使用的emmc器件烧录的官方android10系统,无法进入系统,打印log卡在
[ 1.345894] usb usb5: Manufacturer: Linux 4.19.111 ehci_hcd
[ 1.345929] usb usb5: SerialNumber: fe380000.usb
[ 1.347230] hub 5-0:1.0: USB hub found
[ 1.347320] hub 5-0:1.0: 1 port detected
[ 1.348831] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.349254] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.349794] ohci-platform fe3a0000.usb: irq 32, io mem 0xfe3a0000
[ 1.355471] usb 1-1: New USB device found, idVendor=0bda, idProduct=d723, bcdDevice= 2.00
[ 1.355526] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.355547] usb 1-1: Product: 802.11n WLAN Adapter
[ 1.355566] usb 1-1: Manufacturer: Realtek
[ 1.355583] usb 1-1: SerialNumber: 00e04c000001
[ 1.356949] rtk_btusb: btusb_probe: usb_interface 000000003d634fbf, bInterfaceNumber 0, idVendor 0x0bda, idProduct 0x0000
[ 1.356981] rtk_btusb: get_fw_table_entry: Product id = 0xd723, fw table entry size 62
[ 1.356999] rtk_btusb: firmware_info_init: Auto suspend is disabled
[ 1.357025] rtk_btusb: btusb_probe: Check bt reset flag 0
[ 1.357042] rtk_btusb: load_firmware_info: Default lmp version = 0x8723, fw file name[rtl8723d_fw]
[ 1.357174] usb 1-1: Direct firmware load for rtl8723d_fw failed with error -2
[ 1.405744] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.405806] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.405829] usb usb6: Product: Generic Platform OHCI controller
[ 1.405885] usb usb6: Manufacturer: Linux 4.19.111 ohci_hcd
[ 1.405909] usb usb6: SerialNumber: fe3a0000.usb
[ 1.407093] hub 6-0:1.0: USB hub found
[ 1.407203] hub 6-0:1.0: 1 port detected
[ 1.408941] rockchip-dmc dmc: Linked as a consumer to regulator.15
[ 1.409131] rockchip-dmc dmc: Failed to get leakage
[ 1.409229] rockchip-dmc dmc: Failed to get pvtm
[ 1.410097] rockchip-dmc dmc: avs=0
[ 1.410467] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.410538] rockchip-dmc dmc: could not find power_model node
[ 1.414231] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 1.420057] rockchip-cdndp-sound dp-sound: spdif-hifi ↔ ff870000.spdif mapping ok
[ 1.427709] lzfdebug enter rtc_hctosys
[ 1.427932] rtc-hym8563 0-0051: setting system clock to 2017-01-15 19:14:22 UTC (1484507662)
[ 1.429591] It doesn’t contain Rogue gpu
[ 1.430320] rockchip_headset rk-headset: Can not read property hook_gpio
[ 1.430369] rockchip_headset rk-headset: headset have hook adc mode
[ 1.430704] input: rk-headset as /devices/platform/rk-headset/input/input2
[ 1.434628] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.437444] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.437699] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.437738] cfg80211: failed to load regulatory.db
[ 1.439060] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘17:08:22’, on ‘Nov 6 2020’.
[ 1.439879] Mali:
[ 1.439884] Mali device driver loaded
[ 1.440633] input: rk29-keypad as /devices/platform/rockchip-key/input/input3
[ 1.441387] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 1.442244] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.442348] rkisp1: update sensor failed
[ 1.442396] rkisp1 ff920000.rkisp1: clear unready subdev num: 1
[ 1.442915] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.442963] rkisp1: update sensor failed
u▒ 1.445010]
请各位大佬帮忙看看。
