18.04和20.04都不能重启,不管是命令行还是图形界面,点reboot,都是自动关机。两块板子都一样,刷各种ubuntu系统版本都不行,麻烦协助解决一下。
root@firefly:~# reboot
root@firefly:~# logout
Stopping Session 1 of user root.
Stopping Session c1 of user firefly.
[ OK ] Removed slice system-modprobe.slice.
[ OK ] Stopped target Bluetooth.
[ OK ] Stopped target Graphical Interface.
[ OK ] Stopped target Multi-User System.
[ OK ] Stopped target Login Prompts.
[ OK ] Stopped target Host and Network Name Lookups.
[ OK ] Stopped target Sound Card.
[ OK ] Stopped target Timers.
[ OK ] Stopped Trigger anacron every hour.
[ OK ] Stopped Daily apt upgrade and clean activities.
[ OK ] Stopped Daily apt download activities.
[ OK ] Stopped Periodic ext4 Onli…ata Check for All Filesystems.
[ OK ] Stopped Discard unused blocks once a week.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Stopped Ubuntu Advantage update messaging.
[ OK ] Stopped target System Time Synchronized.
[ OK ] Stopped target System Time Set.
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping Modem Manager…
Stopping Adbd for linux…
Stopping Save/Restore Sound Card State…
Stopping Avahi mDNS/DNS-SD Stack…
Stopping Bluetooth service…
Stopping bluetooth-toggle…
Stopping Getty on tty1…
Stopping Light Display Manager…
Stopping System Logging Service…
Stopping Serial Getty on ttyFIQ0…
Stopping OpenBSD Secure Shell server…
[ 1027.123080] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc0edd8c238
Stopping Load/Save Random Seed…
Stopping Disk Manager…
Stopping Daemon for power management…
Stopping crash report submission daemon…
[ OK ] Stopped Avahi mDNS/DNS-SD Stack.
[ OK ] Stopped System Logging Service.
[ OK ] Stopped Modem Manager.
[ OK ] Stopped Disk Manager.
[ OK ] Stopped bluetooth-toggle.
[ OK ] Stopped Bluetooth service.
[ OK ] Stopped crash report submission daemon.
[ OK ] Stopped Serial Getty on ttyFIQ0.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped OpenBSD Secure Shell server.
[ OK ] Stopped Daemon for power management.
[ OK ] Stopped Adbd for linux.
[ OK ] Stopped Save/Restore Sound Card State.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped Session 1 of user root.
[ OK ] Removed slice system-getty.slice.
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Stopped target Network is Online.
Stopping Authorization Manager…
Stopping User Manager for UID 0…
[ OK ] Stopped Authorization Manager.
[ OK ] Stopped User Manager for UID 0.
Stopping User Runtime Directory /run/user/0…
[ OK ] Unmounted /run/user/0.
[ OK ] Stopped User Runtime Directory /run/user/0.
[ OK ] Removed slice User Slice of UID 0.
[ 1028.204024] configfs-gadget fe800000.dwc3: failed to start rockchip: -19
[ OK ] Stopped Session c1 of user firefly.
Stopping Login Service…
Stopping User Manager for UID 1000…
[ OK ] Unmounted /run/user/1000/gvfs.
[ OK ] Stopped Login Service.
[ OK ] Stopped Light Display Manager.
[ OK ] Stopped User Manager for UID 1000.
Stopping User Runtime Directory /run/user/1000…
[ OK ] Unmounted /run/user/1000.
[ OK ] Stopped User Runtime Directory /run/user/1000.
[ OK ] Removed slice User Slice of UID 1000.
Stopping Permit User Sessions…
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped target Network.
[ OK ] Stopped target Remote File Systems.
Stopping Network Manager…
Stopping Network Name Resolution…
Stopping WPA supplicant…
[ OK ] Stopped WPA supplicant.
[ OK ] Stopped Network Name Resolution.
[ OK ] Stopped Network Manager.
Stopping D-Bus System Message Bus…
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Paths.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Sockets.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Stopped target System Initialization.
[ OK ] Stopped target Local Encrypted Volumes.
[ OK ] Stopped Dispatch Password …ts to Console Directory Watch.
[ OK ] Stopped Forward Password R…uests to Wall Directory Watch.
[ OK ] Stopped target Swap.
[ OK ] Closed Syslog Socket.
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
Stopping Network Time Synchronization…
Stopping Update UTMP about System Boot/Shutdown…
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Update UTMP about System Boot/Shutdown.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped target Local File Systems.
Unmounting /root-ro…
Unmounting /userdata…
[ OK ] Unmounted /root-ro.
[ OK ] Unmounted /userdata.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Stopped Create System Users.
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Reached target Shutdown.
[ OK ] Reached target Final Step.
[ OK ] Finished Reboot.
[ OK ] Reached target Reboot.
[ 1029.874616] rk808->stby_gpio(56) = low
[ 1029.875030] rk808->hold_gpio(45) = low
[ 1030.076823] reboot: Restarting system
DDR Version 1.26 20210628
soft reset
SRX
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
谁来解决一下啊?没有工程师啊???????这售后服务真的是不行啊。
板子完全断电再插上试试?
Liuth 发表于 2021-10-15 14:43
板子完全断电再插上试试?
断电后再开可以的,按一下reset也是可以的。就是重启后像关机一样没反应了。
你好,我确认下是不是硬件问题
1.你刷的固件的具体名称是什么
2.你这2块板子大概是什么时候买的
895816513 发表于 2021-10-16 17:58
你好,我确认下是不是硬件问题1.你刷的固件的具体名称是什么
FIREFLY-RK3399-UBUNTU-20.04_DESKTOP-GPT-20210915-1112.img
这两块板子买的时间比较久了。应该是2017年买的,是不是时间久了不兼容?
时间太久了,应该保存也不好,rk808附件电路应该是有损毁了,只是无法重启而已。做项目实验还是没有问题的
这个保存没有问题的,盒子里拿出来的新的。原封的。
那你联系下客服看看售后行不行,软件是没问题的
原因找到了,ubuntu16的版本可以reboot重启,但是18和20版本都不行,官方能给个说明,为什么吗?
