各位大侠:
prime板子烧写官方提供的Android4.4.4固件kernel启动不了,卡主了是什么原因啊?log如下:
DDR Version 2.03 20150112
1A1A292A 0
1A1A292A 3
LPDDR2
292A292A F
Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Die Bus-Width=32 Size=1024MB
mach:14
2.20 1
ChipType = a
No.1 FLASH ID:ad de 14 a7 42 4a
*V玨%攻氧0 20
StorageInit ok = 632997
the
U-Boot 2014.10-RK3128-01-01494-ge43350b (Jul 31 2015 - 14:46:21)
CPU: rk3128
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks:1
128 MiB
rk dma pl330 v譑厺晛init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk312x!
Unknow param: MACHINE_ID:007!
power key: bank-3 pin-23
#Boot ver: 2015-02-26#2.20
empty serial no.
checkKey
vbus = 1
read logo_on switch from dts [1]
can’t find dts node for deviceinfo
rk_hdmi_register:fail to read deviceinfo
preset hdmi resolution is 1280x720@60-0,i=8
preset tve resolution is 720x576@50-1,i=1
Hdmi Devices Not Exist.
test_mode=0,saturation=0x0
SCREEN_TVOUT
rk3036_tve_init:use baseparamer config g_tve_pos = 1
failed to find part:logo
show_resource_image:show logo from resource or boot partition
checkKey
vbus = 1
got recovery cmd from misc.
failed to load fdt from recovery!
kernel @ 0x62000000 (0x0067cc20)
ramdisk @ 0x64bf0000 (0x0042a1d8)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 64516000, end 6452c003 … OK
Add bank:0000000060000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (fuyongjie@A11140321040063) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Jul 31 14:45:43 CST 2015 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128 [ 0.000000] hdmi init vic is -1 [ 0.000000] cvbs init tve.format is 1 [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(0) size(800000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 8 MiX0000 [ 0.000000] ion_
