CAM-8MS1M摄像头 无法出图
CAM-8MS1M摄像头 无法出图,请教下,使用方式是不是不对:
软件环境: SDK : firefly/rk356x_linux_release_20211019
硬件环境:ROC-RK3568-PC V1.0 2021.05.20 + CAM-8MS1M
[root@RK356X:/]# media-ctl -p -d /dev/media0
Media controller API version 4.19.206
Media device information
driver rkisp-vir0
model rkisp0
serial
bus info
hw revision 0x0
driver version 4.19.206
Device topology
  • entity 1: rkisp-isp-subdev (4 pads, 7 links)
    type V4L2 subdev subtype Unknown flags 0
    device node name /dev/v4l-subdev0
    pad0: Sink
    [fmt:YUYV8_2X8/1920x1080 field:none
    crop.bounds:(0,0)/1920x1080
    crop:(0,0)/1920x1080]
    ← “rkisp-csi-subdev”:1 [ENABLED]
    ← “rkisp_rawrd0_m”:0
    ← “rkisp_rawrd2_s”:0
    pad1: Sink
    ← “rkisp-input-params”:0 [ENABLED]
    pad2: Source
    [fmt:YUYV8_2X8/1920x1080 field:none colorspace:smpte170m quantization:full-range
    → “rkisp_mainpath”:0 [ENABLED]
    → “rkisp_selfpath”:0 [ENABLED]
    pad3: Source
    → “rkisp-statistics”:0 [ENABLED]
  • entity 6: rkisp-csi-subdev (6 pads, 5 links)
    device node name /dev/v4l-subdev1
    pad0: Sink
    [fmt:YUYV8_2X8/1920x1080 field:none]
    ← “rockchip-csi2-dphy0”:1 [ENABLED]
    pad1: Source
    → “rkisp-isp-subdev”:0 [ENABLED]
    pad2: Source
    → “rkisp_rawwr0”:0 [ENABLED]
    pad3: Source
    pad4: Source
    → “rkisp_rawwr2”:0 [ENABLED]
    pad5: Source
    → “rkisp_rawwr3”:0 [ENABLED]
  • entity 13: rkisp_mainpath (1 pad, 1 link)
    type Node subtype V4L flags 0
    device node name /dev/video0
    pad0: Sink
    ← “rkisp-isp-subdev”:2 [ENABLED]
  • entity 19: rkisp_selfpath (1 pad, 1 link)
    device node name /dev/video1
    pad0: Sink
  • entity 25: rkisp_rawwr0 (1 pad, 1 link)
    device node name /dev/video2
    pad0: Sink
    ← “rkisp-csi-subdev”:2 [ENABLED]
  • entity 31: rkisp_rawwr2 (1 pad, 1 link)
    device node name /dev/video3
    pad0: Sink
    ← “rkisp-csi-subdev”:4 [ENABLED]
  • entity 37: rkisp_rawwr3 (1 pad, 1 link)
    device node name /dev/video4
    pad0: Sink
    ← “rkisp-csi-subdev”:5 [ENABLED]
  • entity 43: rkisp_rawrd0_m (1 pad, 1 link)
    device node name /dev/video5
    pad0: Source
  • entity 49: rkisp_rawrd2_s (1 pad, 1 link)
    device node name /dev/video6
    pad0: Source
  • entity 55: rkisp-statistics (1 pad, 1 link)
    device node name /dev/video7
    pad0: Sink
    ← “rkisp-isp-subdev”:3 [ENABLED]
  • entity 61: rkisp-input-params (1 pad, 1 link)
    device node name /dev/video8
    pad0: Source
    → “rkisp-isp-subdev”:1 [ENABLED]
  • entity 67: rockchip-csi2-dphy0 (2 pads, 2 links)
    device node name /dev/v4l-subdev2
    pad0: Sink
    [fmt:YUYV8_2X8/1920x1080@10000/300000 field:none]
    ← “m00_b_xc7160 4-001b”:0 [ENABLED]
    pad1: Source
    → “rkisp-csi-subdev”:0 [ENABLED]
  • entity 70: m00_b_xc7160 4-001b (1 pad, 1 link)
    type V4L2 subdev subtype Sensor flags 0
    device node name /dev/v4l-subdev3
    pad0: Source
    → “rockchip-csi2-dphy0”:0 [ENABLED]
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]# v4l2-ctl -d /dev/video0 --list-formats
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture Multiplanar
    [0]: 'UYVY' (UYVY 4:2:2)
    [1]: '422P' (Planar YUV 4:2:2)
    [2]: 'NV16' (Y/CbCr 4:2:2)
    [3]: 'NV61' (Y/CrCb 4:2:2)
    [4]: 'YM16' (Planar YUV 4:2:2 (N-C))
    [5]: 'NV21' (Y/CrCb 4:2:0)
    [6]: 'NV12' (Y/CbCr 4:2:0)
    [7]: 'NM21' (Y/CrCb 4:2:0 (N-C))
    [8]: 'NM12' (Y/CbCr 4:2:0 (N-C))
    [9]: 'YU12' (Planar YUV 4:2:0)
    [10]: 'YM24' (Planar YUV 4:4:4 (N-C))
    [11]: 'RGGB' (8-bit Bayer RGRG/GBGB)
    [12]: 'GRBG' (8-bit Bayer GRGR/BGBG)
    [13]: 'GBRG' (8-bit Bayer GBGB/RGRG)
    [14]: 'BA81' (8-bit Bayer BGBG/GRGR)
    [15]: 'RG10' (10-bit Bayer RGRG/GBGB)
    [16]: 'BA10' (10-bit Bayer GRGR/BGBG)
    [17]: 'GB10' (10-bit Bayer GBGB/RGRG)
    [18]: 'BG10' (10-bit Bayer BGBG/GRGR)
    [19]: 'RG12' (12-bit Bayer RGRG/GBGB)
    [20]: 'BA12' (12-bit Bayer GRGR/BGBG)
    [21]: 'GB12' (12-bit Bayer GBGB/RGRG)
    [22]: 'BG12' (12-bit Bayer BGBG/GRGR)
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]# v4l2-ctl --verbose -d /dev/video0 --set-selection=target=crop,t
op=0,left=0,width=1920,height=1080 --set-fmt-video=width=1920,height=1080,pixelf
ormat=NV12 --stream-mmap=3 --stream-to=/tmp/nv12.bin --stream-count=10 --stream-
poll
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture Multiplanar:
Width/Height : 1920/1080
Pixel Format : ‘NV12’ (Y/CbCr 4:2:0)
Field : None
Number of planes : 1
Flags :
Colorspace : Default
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Full Range
Plane 0 :
Bytes per Line : 1920
Size Image : 3110400
VIDIOC_G_SELECTION: ok
VIDIOC_S_SELECTION: ok
select timeout
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]# dmesg | grep dphy
[ 0.764373] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.764587] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 2.171349] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_xc7160 4-001b:bus type 4
[ 327.973930] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 327.973978] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 330.940165] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 330.940231] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 1276.083254] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 1276.083304] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 1279.071016] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 1279.071083] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]# dmesg | grep xc7160
[ 2.156066] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 2.156341] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 2.156413] xc7160 4-001b: Looking up avdd-supply from device tree
[ 2.156424] xc7160 4-001b: Looking up avdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.156456] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 2.156539] xc7160 4-001b: Linked as a consumer to regulator.0
[ 2.156559] xc7160 4-001b: Looking up dovdd-supply from device tree
[ 2.156568] xc7160 4-001b: Looking up dovdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.156586] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 2.156633] xc7160 4-001b: Looking up dvdd-supply from device tree
[ 2.156642] xc7160 4-001b: Looking up dvdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.156658] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 2.156719] xc7160 4-001b: could not get default pinstate
[ 2.156736] xc7160 4-001b: could not get sleep pinstate
[ 2.156761] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 2.156776] xc7160 4-001b: xc7160 num data lanes is 4
[ 2.171118] xc7160 4-001b: isp chip is xc7160
[ 4.977753] xc7160 4-001b: isp chip is xc7160
[ 5.008350] xc7160 4-001b: isp chip is xc7160
[ 5.044364] xc7160 4-001b: isp chip is xc7160
[ 5.074432] xc7160 4-001b: isp chip is xc7160
[ 5.834502] xc7160 4-001b: isp chip is xc7160
[ 5.870525] xc7160 4-001b: isp chip is xc7160
[ 318.361127] xc7160 4-001b: isp chip is xc7160
[ 327.964417] xc7160 4-001b: isp chip is xc7160
[ 327.973993] xc7160 4-001b: xc7160 res wxh: 1920x1080@30fps
[ 328.356446] xc7160 4-001b: sensor chip is SC8238
[ 1276.072418] xc7160 4-001b: isp chip is xc7160
[ 1276.083318] xc7160 4-001b: xc7160 res wxh: 1920x1080@30fps
[ 1276.471569] xc7160 4-001b: sensor chip is SC8238
试一下执行这个命令看看能否出图
v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat='NV12' --stream-mmap=4
zyk 发表于 2021-12-14 16:40
试一下执行这个命令看看能否出图
也不行, 没有数据上来,挂在那儿了。
使用官方最新的linux 固件:ROC-RK3568-PC-BUILDROOT-GPT-20211203-0931.img
硬件是:ROC-RK3568-PC V1.0 2021.05.20 + CAM-8MS1M
[root@RK356X:/]# v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,he
ight=1080,pixelformat=‘NV12’ --stream-mmap=4
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Field : None
Flags :
Plane 0 :
^C
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]# uname -a
Linux RK356X 4.19.206 #364 SMP Thu Dec 2 16:12:10 CST 2021 aarch64 GNU/Linux
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]#
[ 0.765047] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.765262] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 2.145452] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_xc7160 4-001b:bus type 4
[ 50.448267] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 50.448314] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 53.524465] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 53.524539] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 256.414795] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 256.414841] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 259.443922] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 259.443941] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 585.753559] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 585.753609] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 618.069090] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 618.069155] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 637.641224] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 637.641274] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 640.549567] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 640.549633] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 1054.010967] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 1054.011013] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 1100.842240] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 1100.842305] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 1139.324038] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 1139.324087] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 1149.935915] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 1149.935983] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 1182.080932] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 1182.080980] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 1211.909799] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 1211.909865] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[root@RK356X:/]#
还请指教,谢谢。
试一下烧写最新的Android固件看能否出图,排除一下硬件问题。https://www.t-firefly.com/doc/download/107.html#other_474
zyk 发表于 2021-12-14 17:00
试一下烧写最新的Android固件看能否出图,排除一下硬件问题。https://www.t-firefly.com/doc/download/107. …
软件 : ROC-RK3568-PC_Android11_HDMI_211119
C:\Users\admin>
C:\Users\admin>
C:\Users\admin>
C:\Users\admin>adb root
C:\Users\admin>adb shell
rk3568_firefly_roc_pc:/ $
rk3568_firefly_roc_pc:/ $ uname -a
Linux localhost 4.19.193 #23 SMP PREEMPT Fri Nov 19 14:42:03 CST 2021 aarch64
rk3568_firefly_roc_pc:/ $ media-ctl -p -d /dev/media0
Opening media device /dev/media0
media_open_debug: Can’t open media device /dev/media0
Failed to open /dev/media0
1|rk3568_firefly_roc_pc:/ $ v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=‘NV12’ --stream-mmap=4
Failed to open /dev/video0: Permission denied
请教下,怎么进入ROOT,没有限访问相机,谢谢。
vm回车,如果有屏可以接上显示屏通过相机应用打开
仍然接收不到数据
1|rk3568_firefly_roc_pc:/ $ vm
:confused: #
:confused: #
:confused: #
:confused: #
ideo=width=1920,height=1080,pixelformat=‘NV12’ --stream-mmap=4 <
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Field : None
Flags :
YCbCr Encoding : Default
Plane 0 :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
^C
130|:confused: #
130|:confused: # dmesg | grep xc7
[ 1.164569] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 1.165240] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 1.165510] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 1.165681] xc7160 4-001b: Linked as a consumer to regulator.0
[ 1.165744] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 1.165832] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 1.165900] xc7160 4-001b: could not get default pinstate
[ 1.165916] xc7160 4-001b: could not get sleep pinstate
[ 1.165946] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 1.165955] xc7160 4-001b: xc7160 num data lanes is 4
[ 1.181917] xc7160 4-001b: isp chip is xc7160
[ 1.182304] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_xc7160 4-001b:bus type 4
[ 6.215421] xc7160 4-001b: isp chip is xc7160
[ 6.253708] xc7160 4-001b: isp chip is xc7160
[ 6.291981] xc7160 4-001b: isp chip is xc7160
[ 6.321435] xc7160 4-001b: isp chip is xc7160
[ 6.358513] xc7160 4-001b: isp chip is xc7160
[ 6.388396] xc7160 4-001b: isp chip is xc7160
[ 6.421957] xc7160 4-001b: isp chip is xc7160
[ 6.455135] xc7160 4-001b: isp chip is xc7160
[ 6.488075] xc7160 4-001b: isp chip is xc7160
[ 6.521691] xc7160 4-001b: isp chip is xc7160
[ 6.555126] xc7160 4-001b: isp chip is xc7160
[ 6.588425] xc7160 4-001b: isp chip is xc7160
[ 443.881760] xc7160 4-001b: isp chip is xc7160
[ 443.901016] xc7160 4-001b: xc7160 res wxh: 1920x1080@30fps
[ 444.163612] xc7160 4-001b: sensor chip is SC8238
:confused: #
:confused: # dmesg | grep dphy
[ 0.187922] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.188049] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 443.900949] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 443.901001] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 478.914124] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 478.914188] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
:confused: #
检查一下排线有没有问题。重新连接一下摄像头,不行把dmesg完整的log发出来看一下
LOG 如下,请参考,谢谢。
已经换了根短排线。
C:\Users\admin>
C:\Users\admin>
C:\Users\admin>
C:\Users\admin>
:confused: #
:confused: #
:confused: #
ideo=width=1920,height=1080,pixelformat=‘NV12’ --stream-mmap=4 --stream-poll <
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Field : None
Flags :
Plane 0 :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
select timeout
:confused: #
:confused: #
:confused: #
:confused: # dmesg > dmesg.log
sh: can’t create dmesg.log: Read-only file system
1|:confused: #
1|:confused: #
1|:confused: #
1|:confused: # dmesg
[ 0.000000] Linux version 4.19.193 (zhongwei@tchip-server15) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #23 SMP PREEMPT Fri Nov 19 14:42:03 CST 2021
[ 0.000000] Machine model: ROC-RK3568-PC HDMI (Android)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options ‘’)
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000010000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 1043968
[ 0.000000] DMA32 zone: 15288 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 978432 pages, LIFO batch:63
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 65536 pages, LIFO batch:15
[ 0.000000] percpu: Embedded 24 pages/cpu s58968 r8192 d31144 u98304
[ 0.000000] pcpu-alloc: s58968 r8192 d31144 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtb_idx=0 androidboot.dtbo_idx=0 androidboot.verifiedbootstate=orange androidboot.slot_suffix= androidboot.serialno=LBVNPNVC7Y console=ttyFIQ0 androidboot.baseband=N/A androidboot.wificountrycode=CN androidboot.veritymode=enforcing androidboot.hardware=rk30board androidboot.console=ttyFIQ0 androidboot.verifiedbootstate=orange firmware_class.path=/vendor/etc/firmware init=/init rootwait ro loop.max_part=7 androidboot.selinux=permissive buildvariant=userdebug earlycon=uart8250,mmio32,0xfe660000 androidboot.boot_devices=fe310000.sdhci,usbhost/fd000000.dwc3/xhci-hcd.5.auto,fd880000.usb,fd800000.usb,fe2b0000.dwmmc,fc800000.sata,3c0800000.pcie,3c0000000.pcie
[ 0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB)
[ 0.000000] Memory: 3977260K/4175872K available (15166K kernel code, 2052K rwdata, 9104K rodata, 4032K init, 926K bss, 190420K reserved, 8192K cma-reserved)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: \x09RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] \x09Tasks RCU enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @210000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @220000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x0000000000230000
[ 0.000000] CPU0: using LPI pending table @0x0000000000240000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x4f0 with crng_init=0
[ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001643] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002603] pid_max: default: 32768 minimum: 301
[ 0.003113] Security Framework initialized
[ 0.003501] SELinux: Initializing.
[ 0.003911] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004545] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006440] ASID allocator initialised with 32768 entries
[ 0.007037] rcu: Hierarchical SRCU implementation.
[ 0.007835] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.008850] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.010282] smp: Bringing up secondary CPUs …
[ 0.011175] Detected VIPT I-cache on CPU1
[ 0.011203] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.011238] CPU1: using LPI pending table @0x0000000000250000
[ 0.011276] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.011819] Detected VIPT I-cache on CPU2
[ 0.011841] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.011874] CPU2: using LPI pending table @0x0000000000260000
[ 0.011903] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.012468] Detected VIPT I-cache on CPU3
[ 0.012486] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.012518] CPU3: using LPI pending table @0x0000000000270000
[ 0.012546] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.012625] smp: Brought up 1 node, 4 CPUs
[ 0.019518] SMP: Total of 4 processors activated.
[ 0.019958] CPU features: detected: GIC system register CPU interface
[ 0.020555] CPU features: detected: Privileged Access Never
[ 0.021072] CPU features: detected: LSE atomic instructions
[ 0.021588] CPU features: detected: User Access Override
[ 0.022082] CPU features: detected: 32-bit EL0 Support
[ 0.022559] CPU features: detected: RAS Extension Support
[ 0.030119] CPU: All CPU(s) started at EL2
[ 0.030527] alternatives: patching kernel code
[ 0.035030] devtmpfs: initialized
[ 0.050885] Trying to unpack rootfs image as initramfs…
[ 0.051411] Registered cp15_barrier emulation handler
[ 0.051423] Registered setend emulation handler
[ 0.051716] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.053222] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.053927] pinctrl core: initialized pinctrl subsystem
[ 0.055249] NET: Registered protocol family 16
[ 0.061658] schedtune: configured to support 6 boost groups
[ 0.062297] audit: initializing netlink subsys (disabled)
[ 0.062960] audit: type=2000 audit(0.059:1): state=initialized audit_enabled=0 res=1
[ 0.064953] cpuidle: using governor menu
[ 0.065347] Registered FIQ tty driver
[ 0.066275] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.067135] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.070249] console [pstore-1] enabled
[ 0.070801] pstore: Registered ramoops as persistent store backend
[ 0.071378] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.074739] Freeing initrd memory: 804K
[ 0.092027] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.093006] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.093953] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.094905] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.095878] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.096539] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.105722] cryptd: max_cpu_qlen set to 1000
[ 0.107712] console [ttyFIQ0] enabled
[ 0.108408] bootconsole [uart8250] disabled
[ 0.108980] Registered fiq debugger ttyFIQ0
[ 0.109703] vcc3v3_sys: supplied by dc_12v
[ 0.109947] vcc5v0_sys: supplied by dc_12v
[ 0.110165] vcc5v0_usb: supplied by dc_12v
[ 0.110499] vcc5v0_host: supplied by vcc5v0_usb
[ 0.110749] vcc3v3_lcd0_n: supplied by vcc3v3_sys
[ 0.110998] vcc3v3_lcd1_n: supplied by vcc3v3_sys
[ 0.111238] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.111483] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.111707] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.111984] vcc3v3_pcie: supplied by dc_12v
[ 0.112226] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.113370] rk_iommu fde4b000.iommu: version = 2
[ 0.113772] rk_iommu fdea0800.iommu: version = 2
[ 0.114057] rk_iommu fded0480.iommu: version = 2
[ 0.114239] rk_iommu fdee0800.iommu: version = 2
[ 0.114420] rk_iommu fdef0800.iommu: version = 2
[ 0.114605] rk_iommu fdf40f00.iommu: version = 2
[ 0.114812] rk_iommu fdf80800.iommu: version = 2
[ 0.114998] rk_iommu fdff1a00.iommu: version = 2
[ 0.115198] rk_iommu fe043e00.iommu: version = 2
[ 0.115790] SCSI subsystem initialized
[ 0.115841] libata version 3.00 loaded.
[ 0.115981] usbcore: registered new interface driver usbfs
[ 0.116031] usbcore: registered new interface driver hub
[ 0.116072] usbcore: registered new device driver usb
[ 0.116414] media: Linux media interface: v0.10
[ 0.116449] videodev: Linux video capture interface: v2.00
[ 0.116514] pps_core: LinuxPPS API ver. 1 registered
[ 0.116528] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.116552] PTP clock support registered
[ 0.116773] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 0.118842] Advanced Linux Sound Architecture Driver Initialized.
[ 0.119226] Bluetooth: Core ver 2.22
[ 0.119278] NET: Registered protocol family 31
[ 0.119292] Bluetooth: HCI device and connection manager initialized
[ 0.119309] Bluetooth: HCI socket layer initialized
[ 0.119324] Bluetooth: L2CAP socket layer initialized
[ 0.119374] Bluetooth: SCO socket layer initialized
[ 0.119720] rockchip-cpuinfo cpuinfo: SoC\x09\x09: 35681000
[ 0.119738] rockchip-cpuinfo cpuinfo: Serial\x09\x09: 4ec326ac7f10d45d
[ 0.120697] clocksource: Switched to clocksource arch_sys_counter
[ 0.171618] VFS: Disk quotas dquot_6.6.0
[ 0.171708] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.172796] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.173094] NET: Registered protocol family 2
[ 0.173573] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.173619] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.173805] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.174215] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.174342] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.174404] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.174576] NET: Registered protocol family 1
[ 0.175191] PCI: CLS 0 bytes, default 64
[ 0.176724] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.178173] Initialise system trusted keyrings
[ 0.178394] workingset: timestamp_bits=45 max_order=20 bucket_order=0
[ 0.182388] utf8_selftest: All 154 tests passed
[ 0.182413] fuse init (API version 7.27)
[ 0.183481] \x0aTEE Core Framework initialization (ver 1:0.1)
[ 0.183513] TEE armv7 Driver initialization
[ 0.183964] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.183985] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.184180] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.185331] Key type asymmetric registered
[ 0.185349] Asymmetric key parser ‘x509’ registered
[ 0.185392] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.185408] io scheduler noop registered
[ 0.185527] io scheduler cfq registered (default)
[ 0.185544] io scheduler mq-deadline registered
[ 0.185556] io scheduler kyber registered
[ 0.185639] io scheduler bfq registered
[ 0.186448] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.186575] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.188005] phy phy-fe8b0000.usb2-phy.0: Linked as a consumer to regulator.5
[ 0.188124] phy phy-fe8b0000.usb2-phy.1: Linked as a consumer to regulator.5
[ 0.188206] phy phy-fe8b0000.usb2-phy.1: No vbus specified for otg port
[ 0.194315] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.11
[ 0.194642] iep: Module initialized.
[ 0.194709] mpp_service mpp-srv: 47b12149d90 author: Firefly 2021-11-19 aosp update to android-11.0.0_r39
[ 0.194727] mpp_service mpp-srv: probe start
[ 0.195364] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.195395] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.195557] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.195927] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.195944] rkvenc_init:1199: failed to add venc devfreq
[ 0.196988] iommu: Adding device fdea0400.vdpu to group 1
[ 0.197013] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.197143] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.197642] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.198095] iommu: Adding device fdee0000.vepu to group 3
[ 0.198127] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.198269] mpp_vepu2 fdee0000.vepu: probe device
[ 0.198695] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.199118] iommu: Adding device fdef0000.iep to group 4
[ 0.199147] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.199252] mpp-iep2 fdef0000.iep: probe device
[ 0.199602] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.199737] mpp-iep2 fdef0000.iep: probing finish
[ 0.200132] iommu: Adding device fded0000.jpegd to group 2
[ 0.200155] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.200258] mpp_jpgdec fded0000.jpegd: probe device
[ 0.200680] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.201139] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.201169] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.201342] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.201472] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.201729] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.201747] rkvdec2_init:661: No niu aclk reset resource define
[ 0.201763] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.201774] rkvdec2_init:664: No niu hclk reset resource define
[ 0.201908] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.201926] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.201940] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.201951] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 0.201965] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.202009] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 0.202067] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.202339] mpp_service mpp-srv: probe success
[ 0.206544] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.206580] dma-pl330 fe530000.dmac: \x09DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.208133] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.208156] dma-pl330 fe550000.dmac: \x09DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.209312] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.210130] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.210767] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 66, base_baud = 1500000) is a 16550A
[ 0.211176] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 67, base_baud = 1500000) is a 16550A
[ 0.211529] fe6b0000.serial: ttyS7 at MMIO 0xfe6b0000 (irq = 68, base_baud = 1500000) is a 16550A
[ 0.211873] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 69, base_baud = 1500000) is a 16550A
[ 0.212219] fe6d0000.serial: ttyS9 at MMIO 0xfe6d0000 (irq = 70, base_baud = 1500000) is a 16550A
[ 0.213777] random: fast init done
[ 0.214148] iommu: Adding device fe040000.vop to group 8
[ 0.214185] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.216514] random: crng init done
[ 0.216530] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.216540] rk-pcie 3c0800000.pcie: Missing config reg space
[ 0.216566] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.216612] rk-pcie 3c0800000.pcie: err 0x380000000..0x3807fffff → 0x80000000
[ 0.216651] rk-pcie 3c0800000.pcie: IO 0x380800000..0x3808fffff → 0x80800000
[ 0.216679] rk-pcie 3c0800000.pcie: MEM 0x380900000..0x3bfffffff → 0x80900000
[ 0.217435] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.218240] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.219557] rockchip-drm display-subsystem: defer getting devfreq
[ 0.219789] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4
[ 0.219812] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1
[ 0.219831] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.220202] [drm] unsupported AFBC format[3432564e]
[ 0.220413] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops)
[ 0.220581] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.221079] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.221513] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.221534] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.221543] [drm] No driver support for vblank timestamp query.
[ 0.221805] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 0.221829] rockchip-drm display-subsystem: can’t not find any loader display
[ 0.221848] rockchip-drm display-subsystem: failed to show loader logo
[ 0.222437] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.228673] mali fde60000.gpu: Kernel DDK version g2p0-01eac0
[ 0.228773] mali fde60000.gpu: Power management initialization failed error = -517
[ 0.228801] mali fde60000.gpu: Device initialization Deferred
[ 0.229164] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.234761] brd: module loaded
[ 0.245440] loop: module loaded
[ 0.245800] zram: Added device: zram0
[ 0.246499] SCSI Media Changer driver v0.25
[ 0.247547] ahci fc800000.sata: forcing port_map 0x0 → 0x1
[ 0.247595] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 0.247607] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 0.247627] ahci fc800000.sata: port 0 is not capable of FBS
[ 0.248214] scsi host0: ahci
[ 0.248482] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 11
[ 0.249716] register firefly_spi_init spi return v = :0
[ 0.250240] libphy: Fixed MDIO Bus: probed
[ 0.250272] tun: Universal TUN/TAP device driver, 1.6
[ 0.250445] CAN device driver interface
[ 0.252475] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 0.252506] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 0.252521] rk_gmac-dwmac fe010000.ethernet: TX delay(0x3e).
[ 0.252535] rk_gmac-dwmac fe010000.ethernet: RX delay(0x32).
[ 0.252551] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 0.252591] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 0.257606] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 0.257656] rk_gmac-dwmac fe010000.ethernet: [stmmac_dvr_probe-4333]led_status_value = 0x6940
[ 0.257843] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.257864] rk_gmac-dwmac fe010000.ethernet: \x09DWMAC4/5
[ 0.257886] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 0.257895] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 0.257901] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 0.257909] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 0.257943] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 0.257957] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.257971] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 0.390716] libphy: stmmac: probed
[ 0.392026] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 0.392050] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 0.392060] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x4a).
[ 0.392067] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2e).
[ 0.392077] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 0.392108] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 0.397130] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 0.397182] rk_gmac-dwmac fe2a0000.ethernet: [stmmac_dvr_probe-4333]led_status_value = 0x6940
[ 0.397386] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.397410] rk_gmac-dwmac fe2a0000.ethernet: \x09DWMAC4/5
[ 0.397427] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 0.397441] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 0.397453] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 0.397464] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 0.397496] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 0.397510] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.397524] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 0.530712] libphy: stmmac: probed
[ 0.530994] phy_rtl8211f_led_fixup in
[ 0.552418] PPP generic driver version 2.4.2
[ 0.552588] PPP BSD Compression module registered
[ 0.552604] PPP Deflate Compression module registered
[ 0.552636] PPP MPPE Compression module registered
[ 0.552649] NET: Registered protocol family 24
[ 0.552677] PPTP driver version 0.8.5
[ 0.552912] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.552919] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.552993] usbcore: registered new interface driver catc
[ 0.553048] usbcore: registered new interface driver kaweth
[ 0.553063] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.553114] usbcore: registered new interface driver pegasus
[ 0.553160] usbcore: registered new interface driver rtl8150
[ 0.553202] usbcore: registered new interface driver r8152
[ 0.553215] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.553272] usbcore: registered new interface driver hso
[ 0.553317] usbcore: registered new interface driver asix
[ 0.553359] usbcore: registered new interface driver ax88179_178a
[ 0.553401] usbcore: registered new interface driver cdc_ether
[ 0.553442] usbcore: registered new interface driver cdc_eem
[ 0.553486] usbcore: registered new interface driver dm9601
[ 0.553531] usbcore: registered new interface driver smsc75xx
[ 0.553576] usbcore: registered new interface driver smsc95xx
[ 0.553616] usbcore: registered new interface driver gl620a
[ 0.553662] usbcore: registered new interface driver net1080
[ 0.553695] usbcore: registered new interface driver plusb
[ 0.553737] usbcore: registered new interface driver rndis_host
[ 0.553778] usbcore: registered new interface driver cdc_subset
[ 0.553819] usbcore: registered new interface driver zaurus
[ 0.553863] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.553909] usbcore: registered new interface driver int51x1
[ 0.553946] usbcore: registered new interface driver kalmia
[ 0.553989] usbcore: registered new interface driver ipheth
[ 0.554057] usbcore: registered new interface driver sierra_net
[ 0.554108] usbcore: registered new interface driver cx82310_eth
[ 0.554155] usbcore: registered new interface driver cdc_ncm
[ 0.554190] usbcore: registered new interface driver qmi_wwan_q
[ 0.554232] usbcore: registered new interface driver qmi_wwan
[ 0.554277] usbcore: registered new interface driver cdc_mbim
[ 0.555330] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 0.556056] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 0.557762] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.557772] ehci-pci: EHCI PCI platform driver
[ 0.557827] ehci-platform: EHCI generic platform driver
[ 0.560049] ehci-platform fd800000.usb: EHCI Host Controller
[ 0.560216] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 0.560341] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[ 0.560424] ata1: SATA link down (SStatus 0 SControl 300)
[ 0.570722] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 0.570878] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.570896] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.570909] usb usb1: Product: EHCI Host Controller
[ 0.570921] usb usb1: Manufacturer: Linux 4.19.193 ehci_hcd
[ 0.570933] usb usb1: SerialNumber: fd800000.usb
[ 0.571294] hub 1-0:1.0: USB hub found
[ 0.571334] hub 1-0:1.0: 1 port detected
[ 0.573764] ehci-platform fd880000.usb: EHCI Host Controller
[ 0.573914] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 0.574016] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000
[ 0.587386] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 0.587529] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.587547] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.587564] usb usb2: Product: EHCI Host Controller
[ 0.587577] usb usb2: Manufacturer: Linux 4.19.193 ehci_hcd
[ 0.587590] usb usb2: SerialNumber: fd880000.usb
[ 0.587932] hub 2-0:1.0: USB hub found
[ 0.587973] hub 2-0:1.0: 1 port detected
[ 0.588588] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.588619] ohci-platform: OHCI generic platform driver
[ 0.588826] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 0.588978] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 0.589094] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000
[ 0.648181] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.648199] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.648207] usb usb3: Product: Generic Platform OHCI controller
[ 0.648214] usb usb3: Manufacturer: Linux 4.19.193 ohci_hcd
[ 0.648220] usb usb3: SerialNumber: fd840000.usb
[ 0.648554] hub 3-0:1.0: USB hub found
[ 0.648594] hub 3-0:1.0: 1 port detected
[ 0.648972] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 0.649131] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 0.649243] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[ 0.708186] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.708204] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.708212] usb usb4: Product: Generic Platform OHCI controller
[ 0.708219] usb usb4: Manufacturer: Linux 4.19.193 ohci_hcd
[ 0.708225] usb usb4: SerialNumber: fd8c0000.usb
[ 0.708555] hub 4-0:1.0: USB hub found
[ 0.708600] hub 4-0:1.0: 1 port detected
[ 0.709921] usbcore: registered new interface driver cdc_acm
[ 0.709930] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.709984] usbcore: registered new interface driver usblp
[ 0.710040] usbcore: registered new interface driver cdc_wdm
[ 0.710275] usbcore: registered new interface driver uas
[ 0.710358] usbcore: registered new interface driver usb-storage
[ 0.710405] usbcore: registered new interface driver ums-alauda
[ 0.710449] usbcore: registered new interface driver ums-cypress
[ 0.710495] usbcore: registered new interface driver ums-datafab
[ 0.710539] usbcore: registered new interface driver ums_eneub6250
[ 0.710586] usbcore: registered new interface driver ums-freecom
[ 0.710630] usbcore: registered new interface driver ums-isd200
[ 0.710665] usbcore: registered new interface driver ums-jumpshot
[ 0.710728] usbcore: registered new interface driver ums-karma
[ 0.710773] usbcore: registered new interface driver ums-onetouch
[ 0.710818] usbcore: registered new interface driver ums-sddr09
[ 0.710862] usbcore: registered new interface driver ums-sddr55
[ 0.710906] usbcore: registered new interface driver ums-usbat
[ 0.710987] usbcore: registered new interface driver usbserial_generic
[ 0.711018] usbserial: USB Serial support registered for generic
[ 0.711066] usbcore: registered new interface driver option
[ 0.711094] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.711234] usbcore: registered new interface driver trancevibrator
[ 0.711777] usbcore: registered new interface driver xpad
[ 0.711829] usbcore: registered new interface driver usb_acecad
[ 0.711874] usbcore: registered new interface driver aiptek
[ 0.711920] usbcore: registered new interface driver gtco
[ 0.711970] usbcore: registered new interface driver hanwang
[ 0.712017] usbcore: registered new interface driver kbtab
[ 0.712097] [HXTP] himax_hx83102_init
[ 0.712104] [HXTP] himax_hx83102_probe:Enter
[ 0.712116] [HXTP] Himax common touch panel driver init
[ 0.712173] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 0.712190] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 0.712541] .. rk pwm remotectl v2.0 init
[ 0.712761] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 0.713056] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[ 0.713107] remotectl-pwm fe6e0030.pwm: Controller support pwrkey capture
[ 0.714439] i2c /dev entries driver
[ 0.716204] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 0.719430] vdd_cpu: supplied by vcc5v0_sys
[ 0.721222] rk808 0-0020: chip id: 0x8090
[ 0.721265] rk808 0-0020: No cache defaults, reading back from HW
[ 0.744917] rk808 0-0020: source: on=0x40, off=0x00
[ 0.744938] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 0.744948] rk808 0-0020: support pmic reset mode:0,0
[ 0.749600] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.749641] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.750200] vdd_logic: supplied by vcc3v3_sys
[ 0.750862] vdd_gpu: supplied by vcc3v3_sys
[ 0.751092] vcc_ddr: supplied by vcc3v3_sys
[ 0.751331] vdd_npu: supplied by vcc3v3_sys
[ 0.751907] vcc_1v8: supplied by vcc3v3_sys
[ 0.752133] vdda0v9_image: supplied by vcc3v3_sys
[ 0.752710] vdda_0v9: supplied by vcc3v3_sys
[ 0.752936] vdda0v9_pmu: supplied by vcc3v3_sys
[ 0.753169] vccio_acodec: supplied by vcc3v3_sys
[ 0.753737] vccio_sd: supplied by vcc3v3_sys
[ 0.753971] vcc3v3_pmu: supplied by vcc3v3_sys
[ 0.754563] vcca_1v8: supplied by vcc3v3_sys
[ 0.754807] vcca1v8_pmu: supplied by vcc3v3_sys
[ 0.755048] vcca1v8_image: supplied by vcc3v3_sys
[ 0.755611] vcc_3v3: supplied by vcc3v3_sys
[ 0.756158] vcc3v3_sd: supplied by vcc3v3_sys
[ 0.756407] rk817-battery rk817-battery: Failed to find matching dt id
[ 0.756607] rk817-charger rk817-charger: Failed to find matching dt id
[ 0.759588] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 0.759937] rk808-rtc rk808-rtc: device is disabled
[ 0.759961] rk808-rtc: probe of rk808-rtc failed with error -22
[ 0.760829] fusb302 0-0022: Can’t get property of role, set role to default DRP
[ 0.769596] fusb302 0-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 0.769715] input: Typec_Headphone as /devices/platform/fdd40000.i2c/i2c-0/0-0022/input/input2
[ 0.778767] rtc-hym8563 5-0051: rtc core: registered hym8563 as rtc0
[ 0.779803] rtc-hym8563 5-0051: setting system clock to 2021-12-14 09:24:19 UTC (1639473859)
[ 0.781195] gsensor_mc3230 5-004c: sensor_register_device: gs_mc3230, id = 27
[ 0.781219] i2c i2c-5: sensor_probe: gs_mc3230,0000000056824fb1
[ 0.781249] gsensor_mc3230 5-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x0000000044ffae00
[ 0.820854] [Gsensor] init_3230_ctl_data 457 : error: -6
[ 0.820873] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor
[ 0.820880] gsensor_mc3230 5-004c: sensor_chip_init:fail to init sensor
[ 0.820888] i2c i2c-5: sensor_probe failed -2\x0a
[ 0.822879] iommu: Adding device fdff0000.rkisp to group 7
[ 0.822916] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[ 0.823081] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 0.823092] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 0.823121] rkisp_hw fdff0000.rkisp: can’t request region for resource [mem 0xfdff0000-0xfdffffff]
[ 0.823775] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[ 0.823866] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 0.824061] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 0.824078] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 0.825593] usbcore: registered new interface driver uvcvideo
[ 0.825614] USB Video Class driver (1.1.1)
[ 0.825875] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.26
[ 0.825910] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 0.825988] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 0.826054] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.24
[ 0.826085] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 0.826192] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.25
[ 0.826223] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 0.826282] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.20
[ 0.826312] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 0.826389] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.30
[ 0.826420] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 0.826507] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 0.826593] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 0.827915] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 0.828066] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 0.828274] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.828357] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 0.830389] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 0.831366] device-mapper: uevent: version 1.0.3
[ 0.831580] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 0.831769] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 0.831782] Bluetooth: HCI UART driver ver 2.3
[ 0.831790] Bluetooth: HCI UART protocol H4 registered
[ 0.832044] cpu cpu0: leakage=28
[ 0.832640] cpu cpu0: Linked as a consumer to regulator.15
[ 0.837500] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 0.848372] cpu cpu0: temp=31875, pvtm=87919 (88153 + -234)
[ 0.848512] cpu cpu0: Dropping the link to regulator.15
[ 0.848551] cpu cpu0: pvtm-volt-sel=1
[ 0.849596] cpu cpu0: Linked as a consumer to regulator.15
[ 0.849637] cpu cpu0: Dropping the link to regulator.15
[ 0.850526] cpu cpu0: Linked as a consumer to regulator.15
[ 0.851190] cpu cpu0: avs=0
[ 0.851241] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[ 0.851411] energy_model: Created perf domain 0-3
[ 0.851438] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 0.855750] cpu cpu0: failed to find power_model node
[ 0.856969] sdhci: Secure Digital Host Controller Interface driver
[ 0.856992] sdhci: Copyright(c) Pierre Ossman
[ 0.856999] Synopsys Designware Multimedia Card Interface Driver
[ 0.857846] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.857893] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 0.857911] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 0.857959] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 0.858078] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 0.858097] mmc_host mmc3: card is non-removable.
[ 0.977782] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 0.985275] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[ 0.985295] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.985303] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 0.985963] hub 2-1:1.0: USB hub found
[ 0.986110] hub 2-1:1.0: 4 ports detected
[ 0.990993] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.991063] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 0.991081] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 0.991131] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 51,32 bit host data width,256 deep fifo
[ 0.991228] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.31
[ 0.991290] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.25
[ 1.004353] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.004984] fusb302 0-0022: CC connected in CC1 as UFP
[ 1.017314] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.018533] mmc2: Unknown controller version (5). You may experience problems.
[ 1.024936] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.026745] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.028688] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.032071] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.049772] mmc2: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 1.051620] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.054371] usbcore: registered new interface driver usbhid
[ 1.054394] usbhid: USB HID core driver
[ 1.054478] ion_device_add_heap: ion_system_contig_heap id=0 type=1
[ 1.054487] orders[0] = 6
[ 1.054499] orders[1] = 4
[ 1.054513] orders[2] = 0
[ 1.054754] ion_device_add_heap: ion_system_heap id=1 type=0
[ 1.054792] ion_device_add_heap: linux,cma id=2 type=4
[ 1.055078] ashmem: initialized
[ 1.055407] rockchip,bus bus-npu: Linked as a consumer to regulator.16
[ 1.055433] rockchip,bus bus-npu: Failed to get leakage
[ 1.055513] rockchip,bus bus-npu: pvtm = 87919, form pvtm_value
[ 1.055533] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 1.055720] rockchip,bus bus-npu: avs=0
[ 1.059008] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.27
[ 1.059506] optee: probing for conduit method from DT.
[ 1.059541] optee: revision 3.6 (0b06ae94)
[ 1.059821] optee: initialized driver
[ 1.059841] rksfc_base v1.1 2016-01-08
[ 1.060559] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 1.060619] rkflash_dev_init enter
[ 1.060643] sfc nor id: ff ff ff
[ 1.060655] rkflash[1] is invalid
[ 1.061202] usbcore: registered new interface driver snd-usb-audio
[ 1.063293] rk817-codec rk817-codec: DMA mask not set
[ 1.063999] rk817_codec_parse_dt_property: rk809 have no io-channels defined
[ 1.064063] invalid rk817->hp_det_gpio: -2
[ 1.064083] invalid gpio: -2
[ 1.070259] netem: version 1.3
[ 1.070347] u32 classifier
[ 1.070459] Actions configured
[ 1.072321] xt_time: kernel timezone is -0000
[ 1.072633] gre: GRE over IPv4 demultiplexor driver
[ 1.072680] IPv4 over IPsec tunneling driver
[ 1.074482] Initializing XFRM netlink socket
[ 1.074530] IPsec XFRM device driver
[ 1.074964] NET: Registered protocol family 10
[ 1.076283] Segment Routing with IPv6
[ 1.076451] mip6: Mobile IPv6
[ 1.077277] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.078314] NET: Registered protocol family 17
[ 1.078372] NET: Registered protocol family 15
[ 1.078436] Bridge firewalling registered
[ 1.078525] can: controller area network core (rev 20170425 abi 9)
[ 1.078637] NET: Registered protocol family 29
[ 1.078662] can: raw protocol (rev 20170425)
[ 1.078670] can: broadcast manager protocol (rev 20170425 t)
[ 1.078684] can: netlink gateway (rev 20170425) max_hops=1
[ 1.078956] Bluetooth: RFCOMM TTY layer initialized
[ 1.078981] Bluetooth: RFCOMM socket layer initialized
[ 1.079021] Bluetooth: RFCOMM ver 1.11
[ 1.079043] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.079055] Bluetooth: BNEP filters: protocol multicast
[ 1.079071] Bluetooth: BNEP socket layer initialized
[ 1.079085] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.079099] Bluetooth: HIDP socket layer initialized
[ 1.079133] l2tp_core: L2TP core driver, V2.0
[ 1.079151] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.079158] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.079163] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.079680] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.079724] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 1.079738] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.079749] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.079785] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 1.079802] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.079813] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.079830] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 1.079835] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.080399] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 1.080435] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96.
[ 1.080458] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 98.
[ 1.080477] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 97.
[ 1.080541] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.080636] [BT_RFKILL]: ** disable irq
[ 1.080791] [BT_RFKILL]: bt_default device registered.
[ 1.081167] flash vendor_init_thread!
[ 1.081183] flash vendor storage:20170308 ret = -1
[ 1.083064] mmc2: new HS200 MMC card at address 0001
[ 1.083277] registered taskstats version 1
[ 1.083295] Loading compiled-in X.509 certificates
[ 1.083407] Key type ._fscrypt registered
[ 1.083424] Key type .fscrypt registered
[ 1.083437] Key type fscrypt-provisioning registered
[ 1.083908] mmcblk2: mmc2:0001 Y2P032 29.1 GiB
[ 1.084152] pstore: Using compression: deflate
[ 1.084600] mmcblk2boot0: mmc2:0001 Y2P032 partition 1 4.00 MiB
[ 1.085174] mmcblk2boot1: mmc2:0001 Y2P032 partition 2 4.00 MiB
[ 1.085413] mmcblk2rpmb: mmc2:0001 Y2P032 partition 3 16.0 MiB, chardev (237:0)
[ 1.085555] rga2: Driver loaded successfully ver:3.2.63318
[ 1.085954] rga2: Module initialized.
[ 1.088202] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 1.111828] phy phy-fe8a0000.usb2-phy.6: Linked as a consumer to regulator.5
[ 1.112064] phy phy-fe8a0000.usb2-phy.7: No vbus specified for otg port
[ 1.113188] mpp_rkvenc fdf40000.rkvenc: probing start
[ 1.113740] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to regulator.16
[ 1.113812] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[ 1.113870] mpp_rkvenc fdf40000.rkvenc: pvtm = 87919, form pvtm_value
[ 1.113890] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[ 1.114124] mpp_rkvenc fdf40000.rkvenc: avs=0
[ 1.114294] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node
[ 1.114305] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model
[ 1.114312] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient
[ 1.114613] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 1.115015] mali fde60000.gpu: Kernel DDK version g2p0-01eac0
[ 1.115220] mali fde60000.gpu: Linked as a consumer to regulator.17
[ 1.115329] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 1.115418] mali fde60000.gpu: leakage=8
[ 1.115919] mali fde60000.gpu: avs=0
[ 1.115938] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 1.116159] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 1.116232] mali fde60000.gpu: No memory group manager is configured
[ 1.116647] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.117267] mali fde60000.gpu: Probed as mali0
[ 1.117681] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.119213] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 1.121054] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.124866] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 1.125089] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 5
[ 1.125240] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 1.125287] xhci-hcd xhci-hcd.5.auto: irq 85, io mem 0xfd000000
[ 1.125535] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.125549] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.125559] usb usb5: Product: xHCI Host Controller
[ 1.125569] usb usb5: Manufacturer: Linux 4.19.193 xhci-hcd
[ 1.125578] usb usb5: SerialNumber: xhci-hcd.5.auto
[ 1.125935] hub 5-0:1.0: USB hub found
[ 1.125975] hub 5-0:1.0: 1 port detected
[ 1.126183] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 1.126302] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 6
[ 1.126321] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[ 1.126384] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.126579] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.126592] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.126603] usb usb6: Product: xHCI Host Controller
[ 1.126612] usb usb6: Manufacturer: Linux 4.19.193 xhci-hcd
[ 1.126618] usb usb6: SerialNumber: xhci-hcd.5.auto
[ 1.126936] hub 6-0:1.0: USB hub found
[ 1.126985] hub 6-0:1.0: 1 port detected
[ 1.127727] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 1.128304] rockchip-dmc dmc: Linked as a consumer to regulator.16
[ 1.128386] rockchip-dmc dmc: leakage=55
[ 1.128404] rockchip-dmc dmc: leakage-volt-sel=0
[ 1.128549] rockchip-dmc dmc: avs=0
[ 1.128568] rockchip-dmc dmc: current ATF version 0x101
[ 1.129245] rockchip-dmc dmc: normal_rate = 780000000
[ 1.129260] rockchip-dmc dmc: reboot_rate = 1560000000
[ 1.129272] rockchip-dmc dmc: suspend_rate = 324000000
[ 1.129282] rockchip-dmc dmc: video_4k_rate = 780000000
[ 1.129292] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[ 1.129302] rockchip-dmc dmc: boost_rate = 1560000000
[ 1.129312] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000
[ 1.129322] rockchip-dmc dmc: performance_rate = 1560000000
[ 1.129341] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 1.129461] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.129498] rockchip-dmc dmc: could not find power_model node
[ 1.131529] asoc-simple-card hdmi-sound: i2s-hifi ↔ fe400000.i2s mapping ok
[ 1.136251] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 253
[ 1.137881] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[ 1.139492] asoc-simple-card rk809-sound: rk817-hifi ↔ fe410000.i2s mapping ok
[ 1.139533] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 1.139547] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.139558] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 1.139570] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.139581] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 1.139591] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 1.139602] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 1.139612] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 1.142760] register spi return v = :0
[ 1.145887] It doesn’t contain Rogue gpu
[ 1.146953] iommu: Adding device fde40000.npu to group 0
[ 1.147001] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 1.148053] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 1.148311] RKNPU fde40000.npu: Linked as a consumer to regulator.19
[ 1.148349] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
[ 1.149204] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[ 1.149692] RKNPU fde40000.npu: leakage=4
[ 1.150333] RKNPU fde40000.npu: avs=0
[ 1.151117] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.151157] RKNPU fde40000.npu: failed to find power_model node
[ 1.151171] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 1.151183] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 1.153233] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.154680] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.154900] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.154919] cfg80211: failed to load regulatory.db
[ 1.157072] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 1.159242] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘14:41:08’, on ‘Nov 19 2021’.
[ 1.159759] Mali:
[ 1.159761] Mali device driver loaded
[ 1.160204] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 1.160911] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 1.161088] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 1.161216] xc7160 4-001b: Linked as a consumer to regulator.0
[ 1.161244] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 1.161304] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 1.161410] xc7160 4-001b: could not get default pinstate
[ 1.161423] xc7160 4-001b: could not get sleep pinstate
[ 1.161451] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 1.161462] xc7160 4-001b: xc7160 num data lanes is 4
[ 1.177088] xc7160 4-001b: isp chip is xc7160
[ 1.177315] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_xc7160 4-001b:bus type 4
[ 1.178289] rkisp rkisp-vir0: clear unready subdev num: 4
[ 1.179281] rkisp-vir0: Async subdev notifier completed
[ 1.182666] ret 1024 0
[ 1.183177] ALSA device list:
[ 1.183194] #0: rockchip,hdmi
[ 1.183200] #1: rockchip,rk809-codec
[ 1.187198] Freeing unused kernel memory: 4032K
[ 1.187638] Run /init as init process
[ 1.191295] init: init first stage started!
[ 1.191564] init: Unable to open /lib/modules, skipping module loading.
[ 1.192076] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
[ 1.192940] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 1.210811] vendor storage:20190527 ret = 0
[ 1.225653] devfreq fde60000.gpu: Couldn’t update frequency transition information.
[ 1.227523] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 1.235081] init: android::init::ListenerAction android::init::BlockDevInitializer::HandleUevent(const android::init::Uevent &, std::setstd::string ): found partition: super
[ 1.236648] init: android::init::ListenerAction android::init::BlockDevInitializer::HandleUevent(const android::init::Uevent &, std::setstd::string ): found partition: metadata
[ 1.238758] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[ 1.238973] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
[ 1.239123] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=-1: No such file or directory
[ 1.239258] init: [libfs_mgr]Not running /system/bin/e2fsck on /dev/block/mmcblk2p11 (executable not in system image)
[ 1.255624] EXT4-fs (mmcblk2p11): recovery complete
[ 1.256213] EXT4-fs (mmcblk2p11): mounted filesystem with ordered data mode. Opts: discard
[ 1.271433] EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1
[ 1.279669] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1
[ 1.285393] EXT4-fs (dm-4): mounted filesystem without journal. Opts: barrier=1
[ 1.291179] EXT4-fs (dm-3): mounted filesystem without journal. Opts: barrier=1
[ 1.295978] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1
[ 1.311092] init: 20 output lines suppressed due to ratelimiting
[ 1.459474] init: Loading SELinux policy
[ 1.496171] SELinux: policy capability network_peer_controls=1
[ 1.496282] SELinux: policy capability open_perms=1
[ 1.496291] SELinux: policy capability extended_socket_class=1
[ 1.496299] SELinux: policy capability always_check_network=0
[ 1.496306] SELinux: policy capability cgroup_seclabel=0
[ 1.496313] SELinux: policy capability nnp_nosuid_transition=1
[ 1.658486] audit: type=1403 audit(1639473860.376:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[ 1.658811] selinux: SELinux: Loaded policy from /odm/etc/selinux/precompiled_sepolicy
[ 1.658836] selinux:
[ 1.667534] selinux: SELinux: Loaded file_contexts
[ 1.667613] selinux:
[ 1.709051] init: init second stage started!
[ 1.780581] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 1.782901] init: Init cannot set ‘ro.boot.verifiedbootstate’ to ‘orange’: Read-only property was already set
[ 1.795044] init: Couldn’t load property file ‘/factory/factory.prop’: open() failed: No such file or directory: No such file or directory
[ 1.797182] init: Setting product property ro.product.brand to ‘Firefly’ (from ro.product.product.brand)
[ 1.797257] init: Setting product property ro.product.device to ‘rk3568_firefly_roc_pc’ (from ro.product.product.device)
[ 1.797294] init: Setting product property ro.product.manufacturer to ‘T-CHIP’ (from ro.product.product.manufacturer)
[ 1.797342] init: Setting product property ro.product.model to ‘ROC-RK3568-PC’ (from ro.product.product.model)
[ 1.797433] init: Setting product property ro.product.name to ‘rk3568_firefly_roc_pc’ (from ro.product.product.name)
[ 1.797506] init: Setting property ‘ro.build.fingerprint’ to ‘Firefly/rk3568_firefly_roc_pc/rk3568_firefly_roc_pc:11/RQ3A.210705.001/eng.zhongw.20211119.145820:userdebug/release-keys’
[ 1.869427] audit: type=1107 audit(1639473860.586:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg=‘avc: denied { read } for property=persist.sys.adb_enable pid=0 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1’
[ 1.869929] audit: type=1107 audit(1639473860.586:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg=‘avc: denied { read } for property=app.firefly.config pid=0 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1’
[ 2.030047] ueventd: ueventd started!
[ 2.034509] selinux: SELinux: Loaded file_contexts
[ 2.034628] selinux:
[ 2.035485] ueventd: Parsing file /system/etc/ueventd.rc…
[ 2.037504] ueventd: Parsing file /vendor/ueventd.rc…
[ 2.039684] ueventd: Parsing file /odm/ueventd.rc…
[ 2.039830] ueventd: Unable to read config file ‘/odm/ueventd.rc’: open() failed: No such file or directory
[ 2.039886] ueventd: Parsing file /ueventd.rk30board.rc…
[ 2.039929] ueventd: Unable to read config file ‘/ueventd.rk30board.rc’: open() failed: No such file or directory
[ 2.081759] apexd: This device does not support updatable APEX. Exiting
[ 2.240799] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x1
[ 2.373073] phy phy-fe8a0000.usb2-phy.7: charger = USB_SDP_CHARGER
[ 2.496415] bifrost_kbase: disagrees about version of symbol regulator_enable
[ 2.496462] bifrost_kbase: Unknown symbol regulator_enable (err -22)
[ 2.496487] bifrost_kbase: disagrees about version of symbol get_user_pages_fast
[ 2.496493] bifrost_kbase: Unknown symbol get_user_pages_fast (err -22)
[ 2.496509] bifrost_kbase: disagrees about version of symbol simple_attr_write
[ 2.496514] bifrost_kbase: Unknown symbol simple_attr_write (err -22)
[ 2.496532] bifrost_kbase: disagrees about version of symbol __put_page
[ 2.496537] bifrost_kbase: Unknown symbol __put_page (err -22)
[ 2.496558] bifrost_kbase: disagrees about version of symbol wakeup_source_remove
[ 2.496562] bifrost_kbase: Unknown symbol wakeup_source_remove (err -22)
[ 2.496573] bifrost_kbase: disagrees about version of symbol release_firmware
[ 2.496579] bifrost_kbase: Unknown symbol release_firmware (err -22)
[ 2.496596] bifrost_kbase: disagrees about version of symbol simple_attr_open
[ 2.496606] bifrost_kbase: Unknown symbol simple_attr_open (err -22)
[ 2.496634] bifrost_kbase: disagrees about version of symbol bpf_trace_run4
[ 2.496643] bifrost_kbase: Unknown symbol bpf_trace_run4 (err -22)
[ 2.496675] bifrost_kbase: disagrees about version of symbol devfreq_register_opp_notifier
[ 2.496684] bifrost_kbase: Unknown symbol devfreq_register_opp_notifier (err -22)
[ 2.496700] bifrost_kbase: disagrees about version of symbol dev_pm_opp_put_regulators
[ 2.496708] bifrost_kbase: Unknown symbol dev_pm_opp_put_regulators (err -22)
[ 2.496812] bifrost_kbase: disagrees about version of symbol of_find_device_by_node
[ 2.496817] bifrost_kbase: Unknown symbol of_find_device_by_node (err -22)
[ 2.496862] bifrost_kbase: disagrees about version of symbol of_devfreq_cooling_register_power
[ 2.496871] bifrost_kbase: Unknown symbol of_devfreq_cooling_register_power (err -22)
[ 2.496924] bifrost_kbase: disagrees about version of symbol request_firmware
[ 2.496933] bifrost_kbase: Unknown symbol request_firmware (err -22)
[ 2.496966] bifrost_kbase: disagrees about version of symbol regulator_put
[ 2.496974] bifrost_kbase: Unknown symbol regulator_put (err -22)
[ 2.497000] bifrost_kbase: disagrees about version of symbol register_shrinker
[ 2.497008] bifrost_kbase: Unknown symbol register_shrinker (err -22)
[ 2.497047] bifrost_kbase: disagrees about version of symbol unmap_mapping_range
[ 2.497052] bifrost_kbase: Unknown symbol unmap_mapping_range (err -22)
[ 2.497065] bifrost_kbase: disagrees about version of symbol remap_pfn_range
[ 2.497073] bifrost_kbase: Unknown symbol remap_pfn_range (err -22)
[ 2.497118] bifrost_kbase: disagrees about version of symbol bpf_trace_run2
[ 2.497126] bifrost_kbase: Unknown symbol bpf_trace_run2 (err -22)
[ 2.497199] bifrost_kbase: disagrees about version of symbol get_device
[ 2.497208] bifrost_kbase: Unknown symbol get_device (err -22)
[ 2.497227] bifrost_kbase: disagrees about version of symbol rockchip_init_opp_table
[ 2.497236] bifrost_kbase: Unknown symbol rockchip_init_opp_table (err -22)
[ 2.497277] bifrost_kbase: disagrees about version of symbol kmem_cache_alloc_trace
[ 2.497282] bifrost_kbase: Unknown symbol kmem_cache_alloc_trace (err -22)
[ 2.497312] bifrost_kbase: disagrees about version of symbol get_user_pages_remote
[ 2.497320] bifrost_kbase: Unknown symbol get_user_pages_remote (err -22)
[ 2.497338] bifrost_kbase: disagrees about version of symbol wake_up_process
[ 2.497346] bifrost_kbase: Unknown symbol wake_up_process (err -22)
[ 2.497391] bifrost_kbase: disagrees about version of symbol devfreq_add_device
[ 2.497402] bifrost_kbase: Unknown symbol devfreq_add_device (err -22)
[ 2.497415] bifrost_kbase: disagrees about version of symbol trace_event_buffer_commit
[ 2.497423] bifrost_kbase: Unknown symbol trace_event_buffer_commit (err -22)
[ 2.497458] bifrost_kbase: disagrees about version of symbol rockchip_monitor_dev_high_temp_adjust
[ 2.497467] bifrost_kbase: Unknown symbol rockchip_monitor_dev_high_temp_adjust (err -22)
[ 2.497511] bifrost_kbase: disagrees about version of symbol regulator_get_optional
[ 2.497516] bifrost_kbase: Unknown symbol regulator_get_optional (err -22)
[ 2.497548] bifrost_kbase: disagrees about version of symbol get_user_pages
[ 2.497556] bifrost_kbase: Unknown symbol get_user_pages (err -22)
[ 2.497598] bifrost_kbase: disagrees about version of symbol put_device
[ 2.497606] bifrost_kbase: Unknown symbol put_device (err -22)
[ 2.497639] bifrost_kbase: disagrees about version of symbol dev_pm_opp_put
[ 2.497647] bifrost_kbase: Unknown symbol dev_pm_opp_put (err -22)
[ 2.497674] bifrost_kbase: disagrees about version of symbol unregister_shrinker
[ 2.497682] bifrost_kbase: Unknown symbol unregister_shrinker (err -22)
[ 2.497704] bifrost_kbase: disagrees about version of symbol __free_pages
[ 2.497712] bifrost_kbase: Unknown symbol __free_pages (err -22)
[ 2.497731] bifrost_kbase: disagrees about version of symbol _dev_info
[ 2.497738] bifrost_kbase: Unknown symbol _dev_info (err -22)
[ 2.497747] bifrost_kbase: disagrees about version of symbol find_vma
[ 2.497751] bifrost_kbase: Unknown symbol find_vma (err -22)
[ 2.497781] bifrost_kbase: disagrees about version of symbol device_create_file
[ 2.497789] bifrost_kbase: Unknown symbol device_create_file (err -22)
[ 2.497823] bifrost_kbase: disagrees about version of symbol __pm_relax
[ 2.497831] bifrost_kbase: Unknown symbol __pm_relax (err -22)
[ 2.497867] bifrost_kbase: disagrees about version of symbol perf_trace_run_bpf_submit
[ 2.497876] bifrost_kbase: Unknown symbol perf_trace_run_bpf_submit (err -22)
[ 2.497886] bifrost_kbase: disagrees about version of symbol fput
[ 2.497894] bifrost_kbase: Unknown symbol fput (err -22)
[ 2.497908] bifrost_kbase: disagrees about version of symbol _dev_err
[ 2.497916] bifrost_kbase: Unknown symbol _dev_err (err -22)
[ 2.497926] bifrost_kbase: disagrees about version of symbol devfreq_remove_device
[ 2.497934] bifrost_kbase: Unknown symbol devfreq_remove_device (err -22)
[ 2.497959] bifrost_kbase: disagrees about version of symbol dev_pm_opp_set_regulators
[ 2.497967] bifrost_kbase: Unknown symbol dev_pm_opp_set_regulators (err -22)
[ 2.497981] bifrost_kbase: disagrees about version of symbol simple_open
[ 2.497985] bifrost_kbase: Unknown symbol simple_open (err -22)
[ 2.498024] bifrost_kbase: disagrees about version of symbol dev_pm_opp_find_freq_floor
[ 2.498032] bifrost_kbase: Unknown symbol dev_pm_opp_find_freq_floor (err -22)
[ 2.498045] bifrost_kbase: disagrees about version of symbol simple_attr_release
[ 2.498054] bifrost_kbase: Unknown symbol simple_attr_release (err -22)
[ 2.498064] bifrost_kbase: disagrees about version of symbol rockchip_monitor_dev_low_temp_adjust
[ 2.498072] bifrost_kbase: Unknown symbol rockchip_monitor_dev_low_temp_adjust (err -22)
[ 2.498108] bifrost_kbase: disagrees about version of symbol bpf_trace_run5
[ 2.498116] bifrost_kbase: Unknown symbol bpf_trace_run5 (err -22)
[ 2.498137] bifrost_kbase: disagrees about version of symbol rockchip_system_monitor_register
[ 2.498145] bifrost_kbase: Unknown symbol rockchip_system_monitor_register (err -22)
[ 2.498228] bifrost_kbase: disagrees about version of symbol devfreq_unregister_opp_notifier
[ 2.498236] bifrost_kbase: Unknown symbol devfreq_unregister_opp_notifier (err -22)
[ 2.498273] bifrost_kbase: disagrees about version of symbol freezing_slow_path
[ 2.498281] bifrost_kbase: Unknown symbol freezing_slow_path (err -22)
[ 2.498295] bifrost_kbase: disagrees about version of symbol bpf_trace_run1
[ 2.498304] bifrost_kbase: Unknown symbol bpf_trace_run1 (err -22)
[ 2.498323] bifrost_kbase: disagrees about version of symbol _dev_warn
[ 2.498331] bifrost_kbase: Unknown symbol _dev_warn (err -22)
[ 2.498359] bifrost_kbase: disagrees about version of symbol dev_pm_opp_get_opp_count
[ 2.498367] bifrost_kbase: Unknown symbol dev_pm_opp_get_opp_count (err -22)
[ 2.498393] bifrost_kbase: disagrees about version of symbol simple_attr_read
[ 2.498401] bifrost_kbase: Unknown symbol simple_attr_read (err -22)
[ 2.498417] bifrost_kbase: disagrees about version of symbol __mmdrop
[ 2.498425] bifrost_kbase: Unknown symbol __mmdrop (err -22)
[ 2.498440] bifrost_kbase: disagrees about version of symbol nonseekable_open
[ 2.498445] bifrost_kbase: Unknown symbol nonseekable_open (err -22)
[ 2.498460] bifrost_kbase: disagrees about version of symbol __alloc_pages_nodemask
[ 2.498467] bifrost_kbase: Unknown symbol __alloc_pages_nodemask (err -22)
[ 2.498481] bifrost_kbase: disagrees about version of symbol bpf_trace_run3
[ 2.498489] bifrost_kbase: Unknown symbol bpf_trace_run3 (err -22)
[ 2.498529] bifrost_kbase: disagrees about version of symbol devfreq_suspend_device
[ 2.498537] bifrost_kbase: Unknown symbol devfreq_suspend_device (err -22)
[ 2.498588] bifrost_kbase: disagrees about version of symbol rockchip_system_monitor_unregister
[ 2.498597] bifrost_kbase: Unknown symbol rockchip_system_monitor_unregister (err -22)
[ 2.498607] bifrost_kbase: disagrees about version of symbol thermal_zone_get_zone_by_name
[ 2.498615] bifrost_kbase: Unknown symbol thermal_zone_get_zone_by_name (err -22)
[ 2.498631] bifrost_kbase: disagrees about version of symbol set_page_dirty_lock
[ 2.498639] bifrost_kbase: Unknown symbol set_page_dirty_lock (err -22)
[ 2.498665] bifrost_kbase: disagrees about version of symbol dev_pm_opp_find_freq_ceil
[ 2.498670] bifrost_kbase: Unknown symbol dev_pm_opp_find_freq_ceil (err -22)
[ 2.498682] bifrost_kbase: disagrees about version of symbol __pm_stay_awake
[ 2.498686] bifrost_kbase: Unknown symbol __pm_stay_awake (err -22)
[ 2.498701] bifrost_kbase: disagrees about version of symbol regulator_disable
[ 2.498709] bifrost_kbase: Unknown symbol regulator_disable (err -22)
[ 2.498730] bifrost_kbase: disagrees about version of symbol dev_pm_opp_get_voltage
[ 2.498737] bifrost_kbase: Unknown symbol dev_pm_opp_get_voltage (err -22)
[ 2.498754] bifrost_kbase: disagrees about version of symbol wakeup_source_add
[ 2.498762] bifrost_kbase: Unknown symbol wakeup_source_add (err -22)
[ 2.498784] bifrost_kbase: disagrees about version of symbol devfreq_resume_device
[ 2.498792] bifrost_kbase: Unknown symbol devfreq_resume_device (err -22)
[ 2.498812] bifrost_kbase: disagrees about version of symbol regulator_set_voltage
[ 2.498820] bifrost_kbase: Unknown symbol regulator_set_voltage (err -22)
[ 2.498836] bifrost_kbase: disagrees about version of symbol kmalloc_caches
[ 2.498844] bifrost_kbase: Unknown symbol kmalloc_caches (err -22)
[ 2.498858] bifrost_kbase: disagrees about version of symbol device_remove_file
[ 2.498866] bifrost_kbase: Unknown symbol device_remove_file (err -22)
[ 2.498877] bifrost_kbase: disagrees about version of symbol vm_insert_pfn_prot
[ 2.498885] bifrost_kbase: Unknown symbol vm_insert_pfn_prot (err -22)
[ 2.780112] ueventd: Coldboot took 0.738 seconds
[ 2.861325] Registered swp emulation handler
[ 2.876970] EXT4-fs (mmcblk2p14): mounted filesystem with ordered data mode. Opts: (null)
[ 2.941519] EXT4-fs (mmcblk2p10): Ignoring removed nomblk_io_submit option
[ 2.943312] logd.auditd: start
[ 2.943391] logd.klogd: 2939367490
[ 2.969682] EXT4-fs (mmcblk2p10): recovery complete
[ 2.971838] EXT4-fs (mmcblk2p10): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.999941] type=1107 audit(1639473861.680:5): uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg=‘avc: denied { set } for property=persist.vendor.rknn.log.level pid=155 uid=0 gid=0 scontext=u:r:rknn_server:s0 tcontext=u:object_r:vendor_default_prop:s0 tclass=property_service permissive=1’
[ 3.020572] e2fsck: e2fsck 1.45.4 (23-Sep-2019)
[ 3.025300] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 3.027698] e2fsck: Pass 2: Checking directory structure
[ 3.029157] e2fsck: Pass 3: Checking directory connectivity
[ 3.029267] e2fsck: Pass 4: Checking reference counts
[ 3.034454] e2fsck: Pass 5: Checking group summary information
[ 3.047349] e2fsck: /dev/block/by-name/cache: 17/98304 files (0.0% non-contiguous), 7208/98304 blocks
[ 3.053051] EXT4-fs (mmcblk2p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.160511] wait_for_keymaster: Waiting for Keymaster device
[ 3.210886] HidlServiceManagement: getService: Trying again for android.hardware.keymaster@4.0::IKeymasterDevice/default…
[ 3.254076] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.278878] wait_for_keymaster: List of Keymaster HALs found:
[ 3.279217] wait_for_keymaster: Keymaster HAL #1: OpteeKeymasterDevice from Rockchip SecurityLevel: TRUSTED_ENVIRONMENT HAL: android.hardware.keymaster@4.1::IKeymasterDevice/default
[ 3.279512] wait_for_keymaster: Computing HMAC with params { (seed: , nonce: 3dd4668e3dbf52c32d484ce261f88c29b9567bdfd5139d99dfae261b2a5f5) }
[ 3.279533] wait_for_keymaster: Computing HMAC for OpteeKeymasterDevice from Rockchip SecurityLevel: TRUSTED_ENVIRONMENT HAL: android.hardware.keymaster@4.1::IKeymasterDevice/default
[ 3.279664] wait_for_keymaster: Using OpteeKeymasterDevice from Rockchip for encryption. Security level: TRUSTED_ENVIRONMENT, HAL: android.hardware.keymaster@4.1::IKeymasterDevice/default
[ 3.279694] wait_for_keymaster: Keymaster device ready
[ 3.301771] vdc: Waited 0ms for vold
[ 3.303313] vdc: Command: checkpoint restoreCheckpoint /dev/block/by-name/userdata Failed: Status(-8, EX_SERVICE_SPECIFIC): ‘22: No magic’
[ 3.321833] vdc: Waited 0ms for vold
[ 3.327034] EXT4-fs (mmcblk2p15): Ignoring removed nomblk_io_submit option
[ 3.327070] EXT4-fs (mmcblk2p15): Using encoding defined by superblock: utf8-12.1.0 with flags 0x0
[ 3.423820] EXT4-fs (mmcblk2p15): recovery complete
[ 3.424944] EXT4-fs (mmcblk2p15): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 3.465497] e2fsck: e2fsck 1.45.4 (23-Sep-2019)
[ 3.503376] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 3.579038] e2fsck: Pass 2: Checking directory structure
[ 3.877520] EXT4-fs (mmcblk2p15): Using encoding defined by superblock: utf8-12.1.0 with flags 0x0
[ 3.886324] EXT4-fs (mmcblk2p15): mounted filesystem with ordered data mode. Opts: discard,noauto_da_alloc,data=ordered,user_xattr,barrier=1
[ 3.919845] fusb302 0-0022: PD disabled
[ 3.972937] vdc: Waited 0ms for vold
[ 4.011532] fscrypt: AES-256-CTS-CBC using implementation “cts(cbc-aes-ce)”
[ 4.021928] fscrypt: AES-256-XTS using implementation “xts-aes-ce”
[ 4.041399] apexd: This device does not support updatable APEX. Exiting
[ 4.041465] apexd: Marking APEXd as activated
[ 4.140445] type=1400 audit(1639473862.856:6): avc: denied { read } for comm=“android.hardwar” name=“resolution_white.xml” dev=“dm-0” ino=3965 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
[ 4.140673] type=1400 audit(1639473862.856:7): avc: denied { open } for comm=“android.hardwar” path=“/system/usr/share/resolution_white.xml” dev=“dm-0” ino=3965 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
[ 4.140824] type=1400 audit(1639473862.856:8): avc: denied { getattr } for comm=“android.hardwar” path=“/system/usr/share/resolution_white.xml” dev=“dm-0” ino=3965 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
[ 4.207868] type=1400 audit(1639473862.926:9): avc: denied { read } for comm=“android.hardwar” name=“u:object_r:default_prop:s0” dev=“tmpfs” ino=18621 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1
[ 4.208087] type=1400 audit(1639473862.926:10): avc: denied { open } for comm=“android.hardwar” path=“/dev/properties/u:object_r:default_prop:s0” dev=“tmpfs” ino=18621 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1
[ 4.208181] type=1400 audit(1639473862.926:11): avc: denied { getattr } for comm=“android.hardwar” path=“/dev/properties/u:object_r:default_prop:s0” dev=“tmpfs” ino=18621 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1
[ 4.208263] type=1400 audit(1639473862.926:12): avc: denied { map } for comm=“android.hardwar” path=“/dev/properties/u:object_r:default_prop:s0” dev=“tmpfs” ino=18621 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1
[ 4.255144] vdc: Waited 0ms for vold
[ 4.267401] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 4.360760] apexd: This device does not support updatable APEX. Exiting
[ 4.360806] apexd: Marking APEXd as ready
[ 4.496530] init: Verified that /data/nfc has the encryption policy f7424c7de0d57868df885afc08bef6e9 v2 modes 1/4 flags 0x2
[ 4.497038] init: Inferred action different from explicit one, expected 0 but got 2
[ 4.497351] init: Verified that /data/nfc/param has the encryption policy f7424c7de0d57868df885afc08bef6e9 v2 modes 1/4 flags 0x2
[ 4.978635] healthd: BatteryCurrentNowPath not found
[ 4.978739] healthd: BatteryCycleCountPath not found
[ 4.996739] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 5.071697] file system registered
[ 5.074895] using random self ethernet address
[ 5.074942] using random host ethernet address
[ 5.280806] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 5.334140] [dhd] dhd_module_init: in Dongle Host Driver, version 100.10.545.12 (r826445-20200708-1)
[ 5.334401] [dhd] ======== dhd_wlan_init_plat_data ========
[ 5.334465] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 5.334549] [dhd] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=114, oob_irq_flags=0x414
[ 5.334568] [dhd] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 5.334585] [dhd] dhd_wifi_platform_load: Enter
[ 5.334601] [dhd] Power-up adapter ‘DHD generic adapter’
[ 5.352362] [dhd] wifi_platform_set_power = 1, delay: 200 msec
[ 5.352462] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 5.352483] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 5.352506] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 5.352522] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 5.441016] read descriptors
[ 5.441076] read strings
[ 5.586982] xc7160 4-001b: isp chip is xc7160
[ 5.633604] xc7160 4-001b: isp chip is xc7160
[ 5.677255] xc7160 4-001b: isp chip is xc7160
[ 5.714764] xc7160 4-001b: isp chip is xc7160
[ 5.747402] [dhd] wifi_platform_bus_enumerate device present 1
[ 5.747434] [dhd] ======== Card detection to detect SDIO card! ========
[ 5.747440] mmc3:mmc host rescan start!
[ 5.759197] xc7160 4-001b: isp chip is xc7160
[ 5.770563] [dhd] bcmsdh_register: register client driver
[ 5.771176] [dhd] bcmsdh_sdmmc_probe: Enter num=1
[ 5.772679] [dhd] bcmsdh_sdmmc_probe: Enter num=2
[ 5.772707] [dhd] bus num (host idx)=3, slot num (rca)=1
[ 5.772714] [dhd] found adapter info ‘DHD generic adapter’
[ 5.772770] [dhd] sdioh_attach: set sd_f2_blocksize 256
[ 5.772856] [dhd] sdioh_attach: sd clock rate = 0
[ 5.773046] [dhd] dhdsdio_probe : no mutex held. set lock
[ 5.773160] [dhd] F1 signature read @0x18000000=0x1042aae8
[ 5.782443] [dhd] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 5.783304] [dhd] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 5.784294] [dhd] dhd_conf_set_chiprev : chip=0xaae8, chiprev=2
[ 5.790476] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790570] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790597] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790612] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790627] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790642] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790657] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790680] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790750] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790799] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.790816] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 5.795989] [dhd] dhd_log_dump_init: kernel log buf size = 512KB; logdump_prsrv_tailsize = 80KB; limit prsrv tail size to = 76KB
[ 5.803492] dhd_attach(): thread:dhd_watchdog_thread:16c started
[ 5.805216] dhd_attach(): thread:dhd_dpc:16d started
[ 5.805436] dhd_attach(): thread:dhd_rxf:16e started
[ 5.805463] [dhd] dhd_deferred_work_init: work queue initialized
[ 5.805473] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 5.805689] [dhd] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 5.805712] [dhd] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 5.805728] [dhd] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 5.811144] [dhd] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 5.811248] [dhd] Dongle Host Driver, version 100.10.545.12 (r826445-20200708-1)
[ 5.817199] [dhd] Register interface [wlan0] MAC: 10:2c:6b:7f:a0:34\x0a
[ 5.817654] xc7160 4-001b: isp chip is xc7160
[ 5.822247] [dhd] dhd_dbg_detach_pkt_monitor, 2099
[ 5.822277] [dhd] dhd_bus_devreset: == Power OFF ==
[ 5.822423] [dhd] dhd_bus_stop: making DHD_BUS_DOWN
[ 5.822453] [dhd] bcmsdh_oob_intr_unregister: Enter
[ 5.822467] [dhd] bcmsdh_oob_intr_unregister: irq is not registered
[ 5.822490] [dhd] dhd_bus_devreset: making dhdpub up FALSE
[ 5.822500] [dhd] dhd_txglom_enable: enable 0
[ 5.822509] [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[ 5.822518] [dhd] dhd_bus_devreset: WLAN OFF DONE
[ 5.822546] [dhd] wifi_platform_set_power = 0, delay: 0 msec
[ 5.822556] [dhd] ======== PULL WL_REG_ON(-1) LOW! ========
[ 5.822565] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 5.822582] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 5.822605] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 5.822617] [dhd] dhdsdio_probe : the lock is released.
[ 5.823487] [dhd] dhd_module_init: Exit err=0
[ 5.855155] xc7160 4-001b: isp chip is xc7160
[ 5.911123] xc7160 4-001b: isp chip is xc7160
[ 6.095969] xc7160 4-001b: isp chip is xc7160
[ 6.189507] xc7160 4-001b: isp chip is xc7160
[ 6.251212] xc7160 4-001b: isp chip is xc7160
[ 6.294137] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 6.327494] xc7160 4-001b: isp chip is xc7160
[ 6.365184] dwc3 fcc00000.dwc3: device reset
[ 6.467501] android_work: sent uevent USB_STATE=CONNECTED
[ 6.588479] dwc3 fcc00000.dwc3: device reset
[ 6.588977] android_work: sent uevent USB_STATE=DISCONNECTED
[ 6.691223] android_work: sent uevent USB_STATE=CONNECTED
[ 6.701265] configfs-gadget gadget: high-speed config #1: b
[ 6.701521] android_work: sent uevent USB_STATE=CONFIGURED
[ 6.833573] init: Control message: Processed ctl.start for ‘bootanim’ from pid: 183 (/system/bin/surfaceflinger)
[ 7.310728] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 8.320730] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 8.530011] type=1400 audit(1639473867.246:30): avc: denied { getattr } for comm=“main” path=“/oem” dev=“mmcblk2p14” ino=2 scontext=u:r:zygote:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[ 8.534287] type=1400 audit(1639473867.250:31): avc: denied { search } for comm=“main” name=“/” dev=“mmcblk2p14” ino=2 scontext=u:r:zygote:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[ 9.334084] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 9.952694] type=1400 audit(1639473868.670:32): avc: denied { read } for comm=“Binder:181_2” name=“wakeup2” dev=“sysfs” ino=16164 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 9.952947] type=1400 audit(1639473868.670:33): avc: denied { open } for comm=“Binder:181_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2” dev=“sysfs” ino=16164 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 9.953037] type=1400 audit(1639473868.670:34): avc: denied { read } for comm=“Binder:181_2” name=“event_count” dev=“sysfs” ino=16171 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 9.953118] type=1400 audit(1639473868.670:35): avc: denied { open } for comm=“Binder:181_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2/event_count” dev=“sysfs” ino=16171 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 9.953200] type=1400 audit(1639473868.670:36): avc: denied { getattr } for comm=“Binder:181_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2/event_count” dev=“sysfs” ino=16171 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 9.953839] type=1400 audit(1639473868.670:37): avc: denied { read } for comm=“Binder:181_2” name=“wakeup9” dev=“sysfs” ino=25285 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1
[ 9.953934] type=1400 audit(1639473868.670:38): avc: denied { open } for comm=“Binder:181_2” path=“/sys/devices/virtual/power_supply/test_battery/wakeup9” dev=“sysfs” ino=25285 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1
[ 10.347484] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 11.360737] rk-pcie 3c0800000.pcie: PCIe Link Fail
[ 11.360771] rk-pcie 3c0800000.pcie: failed to initialize host
[ 13.877892] init: Control message: Processed ctl.start for ‘idmap2d’ from pid: 435 (system_server)
[ 13.996884] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 14.010926] type=1400 audit(1639473872.726:39): avc: denied { read } for comm=“Binder:181_2” name=“wakeup2” dev=“sysfs” ino=16164 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 14.011086] type=1400 audit(1639473872.726:40): avc: denied { open } for comm=“Binder:181_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2” dev=“sysfs” ino=16164 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 14.011167] type=1400 audit(1639473872.726:41): avc: denied { read } for comm=“Binder:181_2” name=“event_count” dev=“sysfs” ino=16171 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 14.011246] type=1400 audit(1639473872.726:42): avc: denied { open } for comm=“Binder:181_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2/event_count” dev=“sysfs” ino=16171 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 14.011353] type=1400 audit(1639473872.726:43): avc: denied { getattr } for comm=“Binder:181_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2/event_count” dev=“sysfs” ino=16171 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 14.057861] android_work: sent uevent USB_STATE=DISCONNECTED
[ 14.058541] init: Service ‘adbd’ (pid 317) exited with status 1
[ 14.058585] init: Sending signal 9 to service ‘adbd’ (pid 317) process group…
[ 14.058842] libprocessgroup: Successfully killed process cgroup uid 0 pid 317 in 0ms
[ 14.060320] init: starting service ‘adbd’…
[ 14.061303] init: Created socket ‘/dev/socket/adbd’, mode 660, user 1000, group 1000
[ 14.093910] read descriptors
[ 14.094002] read strings
[ 14.095187] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/system/etc/init/hw/init.usb.configfs.rc:20)
[ 14.096491] init: Command ‘symlink /config/usb_gadget/g1/functions/ffs.adb /config/usb_gadget/g1/configs/b.1/f1’ action=sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1 (/system/etc/init/hw/init.usb.configfs.rc:22) took 0ms and failed: symlink() failed: File exists
[ 14.191460] type=1400 audit(1639473872.903:44): avc: denied { read } for comm=“Binder:435_3” name=“hctosys” dev=“sysfs” ino=24891 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 14.191685] type=1400 audit(1639473872.903:45): avc: denied { open } for comm=“Binder:435_3” path=“/sys/devices/platform/fe5e0000.i2c/i2c-5/5-0051/rtc/rtc0/hctosys” dev=“sysfs” ino=24891 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 14.191865] type=1400 audit(1639473872.903:46): avc: denied { getattr } for comm=“Binder:435_3” path=“/sys/devices/platform/fe5e0000.i2c/i2c-5/5-0051/rtc/rtc0/hctosys” dev=“sysfs” ino=24891 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 14.307007] dwc3 fcc00000.dwc3: device reset
[ 14.307148] android_work: did not send uevent (0 0 (null))
[ 14.382001] init: processing action (sys.sysctl.extra_free_kbytes=
) from (/system/etc/init/hw/init.rc:994)
[ 14.408461] android_work: sent uevent USB_STATE=CONNECTED
[ 14.524158] dwc3 fcc00000.dwc3: device reset
[ 14.524340] android_work: sent uevent USB_STATE=DISCONNECTED
[ 14.626505] android_work: sent uevent USB_STATE=CONNECTED
[ 14.636060] configfs-gadget gadget: high-speed config #1: b
[ 14.636296] android_work: sent uevent USB_STATE=CONFIGURED
[ 15.305087] read descriptors
[ 15.305126] read strings
[ 15.305217] read descriptors
[ 15.305236] read strings
[ 15.365505] type=1400 audit(1639473874.083:47): avc: denied { getattr } for comm=“main” path=“/oem” dev=“mmcblk2p14” ino=2 scontext=u:r:zygote:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[ 15.369902] type=1400 audit(1639473874.086:48): avc: denied { search } for comm=“main” name=“/” dev=“mmcblk2p14” ino=2 scontext=u:r:zygote:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[ 15.595777] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 15.596027] phy_rtl8211f_led_fixup in
[ 15.616740] phy_rtl8211f_led_fixup in
[ 15.637937] Generic PHY stmmac-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 15.648609] dwmac4: Master AXI performs any burst length
[ 15.648649] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[ 15.648670] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 15.649199] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[ 15.649708] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.649734] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 15.652425] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 15.653275] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 15.653489] phy_rtl8211f_led_fixup in
[ 15.678180] phy_rtl8211f_led_fixup in
[ 15.708063] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 15.709110] dwmac4: Master AXI performs any burst length
[ 15.709186] rk_gmac-dwmac fe2a0000.ethernet eth1: No Safety Features support found
[ 15.709284] rk_gmac-dwmac fe2a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[ 15.713811] rk_gmac-dwmac fe2a0000.ethernet eth1: registered PTP clock
[ 15.715431] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 15.715513] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 16.667556] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 16.721713] rk_gmac-dwmac fe2a0000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 16.721793] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 16.721936] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 16.863504] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
[ 18.056031] init: processing action (sys.sysctl.tcp_def_init_rwnd=
) from (/system/etc/init/hw/init.rc:998)
[ 19.840238] init: processing action (sys.boot_completed=1) from (/system/etc/init/hw/init.rc:985)
[ 19.841120] init: starting service ‘exec 14 (/bin/rm -rf /data/per_boot)’…
[ 19.843385] init: SVC_EXEC service ‘exec 14 (/bin/rm -rf /data/per_boot)’ pid 1069 (uid 1000 gid 1000+0 context default) started; waiting…
[ 19.880541] init: Service ‘exec 14 (/bin/rm -rf /data/per_boot)’ (pid 1069) exited with status 0 waiting took 0.037000 seconds
[ 19.880647] init: Sending signal 9 to service ‘exec 14 (/bin/rm -rf /data/per_boot)’ (pid 1069) process group…
[ 19.881041] libprocessgroup: Successfully killed process cgroup uid 1000 pid 1069 in 0ms
[ 19.894208] init: Encryption policy of /data/per_boot set to 19a37f6c29e99114575408a9d09ffd10 v2 modes 1/4 flags 0x2
[ 19.894487] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.rk30board.rc:232)
[ 19.922120] init: starting service ‘mode_switch’…
[ 19.940360] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.rk356x.rc:1)
[ 19.958382] type=1400 audit(1639473878.676:70): avc: denied { entrypoint } for comm=“init” path=“/system/bin/usb_mode_switch.sh” dev=“dm-0” ino=1753 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=file permissive=1
[ 19.981401] type=1400 audit(1639473878.680:71): avc: denied { map } for comm=“usb_mode_switch” path=“/system/bin/sh” dev=“dm-0” ino=1672 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 19.984457] type=1400 audit(1639473878.680:72): avc: denied { read } for comm=“usb_mode_switch” path=“/system/bin/sh” dev=“dm-0” ino=1672 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 19.984703] type=1400 audit(1639473878.680:73): avc: denied { execute } for comm=“usb_mode_switch” path=“/system/bin/sh” dev=“dm-0” ino=1672 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 19.997579] type=1400 audit(1639473878.680:74): avc: denied { getattr } for comm=“usb_mode_switch” path=“/system/bin/sh” dev=“dm-0” ino=1672 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 20.004318] rockchip-usb2phy fe8a0000.usb2-phy: Same as current mode
[ 20.029392] type=1400 audit(1639473878.690:75): avc: denied { read } for comm=“usb_mode_switch” path=“/system/bin/sh” dev=“dm-0” ino=1672 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 20.029569] type=1400 audit(1639473878.696:76): avc: denied { read } for comm=“usb_mode_switch” name=“usb_mode_switch.sh” dev=“dm-0” ino=1753 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=file permissive=1
[ 20.029657] type=1400 audit(1639473878.696:77): avc: denied { open } for comm=“usb_mode_switch” path=“/system/bin/usb_mode_switch.sh” dev=“dm-0” ino=1753 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=file permissive=1
[ 20.029789] type=1400 audit(1639473878.700:78): avc: denied { getattr } for comm=“usb_mode_switch” path=“/system/bin/toolbox” dev=“dm-0” ino=1721 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 20.029949] type=1400 audit(1639473878.700:79): avc: denied { execute } for comm=“usb_mode_switch” name=“toolbox” dev=“dm-0” ino=1721 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 20.259625] zram0: detected capacity change from 0 to 2038833152
[ 20.309305] mkswap: Swapspace size: 1991044k, UUID=51b1d0cf-0de9-4fa8-93b1-6a20dec60350
[ 20.312839] Adding 1991044k swap on /dev/block/zram0. Priority:-2 extents:1 across:1991044k SS
[ 22.853465] audit: audit_lost=1 audit_rate_limit=5 audit_backlog_limit=64
[ 22.853495] audit: rate limit exceeded
[ 32.054221] vcc3v3_lcd0_n: disabling
[ 32.054394] vcc3v3_lcd1_n: disabling
[ 32.054433] vcc3v3_pcie: disabling
[ 50.017204] xc7160 4-001b: isp chip is xc7160
[ 50.032882] rkisp rkisp-vir0: can not get first iq setting in stream on
[ 50.034060] rockchip-csi2-dphy0: dphy0, data_rate_mbps 1152
[ 50.034100] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 50.034110] xc7160 4-001b: xc7160 res wxh: 1920x1080@30fps
[ 50.292755] xc7160 4-001b: sensor chip is SC8238
[ 52.854251] rkisp-vir0: rkisp_stream_stop id:0 timeout
[ 52.856224] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 52.856286] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 65.001434] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
:confused: #
有下载SDK,编译过内核吗
zyk 发表于 2021-12-14 17:36
有下载SDK,编译过内核吗
也下载过,也编译过,都不能用。 用的这修版本rk356x_linux_release_20211019
上边的两个我用的都是官方的固件,没动过。
也可以。烧回buildroot的固件,然后驱动kernel/drivers/media/i2c/xc7160.c添加一下这句 xc7160->isp_out_colorbar = true;
static int __xc7160_start_stream(struct xc7160 *xc7160)
        int ret;
        struct device *dev = &xc7160->client->dev;
#ifdef FIREFLY_DEBUG
                xc7160_check_isp_reg(xc7160);
#endif // DEBUG
        /*if the application doesn't call xxx_set_fmt, we initial isp and sensor  here*/
        if(xc7160->initial_status != true){
                xc7160_global_regs = xc7160->cur_mode->isp_reg_list;
                sc8238_global_regs = xc7160->cur_mode->sensor_reg_list;
                camera_isp_sensor_initial(xc7160);
+        xc7160->isp_out_colorbar = true;
        if(xc7160->isp_out_colorbar == true){
                dev_info(dev, "colorbar on !!!\n");
                ret = xc7160_write_array(xc7160->client, xc7160_colorbar_on_regs);
        }else
                ret = xc7160_write_array(xc7160->client, xc7160_stream_on_regs);
        if(ret)
                dev_err(dev, "xc7160 write stream or colorbar regs failed\n");
之后编译内核烧写,看一下能否输出彩条
zyk 发表于 2021-12-14 17:44
也可以。烧回buildroot的固件,然后驱动kernel/drivers/media/i2c/xc7160.c添加一下这句 xc7160->isp_out_c …
加过后,仍然不行,还请指教,谢谢。
C:\Users\admin>adb shell
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]# demsg | grep xc7
/bin/sh: demsg: not found
[root@RK356X:/]# dmesg | grep xc7
[ 2.122416] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 2.122658] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 2.122716] xc7160 4-001b: Looking up avdd-supply from device tree
[ 2.122724] xc7160 4-001b: Looking up avdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.122751] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 2.122807] xc7160 4-001b: Linked as a consumer to regulator.0
[ 2.122819] xc7160 4-001b: Looking up dovdd-supply from device tree
[ 2.122826] xc7160 4-001b: Looking up dovdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.122843] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 2.122878] xc7160 4-001b: Looking up dvdd-supply from device tree
[ 2.122885] xc7160 4-001b: Looking up dvdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.122899] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 2.122950] xc7160 4-001b: could not get default pinstate
[ 2.122962] xc7160 4-001b: could not get sleep pinstate
[ 2.122980] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 2.122989] xc7160 4-001b: xc7160 num data lanes is 4
[ 2.142055] xc7160 4-001b: isp chip is xc7160
[ 2.142428] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_xc7160 4-001b:bus type 4
[ 4.751891] xc7160 4-001b: isp chip is xc7160
[ 4.788564] xc7160 4-001b: isp chip is xc7160
[ 4.821910] xc7160 4-001b: isp chip is xc7160
[ 5.572141] xc7160 4-001b: isp chip is xc7160
[ 5.611973] xc7160 4-001b: isp chip is xc7160
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]# v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,he
ight=1080,pixelformat=‘NV12’ --stream-mmap=4
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture Multiplanar:
Width/Height : 1920/1080
Pixel Format : ‘NV12’ (Y/CbCr 4:2:0)
Field : None
Number of planes : 1
Flags :
Colorspace : Default
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Full Range
Plane 0 :
Bytes per Line : 1920
Size Image : 3110400
^C
[root@RK356X:/]# uname -a
Linux RK356X 4.19.206 #16 SMP Tue Dec 14 17:50:04 CST 2021 aarch64 GNU/Linux
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]#
dmesg|grep colorbar 看一下,好像没有看见打印彩条
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]#
[root@RK356X:/]# dmesg|grep colorbar
[ 63.577044] xc7160 4-001b: colorbar on !!!
[root@RK356X:/]#
我这边试了linux和Android的固件都可以出图
[root@RK356X:/]#
ight=1080,pixelformat='NV12' --stream-mmap=4
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
	Pixel Format      : 'NV12' (Y/CbCr 4:2:0)
	Field             : None
	Flags             :
	Plane 0           :
idx: 0 seq:      1 bytesused: 3110400 ts: 25.431010
idx: 1 seq:      2 bytesused: 3110400 ts: 25.464393 delta: 33.383 ms
idx: 2 seq:      3 bytesused: 3110400 ts: 25.497672 delta: 33.279 ms
idx: 3 seq:      4 bytesused: 3110400 ts: 25.531001 delta: 33.329 ms
idx: 0 seq:     12 bytesused: 3110400 ts: 26.025495 delta: 494.494 ms fps: 18.50dropped: 7
idx: 1 seq:     13 bytesused: 3110400 ts: 26.058810 delta: 33.315 ms fps: 19.11
idx: 2 seq:     14 bytesused: 3110400 ts: 26.092090 delta: 33.280 ms fps: 19.66
idx: 3 seq:     15 bytesused: 3110400 ts: 26.125519 delta: 33.429 ms fps: 20.16
idx: 0 seq:     16 bytesused: 3110400 ts: 26.158809 delta: 33.290 ms fps: 20.61
idx: 1 seq:     17 bytesused: 3110400 ts: 26.192125 delta: 33.316 ms fps: 21.02
idx: 2 seq:     18 bytesused: 3110400 ts: 26.225438 delta: 33.313 ms fps: 21.40
idx: 3 seq:     19 bytesused: 3110400 ts: 26.258768 delta: 33.330 ms fps: 21.75
idx: 0 seq:     20 bytesused: 3110400 ts: 26.292127 delta: 33.359 ms fps: 22.06
idx: 1 seq:     21 bytesused: 3110400 ts: 26.325430 delta: 33.303 ms fps: 22.36
手头上有多余的板子吗,没有建议你走一下售后。把板子和摄像头模组寄过来分析一下,写明让软件工程师处理
手头上有多余的板子吗,没有建议你走一下售后。把板子和摄像 …
手头就这一块板子,摄像头新买的。
给个联系方式,寄过去分析下吧。
联系售后,你可以把帖子发给售后看一下。到时候你把单号私发给我
快递已发,单号:SF1139344208697, 请注意查收 ,谢谢。
好的
