AIO-3399J的UBUNTU是否支持HDMIIN功能
您好,我用的是AIO-3399J的板子,收到板子后重新烧的UBUNTU固件,版本是AIO-3399J-UBUNTU-18.04_DESKTOP-GPT-20211028-1323.img,用了一个HDMI输入的信号,发现有问题,麻烦工程师帮忙看一下,该版本的固件是否支持HDMIIN的功能,有没有直接支持HMDIIN功能的固件,谢谢您!
建服务器的指令是./test-launch “( rkisp device=/dev/video0 io-mode=1 analyzer=0 enable-3a=0 ! video/x-raw,format=NV12,width=1920,height=1080, framerate=30/1 ! videoconvert ! mpph264enc ! rtph264pay name=pay0 pt=96 )”,
用其他电脑来获取数据流,发现出错,
日志为mpp[1344]: mpp_info: mpp version: 49f29006 author: Jeffy Chen 2021-08-04 [drm]: Add mmap flag detection
mpp[1344]: mpp_rt: NOT found ion allocator
mpp[1344]: mpp_rt: found drm allocator
[ 302.426468] rk_vcodec: vpu_service_ioctl:2142: error: unknown vpu service ioctl cmd 40086c01
media get entity by name: lens is null
[NO]:XCAM ERROR rkisp_control_loop_impl.cpp:146: failed to get camera module info
[NO]:XCAM ERROR rkisp_control_loop_impl.cpp:337: failed to get cam module info
[XCORE]:XCAM ERROR rkisp_device.cpp:72: atomisp device(/dev/video0) try subdev format failed
[XCORE]:XCAM ERROR v4l2_device.cpp:342: device(/dev/video0) set v4l2 format failed, supported format: width:800, height:600
[NO]:XCAM ERROR rkisp_control_loop_impl.cpp:391: rkisp_cl_start: invalid cl state 0
Segmentation fault
