firefly Ubuntu 怎么换启动的logo
技术支持的大神,想问下fire Ubuntu 18.04 怎么换启动的logo(不是Ubuntu起来之后的桌面),我现在直接换SDK kernel下的logo 与 kernel logo 文件,但是编译后的固件,烧进去会报错,求大神指点一下呢
只改了logo文件,与kernel logo文件,换成原厂的编译就可以的。
换了logo的日志如下: logo.bmp 都改成与原来firefly 一样的 500*501 32位宽
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-181-gc9a647cae:cl
NOTICE: BL31: Built : 10:55:41, Oct 18 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #hisping.lin (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug 4 07:11:39 UTC 2021 aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09-g5961c0c398 #forlinx (Dec 13 2021 - 15:46:27 +0800)
Model: Firefly RK3568 Board
PreSerial: 2, raw, 0xfe660000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: ed356000
Relocation fdt: eb9f8310 - eb9fece0
CR: M/C/I
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: recovery (misc)
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 100000Hz
PMIC: RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
Model: AIO-3568J HDMI (Linux)
“Synchronous Abort” handler, esr 0x96000145
  • Reason: Exception from a Data abort, from current exception level
  • PC = 0000000000a01ac8
  • LR = 0000000000a4e9f0
  • SP = 00000000eb9f7f80
  • ESR_EL2 = 0000000096000145
  • Reloc Off = 00000000ed356000
x0 : 0000000100000000 x1 : 000000010de48880
x2 : 0000000000000040 x3 : 000000000000003f
x4 : 00000000ebed5f00 x5 : 0000000000000005
x6 : 0000000000000018 x7 : 0000000000000010
x8 : 0000000000000000 x9 : 0000000000000008
x10: 00000000ebec5460 x11: 00000000ebd5c0f0
x12: 0000000000000000 x13: 0000000000000200
x14: 0000000000000064 x15: 00000000ffffffff
x16: 000000000000000c x17: 0000000000000001
x18: 00000000eb9ffcf8 x19: 0000000000000000
x20: 000000001ff48874 x21: 00000000ebec5ab0
x22: 00000000ebed5f10 x23: 00000000000020cf
x24: 00000000000b77c2 x25: 00000000ebed5eb0
x26: 0000000000000000 x27: 00000000edf00000
x28: 00000000edf00000 x29: 00000000eb9f8160
Call trace:
PC: [< 00a01ac8 >]
LR: [< 00a4e9f0 >]
Stack:
[< 00a01ac8 >]
[< 00a4ebf8 >]
[< 00a03b98 >]
[< 00a99a18 >]
[< 00a19720 >]
[< 00a01e00 >]
Copy info from “Call trace…” to a file(eg. dump.txt), and run
command in your U-Boot project: ./scripts/stacktrace.sh dump.txt
Resetting CPU …
是不是把 logo 图片格式不对,或者大小太大了,把logo 修改成 firefly log 相同的格式和大小试试,我记得是 bmp 500x500
板蓝根 发表于 2021-12-13 16:54
是不是把 logo 图片格式不对,或者大小太大了,把logo 修改成 firefly log 相同的格式和大小试试,我记得是 …
确认是500*501的bmp
图片格式要求:
8bit 或者 24bit BMP 格式;
logo.bmp 和 logo_kernel.bmp 的图片分辨率大小一致;
有重新编译 recovery 吗?编译后试下
./build.sh kernel
./build.sh recovery
好的,我测试一下
确认图片格式24bmp格式, 500*501 ,我直接编译./build.sh
目前你可以把图片改成8位位深(256色)来试一下
INFO: Preloader serial: …
跟你一样的问题,怎么解决此问题?
