从firefly img导出的rootfs,重新制作成img烧录进开发板,没问题,可正常登录,但是用nfs挂载启动这个rootfs出现好几个问题。看起来好像是没有写权限。有没有小伙伴成功挂载firefly img的rootfs,请指教一下,以下是nfs系统启动的打印
[ 8.432458] No soundcards found.
[ 8.449632] VFS: Mounted root (nfs filesystem) on device 0:16.
[ 8.456334] devtmpfs: mounted
[ 8.460005] Freeing unused kernel memory: 1024K
[ 11.709698] systemd[1]: System time before build time, advancing clock.
[ 11.858200] systemd[1]: Failed to insert module ‘autofs4’: No such file or directory
[ 11.887742] cgroup: cgroup2: unknown option “nsdelegate”
[ 11.945239] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 11.968031] systemd[1]: Detected architecture arm.
Welcome to Ubuntu 18.04.4 LTS!
[ 11.990230] systemd[1]: Set hostname to .
[ 13.061493] systemd[1]: File /lib/systemd/system/systemd-udevd.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 13.079353] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 14.608896] systemd[1]: /lib/systemd/system/serial-getty@.service:14: Failed to add dependency on dev-ttyFIQ0, ignoring: Invalid argument
[ 14.799315] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 14.807458] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 14.815081] systemd[1]: Reached target User and Group Name Lookups.
[ OK ] Reached target User and Group Name Lookups.
[ 14.827286] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 14.842088] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 14.853723] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 14.864120] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 14.873621] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 14.884586] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 14.895179] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 14.905735] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 14.916173] systemd[1]: Mounting Kernel Debug File System…
[ 14.935593] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 14.944100] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 14.963704] systemd[1]: Starting Load Kernel Modules…
[ 14.974116] systemd[1]: Starting Set the console keyboard layout…
[ 15.064945] systemd[1]: Starting Journal Service…
[ 15.070258] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 15.079534] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 15.090347] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 15.103457] systemd[1]: Starting udev Coldplug all Devices…
[ 15.114014] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 15.123047] systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
[ 15.174173] systemd[1]: Started Load Kernel Modules.
[ OK ] Started Load Kernel Modules.
[ 15.182303] systemd[1]: Mounting FUSE Control File System…
[ 15.191972] systemd[1]: Starting Apply Kernel Variables…
[ 15.202036] systemd[1]: Mounting Kernel Configuration File System…
[ 15.225723] systemd[1]: Starting Load/Save Random Seed…
[ 15.232896] systemd[1]: Mounted FUSE Control File System.
[ OK ] Mounted FUSE Control File System.
[ 15.247350] systemd[1]: Mounted Kernel Configuration File System.
[ OK ] Mounted Kernel Configuration File System.
[ 15.261641] systemd[1]: Started Create Static Device Nodes in /dev.
[ OK ] Started Create Static Device Nodes in /dev.
[ 15.271217] systemd[1]: Starting udev Kernel Device Manager…
[ 15.301291] systemd[1]: Failed to start Load/Save Random Seed.
[FAILED] Failed to start Load/Save Random Seed.
See ‘systemctl status systemd-random-seed.service’ for details.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage…
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Set the console keyboard layout.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Set console font and keymap…
Starting Tell Plymouth To Write Out Runtime Data…
Starting Create Volatile Files and Directories…
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Set console font and keymap.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[FAILED] Failed to start Create Volatile Files and Directories.
See ‘systemctl status systemd-tmpfiles-setup.service’ for details.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Network Name Resolution…
Starting Network Time Synchronization…
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…ightness of backlight:backlight…
[FAILED] Failed to start Network Time Synchronization.
See ‘systemctl status systemd-timesyncd.service’ for details.
[FAILED] Failed to start Load/Save Screen Ba…Brightness of backlight:backlight.
See ‘systemctl status systemd-backlight…cklight:backlight.service’ for details.
[ OK ] Stopped Network Time Synchronization.
Starting Load/Save RF Kill Switch Status…
[FAILED] Failed to start Load/Save RF Kill Switch Status.
See ‘systemctl status systemd-rfkill.service’ for details.
[ OK ] Reached target System Time Synchronized.
[FAILED] Failed to start Update UTMP about System Boot/Shutdown.
See ‘systemctl status systemd-update-utmp.service’ for details.
[DEPEND] Dependency failed for Update UTMP about System Runlevel Changes.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
[ OK ] Reached target Paths.
[ OK ] Reached target Basic System.
Starting System Logging Service…
Starting Login Service…
Starting Avahi mDNS/DNS-SD Stack…
Starting Accounts Service…
Starting rkisp 3A engine…
[ OK ] Started Set the CPU Frequency Scaling governor.
[ OK ] Started D-Bus System Message Bus.
Starting WPA supplicant…
Starting Modem Manager…
Starting Restore /etc/resolv.conf i…fore the ppp link was shut down…
[ OK ] Started Regular background program processing daemon.
Starting LSB: automatic crash report generation…
Starting Dispatcher daemon for systemd-networkd…
Starting Adbd for linux…
Starting Disk Manager…
Starting Network Manager…
[ OK ] Started Network Name Resolution.
[ OK ] Started System Logging Service.
[ OK ] Started Login Service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started WPA supplicant.
[ OK ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[ 19.633587] stmmac_hw_setup: DMA engine initialization failed
[ 19.639358] stmmac_open: Hw setup failed
[ OK ] Started rkisp 3A engine.
Starting Authorization Manager…
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Started Authorization Manager.
[ OK ] Started Accounts Service.
[ OK ] Started Modem Manager.
Starting Hostname Service…
[ OK ] Started Disk Manager.
[ OK ] Started Hostname Service.
Starting Network Manager Script Dispatcher Service…
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Started Adbd for linux.
[ 22.090615] stmmac_hw_setup: DMA engine initialization failed
[ 22.096381] stmmac_open: Hw setup failed
[ OK ] Started Dispatcher daemon for systemd-networkd.
[ 22.505848] stmmac_hw_setup: DMA engine initialization failed
[ 22.511620] stmmac_open: Hw setup failed
[ 22.649995] stmmac_hw_setup: DMA engine initialization failed
[ 22.655745] stmmac_open: Hw setup failed
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting Permit User Sessions…
Starting OpenBSD Secure Shell server…
Starting /etc/rc.local Compatibility…
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Permit User Sessions.
Starting Hold until boot process finishes up…
Starting Light Display Manager…
[ OK ] Started Hold until boot process finishes up.
Starting Set console scheme…
[ OK ] Started Serial Getty on ttyFIQ0.
[ 22.775197] stmmac_hw_setup: DMA engine initialization failed
[ 22.786387] stmmac_open: Hw setup failed
[ OK ] Started Set console scheme.
[ OK ] Created slice system-getty.slice.
[ 22.907022] stmmac_hw_setup: DMA engine initialization failed
[ 22.916437] stmmac_open: Hw setup failed
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Reached target Multi-User System.
Ubuntu 18.04.4 LTS firefly ttyFIQ0
firefly login: root (automatic login)
Authentication failure
