RK3399编译LINUX镜像
按照官网流程 make之后如何生成可烧写的文件,比如update.img文件,我按照教程./build.sh update之后有问题
hl@hl-ThinkCentre-M930t-N000:~/project/huolong/android/rk3399firefly/rk3399_linux_release_v2.5.1$./build.sh
processing option: allff
TARGET_ARCH=arm64
TARGET_PLATFORM=rk3399
TARGET_UBOOT_CONFIG=firefly-rk3399
TARGET_SPL_CONFIG=
TARGET_KERNEL_CONFIG=firefly_linux_defconfig
TARGET_KERNEL_DTS=rk3399-firefly
TARGET_TOOLCHAIN_CONFIG=
TARGET_BUILDROOT_CONFIG=
TARGET_RECOVERY_CONFIG=
TARGET_PCBA_CONFIG=rockchip_rk3399_pcba
TARGET_RAMBOOT_CONFIG=
============Start building uboot============
## make firefly-rk3399_defconfig -j40
scripts/kconfig/conf --silentoldconfigKconfig
CHK include/config.h
CFG u-boot.cfg
GEN include/autoconf.mk.dep
CFG spl/u-boot.cfg
CFG tpl/u-boot.cfg
GEN tpl/include/autoconf.mk
GEN spl/include/autoconf.mk
CHK include/config/uboot.release
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
CHK include/generated/version_autogenerated.h
CHK include/generated/generic-asm-offsets.h
CHK include/generated/asm-offsets.h
HOSTCC tools/mkenvimage.o
HOSTCC tools/fit_image.o
HOSTCC tools/image-host.o
HOSTCC tools/dumpimage.o
HOSTCC tools/mkimage.o
HOSTCC tools/rockchip/boot_merger.o
HOSTCC tools/rockchip/loaderimage.o
CFG u-boot.cfg
HOSTLD tools/mkenvimage
HOSTLD tools/loaderimage
HOSTLD tools/dumpimage
HOSTLD tools/mkimage
HOSTLD tools/boot_merger
CC arch/arm/cpu/armv8/fwcall.o
LD arch/arm/cpu/armv8/built-in.o
CC cmd/version.o
CC common/main.o
CC drivers/usb/gadget/f_fastboot.o
LD cmd/built-in.o
LD common/built-in.o
CC lib/smbios.o
CC lib/display_options.o
CC lib/efi_loader/helloworld.o
LD lib/efi_loader/helloworld.so
OBJCOPYlib/efi_loader/helloworld.efi
LD lib/built-in.o
LD drivers/usb/gadget/built-in.o
LD u-boot
OBJCOPY u-boot.srec
OBJCOPY u-boot-nodtb.bin
SYM u-boot.sym
start=$(/home/hl/project/huolong/android/rk3399firefly/rk3399_linux_release_v2.5.1/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nmu-boot | grep __rel_dyn_start | cut -f 1 -d ’ ');end=$(/home/hl/project/huolong/android/rk3399firefly/rk3399_linux_release_v2.5.1/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nmu-boot | grep __rel_dyn_end | cut -f 1 -d ’ '); tools/relocate-relau-boot-nodtb.bin 0x00200000 $start $end
make[2]: ‘arch/arm/dts/rk3399-firefly.dtb’ is up to date.
COPY u-boot.dtb
CAT u-boot-dtb.bin
MKIMAGE u-boot.img
MKIMAGE u-boot-dtb.img
COPY u-boot.bin
ALIGN u-boot.bin
COPY spl/u-boot-spl.dtb
COPY tpl/u-boot-tpl.dtb
CC tpl/common/spl/spl.o
CC spl/common/spl/spl.o
CC tpl/arch/arm/mach-rockchip/tpl.o
CC spl/arch/arm/cpu/armv8/fwcall.o
CC tpl/arch/arm/cpu/armv8/fwcall.o
CC tpl/lib/display_options.o
CC spl/lib/display_options.o
LD tpl/arch/arm/cpu/armv8/built-in.o
LD spl/arch/arm/cpu/armv8/built-in.o
LD tpl/arch/arm/mach-rockchip/built-in.o
LD tpl/common/spl/built-in.o
LD spl/common/spl/built-in.o
LD tpl/lib/built-in.o
LD spl/lib/built-in.o
LD tpl/u-boot-tpl
LD spl/u-boot-spl
OBJCOPY tpl/u-boot-tpl-nodtb.bin
CAT tpl/u-boot-tpl-dtb.bin
COPY tpl/u-boot-tpl.bin
OBJCOPY spl/u-boot-spl-nodtb.bin
CAT spl/u-boot-spl-dtb.bin
COPY spl/u-boot-spl.bin
CFGCHK u-boot.cfg
load addr is 0x200000!
pack input u-boot.bin
pack file size: 946304(924 KB)
crc = 0xb7824cb3
uboot version: U-Boot 2017.09 (Jan 11 2022 - 21:06:51)
pack uboot.img success!
pack uboot okay! Input: u-boot.bin
out:trust.img
merge success(trust.img)
/home/hl/project/huolong/android/rk3399firefly/rk3399_linux_release_v2.5.1/u-boot
pack trust okay! Input:/home/hl/project/huolong/android/rk3399firefly/rk3399_linux_release_v2.5.1/rkbin/RKTRUST/RK3399TRUST.ini
Image Type: Rockchip RK33 (SD/MMC) bootimage
Init Data Size: 153600 bytes
pack loader ok.(rk3399_loader_v1.26.126.bin)(0.00)
pack rk3399_loader_v1.26.126.bin okay! Input:/home/hl/project/huolong/android/rk3399firefly/rk3399_linux_release_v2.5.1/rkbin/RKBOOT/RK3399MINIALL.ini
Platform RK3399 is build OK, with new .config(make firefly-rk3399_defconfig-j40)
Running build_uboot succeeded.
Skipping build_loader for missing configs: RK_LOADER_BUILD_TARGET.
============Start building kernel============
TARGET_ARCH =arm64
TARGET_KERNEL_CONFIG =firefly_linux_defconfig
TARGET_KERNEL_DTS =rk3399-firefly
TARGET_KERNEL_CONFIG_FRAGMENT =
CHK scripts/mod/devicetable-offsets.h
make[1]: ‘arch/arm64/boot/dts/rockchip/rk3399-firefly.dtb’ is up to date.
CHK include/generated/timeconst.h
CHK include/generated/bounds.h
CALL scripts/checksyscalls.sh
make[1]: ‘include/generated/vdso-offsets.h’ is up to date.
CHK include/generated/compile.h
fatal: Not a git repository (or any of the parent directories): .git
make[1]: ‘arch/arm64/boot/Image.lz4’ is up to date.
Image: kernel.img is ready
make[2]: ‘include/generated/vdso-offsets.h’ is up to date.
Building modules, stage 2.
MODPOST 1 modules
Image: resource.img (with rk3399-firefly.dtb logo.bmp ) is ready
Image: boot.img (with Image ramdisk.img resource.img) is ready
Image: zboot.img (with Image.lz4 ramdisk.img resource.img) is ready
Running build_kernel succeeded.
Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN.
Skipping build_buildroot for missing configs: RK_CFG_BUILDROOT.
buildroot/output//images/rootfs.ext4 not generated?
Running build_rootfs succeeded.
==========Start building recovery==========
config is
use prebuilt recovery-arm64.cpio.gz for CPIO image
found kernel image
pack recovery.img…done.
you take 0:00.06 to build recovery
====Build recovery ok!====
Running build_recovery succeeded.
Skipping build_ramboot for missing configs: RK_CFG_RAMBOOT.
Running build_all succeeded.
/usr/bin/fakeroot
warning:/home/hl/project/huolong/android/rk3399firefly/rk3399_linux_release_v2.5.1/ubuntu_rootfs/rk3399_ubuntu_rootfs.imgnot found!
please set correct RK_ROOTFS_IMG in device/rockchip/.BoardConfig.mk
create parameter…done.
/home/hl/project/huolong/android/rk3399firefly/rk3399_linux_release_v2.5.1/device/rockchip/rk3399/parameter-ubuntu.txt
0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x00600000@0x0005a000(rootfs),-@0x0065a000(userdata:grow)
create misc.img…done.
warning: not found!
create uboot.img…done.
create idbloader.img…done.
create trust.img…done.
create loader…done.
create boot.img…done.
Image: image in rockdev is ready
Make image ok!
File name is FIREFLY-RK3399-UBUNTU-GPT
Rename the file? [N|y]N
Make update.img
start to make update.img…
Resize rootfs partition size
dumpe2fs 1.42.13 (17-May-2015)
dumpe2fs: No such file or directory while trying to open/home/hl/project/huolong/android/rk3399firefly/rk3399_linux_release_v2.5.1/rockdev/rootfs.img
./mkupdate.sh: line 37: >>9: syntax error: operand expected (error tokenis “>>9”)
Android Firmware Package Tool v1.66
------ PACKAGE ------
Add file: ./package-file
Add file: ./package-file done,offset=0x800,size=0x136,userspace=0x1
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/MiniLoaderAll.bin done,offset=0x1000,size=0x7194e,userspace=0xe4
Add file: ./Image/parameter.txt
Add file: ./Image/parameter.txtdone,offset=0x73000,size=0x1f0,userspace=0x1
Add file: ./Image/trust.img
Add file: ./Image/trust.imgdone,offset=0x73800,size=0x400000,userspace=0x800
Add file: ./Image/uboot.img
Add file: ./Image/uboot.imgdone,offset=0x473800,size=0x400000,userspace=0x800
Add file: ./Image/boot.img
Add file: ./Image/boot.imgdone,offset=0x873800,size=0x1ea3000,userspace=0x3d46
Add file: ./Image/misc.img
Add file: ./Image/misc.img done,offset=0x2716800,size=0xc000,userspace=0x18
Add file: ./Image/recovery.img
Add file: ./Image/recovery.imgdone,offset=0x2722800,size=0x1e7f000,userspace=0x3cfe
Add file: ./Image/rootfs.img
Error: open file failed,err=2!
------ FAILED ------
Press any key to quit:
ERROR: Running build_updateimg failed!
ERROR: exit code 1 from line 1204:
./mkupdate.sh
