Linux SDK同步失败
.repo/repo/repo sync -c --no-tags
File “/work/rk356x_linux_release_20211019/.repo/repo/main.py”, line 531, in
_Main(sys.argv[1:])
File “/work/rk356x_linux_release_20211019/.repo/repo/main.py”, line 507, in _Main
result = repo._Run(argv) or 0
File “/work/rk356x_linux_release_20211019/.repo/repo/main.py”, line 158, in _Run
copts, cargs = cmd.OptionParser.parse_args(argv)
File “/work/rk356x_linux_release_20211019/.repo/repo/command.py”, line 67, in OptionParser
self._Options(self._optparse)
File “/work/rk356x_linux_release_20211019/.repo/repo/subcmds/sync.py”, line 189, in _Options
self.jobs = self.manifest.default.sync_j
File “/work/rk356x_linux_release_20211019/.repo/repo/manifest_xml.py”, line 360, in default
self._Load()
File “/work/rk356x_linux_release_20211019/.repo/repo/manifest_xml.py”, line 407, in _Load
self.manifestProject.worktree))
File “/work/rk356x_linux_release_20211019/.repo/repo/manifest_xml.py”, line 444, in _ParseManifestXml
except (OSError, xml.parsers.expat.ExpatError) as e:
AttributeError: ‘module’ object has no attribute ‘expat’
搭建编译环境的步骤有做吗?
https://wiki.t-firefly.com/Core-3568J/linux_compile_gpt.html#da-jian-bian-yi-huan-jing
