从wifi上下载的代码rv1126_rv1109_linux_ai_camera_release_20210306编译不通过,错误
y/linux_SDK/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109/Makefile
2022-01-02T16:39:22 >>> rkaiq_switch_mode master Syncing from source dir /home/lgs/V4/data_rv1126_rv1109/firefly/linux_SDK/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/../app/rkaiq_switch_mode
2022-01-02T16:39:22 ERROR: /home/lgs/V4/data_rv1126_rv1109/firefly/linux_SDK/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/../app/rkaiq_switch_mode does not exist
2022-01-02T16:39:22 package/pkg-generic.mk:201: recipe for target ‘/home/lgs/V4/data_rv1126_rv1109/firefly/linux_SDK/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109/build/rkaiq_switch_mode-master/.stamp_rsynced’ failed
2022-01-02T16:39:22 make[1]: *** [/home/lgs/V4/data_rv1126_rv1109/firefly/linux_SDK/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109/build/rkaiq_switch_mode-master/.stamp_rsynced] Error 1
2022-01-02T16:39:22 /home/lgs/V4/data_rv1126_rv1109/firefly/linux_SDK/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109/Makefile:16: recipe for target ‘_all’ failed
2022-01-02T16:39:22 make: *** [_all] Error 2
you take 0:10.14 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 648:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
root@lgssvr:/home/lgs/V4/data_rv1126_rv1109/firefly/linux_SDK/rv1126_rv1109_linux_ai_camera_release_20210306#
