使用全自动编译Ubuntu固件的时候,执行recovery这一步的时候,ubunturootfs里面的跟文件系统自动被删除了,导致最后打包报错了,请大神帮忙分析是什么原因:
zgh@linux:~/rk3399_linux_release_v2.5.1_20210301$ ./build.sh
processing option: allff
TARGET_ARCH=arm64
TARGET_PLATFORM=rk3399
TARGET_UBOOT_CONFIG=firefly-rk3399
TARGET_SPL_CONFIG=
TARGET_KERNEL_CONFIG=firefly_linux_defconfig
TARGET_KERNEL_DTS=rk3399-firefly-aiojd4-lvds
TARGET_TOOLCHAIN_CONFIG=
TARGET_BUILDROOT_CONFIG=
TARGET_RECOVERY_CONFIG=rockchip_rk3399_recovery
TARGET_PCBA_CONFIG=rockchip_rk3399_pcba
TARGET_RAMBOOT_CONFIG=
============Start building uboot============
## make firefly-rk3399_defconfig -j8
CHK include/config.h
CFG u-boot.cfg
GEN include/autoconf.mk.dep
CFG spl/u-boot.cfg
CFG tpl/u-boot.cfg
GEN spl/include/autoconf.mk
GEN tpl/include/autoconf.mk
CHK include/config/uboot.release
CHK include/generated/timestamp_autogenerated.h
CFG u-boot.cfg
UPD include/generated/timestamp_autogenerated.h
CHK include/generated/version_autogenerated.h
CHK include/generated/generic-asm-offsets.h
CHK include/generated/asm-offsets.h
HOSTCC tools/mkenvimage.o
HOSTCC tools/fit_image.o
HOSTCC tools/image-host.o
HOSTCC tools/dumpimage.o
HOSTCC tools/mkimage.o
HOSTCC tools/rockchip/boot_merger.o
HOSTCC tools/rockchip/loaderimage.o
HOSTLD tools/mkenvimage
HOSTLD tools/loaderimage
HOSTLD tools/dumpimage
HOSTLD tools/mkimage
HOSTLD tools/boot_merger
CC arch/arm/cpu/armv8/fwcall.o
CC cmd/version.o
CC common/main.o
LD arch/arm/cpu/armv8/built-in.o
LD cmd/built-in.o
LD common/built-in.o
CC drivers/usb/gadget/f_fastboot.o
CC lib/smbios.o
CC lib/display_options.o
CC lib/efi_loader/helloworld.o
LD lib/efi_loader/helloworld.so
OBJCOPY lib/efi_loader/helloworld.efi
LD drivers/usb/gadget/built-in.o
LD lib/built-in.o
LD u-boot
OBJCOPY u-boot.srec
OBJCOPY u-boot-nodtb.bin
SYM u-boot.sym
start=$(/home/zgh/rk3399_linux_release_v2.5.1_20210301/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ’ '); end=$(/home/zgh/rk3399_linux_release_v2.5.1_20210301/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ’ '); tools/relocate-rela u-boot-nodtb.bin 0x00200000 $start $end
make[2]: “arch/arm/dts/rk3399-firefly.dtb”已是最新。
CAT u-boot-dtb.bin
MKIMAGE u-boot.img
COPY u-boot.dtb
MKIMAGE u-boot-dtb.img
COPY u-boot.bin
ALIGN u-boot.bin
CC tpl/common/spl/spl.o
CC tpl/arch/arm/mach-rockchip/tpl.o
CC spl/arch/arm/cpu/armv8/fwcall.o
CC spl/common/spl/spl.o
CC tpl/arch/arm/cpu/armv8/fwcall.o
LD spl/arch/arm/cpu/armv8/built-in.o
LD tpl/arch/arm/cpu/armv8/built-in.o
LD tpl/arch/arm/mach-rockchip/built-in.o
LD tpl/common/spl/built-in.o
LD spl/common/spl/built-in.o
COPY spl/u-boot-spl.dtb
COPY tpl/u-boot-tpl.dtb
CC tpl/lib/display_options.o
LD tpl/lib/built-in.o
CC spl/lib/display_options.o
LD spl/lib/built-in.o
LD tpl/u-boot-tpl
LD spl/u-boot-spl
OBJCOPY tpl/u-boot-tpl-nodtb.bin
CAT tpl/u-boot-tpl-dtb.bin
COPY tpl/u-boot-tpl.bin
OBJCOPY spl/u-boot-spl-nodtb.bin
CAT spl/u-boot-spl-dtb.bin
COPY spl/u-boot-spl.bin
CFGCHK u-boot.cfg
load addr is 0x200000!
pack input u-boot.bin
pack file size: 946352(924 KB)
crc = 0x84f82744
uboot version: U-Boot 2017.09-g948c63a14e-dirty #zgh (Nov 24 2021 - 09:53:38)
pack uboot.img success!
pack uboot okay! Input: u-boot.bin
out:trust.img
merge success(trust.img)
/home/zgh/rk3399_linux_release_v2.5.1_20210301/u-boot
pack trust okay! Input: /home/zgh/rk3399_linux_release_v2.5.1_20210301/rkbin/RKTRUST/RK3399TRUST.ini
Image Type: Rockchip RK33 (SD/MMC) boot image
Init Data Size: 153600 bytes
pack loader ok.(rk3399_loader_v1.26.126.bin)(0.00)
pack rk3399_loader_v1.26.126.bin okay! Input: /home/zgh/rk3399_linux_release_v2.5.1_20210301/rkbin/RKBOOT/RK3399MINIALL.ini
Platform RK3399 is build OK, with new .config(make firefly-rk3399_defconfig -j8)
Running build_uboot succeeded.
Skipping build_loader for missing configs: RK_LOADER_BUILD_TARGET.
============Start building kernel============
TARGET_ARCH =arm64
TARGET_KERNEL_CONFIG =firefly_linux_defconfig
TARGET_KERNEL_DTS =rk3399-firefly-aiojd4-lvds
TARGET_KERNEL_CONFIG_FRAGMENT =
CHK scripts/mod/devicetable-offsets.h
make[1]: “arch/arm64/boot/dts/rockchip/rk3399-firefly-aiojd4-lvds.dtb”已是最新。
CHK include/generated/timeconst.h
CHK include/generated/bounds.h
CALL scripts/checksyscalls.sh
make[1]: “include/generated/vdso-offsets.h”已是最新。
CHK include/generated/compile.h
make[1]: “arch/arm64/boot/Image.lz4”已是最新。
Image: kernel.img is ready
make[2]: “include/generated/vdso-offsets.h”已是最新。
Building modules, stage 2.
MODPOST 2 modules
Image: resource.img (with rk3399-firefly-aiojd4-lvds.dtb logo.bmp ) is ready
Image: boot.img (with Image ramdisk.img resource.img) is ready
Image: zboot.img (with Image.lz4 ramdisk.img resource.img) is ready
Running build_kernel succeeded.
Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN.
Skipping build_buildroot for missing configs: RK_CFG_BUILDROOT.
buildroot/output//images/rootfs.ext4 not generated?
Running build_rootfs succeeded.
==========Start building recovery==========
config is rockchip_rk3399_recovery
found kernel image
Top of tree: /home/zgh/rk3399_linux_release_v2.5.1_20210301
#TARGET_BOARD=rk3399
#OUTPUT_DIR=output/rockchip_rk3399_recovery
#CONFIG=rockchip_rk3399_recovery_defconfig
make: Entering directory ‘/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot’
GEN /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/Makefile
/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/build/defconfig_hook.py -m /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/configs/rockchip_rk3399_recovery_defconfig /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig
BR2_DEFCONFIG=‘’ KCONFIG_AUTOCONFIG=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/buildroot-config/tristate.config BR2_CONFIG=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.config HOST_GCC_VERSION=“7” BUILD_DIR=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build SKIP_LEGACY= BR2_DEFCONFIG=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/configs/rockchip_rk3399_recovery_defconfig /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/buildroot-config/conf --defconfig=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig Config.in
/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:65
override: reassigning to symbol BR2_PACKAGE_UPDATE
/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:66
override: reassigning to symbol BR2_PACKAGE_RKSCRIPT
/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:70
override: reassigning to symbol BR2_PACKAGE_EXFAT
/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:71
override: reassigning to symbol BR2_PACKAGE_EXFAT_UTILS
/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:73
override: reassigning to symbol BR2_PACKAGE_NTFS_3G
# configuration written to /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.config
make: Leaving directory ‘/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot’
====Start build rockchip_rk3399_recovery====
2021-11-24T09:54:28 >>> Finalizing target directory
2021-11-24T09:54:30 >>> Sanitizing RPATH in target tree
2021-11-24T09:54:31 >>> Copying overlay board/rockchip/rk3399/fs-overlay-64/
2021-11-24T09:54:31 >>> Copying overlay board/rockchip/common/base
2021-11-24T09:54:31 >>> Copying overlay board/rockchip/common/recovery
2021-11-24T09:54:31 >>> Executing post-build script build/post.sh
2021-11-24T09:54:31 >>> Generating root filesystem image rootfs.cpio
2021-11-24T09:54:34 >>> Generating root filesystem image rootfs.ext2
2021-11-24T09:54:35 >>> Generating root filesystem image rootfs.squashfs
2021-11-24T09:54:36 >>> Generating root filesystem image rootfs.tar
Done in 14s
log saved on /home/zgh/rk3399_linux_release_v2.5.1_20210301/br.log
====Build rockchip_rk3399_recovery ok!====
pack recovery.img…done.
you take 0:17.77 to build recovery
====Build recovery ok!====
Running build_recovery succeeded.
Skipping build_ramboot for missing configs: RK_CFG_RAMBOOT.
Running build_all succeeded.
/usr/bin/fakeroot
warning: /home/zgh/rk3399_linux_release_v2.5.1_20210301/ubunturootfs/ubuntu_18.04_arm64_NOGPUVPU_ext4_v2.03-28-g6eebc47_20201204-0948_MINIMAL.img not found!
please set correct RK_ROOTFS_IMG in device/rockchip/.BoardConfig.mk
create parameter…done.
/home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/rk3399/parameter-4.19.txt
0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x00020000@0x0003a000(oem),0x00c00000@0x0005a000(rootfs),-@0x00c5a000(userdata:grow)
create recovery.img…done.
create misc.img…done.
Source buildroot/build/envsetup.sh
No available configs for: /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/oem/oem_normal
Making /home/zgh/rk3399_linux_release_v2.5.1_20210301/rockdev/oem.img from /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/oem/oem_normal (auto sized)
Making /home/zgh/rk3399_linux_release_v2.5.1_20210301/rockdev/oem.img from /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/oem/oem_normal with size(17M)
0+0 records in
0+0 records out
0 bytes copied, 2.2429e-05 s, 0.0 kB/s
mke2fs 1.44.1 (24-Mar-2018)
Discarding device blocks: done
Creating filesystem with 17408 1k blocks and 4368 inodes
Filesystem UUID: 162e3adb-726f-4163-b474-296bcd70e013
Superblock backups stored on blocks:
8193
Allocating group tables: done
Writing inode tables: done
Copying files into the device: done
Writing superblocks and filesystem accounting information: done
tune2fs 1.44.1 (24-Mar-2018)
Setting maximal mount count to -1
Setting interval between checks to 0 seconds
No available configs for: /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/userdata/userdata_normal
Making /home/zgh/rk3399_linux_release_v2.5.1_20210301/rockdev/userdata.img from /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/userdata/userdata_normal (auto sized)
Making /home/zgh/rk3399_linux_release_v2.5.1_20210301/rockdev/userdata.img from /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/userdata/userdata_normal with size(5M)
0+0 records in
0+0 records out
0 bytes copied, 2.2193e-05 s, 0.0 kB/s
Creating filesystem with 5120 1k blocks and 1280 inodes
create uboot.img…done.
create idbloader.img…done.
create trust.img…done.
create loader…done.
create boot.img…done.
Image: image in rockdev is ready
Make image ok!
File name is BOARDCONFIGUBUNTU-GPT
Rename the file? [N|y]Make update.img
start to make update.img…
Resize rootfs partition size
dumpe2fs 1.44.1 (24-Mar-2018)
dumpe2fs: No such file or directory while trying to open /home/zgh/rk3399_linux_release_v2.5.1_20210301/ubunturootfs/Firefly_Ubuntu_18.04.5_LTS_DESKTOP_ext4_202012301242_PYTHON3.5-RKNN-OPENCV.img
./mkupdate.sh: line 37: >>9: syntax error: operand expected (error token is “>>9”)
Android Firmware Package Tool v1.66
------ PACKAGE ------
Add file: ./package-file
Add file: ./package-file done,offset=0x800,size=0x28a,userspace=0x1
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/MiniLoaderAll.bin done,offset=0x1000,size=0x7194e,userspace=0xe4
Add file: ./Image/parameter.txt
Add file: ./Image/parameter.txt done,offset=0x73000,size=0x20d,userspace=0x1
Add file: ./Image/trust.img
Add file: ./Image/trust.img done,offset=0x73800,size=0x400000,userspace=0x800
Add file: ./Image/uboot.img
Add file: ./Image/uboot.img done,offset=0x473800,size=0x400000,userspace=0x800
Add file: ./Image/misc.img
Add file: ./Image/misc.img done,offset=0x873800,size=0xc000,userspace=0x18
Add file: ./Image/boot.img
Add file: ./Image/boot.img done,offset=0x87f800,size=0x1ea4000,userspace=0x3d48
Add file: ./Image/recovery.img
Add file: ./Image/recovery.img done,offset=0x2723800,size=0x1e80800,userspace=0x3d01
Add file: ./Image/rootfs.img
Error: open file failed,err=2!
------ FAILED ------
Press any key to quit:
ERROR: Running build_updateimg failed!
ERROR: exit code 1 from line 1207:
./mkupdate.sh
另外BoardConfig的配置内容如下:
1 #!/bin/bash
2
3 # Target arch
4 export RK_ARCH=arm64
5 # Uboot defconfig
6 export RK_UBOOT_DEFCONFIG=firefly-rk3399
7 # Kernel defconfig
8 export RK_KERNEL_DEFCONFIG=firefly_linux_defconfig
9 # Kernel dts
10 export RK_KERNEL_DTS=rk3399-firefly-aiojd4-lvds
11 # boot image type
12 export RK_BOOT_IMG=boot.img
13 # kernel image path
14 export RK_KERNEL_IMG=kernel/arch/arm64/boot/Image
15 # parameter for GPT table
16 export RK_PARAMETER=parameter-4.19.txt
17 # Recovery config
18 export RK_CFG_RECOVERY=rockchip_rk3399_recovery
19 # ramboot config
20 export RK_CFG_RAMBOOT=
21 # Pcba config
22 export RK_CFG_PCBA=rockchip_rk3399_pcba
23 # Build jobs
24 export RK_JOBS=12
25 # target chip
26 export RK_TARGET_PRODUCT=rk3399
27 # Set rootfs type, including ext2 ext4 squashfs
28 export RK_ROOTFS_TYPE=ext4
29 # yocto machine
30 export RK_YOCTO_MACHINE=rockchip-rk3399-sapphire-excavator
31 # rootfs image path
32 export RK_ROOTFS_IMG=ubunturootfs/ubuntu_18.04_arm64_NOGPUVPU_ext4_v2.03-28- g6eebc47_20201204-0948_MINIMAL.img
33 # Set ramboot image type
34 export RK_RAMBOOT_TYPE=
35 # Set oem partition type, including ext2 squashfs
36 export RK_OEM_FS_TYPE=ext2
37 # Set userdata partition type, including ext2, fat
38 export RK_USERDATA_FS_TYPE=ext2
39 #OEM config
40 export RK_OEM_DIR=oem_normal
41 #userdata config
42 export RK_USERDATA_DIR=userdata_normal
43 #misc image
44 export RK_MISC=wipe_all-misc.img
45 #choose enable distro module
46 export RK_DISTRO_MODULE=
47 # Define pre-build script for this board
48 export RK_BOARD_PRE_BUILD_SCRIPT=app-build.sh
