移植自己打包的Ubuntu启动时卡死,按照官网的教程
DDR Version V1.11 20211103
ddrconfig:7
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB
tdqss: cs0 dqs0: 48ps, dqs1: -48ps, dqs2: 24ps, dqs3: -120ps,
tdqss: cs1 dqs0: 72ps, dqs1: -48ps, dqs2: 24ps, dqs3: -120ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:0
vrefinner:41%, vrefout:41%
dram drv:40,odt:0
clk skew:0x60
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1560MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x17
cs 0:
the read training result:
DQS0:0x36, DQS1:0x37, DQS2:0x39, DQS3:0x34,
min :0x10 0x11 0x13 0x10 0x2 0xa 0xb 0x4 , 0xb 0xa 0x3 0x1 0xf 0xc 0xf 0x9 ,
0x15 0x15 0xc 0xb 0x4 0x2 0x4 0x4 , 0xe 0xb 0x9 0x1 0x11 0x11 0xe 0x11 ,
mid :0x2b 0x2c 0x2e 0x2b 0x1d 0x24 0x26 0x20 ,0x27 0x26 0x1e 0x1d 0x2b 0x27 0x2a 0x25 ,
0x2e 0x2e 0x27 0x26 0x1f 0x1e 0x1f 0x20 ,0x28 0x26 0x23 0x1c 0x2c 0x2c 0x29 0x2b ,
max :0x46 0x48 0x49 0x46 0x39 0x3f 0x41 0x3d ,0x43 0x42 0x3a 0x3a 0x47 0x43 0x46 0x41 ,
0x47 0x47 0x43 0x41 0x3a 0x3b 0x3a 0x3d ,0x43 0x41 0x3d 0x38 0x47 0x48 0x45 0x45 ,
range:0x36 0x37 0x36 0x36 0x37 0x35 0x36 0x39 ,0x38 0x38 0x37 0x39 0x38 0x37 0x37 0x38 ,
0x32 0x32 0x37 0x36 0x36 0x39 0x36 0x39 ,0x35 0x36 0x34 0x37 0x36 0x37 0x37 0x34 ,
the write training result:
DQS0:0x20, DQS1:0xe, DQS2:0x1b, DQS3:0x0,
min :0x6f 0x72 0x73 0x71 0x61 0x66 0x68 0x68 0x68 ,0x53 0x53 0x4b 0x4f 0x57 0x56 0x57 0x53 0x50 ,
0x6c 0x6e 0x65 0x64 0x5c 0x59 0x5c 0x5f 0x62 ,0x4e 0x4c 0x4a 0x46 0x51 0x52 0x4f 0x52 0x4a ,
mid :0x8c 0x8f 0x90 0x8d 0x7c 0x81 0x84 0x82 0x82 ,0x70 0x70 0x66 0x69 0x73 0x71 0x72 0x6e 0x6c ,
0x87 0x88 0x80 0x80 0x77 0x73 0x77 0x7a 0x7c ,0x6a 0x67 0x64 0x60 0x6d 0x6e 0x6a 0x6e 0x65 ,
max :0xa9 0xad 0xad 0xa9 0x98 0x9c 0xa1 0x9c 0x9c ,0x8e 0x8d 0x82 0x83 0x90 0x8d 0x8e 0x89 0x88 ,
0xa3 0xa3 0x9b 0x9c 0x92 0x8e 0x92 0x95 0x97 ,0x87 0x83 0x7e 0x7b 0x89 0x8a 0x86 0x8b 0x81 ,
range:0x3a 0x3b 0x3a 0x38 0x37 0x36 0x39 0x34 0x34 ,0x3b 0x3a 0x37 0x34 0x39 0x37 0x37 0x36 0x38 ,
0x37 0x35 0x36 0x38 0x36 0x35 0x36 0x36 0x35 ,0x39 0x37 0x34 0x35 0x38 0x38 0x37 0x39 0x37 ,
cs 1:
DQS0:0x37, DQS1:0x36, DQS2:0x36, DQS3:0x33,
min :0x10 0x11 0x13 0xf 0x2 0x9 0xa 0x4 , 0xa 0x9 0x2 0x0 0xd 0xc 0xe 0x8 ,
0x13 0x14 0xc 0xb 0x3 0x2 0x3 0x4 , 0xe 0xb 0x9 0x1 0x11 0x11 0xf 0x11 ,
mid :0x2b 0x2d 0x2e 0x2a 0x1d 0x24 0x26 0x20 ,0x25 0x24 0x1d 0x1c 0x29 0x28 0x29 0x24 ,
0x2b 0x2b 0x25 0x24 0x1c 0x1d 0x1c 0x1f ,0x28 0x26 0x23 0x1c 0x2c 0x2c 0x2a 0x2b ,
max :0x47 0x49 0x49 0x46 0x39 0x3f 0x42 0x3c ,0x41 0x40 0x38 0x38 0x46 0x44 0x45 0x40 ,
0x43 0x43 0x3e 0x3d 0x36 0x38 0x36 0x3a ,0x43 0x41 0x3d 0x38 0x47 0x47 0x45 0x45 ,
range:0x37 0x38 0x36 0x37 0x37 0x36 0x38 0x38 ,0x37 0x37 0x36 0x38 0x39 0x38 0x37 0x38 ,
0x30 0x2f 0x32 0x32 0x33 0x36 0x33 0x36 ,0x35 0x36 0x34 0x37 0x36 0x36 0x36 0x34 ,
min :0x73 0x77 0x77 0x75 0x66 0x6b 0x6c 0x6c 0x6c ,0x55 0x55 0x4d 0x50 0x5a 0x58 0x59 0x56 0x53 ,
0x6a 0x6c 0x64 0x63 0x5b 0x58 0x5b 0x5d 0x5f ,0x4b 0x4a 0x47 0x43 0x50 0x50 0x4e 0x51 0x47 ,
mid :0x90 0x93 0x94 0x91 0x81 0x86 0x88 0x86 0x86 ,0x72 0x72 0x68 0x6a 0x76 0x73 0x74 0x70 0x6e ,
0x86 0x87 0x7f 0x7f 0x76 0x73 0x75 0x78 0x7b ,0x68 0x66 0x62 0x5e 0x6b 0x6d 0x68 0x6d 0x62 ,
max :0xae 0xb0 0xb1 0xae 0x9c 0xa1 0xa5 0xa1 0xa1 ,0x8f 0x8f 0x83 0x85 0x92 0x8f 0x8f 0x8b 0x89 ,
0xa3 0xa3 0x9b 0x9b 0x92 0x8e 0x90 0x94 0x97 ,0x86 0x83 0x7e 0x7a 0x87 0x8a 0x83 0x89 0x7e ,
range:0x3b 0x39 0x3a 0x39 0x36 0x36 0x39 0x35 0x35 ,0x3a 0x3a 0x36 0x35 0x38 0x37 0x36 0x35 0x36 ,
0x39 0x37 0x37 0x38 0x37 0x36 0x35 0x37 0x38 ,0x3b 0x39 0x37 0x37 0x37 0x3a 0x35 0x38 0x37 ,
CA Training result:
cs:0 min :0x4b 0x44 0x40 0x39 0x40 0x34 0x44 ,0x49 0x44 0x3e 0x37 0x3c 0x37 0x44 ,
cs:0 mid :0x87 0x85 0x7a 0x79 0x7c 0x75 0x6f ,0x86 0x83 0x7b 0x76 0x78 0x76 0x70 ,
cs:0 max :0xc3 0xc7 0xb5 0xb9 0xb8 0xb6 0x9b ,0xc3 0xc2 0xb8 0xb6 0xb5 0xb5 0x9d ,
cs:0 range:0x78 0x83 0x75 0x80 0x78 0x82 0x57 ,0x7a 0x7e 0x7a 0x7f 0x79 0x7e 0x59 ,
cs:1 min :0x48 0x4c 0x3d 0x40 0x40 0x3c 0x48 ,0x46 0x49 0x3b 0x3c 0x3c 0x3d 0x44 ,
cs:1 mid :0x88 0x87 0x7c 0x7b 0x7e 0x76 0x76 ,0x87 0x83 0x7c 0x76 0x7a 0x77 0x73 ,
cs:1 max :0xc9 0xc2 0xbc 0xb6 0xbd 0xb1 0xa4 ,0xc9 0xbe 0xbe 0xb0 0xb9 0xb1 0xa3 ,
cs:1 range:0x81 0x76 0x7f 0x76 0x7d 0x75 0x5c ,0x83 0x75 0x83 0x74 0x7d 0x74 0x5f ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-g5961c0c398 #anzhi (Dec 14 2021 - 09:01:29)
unknown raw ID phN
Trying to boot from MMC2
mmc_init: -95, time 9
Trying to boot from MMC1
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(fe4f274c06…) + OK
## Checking uboot 0x00a00000 … sha256(83854851b1…) + OK
## Checking fdt 0x00b22630 … sha256(30938731de…) + OK
## Checking atf-2 0x00068000 … sha256(8d44036095…) + OK
## Checking atf-3 0xfdcd0000 … sha256(e410275b51…) + OK
## Checking atf-4 0xfdcc9000 … sha256(990c53fc01…) + OK
## Checking atf-5 0x00066000 … sha256(315a4195a9…) + OK
## Checking optee 0x08400000 … sha256(5a22c90dfc…) + OK
Total: 224.239 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-181-gc9a647cae:cl
NOTICE: BL31: Built : 10:55:41, Oct 18 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #hisping.lin (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug 4 07:11:39 UTC 2021 aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09-g5961c0c398 #anzhi (Dec 14 2021 - 09:01:29 +0000)
Model: Firefly RK3568 Board
PreSerial: 2, raw, 0xfe660000
DRAM: 7.7 GiB
Sysmem: init
Relocation Offset: ed356000
Relocation fdt: eb9f8310 - eb9fece0
CR: M/C/I
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 100000Hz
PMIC: RK8090 (on=0x10, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
Model: AIO-3568J HDMI (Linux)
VOP have 1 active VP
vp0 have layer nr:6[0 2 4 1 3 5 ], primary plane: 4
vp1 have layer nr:0, primary plane: 0
vp2 have layer nr:0, primary plane: 0
hdmi@fe0a0000 disconnected
apll 816000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000, eth0: ethernet@fe2a0000
## Booting FIT Image at 0xe9862700 with size 0x01f94c00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at e9862700 …
Using ‘conf’ configuration
optee api revision: 2.0
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0xe9883300
Data Size: 24119304 Bytes = 23 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00280000
Entry Point: 0x00280000
Hash algo: sha256
Hash value: f51471e67b74e7dba262c95f72f9952721945a025c0b6f5978a474516cc93fbf
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at e9862700 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0xeaf83d00
Data Size: 8860887 Bytes = 8.5 MiB
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 252b580d48d2afa60baba78b73045c9ccc36e894535d5683b9d1d2f4158db7e1
Loading ramdisk from 0xeaf83d00 to 0x0a200000
## Loading fdt from FIT Image at e9862700 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0xe9862f00
Data Size: 131705 Bytes = 128.6 KiB
Load Address: 0x0a100000
Hash algo: sha256
Hash value: 8780cc7f5cc20124a4b525ea38a2df2f8001ab0c7dfbc7da11b8119d4e247913
Loading fdt from 0x0a100000 to 0x0a100000
Loading Kernel Image from 0xe9883300 to 0x00280000 … OK
kernel loaded at 0x00280000, end = 0x01980808
Using Device Tree in place at 000000000a100000, end 000000000a123278
vp0, plane_mask:0x3f, primary-id:4, curser-id:-1
vp1, plane_mask:0x0, primary-id:0, curser-id:-1
vp2, plane_mask:0x0, primary-id:0, curser-id:-1
Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000)
Total: 853.166 ms
[ 0.000000] Linux version 4.19.206 (anzhi@anzhi) (firefly: c0c173e0214eeaa0d057599d2f1c6a83213483b1) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #1 SMP Tue Dec 14 09:02:12 UTC 2021
[ 0.000000] Machine model: AIO-3568J HDMI (Linux)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options ‘’)
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000
[ 0.000000] percpu: Embedded 23 pages/cpu s54184 r8192 d31832 u94208
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1995336
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=sdhci@fe310000 ro rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB)
[ 0.000000] Memory: 7846368K/8108032K available (14718K kernel code, 1986K rwdata, 5220K rodata, 1600K init, 586K bss, 245280K reserved, 16384K cma-reserved)
[ 0.000000] ftrace: allocating 53255 entries in 209 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @210000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @220000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x0000000000230000
[ 0.000000] CPU0: using LPI pending table @0x0000000000240000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x510 with crng_init=0
[ 0.002235] Console: colour dummy device 80x25
[ 0.002697] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003656] pid_max: default: 32768 minimum: 301
[ 0.004293] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004979] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.007485] ASID allocator initialised with 32768 entries
[ 0.008159] rcu: Hierarchical SRCU implementation.
[ 0.011552] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.012753] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.014389] smp: Bringing up secondary CPUs …
[ 0.016306] Detected VIPT I-cache on CPU1
[ 0.016348] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.016403] CPU1: using LPI pending table @0x0000000000250000
[ 0.016462] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.018065] Detected VIPT I-cache on CPU2
[ 0.018103] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.018157] CPU2: using LPI pending table @0x0000000000260000
[ 0.018204] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.019754] Detected VIPT I-cache on CPU3
[ 0.019787] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.019841] CPU3: using LPI pending table @0x0000000000270000
[ 0.019885] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.020019] smp: Brought up 1 node, 4 CPUs
[ 0.026981] SMP: Total of 4 processors activated.
[ 0.027426] CPU features: detected: GIC system register CPU interface
[ 0.028028] CPU features: detected: Privileged Access Never
[ 0.028548] CPU features: detected: LSE atomic instructions
[ 0.029069] CPU features: detected: User Access Override
[ 0.029563] CPU features: detected: 32-bit EL0 Support
[ 0.030045] CPU features: detected: RAS Extension Support
[ 0.030750] CPU: All CPU(s) started at EL2
[ 0.031166] alternatives: patching kernel code
[ 0.039473] devtmpfs: initialized
[ 0.069626] Registered cp15_barrier emulation handler
[ 0.070121] Registered setend emulation handler
[ 0.070881] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.071851] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.073212] pinctrl core: initialized pinctrl subsystem
[ 0.074836] NET: Registered protocol family 16
[ 0.080365] cpuidle: using governor menu
[ 0.080773] Registered FIQ tty driver
[ 0.082057] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.084190] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.090950] console [pstore-1] enabled
[ 0.091309] pstore: Registered ramoops as persistent store backend
[ 0.091914] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.132978] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.134288] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.135592] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.136880] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.138149] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.138877] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.157380] cryptd: max_cpu_qlen set to 1000
[[ 0.159793] console [ttyFIQ0] enabled
[ 0.160482] bootconsole [uart8250] disabled
[ 0.161172] Registered fiq debugger ttyFIQ0
[ 0.162279] vcc3v3_sys: supplied by dc_12v
[ 0.162770] vcc5v0_sys: supplied by dc_12v
[ 0.164996] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.165496] vcc3v3_vga: supplied by vcc3v3_sys
[ 0.165981] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.166476] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.166972] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.170959] rk_iommu fde4b000.iommu: version = 2
[ 0.171770] rk_iommu fdea0800.iommu: version = 2
[ 0.172322] rk_iommu fded0480.iommu: version = 2
[ 0.172717] rk_iommu fdee0800.iommu: version = 2
[ 0.173069] rk_iommu fdef0800.iommu: version = 2
[ 0.173442] rk_iommu fdf40f00.iommu: version = 2
[ 0.173878] rk_iommu fdf80800.iommu: version = 2
[ 0.174258] rk_iommu fdff1a00.iommu: version = 2
[ 0.174644] rk_iommu fe043e00.iommu: version = 2
[ 0.175756] SCSI subsystem initialized
[ 0.176112] usbcore: registered new interface driver usbfs
[ 0.176204] usbcore: registered new interface driver hub
[ 0.176283] usbcore: registered new device driver usb
[ 0.176409] media: Linux media interface: v0.10
[ 0.176486] videodev: Linux video capture interface: v2.00
[ 0.176613] pps_core: LinuxPPS API ver. 1 registered
[ 0.176642] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.176691] PTP clock support registered
[ 0.177106] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 0.180288] Advanced Linux Sound Architecture Driver Initialized.
[ 0.180906] Bluetooth: Core ver 2.22
[ 0.180983] NET: Registered protocol family 31
[ 0.181009] Bluetooth: HCI device and connection manager initialized
[ 0.181040] Bluetooth: HCI socket layer initialized
[ 0.181067] Bluetooth: L2CAP socket layer initialized
[ 0.181134] Bluetooth: SCO socket layer initialized
[ 0.181725] rockchip-cpuinfo cpuinfo: SoC : 35681000
[ 0.181759] rockchip-cpuinfo cpuinfo: Serial : acb47e62fe38f905
[ 0.183291] clocksource: Switched to clocksource arch_sys_counter
[ 0.284107] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.284525] NET: Registered protocol family 2
[ 0.284996] IP idents hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.288742] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes)
[ 0.288953] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.289572] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes)
[ 0.291650] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.291848] UDP hash table entries: 4096 (order: 6, 393216 bytes)
[ 0.292246] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes)
[ 0.292828] NET: Registered protocol family 1
[ 0.293560] RPC: Registered named UNIX socket transport module.
[ 0.293588] RPC: Registered udp transport module.
[ 0.293608] RPC: Registered tcp transport module.
[ 0.293627] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.295539] Trying to unpack rootfs image as initramfs…
[ 0.751217] Freeing initrd memory: 8652K
[ 0.753112] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.756132] Initialise system trusted keyrings
[ 0.756391] workingset: timestamp_bits=61 max_order=21 bucket_order=0
[ 0.764878] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.765935] NFS: Registering the id_resolver key type
[ 0.765992] Key type id_resolver registered
[ 0.766007] Key type id_legacy registered
[ 0.766060] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.766360] fuse init (API version 7.27)
[ 0.767107] SGI XFS with security attributes, no debug enabled
[ 0.770510] NET: Registered protocol family 38
[ 0.770564] Key type asymmetric registered
[ 0.770581] Asymmetric key parser ‘x509’ registered
[ 0.770649] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.770678] io scheduler noop registered
[ 0.770699] io scheduler deadline registered
[ 0.770886] io scheduler cfq registered (default)
[ 0.770915] io scheduler mq-deadline registered
[ 0.770937] io scheduler kyber registered
[ 0.772309] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.772528] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.775633] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.4
[ 0.776035] phy phy-fe8a0000.usb2-phy.1: Linked as a consumer to regulator.5
[ 0.777709] extcon extcon1: failed to create extcon usb2-phy link
[ 0.777900] phy phy-fe8b0000.usb2-phy.2: Linked as a consumer to regulator.4
[ 0.778133] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to regulator.4
[ 0.778321] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[ 0.789509] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.17
[ 0.790281] mpp_service mpp-srv: d47e486b19bd author: Yandong Lin 2021-11-04 video: rockchip: mpp: use dma-buf-cache func
[ 0.790317] mpp_service mpp-srv: probe start
[ 0.791560] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.791615] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.791887] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.792528] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.792556] rkvenc_init:1199: failed to add venc devfreq
[ 0.792994] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 0.794609] iommu: Adding device fdea0400.vdpu to group 1
[ 0.794668] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.794901] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.795668] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.796445] iommu: Adding device fdee0000.vepu to group 3
[ 0.796499] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.796805] mpp_vepu2 fdee0000.vepu: probe device
[ 0.797542] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.798305] iommu: Adding device fdef0000.iep to group 4
[ 0.798359] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.798564] mpp-iep2 fdef0000.iep: probe device
[ 0.799170] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.799406] mpp-iep2 fdef0000.iep: probing finish
[ 0.800151] iommu: Adding device fded0000.jpegd to group 2
[ 0.800207] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.800413] mpp_jpgdec fded0000.jpegd: probe device
[ 0.801127] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.801672] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.801716] rk-pcie 3c0800000.pcie: Missing config reg space
[ 0.801747] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.801800] rk-pcie 3c0800000.pcie: err 0x380000000..0x3807fffff → 0x80000000
[ 0.801830] rk-pcie 3c0800000.pcie: IO 0x380800000..0x3808fffff → 0x80800000
[ 0.801873] rk-pcie 3c0800000.pcie: MEM 0x380900000..0x3bfffffff → 0x80900000
[ 0.801917] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.801972] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.802297] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.802536] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.803010] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.803040] rkvdec2_init:661: No niu aclk reset resource define
[ 0.803070] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.803085] rkvdec2_init:664: No niu hclk reset resource define
[ 0.803384] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.803415] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.803440] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.803463] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 0.803488] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.803569] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 0.803672] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.804156] mpp_service mpp-srv: probe success
[ 0.812183] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.812228] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.815441] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.815480] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.817378] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.818791] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.819923] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 67, base_baud = 1500000) is a 16550A
[ 0.820857] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 68, base_baud = 1500000) is a 16550A
[ 0.821731] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 69, base_baud = 1500000) is a 16550A
[ 0.825591] random: fast init done
[ 0.825936] random: crng init done
[ 0.826374] iommu: Adding device fe040000.vop to group 8
[ 0.826422] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.833114] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.834965] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.837795] rockchip-drm display-subsystem: dmc is disabled
[ 0.838176] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4
[ 0.838218] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1
[ 0.838254] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.838538] [drm] unsupported AFBC format[3432564e]
[ 0.838624] [drm] failed to init overlay plane Cluster0-win1
[ 0.838712] [drm] failed to init overlay plane Cluster1-win1
[ 0.838871] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008fba4d8)
[ 0.839124] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.839862] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.840723] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008fbdff0)
[ 0.840759] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.840773] [drm] No driver support for vblank timestamp query.
[ 0.841077] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 0.841173] rockchip-drm display-subsystem: can’t not find any loader display
[ 0.841207] rockchip-drm display-subsystem: failed to show loader logo
[ 0.841259] [drm] Cannot find any crtc or sizes
[ 0.842307] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.849941] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 0.850127] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.850152] mali fde60000.gpu: Device initialization Deferred
[ 0.851192] brd: module loaded
[ 0.860634] loop: module loaded
[ 0.861259] zram: Added device: zram0
[ 0.861451] lkdtm: No crash points registered, enable through debugfs
[ 0.863251] ahci fc800000.sata: forcing port_map 0x0 → 0x1
[ 0.863387] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 0.863422] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 0.863460] ahci fc800000.sata: port 0 is not capable of FBS
[ 0.864727] scsi host0: ahci
[ 0.865230] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 11
[ 0.869138] libphy: Fixed MDIO Bus: probed
[ 0.869214] CAN device driver interface
[ 0.873807] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 0.873853] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 0.873873] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[ 0.873888] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26).
[ 0.873909] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 0.873986] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 0.879025] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 0.879361] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.879399] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 0.879428] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 0.879453] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 0.879474] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 0.879495] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 0.879554] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 0.879572] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.879587] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 1.010002] libphy: stmmac: probed
[ 1.017129] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 1.017175] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 1.017195] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c).
[ 1.017213] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f).
[ 1.017234] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 1.017311] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 1.022349] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 1.022631] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 1.022659] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 1.022687] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 1.022710] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 1.022730] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 1.022751] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 1.022816] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 1.022843] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.022867] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 1.153333] libphy: stmmac: probed
[ 1.160178] usbcore: registered new interface driver rndis_wlan
[ 1.160290] usbcore: registered new interface driver rtl8150
[ 1.160371] usbcore: registered new interface driver r8152
[ 1.160456] usbcore: registered new interface driver asix
[ 1.160533] usbcore: registered new interface driver ax88179_178a
[ 1.160616] usbcore: registered new interface driver cdc_ether
[ 1.160695] usbcore: registered new interface driver rndis_host
[ 1.160787] usbcore: registered new interface driver cdc_ncm
[ 1.160870] usbcore: registered new interface driver qmi_wwan_q
[ 1.160956] usbcore: registered new interface driver qmi_wwan
[ 1.161019] usbcore: registered new interface driver cdc_mbim
[ 1.162702] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.169279] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.176036] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.176086] ehci-pci: EHCI PCI platform driver
[ 1.176189] ehci-platform: EHCI generic platform driver
[ 1.176721] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.178139] ehci-platform fd800000.usb: EHCI Host Controller
[ 1.178426] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 1.178897] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[ 1.190012] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 1.190375] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.190408] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.190437] usb usb1: Product: EHCI Host Controller
[ 1.190461] usb usb1: Manufacturer: Linux 4.19.206 ehci_hcd
[ 1.190484] usb usb1: SerialNumber: fd800000.usb
[ 1.191138] hub 1-0:1.0: USB hub found
[ 1.191216] hub 1-0:1.0: 1 port detected
[ 1.194043] ehci-platform fd880000.usb: EHCI Host Controller
[ 1.194306] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 1.194766] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000
[ 1.206678] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 1.207016] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.207049] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.207075] usb usb2: Product: EHCI Host Controller
[ 1.207098] usb usb2: Manufacturer: Linux 4.19.206 ehci_hcd
[ 1.207120] usb usb2: SerialNumber: fd880000.usb
[ 1.207731] hub 2-0:1.0: USB hub found
[ 1.207795] hub 2-0:1.0: 1 port detected
[ 1.208907] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.208954] ohci-platform: OHCI generic platform driver
[ 1.209296] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 1.209576] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 1.209869] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000
[ 1.267585] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.267617] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.267634] usb usb3: Product: Generic Platform OHCI controller
[ 1.267649] usb usb3: Manufacturer: Linux 4.19.206 ohci_hcd
[ 1.267663] usb usb3: SerialNumber: fd840000.usb
[ 1.268326] hub 3-0:1.0: USB hub found
[ 1.268409] hub 3-0:1.0: 1 port detected
[ 1.269129] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 1.269395] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 1.269709] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[ 1.327581] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.327612] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.327629] usb usb4: Product: Generic Platform OHCI controller
[ 1.327643] usb usb4: Manufacturer: Linux 4.19.206 ohci_hcd
[ 1.327656] usb usb4: SerialNumber: fd8c0000.usb
[ 1.328303] hub 4-0:1.0: USB hub found
[ 1.328378] hub 4-0:1.0: 1 port detected
[ 1.330755] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.331035] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[ 1.331865] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 1.331954] xhci-hcd xhci-hcd.4.auto: irq 85, io mem 0xfd000000
[ 1.332409] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.332442] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.332468] usb usb5: Product: xHCI Host Controller
[ 1.332491] usb usb5: Manufacturer: Linux 4.19.206 xhci-hcd
[ 1.332512] usb usb5: SerialNumber: xhci-hcd.4.auto
[ 1.333160] hub 5-0:1.0: USB hub found
[ 1.333238] hub 5-0:1.0: 1 port detected
[ 1.333798] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.334037] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 6
[ 1.334074] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 1.334220] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.334443] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.334475] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.334500] usb usb6: Product: xHCI Host Controller
[ 1.334523] usb usb6: Manufacturer: Linux 4.19.206 xhci-hcd
[ 1.334545] usb usb6: SerialNumber: xhci-hcd.4.auto
[ 1.335171] hub 6-0:1.0: USB hub found
[ 1.335245] hub 6-0:1.0: 1 port detected
[ 1.335951] usbcore: registered new interface driver cdc_acm
[ 1.335980] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.336080] usbcore: registered new interface driver cdc_wdm
[ 1.336386] usbcore: registered new interface driver uas
[ 1.336674] usbcore: registered new interface driver usb-storage
[ 1.336834] usbcore: registered new interface driver usbserial_generic
[ 1.336896] usbserial: USB Serial support registered for generic
[ 1.336979] usbcore: registered new interface driver cp210x
[ 1.337035] usbserial: USB Serial support registered for cp210x
[ 1.337189] usbcore: registered new interface driver ftdi_sio
[ 1.337251] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.337599] usbcore: registered new interface driver keyspan
[ 1.337655] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.337697] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.337749] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.337803] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.337903] usbcore: registered new interface driver option
[ 1.337946] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.338433] usbcore: registered new interface driver oti6858
[ 1.338496] usbserial: USB Serial support registered for oti6858
[ 1.338588] usbcore: registered new interface driver pl2303
[ 1.338641] usbserial: USB Serial support registered for pl2303
[ 1.338738] usbcore: registered new interface driver qcserial
[ 1.338795] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.338928] usbcore: registered new interface driver sierra
[ 1.338989] usbserial: USB Serial support registered for Sierra USB modem
[ 1.340992] usbcore: registered new interface driver usbtouchscreen
[ 1.341065] ============ himax_hx83102_init 1742 jjlook ==========
[ 1.341090] ============ himax_hx83102_probe 1725 jjlook ==========
[ 1.341181] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 1.341199] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 1.341708] .. rk pwm remotectl v2.0 init
[ 1.342043] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 1.342546] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[ 1.342592] remotectl-pwm fe6e0030.pwm: cannot find PWR IRQ
[ 1.342613] remotectl-pwm fe6e0030.pwm: pwm sip wakeup config error!!
[ 1.342638] remotectl-pwm fe6e0030.pwm: Donot support ATF Wakeup
[ 1.343651] i2c /dev entries driver
[ 1.346081] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 1.347641] vdd_cpu: supplied by vcc5v0_sys
[ 1.352910] rk808 0-0020: chip id: 0x8090
[ 1.352987] rk808 0-0020: No cache defaults, reading back from HW
[ 1.376924] rk808 0-0020: source: on=0x10, off=0x00
[ 1.376964] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 1.376984] rk808 0-0020: support pmic reset mode:0,0
[ 1.383531] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.383596] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.384082] vdd_logic: supplied by vcc3v3_sys
[ 1.384981] vdd_gpu: supplied by vcc3v3_sys
[ 1.385462] vcc_ddr: supplied by vcc3v3_sys
[ 1.385947] vdd_npu: supplied by vcc3v3_sys
[ 1.386817] vcc_1v8: supplied by vcc3v3_sys
[ 1.387274] vdda0v9_image: supplied by vcc3v3_sys
[ 1.388110] vdda_0v9: supplied by vcc3v3_sys
[ 1.388578] vdda0v9_pmu: supplied by vcc3v3_sys
[ 1.389026] vccio_acodec: supplied by vcc3v3_sys
[ 1.389857] vccio_sd: supplied by vcc3v3_sys
[ 1.390391] vcc3v3_pmu: supplied by vcc3v3_sys
[ 1.391228] vcca_1v8: supplied by vcc3v3_sys
[ 1.391701] vcca1v8_pmu: supplied by vcc3v3_sys
[ 1.392190] vcca1v8_image: supplied by vcc3v3_sys
[ 1.393020] vcc_3v3: supplied by vcc3v3_sys
[ 1.393860] vcc3v3_sd: supplied by vcc3v3_sys
[ 1.394492] rk817-battery rk817-battery: Failed to find matching dt id
[ 1.394836] rk817-charger rk817-charger: Failed to find matching dt id
[ 1.398372] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 1.399024] rk808-rtc rk808-rtc: device is disabled
[ 1.399068] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.401255] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 1.401368] pca953x 1-0021: Linked as a consumer to regulator.0
[ 1.413003] rtc-hym8563 5-0051: rtc core: registered hym8563 as rtc0
[ 1.414092] rtc-hym8563 5-0051: setting system clock to 2021-12-14 09:21:56 UTC (1639473716)
[ 1.415815] gsensor_mc3230 5-004c: sensor_register_device: gs_mc3230, id = 27
[ 1.415852] i2c i2c-5: sensor_probe: gs_mc3230,00000000818ff14c
[ 1.415911] gsensor_mc3230 5-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x0000000013f7f495
[ 1.453500] [Gsensor] init_3230_ctl_data 457 : error: -6
[ 1.453532] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor
[ 1.453548] gsensor_mc3230 5-004c: sensor_chip_init:fail to init sensor
[ 1.453563] i2c i2c-5: sensor_probe failed -2
[ 1.453563]
[ 1.457640] iommu: Adding device fdff0000.rkisp to group 7
[ 1.457703] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[ 1.457970] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 1.457993] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 1.458044] rkisp_hw fdff0000.rkisp: can’t request region for resource [mem 0xfdff0000-0xfdffffff]
[ 1.459424] rkisp rkisp-vir0: rkisp driver version: v01.07.00
[ 1.459564] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 1.459845] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 1.459887] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 1.463402] usbcore: registered new interface driver uvcvideo
[ 1.463438] USB Video Class driver (1.1.1)
[ 1.463839] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.29
[ 1.463907] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 1.464070] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 1.464238] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.27
[ 1.464287] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 1.464490] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.28
[ 1.464538] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 1.464681] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.23
[ 1.464740] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 1.464900] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.33
[ 1.464963] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 1.465116] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 1.465286] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 1.469813] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 1.471428] Bluetooth: HCI UART driver ver 2.3
[ 1.471463] Bluetooth: HCI UART protocol H4 registered
[ 1.471485] Bluetooth: HCI UART protocol ATH3K registered
[ 1.471789] Bluetooth: HCI UART protocol Broadcom registered
[ 1.471910] usbcore: registered new interface driver bfusb
[ 1.472024] usbcore: registered new interface driver btusb
[ 1.472417] cpu cpu0: leakage=25
[ 1.473118] cpu cpu0: Linked as a consumer to regulator.18
[ 1.488432] cpu cpu0: temp=45000, pvtm=84428 (84298 + 130)
[ 1.491502] cpu cpu0: Dropping the link to regulator.18
[ 1.491577] cpu cpu0: pvtm-volt-sel=1
[ 1.492525] cpu cpu0: Linked as a consumer to regulator.18
[ 1.492609] cpu cpu0: Dropping the link to regulator.18
[ 1.493359] cpu cpu0: Linked as a consumer to regulator.18
[ 1.494481] cpu cpu0: avs=0
[ 1.494584] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[ 1.494933] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.498629] cpu cpu0: failed to find power_model node
[ 1.500399] sdhci: Secure Digital Host Controller Interface driver
[ 1.500427] sdhci: Copyright(c) Pierre Ossman
[ 1.500437] Synopsys Designware Multimedia Card Interface Driver
[ 1.501640] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.501907] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 1.501927] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 1.501996] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 1.502184] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 1.502201] mmc_host mmc3: card is non-removable.
[ 1.583371] usb 5-1: new high-speed USB device number 2 using xhci-hcd
[ 1.620986] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.634248] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.634394] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 1.634416] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 1.634492] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 50,32 bit host data width,256 deep fifo
[ 1.634632] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.34
[ 1.634760] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.28
[ 1.646997] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.660084] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.661457] mmc0: Unknown controller version (5). You may experience problems.
[ 1.667873] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.669654] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.671507] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.674745] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.693044] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 1.701984] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.703204] usbcore: registered new interface driver usbhid
[ 1.703265] usbhid: USB HID core driver
[ 1.704337] rockchip,bus bus-npu: Linked as a consumer to regulator.19
[ 1.704425] rockchip,bus bus-npu: Failed to get leakage
[ 1.704559] rockchip,bus bus-npu: pvtm = 84428, form pvtm_value
[ 1.704636] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 1.705263] rockchip,bus bus-npu: avs=0
[ 1.712087] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.30
[ 1.714511] rksfc_base v1.1 2016-01-08
[ 1.716516] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 1.716863] rkflash_dev_init enter
[ 1.716933] sfc nor id: ef 60 19
[ 1.716996] rkflash[1] init success
[ 1.720197] sfc_nor_mtd_init register mtd succuss
[ 1.720264] rkflash_dev_init device register as mtd dev, ret= 0
[ 1.722459] usbcore: registered new interface driver snd-usb-audio
[ 1.727142] usb 5-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91
[ 1.727223] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.727253] usb 5-1: Product: USB2.1 Hub
[ 1.727280] usb 5-1: Manufacturer: GenesysLogic
[ 1.728963] rk817-codec rk817-codec: DMA mask not set
[ 1.729830] mmc0: new HS200 MMC card at address 0001
[ 1.730943] rk817_codec_parse_dt_property: rk809 hp adc effective value of detection 976~1024
[ 1.731241] invalid rk817->hp_det_gpio: -2
[ 1.731320] invalid gpio: -2
[ 1.732370] mmcblk0: mmc0:0001 TX2964 58.3 GiB
[ 1.733879] mmcblk0boot0: mmc0:0001 TX2964 partition 1 4.00 MiB
[ 1.735254] mmcblk0boot1: mmc0:0001 TX2964 partition 2 4.00 MiB
[ 1.735870] mmcblk0rpmb: mmc0:0001 TX2964 partition 3 4.00 MiB, chardev (239:0)
[ 1.739506] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 1.742520] Initializing XFRM netlink socket
[ 1.742931] NET: Registered protocol family 10
[ 1.743959] Segment Routing with IPv6
[ 1.744061] NET: Registered protocol family 17
[ 1.744091] NET: Registered protocol family 15
[ 1.744126] can: controller area network core (rev 20170425 abi 9)
[ 1.744264] NET: Registered protocol family 29
[ 1.744296] can: raw protocol (rev 20170425)
[ 1.744313] can: broadcast manager protocol (rev 20170425 t)
[ 1.744333] can: netlink gateway (rev 20170425) max_hops=1
[ 1.744683] Bluetooth: RFCOMM socket layer initialized
[ 1.744723] Bluetooth: RFCOMM ver 1.11
[ 1.744756] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.744776] Bluetooth: HIDP socket layer initialized
[ 1.744820] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.744834] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.745482] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.745535] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 1.745551] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.745563] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.745644] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 1.745664] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.745678] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.745687] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 1.745695] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.746334] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 1.746370] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96.
[ 1.746396] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 109.
[ 1.746413] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 95.
[ 1.746517] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.746670] [BT_RFKILL]: ** disable irq
[ 1.746814] [BT_RFKILL]: bt_default device registered.
[ 1.746987] Key type dns_resolver registered
[ 1.747359] flash vendor_init_thread!
[ 1.747384] flash vendor storage:20170308 ret = -1
[ 1.750419] Loading compiled-in X.509 certificates
[ 1.751430] pstore: Using compression: deflate
[ 1.752712] rga2: Driver loaded successfully ver:3.2.63318
[ 1.753332] rga2: Module initialized.
[ 1.767148] vendor storage:20190527 ret = 0
[ 1.768582] mmc_host mmc3: Bus speed (slot 0) = 50000000Hz (slot req 100000000Hz, actual 50000000HZ div = 0)
[ 1.776358] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 354
[ 1.778264] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[ 1.782597] hub 5-1:1.0: USB hub found
[ 1.782881] hub 5-1:1.0: 4 ports detected
[ 1.793880] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 1.793950] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 1.794071] mali fde60000.gpu: Linked as a consumer to regulator.20
[ 1.794218] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 1.794309] mali fde60000.gpu: leakage=8
[ 1.794764] mali fde60000.gpu: avs=0
[ 1.794789] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 1.795147] asoc-simple-card hdmi-sound: i2s-hifi ↔ fe400000.i2s mapping ok
[ 1.795220] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 1.795299] mali fde60000.gpu: No priority control manager is configured
[ 1.795315] mali fde60000.gpu: No memory group manager is configured
[ 1.795801] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.796458] mali fde60000.gpu: Probed as mali0
[ 1.801262] asoc-simple-card rk809-sound: rk817-hifi ↔ fe410000.i2s mapping ok
[ 1.801291] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 1.801304] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.801314] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 1.801324] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.801334] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 1.801344] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 1.801353] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 1.801363] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 1.803851] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.816649] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 1.846817] usb 6-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 1.950742] devfreq fde60000.gpu: Couldn’t update frequency transition information.
[ 1.959888] usb 6-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91
[ 1.959904] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.959911] usb 6-1: Product: USB3.2 Hub
[ 1.959917] usb 6-1: Manufacturer: GenesysLogic
[ 1.977518] wk2xxx_serial_init()
[ 1.977567] wk2xxx_request_port
[ 1.977576] ttysWK0 at I/O 0x1 (irq = 113, base_baud = 460800) is a wk2xxx
[ 1.977796] uart_add_one_port success for line i:= 0 with right 0
[ 1.977810] wk2xxx_request_port
[ 1.977821] ttysWK1 at I/O 0x2 (irq = 113, base_baud = 460800) is a wk2xxx
[ 1.977989] uart_add_one_port success for line i:= 1 with right 0
[ 1.978003] wk2xxx_request_port
[ 1.978014] ttysWK2 at I/O 0x3 (irq = 113, base_baud = 460800) is a wk2xxx
[ 1.978175] uart_add_one_port success for line i:= 2 with right 0
[ 1.978189] wk2xxx_request_port
[ 1.978199] ttysWK3 at I/O 0x4 (irq = 113, base_baud = 460800) is a wk2xxx
[ 1.978362] uart_add_one_port success for line i:= 3 with right 0
[ 1.978374] uart_add_one_port = 0x0
[ 1.978983] register spi return v = :0
[ 1.978999] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 1.979007] ======== dhd_wlan_init_plat_data ========
[ 1.979012] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.979055] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=114, oob_irq_flags=0x414
[ 1.979064] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 1.979073] dhd_wifi_platform_load: Enter
[ 1.979082] Power-up adapter ‘DHD generic adapter’
[ 1.980084] wifi_platform_set_power = 1, delay: 200 msec
[ 1.980101] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.980110] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.980118] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 1.980127] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 1.990415] hub 6-1:1.0: USB hub found
[ 1.990780] hub 6-1:1.0: 4 ports detected
[ 2.286870] wifi_platform_bus_enumerate device present 1
[ 2.286950] ======== Card detection to detect SDIO card! ========
[ 2.286975] mmc3:mmc host rescan start!
[ 2.303114] bcmsdh_register: register client driver
[ 2.303293] bcmsdh_sdmmc_probe: Enter num=1
[ 2.303941] bcmsdh_sdmmc_probe: Enter num=2
[ 2.303953] bus num (host idx)=3, slot num (rca)=1
[ 2.303965] found adapter info ‘DHD generic adapter’
[ 2.304023] sdioh_attach: set sd_f2_blocksize 256
[ 2.304084] sdioh_attach: sd clock rate = 0
[ 2.304362] dhdsdio_probe : no mutex held. set lock
[ 2.304520] F1 signature read @0x18000000=0x1042aae8
[ 2.308837] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 2.309524] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 2.309605] [dhd] dhd_conf_set_chiprev : chip=0xaae8, chiprev=2
[ 2.310220] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.310233] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.310243] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.310251] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.310260] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.310461] dhd_log_dump_init: kernel log buf size = 256KB; logdump_prsrv_tailsize = 80KB; limit prsrv tail size to = 38KB
[ 2.311250] dhd_attach(): thread:dhd_watchdog_thread:6b started
[ 2.311386] dhd_attach(): thread:dhd_dpc:6c started
[ 2.311508] dhd_attach(): thread:dhd_rxf:6d started
[ 2.311527] dhd_deferred_work_init: work queue initialized
[ 2.311541] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 2.311604] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 2.311618] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 2.311632] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 2.320336] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 2.320491] Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 2.320921] Register interface [wlan0] MAC: 10:2c:6b:7f:87:18
[ 2.320921]
[ 2.321015] dhd_dbg_detach_pkt_monitor, 2100
[ 2.321029] dhd_bus_devreset: == Power OFF ==
[ 2.321246] dhd_bus_stop: making DHD_BUS_DOWN
[ 2.321284] bcmsdh_oob_intr_unregister: Enter
[ 2.321295] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.321311] dhd_bus_devreset: making dhdpub up FALSE
[ 2.321322] dhd_txglom_enable: enable 0
[ 2.321331] dhd_bus_devreset: making DHD_BUS_DOWN
[ 2.321340] dhd_bus_devreset: WLAN OFF DONE
[ 2.321387] wifi_platform_set_power = 0, delay: 0 msec
[ 2.321401] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.321410] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.321428] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 2.321437] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 2.321447] dhdsdio_probe : the lock is released.
[ 2.322071] dhd_module_init: Exit err=0
[ 2.322417] ==gsl_ts_init==
[ 2.322478] ret=0
[ 2.323238] iommu: Adding device fde40000.npu to group 0
[ 2.323271] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 2.323740] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 2.323861] RKNPU fde40000.npu: Linked as a consumer to regulator.22
[ 2.323885] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
[ 2.324302] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[ 2.324549] RKNPU fde40000.npu: leakage=4
[ 2.324975] RKNPU fde40000.npu: avs=0
[ 2.325532] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.325558] RKNPU fde40000.npu: failed to find power_model node
[ 2.325569] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 2.325579] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 2.326559] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.331154] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 2.331247] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.331262] cfg80211: failed to load regulatory.db
[ 2.332560] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 2.333729] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘09:04:16’, on ‘Dec 14 2021’.
[ 2.334073] Mali:
[ 2.334075] Mali device driver loaded
[ 2.334308] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 2.334538] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 2.336905] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 2.336977] xc7160 4-001b: Linked as a consumer to regulator.0
[ 2.337010] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 2.337066] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 2.337114] xc7160 4-001b: could not get default pinstate
[ 2.337126] xc7160 4-001b: could not get sleep pinstate
[ 2.337145] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 2.337155] xc7160 4-001b: xc7160 num data lanes is 4
[ 2.353588] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed
[ 2.354916] xc7160: probe of 4-001b failed with error -5
[ 2.355071] rkisp rkisp-vir0: clear unready subdev num: 4
[ 2.355113] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.355994] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.356027] rkisp-vir0: update sensor failed
[ 2.363986] ret 1024 0
[ 2.364377] ALSA device list:
[ 2.364396] #0: rockchip,hdmi
[ 2.364403] #1: rockchip,rk809-codec
[ 2.367691] Freeing unused kernel memory: 1600K
[ 2.370030] Run /init as init process
Loading, please wait…
/dev/console is Ok
[ 2.398944] phy phy-fe8a0000.usb2-phy.1: charger = USB_SDP_CHARGER
starting version 237
[ 2.830264] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.843563] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x1
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 4.285583] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 4.546104] EXT4-fs (mmcblk0p7): recovery complete
[ 4.546152] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/4.19.206 in initramfs.
done.
run-init: /sbin/init: No such file or directory
Target filesystem doesn’t have requested /sbin/init.
run-init: /etc/init: No such file or directory
run-init: /bin/init: No such file or directory
run-init: /bin/sh: Exec format error
[ 4.647380] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[ 4.647380]
[ 4.648438] CPU: 2 PID: 1 Comm: run-init Not tainted 4.19.206 #1
[ 4.648965] Hardware name: AIO-3568J HDMI (Linux) (DT)
[ 4.649425] Call trace:
[ 4.649656] dump_backtrace+0x0/0x188
[ 4.649982] show_stack+0x24/0x30
[ 4.650285] dump_stack+0x8c/0xb4
[ 4.650587] panic+0x138/0x2b0
[ 4.650867] do_exit+0x1a4/0x868
[ 4.651156] do_group_exit+0x0/0xa0
[ 4.651471] el0_svc_common.constprop.0+0xe8/0x168
[ 4.651897] el0_svc_handler+0x70/0x8c
[ 4.652233] el0_svc+0x8/0xc
[ 4.652491] SMP: stopping secondary CPUs
[ 4.652876] PMU CRU:
[ 4.653084] 00000000: 00006064 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[ 4.653834] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.654585] 00000040: 00002063 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[ 4.655335] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.656086] 00000080: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.656837] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.657586] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.658336] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.659085] 00000100: 00000080 0040b71b 00000001 00000001 00000800 00000000 00000001 00000009
[ 4.659834] 00000120: 0000050f 00008888 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.660583] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.661333] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.662082] 00000180: 00000000 00003dff 00009579 00000000 00000000 00000000 00000000 00000000
[ 4.662831] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.663580] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.664330] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.665079] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.665828] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.666573] 00000240: 00040020 00000000
[ 4.666918] CRU:
[ 4.667087] 00000000: 00001043 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[ 4.667836] 00000020: 00004082 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[ 4.668584] 00000040: 00002063 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[ 4.669334] 00000060: 0000107d 00001443 00000000 00000007 00007f00 00000000 00000000 00000000
[ 4.670083] 00000080: 00002064 00001441 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.670831] 000000a0: 0000307d 00001442 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.671580] 000000c0: 00004455 00000000 00000000 00000000 00640064 00000000 00000000 00000103
[ 4.672329] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.673078] 00000100: 000080c0 00000000 00008100 00000505 00000a0a 00000111 00004155 000080e5
[ 4.673827] 00000120: 00000053 00000100 00000001 00008000 00040004 00008000 00040004 00000401
[ 4.674576] 00000140: 01003057 00008000 00040004 00008000 00040004 00008000 00040004 00004000
[ 4.675324] 00000160: 00040004 0000000b 00000000 00000010 00001011 00001c30 00000520 00000004
[ 4.676073] 00000180: 00000320 00000004 00000310 0000c001 0000c0c0 00003100 00000001 00000000
[ 4.676821] 000001a0: 00000401 00000003 00000103 00002100 00000203 00000003 00000000 00000103
[ 4.677570] 000001c0: 00000003 00000303 00000001 00001725 0000200b 00000000 0000200b 00000000
[ 4.678319] 000001e0: 0000200b 00000000 0000200b 00000000 0000200b 00000000 0000200b 00000000
[ 4.679069] 00000200: 0000200b 00000000 0000200b 00000000 0000200b 00000000 00008903 00000289
[ 4.679817] 00000220: 00001500 00000000 0000001f 00000302 00000705 00000f0b 0000013b 00000303
[ 4.680566] 00000240: 00000f07 00002713 00001f09 00008000 00040004 00003b2f 00000101 00000302
[ 4.681314] 00000260: 00000704 0000130f 00001f27 00000000 00000000 00000000 00000000 00000000
[ 4.682063] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.682811] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.683559] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.684308] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.685056] 00000300: 00000000 00000e00 000001c9 00000e0a 00000000 0000f300 0000ffff 0000ffff
[ 4.685805] 00000320: 0000f87f 00000c0b 00000010 00000077 00001f1f 00000040 00000000 0000119c
[ 4.686554] 00000340: 00000000 00000467 00002e07 00000717 00003d40 000003c7 0000d033 0000fff3
[ 4.687303] 00000360: 000001c3 000001f3 00000e00 0000f7e0 0000fff6 0000ffff 0000cfff 0000f2ab
[ 4.688051] 00000380: 00008fe7 0000e000 00007800 00000000 00000000 00000000 00000000 00000000
[ 4.688800] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.689549] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.690297] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.691046] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.691794] 00000420: 00000000 00000000 00000002 00000002 00000000 00000000 00000000 00000000
[ 4.692542] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.693292] 00000460: 00000000 00000000 00000400 00000000 00000000 00000000 00000000 00000000
[ 4.694041] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.694790] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.695539] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.696287] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.697036] 00000500: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[ 4.697785] 00000520: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[ 4.698533] 00000540: 00040020 00000000 00040020 00000000 00000000 00000000 00000000 00000000
[ 4.699281] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.700027] 00000580: 00000002 00000000
[ 4.700373] CPU0 online:0
[ 4.700610] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.701174] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.701738] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.702306] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.702870] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.703434] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.704001] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.704565] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.705128] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.705694] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.706258] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.706822] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.707385] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.707953] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.708517] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.709081] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.709648] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.710215] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.710779] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.711344] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.711909] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.712473] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.713038] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.713602] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.714167] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.714731] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.715295] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.715860] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.716424] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.716988] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.717553] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.718118] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.718678]
[ 4.718819] CPU1 online:0
[ 4.719054] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.719618] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.720184] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.720748] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.721313] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.721879] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.722444] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.723008] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.723572] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.724136] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.724703] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.725267] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.725831] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.726400] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.726964] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.727533] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.728098] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.728663] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.729229] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.729793] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.730359] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.730923] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.731488] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.732053] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.732618] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.733183] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.733748] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.734312] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.734875] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.735440] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.736007] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.736573] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.737133]
[ 4.737274] CPU2 online:1
[ 4.737512] EL2(NS) PC: <0xffffff80085a0b68> rockchip_panic_notify+0x88/0x244
[ 4.738219]
[ 4.738360] CPU3 online:0
[ 4.738595] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.739161] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.739730] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.740294] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.740861] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.741428] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.741992] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.742556] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.743122] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.743693] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.744258] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.744821] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.745386] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.745951] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.746517] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.747081] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.747644] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.748208] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.748772] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.749340] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.749907] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.750473] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.751037] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.751601] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.752167] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.752731] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.753295] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.753860] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.754426] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.754990] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.755556] EL2(NS) PC: <0xffffff800809537c> handle_IPI+0x238/0x2a0
[ 4.756121] EL2(NS) PC: <0xffffff8008095380> handle_IPI+0x23c/0x2a0
[ 4.756681]
[ 4.756823] PMU:
[ 4.756993] 00000000: 03003566 00000e0c 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.757742] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.758492] 00000040: 00000000 00000000 00000000 00000000 000001ea 00000000 00000000 00000000
[ 4.759241] 00000060: 000001ea 00000000 000001ea 00000000 0000ffff 0000000f 00000000 00000000
[ 4.759991] 00000080: 00000000 00000000 00000000 00000002 00000000 00000000 0000007d 00000000
[ 4.760741] 000000a0: 0000007d 00000000 00000003 00000000 00000000 00000000 00000000 00000000
[ 4.761492] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.762241] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.762984] Kernel Offset: disabled
[ 4.763297] CPU features: 0x00000004,22002a38
[ 4.763687] Memory Limit: none
[ 4.763979] rockchip-thermal fe710000.tsadc: channal 0: temperature(44 C)
[ 4.764575] THERMAL REGS:
[ 4.764813] 00000000: 00000fc0 00030033 00000301 00000002 00000000 00000000 00000000 00000000
[ 4.765562] 00000020: 00000878 0000085c 00000000 00000000 00000940 00000000 00000000 00000000
[ 4.766312] 00000040: 00000a70 00000a70 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.767061] 00000060: 00000004 00000004 00000656 00000656 00000000 00000000 00000000 00000000
[ 4.767806] 00000080: 00000000 00000000
[ 4.780333] —[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[ 4.780333] ]—
[ 10.509977] WARNING: CPU: 2 PID: 1 at kernel/irq_work.c:102 irq_work_queue_on+0x34/0xc8
[ 10.510680] Modules linked in:
[ 10.510963] CPU: 2 PID: 1 Comm: run-init Not tainted 4.19.206 #1
[ 10.511491] Hardware name: AIO-3568J HDMI (Linux) (DT)
[ 10.511950] pstate: 80400089 (Nzcv daIf +PAN -UAO)
[ 10.512377] pc : irq_work_queue_on+0x34/0xc8
[ 10.512761] lr : update_util_handler+0x78/0x84
[ 10.513152] sp : ffffff8008013b60
[ 10.513452] x29: ffffff8008013b60 x28: 000000000000b731
[ 10.513924] x27: ffffffc1fff451c0 x26: ffffff8008b146a0
[ 10.514396] x25: ffffffc1fff43e48 x24: 0000000000000009
[ 10.514867] x23: 0000000000000000 x22: 0000000000000001
[ 10.515339] x21: ffffffc1fff45040 x20: 0000000272712018
[ 10.515810] x19: 0000000000000003 x18: 000000000000000a
[ 10.516282] x17: 000000000000000a x16: 0000000000000000
[ 10.516753] x15: 00000000000be82d x14: 000000000006d1c8
[ 10.517225] x13: 0032dcd555555555 x12: 000032dcd555bd80
[ 10.517696] x11: 0000000000000800 x10: 0000000000000000
[ 10.518168] x9 : 0000000000000000 x8 : 0000000000000001
[ 10.518639] x7 : 0008000000000000 x6 : 0000000000000004
[ 10.519110] x5 : 00ffffffffffffff x4 : ffffffc1fff43e58
[ 10.519582] x3 : ffffffc1f3639e00 x2 : 000000015dad2730
[ 10.520053] x1 : ffffff80095a4640 x0 : 0000000000000000
[ 10.520525]
[ 10.520525] PC: 0xffffff80081949d8:
[ 10.520962] 49d8 d65f03c0 d53cd040 8b000042 aa0103e0 940ce323 17fffff7 aa0003e4 a9bf7bfd
[ 10.521690] 49f8 910003fd 97ffff8f 72001c1f 540000c0 aa0403e0 97ffffe0 52800020 a8c17bfd
[ 10.522417] 4a18 d65f03c0 52800000 17fffffd aa0003e4 52800800 a9be7bfd 1ac00c20 910003fd
[ 10.523143] 4a38 f9000bf3 2a0103f3 9000a081 91190021 937d7c00 f8616800 9ad32400 37000040
[ 10.523869] 4a58 d4210000 aa0403e0 97ffff76 72001c1f 540003e0 90009f20 91006000 d53cd041
[ 10.524596] 4a78 b8616800 6b00027f 540002c0 d5384100 b9401000 36a00040 d4210000 b000a082
[ 10.525322] 4a98 91006042 91002081 b0009f60 91226000 f873d842 8b020002 aa0103e0 940ce2f0
[ 10.526048] 4ab8 72001c1f 54000060 2a1303e0 97fc0178 52800020 f9400bf3 a8c27bfd d65f03c0
[ 10.526776]
[ 10.526776] LR: 0xffffff8008b14698:
[ 10.527212] 4698 aa1603e3 17fffffa a9be7bfd 910003fd a90153f3 aa0003f3 aa0103f4 aa1e03e0
[ 10.527938] 46b8 d503201f 39414260 350002c0 f9400660 d2807d01 f9402262 cb020282 f9400403
[ 10.528665] 46d8 f9407860 9b017c00 eb00005f 540001a3 f9002274 b940f060 97d86883 f0005401
[ 10.529391] 46f8 f944c021 8b000020 b9415261 f9002660 52800020 39014260 91004260 97da00c4
[ 10.530118] 4718 a94153f3 a8c27bfd d65f03c0 a9bb7bfd 910003fd a90153f3 a9025bf5 a90363f7
[ 10.530845] 4738 f90023f9 aa0003f8 aa1e03e0 d503201f 90005496 911e12d4 12800013 f9402f00
[ 10.531571] 4758 f9400015 aa1503e1 2a1303e0 940e7c0b 2a0003f3 b9400281 6b01001f 54000283
[ 10.532297] 4778 b0005497 910062f7 12800015 d0005374 97d84dcc 91392294 2a1503e0 aa1803e1
[ 10.533024]
[ 10.533024] SP: 0xffffff8008013ae0:
[ 10.533461] 3ae0 00000009 00000000 fff43e48 ffffffc1 08b146a0 ffffff80 fff451c0 ffffffc1
[ 10.534188] 3b00 0000b731 00000000 08013b60 ffffff80 08b14718 ffffff80 08013b60 ffffff80
[ 10.534914] 3b20 08194a58 ffffff80 80400089 00000000 fff45180 ffffffc1 fff45100 ffffffc1
[ 10.535640] 3b40 ffffffff 0000007f fff45100 ffffffc1 08013b60 ffffff80 08194a58 ffffff80
[ 10.536367] 3b60 08013b80 ffffff80 08b14718 ffffff80 fff43e48 ffffffc1 00000001 00000000
[ 10.537093] 3b80 08013ba0 ffffff80 080ef2b0 ffffff80 fff45100 ffffffc1 f1032b80 ffffffc1
[ 10.537820] 3ba0 08013c00 ffffff80 080f0064 ffffff80 fff45100 ffffffc1 f1032b80 ffffffc1
[ 10.538546] 3bc0 00000003 00000000 fff45040 ffffffc1 fff45100 ffffffc1 095bd000 ffffff80
[ 10.539274]
[ 10.539274] X1: 0xffffff80095a45c0:
[ 10.539710] 45c0 ffffffff 00000000 ffffffff ffffffff 00000000 dead4ead ffffffff 00000000
[ 10.540438] 45e0 ffffffff ffffffff 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 10.541164] 4600 00000002 00000100 d61b2500 75a065b0 00000001 00000000 00000000 00000000
[ 10.541891] 4620 00119fff 00000000 0037b0d6 0000001f 01000000 00000000 00000000 00000000
[ 10.542617] 4640 00000004 00000000 0000000f 00000000 0000000f 00000000 0000000f 00000000
[ 10.543343] 4660 00000000 00000000 00000000 00000000 f6c06600 ffffffc1 f6c06800 ffffffc1
[ 10.544069] 4680 f6c06a00 ffffffc1 f6c06c00 ffffffc1 f6c06e00 ffffffc1 f6c07000 ffffffc1
[ 10.544796] 46a0 f6c07200 ffffffc1 f6c02600 ffffffc1 017ed73b 00000001 00000001 00000020
[ 10.545524]
[ 10.545524] X3: 0xffffffc1f3639d80:
[ 10.545961] 9d80 00000000 00000000 ab04bd18 00000000 0002c4a8 00000000 2f4c05e0 00000000
[ 10.546688] 9da0 00029715 00000000 00000001 00000000 00000000 00000000 00000000 00000000
[ 10.547414] 9dc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.548140] 9de0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.548866] 9e00 f365f100 ffffffc1 f3639e08 ffffffc1 f3639e08 ffffffc1 f43e24c8 ffffffc1
[ 10.549592] 9e20 00000000 00000000 096b43a8 ffffff80 f365e6e8 ffffffc1 00000001 00000003
[ 10.550319] 9e40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.551045] 9e60 f365f090 ffffffc1 f365f090 ffffffc1 00000000 00000000 00000000 dead4ead
[ 10.551772]
[ 10.551772] X4: 0xffffffc1fff43dd8:
[ 10.552209] 3dd8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.552935] 3df8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.553661] 3e18 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.554387] 3e38 00000000 00000000 00000000 00000000 08b146a0 ffffff80 f365f080 ffffffc1
[ 10.555114] 3e58 00000000 00000000 00000000 00000000 08b15614 ffffff80 00000000 00000000
[ 10.555840] 3e78 00000000 00000000 08b13734 ffffff80 72712018 00000002 fffeacc6 00000000
[ 10.556566] 3e98 00000001 00000000 00000000 00000000 fff43ea8 ffffffc1 fff43ea8 ffffffc1
[ 10.557292] 3eb8 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[ 10.558024]
[ 10.558024] X21: 0xffffffc1fff44fc0:
[ 10.558472] 4fc0 02400004 00000000 0000003e 00000000 f6c0e100 ffffffc1 00000000 00000000
[ 10.559200] 4fe0 00000000 00000000 00000001 00000000 00000000 00000000 00000000 00000000
[ 10.559927] 5000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.560654] 5020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.561380] 5040 00000001 dead4ead 00000002 00000000 f6ea0000 ffffffc1 00000000 00000000
[ 10.562106] 5060 00000000 00000000 00000003 00000000 00000045 00000000 00000099 00000000
[ 10.562832] 5080 000000a4 00000000 fffea5e1 00000000 fffea5e1 00000000 00000001 00000001
[ 10.563558] 50a0 00000003 00000000 00000000 00000000 00000000 00000000 00000270 00000000
[ 10.564287]
[ 10.564287] X25: 0xffffffc1fff43dc8:
[ 10.564735] 3dc8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.565461] 3de8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.566187] 3e08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.566913] 3e28 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.567640] 3e48 08b146a0 ffffff80 f365f080 ffffffc1 00000000 00000000 00000000 00000000
[ 10.568367] 3e68 08b15614 ffffff80 00000000 00000000 00000000 00000000 08b13734 ffffff80
[ 10.569093] 3e88 72712018 00000002 fffeacc6 00000000 00000001 00000000 00000000 00000000
[ 10.569819] 3ea8 fff43ea8 ffffffc1 fff43ea8 ffffffc1 00000000 dead4ead ffffffff 00000000
[ 10.570545]
[ 10.570545] X26: 0xffffff8008b14620:
[ 10.570993] 4620 d00043fb b940e2a0 6b00029f 5400022b d1000660 b00041c1 8b000320 912f4421
[ 10.571720] 4640 940eae43 aa1a03e1 aa1803e0 940f07f4 f9402bfb aa1303e0 a94153f3 a9425bf5
[ 10.572446] 4660 a94363f7 a9446bf9 a8c67bfd d65f03c0 f9406ea1 8b130320 b874d822 370000f4
[ 10.573173] 4680 aa1703e3 9119af61 11000694 940ebf2b 8b20c273 17ffffe4 aa1603e3 17fffffa
[ 10.573900] 46a0 a9be7bfd 910003fd a90153f3 aa0003f3 aa0103f4 aa1e03e0 d503201f 39414260
[ 10.574627] 46c0 350002c0 f9400660 d2807d01 f9402262 cb020282 f9400403 f9407860 9b017c00
[ 10.575354] 46e0 eb00005f 540001a3 f9002274 b940f060 97d86883 f0005401 f944c021 8b000020
[ 10.576081] 4700 b9415261 f9002660 52800020 39014260 91004260 97da00c4 a94153f3 a8c27bfd
[ 10.576808]
[ 10.576808] X27: 0xffffffc1fff45140:
[ 10.577256] 5140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.577983] 5160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.578709] 5180 72460c00 00000002 00000000 00000000 00000000 00000000 00000000 00000183
[ 10.579435] 51a0 00000000 00000000 00000000 00000000 00000000 00000000 00000201 00000000
[ 10.580161] 51c0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[ 10.580888] 51e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 10.581614] 5200 00000000 00000000 00000001 00000000 0017dbd5 00000000 00000495 00000000
[ 10.582340] 5220 fffeacc0 00000000 00000000 00000000 fff45040 ffffffc1 00000001 00000000
[ 10.583067]
[ 10.583067] X29: 0xffffff8008013ae0:
[ 10.583515] 3ae0 00000009 00000000 fff43e48 ffffffc1 08b146a0 ffffff80 fff451c0 ffffffc1
[ 10.584242] 3b00 0000b731 00000000 08013b60 ffffff80 08b14718 ffffff80 08013b60 ffffff80
[ 10.584968] 3b20 08194a58 ffffff80 80400089 00000000 fff45180 ffffffc1 fff45100 ffffffc1
[ 10.585694] 3b40 ffffffff 0000007f fff45100 ffffffc1 08013b60 ffffff80 08194a58 ffffff80
[ 10.586421] 3b60 08013b80 ffffff80 08b14718 ffffff80 fff43e48 ffffffc1 00000001 00000000
[ 10.587148] 3b80 08013ba0 ffffff80 080ef2b0 ffffff80 fff45100 ffffffc1 f1032b80 ffffffc1
[ 10.587874] 3ba0 08013c00 ffffff80 080f0064 ffffff80 fff45100 ffffffc1 f1032b80 ffffffc1
[ 10.588600] 3bc0 00000003 00000000 fff45040 ffffffc1 fff45100 ffffffc1 095bd000 ffffff80
[ 10.589327]
[ 10.589468] Call trace:
[ 10.589692] irq_work_queue_on+0x34/0xc8
[ 10.590040] update_util_handler+0x78/0x84
[ 10.590412] enqueue_entity+0x1e4/0xbf4
[ 10.590759] enqueue_task_fair+0x3a4/0x998
[ 10.591130] activate_task+0xb4/0xc4
[ 10.591454] ttwu_do_activate+0x58/0x98
[ 10.591802] try_to_wake_up+0x2dc/0x3e8
[ 10.592149] wake_up_process+0x2c/0x38
[ 10.592486] commit_timeout+0x20/0x2c
[ 10.592812] call_timer_fn+0x84/0x15c
[ 10.593136] expire_timers+0x108/0x114
[ 10.593472] run_timer_softirq+0x110/0x160
[ 10.593842] __do_softirq+0x1f8/0x2d4
[ 10.594167] irq_exit+0x60/0xa8
[ 10.594448] __handle_domain_irq+0x84/0xb8
[ 10.594817] gic_handle_irq+0xdc/0x1b4
[ 10.595153] el1_irq+0xb0/0x140
[ 10.595434] __delay+0x90/0x9c
[ 10.595712] __const_udelay+0x24/0x2c
[ 10.596038] panic+0x2ac/0x2b0
[ 10.596316] do_exit+0x1a4/0x868
[ 10.596606] do_group_exit+0x0/0xa0
[ 10.596920] el0_svc_common.constprop.0+0xe8/0x168
[ 10.597346] el0_svc_handler+0x70/0x8c
[ 10.597682] el0_svc+0x8/0xc
[ 10.597938] —[ end trace 464d8b5b6d2f41c5 ]—
用的是AIO-3568J 8G+64G
你有对SDK作过什么修改吗?
Liuth 发表于 2021-12-14 17:48
你有对SDK作过什么修改吗?
完全按照教程一步步来的,根文件系统也是按照教程打包的
还有一个,我用的是ubuntu18.04的服务器版本进行的操作,根文件系统没有加入桌面系统,请问有无影响
你有对SDK作过什么修改吗?
替换rootfs制作固件只需要3步的
把要用的文件系统改名为rk356x_ubuntu_rootfs.img放在SDK/ubuntu_rootfs/下
在SDK目录执行 ./build.sh aio-3568j-ubuntu.mk
执行 ./build.sh
你再试试?
