<6>[ 0.596729] rk32-edp rk32-edp: rk32 edp driver probe success
<6>[ 0.619036] rk32-edp rk32-edp: edp pll locked
<6>[ 0.620265] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:4
<3>[ 0.637033] rk32-edp rk32-edp: hw lt err:6
<3>[ 0.637044] rk32-edp rk32-edp: link train failed!
使用Firefly点亮EDP LCD出现以上以上信息
请问问题出在哪呢?
完整的log发出来看看
如下:感謝
<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (tim@tim) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #50 SMP PREEMPT Mon Aug 10 15:27:58 CST 2015
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(cma): base(40000000) size(28000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 640 MiB at 40000000
<6>[ 0.000000] ion_reserve: cma reserved base 40000000 size 671088640
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0c77c00, node_mem_map c0d9e000
<7>[ 0.000000] Normal zone: 1024 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 3072 pages used for memmap
<7>[ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1dd9000 s14016 r8192 d14656 u36864
<7>[ 0.000000] pcpu-alloc: s14016 r8192 d14656 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
<5>[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 earlyprintk androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00200000@0x0039A000(userdata),0x00020000@0x0059A000(radical_update),-@0x005BA000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2015-03-26_10:37:10
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 1388776k/1388776k available, 708376k reserved, 917504K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0ae28fc (11115 kB)
<5>[ 0.000000] .init : 0xc0ae3000 - 0xc0b776c0 ( 594 kB)
<5>[ 0.000000] .data : 0xc0b78000 - 0xc0c7f438 (1054 kB)
<5>[ 0.000000] .bss : 0xc0c7f438 - 0xc0d9d7c4 (1145 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 31
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 3
<6>[ 0.000000] channel:0, lkg:33
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:24
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.355688] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.355703] pid_max: default: 32768 minimum: 301
<6>[ 0.355806] Security Framework initialized
<6>[ 0.355823] SELinux: Initializing.
<7>[ 0.355849] SELinux: Starting in permissive mode
<6>[ 0.355893] Mount-cache hash table entries: 512
<6>[ 0.356526] Initializing cgroup subsys debug
<6>[ 0.356540] Initializing cgroup subsys memory
<6>[ 0.356566] Initializing cgroup subsys freezer
<6>[ 0.356593] CPU: Testing write buffer coherency: ok
<3>[ 0.356904] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.356916] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.356925] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.356934] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.356992] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.357042] Setting up static identity map for 0xc07e2868 - 0xc07e28c0
<6>[ 0.360129] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x168b (version 3.0)
<4>[ 0.433798] CPU1: Booted secondary processor
<6>[ 0.433831] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.453483] CPU2: Booted secondary processor
<6>[ 0.453506] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.473193] CPU3: Booted secondary processor
<6>[ 0.473216] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.473318] Brought up 4 CPUs
<6>[ 0.473347] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.473355] CPU: All CPU(s) started in SVC mode.
<6>[ 0.474071] devtmpfs: initialized
<6>[ 0.479134] pinctrl core: initialized pinctrl subsystem
<6>[ 0.479382] regulator-dummy: no parameters
<6>[ 0.490784] NET: Registered protocol family 16
<6>[ 0.492628] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.492960] ion_snapshot: 0x1e9b0000 map to 0xe0907000 and copy to 0xc0d78dc4 (version 0.1)
<6>[ 0.493269] Registered FIQ tty driver
<3>[ 0.493682] fiq-debugger is disabled in device tree
<4>[ 0.494343] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.494363] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.494380] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.494396] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.494487] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.494550] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.494611] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.494671] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.494733] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.494792] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.494851] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.494911] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.494977] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.495038] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.495051] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.495062] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.495073] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.495145] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.495191] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.495235] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.495285] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.495330] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.495374] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.495423] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.495467] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.495510] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.495554] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.495585] rockchip_interrupts_register:bank_num=7
<4>[ 0.497464] rockchip_pinctrl_probe:init ok
<6>[ 0.503215] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.503301] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.503314] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.503474] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.503550] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.503563] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.503716] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.503786] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.503799] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.503958] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.504033] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504046] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.504207] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.504281] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504293] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.504447] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.504516] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504528] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.504695] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.504765] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.504777] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.506389] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.506401] hw-breakpoint: maximum watchpoint size is 4 bytes.
<4>[ 0.506602] DDR DEBUG: version 1.00 20140603
<4>[ 0.506632] DDR DEBUG: Channel a:
<4>[ 0.506641] DDR DEBUG: DDR3 Device
<4>[ 0.506654] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.506663] DDR DEBUG: Channel b:
<4>[ 0.506669] DDR DEBUG: DDR3 Device
<4>[ 0.506681] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.506690] DDR DEBUG: addr=0xc87000
<4>[ 0.506699] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.506708] DDR DEBUG: socAddr[0]=0xc87000, socAddr[1]=0xc87100
<4>[ 0.506717] DDR DEBUG: chAddr[0]=0xc87000, chAddr[1]=0xc87000
<4>[ 0.506728] DDR DEBUG: dtar[0]=0x70190000, dtar[1]=0x70190000
<4>[ 0.506968] DDR DEBUG: init success!!! freq=300MHz
<4>[ 0.506976] DDR DEBUG: Channel a:
<4>[ 0.506988] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.507000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.507012] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.507024] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.507035] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.507044] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.507052] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.507060] DDR DEBUG: Channel b:
<4>[ 0.507071] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.507083] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.507095] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.507107] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.507117] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.507126] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.507134] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.529233] bio: create slab at 0
<5>[ 0.530021] SCSI subsystem initialized
<6>[ 0.530163] usbcore: registered new interface driver usbfs
<6>[ 0.530205] usbcore: registered new interface driver hub
<6>[ 0.530282] usbcore: registered new device driver usb
<7>[ 0.530521] of_get_named_gpio_flags exited with status 14
<7>[ 0.530550] of_get_named_gpio_flags exited with status 12
<7>[ 0.531441] of_get_named_gpio_flags exited with status 15
<7>[ 0.531460] of_get_named_gpio_flags exited with status 16
<6>[ 0.531607] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.533565] of_get_named_gpio_flags exited with status 260
<7>[ 0.533586] of_get_named_gpio_flags exited with status 261
<6>[ 0.533731] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.535176] of_get_named_gpio_flags exited with status 201
<7>[ 0.535195] of_get_named_gpio_flags exited with status 202
<6>[ 0.535334] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.536107] of_get_named_gpio_flags exited with status 81
<7>[ 0.536126] of_get_named_gpio_flags exited with status 80
<6>[ 0.536255] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.536353] of_get_named_gpio_flags exited with status 241
<7>[ 0.536370] of_get_named_gpio_flags exited with status 242
<6>[ 0.536494] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.536962] media: Linux media interface: v0.10
<6>[ 0.537003] Linux video capture interface: v2.00
<6>[ 0.537049] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.537058] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.537078] PTP clock support registered
<6>[ 0.537565] Rockchip ion module is successfully loaded (v1.0)
<6>[ 0.537722] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.538075] Bluetooth: Core ver 2.16
<6>[ 0.538116] NET: Registered protocol family 31
<6>[ 0.538125] Bluetooth: HCI device and connection manager initialized
<6>[ 0.538140] Bluetooth: HCI socket layer initialized
<6>[ 0.538152] Bluetooth: L2CAP socket layer initialized
<6>[ 0.538176] Bluetooth: SCO socket layer initialized
<6>[ 0.538383] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.539480] act8846_i2c_probe,line=898
<4>[ 0.540435] act8846_parse_dt,line=746
<7>[ 0.541046] of_get_named_gpio_flags exited with status 238
<7>[ 0.541059] of_get_named_gpio_flags exited with status 1
<7>[ 0.541071] of_get_named_gpio_flags exited with status 234
<7>[ 0.541082] of_get_named_gpio_flags exited with status 259
<4>[ 0.541102] act8846_i2c_probe: act8846_pmic_hold=1
<4>[ 0.541121] act8846_i2c_probe: act8846_pmic_sleep=1
<4>[ 0.541135] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
<4>[ 0.541150] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
<6>[ 0.542970] act_dcdc1: 1200 mV
<6>[ 0.545700] vccio: 3300 mV
<6>[ 0.547541] vdd_logic: 700 ↔ 1500 mV at 1100 mV
<6>[ 0.550239] act_dcdc4: 2000 mV
<6>[ 0.551461] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.553530] act_ldo2: 1000 mV
<6>[ 0.555593] act_ldo3: 2800 mV
<6>[ 0.557675] act_ldo4: 3300 mV
<6>[ 0.559743] act_ldo5: 3300 mV
<6>[ 0.561808] act_ldo6: 1000 mV
<6>[ 0.563901] vcc_18: 1800 mV
<6>[ 0.565959] act_ldo8: 1800 mV
<6>[ 0.570711] vdd_arm: 712 ↔ 1500 mV at 1000 mV
<6>[ 0.575411] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
<6>[ 0.576246] Switching to clocksource arch_sys_counter
<7>[ 0.596174] uboot-logo-on:0
<6>[ 0.596217] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.596229] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.596603] rk-screen rk_screen.8: rockchip screen probe success
<3>[ 0.596751] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
<4>[ 0.596769] rk32-lvds: probe of ff96c000.lvds failed with error -22
<6>[ 0.597342] rk32-edp rk32-edp: rk32 edp driver probe success
<7>[ 0.597920] of_get_named_gpio_flags exited with status 13
<6>[ 0.598153] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.598457] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.598607] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.598756] graphics fb3: rockchip framebuffer registerd:fb3
<6>[ 0.619379] rk3288-lcdc lcdc0: lcdc0: dclk:238260000>>fps:60
<6>[ 0.619585] rk32-edp rk32-edp: edp pll locked
<6>[ 0.620814] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:4
<3>[ 0.637582] rk32-edp rk32-edp: hw lt err:6
<3>[ 0.637593] rk32-edp rk32-edp: link train failed!
<6>[ 0.692854] rk3288-lcdc lcdc0: wakeup from standby!
<6>[ 0.735103] alloc_buffer:ion_phy_addr=0x40000000
<6>[ 0.756374] fb0:phy:40000000>>vir:e0971000>>len:0x2b00000
<6>[ 0.764719] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
<4>[ 0.765374] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.765499] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.765600] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.765710] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.765813] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.765914] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.766499] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.766641] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.767173] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.767306] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.767833] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.767974] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.768516] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.768654] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.769987] NET: Registered protocol family 2
<6>[ 0.770437] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.770512] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.770584] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.770631] TCP: reno registered
<6>[ 0.770645] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.770667] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.770853] NET: Registered protocol family 1
<6>[ 0.771028] Unpacking initramfs…
<6>[ 0.838433] Freeing initrd memory: 1272K (c5bf0000 - c5d2e000)
<6>[ 0.839081] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.839538] probe device ff9a0000.vpu_service
<4>[ 0.839715] vpu_service: power on
<6>[ 0.840771] checking hw id 4831
<6>[ 0.841149] vpu_service set to auto frequency mode
<6>[ 0.841184] vpu_service: power off…
<6>[ 0.841221] done
<6>[ 0.841229] init success
<6>[ 0.841274] probe device ff9c0000.hevc_service
<4>[ 0.841464] hevc_service: power on
<6>[ 0.842500] checking hw id 6867
<6>[ 0.842728] hevc_service: power off…
<6>[ 0.842764] done
<6>[ 0.842772] init success
<4>[ 0.842879] rknandbase v1.0 2014-03-31
<3>[ 0.842972] rknand ff400000.nandc0: no irq resource?
<4>[ 0.843087] rknand_driver:ret = 0
<6>[ 0.843832] audit: initializing netlink socket (disabled)
<5>[ 0.843868] type=2000 audit(0.490:1): initialized
<4>[ 0.844619] bounce pool size: 64 pages
<6>[ 0.849037] fuse init (API version 7.22)
<6>[ 0.849378] msgmni has been set to 954
<7>[ 0.849426] SELinux: Registering netfilter hooks
<6>[ 0.851092] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 0.851106] io scheduler noop registered
<6>[ 0.851115] io scheduler deadline registered
<6>[ 0.851202] io scheduler cfq registered (default)
<6>[ 0.854582] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.854729] rga: Driver loaded succesfully
<4>[ 0.855309] IEP Driver loaded succesfully
<4>[ 0.855393] Module initialized.
<6>[ 0.856220] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.856237] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 0.857473] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.857489] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<6>[ 0.857829] vdd_logic: 925 ↔ 1400 mV at 1000 mV
<4>[ 0.857878] vdd_logic: Failed to create debugfs directory
<4>[ 0.858282] rk_serial.c v1.8 2014-03-04
<6>[ 0.858483] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 0.858664] serial ff180000.serial: membase e348a000
<6>[ 0.858791] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
<6>[ 2.452757] console [ttyS2] enabled
<6>[ 2.456377] serial ff690000.serial: membase fed60000
<6>[ 2.463893] loop: module loaded
<6>[ 2.467543] SCSI Media Changer driver v0.25
<6>[ 2.472047] tun: Universal TUN/TAP device driver, 1.6
<6>[ 2.477033] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 2.483218] vmac_init.
<3>[ 2.486041] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<3>[ 2.492732] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
<6>[ 2.499676] stmmac_probe_config_dt: clock input or output? (input).
<6>[ 2.505859] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 2.510655] stmmac_probe_config_dt: RX delay(0x20).
<7>[ 2.515460] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 2.515474] of_get_named_gpio_flags exited with status 136
<7>[ 2.515485] of_get_named_gpio_flags exited with status 6
<4>[ 2.515495] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 2.520814] stmmc_pltfr_init:
<6>[ 2.524008] stmmc_pltfr_init: init for RGMII
<6>[ 2.528219] tx delay=0x30
<6>[ 2.528219] rx delay=0x20
<6>[ 2.533784] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 2.538776] Normal descriptors
<6>[ 2.541865] Ring mode enabled
<6>[ 2.544879] DMA HW capability register supported
<6>[ 2.549334] RX Checksum Offload Engine supported (type 2)
<6>[ 2.554923] TX Checksum insertion supported
<6>[ 2.559121] Wake-Up On Lan supported
<6>[ 2.562745] Enable RX Mitigation via HW Watchdog Timer
<6>[ 2.568275] PPP generic driver version 2.4.2
<6>[ 2.572623] PPP BSD Compression module registered
<6>[ 2.577266] PPP Deflate Compression module registered
<6>[ 2.582243] PPP MPPE Compression module registered
<6>[ 2.586977] NET: Registered protocol family 24
<6>[ 2.591368] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 2.600865] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 2.608070] Rockchip WiFi SYS interface (V1.00) …
<4>[ 2.612984] esp_mem_init enter date Jun 18 2015 14:49:21
<4>[ 2.618253] esp_mem_init complete
<6>[ 2.621666] usbcore: registered new interface driver catc
<6>[ 2.627016] usbcore: registered new interface driver kaweth
<6>[ 2.632496] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 2.639816] usbcore: registered new interface driver pegasus
<6>[ 2.645427] usbcore: registered new interface driver rtl8150
<6>[ 2.651028] usbcore: registered new interface driver r8152
<6>[ 2.656443] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 2.661635] usbcore: registered new interface driver hso
<6>[ 2.666904] usbcore: registered new interface driver asix
<6>[ 2.672263] usbcore: registered new interface driver ax88179_178a
<6>[ 2.678280] usbcore: registered new interface driver cdc_ether
<6>[ 2.684065] usbcore: registered new interface driver cdc_eem
<6>[ 2.689661] usbcore: registered new interface driver dm9601
<6>[ 2.695179] usbcore: registered new interface driver dm9620
<6>[ 2.700705] usbcore: registered new interface driver smsc75xx
<6>[ 2.706403] usbcore: registered new interface driver smsc95xx
<6>[ 2.712091] usbcore: registered new interface driver gl620a
<6>[ 2.717608] usbcore: registered new interface driver net1080
<6>[ 2.723218] usbcore: registered new interface driver plusb
<6>[ 2.728640] usbcore: registered new interface driver rndis_host
<6>[ 2.734512] usbcore: registered new interface driver cdc_subset
<6>[ 2.740358] usbcore: registered new interface driver zaurus
<6>[ 2.745878] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 2.753215] usbcore: registered new interface driver int51x1
<6>[ 2.758810] usbcore: registered new interface driver kalmia
<6>[ 2.764329] usbcore: registered new interface driver ipheth
<6>[ 2.769857] usbcore: registered new interface driver sierra_net
<6>[ 2.775719] usbcore: registered new interface driver cx82310_eth
<6>[ 2.781672] usbcore: registered new interface driver cdc_ncm
<6>[ 2.787276] usbcore: registered new interface driver qmi_wwan
<6>[ 2.792966] usbcore: registered new interface driver cdc_mbim
<6>[ 2.798619] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<4>[ 2.807410] ehci_rk_probe e34c0000 e34c0010
<6>[ 2.811547] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
<6>[ 2.819016] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 2.827440] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 2.849346] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
<6>[ 2.855910] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 2.862601] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 2.869723] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
<6>[ 2.875973] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 2.881300] usb usb1: SerialNumber: ff500000.usb
<6>[ 2.886256] hub 1-0:1.0: USB hub found
<6>[ 2.889971] hub 1-0:1.0: 1 port detected
<4>[ 2.918224] ehci_rk_probe ok
<6>[ 2.921192] usbcore: registered new interface driver cdc_acm
<6>[ 2.926756] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 2.934702] usbcore: registered new interface driver usblp
<6>[ 2.940135] usbcore: registered new interface driver cdc_wdm
<6>[ 2.945749] usbcore: registered new interface driver usb-storage
<6>[ 2.951710] usbcore: registered new interface driver ums-alauda
<6>[ 2.957558] usbcore: registered new interface driver ums-cypress
<6>[ 2.963515] usbcore: registered new interface driver ums-datafab
<6>[ 2.969459] usbcore: registered new interface driver ums_eneub6250
<6>[ 2.975564] usbcore: registered new interface driver ums-freecom
<6>[ 2.981522] usbcore: registered new interface driver ums-isd200
<6>[ 2.987422] usbcore: registered new interface driver ums-jumpshot
<6>[ 2.993441] usbcore: registered new interface driver ums-karma
<6>[ 2.999229] usbcore: registered new interface driver ums-onetouch
<6>[ 3.005247] usbcore: registered new interface driver ums-sddr09
<6>[ 3.011109] usbcore: registered new interface driver ums-sddr55
<6>[ 3.016979] usbcore: registered new interface driver ums-usbat
<6>[ 3.022797] usbcore: registered new interface driver usbserial
<6>[ 3.028590] usbcore: registered new interface driver usbserial_generic
<6>[ 3.035028] usbserial: USB Serial support registered for generic
<6>[ 3.040975] usbcore: registered new interface driver option
<6>[ 3.046496] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 3.053399] usbcore: registered new interface driver trancevibrator
<6>[ 3.059573] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 3.064485] e3500040
<4>[ 3.066656] Core Release: 3.10a
<4>[ 3.069747] Setting default values for core params
<4>[ 3.074571] Using Buffer DMA mode
<4>[ 3.077860] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.083594] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.089082] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.093366] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 3.097242] Dedicated Tx FIFOs mode
<4>[ 3.100682] pcd_init otg_dev = c59ecb00
<6>[ 3.104592] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 3.109674] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
<6>[ 3.117069] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 3.122758] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 3.129459] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 3.136569] usb usb2: Product: DWC OTG Controller
<6>[ 3.141196] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 3.146778] usb usb2: SerialNumber: ff580000.usb
<6>[ 3.151706] hub 2-0:1.0: USB hub found
<6>[ 3.155430] hub 2-0:1.0: 1 port detected
<6>[ 3.159575] usb20_host: version 3.10a 21-DEC-2012
<4>[ 3.166650] e3580040
<4>[ 3.168805] Core Release: 3.10a
<4>[ 3.171894] Setting default values for core params
<4>[ 3.176720] Using Buffer DMA mode
<4>[ 3.179982] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.185726] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.191205] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.195507] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 3.199300] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 3.204463] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
<6>[ 3.211931] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 3.217756] Init: Power Port (0)
<6>[ 3.220974] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 3.227672] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 3.234781] usb usb3: Product: DWC OTG Controller
<6>[ 3.239408] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 3.244990] usb usb3: SerialNumber: ff540000.usb
<6>[ 3.249862] hub 3-0:1.0: USB hub found
<6>[ 3.253613] hub 3-0:1.0: 1 port detected
<4>[ 3.257984] .. rk pwm remotectl v1.0 init
<4>[ 3.262000] remotectl probe j=0x0
<6>[ 3.265402] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
<4>[ 3.271893] pwm enable val=0x646205
<6>[ 3.275675] usbcore: registered new interface driver xpad
<6>[ 3.281022] usbcore: registered new interface driver usb_acecad
<6>[ 3.286894] usbcore: registered new interface driver aiptek
<6>[ 3.292431] usbcore: registered new interface driver gtco
<6>[ 3.297781] usbcore: registered new interface driver hanwang
<6>[ 3.303390] usbcore: registered new interface driver kbtab
<6>[ 3.308834] usbcore: registered new interface driver wacom
<7>[ 3.314313] of_get_named_gpio_flags exited with status 263
<7>[ 3.314326] of_get_named_gpio_flags exited with status 169
<3>[ 3.335206] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 1
<3>[ 3.371804] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 2
<3>[ 3.401321] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 3
<3>[ 3.430840] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 4
<3>[ 3.460359] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 5
<3>[ 3.489879] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 6
<3>[ 3.519400] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 7
<3>[ 3.548920] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 8
<3>[ 3.578439] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 9
<3>[ 3.607959] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 10
<3>[ 3.636546] synaptics_dsx_i2c 1-0020: synaptics_rmi4_set_input_dev: Failed to query device
<3>[ 3.644676] synaptics_dsx synaptics_dsx.0: synaptics_rmi4_probe: Failed to set up input device
<4>[ 3.653172] synaptics_dsx: probe of synaptics_dsx.0 failed with error -5
<6>[ 3.662240] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
<7>[ 3.670667] of_get_named_gpio_flags exited with status 228
<6>[ 3.672582] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 3.678891] i2c /dev entries driver
<6>[ 3.682961] IR NEC protocol handler initialized
<6>[ 3.687445] IR RC5(x) protocol handler initialized
<6>[ 3.692157] IR RC6 protocol handler initialized
<6>[ 3.696620] IR JVC protocol handler initialized
<6>[ 3.701083] IR Sony protocol handler initialized
<6>[ 3.705632] IR RC5 (streamzap) protocol handler initialized
<6>[ 3.711109] IR SANYO protocol handler initialized
<6>[ 3.715741] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 3.721613] usbcore: registered new interface driver uvcvideo
<6>[ 3.727275] USB Video Class driver (1.1.1)
<4>[ 3.731306] CamSys driver version: v0.23.0, CamSys head file version: v0.9.0
<7>[ 3.739648] of_get_named_gpio_flags exited with status 236
<4>[ 3.739662] D1:camsys_platform_probe(1067): 1-gpios-cifpower: gpio=236
<7>[ 3.746269] of_get_named_gpio_flags exited with status 236
<4>[ 3.746279] D1:camsys_platform_probe(1070): gpios-cifpower: gpio_request
<4>[ 3.753055] D1:camsys_platform_probe(1072): 1-gpios-cifpower: gpio_request=0
<4>[ 3.760172] D1:camsys_platform_probe(1079): gpios-cifpower: 236 high
<4>[ 3.766676] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 3.777496] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe34b8000 size: 0x4000)
<4>[ 3.790254] D1:camsys_platform_probe(1183): ff910000.isp memory:
<4>[ 3.796179] D1:camsys_platform_probe(1193): Register memory (phy: 0xff910000 vir: 0xe3560000 size: 0x10000)
<4>[ 3.806116] D1:camsys_platform_probe(1188): I2c memory (phy: 0x599c000 vir: 0xc599c000 size: 0x1000)
<4>[ 3.815446] D1:camsys_platform_probe(1208): Probe ff910000.isp device success
<4>[ 3.823717] rockchip_temp_probe,line=362
<6>[ 3.882542] tsadc ff280000.tsadc: initialized
<6>[ 3.887173] device-mapper: uevent: version 1.0.3
<6>[ 3.891942] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 3.900521] Bluetooth: HCI UART driver ver 2.2
<6>[ 3.904908] Bluetooth: HCI H4 protocol initialized
<6>[ 3.909619] Bluetooth: HCILL protocol initialized
<4>[ 3.916807] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 3.922059] cpuidle: using governor ladder
<6>[ 3.926089] cpuidle: using governor menu
<6>[ 3.929969] Synopsys Designware Multimedia Card Interface Driver
<6>[ 3.936119] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<6>[ 3.942234] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 3.949228] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<4>[ 3.955665] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
<7>[ 3.961438] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 3.961546] 1390..dw_mci_set_ios: no card. [mmc0]
<4>[ 3.980954] 1390..dw_mci_set_ios: no card. [mmc0]
<4>[ 4.000671] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 4.000692] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 4.000735] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<6>[ 4.001351] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<6>[ 4.031494] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 4.038536] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
<4>[ 4.044922] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
<7>[ 4.050726] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 4.050795] mmc1: no vmmc regulator found
<4>[ 4.054904] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 4.061749] 1390..dw_mci_set_ios: no card. [mmc1]
<4>[ 4.079350] 1390..dw_mci_set_ios: no card. [mmc1]
<6>[ 4.084098] mmc0: BKOPS_EN bit is not set
<6>[ 4.089312] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
<4>[ 4.098995] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<4>[ 4.107469] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
<6>[ 4.107500] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 4.107509] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<6>[ 4.107851] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<6>[ 4.135678] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<6>[ 4.135700] mmc0: new high speed MMC card at address 0001
<6>[ 4.136062] mmcblk0: mmc0:0001 MAG2GA 14.5 GiB
<6>[ 4.136448] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 4.136456] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 4.136464] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 4.136471] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 4.136478] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 4.136485] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 4.136492] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 4.136498] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 4.136506] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 4.136513] system: 0x012400000 – 0x072400000 (1536 MB)
<6>[ 4.136520] metadata: 0x072400000 – 0x073400000 (16 MB)
<6>[ 4.136533] userdata: 0x073400000 – 0x0b3400000 (1024 MB)
<6>[ 4.136567] radical_update: 0x0b3400000 – 0x0b7400000 (64 MB)
<6>[ 4.136587] user: 0x0b7400000 – 0x3a3a00000 (11974 MB)
<6>[ 4.138222] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141390..dw_mci_set_ios: no card. [mmc1]
<4>[ 4.238020] 3379..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<4>[ 4.244350] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
<7>[ 4.250099] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 4.250307] 1390..dw_mci_set_ios: no card. [mmc2]
<4>[ 4.266301] 1390..dw_mci_set_ios: no card. [mmc2]
<4>[ 4.285992] 1390..dw_mci_set_ios: no card. [mmc2]
<6>[ 4.286001] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 4.286007] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<4>[ 4.286189] leds-gpio leds.32: pins are not configured from the driver
<7>[ 4.286199] of_get_named_gpio_flags exited with status 257
<7>[ 4.286204] of_get_named_gpio_flags exited with status 258
<7>[ 4.286212] of_get_named_gpio_flags exited with status 257
<7>[ 4.286266] of_get_named_gpio_flags exited with status 258
<6>[ 4.286347] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 4.287414] usbcore: registered new interface driver usbhid
<6>[ 4.287417] usbhid: USB HID core driver
<6>[ 4.287633] zram: Created 1 device(s) …
<6>[ 4.287882] ashmem: initialized
<6>[ 4.287970] logger: created 256K log ‘log_main’
<6>[ 4.288041] logger: created 256K log ‘log_events’
<6>[ 4.288109] logger: created 256K log ‘log_radio’
<6>[ 4.288178] logger: created 256K log ‘log_system’
<7>[ 4.288865] of_get_named_gpio_flags exited with status 5
<7>[ 4.288870] of_get_named_gpio_flags exited with status 5
<6>[ 4.289052] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input1
<7>[ 4.289482] of_get_named_gpio_flags exited with status 10
<7>[ 4.289490] of_get_named_gpio_flags exited with status 239
<4>[ 4.360009] es8323 probe i2c recv ok
<4>[ 4.363694] i2c-core: driver [ES8323] using legacy suspend method
<4>[ 4.369711] i2c-core: driver [ES8323] using legacy resume method
<3>[ 4.377115] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
<4>[ 4.385442] rockchip_hdmi_spdif_audio_probe() register card failed:-517
<6>[ 4.391961] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
<4>[ 4.400893] es8323_probe
<4>[ 5.044955] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
<3>[ 5.052836] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
<4>[ 5.060737] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
<3>[ 5.069074] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
<4>[ 5.076805] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
<3>[ 5.085001] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
<4>[ 5.093152] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
<3>[ 5.100955] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
<4>[ 5.108824] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
<3>[ 5.116691] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
<4>[ 5.124562] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
<3>[ 5.132937] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
<4>[ 5.141290] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
<3>[ 5.149240] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
<4>[ 5.156871] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
<3>[ 5.164521] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
<4>[ 5.172149] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
<3>[ 5.180541] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
<4>[ 5.188988] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
<3>[ 5.196747] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
<4>[ 5.204504] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
<3>[ 5.212258] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
<4>[ 5.219996] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
<3>[ 5.228749] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
<4>[ 5.237226] dwc_otg_hcd_enable, enable host controller
<4>[ 5.242309] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
<3>[ 5.250260] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
<4>[ 5.258223] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
<3>[ 5.266185] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
<4>[ 5.274142] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
<3>[ 5.282105] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
<4>[ 5.290076] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
<3>[ 5.298027] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
<4>[ 5.306004] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
<3>[ 5.313708] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
<4>[ 5.321415] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
<3>[ 5.329114] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
<4>[ 5.336811] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
<3>[ 5.344940] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
<4>[ 5.345641] Using Buffer DMA mode
<4>[ 5.345645] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 5.345648] Multiprocessor Interrupt Enhancement - disabled
<4>[ 5.345652] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 5.345655] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 5.375551] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
<3>[ 5.383333] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
<4>[ 5.391119] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
<4>[ 5.397971] Init: Power Port (0)
<3>[ 5.402068] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
<4>[ 5.409855] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
<3>[ 5.418148] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
<3>[ 5.426551] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
<3>[ 5.432469] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
<3>[ 5.438297] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
<3>[ 5.444118] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
<3>[ 5.449872] ES8323 2-0010: ASoC: mux Differential Mux has no paths
<6>[ 5.459225] rockchip-es8323 rockchip-es8323.29: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
<6>[ 5.467727] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.29/sound/card0/input2
<6>[ 5.476762] rockchip-hdmi-i2s rockchip-hdmi-i2s.26: rk-hdmi-i2s-hifi ↔ rockchip-i2s.0 mapping ok
<6>[ 5.485952] u32 classifier
<6>[ 5.488624] Actions configured
<6>[ 5.491969] Netfilter messages via NETLINK v0.30.
<6>[ 5.496632] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 5.502863] ctnetlink v0.93: registering with nfnetlink.
<6>[ 5.508137] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 5.514975] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 5.520905] xt_time: kernel timezone is -0000
<6>[ 5.525332] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 5.530657] arp_tables: (C) 2002 David S. Miller
<6>[ 5.535216] TCP: cubic registered
<6>[ 5.538483] Initializing XFRM netlink socket
<6>[ 5.542837] NET: Registered protocol family 10
<6>[ 5.547594] mip6: Mobile IPv6
<6>[ 5.550523] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 5.555924] sit: IPv6 over IPv4 tunneling driver
<6>[ 5.560704] NET: Registered protocol family 17
<6>[ 5.565082] NET: Registered protocol family 15
<5>[ 5.569491] Bridge firewalling registered
<6>[ 5.573433] Ebtables v2.0 registered
<6>[ 5.577056] Bluetooth: RFCOMM TTY layer initialized
<6>[ 5.581863] Bluetooth: RFCOMM socket layer initialized
<6>[ 5.586919] Bluetooth: RFCOMM ver 1.11
<6>[ 5.590601] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 5.595826] Bluetooth: BNEP filters: protocol multicast
<6>[ 5.600962] Bluetooth: BNEP socket layer initialized
<6>[ 5.605844] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 5.611660] Bluetooth: HIDP socket layer initialized
<6>[ 5.616554] l2tp_core: L2TP core driver, V2.0
<6>[ 5.620838] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 5.625549] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 5.630300] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 5.635017] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
<6>[ 5.641856] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 5.648868] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 5.657245] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 5.664518] of_get_named_gpio_flags exited with status 156
<6>[ 5.664523] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 5.673509] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 5.673516] of_get_named_gpio_flags exited with status 158
<6>[ 5.673529] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 5.682584] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 5.687735] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 5.696057] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 5.700707] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 5.705090] of_get_named_gpio_flags exited with status 147
<6>[ 5.705096] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 5.713136] of_get_named_gpio_flags exited with status 155
<6>[ 5.713143] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
<7>[ 5.721089] of_get_named_gpio_flags exited with status 157
<6>[ 5.721094] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<4>[ 5.722631] Indeed it is in host mode hprt0 = 00021501
<7>[ 5.734088] of_get_named_gpio_flags exited with status 154
<6>[ 5.734093] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 5.741954] of_get_named_gpio_flags exited with status 159
<6>[ 5.741958] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 5.750193] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 5.755395] [BT_RFKILL]: ** disable irq
<6>[ 5.759221] [BT_RFKILL]: ap6335 device registered.
<6>[ 5.764670] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<4>[ 5.772234] rk3288_init_suspend
<4>[ 5.775321] rk3288_suspend_init enter
<4>[ 5.779058] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 5.783901] gpio_get_dts_info suspend:4
<4>[ 5.787671] gpio_get_dts_info resume:4
<4>[ 5.791351] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 5.799432] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 5.807448] clks_gating_suspend_init:clkgt info ok
<5>[ 5.812235] Registering SWP/SWPB emulation handler
<6>[ 5.817262] ddrfreq: verion 1.2 20140526
<6>[ 5.821132] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
<6>[ 5.832184] ddrfreq: auto-freq=0
<6>[ 5.835373] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 5.839737] ddrfreq: auto-freq-table[1] 324MHz
<7>[ 5.849246] ddrfreq: change freq to 396 MHz when normal
<6>[ 5.849256] ddrfreq: auto-freq-table[2] 396MHz
<6>[ 5.853633] ddrfreq: auto-freq-table[3] 528MHz
<6>[ 5.858359] regulator-dummy: disabling
<3>[ 5.862320] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
<4>[ 5.870562] rockchip_hdmi_spdif_audio_probe() register card failed:-517
<6>[ 5.877066] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
<4>[ 5.885691] pcd_pullup, is_on 0
<6>[ 5.888808] file system registered
<6>[ 5.892685] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 5.899449] android_usb gadget: Number of LUNs=2
<6>[ 5.899745] usb 3-1: new high-speed USB device number 2 using usb20_host
<4>[ 5.910615] Indeed it is in host mode hprt0 = 00001101
<6>[ 5.910620] lun0: LUN: removable file: (no medium)
<6>[ 5.910626] lun1: LUN: removable file: (no medium)
<6>[ 5.910755] android_usb gadget: android_usb ready
<6>[ 5.929875] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:02 UTC (1293883202)
<6>[ 5.942654] rk_spdif:rk_spdif_init
<6>[ 5.946147] rk_spdif:Entered spdif_probe
<6>[ 5.950226] rk_spdif:spdif:spdif probe ok!
<6>[ 5.954779] usbcore: registered new interface driver snd-usb-audio
<6>[ 5.960873] ALSA device list:
<6>[ 5.960951] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
<6>[ 5.973196] #0: RK_ES8323
<6>[ 5.975946] #1: RK-HDMI-I2S
<6>[ 5.978875] #2: RK-HDMI-SPDIF
<6>[ 5.982287] Freeing unused kernel memory: 592K (c0ae3000 - c0b77000)
<7>[ 5.991936] SELinux: 512 avtab hash slots, 1338 rules.
<7>[ 5.992310] SELinux: 512 avtab hash slots, 1338 rules.
<7>[ 5.992323] SELinux: 1 users, 2 roles, 288 types, 1 bools, 1 sens, 1024 cats
<7>[ 5.992330] SELinux: 84 classes, 1338 rules
<6>[ 5.992970] SELinux: Permission attach_queue in class tun_socket not defined in policy.
<6>[ 6.000959] SELinux: the above unknown classes and permissions will be denied
<7>[ 6.007989] SELinux: Completing initialization.
<7>[ 6.007994] SELinux: Setting up existing superblocks.
<7>[ 6.008007] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 6.008018] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 6.008062] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 6.008071] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 6.008086] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 6.008100] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 6.008251] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 6.012121] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 6.012132] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 6.012140] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 6.012149] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 6.012163] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 6.012210] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 6.012218] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 6.012240] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<6>[ 6.126337] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
<6>[ 6.132940] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 6.139967] usb 3-1: Product: USB 2.0 Hub [MTT]
<6>[ 6.144845] hub 3-1:1.0: USB hub found
<6>[ 6.148638] hub 3-1:1.0: 4 ports detected
<5>[ 6.267618] type=1403 audit(1293883202.850:2): policy loaded auid=4294967295 ses=4294967295
<12>[ 6.275990] SELinux: Loaded policy from /sepolicy
<11>[ 7.001724] init: could not import file ‘/init.usbstorage.rc’ from ‘/init.rc’
<4>[ 7.008833] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<11>[ 7.067764] init: /dev/hw_random not found
<6>[ 7.071908] keychord: using input dev ff680000.pwm for fevent
<6>[ 7.077559] keychord: using input dev rk29-keypad for fevent
<7>[ 7.084116] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 7.084465] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 7.084831] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 7.086003] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 7.086371] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 7.086550] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 7.087610] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 7.089441] SELinux: initialized (dev functionfs, type functionfs), not configured for labeling
<11>[ 7.090152] fs_mgr: parse_link_device : path = NULL
<11>[ 7.094991] fs_mgr: parse_link_device : path = NULL
<11>[ 7.099803] fs_mgr: parse_link_device : path = NULL
<14>[ 7.104687] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 7.123251] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
<6>[ 7.142632] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 7.151652] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<4>[ 7.161306] EXT4-fs (mmcblk0p8): warning: maximal mount count reached, running e2fsck is recommended
<6>[ 7.171242] EXT4-fs (mmcblk0p8): recovery complete
<6>[ 7.176724] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 7.186155] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<4>[ 7.188028] EXT4-fs (mmcblk0p11): warning: maximal mount count reached, running e2fsck is recommended
<6>[ 7.198960] EXT4-fs (mmcblk0p11): recovery complete
<6>[ 7.203758] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 7.213289] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<4>[ 7.260596] EXT4-fs (mmcblk0p12): warning: maximal mount count reached, running e2fsck is recommended
<6>[ 7.271333] EXT4-fs (mmcblk0p12): recovery complete
<6>[ 7.277686] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 7.287189] SELinux: initialized (dev mmcblk0p12, type ext4), uses xattr
<4>[ 7.303516] mali pd enabled
<4>[ 7.306270] clk enabled
<4>[ 7.309872] MALI_DVFS_STEP=5,div_dvfs=7
<6>[ 7.313649] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
<6>[ 7.320680] mali_dvfs_infotbl[1].clock=179000,min_threshold=66,max_threshold=77
<6>[ 7.327909] mali_dvfs_infotbl[2].clock=297000,min_threshold=73,max_threshold=84
<6>[ 7.335095] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
<6>[ 7.342297] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
<3>[ 7.349696] turn on mali power
<6>[ 7.352704] kbase_platform_rk_init,register_reboot_notifier
<6>[ 7.358226] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
<6>[ 7.365021] mali ffa30000.gpu: Probed as mali0
<3>[ 7.370819] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<11>[ 7.392013] init: /dev/hw_random not found
<6>[ 7.405104] binder: 157:157 transaction failed 29189, size 0-0
<11>[ 7.406487] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
<11>[ 7.408971] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
<11>[ 7.465450] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 7.475528] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
<7>[ 7.479631] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<11>[ 7.483223] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 7.491124] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 7.500931] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<11>[ 7.589650] fs_mgr: parse_link_device : path = NULL
<11>[ 7.594533] fs_mgr: parse_link_device : path = NULL
<11>[ 7.599367] fs_mgr: parse_link_device : path = NULL
<4>[ 7.615212] phy_power_on: enable = 1
<11>[ 7.652449] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
<4>[ 7.658215] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 7.658232] eth0: device MAC address 8a:ff:6a:68:aa:07
<6>[ 7.662174] libphy: stmmac: probed
<6>[ 7.662182] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
<6>[ 7.662188] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
<11>[ 7.687247] init: powerctl: cannot expand ‘${sys.powerctl}’
<11>[ 7.692943] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
<11>[ 7.703814] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
<11>[ 7.714159] init: property ‘sys.sysctl.tcp_def_init_rwnd’ doesn’t exist while expanding ‘${sys.sysctl.tcp_def_init_rwnd}’
<11>[ 7.725033] init: cannot expand ‘${sys.sysctl.tcp_def_init_rwnd}’ while writing to ‘/proc/sys/net/ipv4/tcp_default_init_rwnd’
<3>[ 7.737155] android_usb: already disabled
<6>[ 7.743444] read descriptors
<6>[ 7.746303] read strings
<4>[ 7.748839] pcd_pullup, is_on 1
<4>[ 8.436346] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 8.443734] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 8.451153] D1:camsys_open(717): camsys_marvin(de10ed10) is opened!
<7>[ 8.457367] of_get_named_gpio_flags exited with status 237
<7>[ 8.457377] of_get_named_gpio_flags exited with status 237
<4>[ 8.457384] rockchip_gpio_request:GPIO7-13
<4>[ 8.461445] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 8.465989] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 8.471840] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 8.478532] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 8.489069] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 8.495849] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
<7>[ 8.522733] ddrfreq: change freq to 528 MHz when isp
<4>[ 8.522815] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 8.530795] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 8.535778] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 8.540757] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<3>[ 8.550080] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<3>[ 8.558439] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 8.566697] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 8.577204] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
<3>[ 8.583534] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 8.590791] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 8.598125] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<7>[ 8.621265] ddrfreq: change freq to 396 MHz when normal
<4>[ 8.621300] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 8.627947] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 8.636756] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 8.645174] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 8.653386] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 8.660871] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 8.668334] D1:camsys_release(741): camsys_marvin(de10ed10) is closed
<4>[ 8.684953] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 8.692310] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 8.699692] D1:camsys_open(717): camsys_marvin(de10ed10) is opened!
<7>[ 8.705924] of_get_named_gpio_flags exited with status 237
<7>[ 8.705933] of_get_named_gpio_flags exited with status 237
<7>[ 8.705940] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 8.705949] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 8.710487] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 8.716324] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 8.722998] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 8.733538] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 8.740307] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
<7>[ 8.768994] ddrfreq: change freq to 528 MHz when isp
<4>[ 8.769066] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 8.777038] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 8.782018] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 8.786947] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<3>[ 8.796224] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<3>[ 8.804576] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 8.812816] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 8.823251] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
<3>[ 8.830740] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
<3>[ 8.837083] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 8.844313] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 8.851547] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<7>[ 8.867519] ddrfreq: change freq to 396 MHz when normal
<4>[ 8.867570] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 8.874214] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 8.883026] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 8.891432] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 8.899643] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 8.907115] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 8.914570] D1:camsys_release(741): camsys_marvin(de10ed10) is closed
<4>[ 8.930429] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 8.937810] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 8.945197] D1:camsys_open(717): camsys_marvin(de10ed10) is opened!
<4>[ 8.951530] D1:camsys_extdev_register(230): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 8.961483] D1:camsys_extdev_register(230): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 8.971416] D1:camsys_extdev_register(230): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 8.981366] of_get_named_gpio_flags exited with status 237
<7>[ 8.981376] of_get_named_gpio_flags exited with status 237
<7>[ 8.981384] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 8.981393] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 8.985935] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 8.991790] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 8.998466] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 9.009003] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 9.015784] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<7>[ 9.048058] ddrfreq: change freq to 528 MHz when isp
<4>[ 9.048126] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 9.056103] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 9.061117] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 9.066027] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 9.075322] D1:camsys_sysctl_extdev(335): Sysctl 11 success, gpio(11) set 1
<4>[ 9.083243] D1:camsys_sysctl_extdev(339): Sysctl 8 success, gpio(79) set 1
<4>[ 9.091072] D1:camsys_sysctl_extdev(339): Sysctl 7 success, gpio(78) set 1
<3>[ 9.101111] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
<3>[ 9.108628] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
<4>[ 9.114970] D1:camsys_sysctl_extdev(335): Sysctl 7 success, gpio(78) set 0
<4>[ 9.121773] D1:camsys_sysctl_extdev(335): Sysctl 8 success, gpio(79) set 0
<4>[ 9.128581] D1:camsys_sysctl_extdev(339): Sysctl 11 success, gpio(11) set 0
<7>[ 9.163019] ddrfreq: change freq to 396 MHz when normal
<4>[ 9.163067] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 9.169707] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 9.178555] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 9.186963] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 9.195176] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.202643] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.210096] D1:camsys_release(741): camsys_marvin(de10ed10) is closed
<4>[ 9.218648] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 9.226073] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 9.233433] D1:camsys_open(717): camsys_marvin(de10ed10) is opened!
<4>[ 9.239677] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 9.246647] D1:camsys_extdev_register(255): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
<7>[ 9.277961] ddrfreq: change freq to 528 MHz when isp
<4>[ 9.278015] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<6>[ 9.286017] rk3288-lcdc lcdc0: blank mode:0
<4>[ 9.286025] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 9.286131] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 9.286167] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<3>[ 9.287247] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<3>[ 9.288317] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 9.289386] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 9.330063] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
<3>[ 9.330108] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 9.330114] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 9.330118] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<7>[ 9.360079] ddrfreq: change freq to 396 MHz when normal
<4>[ 9.375619] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 9.382245] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<11>[ 9.385862] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
<4>[ 9.398255] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 9.406689] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 9.414932] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.422378] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.429837] D1:camsys_release(741): camsys_marvin(de10ed10) is closed
<6>[ 10.479489] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
<6>[ 11.597465] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[ 11.602606] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[ 11.608000] libphy: stmmac-0:01 - Link is Up - 100/Full
<6>[ 11.695924] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
<6>[ 12.798078] binder: send failed reply for transaction 295 to 461:464
<6>[ 12.804552] e4262234,e4262234,e4262234
<6>[ 12.876757] binder: undelivered death notification, 00000000b762dd98
<6>[ 12.876837] e429c234,e429c234,e429c234
<11>[ 13.191590] init: untracked pid 482 exited
<14>[ 66.445074] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 125.484927] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 184.524851] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 243.564842] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 302.604902] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 361.644849] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 420.684908] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 479.724908] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 538.764905] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 597.804853] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 656.844900] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<14>[ 715.884912] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
应该是上电时序不对,检查一下屏datasheet上电部分
