各位大神,好!
我通过.repo/repo/repo sync -c --no-tags 更新了SDK,然后下载了1804的文件系统镜像,现在出现几个问题,桌面出现了多处bug,第一个就是terminal 的 不能上下拖动窗口,第二个就是WiFi与网络在界面上配置后不能保存到系统中去,能否确认下是否是文件系统的问题,谢谢!
测试没有问题,检查一下解压后的md5码:
ubuntu_18.04_RK3568_ext4_v2.10-42-g50c7f0ac_20211201-1436_DESKTOP.img
2c315e7fc8f8c6844250ff8cbce2ad32
确认了下载文件系统md5 没有问题,现在是不是我更新了SDK,导致的,就是用官网下载编译好的镜像没有出现这个问题,我自己编译的版本就会出现这个问题
你好,串口一致不停的打印这个,图形界面设置IP地址后,不能保存到系统中去,能否帮忙看下
314.523124] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
[ 614.546965] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[ 614.546991] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 614.546999] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[ 615.088781] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[ 615.088806] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[ 615.088814] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
[ 615.675872] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[ 615.675898] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 615.675906] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[ 616.259729] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[ 616.259754] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[ 616.259761] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
[ 616.888045] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[ 616.888070] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 616.888078] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[ 617.512605] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[ 617.512630] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[ 617.512638] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
[ 618.182836] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[ 618.182860] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 618.182868] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[ 618.850229] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[ 618.850255] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[ 618.850263] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
你这log显示两个以太网根本就没有起来,初始化失败
你自己编译的时候选择的mk文件是否正确?
./build.sh roc-rk3568-pc-ubuntu.mk
./build.sh
./build.sh …
请教一下,我自己制作的文件系统播放音乐没声音,但是使用官方的就没问题,是需要安装什么库吗
