rk3568 Linux环境下 npu初始化环境失败
服务开启了,lib更新还是报错
→ Init runtime environment
all device(s) with adb mode:
d0f685c761819928
I NPUTransfer: Starting NPU Transfer Client, Transfer version 2.1.0 (b5861e7@2020-11-23T11:50:36)
D RKNNAPI: ==============================================
D RKNNAPI: RKNN VERSION:
D RKNNAPI: API: 1.1.0 (e3000ff build: 2021-08-19 18:03:18)
D RKNNAPI: DRV: rknn_server: 1.1.0 (6d07b2c build: 2021-08-13 16:36:52)
D RKNNAPI: DRV: rknnrt: 1.1.0 (8a9d6f66@2021-08-19T15:09:11)
E RKNNAPI: rknn_init, send(MsgLoad) fail, -9(ERROR_PIPE) != 26367924!
E init_runtime: Catch exception when init runtime!
E init_runtime: Traceback (most recent call last):
E init_runtime: File “rknn/api/rknn_base.py”, line 2553, in rknn.api.rknn_base.RKNNBase.init_runtime
E init_runtime: File “rknn/api/rknn_runtime.py”, line 367, in rknn.api.rknn_runtime.RKNNRuntime.build_graph
E init_runtime: Exception: RKNN init failed. error code: RKNN_ERR_DEVICE_UNAVAILABLE
Init runtime environment failed
你这个应该是rknn_server没有正常运行
使用rknn SDK里面的最新rknn_server和库文件
librknn_api.so librknnrt.so这俩个放在板子的/usr/lib/下
rknn_server放在板子/usr/bin/下
运行:
./rknn_server
