rtsp推流问题
你好
使用core-1126-JD4+配套底板开发时,遇到流媒体推流问题,麻烦看下,谢谢
现象:
在使用core-1126-JD4推流时,用VLC能够打开流媒体,但是流媒体卡在第一张画面上,后面视频看不到
硬件接线:
1、使用一路网口接海康网络摄影头
2、使用另一路网口推流
软件流程:
1、获取rtsp流(使用ffrtsp库)->decode->encode->rtsp推流
测试log:
[root@RV1126_RV1109:/userdata/data/wdg]# ./rtsp_vdec_rga_venc
./rtsp_vdec_rga_venc: /lib/libstdc++.so.6: no version information available (required by /usr/lib/libffrtsp.so)
./rtsp_vdec_rga_venc: /lib/libstdc++.so.6: no version information available (required by /usr/lib/libarcsoft_face_engine.so)
./rtsp_vdec_rga_venc: /lib/libstdc++.so.6: no version information available (required by /usr/lib/libarcsoft_face.so)
media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rockchip-mipi-dphy-rx is null
Rga built version:1.04 cb973b1+2021-06-01 11:34:20
[INFO  rtsp_demo.c:281:rtsp_new_demo] rtsp server demo starting on port 8554
[DEBUG rtsp_demo.c:481:rtsp_new_session] add session path: /live/main_stream
##RKMEDIA Log level: 2
[RKMEDIA][SYS][Info]:text is all=2
[RKMEDIA][SYS][Info]:module is all, log_level is 2
[RKMEDIA][SYS][Info]:RK_MPI_VDEC_CreateChn: Enable VDEC[0] Start...
mpp[2248]: mpp_info: mpp version: 92a7c2a4 author: daijh         2021-04-21 debian: fix patch not found bug
[RKMEDIA][VDEC][Info]:mpi control MPP_DEC_SET_PARSER_SPLIT_MODE ret = 0
mpp[2248]: mpp_rt: NOT found ion allocator
mpp[2248]: mpp_rt: found drm allocator
[RKMEDIA][VDEC][Info]:mpi set group limit = 16
[RKMEDIA][SYS][Info]:RK_MPI_VDEC_CreateChn: Enable VDEC[0] End!
[RKMEDIA][SYS][Info]:RK_MPI_VENC_CreateChn: Enable VENC[0], Type:6 Start...
[RKMEDIA][VENC][Info]:MPP Encoder: MPPConfig: cfg init sucess!
[RKMEDIA][VENC][Info]:MPP Encoder: qpMaxi use default value:48
[RKMEDIA][VENC][Info]:MPP Encoder: qpMini use default value:8
[RKMEDIA][VENC][Info]:MPP Encoder: qpMax use default value:48
[RKMEDIA][VENC][Info]:MPP Encoder: qpMin use default value:8
[RKMEDIA][VENC][Info]:MPP Encoder: qpInit use default value:-1
[RKMEDIA][VENC][Info]:MPP Encoder: qpStep use default value:2
[RKMEDIA][VENC][Info]:MPP Encoder: rotaion = 0
[RKMEDIA][VENC][Info]:MPP Encoder: automatically calculate bsp with bps_max
[RKMEDIA][VENC][Info]:MPP Encoder: Set output block mode.
[RKMEDIA][VENC][Info]:MPP Encoder: Set input block mode.
[RKMEDIA][VENC][Info]:MPP Encoder: bps:[4147200,3732480,1036800] fps: [25/1]->[25/1], gop:25 qpInit:-1, qpMin:8, qpMax:48, qpMinI:8, qpMaxI:48.
[RKMEDIA][VENC][Info]:MPP Encoder: H264 profile use defalut value: 100[RKMEDIA][VENC][Info]:MPP Encoder: AVC: encode profile 100 level 0
mpp[2248]: mpp_enc: MPP_ENC_SET_RC_CFG bps 3732480 [1036800 : 4147200] fps [25:25] gop 25
mpp[2248]: h264e_api_v2: MPP_ENC_SET_PREP_CFG w:h [1920:1080] stride [1920:1088]
mpp[2248]: mpp_enc: send header for set cfg change input/format
[RKMEDIA][VENC][Info]:MPP Encoder: w x h(1920[1920] x 1080[1088])
mpp[2248]: mpp_enc: mode cbr bps [1036800:3732480:4147200] fps fix [25/1] -> fix [25/1] gop i [25] v [0]
[RKMEDIA][SYS][Info]:RK_MPI_VENC_CreateChn: Enable VENC[0], Type:6 End...
[RKMEDIA][SYS][Info]:RK_MPI_RGA_CreateChn: Enable RGA[0], Rect<0,0,1920,1080> Start...
[RKMEDIA][SYS][Info]:FilterFlow:rkrga: Enable BufferPool! memtype:hw_mem, memcnt:12
[RKMEDIA][SYS][Info]:Opened DRM device /dev/dri/card0: driver rockchip version 2.0.0.
[RKMEDIA][SYS][Info]:RK_MPI_RGA_CreateChn: Enable RGA[0], Rect<0,0,1920,1080> End...
[RKMEDIA][SYS][Info]:RK_MPI_SYS_Bind: Bind Mode[VDEC]:Chn[0] to Mode[RGA]:Chn[0]...
[RKMEDIA][SYS][Info]:RK_MPI_SYS_Bind: Bind Mode[VDEC]:Chn[0] to Mode[VENC]:Chn[0]...
Created new TCP socket 41 for connection
Connecting to 192.168.1.5, port 554 on socket 41...
...remote connection opened
Sending request: DESCRIBE rtsp://admin:zd123456@192.168.1.5 RTSP/1.0
CSeq: 2
User-Agent: ffrtspGet (LIVE555 Streaming Media v2017.10.28)
Accept: application/sdp
Received 184 new bytes of response data.
Received a complete DESCRIBE response:
RTSP/1.0 401 Unauthorized
CSeq: 2
WWW-Authenticate: Digest realm="IP Camera(F3061)", nonce="cdad57661c65aa2e1ea2d78f3351752a", stale="FALSE"
Date:  Mon, Dec 06 2021 22:04:14 GMT
Resending...
CSeq: 3
Authorization: Digest username="admin", realm="IP Camera(F3061)", nonce="cdad57661c65aa2e1ea2d78f3351752a", uri="rtsp://admin:zd123456@192.168.1.5", response="6d2d88caa84c04e93e30b7cbf7ee7c25"
Received 702 new bytes of response data.
RTSP/1.0 200 OK
CSeq: 3
Content-Type: application/sdp
Content-Base: rtsp://admin:zd123456@192.168.1.5/
Content-Length: 572
v=0
o=- 1638828254932574 1638828254932574 IN IP4 192.168.1.5
s=Media Presentation
e=NONE
b=AS:5050
t=0 0
a=control:rtsp://admin:zd123456@192.168.1.5/
m=video 0 RTP/AVP 96
c=IN IP4 0.0.0.0
b=AS:5000
a=recvonly
a=x-dimensions:1920,1080
a=control:rtsp://admin:zd123456@192.168.1.5/trackID=1
a=rtpmap:96 H264/90000
a=fmtp:96 profile-level-id=420029; packetization-mode=1; sprop-parameter-sets=Z00AKpY1QPAET8s3AQEBQAABwgAAV+QB,aO4xsg==
a=Media_header:MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;
a=appversion:1.0
[URL:"rtsp://admin:zd123456@192.168.1.5/"]: Got a SDP description:
v=0
e=NONE
b=AS:5050
t=0 0
c=IN IP4 0.0.0.0
b=AS:5000
a=recvonly
a=appversion:1.0
[URL:"rtsp://admin:zd123456@192.168.1.5/"]: Initiated the "video/H264" subsession (client ports 36746-36747)
Sending request: SETUP rtsp://admin:zd123456@192.168.1.5/trackID=1 RTSP/1.0
CSeq: 4
Authorization: Digest username="admin", realm="IP Camera(F3061)", nonce="cdad57661c65aa2e1ea2d78f3351752a", uri="rtsp://admin:zd123456@192.168.1.5/", response="10c4a1dfcdf2b5c1651238c954e703d1"
Transport: RTP/AVP;unicast;client_port=36746-36747
Received 204 new bytes of response data.
Received a complete SETUP response:
RTSP/1.0 200 OK
CSeq: 4
Session:       1383322580;timeout=60
Transport: RTP/AVP;unicast;client_port=36746-36747;server_port=8218-8219;ssrc=32cb7432;mode="play"
[URL:"rtsp://admin:zd123456@192.168.1.5/"]: Set up the "video/H264" subsession (client ports 36746-36747)
[URL:"rtsp://admin:zd123456@192.168.1.5/"]: Created a data sink for the "video/H264" subsession
Sending request: PLAY rtsp://admin:zd123456@192.168.1.5/ RTSP/1.0
CSeq: 5
Authorization: Digest username="admin", realm="IP Camera(F3061)", nonce="cdad57661c65aa2e1ea2d78f3351752a", uri="rtsp://admin:zd123456@192.168.1.5/", response="35c213136d0091d0a2f465b9d6650e24"
Session: 1383322580
Range: npt=0.000-
Received 179 new bytes of response data.
Received a complete PLAY response:
RTSP/1.0 200 OK
CSeq: 5
Session:       1383322580
RTP-Info: url=rtsp://admin:zd123456@192.168.1.5/trackID=1;seq=1629;rtptime=190893420
Date:  Mon, Dec 06 2021 22:04:15 GMT
[URL:"rtsp://admin:zd123456@192.168.1.5/"]: Started playing session...
[RKMEDIA][VDEC][Info]:MppDec Info change get, 1920x1080 in (1920x1088)
[RKMEDIA][RGA][Error]:Src(0Bytes) or Dst(6220800Bytes) Buffer is invalid!
mpp[2248]: mpp_buffer: mpp_buffer_put invalid input: buffer NULL from PrepareMppFrame
mpp[2248]: h264e_sps: set level to 4
[DEBUG utils.c:160:rtsp_codec_data_parse_from_user_h264] sps 27
[DEBUG utils.c:168:rtsp_codec_data_parse_from_user_h264] pps 4
测试代码:
#include <assert.h>
#include <fcntl.h>
#include <pthread.h>
#include <signal.h>
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <time.h>
#include <unistd.h>
#include <sys/time.h>
#include "common/sample_common.h"
#include "rkmedia_api.h"
#include "rkmedia_vdec.h"
#include "ffrtsp/ffrtsp.hh"
#include "librtsp/rtsp_demo.h"
#define  full_flow1
#define  close_mux1
//视频流处理pipeline
//rtsp->vdec->rga->im2gray->算法处理(测试RGA直接转IMAGE_TYPE_GRAY8)->处理结果添加水印->venc->rtsp推流
//			->venc->保存历史视频(mux测试)
//			->venc->添加水印—>rtsp流(后期流程)
typedef struct rkMuxerHandle {
	RK_U32 u32ModeIdx;
 	RK_U32 u32ChnIdx;
} MuxerHandle;
rtsp_demo_handle g_rtsplive = NULL;
static rtsp_session_handle g_rtsp_session;
static bool quit = false;
static void sigterm_handler(int sig) {
	fprintf(stderr, "signal %d\n", sig);
	quit = true;
static long getCurrentTimeMsec() {
	long msec = 0;
	char str[20] = {0};
	struct timeval stuCurrentTime;
	gettimeofday(&stuCurrentTime, NULL);
	sprintf(str, "%ld%03ld", stuCurrentTime.tv_sec,(stuCurrentTime.tv_usec) / 1000);
	for (size_t i = 0; i < strlen(str); i++) {
		msec = msec * 10 + (str[i] - '0');
	return msec;
static RK_U32 gu32FileIdx;
int GetRecordFileName(RK_VOID *pHandle, RK_U32 u32FileCnt,RK_CHAR **pcFileName) {
	printf("#%s: Handle:%p, idx:%u ...\n", __func__, pHandle, *((RK_U32 *)pHandle));
	for (RK_U32 i = 0; i < u32FileCnt; i++) {
		sprintf(pcFileName[i], "/userdata/MuxerCbTest_%u.mp4",*((RK_U32 *)pHandle));
 	 printf("#%s: NewRecordFileName:[%s]\n", __func__, pcFileName[0]);
  	*((RK_U32 *)pHandle) = *((RK_U32 *)pHandle) + 1;
  	return 0;
void muxer_event_cb(RK_VOID *pHandle, RK_VOID *pstEvent) {
	RK_S32 s32ModeIdx = -1;
	RK_S32 s32ChnIdx = -1;
	printf("### %s: Handle:%p, event:%p\n", __func__, pHandle, pstEvent);
	if (pHandle) {
		MuxerHandle *pstMuxerHandle = (MuxerHandle *)pHandle;
		s32ModeIdx = (RK_S32)pstMuxerHandle->u32ModeIdx;
		s32ChnIdx = (RK_S32)pstMuxerHandle->u32ChnIdx;
	if (pstEvent) {
		MUXER_EVENT_INFO_S *pstMuxerEvent = (MUXER_EVENT_INFO_S *)pstEvent;
		printf("@@@ %s: ModeID:%d, ChnID:%d, EventType:%d, filename:%s, value:%d\n",
		__func__, s32ModeIdx, s32ChnIdx, pstMuxerEvent->enEvent,
		pstMuxerEvent->unEventInfo.stFileInfo.asFileName,
		(int)pstMuxerEvent->unEventInfo.stFileInfo.u32Duration);
int FFRKMedia_Vdec_Send(u_int8_t* framebuff,unsigned framesize,bool * pquit,int cur_chn)
	//RTSP流数据送到decode通道
    MEDIA_BUFFER mb = RK_MPI_MB_CreateBuffer(framesize, RK_FALSE, 0);
    RK_MPI_MB_SetSize(mb, framesize);
    memcpy(RK_MPI_MB_GetPtr(mb) ,framebuff , framesize);
    RK_MPI_SYS_SendMediaBuffer(RK_ID_VDEC, 0, mb);
    RK_MPI_MB_ReleaseBuffer(mb);
    if (quit)
    	*pquit = true;
void vdec_packet_cb(MEDIA_BUFFER mb) {
	 // decode 流媒体数据为NV12
	int ret;
	static RK_U32 jpeg_id = 0;
	MB_IMAGE_INFO_S stImageInfo = {0};
	ret = RK_MPI_MB_GetImageInfo(mb, &stImageInfo);//指定图像中获取图像信息 ,宽高,图片格式
	if (ret) {
		printf("Get image info failed! ret = %d\n", ret);
		return ;
	printf("Get Frame:ptr:%p, fd:%d, size:%zu, mode:%d, channel:%d, "
	     "timestamp:%lld, ImgInfo:<wxh %dx%d, fmt 0x%x>\n",
	     RK_MPI_MB_GetPtr(mb), RK_MPI_MB_GetFD(mb), RK_MPI_MB_GetSize(mb),
	     RK_MPI_MB_GetModeID(mb), RK_MPI_MB_GetChannelID(mb),
	     RK_MPI_MB_GetTimestamp(mb), stImageInfo.u32Width,
	     stImageInfo.u32Height, stImageInfo.enImgType);
/*	char jpeg_path[128];
	sprintf(jpeg_path, "/userdata/data/test_yuv%d.yuv", jpeg_id);
	FILE *file = fopen(jpeg_path, "w");
	if (file) {
		fwrite(RK_MPI_MB_GetPtr(mb), 1, RK_MPI_MB_GetSize(mb), file);
		fclose(file);
	jpeg_id++;
static void *MainStream(void * data)  {
	MEDIA_BUFFER buffer;
	while (!quit) {
		//printf("%s\n",__func__);
		buffer = RK_MPI_SYS_GetMediaBuffer(RK_ID_RGA, 0, -1);
		if (!buffer)
			continue;
/*		sprintf(jpeg_path, "/userdata/data/test%d.jpg", jpeg_id);
		if (file) {
			fwrite(RK_MPI_MB_GetPtr(buffer), 1, RK_MPI_MB_GetSize(buffer), file);
			fclose(file);
		RK_MPI_MB_ReleaseBuffer(buffer);
		jpeg_id++;
static FILE *g_output_file=NULL;
#define video_output_path "/userdata/data/"
#define video_output_length			25*60*3		//fps=25,3分钟一个视频
static void venc_packet_cb(MEDIA_BUFFER mb) {
	static RK_S32 packet_cnt = 0;
	if (quit)
		return;
	printf("#Get packet-%d, size %zu\n", packet_cnt, RK_MPI_MB_GetSize(mb));
	if (g_rtsplive && g_rtsp_session) {
		printf("rtsp push \n");
		rtsp_tx_video(g_rtsp_session, (uint8_t*)RK_MPI_MB_GetPtr(mb), RK_MPI_MB_GetSize(mb),
		RK_MPI_MB_GetTimestamp(mb)); // RTSP 发送,通过获取 MB 编码数据虚拟地址,大小,时间戳,然后发送
		rtsp_do_event(g_rtsplive);
	packet_cnt++;
	char pOutPath[128];
	struct tm t;
	struct timespec time = { 0, 0 };
#if 1
	if(packet_cnt==0)
		clock_gettime(CLOCK_REALTIME, &time);
        	strftime(pOutPath, sizeof(pOutPath), "/userdata/data/%Y-%m-%d-%H-%M-%S.h264", localtime_r(&time.tv_sec, &t));
		printf("video file name=%s\n",pOutPath);
		if (!g_output_file) {
			g_output_file = fopen(pOutPath, "w");
				printf("ERROR: open file: %s fail, exit\n", pOutPath);
				return ;
#endif
#if 1
	if (quit)
		return;
	const char *nalu_type = "Jpeg data";
	switch (RK_MPI_MB_GetFlag(mb)) {
		case VENC_NALU_IDRSLICE:
			nalu_type = "IDR Slice";
			break;
		case VENC_NALU_PSLICE:
			nalu_type = "P Slice";
			break;
		default:
			break;
	if (g_output_file) {
		fwrite(RK_MPI_MB_GetPtr(mb), 1, RK_MPI_MB_GetSize(mb), g_output_file);
		printf("#Write packet-%d, %s, size %zu\n", packet_cnt, nalu_type,
	} else {
		printf("#Get packet-%d, %s, size %zu\n", packet_cnt, nalu_type,
	RK_MPI_MB_TsNodeDump(mb);
#endif
	packet_cnt++;
#if 1
	if(packet_cnt==video_output_length)
		if (g_output_file)
			fclose(g_output_file);
		g_output_file = NULL;
		packet_cnt = 0;
#endif
static void rga_packet_cb(MEDIA_BUFFER mb) {
	if (quit)
		return;
	if (file) {
	fclose(file);
	jpeg_id++;
int main(int argc, char *argv[])
	int ret=0;
	signal(SIGINT, sigterm_handler);
#if 0
        RK_CHAR *pOutPath = (char*)"/userdata/data/save.h264";
	if (pOutPath) {
			return 0;
#endif
	       //设置rtsp推流属性
        g_rtsplive = create_rtsp_demo(554);
	if(g_rtsplive==NULL)
		printf("g_rtsplive is null\n");
        g_rtsp_session = rtsp_new_session(g_rtsplive, "/live/main_stream");
	if(g_rtsp_session == NULL)
                printf("g_rtsp_session is null\n");
        rtsp_set_video(g_rtsp_session, RTSP_CODEC_ID_VIDEO_H264, NULL, 0);
//      rtsp_sync_video_ts(g_rtsp_session, rtsp_get_reltime(), rtsp_get_ntptime()); //rtsp 同步当前网络时间
	RK_MPI_SYS_Init();//初始化 MPI 系统
	//设置decode属性
	VDEC_CHN_ATTR_S stVdecAttr;
	stVdecAttr.enCodecType = RK_CODEC_TYPE_H264;
	stVdecAttr.enMode = VIDEO_MODE_STREAM;
	stVdecAttr.enDecodecMode = VIDEO_DECODEC_HADRWARE;
	ret = RK_MPI_VDEC_CreateChn(0, &stVdecAttr);
	if (ret) {
		printf("Create Vdec[0] failed! ret=%d\n", ret);
		return -1;
	//设置decode有数据时 回调
	MPP_CHN_S VdecChn; //定义模块设备通道结构体。
	VdecChn.enModId = RK_ID_VDEC;
	VdecChn.s32DevId = 0;
	VdecChn.s32ChnId = 0;
	/*ret = RK_MPI_SYS_RegisterOutCb(&VdecChn, vdec_packet_cb); //注册数据输出回调。
	if (ret) {
		printf("ERROR: register output callback for Vdec[0] error! ret=%d\n", ret);
		return 0;
	//设置encode属性
	MPP_CHN_S VencChn;
	VencChn.enModId = RK_ID_VENC;
	VencChn.s32DevId = 0;
	VencChn.s32ChnId = 0;
	VENC_CHN_ATTR_S venc_chn_attr;
	memset(&venc_chn_attr, 0, sizeof(venc_chn_attr));
	venc_chn_attr.stVencAttr.enType = RK_CODEC_TYPE_H264;
	venc_chn_attr.stRcAttr.enRcMode = VENC_RC_MODE_H264VBR;
	venc_chn_attr.stRcAttr.stH264Vbr.u32Gop = 25;
	venc_chn_attr.stRcAttr.stH264Vbr.u32MaxBitRate = 1920 * 1080 * 2;
	// frame rate: in 30/1, out 30  /1.
	venc_chn_attr.stRcAttr.stH264Vbr.fr32DstFrameRateDen = 1;
	venc_chn_attr.stRcAttr.stH264Vbr.fr32DstFrameRateNum = 25;
	venc_chn_attr.stRcAttr.stH264Vbr.u32SrcFrameRateDen = 1;
	venc_chn_attr.stRcAttr.stH264Vbr.u32SrcFrameRateNum = 25;
	venc_chn_attr.stVencAttr.imageType = IMAGE_TYPE_NV12; //输入图片的格式,和 VI 输出保持一致
	venc_chn_attr.stVencAttr.u32PicWidth = 1920; //编码图像宽度,单位像素点
	venc_chn_attr.stVencAttr.u32PicHeight = 1080;//编码图像高度,单位像素点
	venc_chn_attr.stVencAttr.u32VirWidth = 1920;//stride 宽度,必须 16 对齐
	venc_chn_attr.stVencAttr.u32VirHeight = 1080 + 8;// stride 高度,必须 16 对齐
	venc_chn_attr.stVencAttr.u32Profile = 77; //编码等级 77,是中级 66,基础等级,100,高级
	ret = RK_MPI_VENC_CreateChn(0, &venc_chn_attr);//创建通道
	ret = RK_MPI_SYS_RegisterOutCb(&VencChn, venc_packet_cb); //注册数据输出回调。
	if (ret) {
		return 0;
#ifdef full_flow
	MPP_CHN_S VencChn1;
	VencChn1.enModId = RK_ID_VENC;
	VencChn1.s32DevId = 0;
	VencChn1.s32ChnId = 1;
	venc_chn_attr.stVencAttr.imageType = IMAGE_TYPE_RGB888; //输入图片的格式,和 VI 输出保持一致
	ret = RK_MPI_VENC_CreateChn(1, &venc_chn_attr);//创建通道
#endif
	//设置rga属性
	RGA_ATTR_S stRgaAttr;
	stRgaAttr.bEnBufPool = RK_TRUE;
	stRgaAttr.u16BufPoolCnt = 12;
	stRgaAttr.u16Rotaion = 0;
	stRgaAttr.stImgIn.u32X = 0;
	stRgaAttr.stImgIn.u32Y = 0;
	stRgaAttr.stImgIn.imgType = IMAGE_TYPE_NV12;
	stRgaAttr.stImgIn.u32Width = 1920;
	stRgaAttr.stImgIn.u32Height = 1080;
	stRgaAttr.stImgIn.u32HorStride = 1920;
	stRgaAttr.stImgIn.u32VirStride = 1080;
	stRgaAttr.stImgOut.u32X = 0;
	stRgaAttr.stImgOut.u32Y = 0;
	//stRgaAttr.stImgOut.imgType = IMAGE_TYPE_JPEG;
	stRgaAttr.stImgOut.imgType = IMAGE_TYPE_BGR888;
	stRgaAttr.stImgOut.u32Width = 1920;
	stRgaAttr.stImgOut.u32Height = 1080;
	stRgaAttr.stImgOut.u32HorStride = 1920;
	stRgaAttr.stImgOut.u32VirStride = 1080;
	ret = RK_MPI_RGA_CreateChn(0, &stRgaAttr);
	if (ret) {
		printf("Create rga[0] falied! ret=%d\n", ret);
		return -1;
	MPP_CHN_S vRgaChn;
	vRgaChn.enModId = RK_ID_RGA;
	vRgaChn.s32DevId = 0;
	vRgaChn.s32ChnId = 0;
/*	ret = RK_MPI_SYS_RegisterOutCb(&vRgaChn, rga_packet_cb); //注册数据输出回调。
	if (ret) {
		printf("ERROR: register output callback for RGA[0] error! ret=%d\n", ret);
		return NULL;
	pthread_t main_stream_thread;
	pthread_create(&main_stream_thread, NULL, MainStream, NULL);
#ifdef close_mux
	//设置mux属性
	MUXER_CHN_ATTR_S stMuxerAttr;
	memset(&stMuxerAttr, 0, sizeof(stMuxerAttr));
	stMuxerAttr.enMode = MUXER_MODE_AUTOSPLIT;
	stMuxerAttr.enType = MUXER_TYPE_MP4;
	stMuxerAttr.stSplitAttr.enSplitType = MUXER_SPLIT_TYPE_TIME;
	stMuxerAttr.stSplitAttr.u32TimeLenSec = 30;
	/*printf("#MuxerTest: use split name auto type...\n");
	stMuxerAttr.stSplitAttr.enSplitNameType = MUXER_SPLIT_NAME_TYPE_AUTO;
	stMuxerAttr.stSplitAttr.stNameAutoAttr.pcPrefix = (RK_CHAR*)"muxer_test";
	stMuxerAttr.stSplitAttr.stNameAutoAttr.pcBaseDir = (RK_CHAR*)"/userdata/data";
	// Split File name with timestamp.
	// stMuxerAttr.stSplitAttr.stNameAutoAttr.bTimeStampEnable = RK_TRUE;
	stMuxerAttr.stSplitAttr.stNameAutoAttr.u16StartIdx = 1;*/
	 printf("#MuxerTest: use split name callback type, cb:%p, handle:%p...\n",
           GetRecordFileName, &gu32FileIdx);
    	stMuxerAttr.stSplitAttr.enSplitNameType = MUXER_SPLIT_NAME_TYPE_CALLBACK;
    	stMuxerAttr.stSplitAttr.stNameCallBackAttr.pcbRequestFileNames = GetRecordFileName;
    	stMuxerAttr.stSplitAttr.stNameCallBackAttr.pCallBackHandle =(RK_VOID *)&gu32FileIdx;
	stMuxerAttr.stVideoStreamParam.enCodecType = RK_CODEC_TYPE_H264;
	stMuxerAttr.stVideoStreamParam.enImageType = IMAGE_TYPE_NV12;
	stMuxerAttr.stVideoStreamParam.u16Fps = 25;
	stMuxerAttr.stVideoStreamParam.u16Level = 41;    // for h264
	stMuxerAttr.stVideoStreamParam.u16Profile = 77; // for h264
	stMuxerAttr.stVideoStreamParam.u32BitRate = 1920 * 1080;
	stMuxerAttr.stVideoStreamParam.u32Width = 1920;
	stMuxerAttr.stVideoStreamParam.u32Height = 1080;
	ret = RK_MPI_MUXER_EnableChn(0, &stMuxerAttr);
	if (ret) {
		printf("Create MUXER[0] failed! ret=%d\n", ret);
		return -1;
	MPP_CHN_S muxerChn;
	MUXER_CHN_S stMuxerChn;
	muxerChn.enModId = RK_ID_MUXER;
	muxerChn.s32DevId = 0;
	muxerChn.s32ChnId = 0;
	MuxerHandle stMuxerHandle;
	stMuxerHandle.u32ChnIdx = 0;
	stMuxerHandle.u32ModeIdx = RK_ID_MUXER;
	ret = RK_MPI_SYS_RegisterEventCb(&muxerChn, &stMuxerHandle, muxer_event_cb);
	if (ret) {
		printf("Register event callback failed! ret=%d\n", ret);
		return -1;
	printf("### Start muxer stream...\n");
	ret = RK_MPI_MUXER_StreamStart(0);
	if (ret) {
		printf("Muxer start stream failed! ret=%d\n", ret);
		return -1;
	// Bind VENC[0] to MUXER[0]:VIDEO
	stMuxerChn.enModId = RK_ID_MUXER;
	stMuxerChn.enChnType = MUXER_CHN_TYPE_VIDEO;
	stMuxerChn.s32ChnId = 0;
	ret = RK_MPI_MUXER_Bind(&VencChn, &stMuxerChn);
	if (ret) {
		printf("ERROR: Bind VENC[0] and MUXER[0]:VIDEO error! ret=%d\n", ret);
		return 0;
#endif
	// VDec Bind Rga
	ret = RK_MPI_SYS_Bind(&VdecChn, &vRgaChn);
	if (ret) {
		printf("ERROR: Bind Vdec[0] and VRGA[0] failed! ret=%d\n");
		return -1;
	// VDec Bind VENC for save video
	ret = RK_MPI_SYS_Bind(&VdecChn, &VencChn);
	if (ret) {
		printf("ERROR: Bind Vdec[0] and Venc[0] failed! ret=%d\n");
		return -1;
#ifdef full_flow
	ret = RK_MPI_SYS_Bind(&vRgaChn, &VencChn1);
	if (ret) {
		printf("ERROR: Bind VRGA[0] and Venc[1] failed! ret=%d\n");
		return -1;
	//连接到rtsp推流上
#endif
	//设置流媒体参数
	struct FFRTSPGet ffrtsp_get;
	ffrtsp_get.callback = FFRKMedia_Vdec_Send;
	ffrtsp_get.count = 1;
	ffrtsp_get.ffrtsp_get_info[0].url = (char*)"rtsp://admin:zd123456@192.168.1.5";
	ffrtspGet(ffrtsp_get);
	//设置rtsp推流属性
	//g_rtsplive = create_rtsp_demo(554);
	//g_rtsp_session = rtsp_new_session(g_rtsplive, "/live/main_stream");
	//rtsp_set_video(g_rtsp_session, RTSP_CODEC_ID_VIDEO_H264, NULL, 0);
	while(!quit)
		sleep(1);
	if (g_rtsplive)
		rtsp_del_demo(g_rtsplive);
#ifdef close_mux
	printf("### Stop muxer stream...\n");
	ret = RK_MPI_MUXER_StreamStop(0);
	if (ret) {
		printf("Muxer stop stream failed! ret=%d\n", ret);
		return -1;
	// UnBind VENC[0] to MUXER[0]
	ret = RK_MPI_MUXER_UnBind(&VencChn, &stMuxerChn);
	if (ret) {
		printf("ERROR: UnBind VENC[0] and MUXER[0] error! ret=%d\n", ret);
		return 0;
#endif
	//释放资源
#ifdef full_flow
	RK_MPI_SYS_UnBind(&vRgaChn, &VencChn1);
#endif
	RK_MPI_SYS_UnBind(&VdecChn, &vRgaChn);
	RK_MPI_SYS_UnBind(&VdecChn, &VencChn);
#ifdef full_flow
	RK_MPI_VENC_DestroyChn(1);
#endif
	RK_MPI_VENC_DestroyChn(0);
	RK_MPI_RGA_DestroyChn(0);
	RK_MPI_VDEC_DestroyChn(0);
	return 0;
补充张图片,图片上时间戳,静止不动
你是用 librtsp.a 吧?这个是 rockchip 提供的库,好像是有问题,只要输入源不是 VI 就会出现这种情况,但是因为 rockchip 只提供了静态库文件具体什么问题我们也不得而知。你可以自己实现 rtsp 推流,或者用我们的 libffrtsp.so 试一下
板蓝根 发表于 2021-12-8 09:28
你是用 librtsp.a 吧?这个是 rockchip 提供的库,好像是有问题,只要输入源不是 VI 就会出现这种情况,但 …
使用ffrtsp用VLC打开也卡住了,硬件IP地址配置如下
1、eth0接IP camera设置IP地址192.168.1.25,camera ip为192.168.1.5
2、eth1接PC,设置IP地址10.0.0.6,pc IP为10.0.0.4
3、用VLC打卡地址rtsp://10.0.0.6:8554/H264_stream_0 卡住没有图像。
4、测试代码如下:
#include <assert.h>
#include <fcntl.h>
#include <signal.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <time.h>
#include <unistd.h>
struct RTSP_PUSH_INFO ffrtsp_push[MAXFFRTSPChn];
	quit = true;
	long msec = 0;
	char str[20] = {0};
	return msec;
	//RTSP流数据送到decode通道
	if(ffrtsp_push[0].fp == NULL) {
		continue;
	//printf("%s 1\n",__func__);
	if (RK_MPI_MB_GetPtr(mb) != NULL) {
		fwrite(RK_MPI_MB_GetPtr(mb), RK_MPI_MB_GetSize(mb), 1, ffrtsp_push[0].fp);
    if (quit)
    	*pquit = true;
static void *rtsppushbuff(void *data) {
	((struct RTSP_PUSH_INFO *)data)->type = RTSP_CODEC_H264;
	ffrtsph264Push((struct RTSP_PUSH_INFO *)data);
	int ret=0;
	pthread_t rtsppush_thread;
	ffrtsp_push[0].idex = 0;
	ffrtsp_push[0].port = 8554;
	ffrtsp_push[0].type = RK_CODEC_TYPE_H264;
	// RTSP 推流线程
	pthread_create(&rtsppush_thread, NULL, rtsppushbuff, (void *)&ffrtsp_push[0]);
	//设置流媒体参数
	while(!quit)
		sleep(1);
	return 0;
5、log如下:
 ./rtsp_test1
./rtsp_test1: /lib/libstdc++.so.6: no version information available (required by /usr/lib/libffrtsp.so)
./rtsp_test1: /lib/libstdc++.so.6: no version information available (required by /usr/lib/libarcsoft_face_engine.so)
./rtsp_test1: /lib/libstdc++.so.6: no version information available (required by /usr/lib/libarcsoft_face.so)
rtsppushbuff
Created new TCP socket 8 for connection
Connecting to 192.168.1.5, port 554 on socket 8...
Play this stream using the URL "rtsp://10.0.0.6:8554/H264_stream_0"
Beginning streaming...
CSeq: 2
CSeq: 2
WWW-Authenticate: Digest realm="IP Camera(F3061)", nonce="32be1bc1d9706735c8a7d0ddeb8fa885", stale="FALSE"
Date:  Mon, Dec 13 2021 22:48:44 GMT
Resending...
CSeq: 3
Authorization: Digest username="admin", realm="IP Camera(F3061)", nonce="32be1bc1d9706735c8a7d0ddeb8fa885", uri="rtsp://admin:zd123456@192.168.1.5", response="7ca4546c386098f11bc4bc79352c5576"
RTSP/1.0 200 OK
CSeq: 3
Content-Length: 572
v=0
o=- 1639435724717783 1639435724717783 IN IP4 192.168.1.5
e=NONE
b=AS:5050
t=0 0
c=IN IP4 0.0.0.0
b=AS:5000
a=recvonly
a=appversion:1.0
v=0
e=NONE
b=AS:5050
t=0 0
c=IN IP4 0.0.0.0
b=AS:5000
a=recvonly
a=appversion:1.0
[URL:"rtsp://admin:zd123456@192.168.1.5/"]: Initiated the "video/H264" subsession (client ports 59324-59325)
CSeq: 4
Authorization: Digest username="admin", realm="IP Camera(F3061)", nonce="32be1bc1d9706735c8a7d0ddeb8fa885", uri="rtsp://admin:zd123456@192.168.1.5/", response="9347da75e78d0d7f8950b6dab8316ab7"
Transport: RTP/AVP;unicast;client_port=59324-59325
RTSP/1.0 200 OK
CSeq: 4
Session:        448226533;timeout=60
Transport: RTP/AVP;unicast;client_port=59324-59325;server_port=8222-8223;ssrc=777d88c7;mode="play"
[URL:"rtsp://admin:zd123456@192.168.1.5/"]: Set up the "video/H264" subsession (client ports 59324-59325)
CSeq: 5
Authorization: Digest username="admin", realm="IP Camera(F3061)", nonce="32be1bc1d9706735c8a7d0ddeb8fa885", uri="rtsp://admin:zd123456@192.168.1.5/", response="e2935df5aea2223cfe6517b08beb150c"
Session: 448226533
Range: npt=0.000-
Received 180 new bytes of response data.
RTSP/1.0 200 OK
CSeq: 5
Session:        448226533
RTP-Info: url=rtsp://admin:zd123456@192.168.1.5/trackID=1;seq=47568;rtptime=417018600
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
FFRKMedia_Vdec_Send
没看到有解码器初始化和流发送啊,代码是不是贴漏了?先从下面方式排查一下。
  1. 去掉解码步骤,ffrtsp_get 回调获取到的 buff 直接额送到 ffrtsp_push,确认一下是不是 rtsp 配置问题。ffrtsp_demo_test.cpp
  2. ffrtsp 后直接保留 h264 文件/ Vdec 解码后保留 NV12 / VENC 编码后保留 H264 来确认哪个步骤出了问题
  1. 去掉解码步骤,ffrtsp_ge …
没用解码器,IP camera获得的流就是H264编码,NV12的,直接推流到另一个网口的
ffrtsp_get 之后 fwrite 本地文件保存的文件可以播放吗? 直接跑 ffrtsp_demo_test 可以出流吗? 其次可以用 gdb 等调试手段调式一下呀
板蓝根 发表于 2021-12-15 09:31
ffrtsp_get 之后 fwrite 本地文件保存的文件可以播放吗? 直接跑 ffrtsp_demo_test 可以出流吗? 其次可以 …
使用ffrtsp_demo_test测试也是出不了流,请教下2个问题
1、我打开了SAVE_FILE配置保存为test_rtsp_0,用什么工具打开,我直接拖到VLC上打不开
2、我刚开始的测试代码,偶尔也打开过,想问下是不是需要 网口需要设置路由之类,请问下你们网卡怎么配置的,我在开机启动上以下命令:ifconfig eth0 10.0.0.6 netmask 255.255.255.0;ifconfig eth1 192.168.1.25 netmask 255.255.255.0
  1. ffplay 和 vlc 都可以播放,ffplay 要把文件后缀改成 .264 才可以。
  2. 双网卡的话有可能是网关的问题,建议你先把一张网卡down 掉,PC 先 ping 通在测试。
1、我打开了SAVE_FILE配置保存为test_rtsp_0,用 …
这个可以拉音频么~
拉不了
看看能不能下载…
您好,请问您解决了么,我也遇到同样的问题了,卡住不动。rtsp推流的时候给media buffer加入时间戳,能正常显示一会儿,但每隔40多秒会收到debug信息,会接着卡住不动,几十秒后恢复正常,十几秒后接着卡死。
debug信息如下
[DEBUG rtsp_msg.c:865:rtsp_msg_parse_from_array]
OPTIONS rtsp://192.168.2.5:8554/live/main_stream RTSP/1.0
CSeq: 7
User-Agent: LibVLC/3.0.17.4 (LIVE555 Streaming Media v2016.11.28)
Session: 12345678
[DEBUG rtsp_demo.c:712:rtsp_handle_OPTIONS]
[DEBUG rtsp_msg.c:998:rtsp_msg_build_to_array]
RTSP/1.0 200 OK
CSeq: 7
Date: Fri Aug 4 17:33:05 2017
Session: 12345678
Public: OPTIONS, DESCRIBE, SETUP, PLAY, PAUSE, TEARDOWN
Server: rtsp_demo
我在跑ffrtsp_demo_test时,也遇到了同样的问题,卡在Started playing session… ,请问这个问题该如何解决?
chaney 发表于 2024-5-31 14:05
我在跑ffrtsp_demo_test时,也遇到了同样的问题,卡在Started playing session… ,请问这个问题该如何解 …
您解决了吗 我也遇到了同样的问题
1142688779 发表于 2024-7-27 23:36
您解决了吗 我也遇到了同样的问题
卡在Started playing session… 是假象,你用Wireshark工具测的话,实际在推的
那为什么用vlc拉不到呢?
我用vlc拉流也有这个问题,但是用ffplay正常
