rv1126_rv1109_linux_release_20211022 SDK编译不过
编译不通过:
2021-12-29T19:48:53 HTTP request sent, awaiting response… 404 Not Found
2021-12-29T19:48:53 2021-12-29 19:48:53 ERROR 404: Not Found.
2021-12-29T19:48:53
2021-12-29T19:48:53 package/pkg-generic.mk:166: recipe for target ‘/home/lgs/V4/data_rv1126_rv1109/firefly/linux_SDK/rv1126_rv1109_linux_release_20211022/buildroot/output/firefly_rv1126_rv1109/build/opencv3-3.4.12/.stamp_downloaded’ failed
2021-12-29T19:48:53 make[1]: *** [/home/lgs/V4/data_rv1126_rv1109/firefly/linux_SDK/rv1126_rv1109_linux_release_20211022/buildroot/output/firefly_rv1126_rv1109/build/opencv3-3.4.12/.stamp_downloaded] Error 1
2021-12-29T19:48:53 /home/lgs/V4/data_rv1126_rv1109/firefly/linux_SDK/rv1126_rv1109_linux_release_20211022/buildroot/output/firefly_rv1126_rv1109/Makefile:16: recipe for target ‘_all’ failed
2021-12-29T19:48:53 make: *** [_all] Error 2
you take 2:16.95 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 682:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
http 连接出错了,编译 buildroot 有的包需要从网络上下载,请确认网路有没有问题,另外提供完整 log ,这里 log 没有截取到访问的 http 连接
我现在从wiki下载的SDK包,编译出的固件,在开发板上测试,摄像头不能用,WIFI用指令不能用,请问怎么处理,发了都没人处理的,效率太低了都半个月了
lam007 发表于 2022-1-5 15:36
我现在从wiki下载的SDK包,编译出的固件,在开发板上测试,摄像头不能用,WIFI用指令不能用,请问怎么处理 …
哈哈,恭喜同道入坑
