ROC-RK3328-PC通过维基教程编译的固件无法升级烧录
买了一块stationM1的产品,核心板是ROC-RK3328-PC,根据ROC-RK3328-PC维基教程的步骤,编译了Ubuntu的固件,无法升级烧写,官网提供的固件就可以,求大侠指导
下载了官方的Ubuntu rootfs,修改为ubuntu_rootfs/rk3328_ubuntu_rootfs.img,其他均未修改;使用瑞芯微创建升级磁盘工具写入打包好的固件,一直停留在上面的界面
需要提供一下log,看是在哪个地方卡住了
在哪里看log输出呢
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.12.27 16:43:18 =~=~=~=~=~=~=~=~=~=~=~=
? DDR version 1.16 20190528
DDR3
333MHz
ddrconfig:6
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 233
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=7580MB
FwPartOffset=2000 , 0
StorageInit ok = 151633
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x588400
GPT part: 7, name: userdata, start:0x5e2400, size:0x8ebbdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd1a20
RunBL31 0x40000
INFO: Preloader serial: 2
NOTICE: BL31: v1.3(release):3be52e9
NOTICE: BL31: Built : 14:51:38, Nov 3 2020
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #3 Mon Aug 17 09:29:38 UTC 2020 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc56bc3a030 #root (Dec 25 2021 - 20:00:34 -0800)
Model: Firefly ROC-RK3328-CC
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbf5000, fdt: 7bdea578
no mmc device at slot 1
Found IDB in SDcard
rksdmmc@ff500000: 1 (SD), rksdmmc@ff520000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 50Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(s): OK
Android header version 0
use default hdmi phy table
Warn: can’t find connect driver
In: serial
Out: serial
Err: serial
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
apll 400000 KHz
dpll 664000 KHz
cpll 1200000 KHz
gpll 491009 KHz
npll 600000 KHz
armclk 600000 KHz
aclk_bus 150000 KHz
hclk_bus 75000 KHz
pclk_bus 75000 KHz
aclk_peri 150000 KHz
hclk_peri 75000 KHz
pclk_peri 75000 KHz
Net:
Warning: ethernet@ff540000 (eth0) using random MAC address - ee:ca:34:9d:29:ce
eth0: ethernet@ff540000
Hit key to stop autoboot(‘CTRL+C’): 3  2  1  0
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 21393 KiB
RAM disk load addr 0x0a200000 size 8762 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
Using Device Tree in place at 0000000008300000, end 0000000008315689
No file: logo_kernel.bmp
Total: 4780.882 ms
[ 0.000000] Linux version 4.4.194-g021a2d9d5f48 (root@ubuntu) (firefly: 021a2d9d5f486891ae334300b94bf05ef55e2b1b) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Sat Dec 25 20:09:26 PST 2021
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07ff33000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: sdfwupdate storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=af3d13e871788e97 rockchip_jtag ro rootwait earlyprintk=uart8250-32bit,0xff130000 swiotlb=1 kpti=0 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0x7fdb5000-0x7fdf5000] (0MB)
[ 0.000000] Memory: 1994540K/2064384K available (13246K kernel code, 1808K rwdata, 5084K rodata, 1216K init, 1975K bss, 69844K reserved, 0K cma-reserved)
[ 0.000000] modules : 0xffffff8fff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff ( 246 GB)
[ 0.000000] .init : 0xffffff8009270000 -( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0 ( 13248 KB)
[ 0.000000] .rodata : 0xffffff8008d70000 - ( 5120 KB)
[ 0.000000] .data : 0xffffff80093a0000 - 1809 KB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0x 8 GB maximum)
[ 0.000000] 0xffffffbdc00080000 ( 31 MB actual)
[ 0.000000] fixed : 0xffffffbffec00000 ( 4116 KB)
[ 0.000000] PCI I/O : 0xffffffbffffe00000 ( 16 MB)
[ 0.000000] memory : 0xffffffc0080000000 ( 2046 MB)
[ 0.000000] SLUB: HWalign=64, Order=nObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU impion.
[ 0.000000] Build-time adjustment of leaf fanout to 64 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids00000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_id 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Usingctivate mode
[ 0.000000] Architected cp15 timer(s) running a(phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 n 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps097ns
[ 0.001463] Console: colour dummy device 80x25
[ 0.001496] Calibrating delay loop (skipped), value calculated usin. 48.00 BogoMIPS (lpj=24000)
[ 0.001516] pid_max: default: 3768 minimum: 301
[ 0.001634] Security Framework initialized
[ 0.001735] Mount-cache hash table entries: 4096 (order: 3, 3[ 0.001752] Mountpoint-cache hash table entries: 4096 (order:
[ 0.002789] Initializing cgroup subsys io
[ 0.002815] Iroup subsys memory
[ 0.002859] Initializing cgroup subsys devices
[ 0.002878] Initializing cgroup subsys freezer
[ 0.002897] Initializing cgroup subsys perf_event
[ 0.002923] Initializing cgroup subsys net_prio
[ 0.002942] Initializing ubsys pids
[ 0.002989] ftrace: allocating 48427 entries in 1ages
[ 0.143485] sched-energy: CPU device node has no sched-y-costs
[ 0.143511] Invalid sched_group_energy for CPU0
[ 0.143521] CPU0: update cpu_capacity 1024
[ 0.143608] ASID allocator initialised with 32768 entries
[ 0.150338] DetecteI-cache on CPU1
[ 0.150410] Invalid sched_group_energy for C[ 0.150416] CPU1: update cpu_capacity 1024
[ 0.150421] CPcondary processor [410fd034]
[ 0.151298] Detected VIPT I-cac CPU2
[ 0.151356] Invalid sched_group_energy for CPU2
[ 1363] CPU2: update cpu_capacity 1024
[ 0.151370] CPU2: Booteary processor [410fd034]
[ 0.152218] Detected VIPT I-cache on CPU3
[ 0.152269] Invalid sched_group_energy for CPU3
[ 0.152274] CPU3: update cpu_capacity 1024
[ 0.152279] CPU3: Boted secondary processor [410fd034]
[ 0.152405] Brought up 4
[ 0.152472] SMP: Total of 4 processors activated.
[ 0.152487] CPU features: kernel page table isolation forced OFF by ction
[ 0.152500] CPU features: detected feature: 32-bit EL0 [ 0.152515] CPU: All CPU(s) started at EL2
[ 0.152563] al: patching kernel code
[ 0.152875] Invalid sched_group_energ[ 0.152889] Invalid sched_group_energy for Cluster3
[ 0.1Invalid sched_group_energy for CPU2
[ 0.152912] Invalid scheergy for Cluster2
[ 0.152923] Invalid sched_group_energy for CPU1
[ 0.152932] Invalid sched_group_energy for Cluster1
[ 0.152942] Invalid sched_group_energy for CPU0
[ 0.152952Invalid sched_group_energy for Cluster0
[ 0.153894] devtmpfszed
[ 0.185663] clocksource: jiffies: mask: 0xffffffff max_cf, max_idle_ns: 1911260446275000 ns
[ 0.185711] futex hash tle entries: 1024 (order: 4, 65536 bytes)
[ 0.186436] xor: meoftware checksum speed
[ 0.196380] 8regs : 1080.000 [ 0.206467] 8regs_prefetch: 968.000 MB/sec
[ 0.21655 : 1456.000 MB/sec
[ 0.226640] 32regs_prefetch: 1224.0
[ 0.226651] xor: using function: 32regs (1456.000 MB/sec)
[9] pinctrl core: initialized pinctrl subsystem
[ 0.230312] Filed to find legacy iommu devices
[ 0.231130] NET: Registere protocol family 16
[ 0.236457] cpuidle: using governor ladd[ 0.240483] cpuidle: using governor menu
[ 0.240527] Registered FIQ tty driver
[ 0.241923] vdso: 2 pages (1 code @ ffff8008d76000, 1 data @ ffffff80093a4000)
[ 0.241974] hw-breand 6 breakpoint and 4 watchpoint registers.
[ 0.242193] DMA:located 256 KiB pool for atomic allocations
[ 0.274292] genirq: Setting trigger mode 8 for irq 178 failed (gic_set_type+0x0/[ 0.333605] console [ttyFIQ0] enabled
[ 0.334343] Registered fiq debugger ttyFIQ0
[ 0.423141] raid6: int64x1 gen() 199 MB/s
[ 0.440141] raid6: int64x1 xor() 179 MB/s
[ 0.457349] raid6: int64x2 gen() 324 MB/s
[ 0.474542] raid6: int64x2 xor() 259 MB/s
[ 0.491700] raid6: int64x4 gen() 468 MB/s
[ 0.508827] raid6: int64x4 xor() 320 MB/s
[ 0.526026] raid6: int64x8 gen() 394 MB/s
[ 0.543212] raid6: int64x8 xor() 302 MB/s
[ 0.560379] raid6: neonx1 gen() 359 MB/s
[ 0.577583] raid6: neonx1 xor() 353 MB/s
[ 0.594734] raid6: neonx2 gen() 562 MB/s
[ 0.611966] raid6: neonx2 xor() 457 MB/s
[ 0.629099] raid6: neonx4 gen() 753 MB/s
[ 0.646265] raid6: neonx4 xor() 556 MB/s
[ 0.663482] raid6: neonx8 gen() 769 MB/s
[ 0.680646] raid6: neonx8 xor() 566 MB/s
[ 0.681026] raid6: using algorithm neonx8 gen() 769 MB/s
[ 0.681496] raid6: … xor() 566 MB/s, rmw enabled
[ 0.681945] raid6: using intx1 recovery algorithm
[ 0.682920] mpp venc_srv: mpp_probe enter
[ 0.683340] mpp venc_srv: init success
[ 0.686145] vcc_sd: regulator get failed, ret=-517
[ 0.687703] vcc_host_5v: supplied by vcc_sys
[ 0.691230] iommu: Adding device ff350000.vpu_service to group 0
[ 0.691891] iommu: Adding device ff351000.avsd to group 1
[ 0.692458] iommu: Adding device ff360000.rkvdec to group 2
[ 0.693068] iommu: Adding device ff330000.h265e to group 3
[ 0.693648] iommu: Adding device ff340000.vepu to group 4
[ 0.694244] iommu: Adding device ff370000.vop to group 5
[ 0.695478] rk_iommu ff350800.iommu: can’t get sclk
[ 0.696442] rk_iommu ff360480.iommu: can’t get aclk
[ 0.696892] rk_iommu ff360480.iommu: can’t get hclk
[ 0.697362] rk_iommu ff360480.iommu: can’t get sclk
[ 0.698156] rk_iommu ff330200.iommu: can’t get sclk
[ 0.698910] rk_iommu ff340800.iommu: can’t get sclk
[ 0.699569] rk_iommu ff373f00.iommu: can’t get sclk
[ 0.700819] SCSI subsystem initialized
[ 0.701911] usbcore: registered new interface driver usbfs
[ 0.702524] usbcore: registered new interface driver hub
[ 0.703152] usbcore: registered new device driver usb
[ 0.703751] media: Linux media interface: v0.10
[ 0.704222] Linux video capture interface: v2.00
[ 0.704844] pps_core: LinuxPPS API ver. 1 registered
[ 0.705296] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.706154] PTP clock support registered
[ 0.708850] Advanced Linux Sound Architecture Driver Initialized.
[ 0.710397] Bluetooth: Core ver 2.21
[ 0.710796] NET: Registered protocol family 31
[ 0.711200] Bluetooth: HCI device and connection manager initialized
[ 0.711785] Bluetooth: HCI socket layer initialized
[ 0.712229] Bluetooth: L2CAP socket layer initialized
[ 0.712716] Bluetooth: SCO socket layer initialized
[ 0.714582] rockchip-cpuinfo cpuinfo: Serial : af3d13e871788e97
[ 0.717018] clocksource: Switched to clocksource arch_sys_counter
[ 0.841214] NET: Registered protocol family 2
[ 0.842517] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.843447] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.844809] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.845595] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.846299] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.847383] NET: Registered protocol family 1
[ 0.848394] RPC: Registered named UNIX socket transport module.
[ 0.848928] RPC: Registered udp transport module.
[ 0.849388] RPC: Registered tcp transport module.
[ 0.849815] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.851472] Trying to unpack rootfs image as initramfs…
[ 1.707545] Freeing initrd memory: 8760K
[ 1.709801] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.715828] Initialise system trusted keyring
[ 1.735332] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.737567] NFS: Registering the id_resolver key type
[ 1.738092] Key type id_resolver registered
[ 1.738474] Key type id_legacy registered
[ 1.738865] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.741086] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.742359] fuse init (API version 7.23)
[ 1.743489] SGI XFS with security attributes, no debug enabled
[ 1.753369] NET: Registered protocol family 38
[ 1.753815] Key type asymmetric registered
[ 1.754226] Asymmetric key parser ‘x509’ registered
[ 1.755069] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.755980] io scheduler noop registered
[ 1.756387] io scheduler deadline registered
[ 1.756842] io scheduler cfq registered (default)
[ 1.760465] phy phy-ff450000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator
[ 1.762611] rockchip-u3phy ff470000.usb3-phy: Failed to get VBUS supply regulator
[ 1.766094] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[ 1.770598] ace test_init function.
[ 1.771124] ace test_init end.ret=0
[ 1.771882] radar end.ret=0
[ 1.774067] Module initialized.
[ 1.774815] rk-vcodec vpu_combo: no regulator for vcodec
[ 1.775655] rk-vcodec vpu_combo: failed on clk_get clk_cabac
[ 1.776221] rk-vcodec vpu_combo: failed on clk_get clk_core
[ 1.776821] platform ff350000.vpu_service: probe device
[ 1.777758] platform ff350000.vpu_service: drm allocator with mmu enabled
[ 1.779555] platform ff351000.avsd: probe device
[ 1.780511] platform ff351000.avsd: drm allocator with mmu enabled
[ 1.783504] rk-vcodec vpu_combo: could not find power_model node
[ 1.784085] rk-vcodec vpu_combo: init success
[ 1.784909] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 1.785508] rk-vcodec ff360000.rkvdec: parent devfreq retry
[ 1.787150] probe device ff330000.h265e
[ 1.787930] mpp_dev ff330000.h265e: try to get iommu dev ffffffc07cc21810
[ 1.789114] mpp_dev ff330000.h265e: resource ready, register device
[ 1.790289] probe device ff340000.vepu
[ 1.791099] mpp_dev ff340000.vepu: try to get iommu dev ffffffc07cc22010
[ 1.792157] mpp_dev ff340000.vepu: resource ready, register device
[ 1.796897] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330
[ 1.797535] dma-pl330 ff1f0000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.799676] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.801658] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.803303] ff120000.serial: ttyS1 at MMIO 0xff120000 (irq = 12, base_baud = 1500000) is a 16550A
[ 1.806288] [drm] Initialized drm 1.1.0 20060810
[ 1.811239] [drm] Rockchip DRM driver version: v1.0.1
[ 1.811974] rockchip-drm display-subsystem: devfreq is not set
[ 1.813053] rockchip-vop ff370000.vop: failed to get vop register byname
[ 1.813701] rockchip-vop ff370000.vop: missing rockchip,grf property
[ 1.814595] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff8008e31418)
[ 1.815778] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports
[ 1.816405] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.817285] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[ 1.819793] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff8008e26508)
[ 1.820558] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.821158] [drm] No driver support for vblank timestamp query.
[ 1.822193] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.822959] get_framebuffer_by_node: failed to get logo,offset
[ 1.823503] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.824177] rockchip-drm display-subsystem: failed to show loader logo
[ 1.825016] Freeing drm_logo memory: 616K
[ 1.825401] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.826132] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.854221] Console: switching to colour frame buffer device 128x48
[ 1.874030] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.885462] Unable to detect cache hierarchy for CPU 0
[ 1.887578] brd: module loaded
[ 1.899075] loop: module loaded
[ 1.900589] zram: Added device: zram0
[ 1.901412] lkdtm: No crash points registered, enable through debugfs
[ 1.905357] register spi return v = :0
[ 1.908662] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.909492] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input).
[ 1.910152] rk_gmac-dwmac ff540000.ethernet: TX delay(0x28).
[ 1.910669] rk_gmac-dwmac ff540000.ethernet: RX delay(0x16).
[ 1.911204] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no).
[ 1.912018] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
[ 1.912640] rk_gmac-dwmac ff540000.ethernet: clock input from PHY
[ 1.918218] rk_gmac-dwmac ff540000.ethernet: init for RGMII
[ 1.918878] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.919347] Ring mode enabled
[ 1.919628] DMA HW capability register supported
[ 1.920047] Normal descriptors
[ 1.920361] RX Checksum Offload Engine supported (type 2)
[ 1.920851] Wake-Up On Lan supported
[ 1.921277] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: rk_vendor_read eth mac address failed (-1)
[ 1.922165] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: generate random eth mac address: fe:f1:40:7b:75:de
[ 1.923084] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: rk_vendor_write eth mac address failed (-1)
[ 1.923940] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: mac address: fe:f1:40:7b:75:de
[ 1.924706] eth%d: device MAC address fe:f1:40:7b:75:de
[ 1.925191] Enable RX Mitigation via HW Watchdog Timer
[ 1.997082] libphy: stmmac: probed
[ 1.997407] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[ 1.997983] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[ 2.000472] usbcore: registered new interface driver rtl8192cu
[ 2.001115] usbcore: registered new interface driver rndis_wlan
[ 2.002041] usbcore: registered new interface driver mt7601u
[ 2.002680] Rockchip WiFi SYS interface (V1.00) …
[ 2.003277] usbcore: registered new interface driver rtl8150
[ 2.003870] usbcore: registered new interface driver r8152
[ 2.004469] usbcore: registered new interface driver asix
[ 2.005047] usbcore: registered new interface driver ax88179_178a
[ 2.005651] usbcore: registered new interface driver cdc_ether
[ 2.006254] usbcore: registered new interface driver rndis_host
[ 2.006902] usbcore: registered new interface driver cdc_ncm
[ 2.007501] usbcore: registered new interface driver qmi_wwan
[ 2.008109] usbcore: registered new interface driver cdc_mbim
[ 2.011179] phy phy-ff470000.usb3-phy.2: u3phy u2 power on
[ 2.011706] phy phy-ff470000.usb3-phy.3: u3phy u3 power on
[ 2.013691] ff580000.usb supply vusb_d not found, using dummy regulator
[ 2.014420] ff580000.usb supply vusb_a not found, using dummy regulator
[ 2.027770] dwc2 ff580000.usb: DWC OTG Controller
[ 2.028279] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[ 2.028957] dwc2 ff580000.usb: irq 42, io mem 0xff580000
[ 2.029778] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.030411] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.031074] usb usb1: Product: DWC OTG Controller
[ 2.031505] usb usb1: Manufacturer: Linux 4.4.194-g021a2d9d5f48 dwc2_hsotg
[ 2.032140] usb usb1: SerialNumber: ff580000.usb
[ 2.033624] hub 1-0:1.0: USB hub found
[ 2.034062] hub 1-0:1.0: 1 port detected
[ 2.035663] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.036325] ehci-pci: EHCI PCI platform driver
[ 2.036828] ehci-platform: EHCI generic platform driver
[ 2.040098] ehci-platform ff5c0000.usb: EHCI Host Controller
[ 2.040956] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[ 2.041878] ehci-platform ff5c0000.usb: irq 43, io mem 0xff5c0000
[ 2.048051] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.048946] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.049583] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.050246] usb usb2: Product: EHCI Host Controller
[ 2.050689] usb usb2: Manufacturer: Linux 4.4.194-g021a2d9d5f48 ehci_hcd
[ 2.051300] usb usb2: SerialNumber: ff5c0000.usb
[ 2.052714] hub 2-0:1.0: USB hub found
[ 2.053128] hub 2-0:1.0: 1 port detected
[ 2.054337] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.054925] ohci-platform: OHCI generic platform driver
[ 2.056071] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[ 2.057050] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[ 2.057928] ohci-platform ff5d0000.usb: irq 44, io mem 0xff5d0000
[ 2.113337] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.113953] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.114618] usb usb3: Product: Generic Platform OHCI controller
[ 2.115170] usb usb3: Manufacturer: Linux 4.4.194-g021a2d9d5f48 ohci_hcd
[ 2.115766] usb usb3: SerialNumber: ff5d0000.usb
[ 2.117199] hub 3-0:1.0: USB hub found
[ 2.117591] hub 3-0:1.0: 1 port detected
[ 2.119643] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.120555] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4
[ 2.121505] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x04210010
[ 2.122380] xhci-hcd xhci-hcd.9.auto: irq 181, io mem 0xff600000
[ 2.123380] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.123993] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.124661] usb usb4: Product: xHCI Host Controller
[ 2.125121] usb usb4: Manufacturer: Linux 4.4.194-g021a2d9d5f48 xhci-hcd
[ 2.125719] usb usb4: SerialNumber: xhci-hcd.9.auto
[ 2.127203] hub 4-0:1.0: USB hub found
[ 2.127593] hub 4-0:1.0: 1 port detected
[ 2.128571] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.129395] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[ 2.130236] usb usb5: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.131177] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.131791] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.132458] usb usb5: Product: xHCI Host Controller
[ 2.132901] usb usb5: Manufacturer: Linux 4.4.194-g021a2d9d5f48 xhci-hcd
[ 2.133514] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 2.134948] hub 5-0:1.0: USB hub found
[ 2.135365] hub 5-0:1.0: 1 port detected
[ 2.136615] usbcore: registered new interface driver cdc_acm
[ 2.137145] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.137942] usbcore: registered new interface driver cdc_wdm
[ 2.138563] usbcore: registered new interface driver uas
[ 2.139309] usbcore: registered new interface driver usb-storage
[ 2.140047] usbcore: registered new interface driver usbserial
[ 2.140631] usbcore: registered new interface driver usbserial_generic
[ 2.141286] usbserial: USB Serial support registered for generic
[ 2.141902] usbcore: registered new interface driver ch341
[ 2.142470] usbserial: USB Serial support registered for ch341-uart
[ 2.143137] usbcore: registered new interface driver cp210x
[ 2.143677] usbserial: USB Serial support registered for cp210x
[ 2.144372] usbcore: registered new interface driver ftdi_sio
[ 2.144939] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.146035] usbcore: registered new interface driver keyspan
[ 2.146591] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.147352] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.148080] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.148776] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.149541] usbcore: registered new interface driver option
[ 2.150100] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.151319] usbcore: registered new interface driver oti6858
[ 2.151875] usbserial: USB Serial support registered for oti6858
[ 2.152516] usbcore: registered new interface driver pl2303
[ 2.153111] usbserial: USB Serial support registered for pl2303
[ 2.153761] usbcore: registered new interface driver qcserial
[ 2.154363] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.155137] usbcore: registered new interface driver sierra
[ 2.155684] usbserial: USB Serial support registered for Sierra USB modem
[ 2.158353] usbcore: registered new interface driver usbtouchscreen
[ 2.159499] .. rk pwm remotectl v1.1 init
[ 2.160477] input: ff1b0030.pwm as /devices/platform/ff1b0030.pwm/input/input0
[ 2.162056] sensor_register_slave:mma8452,id=17
[ 2.162483] sensor_register_slave:lis3dh,id=7
[ 2.162887] sensor_register_slave:mma7660,id=18
[ 2.163325] sensor_register_slave:lsm303d,id=22
[ 2.163738] sensor_register_slave:gs_mc3230,id=23
[ 2.164180] [Gsensor] gsensor_init
[ 2.164515] sensor_register_slave:mpu6880_acc,id=24
[ 2.164962] sensor_register_slave:mpu6500_acc,id=25
[ 2.165423] sensor_register_slave:lsm330_acc,id=26
[ 2.165859] sensor_register_slave:akm8975,id=30
[ 2.166291] sensor_register_slave:akm8963,id=31
[ 2.166704] sensor_register_slave:l3g4200d,id=45
[ 2.167141] sensor_register_slave:l3g20d,id=46
[ 2.167555] sensor_register_slave:ewtsa,id=47
[ 2.167957] sensor_register_slave:lsm330_gyro,id=51
[ 2.168420] sensor_register_slave:cm3217,id=53
[ 2.168832] sensor_register_slave:cm3218,id=54
[ 2.170136] i2c /dev entries driver
[ 2.173765] rk808 1-0018: Pmic Chip id: 0x8050
[ 2.175344] rk808 1-0018: source: on=0x40, off=0x00
[ 2.197521] vcc_sd: supplied by vcc_io
[ 2.209300] vdd_11: Bringing 1000000uV into 1100000-1100000uV
[ 2.215713] rk808 1-0018: register rk8050 regulators
[ 2.216685] rk8xx-gpio rk8xx-gpio: register rk8050 gpio successful
[ 2.217600] rk8xx-pwrkey rk8xx-pwrkey: device is disabled
[ 2.218154] rk8xx-pwrkey: probe of rk8xx-pwrkey failed with error -22
[ 2.229385] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.231264] rk808 1-0018: Can not read property pmic,hold-gpio
[ 2.231805] rk808 1-0018: Can not read property pmic,stby-gpio
[ 2.232394] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80097f6000
[ 2.235547] IR NEC protocol handler initialized
[ 2.237275] usbcore: registered new interface driver npu_acm
[ 2.237969] usbcore: registered new interface driver uvcvideo
[ 2.238511] USB Video Class driver (1.1.1)
[ 2.248992] Boot mode: normal
[ 2.250309] rockchip-thermal ff250000.tsadc: Missing tshut mode property, using default (cru)
[ 2.251101] rockchip-thermal ff250000.tsadc: Missing tshut-polarity property, using default (low)
[ 2.252366] rockchip-thermal ff250000.tsadc: tsadc is probed successfully!
[ 2.254919] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.256031] Bluetooth: Virtual HCI driver ver 1.5
[ 2.256756] Bluetooth: HCI UART driver ver 2.3
[ 2.257182] Bluetooth: HCI UART protocol H4 registered
[ 2.257645] Bluetooth: HCI UART protocol LL registered
[ 2.258127] Bluetooth: HCI UART protocol ATH3K registered
[ 2.258610] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.259334] usbcore: registered new interface driver bfusb
[ 2.259953] usbcore: registered new interface driver btusb
[ 2.260970] cpu cpu0: leakage=14
[ 2.261303] cpu cpu0: leakage-volt-sel=1
[ 2.262786] cpu cpu0: Failed to get pvtm
[ 2.265869] cpu cpu0: avs=0
[ 2.266236] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 2.269362] cpu cpu0: failed to find power_model node
[ 2.270332] sdhci: Secure Digital Host Controller Interface driver
[ 2.270888] sdhci: Copyright(c) Pierre Ossman
[ 2.271330] Synopsys Designware Multimedia Card Interface Driver
[ 2.273499] dwmmc_rockchip ff500000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.274217] dwmmc_rockchip ff500000.dwmmc: Using internal DMA controller.
[ 2.274839] dwmmc_rockchip ff500000.dwmmc: Version ID is 270a
[ 2.275452] dwmmc_rockchip ff500000.dwmmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
[ 2.276365] dwmmc_rockchip ff500000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.278060] rockchip-iodomain ff100000.syscon:io-domains: Setting to 3300000 done
[ 2.278784] gpio-regulator: set GRF_SOC_CON10 bit 1 to 0
[ 2.279280] enter gpio_regulator_set_voltage line 111 ,gpio=25 state=0
[ 2.279871] rockchip-iodomain ff100000.syscon:io-domains: Setting to 3300000 done
[ 2.293178] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.306742] dwmmc_rockchip ff500000.dwmmc: 1 slots initialized
[ 2.308422] dwmmc_rockchip ff520000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.309179] dwmmc_rockchip ff520000.dwmmc: Using internal DMA controller.
[ 2.309801] dwmmc_rockchip ff520000.dwmmc: Version ID is 270a
[ 2.310450] dwmmc_rockchip ff520000.dwmmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
[ 2.328103] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.341686] dwmmc_rockchip ff520000.dwmmc: 1 slots initialized
[ 2.342603] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.346560] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.347836] usbcore: registered new interface driver usbhid
[ 2.348374] usbhid: USB HID core driver
[ 2.348991] inv_mpu_iio: inv_mpu_init:746
[ 2.351991] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 2.358667] usbcore: registered new interface driver snd-usb-audio
[ 2.361308] rk3328-codec ff410000.codec: rk3328 have no io-channels defined
[ 2.361977] rk3328-codec ff410000.codec: spk_depop_time use default value.
[ 2.369263] rockchip-iodomain ff100000.syscon:io-domains: Setting to 3300000 done
[ 2.370034] gpio-regulator: set GRF_SOC_CON10 bit 1 to 1
[ 2.370512] enter gpio_regulator_set_voltage line 111 ,gpio=25 state=1
[ 2.371132] rockchip-iodomain ff100000.syscon:io-domains: Setting to 1800000 done
[ 2.372053] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.373283] IPVS: Registered protocols (TCP, UDP)
[ 2.373765] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 2.374666] IPVS: Creating netns size=2104 id=0
[ 2.375286] IPVS: ipvs loaded.
[ 2.375598] IPVS: [rr] scheduler registered.
[ 2.376462] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.377119] Initializing XFRM netlink socket
[ 2.378707] NET: Registered protocol family 10
[ 2.379640] mmc_host mmc1: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 2.381964] NET: Registered protocol family 17
[ 2.382603] NET: Registered protocol family 15
[ 2.383257] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.384518] Bridge firewalling registered
[ 2.385339] Bluetooth: RFCOMM socket layer initialized
[ 2.385830] Bluetooth: RFCOMM ver 1.11
[ 2.386228] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.386762] Bluetooth: HIDP socket layer initialized
[ 2.387316] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.388152] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.388803] Key type dns_resolver registered
[ 2.389435] sensor_register_slave:mpu6880_gyro,id=50
[ 2.391373] Registered cp15_barrier emulation handler
[ 2.391832] Registered setend emulation handler
[ 2.393267] Loading compiled-in X.509 certificates
[ 2.396772] Btrfs loaded
[ 2.398295] rga2: Driver loaded successfully ver:4.00
[ 2.399032] rga2: Module initialized.
[ 2.399392] pvtm list NULL
[ 2.400432] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 2.401013] rk-vcodec ff360000.rkvdec: parent devfreq retry
[ 2.403499] rockchip-dmc dmc: current ATF version 0x101!
[ 2.403976] rockchip-dmc dmc: read tf version 0x101!
[ 2.406793] rockchip-dmc dmc: leakage=12
[ 2.407184] rockchip-dmc dmc: leakage-volt-sel=0
[ 2.408568] rockchip-dmc dmc: Failed to get pvtm
[ 2.409652] rockchip-dmc dmc: avs=0
[ 2.410029] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 2.410603] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 2.411391] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 2.414484] rockchip-dmc dmc: Get wrong frequency, Request 1020000000, Current 332000000
[ 2.417091] devfreq dmc: Couldn’t update frequency transition information.
[ 2.439550] asoc-simple-card sound: rk3328-hifi ↔ ff010000.i2s mapping ok
[ 2.442834] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff000000.i2s mapping ok
[ 2.444716] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 2.445285] rk-vcodec ff360000.rkvdec: parent devfreq is ok
[ 2.446315] rk-vcodec ff360000.rkvdec: probe device
[ 2.447286] rk-vcodec ff360000.rkvdec: drm allocator with mmu enabled
[ 2.448673] rk-vcodec ff360000.rkvdec: init success
[ 2.449743] ==gsl_ts_init==
[ 2.450073] ret=0
[ 2.452929] rk808-rtc rk808-rtc: setting system clock to 2016-01-21 08:50:08 UTC (1453366208)
[ 2.886011] dwmmc_rockchip ff500000.dwmmc: Busy; trying anyway
[ 2.886542] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 2.889865] rockchip-iodomain ff100000.syscon:io-domains: Setting to 3300000 done
[ 2.890593] gpio-regulator: set GRF_SOC_CON10 bit 1 to 0
[ 2.891076] enter gpio_regulator_set_voltage line 111 ,gpio=25 state=0
[ 2.891657] rockchip-iodomain ff100000.syscon:io-domains: Setting to 3300000 done
[ 2.925664] mmc0: error -110 whilst initialising SD card
[ 3.092420] random: nonblocking pool is initialized
[ 3.427002] dwmmc_rockchip ff500000.dwmmc: Busy; trying anyway
[ 3.427524] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 3.693328] dwmmc_rockchip ff520000.dwmmc: Successfully tuned phase to 237
[ 3.694261] mmc1: new HS200 MMC card at address 0001
[ 3.696428] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 3.697916] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 3.699527] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 3.700975] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 3.706149] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 3.915154] vendor storage:20190527 ret = 0
[ 4.469984] ret 1024
[ 4.470996] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘20:04:53’, on ‘Dec 25 2021’.
[ 4.473344] mali-utgard ff300000.gpu: mali_platform_device->num_resources = 9
[ 4.473998] mali-utgard ff300000.gpu: resource[0].start = 0x0x00000000ff300000
[ 4.474685] mali-utgard ff300000.gpu: resource[1].start = 0x0x00000000ff300000
[ 4.475368] mali-utgard ff300000.gpu: resource[2].start = 0x0x0000000000000012
[ 4.476046] mali-utgard ff300000.gpu: resource[3].start = 0x0x0000000000000013
[ 4.476703] mali-utgard ff300000.gpu: resource[4].start = 0x0x0000000000000014
[ 4.477390] mali-utgard ff300000.gpu: resource[5].start = 0x0x0000000000000015
[ 4.478069] mali-utgard ff300000.gpu: resource[6].start = 0x0x0000000000000016
[ 4.478725] mali-utgard ff300000.gpu: resource[7].start = 0x0x0000000000000017
[ 4.479403] mali-utgard ff300000.gpu: resource[8].start = 0x0x0000000000000018
[ 4.480083] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[ 4.482291] mali-utgard ff300000.gpu: leakage=12
[ 4.482776] mali-utgard ff300000.gpu: leakage-volt-sel=1
[ 4.483899] mali-utgard ff300000.gpu: Failed to get pvtm
[ 4.485620] mali-utgard ff300000.gpu: avs=0
[ 4.486663] mali-utgard ff300000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 4.491325] Mali: Mali device driver loaded
[ 4.495048] ALSA device list:
[ 4.495334] #0: rockchip,rk3328
[ 4.495638] #1: rockchip,hdmi
[ 4.497244] Freeing unused kernel memory: 1216K
/dev/console is OK
NAME=Buildroot
VERSION=2018.02-rc3-g1e7d09e844
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME=“Buildroot 2018.02-rc3”
Starting logging: OK
Populating /dev using udev: [ 4.584741] udevd[168]: starting version 3.2.7
[ 4.586619] devfreq ff300000.gpu: Couldn’t update frequency transition information.
[ 4.589924] udevd[168]: specified group ‘kvm’ unknown
[ 4.598514] udevd[169]: starting eudev-3.2.7
done
Initializing random number generator… done.
[ 4.996662] EXT4-fs (mmcblk1p8): recovery complete
[ 4.997146] EXT4-fs (mmcblk1p8): mounted filesystem with ordered data mode. Opts: (null)
Starting network: cmdline=sdfwupdate storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=af3d13e871788e97 rockchip_jtag ro rootwait earlyprintk=uart8250-32bit,0xff130000 swiotlb=1 kpti=0 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
_?
read console from cmdline is /dev/ttyFIQ0
Starting recovery on Thu Jan 21 08:50:11 2016
failed to read font: res=-1, fall back to the compiled-in font
cannot find/open a drm device: No such file or directory
gr_init faile
Noui upgrade
recovery filesystem table
0 (null) /tmp ramdisk (null) (null) (null)
1 /dev/root / ext2 rw,noauto 0 1
2 proc /proc proc defaults 0 0
3 devpts /dev/pts devpts defaults,gid=5,mode=620 0 0
4 tmpfs /dev/shm tmpfs mode=0777 0 0
5 tmpfs /tmp tmpfs mode=1777 0 0
6 tmpfs /run tmpfs mode=0755,nosuid,nodev 0 0
7 sysfs /sys sysfs defaults 0 0
8 debug /sys/kernel/debug debugfs defaults 0 0
9 pstore /sys/fs/pstore pstore defaults 0 0
10 /dev/block/by-name/misc /misc emmc defaults 0 0
11 /dev/block/by-name/oem /oem ext2 defaults 0 2
12 /dev/block/by-name/userdata /userdata ext4 defaults 0 2
buf = /dev/block/by-name/misc
### get mount_ponit = /dev/block/by-name/misc ###
emmc_point is /dev/mmcblk1
sd_point is (null)
sd_point_2 is (null)
read cmdline
Boot from SDcard
is_sdcard_update in
configFile = /mnt/sdcard/sd_boot_config.config
OK
Debug: configfs_init
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0’: No such file or directory
[ 5.090754] file system registered
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/rndis.gs0’: No such file or directory
[ 5.110881] Mass Storage Function, version: 2009/09/11
[ 5.111377] LUN: removable file: (no medium)
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uvc.gs6’: No such file or directory
[ 5.155054] read descriptors
[ 5.155343] read strings
sh: write error: No such device
Starting input-event-daemon: input-event-daemon: Start parsing /etc/input-event-daemon.conf…
input-event-daemon: Adding device: /dev/input/event0…
input-event-daemon: Start listening on 1 devices…
done
/etc/init.d/rcS: line 28: alsactl: not found
[root@buildroot:/]# [ 48.254547] irq 106: nobody cared (try booting with the “irqpoll” option)
[ 48.255163] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.194-g021a2d9d5f48 #1
[ 48.255799] Hardware name: Firefly ROC-RK3328-CC (DT)
[ 48.256248] Call trace:
[ 48.256484] [] dump_backtrace+0x0/0x220
[ 48.256961] [] show_stack+0x24/0x30
[ 48.257415] [] dump_stack+0x94/0xbc
[ 48.257869] [] __report_bad_irq+0x44/0xe0
[ 48.258364] [] note_interrupt+0x124/0x290
[ 48.258858] [] handle_irq_event_percpu+0x74/0x1fc
[ 48.259407] [] handle_irq_event+0x50/0x80
[ 48.259902] [] handle_level_irq+0xf8/0x11c
[ 48.260407] [] generic_handle_irq+0x2c/0x44
[ 48.260914] [] rockchip_irq_demux+0x16c/0x1ec
[ 48.261440] [] generic_handle_irq+0x2c/0x44
[ 48.261945] [] __handle_domain_irq+0xb4/0xb8
[ 48.262462] [] gic_handle_irq+0x78/0xc8
[ 48.262934] Exception stack(0xffffff80093a3dd0 to 0xffffff80093a3f00)
[ 48.263506] 3dc0: 0000004076bce000 ffffff8009365000
[ 48.264197] 3de0: 0000000000000000 ffffff80093c6c80 0100000000000000 000000004cd8b875
[ 48.264887] 3e00: 000000000001772a 0000000b3c1b06ae ffffff80093b7de0 ffffff80093a3ea0
[ 48.265577] 3e20: 00000000000009b0 0000000000000400 0000000000000400 00000000000057c1
[ 48.266271] 3e40: 00000000fa83b2da 0000000000000007 000000000000000e 0000000000000050
[ 48.266962] 3e60: 0000000035f3dcb4 ffffff8009365000 ffffff8009525420 ffffff8009525000
[ 48.267652] 3e80: ffffff8009365000 ffffff8009365000 ffffff80093b73d0 ffffff8008d77000
[ 48.268342] 3ea0: 0000000001955000 0000000000f5f23c 000000000147001c ffffff80093a3f00
[ 48.269032] 3ec0: ffffff80080849e4 ffffff80093a3f00 ffffff80080849e8 0000000060000145
[ 48.269722] 3ee0: ffffff8009365000 ffffff8009365000 ffffffffffffffff ffffff80[ 48.270413] [] el1_irq+0xb4/0x140
[ 48.2ffffff80080849e8>] arch_cpu_idle+0x74/0x108
[ 48.271325] [] default_idle_call+0x2c/0x30
[ 48.271818] [<ffffff8008u_startup_entry+0x224/0x2bc
[ 48.272343] [] rest_init+0x74/0x7c
[ 48.272785] [] start_l+0x3c8/0x3ec
[ 48.273260] [] __primary_swi30/0x6c
[ 48.273762] handlers:
[ 48.273978] [] irq_default_primary_handler threaded []map_irq_thread
[ 48.274865] Disabling IRQ #106
是用的 ROC-RK3328-CC 还是 ROC-RK3328-PC ?
In:    serial
Out:   serial
Err:   serial
  apll 400000 KHz
TF 卡启动吗?烧到 emmc 行不行呢?
In:    serial
station M1的硬件,据客服说是 ROC-RK3328-PC,但是我看了ROC-RK3328-CC和ROC-RK3328-PC的维基教程,指向的Linux SDK源码都是一样,编译的过程也是一样的,这里是否有误了
In:    serial
修改为ROC-RK3328-PC的配置roc-rk3328-pc-ubuntu.mk编译就可以,维基教程哪里有问题,需要修改一下
处理中 {:4_213:}
