AIO-3399ProC编译9.0源码失败(压缩包方式)
官网下载android9.0源码包
1 校验
$ md5sum /path/to/rk3399pro_firefly_android9.0_20191126.7z.001
$ md5sum /path/to/rk3399pro_firefly_android9.0_20191126.7z.002
6e1d3969c8a0f643522727ff07800bb5 rk3399pro_firefly_android9.0_20191126.7z.001
a6b8d6a775c3d5ed28f4d41cb210a84d rk3399pro_firefly_android9.0_20191126.7z.002
2,解压
cd ~/proj/
7z x ./rk3399pro_firefly_android9.0_20191126.7z.001 -oAIO-3399Pro
cd ./AIO-3399Pro
git reset --hard
正常
3,HDMI显示编译
./FFTools/make.sh -d rk3399pro-firefly-aioc -j8 -l rk3399pro_firefly_aioc-userdebug
编程出错如下
bundle更新一下SDK
我也是遇到同样问题。如果不在论坛里面找。也不知道原因。第一反应是既然是发布的资料包,应该不会存在这种编译失败的低级错误。
不得不吐槽一下。既然是官方发布的资源,官方发布的资料没有经过充分的验证就发布了。这是一种不负责任的行为。
另外,既然发现了有问题。也可以及时更新wifi的教程提醒一下如果编译失败需要更新bundle。
不然技术支持一直要回答编译失败的问题。同时用户对你们公司也会有看法。
@社区版主
[ 60% 46911/78034] //bionic/libc:libc…ndk versioner preprocess include [arm]
warning: attempted to generate guard with empty availability: obsoleted = 21
warning: attempted to generate guard with empty availability: obsoleted = 23
[ 60% 46912/78034] //bionic/libc:commo…ioner preprocess include [linux_glibc]
[ 60% 46913/78034] //bionic/libc:libc.llndk versioner preprocess include
[ 60% 46914/78034] //libcore:core-oj javac [common]
ninja: build stopped: subcommand failed.
22:26:25 ninja failed with: exit status 1
更新后,我这里执行 ./FFTools/make.sh -d rk3399pro-firefly-aioc -j8 -l rk3399pro_firefly_aioc-userdebug, 报上述错误,请帮忙看下原因;
[ 60% 46907/78034] build out/target/co…ntermediates/dex-hiddenapi/classes.dex
FAILED: out/target/common/obj/JAVA_LIBRARIES/apache-xml_intermediates/dex-hiddenapi/classes.dex
/bin/bash -c “(rm -rf out/target/common/obj/JAVA_LIBRARIES/apache-xml_intermediates/dex-hiddenapi/ ) && (mkdir -p out/target/common/obj/JAVA_LIBRARIES/apache-xml_intermediates/dex-hiddenapi/ ) && (find out/target/common/obj/JAVA_LIBRARIES/apache-xml_intermediates/dex/ -maxdepth 1 -name "classes*.dex" | sort | xargs -I{} cp -f {} out/target/common/obj/JAVA_LIBRARIES/apache-xml_intermediates/dex-hiddenapi/ ) && (find out/target/common/obj/JAVA_LIBRARIES/apache-xml_intermediates/dex-hiddenapi/ -name "classes*.dex" | sort | sed ‘s/^/–dex=/’ | xargs out/host/linux-x86/bin/hiddenapi --light-greylist=out/target/common/obj/PACKAGING/hiddenapi-light-greylist.txt --dark-greylist=out/target/common/obj/PACKAGING/hiddenapi-dark-greylist.txt --blacklist=out/target/common/obj/PACKAGING/hiddenapi-blacklist.txt )”
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] No DEX files specified
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] Command: out/host/linux-x86/bin/hiddenapi --light-greylist=out/target/common/obj/PACKAGING/hiddenapi-light-greylist.txt --dark-greylist=out/target/common/obj/PACKAGING/hiddenapi-dark-greylist.txt --blacklist=out/target/common/obj/PACKAGING/hiddenapi-blacklist.txt
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] Usage: hiddenapi [options]…
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] --dex=: specify dex file whose members’ access flags are to be set.
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] At least one --dex parameter must be specified.
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] --light-greylist=:
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] --dark-greylist=:
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] --blacklist=: text files with signatures of methods/fields to be marked
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] greylisted/blacklisted respectively. At least one list must be provided.
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] --print-hidden-api: dump a list of marked methods/fields to the standard output.
hiddenapi E 04-20 22:26:12 182044 182044 hiddenapi.cc:47] There is no indication which API category they belong to.
