[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #12 SMP PREEMPT Wed Apr 22 11:14:57 CST 2015
[ 0.000000] ion heap(cma): base(40000000) size(28000000) align(0)
[ 0.000000] cma: CMA: reserved 640 MiB at 40000000
[ 0.000000] ion_reserve: cma reserved base 40000000 size 671088640
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ddc000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-11-27_16:44:27
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1388480k/1388480k available, 708672k reserved, 663552K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0ae28fc (11115 kB)
[ 0.000000] .init : 0xc0ae3000 - 0xc0b776c0 ( 594 kB)
[ 0.000000] .data : 0xc0b78000 - 0xc0c7f438 (1054 kB)
[ 0.000000] .bss : 0xc0c7f438 - 0xc0d9d7c4 (1145 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rkclk_init_clks: cnt_rate = 31
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:33
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:32
[ 0.304974] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.304989] pid_max: default: 32768 minimum: 301
[ 0.305094] Security Framework initialized
[ 0.305111] SELinux: Initializing.
[ 0.305182] Mount-cache hash table entries: 512
[ 0.305824] Initializing cgroup subsys debug
[ 0.305838] Initializing cgroup subsys memory
[ 0.305865] Initializing cgroup subsys freezer
[ 0.305893] CPU: Testing write buffer coherency: ok
[ 0.306204] /cpus/cpu@0 missing clock-frequency property
[ 0.306218] /cpus/cpu@1 missing clock-frequency property
[ 0.306227] /cpus/cpu@2 missing clock-frequency property
[ 0.306236] /cpus/cpu@3 missing clock-frequency property
[ 0.306298] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.306349] Setting up static identity map for 0xc07e2690 - 0xc07e26e8
[ 0.309434] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1661 (version 3.0)
[ 0.383019] CPU1: Booted secondary processor
[ 0.383052] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.402703] CPU2: Booted secondary processor
[ 0.402727] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.422413] CPU3: Booted secondary processor
[ 0.422437] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.422539] Brought up 4 CPUs
[ 0.422567] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.422576] CPU: All CPU(s) started in SVC mode.
[ 0.423300] devtmpfs: initialized
[ 0.428270] pinctrl core: initialized pinctrl subsystem
[ 0.428519] regulator-dummy: no parameters
[ 0.439925] NET: Registered protocol family 16
[ 0.441704] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.442028] ion_snapshot: 0x2e1e0000 map to 0xf0107000 and copy to 0xc0d78dc4 (version 0.1)
[ 0.442332] Registered FIQ tty driver
[ 0.442749] fiq-debugger is disabled in device tree
[ 0.443326] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.443347] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.443364] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.443380] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.443467] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.443530] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.443591] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.443651] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.443719] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.443780] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.443839] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.443898] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.443966] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.444027] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.444040] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.444052] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.444063] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.444569] rockchip_interrupts_register:bank_num=7
[ 0.446470] rockchip_pinctrl_probe:init ok
[ 0.452572] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.452664] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.452677] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.452836] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.452904] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.452916] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.453075] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.453143] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453155] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.453314] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.453380] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453392] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.453553] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.453626] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453638] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.453801] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.453873] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453885] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.454047] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.454115] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.454128] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.456038] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.456051] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.456250] DDR DEBUG: version 1.00 20140603
[ 0.456280] DDR DEBUG: Channel a:
[ 0.456288] DDR DEBUG: DDR3 Device
[ 0.456301] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.456309] DDR DEBUG: Channel b:
[ 0.456316] DDR DEBUG: DDR3 Device
[ 0.456329] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.456338] DDR DEBUG: addr=0xc87000
[ 0.456346] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.456355] DDR DEBUG: socAddr[0]=0xc87000, socAddr[1]=0xc87100
[ 0.456364] DDR DEBUG: chAddr[0]=0xc87000, chAddr[1]=0xc87000
[ 0.456375] DDR DEBUG: dtar[0]=0x70190000, dtar[1]=0x70190000
[ 0.456617] DDR DEBUG: init success!!! freq=300MHz
[ 0.456625] DDR DEBUG: Channel a:
[ 0.456637] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,1 extra clock, DGPS=360,360
[ 0.456650] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456662] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,1 extra clock, DGPS=360,360
[ 0.456674] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456685] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.456695] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.456703] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.456710] DDR DEBUG: Channel b:
[ 0.456721] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456733] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456745] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456757] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456768] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.456777] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.456785] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.479097] bio: create slab at 0
[ 0.479902] SCSI subsystem initialized
[ 0.480048] usbcore: registered new interface driver usbfs
[ 0.480090] usbcore: registered new interface driver hub
[ 0.480171] usbcore: registered new device driver usb
[ 0.481565] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.483670] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.485267] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.486196] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.486435] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.486920] media: Linux media interface: v0.10
[ 0.486960] Linux video capture interface: v2.00
[ 0.487005] pps_core: LinuxPPS API ver. 1 registered
[ 0.487015] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.487034] PTP clock support registered
[ 0.487490] Rockchip ion module is successfully loaded (v1.0)
[ 0.487648] Advanced Linux Sound Architecture Driver Initialized.
[ 0.488007] Bluetooth: Core ver 2.16
[ 0.488042] NET: Registered protocol family 31
[ 0.488051] Bluetooth: HCI device and connection manager initialized
[ 0.488065] Bluetooth: HCI socket layer initialized
[ 0.488081] Bluetooth: L2CAP socket layer initialized
[ 0.488123] Bluetooth: SCO socket layer initialized
[ 0.488348] cfg80211: Calling CRDA to update world regulatory domain
[ 0.489562] act8846_i2c_probe,line=898
[ 0.490519] act8846_parse_dt,line=746
[ 0.491272] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.491291] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.491305] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.491320] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.493134] act_dcdc1: 1200 mV
[ 0.495848] vccio: 3300 mV
[ 0.497691] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.500391] act_dcdc4: 2000 mV
[ 0.501630] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.503703] act_ldo2: 1000 mV
[ 0.505781] act_ldo3: 2800 mV
[ 0.507830] act_ldo4: 3300 mV
[ 0.509892] act_ldo5: 3300 mV
[ 0.511969] act_ldo6: 1000 mV
[ 0.514035] vcc_18: 1800 mV
[ 0.516086] act_ldo8: 1800 mV
[ 0.520834] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.525527] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.526295] Switching to clocksource arch_sys_counter
[ 0.546580] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.546593] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.546985] rk-screen rk_screen.8: rockchip screen probe success
[ 0.547145] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.547163] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.547493] rk32-edp ff970000.edp: screen is not edp!
[ 0.547508] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.547658] rk32-dsi
[ 0.547801] dsi->host.irq =51
[ 0.547819] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
[ 0.547827] mipi_dsi v1.3 2014-04-17
[ 0.547853] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
[ 0.547865] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.548371] rk3288-lcdc lcdc0: request lcd_rst gpio fail:-16
[ 0.548612] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.548918] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.549070] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.549220] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.560283] rk3288-lcdc lcdc0: lcdc0: dclk:120000000>>fps:50
[ 0.560296] dsi->phy.sys_clk =24000000
[ 1.057723] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.082798] alloc_buffer:ion_phy_addr=0x40000000
[ 1.095543] fb0:phy:40000000>>vir:f0171000>>len:0x1900000
[ 1.099075] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
[ 1.099235] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 1.099247] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 1.099468] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.099767] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.099922] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.100080] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.147292] alloc_buffer:ion_phy_addr=0x41900000
[ 1.147308] fb0:phy:41900000>>vir: (null)>>len:0x3000000
[ 1.147325] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
[ 1.147984] rockchip_set_mux:warning ignore bank num 15
[ 1.148105] rockchip_set_mux:warning ignore bank num 15
[ 1.148207] rockchip_set_mux:warning ignore bank num 15
[ 1.148316] rockchip_set_mux:warning ignore bank num 15
[ 1.148417] rockchip_set_mux:warning ignore bank num 15
[ 1.148526] rockchip_set_mux:warning ignore bank num 15
[ 1.149099] rockchip_set_mux:warning ignore bank num 15
[ 1.149244] rockchip_set_mux:warning ignore bank num 15
[ 1.149778] rockchip_set_mux:warning ignore bank num 15
[ 1.149912] rockchip_set_mux:warning ignore bank num 15
[ 1.150440] rockchip_set_mux:warning ignore bank num 15
[ 1.150579] rockchip_set_mux:warning ignore bank num 15
[ 1.151127] rockchip_set_mux:warning ignore bank num 15
[ 1.151267] rockchip_set_mux:warning ignore bank num 15
[ 1.152626] NET: Registered protocol family 2
[ 1.153066] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.153197] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.153330] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.153380] TCP: reno registered
[ 1.153394] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.153428] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.153620] NET: Registered protocol family 1
[ 1.153830] Unpacking initramfs…
[ 1.216094] Freeing initrd memory: 1160K (c4bf0000 - c4d12000)
[ 1.216674] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.217151] probe device ff9a0000.vpu_service
[ 1.217341] vpu_service: power on
[ 1.218397] checking hw id 4831
[ 1.218754] vpu_service set to auto frequency mode
[ 1.218788] vpu_service: power off…
[ 1.218823] done
[ 1.218831] init success
[ 1.218880] probe device ff9c0000.hevc_service
[ 1.219071] hevc_service: power on
[ 1.220106] checking hw id 6867
[ 1.220327] hevc_service: power off…
[ 1.220363] done
[ 1.220371] init success
[ 1.220482] rknandbase v1.0 2014-03-31
[ 1.220575] rknand ff400000.nandc0: no irq resource?
[ 1.220700] rknand_driver:ret = 0
[ 1.222291] audit: initializing netlink socket (disabled)
[ 1.222329] type=2000 audit(0.920:1): initialized
[ 1.223077] bounce pool size: 64 pages
[ 1.227526] fuse init (API version 7.22)
[ 1.227873] msgmni has been set to 1450
[ 1.229580] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.229595] io scheduler noop registered
[ 1.229603] io scheduler deadline registered
[ 1.229686] io scheduler cfq registered (default)
[ 1.233209] rga2 ff920000.rga: rga ion client create success!
[ 1.233356] rga: Driver loaded succesfully
[ 1.233969] IEP Driver loaded succesfully
[ 1.234065] Module initialized.
[ 1.234955] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.234971] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.236264] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.236280] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.236553] pwm-voltage-regulator pwm_regulator.28: unable to request PWM, trying legacy API
[ 1.236567] pwm-voltage-regulator pwm_regulator.28: unable to request legacy PWM
[ 1.236576] pwm_regulator_probe:error
[ 1.236595] platform pwm_regulator.28: Driver pwm-voltage-regulator requests probe deferral
[ 1.236932] rk_serial.c v1.8 2014-03-04
[ 1.237133] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.237322] serial ff180000.serial: membase f1a74000
[ 1.237448] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 2.915394] console [ttyS2] enabled
[ 2.919017] serial ff690000.serial: membase fed60000
[ 2.926539] loop: module loaded
[ 2.930193] SCSI Media Changer driver v0.25
[ 2.934707] tun: Universal TUN/TAP device driver, 1.6
[ 2.939708] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.945895] vmac_init.
[ 2.948729] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 2.955404] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 2.962361] stmmac_probe_config_dt: clock input or output? (input).
[ 2.968533] stmmac_probe_config_dt: TX delay(0x30).
[ 2.973329] stmmac_probe_config_dt: RX delay(0x20).
[ 2.978180] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 2.983487] stmmc_pltfr_init:
[ 2.986691] stmmc_pltfr_init: init for RGMII
[ 2.990891] tx delay=0x30
[ 2.990891] rx delay=0x20
[ 2.996476] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.001457] Normal descriptors
[ 3.004547] Ring mode enabled
[ 3.007564] DMA HW capability register supported
[ 3.012019] RX Checksum Offload Engine supported (type 2)
[ 3.017609] TX Checksum insertion supported
[ 3.021807] Wake-Up On Lan supported
[ 3.025433] Enable RX Mitigation via HW Watchdog Timer
[ 3.030988] PPP generic driver version 2.4.2
[ 3.035324] PPP BSD Compression module registered
[ 3.039979] PPP Deflate Compression module registered
[ 3.044955] PPP MPPE Compression module registered
[ 3.049677] NET: Registered protocol family 24
[ 3.054069] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 3.063577] CSLIP: code copyright 1989 Regents of the University of California.
[ 3.070771] Rockchip WiFi SYS interface (V1.00) …
[ 3.075683] esp_mem_init enter date Dec 26 2014 09:48:50
[ 3.080949] esp_mem_init complete
[ 3.084352] usbcore: registered new interface driver catc
[ 3.089704] usbcore: registered new interface driver kaweth
[ 3.095195] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 3.102505] usbcore: registered new interface driver pegasus
[ 3.108116] usbcore: registered new interface driver rtl8150
[ 3.113721] usbcore: registered new interface driver r8152
[ 3.119138] hso: drivers/net/usb/hso.c: Option Wireless
[ 3.124342] usbcore: registered new interface driver hso
[ 3.129598] usbcore: registered new interface driver asix
[ 3.134948] usbcore: registered new interface driver ax88179_178a
[ 3.140979] usbcore: registered new interface driver cdc_ether
[ 3.146753] usbcore: registered new interface driver cdc_eem
[ 3.152348] usbcore: registered new interface driver dm9601
[ 3.157877] usbcore: registered new interface driver dm9620
[ 3.163392] usbcore: registered new interface driver smsc75xx
[ 3.169092] usbcore: registered new interface driver smsc95xx
[ 3.174782] usbcore: registered new interface driver gl620a
[ 3.180300] usbcore: registered new interface driver net1080
[ 3.185908] usbcore: registered new interface driver plusb
[ 3.191329] usbcore: registered new interface driver rndis_host
[ 3.197201] usbcore: registered new interface driver cdc_subset
[ 3.203060] usbcore: registered new interface driver zaurus
[ 3.208567] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 3.215903] usbcore: registered new interface driver int51x1
[ 3.221496] usbcore: registered new interface driver kalmia
[ 3.227015] usbcore: registered new interface driver ipheth
[ 3.232541] usbcore: registered new interface driver sierra_net
[ 3.238403] usbcore: registered new interface driver cx82310_eth
[ 3.244358] usbcore: registered new interface driver cdc_ncm
[ 3.249951] usbcore: registered new interface driver qmi_wwan
[ 3.255652] usbcore: registered new interface driver cdc_mbim
[ 3.261301] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.270092] ehci_rk_probe f1b00000 f1b00010
[ 3.274228] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 3.281709] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 3.290125] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 3.311092] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 3.317674] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.324404] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.331519] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 3.337767] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 3.343084] usb usb1: SerialNumber: ff500000.usb
[ 3.348027] hub 1-0:1.0: USB hub found
[ 3.351743] hub 1-0:1.0: 1 port detected
[ 3.379960] ehci_rk_probe ok
[ 3.382934] usbcore: registered new interface driver cdc_acm
[ 3.388498] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.396426] usbcore: registered new interface driver usblp
[ 3.401865] usbcore: registered new interface driver cdc_wdm
[ 3.407475] usbcore: registered new interface driver usb-storage
[ 3.413420] usbcore: registered new interface driver ums-alauda
[ 3.419265] usbcore: registered new interface driver ums-cypress
[ 3.425207] usbcore: registered new interface driver ums-datafab
[ 3.431148] usbcore: registered new interface driver ums_eneub6250
[ 3.437249] usbcore: registered new interface driver ums-freecom
[ 3.443196] usbcore: registered new interface driver ums-isd200
[ 3.449098] usbcore: registered new interface driver ums-jumpshot
[ 3.455115] usbcore: registered new interface driver ums-karma
[ 3.460891] usbcore: registered new interface driver ums-onetouch
[ 3.466906] usbcore: registered new interface driver ums-sddr09
[ 3.472764] usbcore: registered new interface driver ums-sddr55
[ 3.478621] usbcore: registered new interface driver ums-usbat
[ 3.484429] usbcore: registered new interface driver usbserial
[ 3.490210] usbcore: registered new interface driver usbserial_generic
[ 3.496646] usbserial: USB Serial support registered for generic
[ 3.502591] usbcore: registered new interface driver option
[ 3.508099] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.514998] usbcore: registered new interface driver trancevibrator
[ 3.521171] usb20_otg: version 3.10a 21-DEC-2012
[ 3.526096] f1b80040
[ 3.528266] Core Release: 3.10a
[ 3.531356] Setting default values for core params
[ 3.536170] Using Buffer DMA mode
[ 3.539445] Periodic Transfer Interrupt Enhancement - disabled
[ 3.545170] Multiprocessor Interrupt Enhancement - disabled
[ 3.550657] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.554941] ^^^^^^^^^^^^^^^^^Device Mode
[ 3.558808] Dedicated Tx FIFOs mode
[ 3.562246] pcd_init otg_dev = ed646980
[ 3.566146] usb20_otg ff580000.usb: DWC OTG Controller
[ 3.571229] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.578619] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 3.584310] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.590999] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.598110] usb usb2: Product: DWC OTG Controller
[ 3.602736] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.608309] usb usb2: SerialNumber: ff580000.usb
[ 3.613206] hub 2-0:1.0: USB hub found
[ 3.616921] hub 2-0:1.0: 1 port detected
[ 3.621074] usb20_host: version 3.10a 21-DEC-2012
[ 3.628176] f1c00040
[ 3.630331] Core Release: 3.10a
[ 3.633420] Setting default values for core params
[ 3.638224] Using Buffer DMA mode
[ 3.641486] Periodic Transfer Interrupt Enhancement - disabled
[ 3.647230] Multiprocessor Interrupt Enhancement - disabled
[ 3.652709] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.657001] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.660792] usb20_host ff540000.usb: DWC OTG Controller
[ 3.665958] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 3.673417] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 3.679241] Init: Power Port (0)
[ 3.682458] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.689146] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.696255] usb usb3: Product: DWC OTG Controller
[ 3.700882] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.706455] usb usb3: SerialNumber: ff540000.usb
[ 3.711337] hub 3-0:1.0: USB hub found
[ 3.715087] hub 3-0:1.0: 1 port detected
[ 3.719496] .. rk pwm remotectl v1.0 init
[ 3.723510] remotectl probe j=0x0
[ 3.726923] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 3.733419] pwm enable val=0x646205
[ 3.737206] usbcore: registered new interface driver xpad
[ 3.742555] usbcore: registered new interface driver usb_acecad
[ 3.748426] usbcore: registered new interface driver aiptek
[ 3.753950] usbcore: registered new interface driver gtco
[ 3.759295] usbcore: registered new interface driver hanwang
[ 3.764905] usbcore: registered new interface driver kbtab
[ 3.770337] usbcore: registered new interface driver wacom
[ 3.796706] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 1
[ 3.833532] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 2
[ 3.863053] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 3
[ 3.892570] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 4
[ 3.922090] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 5
[ 3.951610] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 6
[ 3.981132] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 7
[ 4.010648] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 8
[ 4.040172] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 9
[ 4.069692] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 10
[ 4.098284] synaptics_dsx_i2c 1-0020: synaptics_rmi4_set_input_dev: Failed to query device
[ 4.106415] synaptics_dsx synaptics_dsx.0: synaptics_rmi4_probe: Failed to set up input device
[ 4.114911] synaptics_dsx: probe of synaptics_dsx.0 failed with error -5
[ 4.124004] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 4.134354] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 4.140664] i2c /dev entries driver
[ 4.144771] IR NEC protocol handler initialized
[ 4.149257] IR RC5(x) protocol handler initialized
[ 4.153968] IR RC6 protocol handler initialized
[ 4.158430] IR JVC protocol handler initialized
[ 4.162884] IR Sony protocol handler initialized
[ 4.167440] IR RC5 (streamzap) protocol handler initialized
[ 4.172918] IR SANYO protocol handler initialized
[ 4.177551] IR MCE Keyboard/mouse protocol handler initialized
[ 4.183417] usbcore: registered new interface driver uvcvideo
[ 4.189090] USB Video Class driver (1.1.1)
[ 4.193121] CamSys driver version: v0.23.0, CamSys head file version: v0.9.0
[ 4.201485] D1:camsys_platform_probe(1067): 1-gpios-cifpower锛gpio=236
[ 4.208114] D1:camsys_platform_probe(1070): gpios-cifpower锛gpio_request
[ 4.214876] D1:camsys_platform_probe(1072): 1-gpios-cifpower锛gpio_request=0
[ 4.221992] D1:camsys_platform_probe(1079): gpios-cifpower锛236 high
[ 4.228494] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 4.239320] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf1ab0000 size: 0x4000)
[ 4.252076] D1:camsys_platform_probe(1183): ff910000.isp memory:
[ 4.258002] D1:camsys_platform_probe(1193): Register memory (phy: 0xff910000 vir: 0xf1ae0000 size: 0x10000)
[ 4.267940] D1:camsys_platform_probe(1188): I2c memory (phy: 0x2d68f000 vir: 0xed68f000 size: 0x1000)
[ 4.277352] D1:camsys_platform_probe(1208): Probe ff910000.isp device success
[ 4.285721] rockchip_temp_probe,line=362
[ 4.344304] tsadc ff280000.tsadc: initialized
[ 4.348979] device-mapper: uevent: version 1.0.3
[ 4.353738] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 4.362339] Bluetooth: HCI UART driver ver 2.2
[ 4.366743] Bluetooth: HCI H4 protocol initialized
[ 4.371454] Bluetooth: HCILL protocol initialized
[ 4.379188] cpufreq version 1.0, suspend freq 1200 MHz
[ 4.384433] cpuidle: using governor ladder
[ 4.388478] cpuidle: using governor menu
[ 4.392360] Synopsys Designware Multimedia Card Interface Driver
[ 4.398524] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 4.404698] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 4.411705] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 4.418152] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.424024] 1390..dw_mci_set_ios: no card. [mmc0]
[ 4.442709] 1390..dw_mci_set_ios: no card. [mmc0]
[ 4.462424] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 4.462438] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 4.462450] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 4.462737] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 4.492954] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 4.499941] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
[ 4.506286] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.512106] mmc1: no vmmc regulator found
[ 4.516160] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 4.522949] 1390..dw_mci_set_ios: no card. [mmc1]
[ 4.533890] mmc0: BKOPS_EN bit is not set
[ 4.539116] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 4.541090] 1390..dw_mci_set_ios: no card. [mmc1]
[ 4.553529] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 4.560809] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 4.560818] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 4.561156] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 4.583648] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 4.583658] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
[ 4.583767] mmc0: new high speed MMC card at address 0001
[ 4.584110] mmcblk0: mmc0:0001 MAG2GA 14.5 GiB
[ 4.584480] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 4.584490] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 4.584497] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 4.584505] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 4.584512] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 4.584519] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 4.584525] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 4.584532] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 4.584539] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 4.584546] system: 0x012400000 – 0x042400000 (768 MB)
[ 4.584553] metadata: 0x042400000 – 0x042800000 (4 MB)
[ 4.584560] userdata: 0x042800000 – 0x082800000 (1024 MB)
[ 4.584567] radical_update: 0x082800000 – 0x086800000 (64 MB)
[ 4.584575] user: 0x086800000 – 0x3a3a00000 (12754 MB)
[ 4.585948] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141390..dw_mci_set_ios: no card. [mmc1]
[ 4.692865] 3379..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 4.699222] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.705353] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.728058] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.747765] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.747830] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 4.747856] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 4.748786] leds-gpio leds.37: pins are not configured from the driver
[ 4.749677] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.756705] usbcore: registered new interface driver usbhid
[ 4.756727] usbhid: USB HID core driver
[ 4.758038] zram: Created 1 device(s) …
[ 4.759259] ashmem: initialized
[ 4.759754] logger: created 256K log ‘log_main’
[ 4.760232] logger: created 256K log ‘log_events’
[ 4.760694] logger: created 256K log ‘log_radio’
[ 4.761136] logger: created 256K log ‘log_system’
[ 4.765342] input: rk29-keypad as /devices/ff100000.adc/key.39/input/input1
[ 4.821825] es8323 probe i2c recv ok
[ 4.825517] i2c-core: driver [ES8323] using legacy suspend method
[ 4.831532] i2c-core: driver [ES8323] using legacy resume method
[ 4.838948] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered
[ 4.847276] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 4.853794] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral
[ 4.862754] es8323_probe
[ 5.506717] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 5.514514] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 5.522474] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 5.530407] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 5.538188] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 5.546343] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 5.554482] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 5.562300] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 5.570125] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 5.577943] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 5.585773] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 5.594090] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 5.602416] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 5.610067] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 5.617721] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 5.625366] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 5.633001] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 5.641416] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 5.649844] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 5.657565] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 5.665292] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 5.673000] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 5.680711] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 5.689198] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 5.697688] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 5.705669] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 5.713647] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 5.721606] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 5.729585] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 5.737561] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 5.745544] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 5.753520] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 5.761535] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 5.769236] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 5.776966] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 5.784675] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 5.792379] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 5.800504] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 5.808638] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 5.816430] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 5.824223] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 5.832010] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 5.839796] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 5.848099] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 5.856541] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 5.862471] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 5.868296] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 5.874150] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 5.879924] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 5.889494] rockchip-es8323 rockchip-es8323.34: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
[ 5.898013] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.34/sound/card0/input2
[ 5.907211] rockchip-hdmi-i2s rockchip-hdmi-i2s.31: rk-hdmi-i2s-hifi ↔ rockchip-i2s.0 mapping ok
[ 5.916530] u32 classifier
[ 5.919205] Actions configured
[ 5.922553] Netfilter messages via NETLINK v0.30.
[ 5.927215] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.933707] ctnetlink v0.93: registering with nfnetlink.
[ 5.939017] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.945863] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.952008] xt_time: kernel timezone is -0000
[ 5.956509] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.961877] arp_tables: (C) 2002 David S. Miller
[ 5.966445] TCP: cubic registered
[ 5.969724] Initializing XFRM netlink socket
[ 5.974174] NET: Registered protocol family 10
[ 5.979119] mip6: Mobile IPv6
[ 5.982057] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.987479] sit: IPv6 over IPv4 tunneling driver
[ 5.992389] NET: Registered protocol family 17
[ 5.996775] NET: Registered protocol family 15
[ 6.001206] Bridge firewalling registered
[ 6.005151] Ebtables v2.0 registered
[ 6.008841] Bluetooth: RFCOMM TTY layer initialized
[ 6.013653] Bluetooth: RFCOMM socket layer initialized
[ 6.018716] Bluetooth: RFCOMM ver 1.11
[ 6.022401] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.027636] Bluetooth: BNEP filters: protocol multicast
[ 6.032776] Bluetooth: BNEP socket layer initialized
[ 6.037662] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.043484] Bluetooth: HIDP socket layer initialized
[ 6.048402] l2tp_core: L2TP core driver, V2.0
[ 6.052690] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 6.057404] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 6.062175] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 6.066901] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 6.073742] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 6.080757] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 6.089141] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 6.096423] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 6.105405] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 6.114470] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 6.119612] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 6.127943] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 6.132598] [BT_RFKILL]: Enter rfkill_rk_init
[ 6.136997] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 6.145057] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 6.153011] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 6.160971] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 6.168852] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 6.177087] [BT_RFKILL]: Request irq for bt wakeup host
[ 6.182285] [BT_RFKILL]: ** disable irq
[ 6.186125] [BT_RFKILL]: ap6335 device registered.
[ 6.191607] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 6.198173] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 6.205728] rk3288_init_suspend
[ 6.208815] rk3288_suspend_init enter
[ 6.212519] rk3288_suspend_init: pm_ctrbits =200007
[ 6.217339] gpio_get_dts_info suspend:4
[ 6.221106] gpio_get_dts_info resume:4
[ 6.224811] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.232892] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.240894] clks_gating_suspend_init:clkgt info ok
[ 6.245678] Registering SWP/SWPB emulation handler
[ 6.250653] ddrfreq: verion 1.2 20140526
[ 6.254524] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
[ 6.265548] ddrfreq: auto-freq=0
[ 6.268729] ddrfreq: auto-freq-table[0] 240MHz
[ 6.273098] ddrfreq: auto-freq-table[1] 324MHz
[ 6.277462] ddrfreq: auto-freq-table[2] 396MHz
[ 6.281825] ddrfreq: auto-freq-table[3] 528MHz
[ 6.288431] regulator-dummy: disabling
[ 6.292462] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered
[ 6.300711] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 6.307236] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral
[ 6.315872] pcd_pullup, is_on 0
[ 6.318991] file system registered
[ 6.322837] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 6.329592] android_usb gadget: Number of LUNs=2
[ 6.334139] lun0: LUN: removable file: (no medium)
[ 6.338930] lun1: LUN: removable file: (no medium)
[ 6.343851] android_usb gadget: android_usb ready
[ 6.348997] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:02 UTC (1293883202)
[ 6.361823] rk_spdif:rk_spdif_init
[ 6.365325] rk_spdif:Entered spdif_probe
[ 6.369374] rk_spdif:spdif:spdif probe ok!
[ 6.373918] usbcore: registered new interface driver snd-usb-audio
[ 6.380003] ALSA device list:
[ 6.380101] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
[ 6.392366] #0: RK_ES8323
[ 6.395110] #1: RK-HDMI-I2S
[ 6.398024] #2: RK-HDMI-SPDIF
[ 6.401441] Freeing unused kernel memory: 592K (c0ae3000 - c0b77000)
[ 6.412076] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 6.420027] SELinux: the above unknown classes and permissions will be denied
[ 6.808017] type=1403 audit(1293883202.960:2): policy loaded auid=4294967295 ses=4294967295
[ 6.816370] SELinux: Loaded policy from /sepolicy
[ 6.822868] type=1404 audit(1293883202.970:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 7.752717] init: could not import file ‘/init.usbstorage.rc’ from ‘/init.rc’
[ 7.760476] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 7.819411] init: /dev/hw_random not found
[ 7.823486] keychord: using input dev ff680000.pwm for fevent
[ 7.829160] keychord: using input dev rk29-keypad for fevent
[ 7.839707] fs_mgr: parse_link_device : path = NULL
[ 7.844515] fs_mgr: parse_link_device : path = NULL
[ 7.849343] fs_mgr: parse_link_device : path = NULL
[ 7.854201] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 7.872614] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
[ 7.891238] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 7.914202] EXT4-fs (mmcblk0p8): recovery complete
[ 7.919680] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.932142] EXT4-fs (mmcblk0p11): recovery complete
[ 7.936952] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 8.061059] EXT4-fs (mmcblk0p12): 3 orphan inodes deleted
[ 8.066391] EXT4-fs (mmcblk0p12): recovery complete
[ 8.093238] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 8.118394] mali pd enabled
[ 8.121149] clk enabled
[ 8.124769] MALI_DVFS_STEP=5,div_dvfs=7
[ 8.128541] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
[ 8.135581] mali_dvfs_infotbl[1].clock=179000,min_threshold=66,max_threshold=77
[ 8.142785] mali_dvfs_infotbl[2].clock=297000,min_threshold=73,max_threshold=84
[ 8.149966] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
[ 8.157165] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
[ 8.164558] turn on mali power
[ 8.167563] kbase_platform_rk_init,register_reboot_notifier
[ 8.173078] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 8.179878] mali ffa30000.gpu: Probed as mali0
[ 8.186903] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 8.210690] init: /dev/hw_random not found
[ 8.223028] binder: 160:160 transaction failed 29189, size 0-0
[ 8.224489] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
[ 8.226950]init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
[ 8.231793] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
[ 8.233183] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
[ 8.234117] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 8.234128] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 8.234307] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 8.418272] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
[ 8.426338] init: powerctl: cannot expand ‘${sys.powerctl}’
[ 8.431884] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
[ 8.442684] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
[ 8.452993] init: property ‘sys.sysctl.tcp_def_init_rwnd’ doesn’t exist while expanding ‘${sys.sysctl.tcp_def_init_rwnd}’
[ 8.463797] init: cannot expand ‘${sys.sysctl.tcp_def_init_rwnd}’ while writing to ‘/proc/sys/net/ipv4/tcp_default_init_rwnd’
[ 8476247] android_usb: already disabled
[ 8.482170] read descriptors
[ 8.485016] read strings
[ 8.487607] pcd_pullup, is_on 1
[ 8.548408] fs_mgr: parse_link_device : path = NULL
[ 8.553242] fs_mgr: parse_link_device : path = NULL
[ 8.558119] fs_mgr: parse_link_device : path = NULL
shell@rk3288:/ $ [ 9.069672] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.077029] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.084413] D1:camsys_open(717): camsys_marvin(ed944510) is opened!
[ 9.090676] rockchip_gpio_request:GPIO7-13
[ 9.094713] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.099310] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.105133] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.111831] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7408,result=0x7408
[ 9.122373] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.129178] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
[ 9.162710] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.170723] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.175714] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.180628] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.189927] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.198354] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.206671] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.217144] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.223432] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.230662] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.237875] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.261915] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.268560] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.277454] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.285875] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.294112] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.301556] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.309040] D1:camsys_release(741): camsys_marvin(ed944510) is closed
[ 9.318601] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.325984] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.333353] D1:camsys_open(717): camsys_marvin(ed944510) is opened!
[ 9.339587] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.344148] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.349972] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.356665] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7408,result=0x7408
[ 9.367209] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.373988] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
[ 9.400811] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.408795] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.413789] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.418698] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.427990] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.436326] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.444588] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.455047] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.462587] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 9.468892] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.476113] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.483343] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.519856] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.526492] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.535322] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.543733] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.551986] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.559430] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.566891] D1:camsys_release(741): camsys_marvin(ed944510) is closed
[ 9.576632] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.584010] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.591397] D1:camsys_open(717): camsys_marvin(ed944510) is opened!
[ 9.597614] D1:camsys_extdev_register(230): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.607550] D1:camsys_extdev_register(230): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.617493] D1:camsys_extdev_register(230): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 9.627458] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.632024] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.637846] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.644534] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7408,result=0x7408
[ 9.655076] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.661856] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 9.678551] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.686504] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.691516] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.696436] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.705716] D1:camsys_sysctl_extdev(335): Sysctl 11 success, gpio(11) set 1
[ 9.713643] D1:camsys_sysctl_extdev(339): Sysctl 8 success, gpio(79) set 1
[ 9.721467] D1:camsys_sysctl_extdev(339): Sysctl 7 success, gpio(78) set 1
[ 9.731477] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 9.738951] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.745256] D1:camsys_sysctl_extdev(335): Sysctl 7 success, gpio(78) set 0
[ 9.752060] D1:camsys_sysctl_extdev(335): Sysctl 8 success, gpio(79) set 0
[ 9.758867] D1:camsys_sysctl_extdev(339): Sysctl 11 success, gpio(11) set 0
[ 9.797661] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.804281] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.813116] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.821535] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.829766] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.837223] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.844663] D1:camsys_release(741): camsys_marvin(ed944510) is closed
[ 9.859784] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.867155] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.874529] D1:camsys_open(717): camsys_marvin(ed944510) is opened!
[ 9.880729] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 9.887687] D1:camsys_extdev_register(255): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
[ 9.916851] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.924823] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.929803] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.934735] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.944009] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.952344] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.960650] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.971154] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 9.977472] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.984689] rk3288-lcdc lcdc0: blank mode:0
[ 9.984697] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.984704] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 10.015951] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 10.022617] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 10.031449] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x1000000) is deregister success
[ 10.039859] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 10.048098] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.055579] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.062816] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
[ 10.070173] D1:camsys_release(741): camsys_marvin(ed944510) is closed
[ 11.158121] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
[ 17.228695] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 17.307263] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 17.314305] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 17.319611] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 17.325046] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 17.330520] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 17.336016] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 17.341501] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 17.574262] phy_power_on: enable = 1
[ 17.617256] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 17.623594] eth0: device MAC address 3a:4c:28:b5:4e:43
[ 17.632768] libphy: stmmac: probed
[ 17.636117] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 17.642120] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 17.755809] wifi_driver_write: wifi driver already rmmod
[ 17.801479] acc_open
[ 17.803642] acc_release
[ 18.495760] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 18.539278] avc: denied { set } for property=sys.vold.hasAsec scontext=u:r:vold:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service
[ 18.551987] init: sys_prop: permission denied uid:0 name:sys.vold.hasAsec
[ 18.559207] init: no such service ‘fuse_internal_sd’
[ 19.078420] init: sys_prop: permission denied uid:10012 name:sys.gmali.version
[ 19.772150] init: sys_prop: permission denied uid:10037 name:sys.gmali.version
[ 20.900725] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 21.008300] f28c7234,f28c7234,f28c7234
[ 33.148366] rk3288-hdmi ff980000.hdmi: Removed.
[ 33.359098] rk3288-lcdc lcdc0: blank mode:4
[ 33.980615] PM: suspend entry 2011-01-01 12:00:30.580880055 UTC
[ 33.986630] PM: Syncing filesystems … done.
[ 34.007525] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 34.018822] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 34.029329] Suspending console(s) (use no_console_suspend to debug)
01-armoff-logdp-osc_offddrc_off2345dDd543210
[ 34.037754] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 34.037774] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 34.037787] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 34.038130] rk_spdif:Entered spdif_suspend
[ 34.038139] rk_spdif:spdif:Entered spdif_suspend
[ 34.040227] dwc_otg_hcd_suspend, usb device mode
[ 34.042570] hym8563_rtc_set_alarm:diff_sec= 34s , use time
[ 34.100809] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 34.101526] phy_power_on: enable = 0
[ 34.103777] PM: suspend of devices complete after 67.147 msecs
[ 34.104915] PM: late suspend of devices complete after 1.133 msecs
[ 34.106279] PM: noirq suspend of devices complete after 1.368 msecs
[ 34.106303] Disabling non-boot CPUs …
[ 34.108725] CPU1: shutdown
[ 34.114138] CPU2: shutdown
[ 34.118660] CPU3: shutdown
[ 34.122144] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 34.122196] rkpm_enter:
[ 34.122221] GPIO0_INTEN: 00000020
[ 34.122232] GPIO4_INTEN: 80000000
[ 34.122247] GPIO6_INTEN: 00400000
[ 34.122254] GPIO7_INTEN: 00000010
[ 34.206273] Resume caused by IRQ 120
[ 34.206327] wakeup irq: 00000000 00000000 01000000 00000000
[ 34.206343] wakeup gpio7: 00000010
[ 34.206548] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 34.206583] Suspended for 0.000 seconds
[ 34.207407] Enabling non-boot CPUs …
[ 34.208185] CPU1: Booted secondary processor
[ 34.209372] CPU1 is up
[ 34.209782] CPU2: Booted secondary processor
[ 34.210372] CPU2 is up
[ 34.210774] CPU3: Booted secondary processor
[ 34.211389] CPU3 is up
[ 34.213952] PM: noirq resume of devices complete after 2.571 msecs
[ 34.215231] PM: early resume of devices complete after 0.774 msecs
[ 34.215606] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 34.215622] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 34.215997] 1390..dw_mci_set_ios: no card. [mmc1]
[ 34.216181] dwc_otg_hcd_resume, usb device mode
[ 34.221193] phy_power_on: enable = 1
[ 34.256023] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 34.258653] PM: resume of devices complete after 44.097 msecs
[ 34.258772] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 34.258785] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 34.258797] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 34.259334] rk_spdif:spdif:Entered spdif_resume
[ 34.260126] [BT_RFKILL]: ** disable irq
[ 34.491362] Restarting tasks … done.
[ 34.497531] PM: suspend exit 2011-01-01 12:01:04.244169334 UTC
[ 34.542804] PM: suspend entry 2011-01-01 12:01:04.290180334 UTC
[ 34.548654] PM: Syncing filesystems … done.
[ 34.560251] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 34.571639] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 34.582230] Suspending console(s) (use no_console_suspend to debug)
[ 34.590698] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 34.590715] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 34.590728] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 34.591036] rk_spdif:Entered spdif_suspend
[ 34.591056] rk_spdif:spdif:Entered spdif_suspend
[ 34.593638] dpm_run_callback(): platform_pm_suspend+0x0/0x5c returns -16
[ 34.593668] PM: Device alarmtimer failed to suspend: error -16
[ 34.595983] PM: Some devices failed to suspend
[ 34.597675] rk_spdif:spdif:Entered spdif_resume
[ 34.608371] PM: resume of devices complete after 12.557 msecs
[ 34.608471] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 34.608482] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 34.608497] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 34.609265] [BT_RFKILL]: ** disable irq
[ 34.694252] Restarting tasks … [ 34.699785] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 34.700512] PM: suspend exit 2011-01-01 12:01:04.450450001 UTC
done.
[ 36.556944] PM: suspend entry 2011-01-01 12:01:06.336979751 UTC
[ 36.563617] PM: Syncing filesystems … done.
[ 36.582344] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 36.593540] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 36.604078] Suspending console(s) (use no_console_suspend to debug)
[ 36.612301] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 36.612320] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 36.612333] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 36.612652] rk_spdif:Entered spdif_suspend
[ 36.612661] rk_spdif:spdif:Entered spdif_suspend
[ 36.614743] dwc_otg_hcd_suspend, usb device mode
[ 36.616584] hym8563_rtc_set_alarm:diff_sec= 9s , use time
[ 36.674877] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 36.675557] phy_power_on: enable = 0
[ 36.677207] PM: suspend of devices complete after 66.024 msecs
[ 36.678304] PM: late suspend of devices complete after 1.087 msecs
[ 36.679547] PM: noirq suspend of devices complete after 1.245 msecs
[ 36.679560] Disabling non-boot CPUs …
[ 36.682030] CPU1: shutdown
[ 36.685883] CPU2: shutdown
[ 36.688397] CPU3: shutdown
[ 36.690221] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 36.690261] rkpm_enter:
[ 36.690282] GPIO0_INTEN: 00000020
[ 36.690297] GPIO4_INTEN: 80000000
[ 36.690306] GPIO6_INTEN: 00400000
[ 36.690313] GPIO7_INTEN: 00000010
[ 36.774587] Resume caused by IRQ 120
[ 36.774627] wakeup irq: 00000000 00000000 01000000 00000000
[ 36.774639] wakeup gpio7: 00000010
[ 36.774849] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 36.774884] Suspended for 0.000 seconds
[ 36.775683] Enabling non-boot CPUs …
[ 36.776457] CPU1: Booted secondary processor
[ 36.777622] CPU1 is up
[ 36.778032] CPU2: Booted secondary processor
[ 36.778636] CPU2 is up
[ 36.779026] CPU3: Booted secondary processor
[ 36.779663] CPU3 is up
[ 36.782172] PM: noirq resume of devices complete after 2.521 msecs
[ 36.783210] PM: early resume of devices complete after 0.583 msecs
[ 36.783587] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 36.783604] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 36.784100] 1390..dw_mci_set_ios: no card. [mmc1]
[ 36.784273] dwc_otg_hcd_resume, usb device mode
[ 36.789374] phy_power_on: enable = 1
[ 36.824116] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 36.826514] rk_spdif:spdif:Entered spdif_resume
[ 36.826694] PM: resume of devices complete after 44.166 msecs
[ 36.826981] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 36.826995] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 36.827007] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 36.827939] [BT_RFKILL]: ** disable irq
[ 37.059034] Restarting tasks … done.
[ 37.065575] PM: suspend exit 2011-01-01 12:01:15.244285125 UTC
[ 37.078050] PM: suspend entry 2011-01-01 12:01:15.256951333 UTC
[ 37.083934] PM: Syncing filesystems … done.
[ 37.096142] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 37.107558] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 37.118100] Suspending console(s) (use no_console_suspend to debug)
[ 37.126610] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 37.126628] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 37.126638] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 37.126975] rk_spdif:Entered spdif_suspend
[ 37.126987] rk_spdif:spdif:Entered spdif_suspend
[ 37.129176] dwc_otg_hcd_suspend, usb device mode
[ 37.131024] hym8563_rtc_set_alarm:diff_sec= 50s , use time
[ 37.192712] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 37.193455] phy_power_on: enable = 0
[ 37.195058] PM: suspend of devices complete after 69.623 msecs
[ 37.196127] PM: late suspend of devices complete after 1.061 msecs
[ 37.197176] PM: noirq suspend of devices complete after 1.050 msecs
[ 37.197190] Disabling non-boot CPUs …
[ 37.199424] CPU1: shutdown
[ 37.202864] CPU2: shutdown
[ 37.205818] CPU3: shutdown
[ 37.207733] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 37.207793] rkpm_enter:
[ 37.207815] GPIO0_INTEN: 00000020
[ 37.207827] GPIO4_INTEN: 80000000
[ 37.207836] GPIO6_INTEN: 00400000
[ 37.207847] GPIO7_INTEN: 00000010
[ 37.292261] Resume caused by IRQ 120
[ 37.292305] wakeup irq: 00000000 00000000 01000000 00000000
[ 37.292314] wakeup gpio7: 00000010
[ 37.292518] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 37.292549] Suspended for 0.000 seconds
[ 37.293400] Enabling non-boot CPUs …
[ 37.294189] CPU1: Booted secondary processor
[ 37.295407] CPU1 is up
[ 37.295805] CPU2: Booted secondary processor
[ 37.296398] CPU2 is up
[ 37.296810] CPU3: Booted secondary processor
[ 37.297560] CPU3 is up
[ 37.300068] PM: noirq resume of devices complete after 2.516 msecs
[ 37.301147] PM: early resume of devices complete after 0.573 msecs
[ 37.301465] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 37.301528] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 37.301921] 1390..dw_mci_set_ios: no card. [mmc1]
[ 37.302101] dwc_otg_hcd_resume, usb device mode
[ 37.307156] phy_power_on: enable = 1
[ 37.341916] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 37.344436] rk_spdif:spdif:Entered spdif_resume
[ 37.344598] PM: resume of devices complete after 44.133 msecs
[ 37.344977] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 37.344996] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 37.345058] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 37.345899] [BT_RFKILL]: ** disable irq
[ 37.576879] Restarting tasks … [ 37.582570] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 37.582884] PM: suspend exit 2011-01-01 12:02:05.243794251 UTC
done.
[ 37.650300] PM: suspend entry 2011-01-01 12:02:05.312295084 UTC
[ 37.656900] PM: Syncing filesystems … done.
[ 37.670502] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 37.682166] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 37.692777] Suspending console(s) (use no_console_suspend to debug)
[ 37.701322] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 37.701340] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 37.701350] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 37.701657] rk_spdif:Entered spdif_suspend
[ 37.701671] rk_spdif:spdif:Entered spdif_suspend
[ 37.703801] dwc_otg_hcd_suspend, usb device mode
[ 37.705634] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 37.769586] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 37.770339] phy_power_on: enable = 0
[ 37.772063] PM: suspend of devices complete after 71.943 msecs
[ 37.773160] PM: late suspend of devices complete after 1.085 msecs
[ 37.774456] PM: noirq suspend of devices complete after 1.298 msecs
[ 37.774476] Disabling non-boot CPUs …
[ 37.776727] CPU1: shutdown
[ 37.780235] CPU2: shutdown
[ 37.783099] CPU3: shutdown
[ 37.784923] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 37.784971] rkpm_enter:
[ 37.784999] GPIO0_INTEN: 00000020
[ 37.785011] GPIO4_INTEN: 80000000
[ 37.785020] GPIO6_INTEN: 00400000
[ 37.785030] GPIO7_INTEN: 00000010
[ 37.869313] Resume caused by IRQ 120
[ 37.869357] wakeup irq: 00000000 00000000 01000000 00000000
[ 37.869373] wakeup gpio7: 00000010
[ 37.869576] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 37.869611] Suspended for 0.000 seconds
[ 37.870445] Enabling non-boot CPUs …
[ 37.871231] CPU1: Booted secondary processor
[ 37.872500] CPU1 is up
[ 37.872907] CPU2: Booted secondary processor
[ 37.873504] CPU2 is up
[ 37.873925] CPU3: Booted secondary processor
[ 37.874556] CPU3 is up
[ 37.877078] PM: noirq resume of devices complete after 2.529 msecs
[ 37.878151] PM: early resume of devices complete after 0.593 msecs
[ 37.878601] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 37.878625] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 37.879005] 1390..dw_mci_set_ios: no card. [mmc1]
[ 37.879230] dwc_otg_hcd_resume, usb device mode
[ 37.884315] phy_power_on: enable = 1
[ 37.919049] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 37.921610] rk_spdif:spdif:Entered spdif_resume
[ 37.921795] PM: resume of devices complete after 44.330 msecs
[ 37.922093] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 37.922105] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 37.922114] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 37.923024] [BT_RFKILL]: ** disable irq
[ 38.153993] Restarting tasks … [ 38.159329] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 38.159544] PM: suspend exit 2011-01-01 12:03:05.243289083 UTC
done.
[ 38.232034] PM: suspend entry 2011-01-01 12:03:05.316943667 UTC
[ 38.238592] PM: Syncing filesystems … done.
[ 38.250034] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 38.261482] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 38.272034] Suspending console(s) (use no_console_suspend to debug)
[ 38.280566] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 38.280579] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 38.280589] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 38.280919] rk_spdif:Entered spdif_suspend
[ 38.280931] rk_spdif:spdif:Entered spdif_suspend
[ 38.283139] dwc_otg_hcd_suspend, usb device mode
[ 38.285083] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 38.346516] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 38.347272] phy_power_on: enable = 0
[ 38.348954] PM: suspend of devices complete after 69.556 msecs
[ 38.350077] PM: late suspend of devices complete after 1.110 msecs
[ 38.351459] PM: noirq suspend of devices complete after 1.379 msecs
[ 38.351481] Disabling non-boot CPUs …
[ 38.353772] CPU1: shutdown
[ 38.357057] CPU2: shutdown
[ 38.359801] CPU3: shutdown
[ 38.361596] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 38.361645] rkpm_enter:
[ 38.361672] GPIO0_INTEN: 00000020
[ 38.361685] GPIO4_INTEN: 80000000
[ 38.361693] GPIO6_INTEN: 00400000
[ 38.361701] GPIO7_INTEN: 00000010
[ 38.446075] Resume caused by IRQ 120
[ 38.446120] wakeup irq: 00000000 00000000 01000000 00000000
[ 38.446132] wakeup gpio7: 00000010
[ 38.446337] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 38.446370] Suspended for 0.000 seconds
[ 38.447194] Enabling non-boot CPUs …
[ 38.447966] CPU1: Booted secondary processor
[ 38.449107] CPU1 is up
[ 38.449501] CPU2: Booted secondary processor
[ 38.450121] CPU2 is up
[ 38.450554] CPU3: Booted secondary processor
[ 38.451301] CPU3 is up
[ 38.453895] PM: noirq resume of devices complete after 2.600 msecs
[ 38.454969] PM: early resume of devices complete after 0.592 msecs
[ 38.455379] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 38.455403] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 38.455778] 1390..dw_mci_set_ios: no card. [mmc1]
[ 38.455995] dwc_otg_hcd_resume, usb device mode
[ 38.461060] phy_power_on: enable = 1
[ 38.495754] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 38.498369] rk_spdif:spdif:Entered spdif_resume
[ 38.498608] PM: resume of devices complete after 44.325 msecs
[ 38.499024] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 38.499042] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 38.499051] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 38.499959] [BT_RFKILL]: ** disable irq
[ 38.730640] Restarting tasks … [ 38.735874] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 38.736723] PM: suspend exit 2011-01-01 12:04:05.243739417 UTC
done.
[ 38.812953] PM: suspend entry 2011-01-01 12:04:05.321191209 UTC
[ 38.819608] PM: Syncing filesystems … done.
[ 38.829586] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 38.841162] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 38.851976] Suspending console(s) (use no_console_suspend to debug)
[ 38.860372] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 38.860404] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 38.860422] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 38.860771] rk_spdif:Entered spdif_suspend
[ 38.860788] rk_spdif:spdif:Entered spdif_suspend
[ 38.863080] dwc_otg_hcd_suspend, usb device mode
[ 38.865007] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 38.923353] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 38.924086] phy_power_on: enable = 0
[ 38.925692] PM: suspend of devices complete after 66.450 msecs
[ 38.926783] PM: late suspend of devices complete after 1.064 msecs
[ 38.928065] PM: noirq suspend of devices complete after 1.281 msecs
[ 38.928095] Disabling non-boot CPUs …
[ 38.930363] CPU1: shutdown
[ 38.933837] CPU2: shutdown
[ 38.936546] CPU3: shutdown
[ 38.938449] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 38.938498] rkpm_enter:
[ 38.938521] GPIO0_INTEN: 00000020
[ 38.938530] GPIO4_INTEN: 80000000
[ 38.938541] GPIO6_INTEN: 00400000
[ 38.938549] GPIO7_INTEN: 00000010
[ 39.022849] Resume caused by IRQ 120
[ 39.022896] wakeup irq: 00000000 00000000 01000000 00000000
[ 39.022909] wakeup gpio7: 00000010
[ 39.023113] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 39.023146] Suspended for 0.000 seconds
[ 39.023973] Enabling non-boot CPUs …
[ 39.024732] CPU1: Booted secondary processor
[ 39.025950] CPU1 is up
[ 39.026371] CPU2: Booted secondary processor
[ 39.026973] CPU2 is up
[ 39.027391] CPU3: Booted secondary processor
[ 39.028069] CPU3 is up
[ 39.030570] PM: noirq resume of devices complete after 2.508 msecs
[ 39.031647] PM: early resume of devices complete after 0.587 msecs
[ 39.031963] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 39.032032] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 39.032418] 1390..dw_mci_set_ios: no card. [mmc1]
[ 39.032617] dwc_otg_hcd_resume, usb device mode
[ 39.037755] phy_power_on: enable = 1
[ 39.072486] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 39.075035] rk_spdif:spdif:Entered spdif_resume
[ 39.075140] PM: resume of devices complete after 44.181 msecs
[ 39.075541] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 39.075556] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 39.075565] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 39.076071] [BT_RFKILL]: ** disable irq
[ 39.307419] Restarting tasks … [ 39.312775] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 39.313377] PM: suspend exit 2011-01-01 12:05:05.243674083 UTC
done.
[ 39.382791] PM: suspend entry 2011-01-01 12:05:05.314189458 UTC
[ 39.389260] PM: Syncing filesystems … done.
[ 39.400272] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 39.411893] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 39.422465] Suspending console(s) (use no_console_suspend to debug)
[ 39.430885] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 39.430995] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 39.431011] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee37c300
[ 39.431363] rk_spdif:Entered spdif_suspend
[ 39.431378] rk_spdif:spdif:Entered spdif_suspend
[ 39.435420] hym8563_rtc_set_alarm:diff_sec= 60s , use time
[ 39.436123] dwc_otg_hcd_suspend, usb device mode
[ 39.490261] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 39.490986] phy_power_on: enable = 0
[ 39.492731] PM: suspend of devices complete after 62.897 msecs
[ 39.493853] PM: late suspend of devices complete after 1.103 msecs
[ 39.495133] PM: noirq suspend of devices complete after 1.274 msecs
[ 39.495159] Disabling non-boot CPUs …
[ 39.497531] CPU1: shutdown
[ 39.501225] CPU2: shutdown
[ 39.503881] CPU3: shutdown
[ 39.505663] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 39.505726] rkpm_enter:
[ 39.505751] GPIO0_INTEN: 00000020
[ 39.505761] GPIO4_INTEN: 80000000
[ 39.505772] GPIO6_INTEN: 00400000
[ 39.505780] GPIO7_INTEN: 00000010
[ 39.590037] Resume caused by IRQ 126, otg_bvalid
[ 39.590085] wakeup irq: 00000000 00000000 40000000 00000000
[ 39.590284] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x0
[ 39.590322] Suspended for 0.000 seconds
[ 39.591154] Enabling non-boot CPUs …
[ 39.591917] CPU1: Booted secondary processor
[ 39.593057] CPU1 is up
[ 39.593474] CPU2: Booted secondary processor
[ 39.594208] CPU2 is up
[ 39.594489] vbus detect**
[ 39.594629] CPU3: Booted secondary processor
[ 39.595741] CPU3 is up
[ 39.596687] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 39.598304] PM: noirq resume of devices complete after 2.574 msecs
[ 39.598974] PM: early resume of devices complete after 0.447 msecs
[ 39.599332] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 39.599352] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 39.599785] 1390..dw_mci_set_ios: no card. [mmc1]
[ 39.599980] dwc_otg_hcd_resume, usb device mode
[ 39.605057] phy_power_on: enable = 1
[ 39.639761] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 39.641779] PM: resume of devices complete after 43.475 msecs
[ 39.641892] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 39.641905] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 39.641917] cpufreq: cpufreq_resume: Failed to start governor for policy: ee37c300
[ 39.642381] rk_spdif:spdif:Entered spdif_resume
[ 39.642928] [BT_RFKILL]: ** disable irq
[ 39.776409] Using Buffer DMA mode
[ 39.776428] Periodic Transfer Interrupt Enhancement - disabled
[ 39.776437] Multiprocessor Interrupt Enhancement - disabled
[ 39.776446] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 39.776454] ^^^^^^^^^^^^^^^^^Device Mode
[ 39.776550] soft connect!!!
[ 39.892843] USB RESET
[ 39.913866] Restarting tasks … done.
[ 39.920830] PM: suspend exit 2011-01-01 12:05:48.285061875 UTC
[ 39.958650] dsi->phy.sys_clk =24000000
[ 39.986214] android_work: sent uevent USB_STATE=CONNECTED
[ 39.989726] USB RESET
[ 40.144592] android_usb gadget: high-speed config #1: android
[ 40.145683] android_work: sent uevent USB_STATE=CONFIGURED
[ 40.450787] rk3288-lcdc lcdc0: blank mode:0
[ 40.460774] rk3288-hdmi ff980000.hdmi: Removed.
[ 50.042220] rk3288-hdmi ff980000.hdmi: Removed.
[ 50.257649] rk3288-lcdc lcdc0: blank mode:4
[ 50.281099] session end ,soft disconnect***
[ 50.286830] USB RESET
[ 50.287046] pcd_pullup, is_on 0
[ 50.292551] android_work: sent uevent USB_STATE=DISCONNECTED
[ 50.292636] read descriptors
[ 50.292656] read strings
[ 50.292779] pcd_pullup, is_on 1
[ 50.428352] rk_battery_charger_detect_cb , battery_charger_detect 0
[ 50.715415] PM: suspend entry 2011-01-01 12:05:59.255126630 UTC
[ 50.721276] PM: Syncing filesystems … done.
[ 50.748877] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 50.760347] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 50.771024] Suspending console(s) (use no_console_suspend to debug)
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-01 (Nov 27 2014 - 16:44:27)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2014-11-27#2.19
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
kernel @ 0x02000000 (0x00653548)
ramdisk @ 0x04bf0000 (0x00122fc0)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480c000, end 0482a935 … OK
[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #12 SMP PREEMPT Wed Apr 22 11:14:57 CST 2015
[ 0.000000] ion heap(cma): base(40000000) size(28000000) align(0)
[ 0.000000] cma: CMA: reserved 640 MiB at 40000000
[ 0.000000] ion_reserve: cma reserved base 40000000 size 671088640
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ddc000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-11-27_16:44:27
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1388480k/1388480k available, 708672k reserved, 663552K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0ae28fc (11115 kB)
[ 0.000000] .init : 0xc0ae3000 - 0xc0b776c0 ( 594 kB)
[ 0.000000] .data : 0xc0b78000 - 0xc0c7f438 (1054 kB)
[ 0.000000] .bss : 0xc0c7f438 - 0xc0d9d7c4 (1145 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rkclk_init_clks: cnt_rate = 31
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:33
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:32
[ 0.304435] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.304451] pid_max: default: 32768 minimum: 301
[ 0.304555] Security Framework initialized
[ 0.304572] SELinux: Initializing.
[ 0.304643] Mount-cache hash table entries: 512
[ 0.305283] Initializing cgroup subsys debug
[ 0.305297] Initializing cgroup subsys memory
[ 0.305323] Initializing cgroup subsys freezer
[ 0.305351] CPU: Testing write buffer coherency: ok
[ 0.305660] /cpus/cpu@0 missing clock-frequency property
[ 0.305673] /cpus/cpu@1 missing clock-frequency property
[ 0.305682] /cpus/cpu@2 missing clock-frequency property
[ 0.305691] /cpus/cpu@3 missing clock-frequency property
[ 0.305754] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.305805] Setting up static identity map for 0xc07e2690 - 0xc07e26e8
[ 0.308762] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1661 (version 3.0)
[ 0.382490] CPU1: Booted secondary processor
[ 0.382523] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.402176] CPU2: Booted secondary processor
[ 0.402199] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.421883] CPU3: Booted secondary processor
[ 0.421906] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.422008] Brought up 4 CPUs
[ 0.422036] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.422045] CPU: All CPU(s) started in SVC mode.
[ 0.422771] devtmpfs: initialized
[ 0.427789] pinctrl core: initialized pinctrl subsystem
[ 0.428038] regulator-dummy: no parameters
[ 0.439438] NET: Registered protocol family 16
[ 0.441234] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.441598] ion_snapshot: 0x2e248000 map to 0xf0107000 and copy to 0xc0d78dc4 (version 0.1)
[ 0.441916] Registered FIQ tty driver
[ 0.442330] fiq-debugger is disabled in device tree
[ 0.442898] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.442926] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.442944] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.442961] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.443049] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.443112] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.443172] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.443231] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.443291] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.443350] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.443410] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.443469] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.443535] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.443597] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.443611] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.443622] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.443634] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.444142] rockchip_interrupts_register:bank_num=7
[ 0.446046] rockchip_pinctrl_probe:init ok
[ 0.452121] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.452209] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.452223] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.452384] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.452455] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.452467] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.452629] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.452699] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.452711] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.452865] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.452933] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.452945] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.453113] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.453186] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453198] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.453355] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.453426] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453437] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.453608] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.453680] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453692] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.455595] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.455608] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.455805] DDR DEBUG: version 1.00 20140603
[ 0.455834] DDR DEBUG: Channel a:
[ 0.455842] DDR DEBUG: DDR3 Device
[ 0.455855] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.455864] DDR DEBUG: Channel b:
[ 0.455871] DDR DEBUG: DDR3 Device
[ 0.455883] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.455892] DDR DEBUG: addr=0xc87000
[ 0.455901] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.455910] DDR DEBUG: socAddr[0]=0xc87000, socAddr[1]=0xc87100
[ 0.455919] DDR DEBUG: chAddr[0]=0xc87000, chAddr[1]=0xc87000
[ 0.455930] DDR DEBUG: dtar[0]=0x70190000, dtar[1]=0x70190000
[ 0.456169] DDR DEBUG: init success!!! freq=300MHz
[ 0.456177] DDR DEBUG: Channel a:
[ 0.456190] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,1 extra clock, DGPS=360,360
[ 0.456202] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456214] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,1 extra clock, DGPS=360,360
[ 0.456226] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456237] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.456247] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.456255] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.456262] DDR DEBUG: Channel b:
[ 0.456273] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456285] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456297] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456309] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.456320] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.456329] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.456337] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.478097] bio: create slab at 0
[ 0.478940] SCSI subsystem initialized
[ 0.479090] usbcore: registered new interface driver usbfs
[ 0.479133] usbcore: registered new interface driver hub
[ 0.479212] usbcore: registered new device driver usb
[ 0.480587] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.482713] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.484310] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.485228] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.485465] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.485935] media: Linux media interface: v0.10
[ 0.485975] Linux video capture interface: v2.00
[ 0.486023] pps_core: LinuxPPS API ver. 1 registered
[ 0.486033] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.486053] PTP clock support registered
[ 0.486523] Rockchip ion module is successfully loaded (v1.0)
[ 0.486674] Advanced Linux Sound Architecture Driver Initialized.
[ 0.487057] Bluetooth: Core ver 2.16
[ 0.487090] NET: Registered protocol family 31
[ 0.487099] Bluetooth: HCI device and connection manager initialized
[ 0.487114] Bluetooth: HCI socket layer initialized
[ 0.487126] Bluetooth: L2CAP socket layer initialized
[ 0.487151] Bluetooth: SCO socket layer initialized
[ 0.487358] cfg80211: Calling CRDA to update world regulatory domain
[ 0.488592] act8846_i2c_probe,line=898
[ 0.489587] act8846_parse_dt,line=746
[ 0.490311] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.490330] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.490344] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.490359] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.492217] act_dcdc1: 1200 mV
[ 0.494930] vccio: 3300 mV
[ 0.496782] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.499493] act_dcdc4: 2000 mV
[ 0.500733] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.502794] act_ldo2: 1000 mV
[ 0.504870] act_ldo3: 2800 mV
[ 0.506935] act_ldo4: 3300 mV
[ 0.508987] act_ldo5: 3300 mV
[ 0.511088] act_ldo6: 1000 mV
[ 0.513156] vcc_18: 1800 mV
[ 0.515225] act_ldo8: 1800 mV
[ 0.519986] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.524686] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.525456] Switching to clocksource arch_sys_counter
[ 0.545605] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.545618] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.546018] rk-screen rk_screen.8: rockchip screen probe success
[ 0.546180] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.546199] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.546515] rk32-edp ff970000.edp: screen is not edp!
[ 0.546530] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.546679] rk32-dsi
[ 0.546820] dsi->host.irq =51
[ 0.546838] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
[ 0.546845] mipi_dsi v1.3 2014-04-17
[ 0.546870] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
[ 0.546881] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.547405] rk3288-lcdc lcdc0: request lcd_rst gpio fail:-16
[ 0.547647] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.547979] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.548132] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.548282] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.559351] rk3288-lcdc lcdc0: lcdc0: dclk:120000000>>fps:50
[ 0.559365] dsi->phy.sys_clk =24000000
[ 1.056876] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.081883] alloc_buffer:ion_phy_addr=0x40000000
[ 1.094351] fb0:phy:40000000>>vir:f0171000>>len:0x1900000
[ 1.100170] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
[ 1.100329] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 1.100340] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 1.100554] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.100855] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.101012] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.101164] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.148422] alloc_buffer:ion_phy_addr=0x41900000
[ 1.148438] fb0:phy:41900000>>vir: (null)>>len:0x3000000
[ 1.148453] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
[ 1.149115] rockchip_set_mux:warning ignore bank num 15
[ 1.149235] rockchip_set_mux:warning ignore bank num 15
[ 1.149345] rockchip_set_mux:warning ignore bank num 15
[ 1.149451] rockchip_set_mux:warning ignore bank num 15
[ 1.149556] rockchip_set_mux:warning ignore bank num 15
[ 1.149658] rockchip_set_mux:warning ignore bank num 15
[ 1.150220] rockchip_set_mux:warning ignore bank num 15
[ 1.150361] rockchip_set_mux:warning ignore bank num 15
[ 1.150893] rockchip_set_mux:warning ignore bank num 15
[ 1.151033] rockchip_set_mux:warning ignore bank num 15
[ 1.151580] rockchip_set_mux:warning ignore bank num 15
[ 1.151716] rockchip_set_mux:warning ignore bank num 15
[ 1.152245] rockchip_set_mux:warning ignore bank num 15
[ 1.152391] rockchip_set_mux:warning ignore bank num 15
[ 1.153773] NET: Registered protocol family 2
[ 1.154201] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.154332] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.154466] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.154514] TCP: reno registered
[ 1.154529] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.154562] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.154766] NET: Registered protocol family 1
[ 1.154949] Unpacking initramfs…
[ 1.217161] Freeing initrd memory: 1160K (c4bf0000 - c4d12000)
[ 1.217749] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.218223] probe device ff9a0000.vpu_service
[ 1.218396] vpu_service: power on
[ 1.219453] checking hw id 4831
[ 1.219826] vpu_service set to auto frequency mode
[ 1.219861] vpu_service: power off…
[ 1.219897] done
[ 1.219904] init success
[ 1.219951] probe device ff9c0000.hevc_service
[ 1.220140] hevc_service: power on
[ 1.221174] checking hw id 6867
[ 1.221387] hevc_service: power off…
[ 1.221422] done
[ 1.221430] init success
[ 1.221542] rknandbase v1.0 2014-03-31
[ 1.221641] rknand ff400000.nandc0: no irq resource?
[ 1.221770] rknand_driver:ret = 0
[ 1.223353] audit: initializing netlink socket (disabled)
[ 1.223390] type=2000 audit(0.920:1): initialized
[ 1.224171] bounce pool size: 64 pages
[ 1.228578] fuse init (API version 7.22)
[ 1.228913] msgmni has been set to 1450
[ 1.230637] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.230652] io scheduler noop registered
[ 1.230660] io scheduler deadline registered
[ 1.230743] io scheduler cfq registered (default)
[ 1.234341] rga2 ff920000.rga: rga ion client create success!
[ 1.234479] rga: Driver loaded succesfully
[ 1.235094] IEP Driver loaded succesfully
[ 1.235185] Module initialized.
[ 1.236031] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.236048] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.237329] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.237346] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.237620] pwm-voltage-regulator pwm_regulator.28: unable to request PWM, trying legacy API
[ 1.237635] pwm-voltage-regulator pwm_regulator.28: unable to request legacy PWM
[ 1.237643] pwm_regulator_probe:error
[ 1.237663] platform pwm_regulator.28: Driver pwm-voltage-regulator requests probe deferral
[ 1.237987] rk_serial.c v1.8 2014-03-04
[ 1.238192] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.238383] serial ff180000.serial: membase f1a74000
[ 1.238512] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 2.916479] console [ttyS2] enabled
[ 2.920106] serial ff690000.serial: membase fed60000
[ 2.927661] loop: module loaded
[ 2.931304] SCSI Media Changer driver v0.25
[ 2.935817] tun: Universal TUN/TAP device driver, 1.6
[ 2.940822] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.947019] vmac_init.
[ 2.949844] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 2.956535] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 2.963479] stmmac_probe_config_dt: clock input or output? (input).
[ 2.969653] stmmac_probe_config_dt: TX delay(0x30).
[ 2.974448] stmmac_probe_config_dt: RX delay(0x20).
[ 2.979301] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 2.984608] stmmc_pltfr_init:
[ 2.987812] stmmc_pltfr_init: init for RGMII
[ 2.992013] tx delay=0x30
[ 2.992013] rx delay=0x20
[ 2.997596] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.002563] Normal descriptors
[ 3.005666] Ring mode enabled
[ 3.008662] DMA HW capability register supported
[ 3.013116] RX Checksum Offload Engine supported (type 2)
[ 3.018710] TX Checksum insertion supported
[ 3.022908] Wake-Up On Lan supported
[ 3.026545] Enable RX Mitigation via HW Watchdog Timer
[ 3.032082] PPP generic driver version 2.4.2
[ 3.036441] PPP BSD Compression module registered
[ 3.041080] PPP Deflate Compression module registered
[ 3.046071] PPP MPPE Compression module registered
[ 3.050785] NET: Registered protocol family 24
[ 3.055185] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 3.064693] CSLIP: code copyright 1989 Regents of the University of California.
[ 3.071878] Rockchip WiFi SYS interface (V1.00) …
[ 3.076800] esp_mem_init enter date Dec 26 2014 09:48:50
[ 3.082054] esp_mem_init complete
[ 3.085473] usbcore: registered new interface driver catc
[ 3.090809] usbcore: registered new interface driver kaweth
[ 3.096311] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 3.103627] usbcore: registered new interface driver pegasus
[ 3.109219] usbcore: registered new interface driver rtl8150
[ 3.114823] usbcore: registered new interface driver r8152
[ 3.120227] hso: drivers/net/usb/hso.c: Option Wireless
[ 3.125432] usbcore: registered new interface driver hso
[ 3.130703] usbcore: registered new interface driver asix
[ 3.136068] usbcore: registered new interface driver ax88179_178a
[ 3.142086] usbcore: registered new interface driver cdc_ether
[ 3.147859] usbcore: registered new interface driver cdc_eem
[ 3.153461] usbcore: registered new interface driver dm9601
[ 3.158980] usbcore: registered new interface driver dm9620
[ 3.164507] usbcore: registered new interface driver smsc75xx
[ 3.170195] usbcore: registered new interface driver smsc95xx
[ 3.175897] usbcore: registered new interface driver gl620a
[ 3.181403] usbcore: registered new interface driver net1080
[ 3.187006] usbcore: registered new interface driver plusb
[ 3.192440] usbcore: registered new interface driver rndis_host
[ 3.198301] usbcore: registered new interface driver cdc_subset
[ 3.204159] usbcore: registered new interface driver zaurus
[ 3.209664] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 3.217002] usbcore: registered new interface driver int51x1
[ 3.222607] usbcore: registered new interface driver kalmia
[ 3.228116] usbcore: registered new interface driver ipheth
[ 3.233638] usbcore: registered new interface driver sierra_net
[ 3.239500] usbcore: registered new interface driver cx82310_eth
[ 3.245459] usbcore: registered new interface driver cdc_ncm
[ 3.251053] usbcore: registered new interface driver qmi_wwan
[ 3.256755] usbcore: registered new interface driver cdc_mbim
[ 3.262417] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.271195] ehci_rk_probe f1b00000 f1b00010
[ 3.275329] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 3.282799] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 3.291223] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 3.310248] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 3.316816] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.323544] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.330659] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 3.336907] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 3.342226] usb usb1: SerialNumber: ff500000.usb
[ 3.347173] hub 1-0:1.0: USB hub found
[ 3.350890] hub 1-0:1.0: 1 port detected
[ 3.379115] ehci_rk_probe ok
[ 3.382086] usbcore: registered new interface driver cdc_acm
[ 3.387650] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.395571] usbcore: registered new interface driver usblp
[ 3.401010] usbcore: registered new interface driver cdc_wdm
[ 3.406625] usbcore: registered new interface driver usb-storage
[ 3.412572] usbcore: registered new interface driver ums-alauda
[ 3.418418] usbcore: registered new interface driver ums-cypress
[ 3.424362] usbcore: registered new interface driver ums-datafab
[ 3.430303] usbcore: registered new interface driver ums_eneub6250
[ 3.436403] usbcore: registered new interface driver ums-freecom
[ 3.442346] usbcore: registered new interface driver ums-isd200
[ 3.448245] usbcore: registered new interface driver ums-jumpshot
[ 3.454262] usbcore: registered new interface driver ums-karma
[ 3.460041] usbcore: registered new interface driver ums-onetouch
[ 3.466058] usbcore: registered new interface driver ums-sddr09
[ 3.471916] usbcore: registered new interface driver ums-sddr55
[ 3.477774] usbcore: registered new interface driver ums-usbat
[ 3.483578] usbcore: registered new interface driver usbserial
[ 3.489355] usbcore: registered new interface driver usbserial_generic
[ 3.495791] usbserial: USB Serial support registered for generic
[ 3.501733] usbcore: registered new interface driver option
[ 3.507247] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.514144] usbcore: registered new interface driver trancevibrator
[ 3.520318] usb20_otg: version 3.10a 21-DEC-2012
[ 3.525229] f1b80040
[ 3.527401] Core Release: 3.10a
[ 3.530493] Setting default values for core params
[ 3.535306] Using Buffer DMA mode
[ 3.538581] Periodic Transfer Interrupt Enhancement - disabled
[ 3.544314] Multiprocessor Interrupt Enhancement - disabled
[ 3.549801] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.554085] ^^^^^^^^^^^^^^^^^Device Mode
[ 3.557953] Dedicated Tx FIFOs mode
[ 3.561391] pcd_init otg_dev = ed675540
[ 3.565284] usb20_otg ff580000.usb: DWC OTG Controller
[ 3.570365] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.577760] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 3.583453] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.590142] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.597253] usb usb2: Product: DWC OTG Controller
[ 3.601880] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.607453] usb usb2: SerialNumber: ff580000.usb
[ 3.612346] hub 2-0:1.0: USB hub found
[ 3.616061] hub 2-0:1.0: 1 port detected
[ 3.620208] usb20_host: version 3.10a 21-DEC-2012
[ 3.627292] f1c00040
[ 3.629445] Core Release: 3.10a
[ 3.632539] Setting default values for core params
[ 3.637351] Using Buffer DMA mode
[ 3.640613] Periodic Transfer Interrupt Enhancement - disabled
[ 3.646359] Multiprocessor Interrupt Enhancement - disabled
[ 3.651837] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.656128] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.659917] usb20_host ff540000.usb: DWC OTG Controller
[ 3.665080] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 3.672537] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 3.678359] Init: Power Port (0)
[ 3.681579] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.688266] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.695375] usb usb3: Product: DWC OTG Controller
[ 3.700002] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.705574] usb usb3: SerialNumber: ff540000.usb
[ 3.710457] hub 3-0:1.0: USB hub found
[ 3.714209] hub 3-0:1.0: 1 port detected
[ 3.718580] .. rk pwm remotectl v1.0 init
[ 3.722593] remotectl probe j=0x0
[ 3.726005] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 3.732501] pwm enable val=0x646205
[ 3.736293] usbcore: registered new interface driver xpad
[ 3.741642] usbcore: registered new interface driver usb_acecad
[ 3.747516] usbcore: registered new interface driver aiptek
[ 3.753040] usbcore: registered new interface driver gtco
[ 3.758382] usbcore: registered new interface driver hanwang
[ 3.763992] usbcore: registered new interface driver kbtab
[ 3.769424] usbcore: registered new interface driver wacom
[ 3.910442] input: synaptics_dsx as /devices/ff140000.i2c/i2c-1/1-0020/input/input1
[ 3.920963] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 3.931236] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 3.937528] i2c /dev entries driver
[ 3.941658] IR NEC protocol handler initialized
[ 3.946115] IR RC5(x) protocol handler initialized
[ 3.950852] IR RC6 protocol handler initialized
[ 3.955307] IR JVC protocol handler initialized
[ 3.959770] IR Sony protocol handler initialized
[ 3.964310] IR RC5 (streamzap) protocol handler initialized
[ 3.969804] IR SANYO protocol handler initialized
[ 3.974429] IR MCE Keyboard/mouse protocol handler initialized
[ 3.980302] usbcore: registered new interface driver uvcvideo
[ 3.985951] USB Video Class driver (1.1.1)
[ 3.990006] CamSys driver version: v0.23.0, CamSys head file version: v0.9.0
[ 3.998385] D1:camsys_platform_probe(1067): 1-gpios-cifpower锛gpio=236
[ 4.005002] D1:camsys_platform_probe(1070): gpios-cifpower锛gpio_request
[ 4.011788] D1:camsys_platform_probe(1072): 1-gpios-cifpower锛gpio_request=0
[ 4.018904] D1:camsys_platform_probe(1079): gpios-cifpower锛236 high
[ 4.025385] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 4.036215] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf1ab0000 size: 0x4000)
[ 4.048976] D1:camsys_platform_probe(1183): ff910000.isp memory:
[ 4.054886] D1:camsys_platform_probe(1193): Register memory (phy: 0xff910000 vir: 0xf1ae0000 size: 0x10000)
[ 4.064813] D1:camsys_platform_probe(1188): I2c memory (phy: 0x2d6a5000 vir: 0xed6a5000 size: 0x1000)
[ 4.074238] D1:camsys_platform_probe(1208): Probe ff910000.isp device success
[ 4.082583] rockchip_temp_probe,line=362
[ 4.136792] tsadc ff280000.tsadc: initialized
[ 4.141437] device-mapper: uevent: version 1.0.3
[ 4.146180] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 4.154746] Bluetooth: HCI UART driver ver 2.2
[ 4.159139] Bluetooth: HCI H4 protocol initialized
[ 4.163849] Bluetooth: HCILL protocol initialized
[ 4.171557] cpufreq version 1.0, suspend freq 1200 MHz
[ 4.176800] cpuidle: using governor ladder
[ 4.180830] cpuidle: using governor menu
[ 4.184711] Synopsys Designware Multimedia Card Interface Driver
[ 4.190872] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 4.196985] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 4.203972] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 4.210422] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.216308] 1390..dw_mci_set_ios: no card. [mmc0]
[ 4.235207] 1390..dw_mci_set_ios: no card. [mmc0]
[ 4.254927] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 4.255004] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 4.255028] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 4.255685] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 4.285688] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 4.292729] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
[ 4.299147] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.305021] mmc1: no vmmc regulator found
[ 4.309130] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 4.315921] 1390..dw_mci_set_ios: no card. [mmc1]
[ 4.333591] 1390..dw_mci_set_ios: no card. [mmc1]
[ 4.338326] mmc0: BKOPS_EN bit is not set
[ 4.343554] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 4.353243] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 4.361691] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 4.361703] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
[ 4.361816] mmc0: new high speed MMC card at address 0001
[ 4.362121] mmcblk0: mmc0:0001 MAG2GA 14.5 GiB
[ 4.362440] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 4.362450] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 4.362458] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 4.362465] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 4.362472] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 4.362478] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 4.362485] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 4.362492] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 4.362499] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 4.362506] system: 0x012400000 – 0x042400000 (768 MB)
[ 4.362513] metadata: 0x042400000 – 0x042800000 (4 MB)
[ 4.362520] userdata: 0x042800000 – 0x082800000 (1024 MB)
[ 4.362527] radical_update: 0x082800000 – 0x086800000 (64 MB)
[ 4.362534] user: 0x086800000 – 0x3a3a00000 (12754 MB)
[ 4.364345] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141390..dw_mci_set_ios: no card. [mmc1]
[ 4.473503] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 4.479890] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 4.486083] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 4.493151] 3379..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 4.499489] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.505655] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.520577] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.540294] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.540308] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 4.540321] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 4.540695] leds-gpio leds.37: pins are not configured from the driver
[ 4.541050] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.543666] usbcore: registered new interface driver usbhid
[ 4.543675] usbhid: USB HID core driver
[ 4.544130] zram: Created 1 device(s) …
[ 4.544659] ashmem: initialized
[ 4.544858] logger: created 256K log ‘log_main’
[ 4.545027] logger: created 256K log ‘log_events’
[ 4.545186] logger: created 256K log ‘log_radio’
[ 4.545348] logger: created 256K log ‘log_system’
[ 4.547023] input: rk29-keypad as /devices/ff100000.adc/key.39/input/input2
[ 4.614154] es8323 probe i2c recv ok
[ 4.617770] i2c-core: driver [ES8323] using legacy suspend method
[ 4.623778] i2c-core: driver [ES8323] using legacy resume method
[ 4.630770] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered
[ 4.639137] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 4.645652] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral
[ 4.654575] es8323_probe
[ 5.289468] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 5.297353] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 5.305253] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 5.313637] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 5.321514] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 5.330047] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 5.338228] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 5.346019] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 5.353890] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 5.361758] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 5.369629] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 5.378003] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 5.386359] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 5.394297] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 5.401946] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 5.409579] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 5.417224] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 5.425606] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 5.434044] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 5.441772] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 5.449483] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 5.457183] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 5.464879] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 5.473351] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 5.481821] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 5.489782] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 5.497739] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 5.505700] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 5.513652] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 5.521606] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 5.529568] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 5.537522] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 5.545504] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 5.553198] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 5.560898] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 5.568601] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 5.576300] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 5.584426] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 5.592546] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 5.600328] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 5.608116] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 5.615898] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 5.623684] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 5.631974] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 5.640385] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 5.646308] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 5.652127] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 5.657951] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 5.663703] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 5.673043] rockchip-es8323 rockchip-es8323.34: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
[ 5.681474] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.34/sound/card0/input3
[ 5.691139] rockchip-hdmi-i2s rockchip-hdmi-i2s.31: rk-hdmi-i2s-hifi ↔ rockchip-i2s.0 mapping ok
[ 5.700346] u32 classifier
[ 5.703021] Actions configured
[ 5.706366] Netfilter messages via NETLINK v0.30.
[ 5.711026] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.717259] ctnetlink v0.93: registering with nfnetlink.
[ 5.722561] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.729399] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.735330] xt_time: kernel timezone is -0000
[ 5.739761] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.745179] arp_tables: (C) 2002 David S. Miller
[ 5.749741] TCP: cubic registered
[ 5.753004] Initializing XFRM netlink socket
[ 5.757362] NET: Registered protocol family 10
[ 5.762115] mip6: Mobile IPv6
[ 5.765047] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.770444] sit: IPv6 over IPv4 tunneling driver
[ 5.775232] NET: Registered protocol family 17
[ 5.779610] NET: Registered protocol family 15
[ 5.784022] Bridge firewalling registered
[ 5.787963] Ebtables v2.0 registered
[ 5.791603] Bluetooth: RFCOMM TTY layer initialized
[ 5.796411] Bluetooth: RFCOMM socket layer initialized
[ 5.801467] Bluetooth: RFCOMM ver 1.11
[ 5.805150] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.810375] Bluetooth: BNEP filters: protocol multicast
[ 5.815509] Bluetooth: BNEP socket layer initialized
[ 5.820406] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.826234] Bluetooth: HIDP socket layer initialized
[ 5.831130] l2tp_core: L2TP core driver, V2.0
[ 5.835415] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 5.840126] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 5.844888] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 5.849606] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 5.856445] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 5.863457] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 5.871834] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 5.879113] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 5.888093] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 5.897151] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 5.902301] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 5.910621] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 5.915275] [BT_RFKILL]: Enter rfkill_rk_init
[ 5.919689] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 5.927737] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 5.935688] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 5.943646] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 5.951515] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 5.959753] [BT_RFKILL]: Request irq for bt wakeup host
[ 5.964950] [BT_RFKILL]: ** disable irq
[ 5.968786] [BT_RFKILL]: ap6335 device registered.
[ 5.974262] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 5.980827] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 5.988379] rk3288_init_suspend
[ 5.991466] rk3288_suspend_init enter
[ 5.995165] rk3288_suspend_init: pm_ctrbits =200007
[ 5.999984] gpio_get_dts_info suspend:4
[ 6.003752] gpio_get_dts_info resume:4
[ 6.007438] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.015516] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.023541] clks_gating_suspend_init:clkgt info ok
[ 6.028330] Registering SWP/SWPB emulation handler
[ 6.033324] ddrfreq: verion 1.2 20140526
[ 6.037190] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
[ 6.048217] ddrfreq: auto-freq=0
[ 6.051398] ddrfreq: auto-freq-table[0] 240MHz
[ 6.055767] ddrfreq: auto-freq-table[1] 324MHz
[ 6.060130] ddrfreq: auto-freq-table[2] 396MHz
[ 6.064493] ddrfreq: auto-freq-table[3] 528MHz
[ 6.070120] regulator-dummy: disabling
[ 6.074132] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered
[ 6.082364] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 6.088887] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral
[ 6.097524] pcd_pullup, is_on 0
[ 6.100640] file system registered
[ 6.104477] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 6.111247] android_usb gadget: Number of LUNs=2
[ 6.115808] lun0: LUN: removable file: (no medium)
[ 6.120609] lun1: LUN: removable file: (no medium)
[ 6.125516] android_usb gadget: android_usb ready
[ 6.130658] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:02 UTC (1293883202)
[ 6.143527] rk_spdif:rk_spdif_init
[ 6.147054] rk_spdif:Entered spdif_probe
[ 6.151097] rk_spdif:spdif:spdif probe ok!
[ 6.155612] usbcore: registered new interface driver snd-usb-audio
[ 6.161705] ALSA device list:
[ 6.164666] #0: RK_ES8323
[ 6.164770] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
[ 6.176826] #1: RK-HDMI-I2S
[ 6.179741] #2: RK-HDMI-SPDIF
[ 6.183149] Freeing unused kernel memory: 592K (c0ae3000 - c0b77000)
[ 6.193810] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 6.201764] SELinux: the above unknown classes and permissions will be denied
[ 6.531686] type=1403 audit(1293883202.900:2): policy loaded auid=4294967295 ses=4294967295
[ 6.540035] SELinux: Loaded policy from /sepolicy
[ 6.546570] type=1404 audit(1293883202.910:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 7.535636] init: could not import file ‘/init.usbstorage.rc’ from ‘/init.rc’
[ 7.543064] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 7.601952] init: /dev/hw_random not found
[ 7.606028] keychord: using input dev ff680000.pwm for fevent
[ 7.611736] keychord: using input dev rk29-keypad for fevent
[ 7.622369] fs_mgr: parse_link_device : path = NULL
[ 7.627185] fs_mgr: parse_link_device : path = NULL
[ 7.632020] fs_mgr: parse_link_device : path = NULL
[ 7.636877] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 7.655456] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
[ 7.673742] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 7.693243] EXT4-fs (mmcblk0p8): recovery complete
[ 7.698725] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.716915] EXT4-fs (mmcblk0p11): recovery complete
[ 7.721740] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.892205] EXT4-fs (mmcblk0p12): 2 orphan inodes deleted
[ 7.897537] EXT4-fs (mmcblk0p12): recovery complete
[ 7.924736] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.950549] mali pd enabled
[ 7.953305] clk enabled
[ 7.956908] MALI_DVFS_STEP=5,div_dvfs=7
[ 7.960681] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
[ 7.967720] mali_dvfs_infotbl[1].clock=179000,min_threshold=66,max_threshold=77
[ 7.974923] mali_dvfs_infotbl[2].clock=297000,min_threshold=73,max_threshold=84
[ 7.982105] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
[ 7.989310] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
[ 7.996678] gpufreq_input_connect
[ 7.999939] turn on mali power
[ 8.002940] kbase_platform_rk_init,register_reboot_notifier
[ 8.008450] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 8.015257] mali ffa30000.gpu: Probed as mali0
[ 8.022263] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 8.043395] init: /dev/hw_random not found
[ 8.055468] binder: 162:162 transaction failed 29189, size 0-0
[ 8.056905] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
[ 8.059393] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
[ 8.065226] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recvery’
[ 8.066593] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
[ 8.067599] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 8.067613] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 8.067800] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 8.220839] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
[ 8.228905] init: powerctl: cannot expand ‘${sys.powerctl}’
[ 8.234485] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
[ 8.245363] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
[ 8.255668] init: property ‘sys.sysctl.tcp_def_init_rwnd’ doesn’t exist while expanding ‘${sys.sysctl.tcp_def_init_rwnd}’
[ 8.266500] init: cannot expand ‘${sys.sysctl.tcp_def_init_rwnd}’ while writing to ‘/proc/sys/net/ipv4/tcp_default_init_rwnd’
[ 8.278587] android_usb: already disabled
[ 8.284551] read descriptors
[ 8.287395] read strings
[ 8.289951] pcd_pullup, is_on 1
[ 8.375842] fs_mgr: parse_link_device : path = NULL
[ 8.380716] fs_mgr: parse_link_device : path = NULL
[ 8.385559] fs_mgr: parse_link_device : path = NULL
shell@rk3288:/ $ [ 9.100524] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.107910] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.115266] D1:camsys_open(717): camsys_marvin(ed69e110) is opened!
[ 9.121562] rockchip_gpio_request:GPIO7-13
[ 9.125600] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.130172] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.136037] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.142714] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7408,result=0x7408
[ 9.153246] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.160053] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
[ 9.182290] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.190272] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.195317] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.200228] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.209551] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.217921] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.226201] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.236679] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.243023] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.250267] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.257529] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.301384] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.308058] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.316903] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.325361] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.333603] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.341059] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.348571] D1:camsys_release(741): camsys_marvin(ed69e110) is closed
[ 9.361788] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.369175] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.376553] D1:camsys_open(717): camsys_marvin(ed69e110) is opened!
[ 9.382806] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.387345] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.393223] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.399898] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7408,result=0x7408
[ 9.410429] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.417217] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
[ 9.440265] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.448245] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.453246] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.458155] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.467448] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.475788] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.484054] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.494495] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.502006] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 9.508316] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.515536] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.522801] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.559337] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.565957] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.574787] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.583220] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.591473] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.598954] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.606397] D1:camsys_release(741): camsys_marvin(ed69e110) is closed
[ 9.620270] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.627640] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.634995] D1:camsys_open(717): camsys_marvin(ed69e110) is opened!
[ 9.641230] D1:camsys_extdev_register(230): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.651173] D1:camsys_extdev_register(230): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.661115] D1:camsys_extdev_register(230): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 9.671076] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.675615] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.681459] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.688173] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7408,result=0x7408
[ 9.698743] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.705532] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 9.737837] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.745810] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.750790] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.755739] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.765020] D1:camsys_sysctl_extdev(335): Sysctl 11 success, gpio(11) set 1
[ 9.772944] D1:camsys_sysctl_extdev(339): Sysctl 8 success, gpio(79) set 1
[ 9.780797] D1:camsys_sysctl_extdev(339): Sysctl 7 success, gpio(78) set 1
[ 9.790821] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 9.798327] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.804673] D1:camsys_sysctl_extdev(335): Sysctl 7 success, gpio(78) set 0
[ 9.811456] D1:camsys_sysctl_extdev(335): Sysctl 8 success, gpio(79) set 0
[ 9.818302] D1:camsys_sysctl_extdev(339): Sysctl 11 success, gpio(11) set 0
[ 9.856945] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.863567] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.872418] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.880836] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.889066] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.896543] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.904005] D1:camsys_release(741): camsys_marvin(ed69e110) is closed
[ 9.917566] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.924977] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.932336] D1:camsys_open(717): camsys_marvin(ed69e110) is opened!
[ 9.938573] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 9.945548] D1:camsys_extdev_register(255): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
[ 9.954893] rk3288-lcdc lcdc0: blank mode:0
[ 9.976009] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.983999] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.988982] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.993921] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 10.003209] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 10.011535] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 10.019778] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 10.030257] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 10.036623] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 10.039776] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
[ 10.051029] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 10.058259] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 10.075240] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 10.081939] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 10.090779] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x1000000) is deregister success
[ 10.099189] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 10.107435] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.114936] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.122400] D1:camsys_release(741): camsys_marvin(ed69e110) is closed
[ 11.195626] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
[ 17.284760] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 17.387119] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 17.394169] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 17.399474] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 17.404875] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 17.410350] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 17.415840] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 17.421323] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 17.655430] phy_power_on: enable = 1
[ 17.698449] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 17.704776] eth0: device MAC address e2:44:e3:8a:72:3d
[ 17.713996] libphy: stmmac: probed
[ 17.717370] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 17.723358] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 17.837150] wifi_driver_write: wifi driver already rmmod
[ 17.892787] acc_open
[ 17.894970] acc_release
[ 18.829714] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 19.104583] avc: denied { set } for property=sys.vold.hasAsec scontext=u:r:vold:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service
[ 19.117275] init: sys_prop: permission denied uid:0 name:sys.vold.hasAsec
[ 19.124399] init: no such service ‘fuse_internal_sd’
[ 19.454710] init: sys_prop: permission denied uid:10012 name:sys.gmali.version
[ 19.752384] init: sys_prop: permission denied uid:10037 name:sys.gmali.version
[ 20.638754] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 20.737134] f28c7234,f28c7234,f28c7234
[ 32.868553] rk3288-hdmi ff980000.hdmi: Removed.
[ 33.083027] rk3288-lcdc lcdc0: blank mode:4
[ 33.680094] PM: suspend entry 2011-01-01 12:00:30.497389596 UTC
[ 33.686067] PM: Syncing filesystems … done.
[ 33.705471] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 33.717001] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 33.727691] Suspending console(s) (use no_console_suspend to debug)
01-armoff-logdp-osc_offddrc_off2345dDDR Version 1.00 20141007
Memory OK
Memory OK
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
[ 0.305766] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.305782] pid_max: default: 32768 minimum: 301
[ 0.305888] Security Framework initialized
[ 0.305905] SELinux: Initializing.
[ 0.305976] Mount-cache hash table entries: 512
[ 0.306616] Initializing cgroup subsys debug
[ 0.306629] Initializing cgroup subsys memory
[ 0.306656] Initializing cgroup subsys freezer
[ 0.306686] CPU: Testing write buffer coherency: ok
[ 0.306994] /cpus/cpu@0 missing clock-frequency property
[ 0.307006] /cpus/cpu@1 missing clock-frequency property
[ 0.307015] /cpus/cpu@2 missing clock-frequency property
[ 0.307024] /cpus/cpu@3 missing clock-frequency property
[ 0.307087] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.307137] Setting up static identity map for 0xc07e2690 - 0xc07e26e8
[ 0.310211] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1661 (version 3.0)
[ 0.383822] CPU1: Booted secondary processor
[ 0.383854] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.403509] CPU2: Booted secondary processor
[ 0.403532] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.423221] CPU3: Booted secondary processor
[ 0.423244] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.423345] Brought up 4 CPUs
[ 0.423373] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.423382] CPU: All CPU(s) started in SVC mode.
[ 0.424103] devtmpfs: initialized
[ 0.429013] pinctrl core: initialized pinctrl subsystem
[ 0.429263] regulator-dummy: no parameters
[ 0.440680] NET: Registered protocol family 16
[ 0.442455] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.442774] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0d78dc4 (version 0.1)
[ 0.443100] Registered FIQ tty driver
[ 0.443513] fiq-debugger is disabled in device tree
[ 0.444093] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.444115] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.444131] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.444147] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.444237] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.444300] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.444360] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.444419] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.444479] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.444538] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.444598] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.444657] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.444723] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.444785] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.444798] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.444809] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.444821] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.445324] rockchip_interrupts_register:bank_num=7
[ 0.447251] rockchip_pinctrl_probe:init ok
[ 0.453350] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.453438] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453452] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.453612] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.453684] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453696] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.453856] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.453926] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453938] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.454091] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.454159] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.454171] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.454341] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.454413] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.454425] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.454581] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.454650] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.454663] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.454831] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.454901] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.454913] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.456809] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.456822] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.457021] DDR DEBUG: version 1.00 20140603
[ 0.457051] DDR DEBUG: Channel a:
[ 0.457060] DDR DEBUG: DDR3 Device
[ 0.457073] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.457081] DDR DEBUG: Channel b:
[ 0.457088] DDR DEBUG: DDR3 Device
[ 0.457100] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.457109] DDR DEBUG: addr=0xc87000
[ 0.457118] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.457127] DDR DEBUG: socAddr[0]=0xc87000, socAddr[1]=0xc87100
[ 0.457136] DDR DEBUG: chAddr[0]=0xc87000, chAddr[1]=0xc87000
[ 0.457147] DDR DEBUG: dtar[0]=0x70190000, dtar[1]=0x70190000
[ 0.457390] DDR DEBUG: init success!!! freq=300MHz
[ 0.457397] DDR DEBUG: Channel a:
[ 0.457409] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,1 extra clock, DGPS=360,360
[ 0.457422] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457434] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,1 extra clock, DGPS=360,360
[ 0.457446] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457457] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.457466] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.457475] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.457482] DDR DEBUG: Channel b:
[ 0.457493] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457505] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457517] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457528] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457539] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.457548] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.457556] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.479442] bio: create slab at 0
[ 0.480256] SCSI subsystem initialized
[ 0.480401] usbcore: registered new interface driver usbfs
[ 0.480442] usbcore: registered new interface driver hub
[ 0.480519] usbcore: registered new device driver usb
[ 0.481890] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.483998] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.485609] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.486545] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.486787] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.487270] media: Linux media interface: v0.10
[ 0.487309] Linux video capture interface: v2.00
[ 0.487355] pps_core: LinuxPPS API ver. 1 registered
[ 0.487363] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.487383] PTP clock support registered
[ 0.487879] Rockchip ion module is successfully loaded (v1.0)
[ 0.488038] Advanced Linux Sound Architecture Driver Initialized.
[ 0.488399] Bluetooth: Core ver 2.16
[ 0.488439] NET: Registered protocol family 31
[ 0.488449] Bluetooth: HCI device and connection manager initialized
[ 0.488463] Bluetooth: HCI socket layer initialized
[ 0.488475] Bluetooth: L2CAP socket layer initialized
[ 0.488499] Bluetooth: SCO socket layer initialized
[ 0.488707] cfg80211: Calling CRDA to update world regulatory domain
[ 0.489941] act8846_i2c_probe,line=898
[ 0.490893] act8846_parse_dt,line=746
[ 0.491620] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.491639] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.491653] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.491668] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.493482] act_dcdc1: 1200 mV
[ 0.496209] vccio: 3300 mV
[ 0.498052] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.500750] act_dcdc4: 2000 mV
[ 0.501975] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.504042] act_ldo2: 1000 mV
[ 0.506122] act_ldo3: 2800 mV
[ 0.508195] act_ldo4: 3300 mV
[ 0.510253] act_ldo5: 3300 mV
[ 0.512315] act_ldo6: 1000 mV
[ 0.514388] vcc_18: 1800 mV
[ 0.516446] act_ldo8: 1800 mV
[ 0.521202] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.525910] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.526681] Switching to clocksource arch_sys_counter
[ 0.546776] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.546789] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.547179] rk-screen rk_screen.8: rockchip screen probe success
[ 0.547338] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.547357] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.547690] rk32-edp ff970000.edp: screen is not edp!
[ 0.547705] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.547854] rk32-dsi
[ 0.547993] dsi->host.irq =51
[ 0.548010] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
[ 0.548018] mipi_dsi v1.3 2014-04-17
[ 0.548042] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
[ 0.548054] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.548554] rk3288-lcdc lcdc0: request lcd_rst gpio fail:-16
[ 0.548787] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.549090] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.549241] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.549392] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.560459] rk3288-lcdc lcdc0: lcdc0: dclk:120000000>>fps:50
[ 0.560473] dsi->phy.sys_clk =24000000
[ 1.058102] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.083191] alloc_buffer:ion_phy_addr=0x40000000
[ 1.095552] fb0:phy:40000000>>vir:f0171000>>len:0x1900000
[ 1.099080] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
[ 1.099240] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 1.099252] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 1.099478] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.099778] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.099932] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.100088] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.147400] alloc_buffer:ion_phy_addr=0x41900000
[ 1.147416] fb0:phy:41900000>>vir: (null)>>len:0x3000000
[ 1.147431] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
[ 1.148090] rockchip_set_mux:warning ignore bank num 15
[ 1.148212] rockchip_set_mux:warning ignore bank num 15
[ 1.148316] rockchip_set_mux:warning ignore bank num 15
[ 1.148429] rockchip_set_mux:warning ignore bank num 15
[ 1.148530] rockchip_set_mux:warning ignore bank num 15
[ 1.148636] rockchip_set_mux:warning ignore bank num 15
[ 1.149214] rockchip_set_mux:warning ignore bank num 15
[ 1.149358] rockchip_set_mux:warning ignore bank num 15
[ 1.149892] rockchip_set_mux:warning ignore bank num 15
[ 1.150025] rockchip_set_mux:warning ignore bank num 15
[ 1.150559] rockchip_set_mux:warning ignore bank num 15
[ 1.150694] rockchip_set_mux:warning ignore bank num 15
[ 1.151221] rockchip_set_mux:warning ignore bank num 15
[ 1.151364] rockchip_set_mux:warning ignore bank num 15
[ 1.152727] NET: Registered protocol family 2
[ 1.153169] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.153299] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.153432] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.153479] TCP: reno registered
[ 1.153492] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.153526] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.153723] NET: Registered protocol family 1
[ 1.153912] Unpacking initramfs…
[ 1.216210] Freeing initrd memory: 1160K (c4bf0000 - c4d12000)
[ 1.216793] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.217291] probe device ff9a0000.vpu_service
[ 1.217463] vpu_service: power on
[ 1.218519] checking hw id 4831
[ 1.218878] vpu_service set to auto frequency mode
[ 1.218911] vpu_service: power off…
[ 1.218946] done
[ 1.218953] init success
[ 1.219001] probe device ff9c0000.hevc_service
[ 1.219190] hevc_service: power on
[ 1.220224] checking hw id 6867
[ 1.220446] hevc_service: power off…
[ 1.220482] done
[ 1.220489] init success
[ 1.220598] rknandbase v1.0 2014-03-31
[ 1.220690] rknand ff400000.nandc0: no irq resource?
[ 1.220813] rknand_driver:ret = 0
[ 1.222409] audit: initializing netlink socket (disabled)
[ 1.222446] type=2000 audit(0.920:1): initialized
[ 1.223190] bounce pool size: 64 pages
[ 1.227572] fuse init (API version 7.22)
[ 1.227923] msgmni has been set to 1450
[ 1.229619] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.229634] io scheduler noop registered
[ 1.229643] io scheduler deadline registered
[ 1.229728] io scheduler cfq registered (default)
[ 1.233256] rga2 ff920000.rga: rga ion client create success!
[ 1.233385] rga: Driver loaded succesfully
[ 1.233989] IEP Driver loaded succesfully
[ 1.234098] Module initialized.
[ 1.234947] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.234963] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.236280] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.236296] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.236566] pwm-voltage-regulator pwm_regulator.28: unable to request PWM, trying legacy API
[ 1.236581] pwm-voltage-regulator pwm_regulator.28: unable to request legacy PWM
[ 1.236590] pwm_regulator_probe:error
[ 1.236610] platform pwm_regulator.28: Driver pwm-voltage-regulator requests probe deferral
[ 1.236952] rk_serial.c v1.8 2014-03-04
[ 1.237153] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.237340] serial ff180000.serial: membase f1a74000
[ 1.237468] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 2.915418] console [ttyS2] enabled
[ 2.919044] serial ff690000.serial: membase fed60000
[ 2.926544] loop: module loaded
[ 2.930201] SCSI Media Changer driver v0.25
[ 2.934710] tun: Universal TUN/TAP device driver, 1.6
[ 2.939711] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.945896] vmac_init.
[ 2.948741] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 2.955416] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 2.962374] stmmac_probe_config_dt: clock input or output? (input).
[ 2.968547] stmmac_probe_config_dt: TX delay(0x30).
[ 2.973343] stmmac_probe_config_dt: RX delay(0x20).
[ 2.978184] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 2.983502] stmmc_pltfr_init:
[ 2.986697] stmmc_pltfr_init: init for RGMII
[ 2.990906] tx delay=0x30
[ 2.990906] rx delay=0x20
[ 2.996471] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.001463] Normal descriptors
[ 3.004553] Ring mode enabled
[ 3.007568] DMA HW capability register supported
[ 3.012024] RX Checksum Offload Engine supported (type 2)
[ 3.017604] TX Checksum insertion supported
[ 3.021811] Wake-Up On Lan supported
[ 3.025437] Enable RX Mitigation via HW Watchdog Timer
[ 3.030988] PPP generic driver version 2.4.2
[ 3.035330] PPP BSD Compression module registered
[ 3.039985] PPP Deflate Compression module registered
[ 3.044962] PPP MPPE Compression module registered
[ 3.049685] NET: Registered protocol family 24
[ 3.054074] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 3.063582] CSLIP: code copyright 1989 Regents of the University of California.
[ 3.070776] Rockchip WiFi SYS interface (V1.00) …
[ 3.075688] esp_mem_init enter date Dec 26 2014 09:48:50
[ 3.080951] esp_mem_init complete
[ 3.084356] usbcore: registered new interface driver catc
[ 3.089706] usbcore: registered new interface driver kaweth
[ 3.095196] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 3.102506] usbcore: registered new interface driver pegasus
[ 3.108131] usbcore: registered new interface driver rtl8150
[ 3.113723] usbcore: registered new interface driver r8152
[ 3.119139] hso: drivers/net/usb/hso.c: Option Wireless
[ 3.124332] usbcore: registered new interface driver hso
[ 3.129603] usbcore: registered new interface driver asix
[ 3.134950] usbcore: registered new interface driver ax88179_178a
[ 3.140981] usbcore: registered new interface driver cdc_ether
[ 3.146761] usbcore: registered new interface driver cdc_eem
[ 3.152351] usbcore: registered new interface driver dm9601
[ 3.157879] usbcore: registered new interface driver dm9620
[ 3.163394] usbcore: registered new interface driver smsc75xx
[ 3.169091] usbcore: registered new interface driver smsc95xx
[ 3.174779] usbcore: registered new interface driver gl620a
[ 3.180304] usbcore: registered new interface driver net1080
[ 3.185908] usbcore: registered new interface driver plusb
[ 3.191329] usbcore: registered new interface driver rndis_host
[ 3.197199] usbcore: registered new interface driver cdc_subset
[ 3.203046] usbcore: registered new interface driver zaurus
[ 3.208566] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 3.215894] usbcore: registered new interface driver int51x1
[ 3.221500] usbcore: registered new interface driver kalmia
[ 3.227024] usbcore: registered new interface driver ipheth
[ 3.232532] usbcore: registered new interface driver sierra_net
[ 3.238406] usbcore: registered new interface driver cx82310_eth
[ 3.244360] usbcore: registered new interface driver cdc_ncm
[ 3.249953] usbcore: registered new interface driver qmi_wwan
[ 3.255643] usbcore: registered new interface driver cdc_mbim
[ 3.261303] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.270103] ehci_rk_probe f1b00000 f1b00010
[ 3.274239] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 3.281711] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 3.290120] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 3.311470] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 3.318052] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.324785] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.331901] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 3.338150] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 3.343467] usb usb1: SerialNumber: ff500000.usb
[ 3.348421] hub 1-0:1.0: USB hub found
[ 3.352137] hub 1-0:1.0: 1 port detected
[ 3.380339] ehci_rk_probe ok
[ 3.383312] usbcore: registered new interface driver cdc_acm
[ 3.388875] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.396802] usbcore: registered new interface driver usblp
[ 3.402241] usbcore: registered new interface driver cdc_wdm
[ 3.407851] usbcore: registered new interface driver usb-storage
[ 3.413797] usbcore: registered new interface driver ums-alauda
[ 3.419642] usbcore: registered new interface driver ums-cypress
[ 3.425586] usbcore: registered new interface driver ums-datafab
[ 3.431528] usbcore: registered new interface driver ums_eneub6250
[ 3.437628] usbcore: registered new interface driver ums-freecom
[ 3.443576] usbcore: registered new interface driver ums-isd200
[ 3.449479] usbcore: registered new interface driver ums-jumpshot
[ 3.455497] usbcore: registered new interface driver ums-karma
[ 3.461273] usbcore: registered new interface driver ums-onetouch
[ 3.467290] usbcore: registered new interface driver ums-sddr09
[ 3.473148] usbcore: registered new interface driver ums-sddr55
[ 3.479006] usbcore: registered new interface driver ums-usbat
[ 3.484812] usbcore: registered new interface driver usbserial
[ 3.490595] usbcore: registered new interface driver usbserial_generic
[ 3.497031] usbserial: USB Serial support registered for generic
[ 3.502976] usbcore: registered new interface driver option
[ 3.508484] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.515385] usbcore: registered new interface driver trancevibrator
[ 3.521558] usb20_otg: version 3.10a 21-DEC-2012
[ 3.526480] f1b80040
[ 3.528652] Core Release: 3.10a
[ 3.531744] Setting default values for core params
[ 3.536559] Using Buffer DMA mode
[ 3.539835] Periodic Transfer Interrupt Enhancement - disabled
[ 3.545568] Multiprocessor Interrupt Enhancement - disabled
[ 3.551055] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.555338] ^^^^^^^^^^^^^^^^^Device Mode
[ 3.559205] Dedicated Tx FIFOs mode
[ 3.562642] pcd_init otg_dev = ed64c980
[ 3.566543] usb20_otg ff580000.usb: DWC OTG Controller
[ 3.571624] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.579016] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 3.584706] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.591394] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.598504] usb usb2: Product: DWC OTG Controller
[ 3.603131] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.608703] usb usb2: SerialNumber: ff580000.usb
[ 3.613602] hub 2-0:1.0: USB hub found
[ 3.617317] hub 2-0:1.0: 1 port detected
[ 3.621465] usb20_host: version 3.10a 21-DEC-2012
[ 3.628555] f1c00040
[ 3.630709] Core Release: 3.10a
[ 3.633798] Setting default values for core params
[ 3.638604] Using Buffer DMA mode
[ 3.641866] Periodic Transfer Interrupt Enhancement - disabled
[ 3.647610] Multiprocessor Interrupt Enhancement - disabled
[ 3.653088] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.657379] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.661168] usb20_host ff540000.usb: DWC OTG Controller
[ 3.666333] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 3.673796] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 3.679620] Init: Power Port (0)
[ 3.682840] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.689527] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.696635] usb usb3: Product: DWC OTG Controller
[ 3.701261] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.706834] usb usb3: SerialNumber: ff540000.usb
[ 3.711717] hub 3-0:1.0: USB hub found
[ 3.715467] hub 3-0:1.0: 1 port detected
[ 3.719870] .. rk pwm remotectl v1.0 init
[ 3.723884] remotectl probe j=0x0
[ 3.727298] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 3.733800] pwm enable val=0x646205
[ 3.737588] usbcore: registered new interface driver xpad
[ 3.742938] usbcore: registered new interface driver usb_acecad
[ 3.748810] usbcore: registered new interface driver aiptek
[ 3.754336] usbcore: registered new interface driver gtco
[ 3.759682] usbcore: registered new interface driver hanwang
[ 3.765292] usbcore: registered new interface driver kbtab
[ 3.770724] usbcore: registered new interface driver wacom
[ 3.797091] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 1
[ 3.833911] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 2
[ 3.863431] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 3
[ 3.892948] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 4
[ 3.922470] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 5
[ 3.951988] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 6
[ 3.981509] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 7
[ 4.011025] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 8
[ 4.040549] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 9
[ 4.070071] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 10
[ 4.098663] synaptics_dsx_i2c 1-0020: synaptics_rmi4_set_input_dev: Failed to query device
[ 4.106794] synaptics_dsx synaptics_dsx.0: synaptics_rmi4_probe: Failed to set up input device
[ 4.115291] synaptics_dsx: probe of synaptics_dsx.0 failed with error -5
[ 4.126814] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 4.133142] i2c /dev entries driver
[ 4.137230] IR NEC protocol handler initialized
[ 4.141702] IR RC5(x) protocol handler initialized
[ 4.146413] IR RC6 protocol handler initialized
[ 4.150888] IR JVC protocol handler initialized
[ 4.155341] IR Sony protocol handler initialized
[ 4.159889] IR RC5 (streamzap) protocol handler initialized
[ 4.165366] IR SANYO protocol handler initialized
[ 4.170007] IR MCE Keyboard/mouse protocol handler initialized
[ 4.175872] usbcore: registered new interface driver uvcvideo
[ 4.181534] USB Video Class driver (1.1.1)
[ 4.185564] CamSys driver version: v0.23.0, CamSys head file version: v0.9.0
[ 4.193953] D1:camsys_platform_probe(1067): 1-gpios-cifpower锛gpio=236
[ 4.200570] D1:camsys_platform_probe(1070): gpios-cifpower锛gpio_request
[ 4.207342] D1:camsys_platform_probe(1072): 1-gpios-cifpower锛gpio_request=0
[ 4.214462] D1:camsys_platform_probe(1079): gpios-cifpower锛236 high
[ 4.220960] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 4.231790] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf1ab0000 size: 0x4000)
[ 4.244536] D1:camsys_platform_probe(1183): ff910000.isp memory:
[ 4.250476] D1:camsys_platform_probe(1193): Register memory (phy: 0xff910000 vir: 0xf1ae0000 size: 0x10000)
[ 4.260403] D1:camsys_platform_probe(1188): I2c memory (phy: 0x2d68e000 vir: 0xed68e000 size: 0x1000)
[ 4.269824] D1:camsys_platform_probe(1208): Probe ff910000.isp device success
[ 4.278153] rockchip_temp_probe,line=362
[ 4.334821] tsadc ff280000.tsadc: initialized
[ 4.339486] device-mapper: uevent: version 1.0.3
[ 4.344233] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 4.352802] Bluetooth: HCI UART driver ver 2.2
[ 4.357189] Bluetooth: HCI H4 protocol initialized
[ 4.361900] Bluetooth: HCILL protocol initialized
[ 4.369605] cpufreq version 1.0, suspend freq 1200 MHz
[ 4.374874] cpuidle: using governor ladder
[ 4.378904] cpuidle: using governor menu
[ 4.382785] Synopsys Designware Multimedia Card Interface Driver
[ 4.388953] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 4.395089] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 4.402082] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 4.408510] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.414332] 1390..dw_mci_set_ios: no card. [mmc0]
[ 4.433217] 1390..dw_mci_set_ios: no card. [mmc0]
[ 4.452920] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 4.452928] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 4.452935] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 4.453125] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 4.483343] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 4.490287] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
[ 4.496625] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.502421] mmc1: no vmmc regulator found
[ 4.506446] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 4.513205] 1390..dw_mci_set_ios: no card. [mmc1]
[ 4.514555] mmc0: BKOPS_EN bit is not set
[ 4.515818] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 4.515835] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 4.515897] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
[ 4.515990] mmc0: new high speed MMC card at address 0001
[ 4.516242] mmcblk0: mmc0:0001 MAG2GA 14.5 GiB
[ 4.516482] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 4.516488] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 4.516493] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 4.516498] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 4.516503] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 4.516507] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 4.516512] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 4.516517] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 4.516521] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 4.516526] system: 0x012400000 – 0x042400000 (768 MB)
[ 4.516531] metadata: 0x042400000 – 0x042800000 (4 MB)
[ 4.516535] userdata: 0x042800000 – 0x082800000 (1024 MB)
[ 4.516540] radical_update: 0x082800000 – 0x086800000 (64 MB)
[ 4.516545] user: 0x086800000 – 0x3a3a00000 (12754 MB)
[ 4.649693] 1390..dw_mci_set_ios: no card. [mmc1]
[ 4.669381] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141390..dw_mci_set_ios: no card. [mmc1]
[ 4.669396] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 4.669401] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 4.669624] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 4.700568] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 4.707496] 3379..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 4.713847] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.719793] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.738256] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.757951] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.757966] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 4.757971] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 4.758173] leds-gpio leds.37: pins are not configured from the driver
[ 4.758349] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.759532] usbcore: registered new interface driver usbhid
[ 4.759537] usbhid: USB HID core driver
[ 4.759777] zram: Created 1 device(s) …
[ 4.760025] ashmem: initialized
[ 4.760116] logger: created 256K log ‘log_main’
[ 4.760191] logger: created 256K log ‘log_events’
[ 4.760266] logger: created 256K log ‘log_radio’
[ 4.760341] logger: created 256K log ‘log_system’
[ 4.761235] input: rk29-keypad as /devices/ff100000.adc/key.39/input/input1
[ 4.831688] es8323 probe i2c recv ok
[ 4.835263] i2c-core: driver [ES8323] using legacy suspend method
[ 4.841267] i2c-core: driver [ES8323] using legacy resume method
[ 4.847858] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered
[ 4.856077] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 4.862717] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral
[ 4.871496] es8323_probe
[ 5.507022] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 5.514820] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 5.522825] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 5.530677] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 5.538669] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 5.546855] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 5.555025] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 5.562829] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 5.570636] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 5.578462] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 5.586272] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 5.594608] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 5.602930] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 5.610574] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 5.618239] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 5.625883] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 5.633508] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 5.641939] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 5.650346] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 5.658105] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 5.665830] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 5.673570] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 5.681295] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 5.689791] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 5.698308] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 5.706293] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 5.714297] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 5.722282] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 5.730249] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 5.738253] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 5.746234] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 5.754247] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 5.762262] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 5.769978] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 5.777729] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 5.785458] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 5.793192] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 5.801354] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 5.809492] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 5.817328] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 5.825129] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 5.832928] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 5.840733] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 5.849028] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 5.857557] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 5.863502] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 5.869332] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 5.875199] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 5.880975] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 5.890921] rockchip-es8323 rockchip-es8323.34: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
[ 5.899683] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.34/sound/card0/input2
[ 5.909109] rockchip-hdmi-i2s rockchip-hdmi-i2s.31: rk-hdmi-i2s-hifi ↔ rockchip-i2s.0 mapping ok
[ 5.918582] u32 classifier
[ 5.921277] Actions configured
[ 5.924626] Netfilter messages via NETLINK v0.30.
[ 5.929298] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.935595] ctnetlink v0.93: registering with nfnetlink.
[ 5.940888] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.947727] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.953705] xt_time: kernel timezone is -0000
[ 5.958175] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.963523] arp_tables: (C) 2002 David S. Miller
[ 5.968092] TCP: cubic registered
[ 5.971361] Initializing XFRM netlink socket
[ 5.975772] NET: Registered protocol family 10
[ 5.980638] mip6: Mobile IPv6
[ 5.983572] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.989000] sit: IPv6 over IPv4 tunneling driver
[ 5.993845] NET: Registered protocol family 17
[ 5.998248] NET: Registered protocol family 15
[ 6.002656] Bridge firewalling registered
[ 6.006600] Ebtables v2.0 registered
[ 6.010248] Bluetooth: RFCOMM TTY layer initialized
[ 6.015056] Bluetooth: RFCOMM socket layer initialized
[ 6.020128] Bluetooth: RFCOMM ver 1.11
[ 6.023813] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.029036] Bluetooth: BNEP filters: protocol multicast
[ 6.034172] Bluetooth: BNEP socket layer initialized
[ 6.039059] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.044877] Bluetooth: HIDP socket layer initialized
[ 6.049777] l2tp_core: L2TP core driver, V2.0
[ 6.054063] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 6.058780] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 6.063543] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 6.068258] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 6.075098] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 6.082117] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 6.090496] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 6.097781] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 6.106767] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 6.115823] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 6.120978] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 6.129300] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 6.133954] [BT_RFKILL]: Enter rfkill_rk_init
[ 6.138346] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 6.146394] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 6.154345] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 6.162307] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 6.170182] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 6.178416] [BT_RFKILL]: Request irq for bt wakeup host
[ 6.183612] [BT_RFKILL]: ** disable irq
[ 6.187450] [BT_RFKILL]: ap6335 device registered.
[ 6.192931] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 6.199490] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 6.207043] rk3288_init_suspend
[ 6.210131] rk3288_suspend_init enter
[ 6.213830] rk3288_suspend_init: pm_ctrbits =200007
[ 6.218646] gpio_get_dts_info suspend:4
[ 6.222414] gpio_get_dts_info resume:4
[ 6.226101] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.234182] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.242181] clks_gating_suspend_init:clkgt info ok
[ 6.246961] Registering SWP/SWPB emulation handler
[ 6.251932] ddrfreq: verion 1.2 20140526
[ 6.255799] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
[ 6.266824] ddrfreq: auto-freq=0
[ 6.270005] ddrfreq: auto-freq-table[0] 240MHz
[ 6.274375] ddrfreq: auto-freq-table[1] 324MHz
[ 6.278738] ddrfreq: auto-freq-table[2] 396MHz
[ 6.283101] ddrfreq: auto-freq-table[3] 528MHz
[ 6.289395] regulator-dummy: disabling
[ 6.293418] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: ASoC: CPU DAI (null) not registered
[ 6.301636] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 6.308171] platform rockchip-hdmi-spdif.32: Driver rockchip-hdmi-spdif requests probe deferral
[ 6.316806] pcd_pullup, is_on 0
[ 6.319917] file system registered
[ 6.323781] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 6.330535] android_usb gadget: Number of LUNs=2
[ 6.335085] lun0: LUN: removable file: (no medium)
[ 6.339876] lun1: LUN: removable file: (no medium)
[ 6.344784] android_usb gadget: android_usb ready
[ 6.349929] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:50 UTC (1293883250)
[ 6.362748] rk_spdif:rk_spdif_init
[ 6.366252] rk_spdif:Entered spdif_probe
[ 6.370291] rk_spdif:spdif:spdif probe ok!
[ 6.374840] usbcore: registered new interface driver snd-usb-audio
[ 6.374940] rockchip-hdmi-spdif rockchip-hdmi-spdif.32: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
[ 6.390357] ALSA device list:
[ 6.393282] #0: RK_ES8323
[ 6.396026] #1: RK-HDMI-I2S
[ 6.398939] #2: RK-HDMI-SPDIF
[ 6.402354] Freeing unused kernel memory: 592K (c0ae3000 - c0b77000)
[ 6.412983] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 6.420969] SELinux: the above unknown classes and permissions will be denied
[ 6.719848] type=1403 audit(1293883250.870:2): policy loaded auid=4294967295 ses=4294967295
[ 6.728184] SELinux: Loaded policy from /sepolicy
[ 6.734685] type=1404 audit(1293883250.880:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 7.731858] init: could not import file ‘/init.usbstorage.rc’ from ‘/init.rc’
[ 7.738938] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 7.797839] init: /dev/hw_random not found
[ 7.801930] keychord: using input dev ff680000.pwm for fevent
[ 7.807577] keychord: using input dev rk29-keypad for fevent
[ 7.818089] fs_mgr: parse_link_device : path = NULL
[ 7.822915] fs_mgr: parse_link_device : path = NULL
[ 7.827720] fs_mgr: parse_link_device : path = NULL
[ 7.832577] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 7.851871] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
[ 7.869924] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 7.889324] EXT4-fs (mmcblk0p8): recovery complete
[ 7.894798] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.912845] EXT4-fs (mmcblk0p11): recovery complete
[ 7.917665] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 8.070853] EXT4-fs (mmcblk0p12): 2 orphan inodes deleted
[ 8.076182] EXT4-fs (mmcblk0p12): recovery complete
[ 8.101551] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 8.127314] mali pd enabled
[ 8.130069] clk enabled
[ 8.133639] MALI_DVFS_STEP=5,div_dvfs=7
[ 8.137412] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
[ 8.144453] mali_dvfs_infotbl[1].clock=179000,min_threshold=66,max_threshold=77
[ 8.151635] mali_dvfs_infotbl[2].clock=297000,min_threshold=73,max_threshold=84
[ 8.158856] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
[ 8.166056] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
[ 8.173429] turn on mali power
[ 8.176433] kbase_platform_rk_init,register_reboot_notifier
[ 8.181925] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 8.188752] mali ffa30000.gpu: Probed as mali0
[ 8.195737] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 8.217103] init: /dev/hw_random not found
[ 8.229229] binder: 160:160 transaction failed 29189, size 0-0
[ 8.235592] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
[ 8.245667] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
[ 8.314109] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
[ 8.323869] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
[ 8.331573] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 8.339452] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 8.349245] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 8.468343] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
[ 8.476394] init: powerctl: cannot expand ‘${sys.powerctl}’
[ 8.481922] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
[ 8.492712] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
[ 8.503005] init: property ‘sys.sysctl.tcp_def_init_rwnd’ doesn’t exist while expanding ‘${sys.sysctl.tcp_def_init_rwnd}’
[ 8.513793] init: cannot expand ‘${sys.sysctl.tcp_def_init_rwnd}’ while writing to ‘/proc/sys/net/ipv4/tcp_default_init_rwnd’
[ 8.525789] android_usb: already disabled
[ 8.531653] read descriptors
[ 8.534497] read strings
[ 8.537047] pcd_pullup, is_on 1
shell@rk3288:/ $ [ 8.711379] fs_mgr: parse_link_device : path = NULL
[ 8.716282] fs_mgr: parse_link_device : path = NULL
[ 8.721117] fs_mgr: parse_link_device : path = NULL
[ 9.411990] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.419373] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.426762] D1:camsys_open(717): camsys_marvin(ed948610) is opened!
[ 9.433055] rockchip_gpio_request:GPIO7-13
[ 9.437092] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.441634] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.447490] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.454221] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7408,result=0x7408
[ 9.464767] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.471562] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
[ 9.500650] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.508673] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.513722] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.518634] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.527941] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.536374] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.544681] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.555183] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.561557] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.568768] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.576028] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.619738] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.626358] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.635308] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.643733] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.651989] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.659609] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.667054] D1:camsys_release(741): camsys_marvin(ed948610) is closed
[ 9.682684] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.690069] rk3288-lcdc lcdc0: blank mode:0
[ 9.690078] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.690084] D1:camsys_open(717): camsys_marvin(ed948610) is opened!
[ 9.690154] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.690159] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.690168] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.690175] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7408,result=0x7408
[ 9.690180] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.690194] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
[ 9.718967] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.718973] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.719076] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.719105] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.720166] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.721227] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.722279] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.725528] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.726721] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 9.726757] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.726763] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.726768] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.778537] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.778577] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.780636] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.780649] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.780657] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.780661] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.780666] D1:camsys_release(741): camsys_marvin(ed948610) is closed
[ 9.789613] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.789619] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.789625] D1:camsys_open(717): camsys_marvin(ed948610) is opened!
[ 9.789677] D1:camsys_extdev_register(230): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.789687] D1:camsys_extdev_register(230): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.789696] D1:camsys_extdev_register(230): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 9.789727] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.789731] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.789739] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.789746] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7408,result=0x7408
[ 9.789752] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.789765] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 9.857944] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.857950] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.858053] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.858087] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.859160] D1:camsys_sysctl_extdev(335): Sysctl 11 success, gpio(11) set 1
[ 9.860223] D1:camsys_sysctl_extdev(339): Sysctl 8 success, gpio(79) set 1
[ 9.861285] D1:camsys_sysctl_extdev(339): Sysctl 7 success, gpio(78) set 1
[ 9.864526] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 9.865712] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.865750] D1:camsys_sysctl_extdev(335): Sysctl 7 success, gpio(78) set 0
[ 9.865758] D1:camsys_sysctl_extdev(335): Sysctl 8 success, gpio(79) set 0
[ 9.865766] D1:camsys_sysctl_extdev(339): Sysctl 11 success, gpio(11) set 0
[ 9.996818] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.996853] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.998925] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.998937] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.998944] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.998948] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.998952] D1:camsys_release(741): camsys_marvin(ed948610) is closed
[ 10.000942] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.000947] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.000951] D1:camsys_open(717): camsys_marvin(ed948610) is opened!
[ 10.000986] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 10.001078] D1:camsys_extdev_register(255): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
[ 10.115884] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 10.115890] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 10.115993] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 10.116017] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 10.117078] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 10.118132] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 10.119179] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 10.122404] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 10.122439] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 10.122444] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 10.122449] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 10.215101] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 10.215145] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 10.217195] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x1000000) is deregister success
[ 10.217206] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 10.217213] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.217217] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.217220] D1:camsys_release(741): camsys_marvin(ed948610) is closed
[ 10.290799] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
[ 11.211806] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
[ 17.256373] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 17.359021] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 17.366082] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 17.371401] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 17.376814] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 17.382289] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 17.387783] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 17.393271] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 17.634678] phy_power_on: enable = 1
[ 17.677671] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 17.684016] eth0: device MAC address aa:ac:52:16:e8:97
[ 17.693180] libphy: stmmac: probed
[ 17.696528] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 17.702557] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 17.816352] wifi_driver_write: wifi driver already rmmod
[ 17.861802] acc_open
[ 17.863964] acc_release
[ 18.751668] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 18.995045] avc: denied { set } for property=sys.vold.hasAsec scontext=u:r:vold:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service
[ 19.007795] init: sys_prop: permission denied uid:0 name:sys.vold.hasAsec
[ 19.014914] init: no such service ‘fuse_internal_sd’
[ 19.338214] init: sys_prop: permission denied uid:10012 name:sys.gmali.version
[ 19.753836] init: sys_prop: permission denied uid:10037 name:sys.gmali.version
[ 20.769628] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 20.885747] f28c7234,f28c7234,f28c7234
[ 32.981636] rk3288-hdmi ff980000.hdmi: Removed.
[ 33.202102] rk3288-lcdc lcdc0: blank mode:4
[ 33.822693] PM: suspend entry 2011-01-01 12:01:18.419449429 UTC
[ 33.828617] PM: Syncing filesystems … done.
[ 33.848882] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 33.860003] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 33.870648] Suspending console(s) (use no_console_suspend to debug)
01-armoff-logdp-osc_offddrc_off2345dDd543210
[ 33.879267] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee3ca300
[ 33.879286] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee3ca300
[ 33.879296] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee3ca300
[ 33.879631] rk_spdif:Entered spdif_suspend
[ 33.879640] rk_spdif:spdif:Entered spdif_suspend
[ 33.881675] dwc_otg_hcd_suspend, usb device mode
[ 33.883577] hym8563_rtc_set_alarm:diff_sec= 34s , use time
[ 33.943713] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 33.944432] phy_power_on: enable = 0
[ 33.946572] PM: suspend of devices complete after 68.453 msecs
[ 33.947739] PM: late suspend of devices complete after 1.150 msecs
[ 33.948980] PM: noirq suspend of devices complete after 1.238 msecs
[ 33.949010] Disabling non-boot CPUs …
[ 33.951269] CPU1: shutdown
[ 33.957045] CPU2: shutdown
[ 33.961434] CPU3: shutdown
[ 33.965217] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 33.965275] rkpm_enter:
[ 33.965285] GPIO0_INTEN: 00000020
[ 33.965300] GPIO4_INTEN: 80000000
[ 33.965308] GPIO6_INTEN: 00400000
[ 33.965316] GPIO7_INTEN: 00000010
[ 34.049300] Resume caused by IRQ 120
[ 34.049332] wakeup irq: 00000000 00000000 01000000 00000000
[ 34.049342] wakeup gpio7: 00000010
[ 34.049545] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 34.049578] Suspended for 0.000 seconds
[ 34.050372] Enabling non-boot CPUs …
[ 34.051152] CPU1: Booted secondary processor
[ 34.052435] CPU1 is up
[ 34.052827] CPU2: Booted secondary processor
[ 34.053466] CPU2 is up
[ 34.053873] CPU3: Booted secondary processor
[ 34.054468] CPU3 is up
[ 34.056943] PM: noirq resume of devices complete after 2.485 msecs
[ 34.058225] PM: early resume of devices complete after 0.594 msecs
[ 34.058618] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 34.058645] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 34.059007] 1390..dw_mci_set_ios: no card. [mmc1]
[ 34.059189] dwc_otg_hcd_resume, usb device mode
[ 34.064223] phy_power_on: enable = 1
[ 34.099122] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 34.101541] PM: resume of devices complete after 43.999 msecs
[ 34.101718] cpufreq: cpufreq_resume: Failed to start governor for policy: ee3ca300
[ 34.101732] cpufreq: cpufreq_resume: Failed to start governor for policy: ee3ca300
[ 34.101744] cpufreq: cpufreq_resume: Failed to start governor for policy: ee3ca300
[ 34.102179] rk_spdif:spdif:Entered spdif_resume
[ 34.102724] [BT_RFKILL]: ** disable irq
[ 34.334142] Restarting tasks … done.
[ 34.341472] PM: suspend exit 2011-01-01 12:01:52.245194833 UTC
[ 34.347360] PM: suspend entry 2011-01-01 12:01:52.251172833 UTC
[ 34.353362] PM: Syncing filesystems … done.
[ 34.364786] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 34.375958] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 34.386342] Suspending console(s) (use no_console_suspend to debug)
[ 34.394442] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee3ca300
[ 34.394453] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee3ca300
[ 34.394464] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee3ca300
[ 34.394770] rk_spdif:Entered spdif_suspend
[ 34.394779] rk_spdif:spdif:Entered spdif_suspend
[ 34.396900] dwc_otg_hcd_suspend, usb device mode
[ 34.397222] dpm_run_callback(): platform_pm_suspend+0x0/0x5c returns -16
[ 34.397244] PM: Device alarmtimer failed to suspend: error -16
[ 34.399434] PM: Some devices failed to suspend
[ 34.399598] dwc_otg_hcd_resume, usb device mode
[ 34.401152] rk_spdif:spdif:Entered spdif_resume
[ 34.411828] PM: resume of devices complete after 12.571 msecs
[ 34.411941] cpufreq: cpufreq_resume: Failed to start governor for policy: ee3ca300
[ 34.411954] cpufreq: cpufreq_resume: Failed to start governor for policy: ee3ca300
[ 34.411963] cpufreq: cpufreq_resume: Failed to start governor for policy: ee3ca300
[ 34.412625] [BT_RFKILL]: ** disable irq
[ 34.506364] Restarting tasks … [ 34.511690] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 34.512426] PM: suspend exit 2011-01-01 12:01:52.418936000 UTC
done.
[ 36.360457] PM: suspend entry 2011-01-01 12:01:54.296901542 UTC
[ 36.367037] PM: Syncing filesystems … done.
[ 36.384552] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 36.395606] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 36.406179] Suspending console(s) (use no_console_suspend to debug)
[ 36.414379] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee3ca300
[ 36.414394] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee3ca300
[ 36.414406] cpufreq: cpufreq_suspend: Failed to stop governor for policy: ee3ca300
[ 36.414710] rk_spdif:Entered spdif_suspend
[ 36.414731] rk_spdif:spdif:Entered spdif_suspend
[ 36.416795] dwc_otg_hcd_suspend, usb device mode
[ 36.418635] hym8563_rtc_set_alarm:diff_sec= 9s , use time
[ 36.478365] [WLAN_RFKILL]: Enter rfkill_wlan_suspend
[ 36.479060] phy_power_on: enable = 0
[ 36.480699] PM: suspend of devices complete after 67.433 msecs
[ 36.481752] PM: late suspend of devices complete after 1.032 msecs
[ 36.482979] PM: noirq suspend of devices complete after 1.228 msecs
[ 36.483001] Disabling non-boot CPUs …
[ 36.485320] CPU1: shutdown
[ 36.488732] CPU2: shutdown
[ 36.491442] CPU3: shutdown
[ 36.493102] rockchip_pinctrl_suspend:bank_num=7, suspend_wakeup=0x10
[ 36.493157] rkpm_enter:
[ 36.493182] GPIO0_INTEN: 00000020
[ 36.493188] GPIO4_INTEN: 80000000
[ 36.493200] GPIO6_INTEN: 00400000
[ 36.493208] GPIO7_INTEN: 00000010
[ 36.577789] Resume caused by IRQ 120
[ 36.577834] wakeup irq: 00000000 00000000 01000000 00000000
[ 36.577849] wakeup gpio7: 00000010
[ 36.578055] rockchip_pinctrl_resume:bank_num=7, suspend_wakeup=0x10
[ 36.578088] Suspended for 0.000 seconds
[ 36.578891] Enabling non-boot CPUs …
[ 36.579669] CPU1: Booted secondary processor
[ 36.580922] CPU1 is up
[ 36.581327] CPU2: Booted secondary processor
[ 36.581967] CPU2 is up
[ 36.582385] CPU3: Booted secondary processor
[ 36.583114] CPU3 is up
[ 36.585793] PM: noirq resume of devices complete after 2.690 msecs
[ 36.586862] PM: early resume of devices complete after 0.601 msecs
[ 36.587197] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 36.587273] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 36.587832] 1390..dw_mci_set_ios: no card. [mmc1]
[ 36.588000] dwc_otg_hcd_resume, usb device mode
[ 36.593103] phy_power_on: enable = 1
[ 36.627853] [WLAN_RFKILL]: Enter rfkill_wlan_resume
[ 36.630357] rk_spdif:spdif:Entered spdif_resume
[ 36.630553] PM: resume of devices complete after 44.379 msecs
[ 36.630796] cpufreq: cpufreq_resume: Failed to start governor for policy: ee3ca300
[ 36.630814] cpufreq: cpufreq_resume: Failed to start governor for policy: ee3ca300
[ 36.630876] cpufreq: cpufreq_resume: Failed to start governor for policy: ee3ca300
[ 36.631689] [BT_RFKILL]: ** disable irq
[ 36.862678] Restarting tasks … done.
[ 36.873261] PM: suspend exit 2011-01-01 12:02:03.248311584 UTC
[ 36.965563] PM: suspend entry 2011-01-01 12:02:03.342104000 UTC
[ 36.971510] PM: Syncing filesystems … done.
[ 36.985509] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 36.997465] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 37.008185] Suspending console(s) (use no_console_suspend to debug)
求大牛指点迷津
公司:深圳寒武纪
联系方式:18344935179 huang.hq@aiiage.com
