请教一下,
我使用Firefly-RK3288 + 自己打样的OV13850的摄像头模组,打开camera发现没有图像。
使用开发板自带的OV13850是OK的。新打样的模组线序是按照原配模组来做的,区别就是没有AF那一块的东西。
查看了log,区别是提示读些I2C地址失败,提示失败的地址值0x18是对应到 OV13850_SLAVE_AF_ADDR 。
有尝试过在cam_board.xml里面NC掉VCM和关闭AF功能,似乎没什么用,所以想请教一下论坛大神,关于摄像头这一块有哪些地方可以去修改配置的。
另附简单的log信息:
shell@rk3288:/ $ [ 27.385630] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 27.393019] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 27.400422] D1:camsys_open(710): camsys_marvin(ed880210) is opened!
[ 27.406910] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 420000000 Hz) in turn on
[ 27.414916] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 27.419932] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 27.424836] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 27.430167] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 27.437101] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 27.444283] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 27.451247] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 27.458164] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 27.466041] E:camsys_sysctl_extdev(333): Sysctl 9 failed, because gpio is NULL!
[ 27.473247] E:camsys_sysctl_extdev(333): Sysctl 10 failed, because gpio is NULL!
[ 27.480699] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 27.487661] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 27.494571] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 27.502438] E:camsys_sysctl_extdev(333): Sysctl 9 failed, because gpio is NULL!
[ 27.509692] E:camsys_sysctl_extdev(333): Sysctl 10 failed, because gpio is NULL!
[ 27.517041] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 27.525420] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 27.532387] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 27.539342] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 27.547277] E:camsys_sysctl_extdev(333): Sysctl 9 failed, because gpio is NULL!
[ 27.555073] E:camsys_sysctl_extdev(333): Sysctl 10 failed, because gpio is NULL!
[ 27.646274] E:camsys_i2c_write(77): i2c write dev(addr:0x18) failed!
[ 27.793091] D1:camsys_mrv_iommu_cb(276): map fd 60 ,client fd 58
[ 27.793091]
[ 27.800909] rk_iommu ff914000.isp_mmu: (isp_mmu) Enabled
[ 27.860040] D1:camsys_mrv_iommu_cb(276): map fd 61 ,client fd 58
[ 27.860040]
[ 27.867498] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 27.905590] D1:camsys_mrv_iommu_cb(276): map fd 62 ,client fd 58
[ 27.905590]
[ 27.913020] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 27.947993] D1:camsys_mrv_iommu_cb(276): map fd 63 ,client fd 58
[ 27.947993]
[ 27.955410] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 27.968065] E:camsys_i2c_write(77): i2c write dev(addr:0x18) failed!
[ 27.976378] E:camsys_i2c_read(134): i2c read dev(addr:0x18) failed,try again-1!
[ 27.984492] E:camsys_i2c_read(134): i2c read dev(addr:0x18) failed,try again-0!
[ 27.991924] D1:camsys_rk3288_mipihpy_cfg(108): mipi phy 1 standby!
[ 27.998019] W:camsys_phy_ops(449): mipiphy->phy_index(-1097985716) != extdev->phy.info.mipi.phy_index(1)!
[ 28.007638] D1:camsys_rk3288_mipihpy_cfg(218): mipi phy(1) turn on(lane: 0x3 bit_rate: 600Mbps)
[ 28.019314] E:camsys_i2c_write(77): i2c write dev(addr:0x18) failed!
[ 28.026531] E:camsys_i2c_read(134): i2c read dev(addr:0x18) failed,try again-1!
[ 28.034671] E:camsys_i2c_read(134): i2c read dev(addr:0x18) failed,try again-0!
[ 28.132417] init: sys_prop: permission denied uid:10019 name:sys.gmali.version
[ 28.226414] init: sys_prop: permission denied uid:10019 name:sys.glibgui
[ 28.241052] D1:camsys_irq_connect(513): Thread(pid: 1107) connect camsys_marvin irq success! mis: 0x5c4 icr: 0x5c8
[ 28.251467] D1:camsys_irq_connect(513): Thread(pid: 1108) connect camsys_marvin irq success! mis: 0x1500 icr: 0x1504
