用的系统是16.04的,SDK版本是rv1126_rv1109_linux_20210904
kxq@ubuntu:~/Desktop/rv1126_rv1109_linux_release_20210306$ ./build.sh
processing board option: allff
processing option: allff
TARGET_ARCH=arm
TARGET_PLATFORM=rv1126_rv1109
TARGET_UBOOT_CONFIG=rv1126
TARGET_SPL_CONFIG=
TARGET_KERNEL_CONFIG=rv1126_firefly_defconfig
TARGET_KERNEL_DTS=rv1126-firefly-jd4
TARGET_TOOLCHAIN_CONFIG=
TARGET_BUILDROOT_CONFIG=firefly_rv1126_rv1109
TARGET_RECOVERY_CONFIG=firefly_rv1126_rv1109_recovery
TARGET_PCBA_CONFIG=
TARGET_RAMBOOT_CONFIG=
============Start building uboot============
## make rv1126_defconfig -j2
/home/kxq/Desktop/rv1126_rv1109_linux_release_20210306/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: 1: /home/kxq/Desktop/rv1126_rv1109_linux_release_20210306/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: ELF: not found
/home/kxq/Desktop/rv1126_rv1109_linux_release_20210306/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: 1: /home/kxq/Desktop/rv1126_rv1109_linux_release_20210306/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: Syntax error: Unterminated quoted string
dirname: missing operand
Try ‘dirname --help’ for more information.
./scripts/binutils-version.sh: 行 18: /home/kxq/Desktop/rv1126_rv1109_linux_release_20210306/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-as: cannot execute binary file: 可执行文件格式错误
CHK include/config.h
GEN include/autoconf.mk.dep
CFG u-boot.cfg
/home/kxq/Desktop/rv1126_rv1109_linux_release_20210306/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: 1: /home/kxq/Desktop/rv1126_rv1109_linux_release_20210306/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: scripts/Makefile.autoconf:79: recipe for target ‘u-boot.cfg’ failed
make[1]: *** [u-boot.cfg] Error 1
make[1]: *** 正在等待未完成的任务…
ELF: not found
scripts/Makefile.autoconf:50: recipe for target ‘include/autoconf.mk.dep’ failed
make[1]: *** [include/autoconf.mk.dep] Error 1
make: *** No rule to make target ‘include/config/auto.conf’, needed by ‘include/config/uboot.release’. Stop.
ERROR: Running build_uboot failed!
ERROR: exit code 2 from line 454:
./make.sh $RK_UBOOT_DEFCONFIG $UBOOT_COMPILE_COMMANDS
