同步代码出错
我们的ubuntu20.04平台,下载了CORE-3399PRO-JD4的源码Linux-SDK源码包(仅支持RK3399),按照维基教程,安装完编译环境和解包之后,执行.repo/repo/repo sync -l出错,求教大神,错误信息如下:warning: Python 3 support is currently experimental. YMMV.
Please use Python 2.6 - 2.7 instead.
/media/zhang/CACCC8ADCCC894DB/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/main.py:19: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module’s documentation for alternative uses
import imp
error: unable to create file openssl-1.0.2a-parallel-install-dirs.patch?id=c8abcbe8de5d3b6cdd68c162f398c011ff6e2d9d: 无效的参数
error: unable to create file openssl-1.0.2a-parallel-obj-headers.patch?id=c8abcbe8de5d3b6cdd68c162f398c011ff6e2d9d: 无效的参数
error: unable to create file openssl-1.0.2a-parallel-symlinking.patch?id=c8abcbe8de5d3b6cdd68c162f398c011ff6e2d9d: 无效的参数
error: unable to create file openssl-1.0.2d-parallel-build.patch?id=c8abcbe8de5d3b6cdd68c162f398c011ff6e2d9d: 无效的参数
正在更新文件: 100% (325/325), 完成.
File “/media/zhang/CACCC8ADCCC894DB/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/main.py”, line 531, in
_Main(sys.argv[1:])
File “/media/zhang/CACCC8ADCCC894DB/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/main.py”, line 507, in _Main
result = repo._Run(argv) or 0
File “/media/zhang/CACCC8ADCCC894DB/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/main.py”, line 180, in _Run
result = cmd.Execute(copts, cargs)
File “/media/zhang/CACCC8ADCCC894DB/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/subcmds/sync.py”, line 821, in Execute
project.Sync_LocalHalf(syncbuf, force_sync=opt.force_sync)
File “/media/zhang/CACCC8ADCCC894DB/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/project.py”, line 1327, in Sync_LocalHalf
self._InitWorkTree(force_sync=force_sync)
File “/media/zhang/CACCC8ADCCC894DB/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/project.py”, line 2486, in _InitWorkTree
raise GitError(“cannot initialize work tree”)
error.GitError: cannot initialize work tree
