helium@helium-VirtualBox:~/proj/rk356x_linux_release_20211019$ ./build.sh
processing option: allff
TARGET_ARCH=arm64
TARGET_PLATFORM=rk356x
TARGET_UBOOT_CONFIG=firefly-rk3568
TARGET_SPL_CONFIG=
TARGET_KERNEL_CONFIG=firefly_linux_defconfig
TARGET_KERNEL_DTS=rk3568-firefly-roc-pc
TARGET_TOOLCHAIN_CONFIG=
TARGET_BUILDROOT_CONFIG=
TARGET_RECOVERY_CONFIG=
TARGET_PCBA_CONFIG=
TARGET_RAMBOOT_CONFIG=
============Start building uboot============
## make firefly-rk3568_defconfig -j8
/home/helium/proj/rk356x_linux_release_20211019/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc
CHK include/config.h
CFG u-boot.cfg
GEN include/autoconf.mk.dep
CFG spl/u-boot.cfg
CFG tpl/u-boot.cfg
GEN spl/include/autoconf.mk
GEN tpl/include/autoconf.mk
CHK include/config/uboot.release
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
CFG u-boot.cfg
UPD include/config/uboot.release
CHK include/generated/version_autogenerated.h
UPD include/generated/version_autogenerated.h
CHK include/generated/generic-asm-offsets.h
CHK include/generated/asm-offsets.h
HOSTCC tools/mkenvimage.o
HOSTCC tools/fit_image.o
HOSTCC tools/image-host.o
HOSTCC tools/rockchip/boot_merger.o
HOSTCC tools/rockchip/loaderimage.o
HOSTCC tools/mkimage.o
HOSTCC tools/dumpimage.o
HOSTLD tools/mkenvimage
HOSTLD tools/loaderimage
HOSTLD tools/dumpimage
HOSTLD tools/mkimage
HOSTLD tools/boot_merger
CC arch/arm/cpu/armv8/fwcall.o
LD arch/arm/cpu/armv8/built-in.o
CC cmd/version.o
CC common/main.o
LD cmd/built-in.o
LD common/built-in.o
CC drivers/usb/gadget/f_fastboot.o
CC lib/display_options.o
LD lib/built-in.o
LD drivers/usb/gadget/built-in.o
LD u-boot
OBJCOPY u-boot.srec
OBJCOPY u-boot-nodtb.bin
SYM u-boot.sym
start=$(/home/helium/proj/rk356x_linux_release_20211019/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ’ '); end=$(/home/helium/proj/rk356x_linux_release_20211019/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ’ '); tools/relocate-rela u-boot-nodtb.bin 0x00a00000 $start $end
make[2]: ‘arch/arm/dts/rk3568-firefly.dtb’ is up to date.
COPY u-boot.dtb
MKIMAGE u-boot-dtb.img
CAT u-boot-dtb.bin
MKIMAGE u-boot.img
COPY u-boot.bin
ALIGN u-boot.bin
CC spl/arch/arm/cpu/armv8/fwcall.o
CC spl/common/spl/spl.o
CC tpl/arch/arm/cpu/armv8/fwcall.o
CC tpl/arch/arm/mach-rockchip/tpl.o
COPY spl/u-boot-spl.dtb
LD spl/arch/arm/cpu/armv8/built-in.o
LD tpl/arch/arm/cpu/armv8/built-in.o
LD tpl/arch/arm/mach-rockchip/built-in.o
LD spl/common/spl/built-in.o
CC spl/lib/display_options.o
LD tpl/u-boot-tpl
LD spl/lib/built-in.o
OBJCOPY tpl/u-boot-tpl-nodtb.bin
COPY tpl/u-boot-tpl.bin
LD spl/u-boot-spl
OBJCOPY spl/u-boot-spl-nodtb.bin
CAT spl/u-boot-spl-dtb.bin
COPY spl/u-boot-spl.bin
CFGCHK u-boot.cfg
SEC=1
pack u-boot.itb okay! Input: /home/helium/proj/rk356x_linux_release_20211019/rkbin/RKTRUST/RK3568TRUST.ini
FIT description: FIT Image with ATF/OP-TEE/U-Boot
Created: Mon Nov 1 09:50:11 2021
Image 0 (uboot)
Description: U-Boot(64-bit)
Type: Standalone Program
Compression: uncompressed
Data Size: 1188472 Bytes = 1160.62 KiB = 1.13 MiB
Architecture: AArch64
Load Address: 0x00a00000
Entry Point: unavailable
Hash algo: sha256
Hash value: b9232aeefdbeab43eb724cd48fd93849572ecae02b8a9758e7fb9e284316beca
Image 1 (atf-1)
Description: ARM Trusted Firmware
Type: Firmware
Data Size: 155648 Bytes = 152.00 KiB = 0.15 MiB
Load Address: 0x00040000
Hash algo: sha256
Hash value: 796d978c0a3ed60e81d33754e85d52a4e95f77496f7714b9248ff69c30fb1138
Image 2 (atf-2)
Type: Firmware
Data Size: 19019 Bytes = 18.57 KiB = 0.02 MiB
Load Address: 0x00068000
Hash algo: sha256
Hash value: 61f58405c635136602ba390ea42a8cef1fbe9b5ae4ab18e62822abc07cac0dd7
Image 3 (atf-3)
Type: Firmware
Data Size: 8192 Bytes = 8.00 KiB = 0.01 MiB
Load Address: 0xfdcd0000
Hash algo: sha256
Hash value: 87af14e1bdba1c22a83681f00b222238aa8c3e55c0a05ba1b9977f0fda1d26ac
Image 4 (atf-4)
Type: Firmware
Load Address: 0xfdcc9000
Hash algo: sha256
Hash value: 4a24fbbebc39d312f2dd64c9d266ec74c802ae8da794d8bd77af0a9f0178d0fc
Image 5 (atf-5)
Type: Firmware
Data Size: 7668 Bytes = 7.49 KiB = 0.01 MiB
Load Address: 0x00066000
Hash algo: sha256
Hash value: 315a4195a9f6536f971c695a79fcab4870363fc7fc97f355bd091d8d7092261a
Image 6 (optee)
Description: OP-TEE
Type: Firmware
Data Size: 453056 Bytes = 442.44 KiB = 0.43 MiB
Load Address: 0x08400000
Hash algo: sha256
Hash value: 5a22c90dfc99feef08d4ce66236d36ffde04e9d0c3c275d934a63f1c32aa45c3
Image 7 (fdt)
Description: U-Boot dtb
Type: Flat Device Tree
Data Size: 15115 Bytes = 14.76 KiB = 0.01 MiB
Hash algo: sha256
Hash value: 30938731debb4198eb74f983facf8e81a2a52dfccdbac4a0a35ddeccaba3402a
Default Configuration: ‘conf’
Configuration 0 (conf)
Description: rk3568-firefly
Kernel: unavailable
Firmware: atf-1
FDT: fdt
Loadables: uboot
atf-2
atf-3
atf-4
atf-5
optee
pack loader ok.(rk356x_spl_loader_v1.10.111.bin)(0.05)
pack loader(SPL) okay! Input: /home/helium/proj/rk356x_linux_release_20211019/rkbin/RKBOOT/RK3568MINIALL.ini
/home/helium/proj/rk356x_linux_release_20211019/u-boot
pack loader with new: spl/u-boot-spl.bin
Image(no-signed, version=0): uboot.img (FIT with uboot, trust…) is ready
Image(no-signed): rk356x_spl_loader_v1.10.111.bin (with spl, ddr, usbplug) is ready
pack uboot.img okay! Input: /home/helium/proj/rk356x_linux_release_20211019/rkbin/RKTRUST/RK3568TRUST.ini
Platform RK3568 is build OK, with new .config(make firefly-rk3568_defconfig -j8)
Mon Nov 1 09:50:12 CST 2021
Image Type: Rockchip RK35 (SD/MMC) boot image
Init Data Size: 59392 bytes
Boot Data Size: 229376 bytes
Input:
/home/helium/proj/rk356x_linux_release_20211019/rkbin/bin/rk35/rk3568_ddr_1560MHz_v1.10.bin
/home/helium/proj/rk356x_linux_release_20211019/rkbin/bin/rk35/rk356x_spl_v1.11.bin
Pack rk3568 idblock.bin okay!
Running build_uboot succeeded.
Skipping build_loader for missing configs: RK_LOADER_BUILD_TARGET.
============Start building kernel============
TARGET_ARCH =arm64
TARGET_KERNEL_CONFIG =firefly_linux_defconfig
TARGET_KERNEL_DTS =rk3568-firefly-roc-pc
TARGET_KERNEL_CONFIG_FRAGMENT =
scripts/kconfig/conf --syncconfig Kconfig
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
GZIP kernel/config_data.gz
LZ4C arch/arm64/boot/Image.lz4
/bin/sh: 1: lz4c: not found
arch/arm64/boot/Makefile:31: recipe for target ‘arch/arm64/boot/Image.lz4’ failed
make[1]: *** [arch/arm64/boot/Image.lz4] Error 1
arch/arm64/Makefile:139: recipe for target ‘Image.lz4’ failed
make: *** [Image.lz4] Error 2
ERROR: Running build_kernel failed!
ERROR: exit code 2 from line 561:
make ARCH=$RK_ARCH $RK_KERNEL_DTS.img -j$RK_JOBS
