[ 0.857789] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 0.959255] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 0.959629] rockchip-dmc dmc: Failed to get leakage
[ 0.959776] rockchip-dmc dmc: Failed to get pvtm
[ 0.960244] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 0.960281] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 0.960310] rockchip-dmc dmc: don’t add devfreq feature
[ 0.963816] rknandc_base v1.1 2017-01-11
[ 0.964332] rknandc ff4b0000.nandc: rknandc_probe clk rate = 147456000
[ 0.964423] rkflash_dev_init enter
[ 0.964449] …nandc_flash_init enter…
[ 0.964514] rkflash[0] is invalid
[ 0.964743] rksfc_base v1.1 2016-01-08
[ 0.965144] rksfc ff4c0000.sfc: rksfc_probe clk rate = 100000000
[ 0.965228] rkflash_dev_init enter
[ 0.965261] sfc nor id: c8 40 17
[ 0.965286] rkflash[1] init success
[ 0.969171] Alternate GPT is invalid, using primary GPT.
[ 0.969357] rkflash0: p1 p2 p3 p4 p5
[ 0.972248] rkflash_dev_init device register as blk dev, ret= 0
[ 0.979640] dummy_codec dummy-codec: Unable to get mclk
[ 0.980935] rk3308-acodec ff560000.acodec: Don’t need pa-drv gpio
[ 0.980969] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 0.981166] The acodec version is: b
[ 0.989088] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 0.989140] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 0.989573] rk-multicodecs vad-sound: ASoC: CPU DAI (null) not registered
[ 0.989892] flash vendor_init_thread!
[ 0.990304] Registering SWP/SWPB emulation handler
[ 0.992146] flash vendor storage:20170308 ret = 0
[ 0.993526] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 0.995404] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 0.995448] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.050873] rk-multicodecs vad-sound: multicodec ↔ pdm-i2s-dais mapping ok
[ 1.055341] rk-multicodecs bluetooth-sound: dummy_codec ↔ ff350000.i2s mapping ok
[ 1.058266] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.058848] hctosys: unable to open rtc device (rtc0)
[ 1.074170] vcc_sd: disabling
[ 1.074211] vbus_host: disabling
[ 1.074225] vccio_sd: disabling
[ 1.074615] ALSA device list:
[ 1.074632] #0: rockchip,rk3308-vad
[ 1.074642] #1: rockchip,rk3308-pcm
[ 1.074653] #7: Loopback 1
[ 1.074985] Waiting for root device PARTUUID=614e0000-0000…
请教下,外挂了SPI NOR, 打算替换原来的EMMC, 这部分是什么问题?为何会卡在着呢? 该如何解决
你是从spi nor启动?
