ubuntu
背景:
build 为aio-rv1126-rkmedia-uvcc.mk项目.默认 os04a10 正常预览. 但 dts 更换为 gc2053, 插入点亮验证正常的 gc2053 模组, 反复报如下错误.
iq文件名字反复核对和 dts 一样.
##RKMEDIA Log level: 2
[RKMEDIA][SYS][Info]:text is all=2
[RKMEDIA][SYS][Info]:module is all, log_level is 2
Loading model ...
Waitting RKAIQ Init ...
model input num: 1, output num: 2
input tensors:
index=0 name= n_dims=4 dims=[1 300 300 3] n_elems=270000 size=270000 fmt=0 type=3 qnt_type=2 fl=127 zp=127 scale=0.007843
output tensors:
index=0 name= n_dims=4 dims=[1 1917 1 4] n_elems=7668 size=7668 fmt=0 type=3 qnt_type=2 fl=-76 zp=180 scale=0.089482
index=1 name= n_dims=3 dims=[0 1 1917 91] n_elems=174447 size=174447 fmt=0 type=3 qnt_type=2 fl=-66 zp=190 scale=0.137463
create rknn_list success
main initial finish
tcp server listen_sockfd: 7
[ 8.242038] dwc3 ffd00000.dwc3: device reset
start rknn server, version:1.5.2 (e67e5cb build: 2020-12-03 15:04:52)
I NPUTransfer: Starting NPU Transfer Server, Transfer version 2.1.0 (b5861e7@2020-11-23T11:51:07)
[ 8.373855] dwc3 ffd00000.dwc3: device reset
[ 8.373924] android_work: did not send uevent (0 0 (null))
[ 8.518602] android_work: sent uevent USB_STATE=CONNECTED
[ 8.610600] configfs-gadget gadget: high-speed config #1: b
[ 8.610745] configfs-gadget gadget: uvc_function_set_alt(2, 0)
[ 8.610757] configfs-gadget gadget: reset UVC Control
[ 8.610778] configfs-gadget gadget: uvc_function_set_alt(3, 0)
[ 8.610991] android_work: sent uevent USB_STATE=CONFIGURED
[ 8.741471] configfs-gadget gadget: uvc_function_set_alt(3, 0)
[ 8.801643] NOHZ: local_softirq_pending 08
[ 8.813989] NOHZ: local_softirq_pending 08
[ 8.853983] NOHZ: local_softirq_pending 08
[ 9.666014] NOHZ: local_softirq_pending 08
[ 9.857987] NOHZ: local_softirq_pending 08
[ 9.858683] NOHZ: local_softirq_pending 08
[ 9.869944] NOHZ: local_softirq_pending 08
[ 9.903650] NOHZ: local_softirq_pending 08
[ 10.021968] NOHZ: local_softirq_pending 08
[ 10.045939] NOHZ: local_softirq_pending 08
set governor ondemand ok
RKAIQ Init Err !!!
[ 566.385294] adbd (1045): /proc/1045/oom_adj is deprecated, please use /proc/1045/oom_score_adj instead.
[root@RV1126_RV1109:/]#
ubuntu
3
799959745 发表于 2022-1-13 09:05
更换摄像头应该是要修改源代码适配的
再往下追发现 问题点对比 log 如下, 能给点建议吗?
[RKMEDIA][SYS][Warn]:VI[1t]:"rkispp_scale1" buffer mayh be occupied by other module s or apps, try again...
[/code]
os04a10 正常 log
[ [RKMEDIA][SYS][Info]:#V4L2Ctx : open /dev/video20, fd 106
10.242624] [width max:1280 ratio max:8 min:2]
[ 10.242675] rkispp0: scale1:0x0 out of range:
[ 10.242675] [width max:1280 ratio max:8 min:2]
[ 10.242700] rkispp0: scale1:0x0 out of range:
[ 10.242700] [width max:1280 ratio max:8 min:2]
[RKMEDIA][SYS][Info]:RK_MPI_VI_EnableChn: Enable VI[0:1]:rkispp_scale1, 720x576 End...
Rga[0] create
[RKMEDIA][SYS][Info]:RK_MPI_RGA_CreateChn: Enable RGA[0], Rect<0,0,1280,720> Start...
[RKMEDIA][SYS][Info]:FilterFlow:rkrga: Enable BufferPool! memtype:hw_mem, memcnt:2
[RKMEDIA][SYS][Info]:RK_MPI_RGA_CreateChn: Enable RGA[0], Rect<0,0,1280,720> End...
[RKMEDIA][SYS][Info]:RK_MPI_SYS_Bind: Bind Mode[VI]:Chn[0] to Mode[RGA]:Chn[0]...
Rga[1] create
[RKMEDIA][SYS][Info]:RK_MPI_RGA_CreateChn: Enable RGA[1], Rect<0,0,720,576> Start...
[RKMEDIA][SYS][Info]:RK_MPI_RGA_CreateChn: Enable RGA[1], Rect<0,0,720,576> End...
[RKMEDIA][SYS][Info]:RK_MPI_SYS_Bind: Bind Mode[VI]:Chn[1] to Mode[RGA]:Chn[1]...
#Start GetMediaBuffer thread, arg:(nil)
gc2053 异常 log.
[RKMEDIA][SYS][Info]:#V4L2Ct[x: open /dev/video20, fd 105
[RKMEDIA][SYS][Error]:rkisp p_scale1, s fmt failed(cap t ype=1, NV12), Invalid argumen t
[RKMEDIA][SYS][Info]:#V4L2Ctx: close , fd 105
[RKMEDIA][S3YS][Info]:#V4L2Stream: v4l2 2ctx reset to nullptr!
.33242[RKMEDIA][VI][Info]:Create s8tream v4l2_capture_stream fa] iled
[RKMEDIA][VI][Info]:#S urceStreamFlow[]: stream of[wf....
[RKMEDIA][VI][Info]:#iSourceStreamFlow[]: read thread exit sucessfully!
[RKMEDIA][VI][Info]:#SourceStreamFlow[]: stream reset sucessfullyd!
cat proc/version看一下版本。
要改程序源代码。看一下rkmedia/example有关双目摄像头demo的示例进行修改。
ubuntu
5
要改程序源代码。看一下rkmedia/example有关双目摄像头demo的示例进行修改 …
版本如下, 我用的默认 uvc_app. dts里面把 os04a10 换成 gc2053. 请教哪方面的"程序源码"还要修改?
[root@RV1126_RV1109:/]# cat proc/version
Linux version 4.19.111 (x@fa14e1f641f4) (rv1126_rv1109_linux_ai_camera_20210904.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 SMP PREEMPT Thu Jan 6 22:35:58 HKT 2022
ubuntu
6
RKAIQ Init Err !!! 是 ARCUVC_APP 查不到 aiserver 的进程在跑,认为 RKAIQ 没有被初始化然后退出了。你应该 ps -ef | grep ispserver ; ps -ef | grep aiserver 看一下两个进程有没有运行,如果没有,你应该单独自己手动 运行 ispserver 看一下 log RKAIQ 初始化哪里报错
ubuntu
8
板蓝根 发表于 2022-1-17 09:25
RKAIQ Init Err !!! 是 ARCUVC_APP 查不到 aiserver 的进程在跑,认为 RKAIQ 没有被初始化然后退出了。你应 …
赞。
已经找到原因了
首先, 的确如您推测,是ispserver 和aiserver 没起来。 进而发现是RkLunch.sh 都没起来。发现@799959745 做的aio-rv1126-rkmedia-uvcc.mk项目 默认没开RkLunch.sh , 而是如下进程。
[root@RV1126_RV1109:/]# ps -ef | grep sh
root 874 1 0 02:45 ? 00:00:01 /usr/bin/firefly_rkmedia_vi_uvc_test -a /oem/etc/iqfiles/ -c /oem/usr/share/rtsp-nn.cfg -p /oem/usr/share/rknn_model/ssd_inception_v2_rv1109_rv1126.rknn -l
root 881 1 0 02:45 ? 00:00:00 /bin/sh /usr/bin/start_rknn.sh
ubuntu
9
有个疑问请教:
#8 楼中, 我把firefly_rkmedia_vi_uvc_test 进程杀了, 然后 adb 无法使用.
这是怎么回事呢?
确实会这样,如果要独立 adb 还是直接使用原有 /etc/init.d/S50usbdevice 去初始化设备
ubuntu
11
我把S58_lunch_init, 也就是开启firefly_rkmedia_vi_uvc_test对应的脚本, 里面的内容全部删了. 但还是无法 使用adb.
怀疑usb_config.sh 中网口影响(这个网口什么时候用 eth0 ,什么时候是 eth2 ?), 又还原为 eth0 ,也无效.
sed -i s/eth0/eth2/g /oem/usb_config.sh
可以给点建议吗?
source /etc/profile.d/RkEnv.sh
case "$1" in
start)
if (cat /proc/device-tree/model | grep CAM-CRV > /dev/null)
then
echo "/oem/usb_config.sh don't need to modify"
/oem/usb_config.sh rndis
sed -i '$d' /oem/usr/share/rtsp-nn.cfg
sed -i '$a\path=/live/main_stream video_type=7 width=1920 height=1080 image_type=4 video_path=rkispp_scale1' /oem/usr/share/rtsp-nn.cfg
/usr/bin/firefly_rkmedia_vi_uvc_double_cameras_test -a /oem/etc/iqfiles/ -c /oem/usr/share/rtsp-nn.cfg -p /oem/usr/share/rknn_model/ssd_inception_v2_rv1109_rv1126.rknn -l /oem/usr/share/rknn_model/coco_labels_list.txt -b /oem/usr/share/rknn_model/box_priors.txt &
else
sed -i s/eth2/eth0/g /oem/usb_config.sh
#/usr/bin/firefly_rkmedia_vi_uvc_test -a /oem/etc/iqfiles/ -c /oem/usr/share/rtsp-nn.cfg -p /oem/usr/share/rknn_model/ssd_inception_v2_rv1109_rv1126.rknn -l /oem/usr/share/rknn_model/coco_labels_list.txt -b /oem/usr/share/rknn_model/box_priors.txt &
fi
stop)
#killall firefly_rkmedia_vi_uvc_test
echo "Usage: $0 {start|stop}"
exit 1
esac
exit 0
如果不使用 uvc ,需要用 /etc/init.d/S50usbdevice 去初始化而不是用 usb_config.sh
ubuntu
13
直接把 /etc/init.d/S58_lunch_init 里面所以内容都删了, 默认应该先走到S50usbdevice, 似乎 也不行啊?
S50usbdevice 先看一下,uvc mk 编译的话 S50usbdevice 会注释一些代码,需要手动打开,而且建议最好去理解一下 S50usbdevice 干了什么,这个代码量不多的
