我们购买了ROC-RK3568-PC的开发板,参考开发板自己做了板子;
按照SDK编译出来的IMAGE,在开发板上能够正常执行,但是开发板无法完成KERNEL初始化,始终会卡住,仔细跟踪后,LOG信息如下,想请教下:具体的原因是什么?或者有什么解决方法?
U-Boot 2017.09-g912f242c30 #huangjf (Sep 13 2021 - 18:08:18 +0800)
Model: Firefly RK3568 Board
PreSerial: 2, raw, 0xfe660000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: ed35a000
Relocation fdt: eb9f88b0 - eb9fecd8
CR: M/C/I
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: loader
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 100000Hz
PMIC: RK8090 (on=0x10, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
Model: Firefly RK3568-ROC-PC HDMI (Linux)
enter Rockusb!
apll 816000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000, eth0: ethernet@fe2a0000
RKUSB: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x1d1f000
-DDR Version V1.11 20211103
ddrconfig:15
DDR4, 324MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=17 CS=1 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: 96ps, dqs1: 72ps, dqs2: 0ps, dqs3: -24ps,
change to: 324MHz
clk skew:0x79
PHY drv:clk:37,ca:37,DQ:37,odt:0
vrefinner:50%, vrefout:50%
dram drv:34,odt:0
change to: 528MHz
clk skew:0x79
PHY drv:clk:37,ca:37,DQ:37,odt:139
vrefinner:50%, vrefout:61%
dram drv:34,odt:120
change to: 780MHz
clk skew:0x79
dram drv:34,odt:120
change to: 1560MHz(final freq)
clk skew:0x79
dram drv:34,odt:120
cs 0:
the read training result:
DQS0:0x39, DQS1:0x32, DQS2:0x33, DQS3:0x35,
min : 0xf 0xb 0xe 0xb 0x1 0x5 0x4 0x2 , 0x7 0xb 0x1 0x8 0x4 0xb 0x8 0xb ,
0x9 0xb 0x9 0xb 0xa 0x5 0x2 0x2 , 0x5 0x8 0x4 0x2 0x7 0x9 0x6 0x2 ,
mid :0x29 0x27 0x28 0x24 0x1c 0x1e 0x1e 0x1d ,0x1f 0x23 0x17 0x21 0x1c 0x23 0x21 0x22 ,
0x23 0x27 0x23 0x26 0x24 0x20 0x1d 0x1e ,0x21 0x20 0x20 0x1d 0x21 0x25 0x21 0x1f ,
max :0x43 0x43 0x43 0x3e 0x37 0x38 0x38 0x38 ,0x38 0x3b 0x2d 0x3a 0x35 0x3b 0x3b 0x3a ,
0x3e 0x43 0x3e 0x42 0x3e 0x3c 0x39 0x3a ,0x3e 0x38 0x3d 0x39 0x3c 0x41 0x3d 0x3c ,
range:0x34 0x38 0x35 0x33 0x36 0x33 0x34 0x36 ,0x31 0x30 0x2c 0x32 0x31 0x30 0x33 0x2f ,
0x35 0x38 0x35 0x37 0x34 0x37 0x37 0x38 ,0x39 0x30 0x39 0x37 0x35 0x38 0x37 0x3a ,
the write training result:
DQS0:0x8c, DQS1:0x87, DQS2:0x79, DQS3:0x75,
min :0x78 0x78 0x7a 0x79 0x6b 0x6b 0x6e 0x6e 0x76 ,0x71 0x73 0x6b 0x74 0x72 0x74 0x74 0x72 0x6a ,
0x6a 0x6c 0x6e 0x6e 0x6a 0x64 0x64 0x68 0x64 ,0x5f 0x60 0x62 0x5f 0x5f 0x5e 0x5f 0x62 0x61 ,
mid :0x91 0x91 0x92 0x8f 0x81 0x83 0x87 0x85 0x8e ,0x89 0x8b 0x7e 0x89 0x88 0x8a 0x89 0x8a 0x80 ,
0x7f 0x83 0x83 0x83 0x81 0x79 0x7a 0x7e 0x7a ,0x77 0x76 0x78 0x74 0x76 0x75 0x77 0x7a 0x78 ,
max :0xab 0xab 0xab 0xa6 0x98 0x9b 0xa0 0x9c 0xa6 ,0xa1 0xa3 0x92 0x9e 0x9e 0xa1 0x9e 0xa3 0x96 ,
0x94 0x9a 0x98 0x98 0x98 0x8e 0x90 0x94 0x91 ,0x8f 0x8c 0x8f 0x8a 0x8d 0x8d 0x8f 0x93 0x8f ,
range:0x33 0x33 0x31 0x2d 0x2d 0x30 0x32 0x2e 0x30 ,0x30 0x30 0x27 0x2a 0x2c 0x2d 0x2a 0x31 0x2c ,
0x2a 0x2e 0x2a 0x2a 0x2e 0x2a 0x2c 0x2c 0x2d ,0x30 0x2c 0x2d 0x2b 0x2e 0x2f 0x30 0x31 0x2e ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-g5961c0c398 #zsm (Jan 10 2022 - 11:58:41)
unknown raw ID phN
Trying to boot from MMC2
mmc_init: -95, time 10
Trying to boot from MMC1
Magic is incorrect.
Error validating A/B metadata from disk. Resetting and writing new A/B metadata to disk.
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(fe4f274c06…) + OK
## Checking uboot 0x00a00000 … sha256(a42b439b91…) + OK
## Checking fdt 0x00b22628 … sha256(30938731de…) + OK
## Checking atf-2 0x00068000 … sha256(8d44036095…) + OK
## Checking atf-3 0xfdcd0000 … sha256(e410275b51…) + OK
## Checking atf-4 0xfdcc9000 … sha256(990c53fc01…) + OK
## Checking atf-5 0x00066000 … sha256(315a4195a9…) + OK
## Checking optee 0x08400000 … sha256(5a22c90dfc…) + OK
Total: 238.312 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-181-gc9a647cae:cl
NOTICE: BL31: Built : 10:55:41, Oct 18 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #hisping.lin (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug 4 07:11:39 UTC 2021 aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09-g5961c0c398 #zsm (Jan 10 2022 - 11:58:41 +0800)
DRAM: 4 GiB
Sysmem: init
Relocation Offset: ed356000
Relocation fdt: eb9f8310 - eb9fece8
CR: M/C/I
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: recovery (misc)
DTB: rk-kernel.dtb
HASH(c): OK
io-domain: OK
VOP have 1 active VP
vp0 have layer nr:6[0 2 4 1 3 5 ], primary plane: 4
vp1 have layer nr:0, primary plane: 0
vp2 have layer nr:0, primary plane: 0
hdmi@fe0a0000 disconnected
apll 816000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
pclk_pmu 100000 KHz
## Booting FIT Image at 0xe9a3d300 with size 0x01dba000
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at e9a3d300 …
Using ‘conf’ configuration
optee api revision: 2.0
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0xe9a5e100
Data Size: 24119304 Bytes = 23 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00280000
Entry Point: 0x00280000
Hash algo: sha256
Hash value: 3f3ec261ef170adb5c4ed463128473e48944154941f0b57aab863346fd3ee5e4
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at e9a3d300 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0xeb15eb00
Data Size: 6915910 Bytes = 6.6 MiB
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 59c552dc120339ff15cd9e3aa8718c001f996c0f3c0c6da4dbeccf06ac17d616
Loading ramdisk from 0xeb15eb00 to 0x0a200000
## Loading fdt from FIT Image at e9a3d300 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0xe9a3db00
Data Size: 132152 Bytes = 129.1 KiB
Load Address: 0x0a100000
Hash algo: sha256
Hash value: 6f764a41c90575ca782da50a9c589b38da80dc9305e98d6c64baf1fb18fb7644
Loading fdt from 0x0a100000 to 0x0a100000
Loading Kernel Image from 0xe9a5e100 to 0x00280000 … OK
kernel loaded at 0x00280000, end = 0x01980808
Using Device Tree in place at 000000000a100000, end 000000000a123437
vp0, plane_mask:0x3f, primary-id:4, curser-id:-1
vp1, plane_mask:0x0, primary-id:0, curser-id:-1
vp2, plane_mask:0x0, primary-id:0, curser-id:-1
Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000)
Total: 834.833 ms
[ 0.000000] Linux version 4.19.206 (zsm@zsm-virtual-machine) (firefly: c0c173e0214eeaa0d057599d2f1c6a83213483b1) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #4 SMP Mon Jan 10 11:58:48 CST 2022
[ 0.000000] Machine model: Firefly RK3568-ROC-PC HDMI (Linux)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options ‘’)
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000
[ 0.000000] percpu: Embedded 23 pages/cpu s54184 r8192 d31832 u94208
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=sdhci@fe310000 ro rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB)
[ 0.000000] Memory: 3971388K/4175872K available (14718K kernel code, 1986K rwdata, 5220K rodata, 1600K init, 586K bss, 188100K reserved, 16384K cma-reserved)
[ 0.000000] ftrace: allocating 53255 entries in 209 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @210000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @220000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x0000000000230000
[ 0.000000] CPU0: using LPI pending table @0x0000000000240000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x510 with crng_init=0
[ 0.002238] Console: colour dummy device 80x25
[ 0.002700] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003664] pid_max: default: 32768 minimum: 301
[ 0.004262] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004910] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.007398] ASID allocator initialised with 32768 entries
[ 0.008078] rcu: Hierarchical SRCU implementation.
[ 0.011459] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.012644] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.014258] smp: Bringing up secondary CPUs …
[ 0.016190] Detected VIPT I-cache on CPU1
[ 0.016231] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.016284] CPU1: using LPI pending table @0x0000000000250000
[ 0.016340] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.017950] Detected VIPT I-cache on CPU2
[ 0.017988] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.018040] CPU2: using LPI pending table @0x0000000000260000
[ 0.018087] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.019658] Detected VIPT I-cache on CPU3
[ 0.019696] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.019755] CPU3: using LPI pending table @0x0000000000270000
[ 0.019801] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.019940] smp: Brought up 1 node, 4 CPUs
[ 0.026903] SMP: Total of 4 processors activated.
[ 0.027346] CPU features: detected: GIC system register CPU interface
[ 0.027944] CPU features: detected: Privileged Access Never
[ 0.028467] CPU features: detected: LSE atomic instructions
[ 0.028989] CPU features: detected: User Access Override
[ 0.029489] CPU features: detected: 32-bit EL0 Support
[ 0.029972] CPU features: detected: RAS Extension Support
[ 0.030689] CPU: All CPU(s) started at EL2
[ 0.031106] alternatives: patching kernel code
[ 0.038546] devtmpfs: initialized
[ 0.069074] Registered cp15_barrier emulation handler
[ 0.069569] Registered setend emulation handler
[ 0.070352] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.071318] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.072678] pinctrl core: initialized pinctrl subsystem
[ 0.074280] NET: Registered protocol family 16
[ 0.079900] cpuidle: using governor menu
[ 0.080308] Registered FIQ tty driver
[ 0.081606] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.083725] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.088318] console [pstore-1] enabled
[ 0.088675] pstore: Registered ramoops as persistent store backend
[ 0.089258] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.129886] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.131196] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.132522] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.133817] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.135117] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.135865] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.154434] cryptd: max_cpu_qlen set to 1000
[[ 0.156830] console [ttyFIQ0] enabled
[ 0.157516] bootconsole [uart8250] disabled
[ 0.158201] Registered fiq debugger ttyFIQ0
[ 0.159282] vcc3v3_sys: supplied by dc_12v
[ 0.159783] vcc5v0_sys: supplied by dc_12v
[ 0.161563] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.162035] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.162536] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.163023] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.166984] rk_iommu fde4b000.iommu: version = 2
[ 0.167759] rk_iommu fdea0800.iommu: version = 2
[ 0.168209] rk_iommu fded0480.iommu: version = 2
[ 0.168593] rk_iommu fdee0800.iommu: version = 2
[ 0.168959] rk_iommu fdef0800.iommu: version = 2
[ 0.169324] rk_iommu fdf40f00.iommu: version = 2
[ 0.169763] rk_iommu fdf80800.iommu: version = 2
[ 0.170145] rk_iommu fdff1a00.iommu: version = 2
[ 0.170493] rk_iommu fe043e00.iommu: version = 2
[ 0.171619] SCSI subsystem initialized
[ 0.171960] usbcore: registered new interface driver usbfs
[ 0.172051] usbcore: registered new interface driver hub
[ 0.172135] usbcore: registered new device driver usb
[ 0.172262] media: Linux media interface: v0.10
[ 0.172329] videodev: Linux video capture interface: v2.00
[ 0.172459] pps_core: LinuxPPS API ver. 1 registered
[ 0.172486] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.172537] PTP clock support registered
[ 0.172960] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 0.176047] Advanced Linux Sound Architecture Driver Initialized.
[ 0.176658] Bluetooth: Core ver 2.22
[ 0.176735] NET: Registered protocol family 31
[ 0.176762] Bluetooth: HCI device and connection manager initialized
[ 0.176792] Bluetooth: HCI socket layer initialized
[ 0.176819] Bluetooth: L2CAP socket layer initialized
[ 0.176885] Bluetooth: SCO socket layer initialized
[ 0.177453] rockchip-cpuinfo cpuinfo: SoC : 35682000
[ 0.177485] rockchip-cpuinfo cpuinfo: Serial : 8629c8fd777938f1
[ 0.179035] clocksource: Switched to clocksource arch_sys_counter
[ 0.280221] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.280630] NET: Registered protocol family 2
[ 0.280942] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.283298] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes)
[ 0.283423] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.283749] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.284772] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.285021] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.285270] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.285806] NET: Registered protocol family 1
[ 0.286552] RPC: Registered named UNIX socket transport module.
[ 0.286580] RPC: Registered udp transport module.
[ 0.286599] RPC: Registered tcp transport module.
[ 0.286621] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.288493] Trying to unpack rootfs image as initramfs…
[ 0.679489] Freeing initrd memory: 6752K
[ 0.681229] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.684182] Initialise system trusted keyrings
[ 0.684446] workingset: timestamp_bits=61 max_order=20 bucket_order=0
[ 0.693115] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.694184] NFS: Registering the id_resolver key type
[ 0.694237] Key type id_resolver registered
[ 0.694252] Key type id_legacy registered
[ 0.694309] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.694605] fuse init (API version 7.27)
[ 0.695223] SGI XFS with security attributes, no debug enabled
[ 0.698806] NET: Registered protocol family 38
[ 0.698861] Key type asymmetric registered
[ 0.698878] Asymmetric key parser ‘x509’ registered
[ 0.698938] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.698965] io scheduler noop registered
[ 0.698986] io scheduler deadline registered
[ 0.699249] io scheduler cfq registered (default)
[ 0.699280] io scheduler mq-deadline registered
[ 0.699301] io scheduler kyber registered
[ 0.700747] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.700958] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.704595] phy phy-fe8b0000.usb2-phy.0: Linked as a consumer to regulator.4
[ 0.704833] phy phy-fe8b0000.usb2-phy.1: Linked as a consumer to regulator.4
[ 0.705023] phy phy-fe8b0000.usb2-phy.1: No vbus specified for otg port
[ 0.715521] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.15
[ 0.716120] rochchip_p3phy_init: lock failed 0x6890000, check input refclk and power supply
[ 0.716162] phy phy-fe8c0000.phy.5: phy init failed → -110
[ 0.716189] rk-pcie 3c0800000.pcie: fail to init phy, err -110
[ 0.716211] rk-pcie 3c0800000.pcie: phy init failed
[ 0.716217] mpp_service mpp-srv: d47e486b19bd author: Yandong Lin 2021-11-04 video: rockchip: mpp: use dma-buf-cache func
[ 0.716224] mpp_service mpp-srv: probe start
[ 0.717475] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.717531] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.717804] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.718411] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.718441] rkvenc_init:1199: failed to add venc devfreq
[ 0.718927] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 0.720482] iommu: Adding device fdea0400.vdpu to group 1
[ 0.720547] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.720792] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.721574] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.722334] iommu: Adding device fdee0000.vepu to group 3
[ 0.722431] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.722695] mpp_vepu2 fdee0000.vepu: probe device
[ 0.723417] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.724166] iommu: Adding device fdef0000.iep to group 4
[ 0.724220] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.724427] mpp-iep2 fdef0000.iep: probe device
[ 0.725060] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.725296] mpp-iep2 fdef0000.iep: probing finish
[ 0.726028] iommu: Adding device fded0000.jpegd to group 2
[ 0.726084] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.726298] mpp_jpgdec fded0000.jpegd: probe device
[ 0.727043] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.727784] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.727825] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.728165] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.728378] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.728843] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.728873] rkvdec2_init:661: No niu aclk reset resource define
[ 0.728901] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.728923] rkvdec2_init:664: No niu hclk reset resource define
[ 0.729210] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.729241] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.729266] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.729287] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 0.729306] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.729383] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 0.729494] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.729965] mpp_service mpp-srv: probe success
[ 0.737706] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.737751] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.741005] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.741045] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.742934] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.744307] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.745428] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 66, base_baud = 1500000) is a 16550A
[ 0.746363] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 67, base_baud = 1500000) is a 16550A
[ 0.747249] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 68, base_baud = 1500000) is a 16550A
[ 0.751010] random: fast init done
[ 0.751360] random: crng init done
[ 0.751761] iommu: Adding device fe040000.vop to group 8
[ 0.751821] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.758418] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.760302] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.763185] rockchip-drm display-subsystem: dmc is disabled
[ 0.763560] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4
[ 0.763604] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1
[ 0.763640] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.763921] [drm] unsupported AFBC format[3432564e]
[ 0.764007] [drm] failed to init overlay plane Cluster0-win1
[ 0.764094] [drm] failed to init overlay plane Cluster1-win1
[ 0.764252] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008fba4d8)
[ 0.764516] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.765243] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.766120] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008fbdff0)
[ 0.766157] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.766179] [drm] No driver support for vblank timestamp query.
[ 0.766478] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 0.766574] rockchip-drm display-subsystem: can’t not find any loader display
[ 0.766610] rockchip-drm display-subsystem: failed to show loader logo
[ 0.766663] [drm] Cannot find any crtc or sizes
[ 0.767719] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.775212] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 0.775384] mali fde60000.gpu: Device initialization Deferred
[ 0.775535] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.776603] brd: module loaded
[ 0.786312] loop: module loaded
[ 0.786955] zram: Added device: zram0
[ 0.787147] lkdtm: No crash points registered, enable through debugfs
[ 0.788966] ahci fc800000.sata: forcing port_map 0x0 → 0x1
[ 0.789098] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 0.789135] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 0.789175] ahci fc800000.sata: port 0 is not capable of FBS
[ 0.790425] scsi host0: ahci
[ 0.790929] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 i
[ 0.935743] libphy: stmmac: probed
[ 0.941023] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 0.941070] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 0.941091] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c).
[ 0.941107] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f).
[ 0.941130] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 0.941220] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 0.946260] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 0.946595] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.946627] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 0.946655] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 0.946682] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 0.946706] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 0.946728] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 0.946790] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 0.946808] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.946826] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 1.079073] libphy: stmmac: probed
[ 1.084142] usbcore: registered new interface driver rndis_wlan
[ 1.084250] usbcore: registered new interface driver rtl8150
[ 1.084334] usbcore: registered new interface driver r8152
[ 1.084416] usbcore: registered new interface driver asix
[ 1.084505] usbcore: registered new interface driver ax88179_178a
[ 1.084584] usbcore: registered new interface driver cdc_ether
[ 1.084672] usbcore: registered new interface driver rndis_host
[ 1.084768] usbcore: registered new interface driver cdc_ncm
[ 1.084857] usbcore: registered new interface driver qmi_wwan_q
[ 1.084938] usbcore: registered new interface driver qmi_wwan
[ 1.085015] usbcore: registered new interface driver cdc_mbim
[ 1.086661] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.088060] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.091126] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.091172] ehci-pci: EHCI PCI platform driver
[ 1.091268] ehci-platform: EHCI generic platform driver
[ 1.093636] ehci-platform fd800000.usb: EHCI Host Controller
[ 1.093907] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 1.094416] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[ 1.102439] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.105728] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 1.106081] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.106113] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.106143] usb usb1: Product: EHCI Host Controller
[ 1.106168] usb usb1: Manufacturer: Linux 4.19.206 ehci_hcd
[ 1.106192] usb usb1: SerialNumber: fd800000.usb
[ 1.106880] hub 1-0:1.0: USB hub found
[ 1.106956] hub 1-0:1.0: 1 port detected
[ 1.109779] ehci-platform fd880000.usb: EHCI Host Controller
[ 1.110051] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 1.110500] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000
[ 1.122414] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 1.122734] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.122766] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.122793] usb usb2: Product: EHCI Host Controller
[ 1.122818] usb usb2: Manufacturer: Linux 4.19.206 ehci_hcd
[ 1.122840] usb usb2: SerialNumber: fd880000.usb
[ 1.123489] hub 2-0:1.0: USB hub found
[ 1.123572] hub 2-0:1.0: 1 port detected
[ 1.124661] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.124724] ohci-platform: OHCI generic platform driver
[ 1.125046] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 1.125321] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 1.125613] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000
[ 1.183331] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.183365] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.183383] usb usb3: Product: Generic Platform OHCI controller
[ 1.183399] usb usb3: Manufacturer: Linux 4.19.206 ohci_hcd
[ 1.183412] usb usb3: SerialNumber: fd840000.usb
[ 1.184086] hub 3-0:1.0: USB hub found
[ 1.184162] hub 3-0:1.0: 1 port detected
[ 1.184898] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 1.185179] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 1.185455] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[ 1.243328] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.243363] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.243381] usb usb4: Product: Generic Platform OHCI controller
[ 1.243397] usb usb4: Manufacturer: Linux 4.19.206 ohci_hcd
[ 1.243411] usb usb4: SerialNumber: fd8c0000.usb
[ 1.244065] hub 4-0:1.0: USB hub found
[ 1.244139] hub 4-0:1.0: 1 port detected
[ 1.246413] usbcore: registered new interface driver cdc_acm
[ 1.246443] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.246549] usbcore: registered new interface driver cdc_wdm
[ 1.246849] usbcore: registered new interface driver uas
[ 1.247027] usbcore: registered new interface driver usb-storage
[ 1.247184] usbcore: registered new interface driver usbserial_generic
[ 1.247258] usbserial: USB Serial support registered for generic
[ 1.247336] usbcore: registered new interface driver cp210x
[ 1.247395] usbserial: USB Serial support registered for cp210x
[ 1.247520] usbcore: registered new interface driver ftdi_sio
[ 1.247563] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.247831] usbcore: registered new interface driver keyspan
[ 1.247891] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.247944] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.247998] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.248049] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.248139] usbcore: registered new interface driver option
[ 1.248196] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.248543] usbcore: registered new interface driver oti6858
[ 1.248599] usbserial: USB Serial support registered for oti6858
[ 1.248683] usbcore: registered new interface driver pl2303
[ 1.248739] usbserial: USB Serial support registered for pl2303
[ 1.248844] usbcore: registered new interface driver qcserial
[ 1.248903] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.249062] usbcore: registered new interface driver sierra
[ 1.249125] usbserial: USB Serial support registered for Sierra USB modem
[ 1.250935] usbcore: registered new interface driver usbtouchscreen
[ 1.251004] ============ himax_hx83102_init 1742 jjlook ==========
[ 1.251030] ============ himax_hx83102_probe 1725 jjlook ==========
[ 1.251130] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 1.251158] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 1.251650] .. rk pwm remotectl v2.0 init
[ 1.251989] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 1.252538] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[ 1.252585] remotectl-pwm fe6e0030.pwm: cannot find PWR IRQ
[ 1.252613] remotectl-pwm fe6e0030.pwm: pwm sip wakeup config error!!
[ 1.252628] remotectl-pwm fe6e0030.pwm: Donot support ATF Wakeup
[ 1.253592] i2c /dev entries driver
[ 1.255300] fan53555-regulator 0-001c: Failed to get chip ID!
[ 1.256946] rk808 0-0020: chip id: 0x8090
[ 1.257024] rk808 0-0020: No cache defaults, reading back from HW
[ 1.280822] rk808 0-0020: source: on=0x10, off=0x00
[ 1.280861] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 1.280882] rk808 0-0020: support pmic reset mode:0,0
[ 1.287394] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.287457] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.287942] vdd_logic: supplied by vcc3v3_sys
[ 1.288860] vdd_gpu: supplied by vcc3v3_sys
[ 1.289392] vcc_ddr: supplied by vcc3v3_sys
[ 1.289889] vdd_npu: supplied by vcc3v3_sys
[ 1.290767] vcc_1v8: supplied by vcc3v3_sys
[ 1.291237] vdda0v9_image: supplied by vcc3v3_sys
[ 1.292061] vdda_0v9: supplied by vcc3v3_sys
[ 1.292581] vdda0v9_pmu: supplied by vcc3v3_sys
[ 1.293018] vccio_acodec: supplied by vcc3v3_sys
[ 1.293857] vccio_sd: supplied by vcc3v3_sys
[ 1.294337] vcc3v3_pmu: supplied by vcc3v3_sys
[ 1.295177] vcca_1v8: supplied by vcc3v3_sys
[ 1.295671] vcca1v8_pmu: supplied by vcc3v3_sys
[ 1.296184] vcca1v8_image: supplied by vcc3v3_sys
[ 1.297006] vcc_3v3: supplied by vcc3v3_sys
[ 1.297799] vcc3v3_sd: supplied by vcc3v3_sys
[ 1.298412] rk817-battery rk817-battery: Failed to find matching dt id
[ 1.298770] rk817-charger rk817-charger: Failed to find matching dt id
[ 1.302311] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 1.303000] rk808-rtc rk808-rtc: device is disabled
[ 1.303045] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.304557] fusb302 0-0022: Can’t get property of role, set role to default DRP
[ 1.308253] fusb302 0-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.308484] input: Typec_Headphone as /devices/platform/fdd40000.i2c/i2c-0/0-0022/input/input2
[ 1.310327] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 1.310435] pca953x 1-0021: Linked as a consumer to regulator.0
[ 1.310653] pca953x 1-0021: failed reading register
[ 1.310738] pca953x 1-0021: Dropping the link to regulator.0
[ 1.401004] rtc-hym8563 5-0051: could not init device, -6
[ 1.401316] gsensor_mc3230 5-004c: sensor_register_device: gs_mc3230, id = 27
[ 1.401353] i2c i2c-5: sensor_probe: gs_mc3230,00000000647e49f7
[ 1.401427] gsensor_mc3230 5-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x000000002e148fa3
[ 2.091022] [Gsensor] init_3230_ctl_data 457 : error: -6
[ 2.091056] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor
[ 2.091071] gsensor_mc3230 5-004c: sensor_chip_init:fail to init sensor
[ 2.091088] i2c i2c-5: sensor_probe failed -2
[ 2.091088]
[ 2.094959] iommu: Adding device fdff0000.rkisp to group 7
[ 2.095022] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[ 2.095287] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 2.095310] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 2.095362] rkisp_hw fdff0000.rkisp: can’t request region for resource [mem 0xfdff0000-0xfdffffff]
[ 2.096646] rkisp rkisp-vir0: rkisp driver version: v01.07.00
[ 2.096780] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 2.097056] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 2.097088] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 2.099850] usbcore: registered new interface driver uvcvideo
[ 2.099883] USB Video Class driver (1.1.1)
[ 2.100277] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.26
[ 2.100344] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 2.100520] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 2.100669] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.24
[ 2.100729] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 2.100930] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.25
[ 2.100989] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 2.101145] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.20
[ 2.101204] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 2.101349] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.30
[ 2.101398] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 2.101556] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 2.101742] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 2.106124] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 2.107669] Bluetooth: HCI UART driver ver 2.3
[ 2.107704] Bluetooth: HCI UART protocol H4 registered
[ 2.107727] Bluetooth: HCI UART protocol ATH3K registered
[ 2.108026] Bluetooth: HCI UART protocol Broadcom registered
[ 2.108150] usbcore: registered new interface driver bfusb
[ 2.108255] usbcore: registered new interface driver btusb
[ 2.108632] cpu cpu0: leakage=19
[ 2.108712] cpu cpu0: pvtm = 83550, from nvmem
[ 2.108749] cpu cpu0: pvtm-volt-sel=1
[ 2.110990] sdhci: Secure Digital Host Controller Interface driver
[ 2.111023] sdhci: Copyright(c) Pierre Ossman
[ 2.111043] Synopsys Designware Multimedia Card Interface Driver
[ 2.112435] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.112742] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 2.112780] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 2.112882] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 2.113109] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 2.113145] mmc_host mmc3: card is non-removable.
[ 2.232928] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 2.246507] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.246697] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 2.246732] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 2.246852] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 50,32 bit host data width,256 deep fifo
[ 2.247068] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.31
[ 2.247180] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.25
[ 2.256970] mmc3 mmc_send_io_op_cond err: -110
[ 2.259724] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 2.273028] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.274792] mmc0: Unknown controller version (5). You may experience problems.
[ 2.306671] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 2.309431] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.310034] usbcore: registered new interface driver usbhid
[ 2.310065] usbhid: USB HID core driver
[ 2.310614] rockchip,bus bus-npu: Linked as a consumer to regulator.16
[ 2.310660] rockchip,bus bus-npu: Failed to get leakage
[ 2.310741] rockchip,bus bus-npu: pvtm = 83550, from nvmem
[ 2.310781] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 2.311088] rockchip,bus bus-npu: avs=0
[ 2.314730] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.27
[ 2.315885] rksfc_base v1.1 2016-01-08
[ 2.316953] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 2.317050] rkflash_dev_init enter
[ 2.317088] sfc nor id: ef 60 19
[ 2.317127] rkflash[1] init success
[ 2.318781] sfc_nor_mtd_init register mtd succuss
[ 2.318814] rkflash_dev_init device register as mtd dev, ret= 0
[ 2.320070] usbcore: registered new interface driver snd-usb-audio
[ 2.323455] rk817-codec rk817-codec: DMA mask not set
[ 2.324457] rk817_codec_parse_dt_property: rk809 hp adc effective value of detection 976~1024
[ 2.324502] invalid rk817->hp_det_gpio: -2
[ 2.324524] invalid gpio: -2
[ 2.333550] Initializing XFRM netlink socket
[ 2.334229] NET: Registered protocol family 10
[ 2.335486] Segment Routing with IPv6
[ 2.335643] NET: Registered protocol family 17
[ 2.335753] NET: Registered protocol family 15
[ 2.335822] can: controller area network core (rev 20170425 abi 9)
[ 2.336041] NET: Registered protocol family 29
[ 2.336095] can: raw protocol (rev 20170425)
[ 2.336113] can: broadcast manager protocol (rev 20170425 t)
[ 2.336137] can: netlink gateway (rev 20170425) max_hops=1
[ 2.336525] Bluetooth: RFCOMM socket layer initialized
[ 2.336589] Bluetooth: RFCOMM ver 1.11
[ 2.336615] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.336660] Bluetooth: HIDP socket layer initialized
[ 2.336721] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.336744] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.337517] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.337604] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 2.337631] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.337651] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.337722] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 2.337755] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.337777] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.337799] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 2.337819] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.338675] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 2.338739] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96.
[ 2.338781] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 97.
[ 2.338820] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 98.
[ 2.338933] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.339129] [BT_RFKILL]: ** disable irq
[ 2.339336] [BT_RFKILL]: bt_default device registered.
[ 2.339552] Key type dns_resolver registered
[ 2.340223] flash vendor_init_thread!
[ 2.340253] flash vendor storage:20170308 ret = -1
[ 2.340974] mmc0: new HS200 MMC card at address 0001
[ 2.342173] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 2.343148] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 2.343903] Loading compiled-in X.509 certificates
[ 2.344010] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 2.344262] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB, chardev (239:0)
[ 2.344907] pstore: Using compression: deflate
[ 2.346329] rga2: Driver loaded successfully ver:3.2.63318
[ 2.346819] rga2: Module initialized.
[ 2.349311] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.375918] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 300000Hz, actual 187500HZ div = 1)
[ 2.388571] phy phy-fe8a0000.usb2-phy.6: Linked as a consumer to regulator.4
[ 2.389005] phy phy-fe8a0000.usb2-phy.7: No vbus specified for otg port
[ 2.391579] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 2.391628] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 2.391868] mali fde60000.gpu: Linked as a consumer to regulator.17
[ 2.392140] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 2.392284] mali fde60000.gpu: leakage=6
[ 2.392430] mali fde60000.gpu: pvtm = 83550, from nvmem
[ 2.392704] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 2.393194] mali fde60000.gpu: avs=0
[ 2.393238] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 2.393708] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 2.393861] mali fde60000.gpu: No priority control manager is configured
[ 2.393896] mali fde60000.gpu: No memory group manager is configured
[ 2.394728] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 2.395938] mali fde60000.gpu: Probed as mali0
[ 2.397914] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 2.401532] mmc3 mmc_send_io_op_cond err: -110
[ 2.402262] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 2.402671] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[ 2.403506] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 2.403614] xhci-hcd xhci-hcd.4.auto: irq 82, io mem 0xfd000000
[ 2.404091] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 2.404114] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.404143] usb usb5: Product: xHCI Host Controller
[ 2.404167] usb usb5: Manufacturer: Linux 4.19.206 xhci-hcd
[ 2.404190] usb usb5: SerialNumber: xhci-hcd.4.auto
[ 2.404965] hub 5-0:1.0: USB hub found
[ 2.405043] hub 5-0:1.0: 1 port detected
[ 2.405554] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 2.405972] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 6
[ 2.406022] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 2.406153] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.406366] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 2.406400] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.406427] usb usb6: Product: xHCI Host Controller
[ 2.406452] usb usb6: Manufacturer: Linux 4.19.206 xhci-hcd
[ 2.406475] usb usb6: SerialNumber: xhci-hcd.4.auto
[ 2.407232] hub 6-0:1.0: USB hub found
[ 2.407318] hub 6-0:1.0: 1 port detected
[ 2.408515] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 2.410659] asoc-simple-card hdmi-sound: i2s-hifi ↔ fe400000.i2s mapping ok
[ 2.419428] asoc-simple-card rk809-sound: rk817-hifi ↔ fe410000.i2s mapping ok
[ 2.419486] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 2.419505] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 2.419521] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 2.419545] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 2.419569] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 2.419590] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 2.419615] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 2.419638] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 2.424478] register spi return v = :0
[ 2.424517] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 2.424540] ======== dhd_wlan_init_plat_data ========
[ 2.424561] [W
[ 2.500080] devfreq fde60000.gpu: Couldn’t update frequency transition information.
[ 2.519201] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 200000Hz, actual 187500HZ div = 1)
[ 2.535896] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 2.545014] mmc3 mmc_send_io_op_cond err: -110
[ 2.662488] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 100000Hz, actual 93750HZ div = 2)
[ 2.683059] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 2.692191] mmc3 mmc_send_io_op_cond err: -110
[ 2.729205] wifi_platform_bus_enumerate device present 1
[ 2.729239] ======== Card detection to detect SDIO card! ========
[ 2.729253] mmc3:mmc host rescan start!
[ 3.627915] phy phy-fe8a0000.usb2-phy.7: charger = USB_SDP_CHARGER
[ 4.752524] failed to power up DHD generic adapter, 0 retry left
[ 4.768709] wifi_platform_set_power = 0, delay: 0 msec
[ 4.768742] ======== PULL WL_REG_ON(-1) LOW! ========
[ 4.768756] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 4.768775] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 4.768788] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 4.768798] wifi_platform_bus_enumerate device present 0
[ 4.768809] ======== Card detection to remove SDIO card! ========
[ 4.768820] mmc3:mmc host rescan start!
[ 4.768831] failed to power up DHD generic adapter, max retry reached**
[ 4.768845] unregister wifi platform drivers
[ 4.768868] wifi_platform_bus_enumerate device present 0
[ 4.768890] ======== Card detection to remove SDIO card! ========
[ 4.768907] mmc3:mmc host rescan start!
[ 4.768925] ======== dhd_wlan_deinit_plat_data ========
[ 4.768946] dhd_module_init: Failed to load the driver, try cnt 0
[ 4.769059] dhd_module_init: Failed to load driver max retry reached**
[ 4.769076] dhd_module_init: Exit err=-19
[ 4.769676] ==gsl_ts_init==
[ 4.769797] ret=0
[ 4.771451] iommu: Adding device fde40000.npu to group 0
[ 4.771513] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 4.772189] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 4.772469] RKNPU fde40000.npu: Linked as a consumer to regulator.19
[ 4.772518] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
[ 4.773446] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[ 4.773888] RKNPU fde40000.npu: leakage=3
[ 4.773952] RKNPU fde40000.npu: pvtm = 83550, from nvmem
[ 4.774836] RKNPU fde40000.npu: avs=0
[ 4.775685] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 4.775775] RKNPU fde40000.npu: failed to find power_model node
[ 4.775806] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 4.775832] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 4.777859] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.784632] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.784830] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.784863] cfg80211: failed to load regulatory.db
[ 4.786277] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 4.788726] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘19:43:40’, on ‘Jan 7 2022’.
[ 4.789395] Mali:
[ 4.789398] Mali device driver loaded
[ 4.789788] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 4.790160] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 4.790344] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 4.790467] xc7160 4-001b: Linked as a consumer to regulator.0
[ 4.790545] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 4.790694] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 4.790788] xc7160 4-001b: could not get default pinstate
[ 4.790819] xc7160 4-001b: could not get sleep pinstate
[ 4.790852] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 4.790877] xc7160 4-001b: xc7160 num data lanes is 4
[ 5.819141] rk3x-i2c fe5d0000.i2c: timeout, ipd: 0x00, state: 2
[ 5.819183] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed
[ 5.819534] xc7160: probe of 4-001b failed with error -5
[ 5.819652] rkisp rkisp-vir0: clear unready subdev num: 4
[ 5.819683] rockchip-csi2-dphy0: No link between dphy and sensor
[ 5.820505] rockchip-csi2-dphy0: No link between dphy and sensor
[ 5.820535] rkisp-vir0: update sensor failed
v⚌ 5.824608]
