ROC-3566-PC 进入Mask无法发现设备
ROC-3566-PC 按住MaskRom键,插入USB TypeC数据线,无法发现MaskRom设备,调试输出如下:
|?DDR Version V1.10 20210810
ln
ddrconfig:7
LP4 MR14:0x4d
LPDDR4, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
tdqss: cs0 dqs0: 506ps, dqs1: 434ps, dqs2: 458ps, dqs3: 361ps,
tdqss: cs1 dqs0: 506ps, dqs1: 434ps, dqs2: 482ps, dqs3: 361ps,
change to: 324MHz
PHY drv:clk:38,ca:38,DQ:30,odt:0
vrefinner:41%, vrefout:41%
dram drv:40,odt:0
clk skew:0x58
change to: 528MHz
PHY drv:clk:38,ca:38,DQ:30,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x64
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1056MHz(final freq)
vrefinner:16%, vrefout:29%
dram drv:40,odt:80
vref_ca:00000068
clk skew:0x18
cs 0:
the read training result:
DQS0:0x3a, DQS1:0x3b, DQS2:0x3c, DQS3:0x36,
min : 0xe 0xd 0xe 0xc 0x1 0x5 0x9 0x4 , 0xa 0x9 0x3 0x1 0xb 0x9 0xf 0xa ,
0x11 0xf 0xb 0x7 0x4 0x1 0x4 0x5 , 0xd 0x9 0x7 0x1 0xd 0xe 0xb 0xf ,
mid :0x2a 0x2a 0x2b 0x28 0x1e 0x22 0x26 0x21 ,0x27 0x27 0x21 0x1e 0x28 0x27 0x2b 0x28 ,
0x2e 0x2c 0x26 0x23 0x20 0x1d 0x20 0x22 ,0x2a 0x25 0x23 0x1d 0x29 0x2a 0x27 0x2a ,
max :0x47 0x48 0x48 0x45 0x3b 0x3f 0x43 0x3f ,0x45 0x45 0x40 0x3b 0x45 0x45 0x48 0x46 ,
0x4b 0x4a 0x41 0x40 0x3d 0x3a 0x3d 0x3f ,0x47 0x42 0x3f 0x3a 0x46 0x46 0x43 0x46 ,
range:0x39 0x3b 0x3a 0x39 0x3a 0x3a 0x3a 0x3b ,0x3b 0x3c 0x3d 0x3a 0x3a 0x3c 0x39 0x3c ,
0x3a 0x3b 0x36 0x39 0x39 0x39 0x39 0x3a ,0x3a 0x39 0x38 0x39 0x39 0x38 0x38 0x37 ,
the write training result:
DQS0:0x5c, DQS1:0x52, DQS2:0x55, DQS3:0x48,
min :0x91 0x94 0x95 0x92 0x87 0x8c 0x8d 0x8e 0x8e ,0x84 0x84 0x7f 0x7d 0x86 0x87 0x89 0x89 0x86 ,
0x8e 0x8d 0x89 0x87 0x82 0x7e 0x82 0x87 0x88 ,0x83 0x7f 0x7c 0x7a 0x84 0x85 0x82 0x87 0x7e ,
mid :0xae 0xb0 0xb1 0xae 0xa3 0xa8 0xaa 0xa9 0xa9 ,0xa1 0xa0 0x9b 0x99 0xa3 0xa2 0xa3 0xa4 0xa1 ,
0xaa 0xaa 0xa5 0xa3 0x9e 0x98 0x9c 0xa0 0xa2 ,0x9f 0x9c 0x99 0x96 0xa0 0xa2 0x9c 0xa3 0x9a ,
max :0xcc 0xcd 0xce 0xca 0xc0 0xc5 0xc7 0xc4 0xc4 ,0xbe 0xbd 0xb8 0xb6 0xc1 0xbd 0xbe 0xc0 0xbd ,
0xc7 0xc7 0xc1 0xc0 0xba 0xb2 0xb7 0xb9 0xbd ,0xbc 0xb9 0xb7 0xb3 0xbc 0xc0 0xb7 0xc0 0xb7 ,
range:0x3b 0x39 0x39 0x38 0x39 0x39 0x3a 0x36 0x36 ,0x3a 0x39 0x39 0x39 0x3b 0x36 0x35 0x37 0x37 ,
0x39 0x3a 0x38 0x39 0x38 0x34 0x35 0x32 0x35 ,0x39 0x3a 0x3b 0x39 0x38 0x3b 0x35 0x39 0x39 ,
cs 1:
DQS0:0x39, DQS1:0x39, DQS2:0x3b, DQS3:0x34,
min : 0xd 0xd 0xf 0xc 0x1 0x4 0x8 0x4 , 0x8 0x8 0x2 0x1 0x9 0x8 0xe 0x9 ,
0x12 0x10 0xc 0x7 0x5 0x1 0x4 0x6 , 0xd 0x8 0x6 0x2 0xd 0xe 0xb 0xf ,
mid :0x2a 0x2a 0x2b 0x28 0x1e 0x21 0x25 0x20 ,0x25 0x25 0x1f 0x1d 0x27 0x25 0x2a 0x27 ,
0x2e 0x2c 0x26 0x22 0x20 0x1c 0x20 0x22 ,0x29 0x24 0x22 0x1d 0x28 0x29 0x27 0x2a ,
max :0x47 0x47 0x47 0x45 0x3b 0x3e 0x42 0x3d ,0x43 0x43 0x3d 0x3a 0x45 0x43 0x46 0x45 ,
0x4a 0x48 0x40 0x3e 0x3c 0x38 0x3c 0x3f ,0x45 0x40 0x3e 0x38 0x44 0x45 0x44 0x45 ,
range:0x3a 0x3a 0x38 0x39 0x3a 0x3a 0x3a 0x39 ,0x3b 0x3b 0x3b 0x39 0x3c 0x3b 0x38 0x3c ,
0x38 0x38 0x34 0x37 0x37 0x37 0x38 0x39 ,0x38 0x38 0x38 0x36 0x37 0x37 0x39 0x36 ,
min :0x90 0x92 0x93 0x90 0x85 0x89 0x8c 0x8c 0x8c ,0x81 0x82 0x7c 0x7b 0x84 0x85 0x87 0x86 0x84 ,
0x90 0x8f 0x8b 0x8b 0x84 0x81 0x84 0x89 0x8a ,0x82 0x7d 0x7b 0x79 0x83 0x83 0x81 0x85 0x7d ,
mid :0xac 0xae 0xb0 0xac 0xa1 0xa5 0xa8 0xa7 0xa7 ,0x9e 0x9f 0x98 0x97 0xa1 0xa0 0xa1 0xa0 0x9f ,
0xac 0xab 0xa7 0xa7 0x9f 0x9b 0x9e 0xa3 0xa5 ,0x9e 0x9a 0x98 0x95 0x9e 0xa0 0x9a 0xa1 0x99 ,
max :0xc9 0xcb 0xcd 0xc8 0xbe 0xc2 0xc4 0xc2 0xc2 ,0xbc 0xbc 0xb5 0xb3 0xbf 0xbb 0xbc 0xbb 0xbb ,
0xc9 0xc8 0xc3 0xc3 0xbb 0xb5 0xb8 0xbd 0xc1 ,0xbb 0xb7 0xb5 0xb1 0xba 0xbd 0xb4 0xbd 0xb5 ,
range:0x39 0x39 0x3a 0x38 0x39 0x39 0x38 0x36 0x36 ,0x3b 0x3a 0x39 0x38 0x3b 0x36 0x35 0x35 0x37 ,
0x39 0x39 0x38 0x38 0x37 0x34 0x34 0x34 0x37 ,0x39 0x3a 0x3a 0x38 0x37 0x3a 0x33 0x38 0x38 ,
CA Training result:
cs:0 min :0x4f 0x45 0x44 0x3a 0x46 0x3a 0x47 ,0x4b 0x40 0x46 0x3a 0x43 0x37 0x48 ,
cs:0 mid :0x8a 0x88 0x80 0x7e 0x80 0x7d 0x73 ,0x87 0x83 0x7e 0x7c 0x7f 0x7b 0x73 ,
cs:0 max :0xc5 0xcb 0xbc 0xc2 0xbb 0xc1 0x9f ,0xc3 0xc7 0xb6 0xbf 0xbb 0xc0 0x9e ,
cs:0 range:0x76 0x86 0x78 0x88 0x75 0x87 0x58 ,0x78 0x87 0x70 0x85 0x78 0x89 0x56 ,
cs:1 min :0x52 0x47 0x46 0x3c 0x46 0x3d 0x3c ,0x4e 0x41 0x41 0x39 0x45 0x37 0x38 ,
cs:1 mid :0x8c 0x8b 0x82 0x80 0x82 0x80 0x72 ,0x87 0x84 0x7e 0x7c 0x80 0x7b 0x6f ,
cs:1 max :0xc6 0xd0 0xbf 0xc4 0xbf 0xc4 0xa9 ,0xc1 0xc8 0xbb 0xc0 0xbc 0xbf 0xa6 ,
cs:1 range:0x74 0x89 0x79 0x88 0x79 0x87 0x6d ,0x73 0x87 0x7a 0x87 0x77 0x88 0x6e ,
out
U-Boot SPL board init
U-Boot SPL 2017.09 (Dec 22 2021 - 12:11:13)
rk3568_sdmmc_set_clk,rate=400000
Trying to boot from MMC2
mmc_init: -95, time 10
Trying to boot from MMC1
MMC error: The cmd index is 0, ret is -110
mmc_init: -110, time 4
spl: mmc init failed with error: -110
Trying to boot from MTD2
No misc partition
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(98daa5ac76…) + OK
## Checking uboot 0x00a00000 … sha256(c3925b687d…) + OK
## Checking fdt 0x00b27c70 … sha256(9679fe2a45…) + OK
## Checking atf-2 0x00068000 … sha256(c7d2bb5100…) + OK
## Checking atf-3 0xfdcd0000 … sha256(a37442869e…) + OK
## Checking atf-4 0xfdcc9000 … sha256(9edcb98829…) + OK
## Checking atf-5 0x00066000 … sha256(315a4195a9…) + OK
## Checking optee 0x08400000 … sha256(b8cddafab0…) + OK
Total: 540.994 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-168-g367a3ffb3-dirty:xsf
NOTICE: BL31: Built : 19:07:00, Sep 7 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/TC:
I/TC: Start rockchip platform init
I/TC: Rockchip release version: 1.0
I/TC: OP-TEE version: 3.6.0-307-g0b06ae94 #1 Fri May 7 01:52:27 UTC 2021 aarch64
I/TC: Initialized
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Dec 22 2021 - 12:11:13 +0800)
Model: Rockchip RK3568 Evaluation Board
PreSerial: 2, raw, 0xfe660000
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7d351000
Relocation fdt: 7b9f8950 - 7b9fece0
CR: M/C/I
SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Bootdev(atags): mtd 2
PartType: EFI
boot mode: None
FIT: No fdt blob
No resource partition
Failed to load DTB, ret=-19
Failed to get kernel dtb, ret=-19
io-domain: OK
Failed to get scmi clk dev
rockchip_set_ethaddr: vendor_storage_write failed -5
rockchip_set_serialno: could not find efuse/otp device
no recovery key node
apll 816000 KHz
dpll 528000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 24000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 100000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 50000 KHz
aclk_top_high 300000 KHz
aclk_top_low 200000 KHz
hclk_top 150000 KHz
pclk_top 50000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 50000 KHz
Net: No ethernet found.
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
failed to read ca head from misc
Could not read from misc partition
WARNING: Unable to load the BCB.
optee api revision: 2.0
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
Magic is incorrect.
Error validating A/B metadata from disk. Resetting and writing new A/B metadata to disk.
avb_vbmeta_image.c:65: ERROR: Magic is incorrect.
avb_slot_verify.c:773: ERROR: vbmeta: Error verifying vbmeta image: invalid vbmeta header
AVB verify failed
no mmc device at slot 1
no mmc device at slot 0
starting USB…
Bus dwc3@fcc00000: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus dwc3@fd000000: usb maximum-speed not found
USB XHCI 1.10
scanning bus dwc3@fcc00000 for devices… 1 USB Device(s) found
scanning bus dwc3@fd000000 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
难道变砖了?{:5_228:}{:5_228:}{:5_228:}
你这没有进入Makrom,就在这个阶段,输入rbrom命令进入Maskrom
然后按照这个方法一修复固件
https://wiki.t-firefly.com/zh_CN/ROC-RK3566-PC/03-upgrade_firmware_with_flash.html#fang-fa-yi-firefly
