我的平台是ubuntu20.04的,下载了rk3399pro的linux版本的源码,解压后.repo/repo/repo sync -l提示完成,但在.repo/repo/repo sync -c --no-tags时,出现的错误信息如下:希望得到大神帮助
warning: Python 3 support is currently experimental. YMMV.
Please use Python 2.6 - 2.7 instead.
/media/zhang/265c26d4-df61-48f3-a632-015e21d8826a/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/main.py:19: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module’s documentation for alternative uses
import imp
Fetching project external/minilogger
Fetching project external/rknpu-fw
Fetching project yocto/meta-python2
Fetching project kernel
Fetching project external/rknn-toolkit
Fetching project debian
Fetching project external/rockx
error: Cannot fetch external/minilogger (AttributeError: ‘str’ object has no attribute ‘decode’)
Exception in thread Thread-1:
Fetching project buildroot-dl
error: Cannot fetch external/rknpu-fw (AttributeError: ‘str’ object has no attribute ‘decode’)
error: Cannot fetch yocto/meta-python2 (AttributeError: ‘str’ object has no attribute ‘decode’)
Exception in thread Thread-2:
Exception in thread Thread-3:
File “/usr/lib/python3.8/threading.py”, line 932, in _bootstrap_inner
self.run()
self.run()
File “/usr/lib/python3.8/threading.py”, line 870, in run
self.run()
self._target(*self._args, **self._kwargs)
File “/media/zhang/265c26d4-df61-48f3-a632-015e21d8826a/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/subcmds/sync.py”, line 270, in _FetchProjectList
success = self._FetchHelper(opt, project, *args, **kwargs)
File “/media/zhang/265c26d4-df61-48f3-a632-015e21d8826a/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/subcmds/sync.py”, line 307, in _FetchHelper
success = project.Sync_NetworkHalf(
File “/media/zhang/265c26d4-df61-48f3-a632-015e21d8826a/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/project.py”, line 1229, in Sync_NetworkHalf
self._InitGitDir(force_sync=force_sync)
File “/media/zhang/265c26d4-df61-48f3-a632-015e21d8826a/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/project.py”, line 2298, in _InitGitDir
self.config.SetString(‘filter.lfs.smudge’, ‘git-lfs smudge --skip – %f’)
File “/media/zhang/265c26d4-df61-48f3-a632-015e21d8826a/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/git_config.py”, line 158, in SetString
old = self._cache[key]
File “/media/zhang/265c26d4-df61-48f3-a632-015e21d8826a/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/git_config.py”, line 248, in _cache
self._cache_dict = self._Read()
File “/media/zhang/265c26d4-df61-48f3-a632-015e21d8826a/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/git_config.py”, line 254, in _Read
d = self._ReadGit()
d = self._ReadGit()
File “/media/zhang/265c26d4-df61-48f3-a632-015e21d8826a/source/rk3399pro_linux_release_v2.5.1_20210304/.repo/repo/git_config.py”, line 299, in _ReadGit
d = self._ReadGit()
for line in d.decode(‘utf-8’).rstrip(‘\0’).split(‘\0’): # pylint: disable=W1401
你告诉我python2和python3的版本是多少
python --version
python3 --version
,不过据我同事反映ubuntu20.04的deb包支持不是很完善的,能同步代码也不能编译。需要装个docker虚拟出ubuntu18.04编译。要不你就直接使用docker技术。
python --version返回3.8.10
有没ubuntu18.04的源代码?
rk3399在ubuntu20.04.2可正常同步编译,没有问题
原因好像是repo仓库没更新
我在.repo/repo/里面执行git pull之后就好了
