RV1126 JD4 官方下载的SDK 无法进终端
新问题:选择 以下这几个都是一样的错误,系统无法进终端,请问需要怎么更改?
  1. firefly_rv1126_rv1109
  2. firefly_rv1126_rv1109_recovery
  3. firefly_rv1126_rv1109_rkmedia_uvcc
还有一个问题是:怎么修改开机APP自启动?通过buildroot?
1, 代码是否有更新?
2. 怎么编译的代码?
3. 参考 /etc/init.d/ 下文件自己写一个,这里的脚本开机会自动执行
1、代码已经更新过
2、运行./build.sh
3.这里在哪里更改?才可以编译打包到系统里面
log如下:
DDR Version V1.05 20201214
LPDDR4, 328MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09(rv1126_rv1109_linux_20211022.xml)-g4127909591 #qzw (Dec 07 2021 - 14:26:46)
unknown raw ID phN
Trying to boot from MMC2
mmc_init: -95, time 9
Trying to boot from MMC1
Magic is incorrect.
Error validating A/B metadata from disk. Resetting and writing new A/B metadata to disk.
## Verified-boot: 0
## Checking optee 0x08400000 … sha256+ OK
## Checking uboot 0x00400000 … sha256+ OK
## Checking fdt 0x004b2534 … sha256+ OK
Jumping to U-Boot(0x00400000) via OP-TEE(0x08400000)
Total: 130.218 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: cpu_st=0xe0
I/TC: OP-TEE version: 3.6.0-319-g6aaba70b #36 Tue May 25 03:24:10 UTC 2021 arm
I/TC: Next entry point address: 0x00400000
I/TC: Initialized
U-Boot 2017.09(rv1126_rv1109_linux_20211022.xml)-g4127909591 #qzw (Dec 07 2021 - 14:26:46 +0800)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM: 1021.7 MiB
Sysmem: init
Relocation Offset: 00000000, fdt: 3bcfa318
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 400000Hz
PMIC: RK8090 (on=0x40, off=0x00)
vdd_npu_vepu 800000 uV
vdd_arm 800000 uV
io-domain: OK
Can’t get crtc id, default set to id = 0
Model: Firefly Core-RV1126-JD4 Board
Using display timing dts
Detailed mode clock 70000 kHz, flags[a]
H: 0800 0980 0990 1000
V: 1280 1288 1292 1296
bus_format: 1009
final DSI-Link bandwidth: 500 Mbps x 4
apll 816000 KHz
dpll 462000 KHz
gpll 1188000 KHz
cpll 500000 KHz
hpll 1400000 KHz
aclk_pdbus 500000 KHz
hclk_pdbus 198000 KHz
pclk_pdbus 99000 KHz
aclk_pdphp 297000 KHz
hclk_pdphp 198000 KHz
hclk_pdaudio 148500 KHz
hclk_pdcore 198000 KHz
pclk_pdpmu 99000 KHz
Net: eth0: ethernet@ffc40000
## Booting FIT Image at 0x3ab30300 with size 0x00fc7000
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 3ab30300 …
Using ‘conf’ configuration
optee api revision: 2.0
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x3ab49d00
Data Size: 7278008 Bytes = 6.9 MiB
Architecture: ARM
OS: Linux
Load Address: 0x02008000
Entry Point: 0x02008000
Hash algo: sha256
Hash value: a9f78d3a336e6aec09ccfb2470ceacdd9afde4af7cbd3f95966e4fd1371cc7af
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at 3ab30300 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0x3b23ab00
Data Size: 9160505 Bytes = 8.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 34c8dbec64a0c800281419dccd445b0b6ff60dcb9c431584b823cc4088347bde
Loading ramdisk from 0x3b23ab00 to 0x0a200000
## Loading fdt from FIT Image at 3ab30300 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0x3ab30b00
Data Size: 102486 Bytes = 100.1 KiB
Architecture: ARM
Load Address: 0x08300000
Hash algo: sha256
Hash value: a6ab3f1c003082ebca2f7c46956c7b840b70edd868eecb8e57a61c22e3a3663d
Loading fdt from 0x08300000 to 0x08300000
Booting using the fdt blob at 0x08300000
Loading Kernel Image from 0x3ab49d00 to 0x02008000 … OK
‘reserved-memory’ ramoops@8000000: addr=8000000 size=100000
Using Device Tree in place at 08300000, end 0831c055
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x40000000 (size: 0x379b8000)
Total: 1082.405 ms
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.19.111 (qzw@superserver) (rv1126_rv1109_linux_20211022.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 SMP PREEMPT Sat Dec 4 11:12:16 CST 2021
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] OF: fdt: Machine model: Firefly Core-RV1126-JD4 Board
[ 0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options ‘’)
[ 0.000000] Reserved memory: created CMA memory pool at 0x3f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x2dc00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 259512
[ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal ro rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 cgroup_enable=memory swapaccount=1 snd_aloop.index=7
[ 0.000000] Memory: 739904K/1046240K available (9216K kernel code, 421K rwdata, 2460K rodata, 1024K init, 946K bss, 36000K reserved, 270336K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xb0000000 - 0xf0000000 (1024 MB)
[ 0.000000] pkmap : 0xafe00000 - 0xb0000000 ( 2 MB)
[ 0.000000] modules : 0xaf000000 - 0xafe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (10208 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 422 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 947 kB)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000760] Switching to timer-based delay loop, resolution 41ns
[ 0.002660] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003626] pid_max: default: 4096 minimum: 301
[ 0.004232] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004861] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.006316] CPU: Testing write buffer coherency: ok
[ 0.007171] /cpus/cpu@f00 missing clock-frequency property
[ 0.007700] /cpus/cpu@f01 missing clock-frequency property
[ 0.008223] /cpus/cpu@f02 missing clock-frequency property
[ 0.008748] /cpus/cpu@f03 missing clock-frequency property
[ 0.009268] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.010604] Setting up static identity map for 0x100000 - 0x100060
[ 0.011355] rcu: Hierarchical SRCU implementation.
[ 0.012453] smp: Bringing up secondary CPUs …
[ 0.013861] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.014939] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.015948] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.016086] smp: Brought up 1 node, 4 CPUs
[ 0.018157] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.018743] CPU: All CPU(s) started in SVC mode.
[ 0.020098] devtmpfs: initialized
[ 0.049074] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.049159] Unpacking initramfs…
[ 0.050481] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.051391] futex hash table entries: 16 (order: -2, 1024 bytes)
[ 0.052209] pinctrl core: initialized pinctrl subsystem
[ 0.054119] NET: Registered protocol family 16
[ 0.055332] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.058110] cpuidle: using governor menu
[ 0.058562] Registered FIQ tty driver
[ 0.059705] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.060452] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.063371] console [pstore-1] enabled
[ 0.064016] pstore: Registered ramoops as persistent store backend
[ 0.064598] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[ 0.114928] cryptd: max_cpu_qlen set to 1000
[ 0.116341] fiq debugger fiq mode enabled
[[ 0.117164] console [ttyFIQ0] enabled
[ 0.117888] bootconsole [uart8250] disabled
[ 0.118589] Registered fiq debugger ttyFIQ0
[ 0.119275] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 0.125070] rk_iommu ffb00f00.iommu: version = 1
[ 0.125735] rk_iommu ffb20800.iommu: version = 1
[ 0.126220] rk_iommu ffb60e00.iommu: version = 1
[ 0.126912] rk_iommu ffb80480.iommu: version = 1
[ 0.127520] rk_iommu ffb90800.iommu: version = 1
[ 0.128040] rk_iommu ffbb0f00.iommu: version = 1
[ 0.129166] SCSI subsystem initialized
[ 0.129521] usbcore: registered new interface driver usbfs
[ 0.129615] usbcore: registered new interface driver hub
[ 0.129819] usbcore: registered new device driver usb
[ 0.129953] media: Linux media interface: v0.10
[ 0.130036] videodev: Linux video capture interface: v2.00
[ 0.130117] pps_core: LinuxPPS API ver. 1 registered
[ 0.130142] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.130188] PTP clock support registered
[ 0.131730] Advanced Linux Sound Architecture Driver Initialized.
[ 0.132485] Bluetooth: Core ver 2.22
[ 0.132584] NET: Registered protocol family 31
[ 0.132612] Bluetooth: HCI device and connection manager initialized
[ 0.132646] Bluetooth: HCI socket layer initialized
[ 0.132675] Bluetooth: L2CAP socket layer initialized
[ 0.132735] Bluetooth: SCO socket layer initialized
[ 0.133332] rockchip-cpuinfo cpuinfo: SoC : 11260000
[ 0.133368] rockchip-cpuinfo cpuinfo: Serial : d3723d53e03c6fcb
[ 0.134682] clocksource: Switched to clocksource arch_sys_counter
[ 0.137327] NET: Registered protocol family 2
[ 0.138354] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.138421] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.138580] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.138777] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.138950] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.139032] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.139298] NET: Registered protocol family 1
[ 0.141518] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.144265] Initialise system trusted keyrings
[ 0.144580] workingset: timestamp_bits=29 max_order=18 bucket_order=0
[ 0.152319] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.155190] Key type asymmetric registered
[ 0.155234] Asymmetric key parser ‘x509’ registered
[ 0.155311] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.155341] io scheduler noop registered
[ 0.155363] io scheduler deadline registered
[ 0.155550] io scheduler cfq registered (default)
[ 0.155581] io scheduler mq-deadline registered
[ 0.155605] io scheduler kyber registered
[ 0.155775] io scheduler bfq registered
[ 0.160121] phy phy-ff4c0000.usb2-phy.1: Linked as a consumer to regulator.5
[ 0.162335] phy phy-ff4c8000.usb2-phy.2: Linked as a consumer to regulator.4
[ 0.166392] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.166565] pwm-backlight backlight: Linked as a consumer to regulator.0
[ 0.167005] mpp_service mpp-srv: 4cdfd254f099 author: Yandong Lin 2021-02-21 video: rockchip: mpp: Fix irq state err.
[ 0.167043] mpp_service mpp-srv: probe start
[ 0.168080] iommu: Adding device ffb80000.rkvdec to group 3
[ 0.168146] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[ 0.168352] mpp_rkvdec ffb80000.rkvdec: probing start
[ 0.169058] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[ 0.169097] rkvdec_init:1182: No niu aclk reset resource define
[ 0.169126] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[ 0.169150] rkvdec_init:1185: No niu hclk reset resource define
[ 0.169477] mpp_rkvdec ffb80000.rkvdec: probing finish
[ 0.170232] iommu: Adding device ffbb0000.rkvenc to group 5
[ 0.170295] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[ 0.170633] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.171326] mpp_rkvenc ffbb0000.rkvenc: venc regulator not ready, retry
[ 0.171401] rkvenc_init:1194: failed to add venc devfreq
[ 0.172615] iommu: Adding device ffb90400.vdpu to group 4
[ 0.172671] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[ 0.172790] mpp_vdpu2 ffb90400.vdpu: probe device
[ 0.173350] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.173397] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.173715] mpp_vdpu2 ffb90400.vdpu: probing finish
[ 0.174402] iommu: Adding device ffb90000.vepu to group 4
[ 0.174463] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[ 0.174596] mpp_vepu2 ffb90000.vepu: probe device
[ 0.175238] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.175282] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.175561] mpp_vepu2 ffb90000.vepu: probing finish
[ 0.176132] iommu: Adding device ffb20000.iep to group 1
[ 0.176191] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[ 0.176306] mpp-iep2 ffb20000.iep: probe device
[ 0.176992] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[ 0.177232] mpp-iep2 ffb20000.iep: probing finish
[ 0.177530] mpp_service mpp-srv: probe success
[ 0.182892] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.182945] dma-pl330 ff4e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.185507] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.186489] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.187454] ff560000.serial: ttyS0 at MMIO 0xff560000 (irq = 33, base_baud = 1500000) is a 16550A
[ 0.190160] random: fast init done
[ 0.190674] random: crng init done
[ 0.190789] iommu: Adding device ffb00000.vop to group 0
[ 0.190844] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[ 0.195281] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[ 0.196376] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[ 0.197741] rockchip-drm display-subsystem: devfreq is not set
[ 0.198313] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb0a3df00)
[ 0.198394] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] ERROR Failed to find panel or bridge: -517
[ 0.198434] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb0a4462c): -517
[ 0.198719] rockchip-drm display-subsystem: master bind failed: -517
[ 0.203970] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.1
[ 0.204054] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[ 0.204164] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[ 0.204213] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[ 0.212993] loop: module loaded
[ 0.213705] zram: Added device: zram0
[ 0.218304] libphy: Fixed MDIO Bus: probed
[ 0.220357] rk_gmac-dwmac ffc40000.ethernet: no regulator found
[ 0.220414] rk_gmac-dwmac ffc40000.ethernet: clock input or output? (output).
[ 0.220439] rk_gmac-dwmac ffc40000.ethernet: TX delay(0x2a).
[ 0.220466] rk_gmac-dwmac ffc40000.ethernet: RX delay(0x1a).
[ 0.220496] rk_gmac-dwmac ffc40000.ethernet: integrated PHY? (no).
[ 0.225604] rk_gmac-dwmac ffc40000.ethernet: init for RGMII
[ 0.225950] rk_gmac-dwmac ffc40000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.225985] rk_gmac-dwmac ffc40000.ethernet: DWMAC4/5
[ 0.226018] rk_gmac-dwmac ffc40000.ethernet: DMA HW capability register supported
[ 0.226043] rk_gmac-dwmac ffc40000.ethernet: RX Checksum Offload Engine supported
[ 0.226067] rk_gmac-dwmac ffc40000.ethernet: TX Checksum insertion supported
[ 0.226091] rk_gmac-dwmac ffc40000.ethernet: Wake-Up On Lan supported
[ 0.226167] rk_gmac-dwmac ffc40000.ethernet: TSO supported
[ 0.226188] rk_gmac-dwmac ffc40000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.226216] rk_gmac-dwmac ffc40000.ethernet: TSO feature enabled
[ 0.358089] libphy: stmmac: probed
[ 0.360181] PPP generic driver version 2.4.2
[ 0.360503] PPP BSD Compression module registered
[ 0.360534] PPP Deflate Compression module registered
[ 0.360583] PPP MPPE Compression module registered
[ 0.360609] NET: Registered protocol family 24
[ 0.360749] usbcore: registered new interface driver r8152
[ 0.360843] usbcore: registered new interface driver asix
[ 0.360932] usbcore: registered new interface driver ax88179_178a
[ 0.361006] usbcore: registered new interface driver cdc_ether
[ 0.361080] usbcore: registered new interface driver net1080
[ 0.361162] usbcore: registered new interface driver cdc_subset
[ 0.361234] usbcore: registered new interface driver zaurus
[ 0.361384] usbcore: registered new interface driver cdc_ncm
[ 0.361469] usbcore: registered new interface driver qmi_wwan
[ 0.363383] dwc3 ffd00000.dwc3: Failed to get clk ‘ref’: -2
[ 0.369958] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.370015] ehci-platform: EHCI generic platform driver
[ 0.373727] ehci-platform ffe00000.usb: EHCI Host Controller
[ 0.373806] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[ 0.374024] ehci-platform ffe00000.usb: irq 68, io mem 0xffe00000
[ 0.384769] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[ 0.385109] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.385146] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.385172] usb usb1: Product: EHCI Host Controller
[ 0.385196] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[ 0.385219] usb usb1: SerialNumber: ffe00000.usb
[ 0.386088] hub 1-0:1.0: USB hub found
[ 0.386173] hub 1-0:1.0: 1 port detected
[ 0.387024] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.387081] ohci-platform: OHCI generic platform driver
[ 0.387773] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[ 0.387834] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[ 0.388102] ohci-platform ffe10000.usb: irq 69, io mem 0xffe10000
[ 0.449066] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.449121] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.449141] usb usb2: Product: Generic Platform OHCI controller
[ 0.449184] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[ 0.449209] usb usb2: SerialNumber: ffe10000.usb
[ 0.450095] hub 2-0:1.0: USB hub found
[ 0.450180] hub 2-0:1.0: 1 port detected
[ 0.452045] usbcore: registered new interface driver cdc_wdm
[ 0.452217] usbcore: registered new interface driver usb-storage
[ 0.452381] usbcore: registered new interface driver option
[ 0.452447] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.453308] ============ himax_hx83102_init 1742 jjlook ==========
[ 0.453333] ============ himax_hx83102_probe 1725 jjlook ==========
[ 0.453350] ============ himax_common_init 1050 jjlook ==========
[ 0.453378] ============ himax_common_init 1059 jjlook ==========
[ 0.453760] i2c /dev entries driver
[ 0.455893] rk808 0-0020: chip id: 0x8090
[ 0.456008] rk808 0-0020: No cache defaults, reading back from HW
[ 0.462446] rk808 0-0020: source: on=0x40, off=0x00
[ 0.462503] rk808 0-0020: support dcdc3 fb mode:-22, -1329985520
[ 0.462530] rk808 0-0020: support pmic reset mode:0,0
[ 0.467189] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.467319] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.467431] DCDC_REG1: supplied by vcc5v0_sys
[ 0.468253] DCDC_REG2: supplied by vcc5v0_sys
[ 0.468924] DCDC_REG3: supplied by vcc5v0_sys
[ 0.469464] DCDC_REG4: supplied by vcc5v0_sys
[ 0.469969] DCDC_REG5: supplied by vcc5v0_sys
[ 0.470641] LDO_REG1: supplied by vcc_buck5
[ 0.471308] LDO_REG2: supplied by vcc_buck5
[ 0.471855] LDO_REG3: supplied by vcc_buck5
[ 0.472373] LDO_REG4: supplied by vcc_buck5
[ 0.472882] LDO_REG5: supplied by vcc_buck5
[ 0.473385] LDO_REG6: supplied by vcc_buck5
[ 0.473460] vcc_dvdd: Bringing 1100000uV into 1200000-1200000uV
[ 0.474103] LDO_REG7: supplied by vcc5v0_sys
[ 0.474617] LDO_REG8: supplied by vcc5v0_sys
[ 0.475335] LDO_REG9: supplied by vcc5v0_sys
[ 0.475995] SWITCH_REG1: supplied by vcc5v0_sys
[ 0.476484] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.478903] input: rk805 pwrkey as /devices/platform/ff3f0000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[ 0.482124] rk808-rtc rk808-rtc: registered as rtc0
[ 0.482758] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:02 UTC (1501837202)
[ 0.485440] pca953x 1-0020: 1-0020 supply vcc not found, using dummy regulator
[ 0.485576] pca953x 1-0020: Linked as a consumer to regulator.0
[ 0.485787] pca953x 1-0020: failed reading register
[ 0.485895] pca953x 1-0020: Dropping the link to regulator.0
[ 0.487910] ircut cam_ircut: driver version: 00.01.00
[ 0.488415] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 0.488502] ircut cam_ircut: Failed to get ircut-open-gpios
[ 0.488571] ircut cam_ircut: Failed to get ircut-close-gpios
[ 0.488698] ircut cam_ircut: probe successful!
[ 0.489621] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[ 0.491094] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[ 0.491159] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[ 0.491426] rkcif rkcif_dvp: rkcif driver version: v00.01.09
[ 0.491554] rkcif rkcif_dvp: attach to cif hw node
[ 0.492657] rkcif_dvp: cif_subdev_notifier: no subdev be found!
[ 0.492691] rkcif_dvp: Failed to register subdev notifier(-19)
[ 0.493653] rkcif rkcif_dvp: detach to cif hw node
[ 0.493787] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.09
[ 0.493908] rkcif rkcif_mipi_lvds: attach to cif hw node
[ 0.495010] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 0.495047] rockchip-mipi-csi2: Async registered subdev
[ 0.497551] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[ 0.497601] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[ 0.497952] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[ 0.498104] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[ 0.498475] rkisp rkisp-vir0: rkisp driver version: v01.04.01
[ 0.498740] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 0.499032] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 0.499082] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 0.499107] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[ 0.502760] iommu: Adding device ffb60000.rkispp to group 2
[ 0.502847] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[ 0.503507] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[ 0.503561] rkispp_hw ffb60000.rkispp: can’t request region for resource [mem 0xffb60000-0xffb7ffff]
[ 0.504108] rkispp rkispp-vir0: rkispp driver version: v01.04.01
[ 0.506932] usbcore: registered new interface driver uvcvideo
[ 0.506972] USB Video Class driver (1.1.1)
[ 0.507478] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.20
[ 0.507606] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.16
[ 0.507824] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.23
[ 0.508172] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.14
[ 0.508314] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.11
[ 0.511726] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -5
[ 0.512181] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[ 0.512735] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = 0
[ 0.513038] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[ 0.514092] Bluetooth: HCI UART driver ver 2.3
[ 0.514131] Bluetooth: HCI UART protocol H4 registered
[ 0.514504] cpu cpu0: bin=0
[ 0.514563] cpu cpu0: leakage=1.500
[ 0.514789] cpu cpu0: Linked as a consumer to regulator.9
[ 0.526545] cpu cpu0: temp=39100, pvtm=98289 (98263 + 26)
[ 0.526694] cpu cpu0: pvtm-volt-sel=1
[ 0.526803] cpu cpu0: Dropping the link to regulator.9
[ 0.526884] cpu cpu0: bin-scale=5
[ 0.527371] cpu cpu0: Linked as a consumer to regulator.9
[ 0.527464] cpu cpu0: Dropping the link to regulator.9
[ 0.527735] cpu cpu0: Linked as a consumer to regulator.9
[ 0.529058] cpu cpu0: avs=0
[ 0.529575] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 0.529615] cpu cpu0: failed to read out thermal zone (-22)
[ 0.530684] cpu cpu0: failed to find power_model node
[ 0.530823] cpuidle: enable-method property ‘psci’ found operations
[ 0.530925] cpuidle: enable-method property ‘psci’ found operations
[ 0.531002] cpuidle: enable-method property ‘psci’ found operations
[ 0.531078] cpuidle: enable-method property ‘psci’ found operations
[ 0.531633] rockchip-pinctrl pinctrl: pin gpio0-6 already requested by ff450000.spi; cannot claim for sdio-pwrseq
[ 0.531680] rockchip-pinctrl pinctrl: pin-6 (sdio-pwrseq) status -22
[ 0.531696] rockchip-pinctrl pinctrl: could not request pin 6 (gpio0-6) from group wifi-enable-h on device rockchip-pinctrl
[ 0.531707] pwrseq_simple sdio-pwrseq: Error applying setting, reverse things back
[ 0.531734] pwrseq_simple: probe of sdio-pwrseq failed with error -22
[ 0.532086] Synopsys Designware Multimedia Card Interface Driver
[ 0.532587] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.532622] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[ 0.532644] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[ 0.532702] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[ 0.532828] mmc_host mmc0: card is non-removable.
[ 0.544921] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.558554] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.558616] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[ 0.558635] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[ 0.558697] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[ 0.558843] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.20
[ 0.571543] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.585053] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.585130] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 0.585166] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 0.585244] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[ 0.587163] usbcore: registered new interface driver usbkbd
[ 0.587232] usbcore: registered new interface driver usbmouse
[ 0.588372] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.16
[ 0.588768] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[ 0.588821] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 0.588937] mmc0: new HS200 MMC card at address 0001
[ 0.589188] rksfc_base v1.1 2016-01-08
[ 0.589676] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[ 0.589841] rkflash_dev_init enter
[ 0.589931] sfc nor id: 0 0 0
[ 0.589980] rkflash[1] is invalid
[ 0.589987] rkflash_dev_init enter
[ 0.590024] sfc_nand id: 0 0 0
[ 0.590045] rkflash[2] is invalid
[ 0.590052] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 0.590847] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 0.591691] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 0.592053] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (241:0)
[ 0.595458] rk817-codec rk817-codec: DMA mask not set
[ 0.595587] rk817_codec_parse_dt_property: rk809 have no io-channels defined
[ 0.595643] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 0.599778] NET: Registered protocol family 17
[ 0.599839] NET: Registered protocol family 15
[ 0.600203] Bluetooth: RFCOMM TTY layer initialized
[ 0.600248] Bluetooth: RFCOMM socket layer initialized
[ 0.600282] Bluetooth: RFCOMM ver 1.11
[ 0.600300] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 0.600315] Bluetooth: HIDP socket layer initialized
[ 0.600323] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.600329] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.600640] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 0.600685] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6236
[ 0.600696] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 0.600706] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 0.600762] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0.
[ 0.600795] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 0.600806] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 0.601163] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 48.
[ 0.601194] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 7.
[ 0.601234] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 5.
[ 0.601252] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 0.601295] [BT_RFKILL]: Request irq for bt wakeup host
[ 0.601518] [BT_RFKILL]: ** disable irq
[ 0.628130] [BT_RFKILL]: bt shut off power
[ 0.628233] [BT_RFKILL]: bt_default device registered.
[ 0.629955] flash vendor_init_thread!
[ 0.629974] os04a10 1-0036: driver version: 00.01.04
[ 0.630008] flash vendor storage:20170308 ret = -1
[ 0.630130] os04a10 1-0036: Get hdr mode failed! no hdr default
[ 0.630412] os04a10 1-0036: could not get sleep pinstate
[ 0.630603] os04a10 1-0036: Linked as a consumer to regulator.19
[ 0.630760] os04a10 1-0036: Linked as a consumer to regulator.16
[ 0.630871] os04a10 1-0036: Linked as a consumer to regulator.18
[ 0.631124] clk_mipicsi_out2io_fracdiv p_rate(297000000) is low than rate(24000000)*20, use integer or half-div
[ 0.642261] os04a10 1-0036: Unexpected sensor id(000000), ret(-5)
[ 0.642566] os04a10 1-0036: Dropping the link to regulator.19
[ 0.642718] os04a10 1-0036: Dropping the link to regulator.16
[ 0.642837] os04a10 1-0036: Dropping the link to regulator.18
[ 0.643753] Registering SWP/SWPB emulation handler
[ 0.646257] Loading compiled-in X.509 certificates
[ 0.647704] rga2: Driver loaded successfully ver:3.02
[ 0.647919] rga2: Module initialized.
[ 0.652370] vendor storage:20190527 ret = 0
[ 0.655614] Freeing initrd memory: 8948K
[ 0.669778] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.670606] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.8
[ 0.670661] mpp_rkvenc ffbb0000.rkvenc: bin=0
[ 0.670683] mpp_rkvenc ffbb0000.rkvenc: leakage=1.125
[ 0.670730] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[ 0.670759] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[ 0.671034] mpp_rkvenc ffbb0000.rkvenc: avs=0
[ 0.671249] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[ 0.671263] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[ 0.671487] mpp_rkvenc ffbb0000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 0.671560] mpp_rkvenc ffbb0000.rkvenc: failed to read out thermal zone (-22)
[ 0.672715] mpp_rkvenc ffbb0000.rkvenc: probing finish
[ 0.674631] rockchip-drm display-subsystem: devfreq is not set
[ 0.675067] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb0a3df00)
[ 0.675164] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb0a4462c)
[ 0.675183] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.675193] [drm] No driver support for vblank timestamp query.
[ 0.683494] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.684054] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 0.685329] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.685411] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 0.685435] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 0.685484] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[ 0.688543] asoc-simple-card rk809-sound: rk817-hifi ↔ ff800000.i2s mapping ok
[ 0.688624] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 0.688639] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 0.688655] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 0.688667] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 0.688683] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 0.688695] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 0.688711] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 0.688726] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 0.689619] input: rockchip,rk809-codec Headphone Jack as /devices/platform/rk809-sound/sound/card0/input2
[ 0.691254] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.691312] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 0.691382] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 0.691431] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[ 0.692621] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.692655] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 0.692680] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 0.692715] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[ 0.693782] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 0.693806] ======== dhd_wlan_init_plat_data ========
[ 0.693818] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 0.693895] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=108, oob_irq_flags=0x414
[ 0.693913] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 0.693927] dhd_wifi_platform_load: Enter
[ 0.693943] Power-up adapter ‘DHD generic adapter’
[ 0.693987] wifi_platform_set_power = 1
[ 0.694002] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 0.694016] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 0.694031] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 0.694085] ==gsl_ts_init==
[ 0.694179] GSLX680 Enter gsl_ts_probe
[ 0.694195] ==kzalloc success=
[ 0.718115] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 0.869735] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=88.32
[ 0.869814] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.869844] usb 1-1: Product: USB2.0 Hub
[ 0.872623] hub 1-1:1.0: USB hub found
[ 0.873700] hub 1-1:1.0: 4 ports detected
[ 0.879395] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.879465] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 0.879490] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 0.879539] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[ 0.998305] wifi_platform_bus_enumerate device present 1
[ 0.998367] ======== Card detection to detect SDIO card! ========
[ 0.998391] sdio: host isn’t initialization successfully.
[ 1.158382] usb 1-1.3: new high-speed USB device number 3 using ehci-platform
[ 1.261274] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8152, bcdDevice=20.00
[ 1.261452] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.261499] usb 1-1.3: Product: USB 10/100 LAN
[ 1.261537] usb 1-1.3: Manufacturer: Realtek
[ 1.261573] usb 1-1.3: SerialNumber: 00E04C61D9C1
[ 1.268659] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.268782] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 1.268831] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 1.268934] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[ 1.348373] usb 1-1.3: reset high-speed USB device number 3 using ehci-platform
[ 1.528891] r8152 1-1.3:1.0 eth1: v2.12.0 (2019/04/29)
[ 1.528961] r8152 1-1.3:1.0 eth1: This product is covered by one or more of the following patents:
[ 1.528961] US6,570,884, US6,115,776, and US6,327,625.
[ 1.528961]
[ 1.530881] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.530944] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 1.530974] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 1.531045] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[ 1.598379] phy phy-ff4c0000.usb2-phy.1: charger = USB_SDP_CHARGER
[ 1.625036] gsl_ts_probe–1377, i2c_master_recv fail
[ 1.625287] ret=0
[ 1.625383] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[ 1.625426] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.629351] rkcif_mipi_lvds: Async subdev notifier completed
[ 1.631251] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.649900] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.650119] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.650140] cfg80211: failed to load regulatory.db
[ 1.650636] rkisp rkisp-vir0: clear unready subdev num: 1
[ 1.651110] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.651139] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.651155] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.651171] rkisp0: Invalid mipi data type
[ 1.651183] rkisp0: update sensor failed
[ 1.651722] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 270
[ 1.652614] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 1.653511] ret 1024 0
[ 1.653852] ALSA device list:
[ 1.653865] #0: rockchip,rk809-codec
[ 1.653879] #7: Loopback 1
[ 1.655192] Freeing unused kernel memory: 1024K
[ 1.655528] Run /init as init process
Loading, please wait…
Couldn’t get a file descriptor referring to the console
starting version 237
[ 3.038239] failed to power up DHD generic adapter, 1 retry left
[ 3.054859] wifi_platform_set_power = 0
[ 3.054928] ======== PULL WL_REG_ON(-1) LOW! ========
[ 3.054954] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.054977] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 3.055000] wifi_platform_bus_enumerate device present 0
[ 3.055019] ======== Card detection to remove SDIO card! ========
[ 3.055042] sdio: host isn’t initialization successfully.
[ 3.055203] wifi_platform_set_power = 1
[ 3.055238] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.055277] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.055300] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
/scripts/init-top/console_setup: line 134: can’t create /dev/tty1: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty1: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty2: No such device or address
[ 3.361559] wifi_platform_bus_enumerate device present 1
[ 3.361614] ======== Card detection to detect SDIO card! ========
[ 3.361626] sdio: host isn’t initialization successfully.
/scripts/init-top/console_setup: line 1: can’t open /dev/tty2: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty3: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty3: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty4: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty4: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty5: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty5: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty6: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty6: No such device or address
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 4.224494] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 4.397099] EXT4-fs (mmcblk0p8): warning: mounting unchecked fs, running e2fsck is recommended
[ 4.399220] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
[[: missing ]]
ln: /root/var/lib/docker: File exists
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/4.19.111 in initramfs.
done.
mount: mounting proc on /proc failed: Device or resource busy
NAME=Buildroot
VERSION=2018.02-rc3-gc54e142782
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME=“Buildroot 2018.02-rc3”
Starting logging: OK
/usr/bin/modetest
Populating /dev using udev: [ 4.779055] udevd[422]: starting version 3.2.7
[ 4.788683] udevd[422]: specified group ‘kvm’ unknown
[ 4.810111] udevd[423]: starting eudev-3.2.7
[ 4.953516] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.956099] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.962802] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.963907] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.973720] rockchip-mipi-dphy-rx: No link between dphy and sensor
done
Initializing random number generator… done.
Will now mount all partitions in /etc/fstab
Note: Create /.skip_fsck to skip fsck
  • The check might take a while if didn’t shutdown properly!
    [ 5.384801] failed to power up DHD generic adapter, 0 retry left
    [ 5.401032] wifi_platform_set_power = 0
    [ 5.401075] ======== PULL WL_REG_ON(-1) LOW! ========
    [ 5.401089] [WLAN_RFKILL]: rockchip_wifi_power: 0
    [ 5.401102] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
    [ 5.401112] wifi_platform_bus_enumerate device present 0
    [ 5.401122] ======== Card detection to remove SDIO card! ========
    [ 5.401132] sdio: host isn’t initialization successfully.
    [ 5.401142] failed to power up DHD generic adapter, max retry reached**
    [ 5.401154] unregister wifi platform drivers
    [ 5.401173] wifi_platform_bus_enumerate device present 0
    [ 5.401195] ======== Card detection to remove SDIO card! ========
    [ 5.401205] sdio: host isn’t initialization successfully.
    [ 5.401216] ======== dhd_wlan_deinit_plat_data ========
    [ 5.401228] dhd_module_init: Failed to load the driver, try cnt 0
    [ 5.401289] dhd_module_init: Failed to load driver max retry reached**
    [ 5.401310] dhd_module_init: Exit err=-19
    Handling misc: /dev/mmcblk0p2 /misc emmc defaults 0
    Unsupported file system emmc for /dev/mmcblk0p2
    Handling oem: /dev/mmcblk0p7 /oem ext2 defaults 2
    Checking /dev/mmcblk0p7(ext2)
    e2fsck 1.43.9 (8-Feb-2018)
    oem: recovering journal
    oem: clean, 432/48192 files, 173343/196608 blocks
    Mounting /dev/mmcblk0p7(ext2) on /oem
    [ 5.777815] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    Handling userdata: /dev/mmcblk0p8 /userdata ext2 defaults 2
    Checking /dev/mmcblk0p8(ext2)
    /dev/mmcblk0p8 is in use.
    e2fsck: Cannot continue, aborting.
Mounting /dev/mmcblk0p8(ext2) on /userdata
Log saved to /tmp/mountall.log
Starting system message bus: done
/etc/init.d/S36load_rv1109_wifi_modules: line 45: can’t create /sys/class/rfkill/rfkill1/state: nonexistent directory
load wifi modules: insmod: can’t insert ‘/vendor/lib/modules/bcmdhd.ko’: No such file or directory
FAIL
Starting network: OK
Starting connman … done.
No state is present for card Loopback
Found hardware: “Loopback” “Loopback Mixer” “” “” “”
Hardware is initialized using a generic method
connect failed: : No such file or directory
[ 6.321592] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 6.321651] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 6.321670] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 6.321723] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[ 6.345569] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 6.346305] rk_gmac-dwmac ffc40000.ethernet: rk_get_eth_addr: mac address: 8a:54:28:c1:04:d7
[ 6.346336] rk_gmac-dwmac ffc40000.ethernet: device MAC address 8a:54:28:c1:04:d7
unknown control ‘band_stop_filter’
[ 6.356377] dwmac4: Master AXI performs any burst length
[ 6.356455] rk_gmac-dwmac ffc40000.ethernet eth0: No Safety Features support found
[ 6.356485] rk_gmac-dwmac ffc40000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 6.356819] rk_gmac-dwmac ffc40000.ethernet eth0: registered PTP clock
Starting dropbear sshd: OK
Starting fcgiwrap daemon: OK
Starting nginx…
Debug: configfs_init
[ 6.593876] file system registered
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0’: No such file or directory
[ 6.622991] using random self ethernet address
[ 6.623052] using random host ethernet address
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6’: No such file or directory
[ 6.642977] Mass Storage Function, version: 2009/09/11
[ 6.643049] LUN: removable file: (no medium)
mkdir: cannot create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/hid.usb0’: No such file or directory
[ 6.732106] read descriptors
[ 6.732168] read strings
insmod NPU modules: [ 7.779424] galcore: loading out-of-tree module taints kernel.
[ 7.788133] galcore: npu init.
[ 7.789496] galcore: start npu probe.
[ 7.789700] galcore ffbc0000.npu: Linked as a consumer to regulator.8
[ 7.790010] npu: platform_get_irq irq = 67
[ 7.790042] npu: platform_get_resource registerMemBase = ffbc0000, registerMemSize = 4000
[ 7.790058] Galcore version 6.4.3.5.293908
[ 7.790067] Galcore options:
[ 7.790076] irqLine = 67
[ 7.790090] registerMemBase = 0xFFBC0000
[ 7.790102] registerMemSize = 0x00004000
[ 7.790114] contiguousSize = 0x00400000
[ 7.790125] contiguousBase = 0x0
[ 7.790137] externalSize = 0x00000000
[ 7.790148] externalBase = 0x0
[ 7.790159] exclusiveSize = 0x00000000
[ 7.790171] exclusiveBase = 0x0
[ 7.790182] bankSize = 0x00000000
[ 7.790193] fastClear = -1
[ 7.790204] compression = 15
[ 7.790216] powerManagement = 1
[ 7.790227] baseAddress = 0x00000000
[ 7.790238] physSize = 0x00000000
[ 7.790249] recovery = 1
[ 7.790260] stuckDump = 0
[ 7.790272] gpuProfiler = 1
[ 7.790283] userClusterMask = 0x0
[ 7.790294] GPU smallBatch = 1
[ 7.790302] allMapInOne = 1
[ 7.790310] irqs =
[ 7.790312] 67,
[ 7.790323] -1,
[ 7.790334] -1,
[ 7.790345] -1,
[ 7.790356] -1,
[ 7.790367] -1,
[ 7.790377] -1,
[ 7.790388] -1,
[ 7.790399] -1,
[ 7.790409] -1,
[ 7.790419]
[ 7.790439] registerBases =
[ 7.790441] 0xFFBC0000,
[ 7.790453] 0x00000000,
[ 7.790464] 0x00000000,
[ 7.790475] 0x00000000,
[ 7.790485] 0x00000000,
[ 7.790496] 0x00000000,
[ 7.790507] 0x00000000,
[ 7.790518] 0x00000000,
[ 7.790529] 0x00000000,
[ 7.790537] 0x00000000,
[ 7.790544]
[ 7.790564] registerSizes =
[ 7.790566] 0x00004000,
[ 7.790578] 0x00000000,
[ 7.790588] 0x00000000,
[ 7.790599] 0x00000000,
[ 7.790610] 0x00000000,
[ 7.790621] 0x00000000,
[ 7.790631] 0x00000000,
[ 7.790642] 0x00000000,
[ 7.790653] 0x00000000,
[ 7.790663] 0x00000000,
[ 7.790674]
[ 7.790694] chipIDs =
[ 7.790696] 0xFFFFFFFF,
[ 7.790707] 0xFFFFFFFF,
[ 7.790718] 0xFFFFFFFF,
[ 7.790730] 0xFFFFFFFF,
[ 7.790741] 0xFFFFFFFF,
[ 7.790753] 0xFFFFFFFF,
[ 7.790764] 0xFFFFFFFF,
[ 7.790772] 0xFFFFFFFF,
[ 7.790779] 0xFFFFFFFF,
[ 7.790790] 0xFFFFFFFF,
[ 7.790801]
[ 7.790822] core 0 internal sRAMBases =
[ 7.790824] 0xFFFFFFFFFFFFFFFF,
[ 7.790835] 0xFFFFFFFFFFFFFFFF,
[ 7.790846]
[ 7.790867] core 1 internal sRAMBases =
[ 7.790869] 0xFFFFFFFFFFFFFFFF,
[ 7.790880] 0xFFFFFFFFFFFFFFFF,
[ 7.790891]
[ 7.790912] core 2 internal sRAMBases =
[ 7.790914] 0xFFFFFFFFFFFFFFFF,
[ 7.790926] 0xFFFFFFFFFFFFFFFF,
[ 7.790936]
[ 7.790953] core 3 internal sRAMBases =
[ 7.790955] 0xFFFFFFFFFFFFFFFF,
[ 7.790967] 0xFFFFFFFFFFFFFFFF,
[ 7.790977]
[ 7.790993] core 4 internal sRAMBases =
[ 7.790995] 0xFFFFFFFFFFFFFFFF,
[ 7.791003] 0xFFFFFFFFFFFFFFFF,
[ 7.791014]
[ 7.791036] core 5 internal sRAMBases =
[ 7.791038] 0xFFFFFFFFFFFFFFFF,
[ 7.791049] 0xFFFFFFFFFFFFFFFF,
[ 7.791060]
[ 7.791077] core 6 internal sRAMBases =
[ 7.791079] 0xFFFFFFFFFFFFFFFF,
[ 7.791091] 0xFFFFFFFFFFFFFFFF,
[ 7.791102]
[ 7.791123] core 7 internal sRAMBases =
[ 7.791125] 0xFFFFFFFFFFFFFFFF,
[ 7.791136] 0xFFFFFFFFFFFFFFFF,
[ 7.791147]
[ 7.791168] core 8 internal sRAMBases =
[ 7.791170] 0xFFFFFFFFFFFFFFFF,
[ 7.791182] 0xFFFFFFFFFFFFFFFF,
[ 7.791192]
[ 7.791213] core 9 internal sRAMBases =
[ 7.791215] 0xFFFFFFFFFFFFFFFF,
[ 7.791225] 0xFFFFFFFFFFFFFFFF,
[ 7.791232]
[ 7.791247] External sRAMBases =
[ 7.791249] 0xffffffffffffffff,
[ 7.791260] 0xffffffffffffffff,
[ 7.791271]
[ 7.791291] mmuPageTablePool = 1
[ 7.791302] mmuDynamicMap = 1
[ 7.791313] isrPoll = 0x00000000
[ 7.791370] Build options:
[ 7.791394] gcdGPU_TIMEOUT = 20000
[ 7.791414] gcdGPU_2D_TIMEOUT = 4000
[ 7.791437] gcdINTERRUPT_STATISTIC = 1
[ 7.793799] Galcore Info: ContiguousBase=0x3f959000 ContiguousSize=0x400000
[ 7.798759] Galcore Info: MMU mapped core 0 SRAM[0] hardware virtual address=0x400000 size=0x40000
[ 7.798795] Galcore Info: MMU mapped core 0 SRAM[1] hardware virtual address=0x440000 size=0x40000
[ 7.801246] NN flop resetting…
[ 7.806668] galcore ffbc0000.npu: Init npu devfreq
[ 7.806717] galcore ffbc0000.npu: bin=0
[ 7.806767] galcore ffbc0000.npu: leakage=1.0
[ 7.818692] galcore ffbc0000.npu: temp=38800, pvtm=97641 (97641 + 0)
[ 7.819010] galcore ffbc0000.npu: pvtm-volt-sel=1
[ 7.819084] galcore ffbc0000.npu: bin-scale=23
[ 7.820196] galcore ffbc0000.npu: avs=0
[ 7.821060] gOK
alcore ffbc0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 7.821123] galcore ffbc0000.npu: failed to read out thermal zone (-22)
[ 7.821299] galcore ffbc0000.npu: failed to find power_model node
[ 7.821381] galcore ffbc0000.npu: failed to initialize power model
[ 7.827406] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 7.827482] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 7.827509] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 7.827569] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
Starting dnsmasq:
dnsmasq: failed to create listening socket for port 53: Address already in use
Exiting, name server cannot be used: Temporary failure in name resolution (-3)FAIL
4 Aug 09:00:09 ntpdate[889]: name server cannot be used: Temporary failure in name resolution (-3)
[ 7.885557] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.885643] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.893863] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.893933] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.902894] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.902970] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.912616] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.912703] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 7.919103] android_work: did not send uevent (0 0 (null))
net.core.wmem_max = 1572864
dbserver[911]: dbserver version 1.0
[ 8.009032] android_work: sent uevent USB_STATE=CONNECTED
[ 8.013463] configfs-gadget gadget: high-speed config #1: b
[ 8.013682] android_work: sent uevent USB_STATE=CONFIGURED
dbserver[911]: [dbserver][main]:dbserver init finish
dbserver[911]: [dbserver][main]:dbserver dbus register finish
netserver[926]: netserver version 1.0
netserver[926]: [main.c][main]:The path of nginx.conf is not specified, use the default path
storage_manager[941]: storage_manager version 1.0
storage_manager[941]: [main.c][main_init]:storage_manager init
netserver[926]: [netctl.c][populate_vpnconnection_hash]:Error getting VPN connections: The name net.connman.vpn was not provided by any .service files
storage_manager[941]: [main.c][main_init]:storage_manager init finish
storage_manager[941]: [manage.c][signal_update_media_path]:storage_manager signal_update_media_path, { }
start rknn server, version:1.6.0 (159d2d3 build: 2021-01-12 17:29:40)
I NPUTransfer: Starting NPU Transfer Server, Transfer version 2.1.0 (b5861e7@2020-11-23T11:51:07)
run ispserver
media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rockchip-mipi-dphy-rx is null
ispserver[972]: ispserver version 1.0.0
ispserver[972]: [ispserver][rkaiq_get_media_info]:get cam_num 0
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media0
media get entity by name: rkisp-isp-subdev is null
media get entity by name: rkisp-input-params is null
media get entity by name: rkisp-statistics is null
media get entity by name: rkispp_input_params is null
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media1
ispserver[972]: [ispserver][rkaiq_get_devname]:get rkisp-isp-subdev devname: /dev/v4l-subdev3
ispserver[972]: [ispserver][rkaiq_get_devname]:get rkisp-input-params devname: /dev/video15
ispserver[972]: [ispserver][rkaiq_get_devname]:get rkisp-statistics devname: /dev/video14
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media2
ispserver[972]: [ispserver][rkaiq_get_devname]:get rkispp_input_params devname: /dev/video23
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media3
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media4
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media5
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media6
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media7
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media8
ispserver[972]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media9
ispserver[972]: [ispserver][rkaiq_get_media_info]:cam id 0 find_sensor 0 find_isp 1 find_ispp 1
ispserver[972]: [ispserver][rkaiq_get_media_info]:cam id 1 find_sensor 0 find_isp 0 find_ispp 0
ispserver[972]: [ispserver][main]:call_fun_ipc_demo_server init
card0-DSI-1
find display
not HDMI
card 0: rockchiprk809co [rockchip,rk809-codec], device 0: ff800000.i2s-rk817-hifi rk817-hifi-0 [ff800000.i2s-rk817-hifi rk817-hifi-0]
find sound card
ash: 1: unknown operand
Filesystem volume name: media
prepare_part /userdata/media
fsck /userdata/media
Superblock last mount time is in the future.
(by less than a day, probably due to the hardware clock being incorrectly set)
Superblock last write time is in the future.
media was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Rga built version:1.04 c54e142+2021-12-04 11:25:07
mpp[986]: [mediaserver.cpp][parse_args]:mediaserver_log_level is 2
##RKMEDIA Log level: 2
[RKMEDIA][SYS][Info]:text is all=2
[RKMEDIA][SYS][Info]:module is all, log_level is 2
mediaserver[986]: mediaserver version 1.0.0
mediaserver[266]: start config: /oem/usr/share/mediaserver/rv1109/ipc-display-firefly.conf
mediaserver[986]: [flow_manager.cpp][ConfigParse]:flow manager parse config
mediaserver[986]: [flow_parser.cpp][SyncReOpenFlow]:flowunit: source_1 copy pipe id 0, flow id 0
mediaserver[986]: [flow_parser.cpp][SyncReOpenFlow]:flowunit: audio_enc_0 copy pipe id 0, flow id 0
mediaserver[986]: [flow_parser.cpp][GetPipeIndex]:find type 1 in pipe_index 0
mediaserver[986]: [flow_parser.cpp][GetPipeIndex]:find type 1 in pipe_index 1
mediaserver[986]: [flow_parser.cpp][GetPipeIndex]:find type 14 in pipe_index 1
mediaserver[986]: [flow_parser.cpp][GetPipeIndex]:find type 1 in pipe_index 2
mediaserver[986]: [flow_unit.cpp][SetEncodeType]:Not Support
mediaserver[986]: [flow_unit.cpp][SetSampleFormat]:Not Support
mediaserver[986]: [flow_manager.cpp][SyncDBConfig]:select region invade database id 0
mediaserver[986]: [flow_db_protocol.cpp][GetMoveDetectRegions]:md_pipe_index is 1
mediaserver[986]: [flow_db_protocol.cpp][GetMoveDetectRegions]:pipe[0] no found md_flow
mediaserver[986]: [flow_manager.cpp][SyncDBConfig]:md_roi_rect is null
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
mediaserver[986]: [flow_db_protocol.cpp][GetMoveDetectRegions]:md_flow belongs to the pipe, height is 480, width is 640
mediaserver[986]: [flow_db_protocol.cpp][GetMoveDetectRegions]:move detection is disabled
Pass 4: Checking reference counts
mediaserver[986]: [flow_db_protocol.cpp][GetMoveDetectRegions]:pipe[2] no found md_flow
mediaserver[986]: [flow_db_protocol.cpp][GetMoveDetectRegions]:pipe[3] no found md_flow
mediaserver[986]: [flow_manager.cpp][SyncDBConfig]:select smart_cover_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 0, “iFaceEnabled”: 0, “iFaceRecognitionEnabled”: 0, “iStreamOverlayEnabled”: 0, “iImageOverlayEnabled”: 0, “iInfoOverlayEnabled”: 0, “sTargetImageType”: “head”, “iWidthRatio”: 10, “iFaceHeightRatio”: 10, “iBodyHeightRatio”: 10, “sImageQuality”: “good” } ] }
mediaserver[986]: [flow_manager.cpp][SyncDBConfig]:select smart_cover_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: }
Pass 5: Checking group summary information
mediaserver[986]: [flow_manager.cpp][SyncDBConfig]:select rtsp_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 3, “sProtocol”: “RTSP”, “iPortNo”: 554 } ] }
mediaserver[986]: [flow_manager.cpp][SyncDBConfig]:select rtmp_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 4, “sProtocol”: “RTMP”, “iPortNo”: 1935 } ] }
mediaserver[986]: [flow_parser.cpp][SyncRTMPDBData]:rtmp old path is rtmp://127.0.0.1:1935/live/mainstream
mediaserver[986]: [flow_parser.cpp][SyncRTMPDBData]:rtmp new path is rtmp://127.0.0.1:1935/live/mainstream
mediaserver[986]: [flow_parser.cpp][SyncRTMPDBData]:rtmp old path is rtmp://127.0.0.1:1935/live/substream
mediaserver[986]: [flow_parser.cpp][SyncRTMPDBData]:rtmp new path is rtmp://127.0.0.1:1935/live/substream
mediaserver[986]: [flow_parser.cpp][SyncRTMPDBData]:rtmp old path is rtmp://127.0.0.1:1935/live/thirdstream
mediaserver[986]: [flow_parser.cpp][SyncRTMPDBData]:rtmp new path is rtmp://127.0.0.1:1935/live/thirdstream
mediaserver[986]: [flow_manager.cpp][SyncDBConfig]:select scenario_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 0, “sScenario”: “normal” } ] }
mediaserver[986]: [flow_manager.cpp][SyncDBConfig]:select enhance_db { “iReturn”: 0, “sErrMsg”: “”, “jData”: [ { “id”: 0, “sNoiseReduceMode”: “default”, “iDenoiseLevel”: 50, “iSpatialDenoiseLevel”: 50, “iTemporalDenoiseLevel”: 50, “sDehaze”: “close”, “iDehazeLevel”: 0, “sDIS”: “close”, “sGrayScaleMode”: “[0-255]”, “iImageRotation”: 0, “sFEC”: “close”, “sDistortionCorrection”: “close”, “iFecLevel”: 100, “iLdchLevel”: 0 } ] }
media: 22/261120 files (0.0% non-contiguous), 18449/1044475 blocks
mediaserver[986]: [flow_parser.cpp][GetPipeIndex]:find type 1 in pipe_ind[ex 2
11.910493] EXT4-fs (mmcblk0p9): mounting ext2 file smediaserver[986]: [flow_paryser.cpp][GetPipeIndex]:find type 1 in pipe_index 2
tem using the ext4 subsystem
mediaserver[986]: [flow_parser.cpp][GetPipeIndex]:find type 1 in pipe_index 3
[ 11.923169] EXT4-fs (mmcblk0p9): mounted filesystem without journal. Opts: (null)
storage_manager[941]: [uevent_monitor.c][uevent_monitor_thread]:uevent_monitor_thread /dev/mmcblk0p9 change
LOG_INFO :*** update_engine: Version V1.1.0 ***.
LOG_INFO :Current Mode is recovery.
mediaserver[986]: [flow_parser.cpp][SyncRtsp]:rstp input_data_type: audio:mp2,video:h265
mediaserver[986]: [flow_parser.cpp][SyncRtsp]:rstp input_data_type: audio:mp2,video:h264
mediaserver[986]: [flow_parser.cpp][SyncSmartEncorde]:smart is close, disable target and min bps
mediaserver[986]: [flow_manager.cpp][CreatePipes]:flow manager create flow pipe
[RKMEDIA][SYS][Info]:RKAIQ: parsing /dev/media0
[RKMEDIA][SYS][Info]:RKAIQ: parsing /dev/media1
[RKMEDIA][SYS][Info]:RKAIQ: model(rkisp0): isp_info(0): isp-subdev entity name: /dev/v4l-subdev3
Starting input-event-daemon: [RKMEDIA][SYS][Info]:RKAIQ: parsing /dev/media2
[RKMEDIA][SYS][Info]:RKAIQ: model(rkispp0): ispp_info(0): ispp-subdev entity name: /dev/v4l-subdev0
[RKMEDIA][SYS][Info]:#V4l2Stream: camraID:0, Device:rkispp_m_bypass
[RKMEDIA][SYS][Warn]:camera_id: 0, chn: rkispp_m_bypass
[RKMEDIA][SYS][Info]:#V4l2Stream: camera id:0, VideoNode:
[RKMEDIA][SYS][Error]:V4L2-CTX: open failed No such file or directory
[RKMEDIA][VI][Info]:Create stream v4l2_capture_stream failed
input-event-daemon: Start parsing /etc/input-event-daemon.conf…
[RKMEDIA][VI][Info]:#SourceStreamFlow: stream off…
[RKMEDIA][VI][Info]:#SourceStreamFlow: read thread exit sucessfully!
input-event-daemon: Adding device: /dev/input/event0…
[RKMEDIA][VI][Info]:#SourceStreamFlow: stream reset sucessfully!
input-event-daemon: Adding device: /dev/input/event1…
mediaserver[986]: [flow_pipe.cpp][CreateFlow]:Create flow source_stream failed
input-event-daemon: Adding device: /dev/input/event2…
mediaserver[986]: [flow_pipe.cpp][CreateFlow]:flow param :
name=v4l2_capture_stream
width=2688
height=1520
virtual_width=2688
virtual_height=1520
device=rkispp_m_bypass
frame_num=6
height=1520
output_data_type=image:nv12
use_libv4l2=1
v4l2_capture_type=VIDEO_CAPTURE
v4l2_mem_type=MEMORY_DMABUF
virtual_height=1520
virtual_width=2688
width=2688
input-event-daemon: Start listening on 3 devices…
done
[root@RV1126_RV1109:/]# storage_manager[941]: [manage.c][file_manage_thread]:MSG_CMD_DEV_CHANGE /dev/mmcblk0p9
storage_manager[941]: [manage.c][signal_update_disks_status]:storage_manager signal_update_disks_status, [ { “id”: 3, “sMountPath”: “/userdata/media”, “sName”: “Emmc”, “sDev”: “/dev/block/by-name/media”, “sAttributes”: “rw,relatime”, “sType”: “ext2”, “iStatus”: 1, “iMediaSize”: 0, “iTotalSize”: 4112300, “iFreeSize”: 4104104, “iFormatStatus”: 0, “iFormatProg”: 0, “sFormatErr”: “” } ]
版主,编译步骤如下有问题吗?source envsetup.sh 选择不同配置好像都一没有改过来
1、source envsetup.sh
2、选择以下四个任何一个,编译出来的都一样进不了终端
4. firefly_rv1126_rv1109
7. firefly_rv1126_rv1109_recovery
8. firefly_rv1126_rv1109_rkmedia_uvcc
3、./build.sh
