_hcd
[ 2.103046] usb usb2: SerialNumber: fe3c0000.usb
[ 2.103995] hub 2-0:1.0: USB hub found
[ 2.104389] hub 2-0:1.0: 1 port detected
[ 2.105669] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.106291] ohci-platform: OHCI generic platform driver
[ 2.107188] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.107968] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 2.108748] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.164356] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.164966] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.165619] usb usb3: Product: Generic Platform OHCI controller
[ 2.166156] usb usb3: Manufacturer: Linux 4.4.194+ ohci_hcd
[ 2.166658] usb usb3: SerialNumber: fe3a0000.usb
[ 2.167669] hub 3-0:1.0: USB hub found
[ 2.168042] hub 3-0:1.0: 1 port detected
[ 2.169108] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.169961] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 2.170775] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.226336] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.226943] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.227597] usb usb4: Product: Generic Platform OHCI controller
[ 2.228122] usb usb4: Manufacturer: Linux 4.4.194+ ohci_hcd
[ 2.228635] usb usb4: SerialNumber: fe3e0000.usb
[ 2.229636] hub 4-0:1.0: USB hub found
[ 2.230013] hub 4-0:1.0: 1 port detected
[ 2.231849] usbcore: registered new interface driver cdc_acm
[ 2.232363] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.233136] usbcore: registered new interface driver cdc_wdm
[ 2.233700] usbcore: registered new interface driver uas
[ 2.234348] usbcore: registered new interface driver usb-storage
[ 2.234986] usbcore: registered new interface driver usbserial
[ 2.235568] usbcore: registered new interface driver usbserial_generic
[ 2.236190] usbserial: USB Serial support registered for generic
[ 2.236776] usbcore: registered new interface driver ch341
[ 2.237316] usbserial: USB Serial support registered for ch341-uart
[ 2.237925] usbcore: registered new interface driver cp210x
[ 2.238467] usbserial: USB Serial support registered for cp210x
[ 2.239083] usbcore: registered new interface driver ftdi_sio
[ 2.239637] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.240546] usbcore: registered new interface driver keyspan
[ 2.241075] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.241816] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.242505] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.243197] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.243903] usbcore: registered new interface driver option
[ 2.244446] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.245413] usbcore: registered new interface driver oti6858
[ 2.245941] usbserial: USB Serial support registered for oti6858
[ 2.246545] usbcore: registered new interface driver pl2303
[ 2.247077] usbserial: USB Serial support registered for pl2303
[ 2.247685] usbcore: registered new interface driver qcserial
[ 2.248242] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.248939] usbcore: registered new interface driver sierra
[ 2.249484] usbserial: USB Serial support registered for Sierra USB modem
[ 2.251925] usbcore: registered new interface driver usbtouchscreen
[ 2.252935] .. rk pwm remotectl v1.1 init
[ 2.253624] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.254834] sensor_register_slave:mma8452,id=17
[ 2.255272] sensor_register_slave:lis3dh,id=7
[ 2.255666] sensor_register_slave:mma7660,id=18
[ 2.256082] sensor_register_slave:lsm303d,id=22
[ 2.256509] sensor_register_slave:gs_mc3230,id=23
[ 2.256928] [Gsensor] gsensor_init
[ 2.257274] sensor_register_slave:mpu6880_acc,id=24
[ 2.257714] sensor_register_slave:mpu6500_acc,id=25
[ 2.258162] sensor_register_slave:lsm330_acc,id=26
[ 2.258601] sensor_register_slave:akm8975,id=30
[ 2.259017] sensor_register_slave:akm8963,id=31
[ 2.259444] sensor_register_slave:l3g4200d,id=45
[ 2.259860] sensor_register_slave:l3g20d,id=46
[ 2.260275] sensor_register_slave:ewtsa,id=47
[ 2.260680] sensor_register_slave:lsm330_gyro,id=51
[ 2.261119] sensor_register_slave:cm3217,id=53
[ 2.261534] sensor_register_slave:cm3218,id=54
[ 2.262559] i2c /dev entries driver
[ 2.264747] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.265484] fan53555-reg: supplied by vcc5v0_sys
[ 2.268586] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.269292] fan53555-reg: supplied by vcc5v0_sys
[ 2.272457] rk808 0-001b: Pmic Chip id: 0x0
[ 2.276299] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.276920] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.277607] DCDC_REG1: supplied by vcc3v3_sys
[ 2.278881] DCDC_REG2: supplied by vcc3v3_sys
[ 2.279998] DCDC_REG3: supplied by vcc3v3_sys
[ 2.280791] DCDC_REG4: supplied by vcc3v3_sys
[ 2.281756] LDO_REG1: supplied by vcc3v3_sys
[ 2.283423] LDO_REG2: supplied by vcc3v3_sys
[ 2.284907] LDO_REG3: supplied by vcc3v3_sys
[ 2.286407] LDO_REG4: supplied by vcc3v3_sys
[ 2.287898] LDO_REG5: supplied by vcc3v3_sys
[ 2.289424] LDO_REG6: supplied by vcc3v3_sys
[ 2.290915] LDO_REG7: supplied by vcc3v3_sys
[ 2.292463] LDO_REG8: supplied by vcc3v3_sys
[ 2.293957] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.294771] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.299010] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.300241] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009ad8000
[ 2.302037] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009ada000
[ 2.303628] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009adc000
[ 2.305849] IR NEC protocol handler initialized
[ 2.307409] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 2.307998] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 2.310897] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.05
[ 2.311501] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 2.314268] usbcore: registered new interface driver npu_acm
[ 2.314874] usbcore: registered new interface driver uvcvideo
[ 2.315399] USB Video Class driver (1.1.1)
[ 2.318620] Boot mode: normal
[ 2.321021] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.322009] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 2.324211] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.325213] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.a2fd257.20190430-133301
[ 2.325896] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 2.326361] rtk_btcoex: create workqueue
[ 2.326711] rtk_btcoex: Coex over UDP
[ 2.327441] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 2.328052] usbcore: registered new interface driver rtk_btusb
[ 2.328602] Bluetooth: Virtual HCI driver ver 1.5
[ 2.329193] Bluetooth: HCI UART driver ver 2.3
[ 2.329593] Bluetooth: HCI UART protocol H4 registered
[ 2.330047] Bluetooth: HCI UART protocol LL registered
[ 2.330567] Bluetooth: HCI UART protocol ATH3K registered
[ 2.331116] usbcore: registered new interface driver bfusb
[ 2.331694] usbcore: registered new interface driver btusb
[ 2.332870] cpu cpu0: bin=1
[ 2.333215] cpu cpu0: leakage=16
[ 2.346266] cpu cpu0: temp=51111, pvtm=143756 (143096 + 660)
[ 2.347118] cpu cpu0: pvtm-volt-sel=1
[ 2.347540] cpu cpu0: bin-scale=34
[ 2.348332] cpu cpu4: bin=1
[ 2.348660] cpu cpu4: leakage=27
[ 2.361083] cpu cpu4: temp=51111, pvtm=151678 (151328 + 350)
[ 2.361714] cpu cpu4: pvtm-volt-sel=1
[ 2.362106] cpu cpu4: bin-scale=17
[ 2.364039] cpu cpu0: avs=0
[ 2.364454] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.365934] cpu cpu0: failed to find power_model node
[ 2.367807] cpu cpu4: avs=0
[ 2.368228] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.370626] cpu cpu4: failed to find power_model node
[ 2.372233] sdhci: Secure Digital Host Controller Interface driver
[ 2.372778] sdhci: Copyright(c) Pierre Ossman
[ 2.373198] Synopsys Designware Multimedia Card Interface Driver
[ 2.375048] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.375725] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.376353] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.376915] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.377801] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.378637] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.379199] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.381052] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.381731] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.382356] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.382906] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.383788] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.384660] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.386473] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.388799] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.389343] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.406222] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.420066] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.422207] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.423097] usbcore: registered new interface driver usbhid
[ 2.423627] usbhid: USB HID core driver
[ 2.424118] inv_mpu_iio: inv_mpu_init:746
[ 2.427671] usbcore: registered new interface driver snd-usb-audio
[ 2.429734] rt5640 1-001c: Can not read property hp_det_gpio
[ 2.430250] rt5640 1-001c: Can not read property: linein-mute.
[ 2.447572] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 2.451169] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.452194] IPVS: Registered protocols (TCP, UDP)
[ 2.452661] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 2.453425] IPVS: Creating netns size=2104 id=0
[ 2.453865] IPVS: ipvs loaded.
[ 2.454165] IPVS: [rr] scheduler registered.
[ 2.454815] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.455395] Initializing XFRM netlink socket
[ 2.456463] NET: Registered protocol family 10
[ 2.458068] NET: Registered protocol family 17
[ 2.458501] NET: Registered protocol family 15
[ 2.458926] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.460060] Bridge firewalling registered
[ 2.460761] Bluetooth: RFCOMM socket layer initialized
[ 2.461261] Bluetooth: RFCOMM ver 1.11
[ 2.461608] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.462181] Bluetooth: HIDP socket layer initialized
[ 2.462673] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.463500] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.463986] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.464614] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.465250] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.465985] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.466796] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.467446] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.467908] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.468393] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.469321] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.470066] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.470796] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.471528] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.471716] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.472656] mmcblk0: mmc0:0001 88A378 7.28 GiB
[ 2.473436] mmcblk0boot0: mmc0:0001 88A378 partition 1 4.00 MiB
[ 2.474229] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.474717] mmcblk0boot1: mmc0:0001 88A378 partition 2 4.00 MiB
[ 2.474740] [BT_RFKILL]: ** disable irq
[ 2.474873] [BT_RFKILL]: bt_default device registered.
[ 2.474964] Key type dns_resolver registered
[ 2.475265] sensor_register_slave:mpu6880_gyro,id=50
[ 2.475648] ov13850 1-0036: driver version: 00.01.03
[ 2.478060] mmcblk0rpmb: mmc0:0001 88A378 partition 3 4.00 MiB
[ 2.478762] ov13850 1-0036: write SCCB_ID failed
[ 2.479379] ov13850: probe of 1-0036 failed with error -5
[ 2.480204] ov13850 1-0046: driver version: 00.01.03
[ 2.483088] ov13850 1-0046: write SCCB_ID failed
[ 2.483661] ov13850: probe of 1-0046 failed with error -5
[ 2.485256] Registered cp15_barrier emulation handler
[ 2.485797] Registered setend emulation handler
[ 2.487464] Loading compiled-in X.509 certificates
[ 2.490016] Btrfs loaded
[ 2.491570] rga2: Driver loaded successfully ver:3.02
[ 2.492372] rga2: Module initialized.
[ 2.494273] mali ff9a0000.gpu: leakage=24
[ 2.507963] mali ff9a0000.gpu: temp=51111, pvtm=123336 (123216 + 120)
[ 2.509868] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.510493] mali ff9a0000.gpu: pvtm-volt-sel=1
[ 2.511785] mali ff9a0000.gpu: avs=0
[ 2.513560] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.514747] mali ff9a0000.gpu: Protected mode not available
[ 2.516310] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.517028] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 2.518457] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.520915] mali ff9a0000.gpu: Probed as mali0
[ 2.522173] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.522783] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.523444] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 2.525127] hub 2-1:1.0: USB hub found
[ 2.525938] hub 2-1:1.0: 7 ports detected
[ 2.529112] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.530009] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[ 2.531187] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.532037] xhci-hcd xhci-hcd.9.auto: irq 229, io mem 0xfe800000
[ 2.532988] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.533635] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.534309] usb usb5: Product: xHCI Host Controller
[ 2.534757] usb usb5: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 2.535297] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 2.536920] hub 5-0:1.0: USB hub found
[ 2.537412] hub 5-0:1.0: 1 port detected
[ 2.538600] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.539378] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[ 2.540202] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.541105] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.541763] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.542433] usb usb6: Product: xHCI Host Controller
[ 2.542880] usb usb6: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 2.543404] usb usb6: SerialNumber: xhci-hcd.9.auto
[ 2.544704] hub 6-0:1.0: USB hub found
[ 2.545099] hub 6-0:1.0: 1 port detected
[ 2.552444] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.553113] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 7
[ 2.553944] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.554766] xhci-hcd xhci-hcd.10.auto: irq 230, io mem 0xfe900000
[ 2.555519] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.556138] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.556776] usb usb7: Product: xHCI Host Controller
[ 2.557221] usb usb7: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 2.557721] usb usb7: SerialNumber: xhci-hcd.10.auto
[ 2.558637] hub 7-0:1.0: USB hub found
[ 2.559001] hub 7-0:1.0: 1 port detected
[ 2.559660] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.560309] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 8
[ 2.561044] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.561863] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.562482] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.563120] usb usb8: Product: xHCI Host Controller
[ 2.563562] usb usb8: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 2.564061] usb usb8: SerialNumber: xhci-hcd.10.auto
[ 2.564934] hub 8-0:1.0: USB hub found
[ 2.565333] hub 8-0:1.0: 1 port detected
[ 2.566944] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.567632] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.568258] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.568788] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.569672] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.570481] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.571026] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.571906] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.585168] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.598785] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.600368] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.601061] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.601684] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.602239] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.603119] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.603975] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.604924] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[ 2.605629] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.606954] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.620391] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.634194] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.648228] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 2.659580] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.662110] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.664550] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[ 2.665506] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.668526]
[ 2.668616] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 2.668624] ======== dhd_wlan_init_plat_data ========
[ 2.668630] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.668644] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=69, oob_irq_flags=0x414
[ 2.668649] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 2.668653] dhd_wifi_platform_load: Enter
[ 2.668680] Power-up adapter ‘DHD generic adapter’
[ 2.668758] wifi_platform_set_power = 1
[ 2.668763] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.668768] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.668774] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.671656] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.674700] =======================================================
[ 2.675314] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.675905] =======================================================
[ 2.676519] Realtek 8723DU USB WiFi driver (Powered by Rockchip) init.
[ 2.677158] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.677615] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.677632] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.678604] RTW: module init start
[ 2.678922] RTW: rtl8723du v5.6.5.1_34252.20190703_COEX20181130-2e2e
[ 2.679529] RTW: build time: Sep 9 2021 14:40:38
[ 2.679985] RTW: rtl8723du BT-Coex version = COEX20181130-2e2e
[ 2.680883] usbcore: registered new interface driver rtl8723du
[ 2.681488] RTW: module init ret=0
[ 2.683744] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 2.685317] ==gsl_ts_init==
[ 2.685778] GSLX680 Enter gsl_ts_probe
[ 2.686186] ==kzalloc success=
[ 2.734889] mmc_host mmc1: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 2.969231] wifi_platform_bus_enumerate device present 1
[ 2.969722] ======== Card detection to detect SDIO card! ========
[ 2.970365] mmc1:mmc host rescan start!
[ 2.980869] vendor storage:20190527 ret = 0
[ 2.994362] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 173
[ 3.006285] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.006861] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 3.024797] bcmsdh_register: register client driver
[ 3.025525] bcmsdh_sdmmc_probe: Enter num=1
[ 3.026077] bcmsdh_sdmmc_probe: Enter num=2
[ 3.026496] bus num (host idx)=1, slot num (rca)=1
[ 3.026930] found adapter info ‘DHD generic adapter’
[ 3.027467] sdioh_attach: set sd_f2_blocksize 256
[ 3.027940] sdioh_attach: sd clock rate = 0
[ 3.028637] dhdsdio_probe : no mutex held. set lock
[ 3.029256] F1 signature read @0x18000000=0x17224356
[ 3.034897] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 3.036239] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.036968] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 3.037836] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 3.039787] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 3.040729] wl_escan_attach: Enter
[ 3.041080] wl_escan_init: Enter
[ 3.042024] wl_create_event_handler(): thread:wl_escan_handler:a5 started
[ 3.042967] tsk Enter, tsk = 0xffffffc0ef5f01b0
[ 3.043520] dhd_attach(): thread:dhd_watchdog_thread:a6 started
[ 3.044943] dhd_attach(): thread:dhd_dpc:a7 started
[ 3.046233] dhd_attach(): thread:dhd_rxf:a8 started
[ 3.046691] dhd_deferred_work_init: work queue initialized
[ 3.047205] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 3.047839] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 3.048583] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[ 3.057526] Dongle Host Driver, version 1.579.77.41.10 (r)
[ 3.058906] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[ 3.059427] Register interface [wlan0] MAC: d4:12:43:a0:36:18
[ 3.059427]
[ 3.060533] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 3.061246] dhd_wl_ioctl: returning as busstate=0
[ 3.061671] dhd_dbg_detach_pkt_monitor, 2204
[ 3.062061] dhd_bus_devreset: == Power OFF ==
[ 3.062728] bcmsdh_oob_intr_unregister: Enter
[ 3.063118] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.063656] dhd_txglom_enable: enable 0
[ 3.064010] dhd_conf_set_txglom_params: txglom_mode=copy
[ 3.064507] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 3.065101] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[ 3.065754] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[ 3.066380] dhd_bus_devreset: WLAN OFF DONE
[ 3.066795] wifi_platform_set_power = 0
[ 3.067157] ======== PULL WL_REG_ON(-1) LOW! ========
[ 3.067611] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.068042] [WLAN_RFKILL]: wifi shut off power.
[ 3.068466] dhdsdio_probe : the lock is released.
[ 3.069050] dhd_module_init: Exit err=0
[ 3.553350] gsl_ts_probe–1375, i2c_master_recv fail
[ 3.553954] ret=0
[ 3.556007] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:53:10 UTC (1358499190)
[ 3.596065] vcc_mipi: disabling
[ 3.596376] dvdd_1v2: disabling
u?
