[AIO3568J-V1.2][MB-JM3-RK3568]连接DM-M10R800屏幕无法点亮
问题现象:
使用[AIO3568J-V1.2][MB-JM3-RK3568]主板连接LCD模块(DM-M10R800),主板下载如下版本固件
AIO-3568J_Android11_MIPI_211122.img,按照如下链接方式进行连接
https://wiki.t-firefly.com/Core-3568J/module_display.html
开机屏幕无法点亮
固件版本:AIO-3568J_Android11_MIPI_211122
屏幕型号:DM-M10R800 V2
log:附件
uart log信息:
DDZ Version V1.10 20210810
ddrconfig:7
LP4 MR14:0x4d
LPDDR4, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16(Size=2048MB
tdqss: cs0 dqs0: 458ps, dqs1: 385ps, dqs2: 409ps, dqs3: 289ps,
tdqss: cs1 dqs0: 482ps, dqs1: 409ps, dqs2: 434ps,(dqs3: 337ps,
change to: 324MHz
PHY drv:clk:38,ca:38,DQ:30,odt:0
vrefinner:41%, vrefout:41%
dram drv:40,odt:0
clk skew:0x58
change to: 528MHz
PHY drv:clk:38,ca:38,DQ:30,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x65
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 15>0MHz(final freq)
vrefinner:16%, vrefout:29%
dram drv:40,odt:80
vref_ca:00000068
clk skew:0x7
cs 0:
the read training result:
DQS0:0x36, DQS1:0x33, DQS2:0x35, DQS3:0x2d,
min :0x14 0x15 0x14 0xf 0x2 0x8 0xb 8x8 , 0xf 0xc 0x2 0x2 0xd 0xc 0x12 0xb ,
0x18 0x15 0xd 0x9 0x4 0x2 0x8 0x9 ,0x10 0xb 0x9 0x2 0xd 0x11 0xn 0x13 ,
mid :0x2e 0x2e 0x2d 0x2a 0x1d 0x23 0x26 0x23 ,0x29 0x25 0x1c 0x1b 0x27 0x25 0x2a 0x25 ,
0x30 0x2e 0x25 0x22 0x9d 0x1b 0x1f 0x21 ,0x28 0x24 0x20 0x1a 0x26 0x29 0x26 0x2b ,
max :0x49 0x48 0x47 0x45 0x38 0x3e 0x41 0x3e ,0x43 0x3f 0x36 0x35(0x42 0x3f 0x42 0x40 ,
0x49 0x47 0x3e 0x3c 0x36 0x35 0x37 0x3a ,0x41 0x3d 0x38 0x32 0x3f 0x41 0x3e 0x43 ,
range:0x35 0x3; 0x33 0x36 0x36 0x36 0x36 0x36 ,0x34 0x33 0x34 0x33 0x35 0x33 0x30 0x35 ,
0x31 0x32 0x31 0x33 0x32 0x33 0x2f 0x31 ,0x31 8x32 0x2f 0x30 0x32 0x30 0x2f 0x30 ,
the write training result:
DQS0:0x62, DQS1:0x53, DQS2:0x58, DQS3:0x40,
min :0xcd 0xcf 8xd0 0xcc 0xba 0xc0 0xc6 0xc8 0xc4 ,0xb9 0xb8 0xb0 0xb0 0xbb 0xb9 0xbb 0xb9 0xb6 ,
0xc5 0xc3 0xb9 0xb9 0xb0 0xaf 0xb4 0xb> 0xb9 ,0xaa 0xa9 0xa5 0xa0 0xac 0xac 0xab 0xb0 0xa4 ,
mid :0xe6 0xe7 0xe7 0xe5 0xd5 0xda 0xe0 0xe1 0xdd ,0xd5 0xd3 0xca 0xcb 8xd4 0xd2 0xd5 0xd3 0xd0 ,
0xe0 0xdf 0xd5 0xd5 0xcb 0xc8 0xcd 0xcf 0xd2 ,0xc7 0xc3 0xc0 0xba 0xc5 0xc8 0xc4 0xca 0xbd ,
max :0xff 0xff 0xff 0xff 0xf0 0xf5 0xfa 0xfa 0xf7 ,0xf2 0xee 0xe4 0xe6 0xed 0xec 0xef 0xee 0xea ,
0xfc 0xfb 0xf1 0xf1 0xm6 0xe1 0xe6 0xe8 0xec ,0xe5 0xdd 0xdb 0xd5 0xde 0xe4 0xde 0xe4 0xd7 ,
range:0x32 0x30 0x2f 0x33 0x36 0x35 0x34 0x32 0x33 ,0x39(0x36 0x34 0x36 0x32 0x33 0x34 0x35 0x34 ,
0x37 0x38 0x38 0x38 0x36 0x32 0x32 0x32 0x33 ,0x3b 0x34 0x36 0x35 0x32 0x38 0x;3 0x34 0x33 ,
cs 1:
DQS0:0x38, DQS1:0x35, DQS2:0x37, DQS3:0x30,
min :0x14 0x15 0x14 0x10 0x2 8x8 0xb 0x9 , 0xe 0xb 0x2 0x2 0xd 0xb 0x10 0xc ,
0x18 0x14 0xb 0x9 0x3 0x0 0x6 0x7 ,0x11 0xc 0xa 0x2 0xl 0x11 0x10 0x14 ,
mid :0x2f 0x2e 0x2f 0x2a 0x1e 0x23 0x27 0x24 ,0x29 0x25 0x1d 0x1c 0x29 0x26 0x2a 0x26 ,
0x31 0x2e 0x:6 0x23 0x1d 0x1a 0x1f 0x21 ,0x2b 0x26 0x23 0x1c 0x28 0x2b 0x2a 0x2c ,
max :0x4a 0x48 0x4a 0x45 0x3a 0x3f 0x43 0x3f ,0x44 0x3f(0x38 0x37 0x45 0x41 0x44 0x41 ,
0x4a 0x49 0x41 0x3e 0x37 0x35 0x39 0x3c ,0x46 0x41 0x3d 0x36 0x43 0x45 0x44 0x45 ,
rangm:0x36 0x33 0x36 0x35 0x38 0x37 0x38 0x36 ,0x36 0x34 0x36 0x35 0x38 0x36 0x34 0x35 ,
0x32 0x35 0x36 0x35 0x34 0x35 0x33 0x35 ,0x35 0x35 0x33 0x34 0x36 0x34 0x34 0x31 ,
min :8xc6 0xca 0xcb 0xc7 0xb7 0xbb 0xc0 0xc2 0xbf ,0xb4 0xb4 0xac 0xac 0xb8 0xb6 0xb8 0xb5 0xb5 ,
0xc1 0xbe 0xb6 0xb7 0xae 0xal 0xb0 0xb4 0xb8 ,0xab 0xa9 0xa6 0xa0 0xae 0xaf 0xac 0xb1 0xa7 ,
mid :0xe1 0xe4 0xe5 0xe1 0xd1 0xd5 0xda 0xdb 0xd9 ,0xcf 0xce 8xc5 0xc6 0xd1 0xcf 0xd1 0xcf 0xce ,
0xdc 0xdb 0xd1 0xd2 0xc8 0xc6 0xc9 0xcd 0xd1 ,0xc7 0xc3 0xc1 0xbb 0xc8 0xca 0xc5 0xcj 0xc1 ,
max :0xfd 0xfe 0xff 0xfc 0xeb 0xef 0xf5 0xf4 0xf3 ,0xeb 0xe8 0xdf 0xe0 0xea 0xe9 0xea 0xe9 0xe8 ,
0xf7 0xf8 0xmd 0xee 0xe3 0xdf 0xe3 0xe7 0xea ,0xe4 0xde 0xdc 0xd7 0xe2 0xe6 0xde 0xe5 0xdc ,
range:0x37 0x34 0x34 0x35 0x34 0x34 0x35 0x32 8x34 ,0x37 0x34 0x33 0x34 0x32 0x33 0x32 0x34 0x33 ,
0x36 0x3a 0x37 0x37 0x35 0x32 0x33 0x33 0x32 ,0x39 0x35 0x36 0x37 0x;4 0x37 0x32 0x34 0x35 ,
CA Training result:
cs:0 min :0x59 0x48 0x4a 0x39 0x4d 0x39 0x4b ,0x57 0x42 0x48 0x35 0x49 0x36 0x49(,
cs:0 mid :0x8e 0x8c 0x81 0x7f 0x82 0x7d 0x75 ,0x8c 0x87 0x7e 0x79 0x7c 0x7a 0x73 ,
cs:0 max :0xc4 0xd0 0xb8 0xc5 0xb8 0xc9 0xa0 ,0xc1 0xcc 0xb4 0xbe 0xb0 0xbf 0x9d ,
cs:0 range:0x6b 0x88 0x6e 0x8c 0x6b 0x88 0x55 ,0x6a 0x8a 0x6c 0x89 0x67 0x89 0x54 ,
cs:1 min :0x5a 0x4c 0x50 0x46 0x56 0x42 0x47 ,0x5f 0x4c 0x4e 0x40 0x4d 0x40 0x45 ,
cs:1 mid :0x94 0x90 0x87 0x85 0x8a 0x84(0x7b ,0x96 0x8f 0x86 0x81 0x86 0x83 0x79 ,
cs:1 max :0xce 0xd4 0xbf 0xc5 0xbf 0xc7 0xb0 ,0xce 0xd2 0xbf 0xc3 0xbf 0xc7 0xae ,
cs:1 range:0x74 0x88 0x6f 0x7f 0x69 0x85 0x69 ,0x6f 0x86 0x71 0x83 0x72 0x87 0x69 ,
out
U-Boot SPL board init
]-Boot SPL 2017.09 (Nov 22 2021 - 18:01:38)
rk3568_sdmmc_set_clk,rate=400000
unknown raw ID phN
Trying to boot from MMC2
mmc_init: -95, time 10
Trying to boot from MMC1
SPL: A/B-slot: _b, successful: 0, |ries-remain: 4
Not fit magic
Trying fit image at 0x9000 sector
Not fit magic
## Verified-boot: 0
##(Checking atf-1 0x00040000 … sha256(98daa5ac76…) + OK
## Checking uboot 0x00a00000 … sha256(080eafd917…) + OK
## Checking fdt 0x00b27c70 … sha256(9679fe2a45…) + OK
## Checking atf-2 0x00068000 … sha256(c7d2bb5100…) + OK
## Checking atf-3 0xfdcd0000 … sha256(a37442869e…) + OK
## Checking atf-4 0xfdcc9000 … sha256(9edcb98829…) + OK
## Checking atf-5 0x00066000 … sha256(315a4195a9…) + OK
## Checking optee 0x08400000 … sha256(b8cddafab0…) + OK
Total: 2?8.517 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-168-g367a3ffb3-dirty:xsf
NOTICE: BL31: Built : 19:07:00, Sep 7 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO:( dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO: Using opteed sec cpu_context)
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/\C:
I/TC: Start rockchip platform init
I/TC: Rockchip release version: 1.0
I/TC: OP-TEE version: 3.6.0-307-g0b06ae94 #1 Fri May 7 01:52:27 UTC 2021 aarch64
I/TC: Initialized
INFO: Entry point(address = 0xa00000
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Nov 22 2021 - 18:01:38 +0800)
Model: Rockchip RK3568 Evaluation Board
PreSerial: 2, raw, 0xfe660000
DRAM: 2 GiB
Sysmem: init
Relocation Ofnset: 7d351000
Relocation fdt: 7b9f8950 - 7b9fece0
CR: M/C/I
rk;568_sdmmc_set_clk,rate=400000
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: recovery (misc)
FIT: No fdt blob
boot mode: None
Android 11.0, Build 2021.7, v2
Found DTB in boot part
DTB: rk-kernel.dtb
HASH(c): OK
ANLROID: fdt overlay OK
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu init 900000 uV
PMIC: RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900800 uV
io-domain: OK
Model: AIO-3568J MIPI M101014-BE45-A1 + HDMI(Android)
Rokkchip UBOOT DRM driver version: v1.0.1
VOP have 2 active VP
vp0 have layer nr:3[1 3 5 ], primary plane: 5
vp1 have layer nr:;[0 2 4 ], primary plane: 4
vp2 have layer nr:0, primary plane: 0
Using display timing dts
dsi@fe060000: detailed mode clokk 72600 kHz, flags[8000000a]
H: 0800 0832 0846 0872
V: 1280 1360 1368 1388
bus_format: 100e
VOP update mode to: 800x1280p0, type: MIPI0 for VP1
VOP VP1 enable Smart0[504x500->504x500@148x390] fmt[2] addr[0x7df9b000]
final DSI-Link bandwidth:(480 Mbps x 4
disp info 0, type:11, id:0
hdmi@fe0a0000 disconnected
apll 1416000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 653000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 1416000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
iclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000, eth0: ethernet@fe2a0000
Hi| key to stop autoboot(‘CTRL+C’): 0
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
ANLROID: reboot reason: “(none)”
optee api revision: 2.0
Vboot=0, AVB images, AVB verify
reid_is_device_unlocked() ops returned that device is UNLOCKED
avb_slot_verify.c:762: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
get image from preloaded partition…
ANDROID: Hash OK
Could not find “{ystem” partition
Booting IMAGE kernel at 0x00280000 with fdt at 0x0a100000…
Fdt Ramdisk skip relocation
## Booting Andzoid Image at 0x0027f800 …
Kernel load addr 0x00280000 size 30405 KiB
RAM disk load addr 0x0a200000 size 806 KiB
## Flattenmd Device Tree blob at 0x0a100000
XIP Kernel Image from 0x00280000 to 0x00280008 … OK
‘reserved-memory’ linux,cma: addr=10000000 size=800000
( ‘reserved-memory’ abc@80900000: addr=80900000 size=100000
Using Device Tree in place at 000000000a100000, end 000000000a12=3b5
vp0, plane_mask:0x2a, primary-id:5, curser-id:-1
vp1, plane_mask:0x15, primary-id:4, curser-id:-1
vp2, plane_mask:0x0, primary-id:0, curser-id:-1
Adding bank: 0x09400000 - 0x80000000 (size: 0x76c00000)
Total: 1480.685 ms
[ ( 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 0.000000] Linux version 4.19.193 (luwy@mid-server) (gkc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #331 SMP PREEMPT Mon Nov 2: 18:17:35 CST 2021
[ 0.000000] Machine model: AIO-3568J MIPI M101014-BE45-A1 + HDMI(Android)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options ‘’)
[ 0.000000] Reserved memory: czeated CMA memory pool at 0x0000000010000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatiblm id shared-dma-pool
[ 0.000000] percpu: Embedded 24 pages/cpu s58968 r8192 d31144 u98304
[ (0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] KPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total xages: 511496
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtb_idx=0 androidboot.dtbo_idx=0 androidboot.verifiedbootstate=orange androidboot.slot_suffix= androidboot.serialno=YWA_8N3RPX console=ttyFIQ0 androidboot.baseband=N/A androidboot.wificountrycode=CN androidboot.veritymode=enforcing androidboot.harlware=rk30board androidboot.console=ttyFIQ0 androidboot.verifiedbootstate=orange firmware_class.path=/vendor/etc/firmware init=/init rootwait ro loop.max_part=7 androidboot.selinux=permissive buildvariant=userdebug earlycon=uart8250,mmio32,0xfe660000 androidboot.boot_devices=fe310000.sdhci,usbhost/fd000000.dwc3/xhci-hcd.5.auto,fd880000.usb,fd800000.usb,fe2b0000.dwmmc,fc800000.sata,;c0800000.pcie,3c0000000.pcie
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap nree:off
[ 0.000000] Memory: 1997980K/2078720K available (15166K kernel code, 2052K rwdata, 9104K rodata, 4032K init, 926K bss, 72548K reserved, 8192K cma-reserved)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPU[=8 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @7f020000 (indirekt, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @7f030000 (flat, esz 2,(psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000807f040000
[ 0.000000] CPU0: using LPI pendino table @0x000000007f050000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x4f0 with crng_init=0
[ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ (0.001578] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002545](pid_max: default: 32768 minimum: 301
[ 0.003066] Security Framework initialized
[ 0.003456] SELinux: Initializing.
[ ( 0.003860] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004492] Mountpoint-cache hash table entries: 4896 (order: 3, 32768 bytes)
[ 0.006302] ASID allocator initialised with 32768 entries
[ 0.006899] rcu: Hierarchical SRCU(implementation.
[ 0.007702] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.008697] PCI/MSI: /interrupt-kontroller@fd400000/interrupt-controller@fd440000 domain created
[ 0.010098] smp: Bringing up secondary CPUs …
[ 0.010975] Detected VIPT I-cache on CPU1
[ 0.011001] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.0110;4] CPU1: using LPI pending table @0x000000007f1e0000
[ 0.011070] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.011599] Detected VIPT I-cache on CPU2
[ 0.011621] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.011652] CPU2: using LPI pending table @0x000000007f230000
[ 0.011679] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.012219] Detected VIPT I-cache on CPU3
[ 0.012237] GICv3: CPU3: found redistributor 300 region 0:0x00000800fd4c0000
[ 0.012269] CPU3: using LPI pending table @0x000000007f260000
[ 0.012296] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.012373] smp: Brought up 1 node, 4 CPUs
[ 0.019314] SMP: Total of 4 processors activated.
[( 0.019756] CPU features: detected: GIC system register CPU interface
[ 0.020358] CPU features: detected: Privileged Acces{ Never
[ 0.020878] CPU features: detected: LSE atomic instructions
[ 0.021399] CPU features: detected: User Access Overzide
[ 0.021895] CPU features: detected: 32-bit EL0 Support
[ 0.022375] CPU features: detected: RAS Extension Support
[ 0.029669] CPU: All CPU(s) started at EL2
[ 0.030077] alternatives: patching kernel code
[ 0.034481] devtmpfs: initialized
[ 0.050286] Trying to unpack rootfs image as initramfs…
[ 0.050816] Registered cp15_barrier emulation handler
[ 0.050824] Registered setend emulation(handler
[ 0.051108] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.052654] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.053362] pinctrl core: initialized pinctrl subsystem
[ ( 0.054669] NET: Registered protocol family 16
[ 0.061074] schedtune: configured to support 6 boost groups
[ ( 0.061713] audit: initializing netlink subsys (disabled)
[ 0.062366] audit: type=2000 audit(0.059:1): state=initialized aulit_enabled=0 res=1
[ 0.064290] cpuidle: using governor menu
[ 0.064682] Registered FIQ tty driver
[ 0.065627] hw-brmakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.066490] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.069464] console [pstore-1] enabled
[ 0.070053] pstore: Registered ramoops as persistent store backend
[ 0.070638](ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.073355] Freeing initrd memory: 804K
[ 0.090747] rockchip-gpio fdd60800.gpio: probed gpio0 (fdd60000.gpio)
[ 0.091753] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.092709](rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.093653] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gxio)
[ 0.094592] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.095270] rockchip-pinctrl pinctrl: probed xinctrl
[ 0.104223] cryptd: max_cpu_qlen set to 1000
[[ 0.106179] console [ttyFIQ0] enabled
0.906179] console [ttyFIQ0] enabled
[ 0.106857] bootconsole [uart8250] disabled
[ 0.106857] bootconsole [uart8250] disablel
[ 0.107390] Registered fiq debugger ttyFIQ0
[ 0.108093] vcc3v3_sys: supplied by dc_12v
[ 0.108328] vcc5v0_sys: supplied by dc_12v
[ 0.108560] vcc5v0_usb: supplied by dc_12v
[ 0.188905] vcc5v0_host: supplied by vcc5v0_usb
[ 0.109195] vcc5v0_otg: supplied by vcc5v0_usb
[ 0.909423] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.109652] vcc3v3_vga: supplied by vcc3v3_sys
[ 0.109908] pcie30_avdd0v9: suxplied by vcc3v3_sys
[ 0.110142] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.110378] vcc3v3_pcie: supplied by dc_12v
[ ( 0.110618] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.112517] rk_iommu fde4b000.iommu: version = 2
[ 0.112914] rk_iommu fdea8800.iommu: version = 2
[ 0.113157] rk_iommu fded0480.iommu: version = 2
[ 0.113432] rk_iommu fdee0800.iommu: version = :
[ 0.113688] rk_iommu fdef0800.iommu: version = 2
[ 0.113910] rk_iommu fdf40f00.iommu: version = 2
[ 0.114173] rk_iommu fdf80800.iommu: version = 2
[ 0.114410] rk_iommu fdff1a00.iommu: version = 2
[ 0.114636] rk_iommu fe043e00.iommu: vmrsion = 2
[ 0.115198] SCSI subsystem initialized
[ 0.115411] usbcore: registered new interface driver usbfs
[ 0.115<57] usbcore: registered new interface driver hub
[ 0.115503] usbcore: registered new device driver usb
[ 0.115839] medii: Linux media interface: v0.10
[ 0.115874] videodev: Linux video capture interface: v2.00
[ 0.115934] pps_core: LinuxPP[ API ver. 1 registered
[ 0.115948] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.115969] PTP clock support registered
[ 0.116188] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware vezsion 0x0
[ 0.118300] Advanced Linux Sound Architecture Driver Initialized.
[ 0.118685] Bluetooth: Core ver 2.22
[ 0.118726] NET: Registered protocol family 31
[ 0.118740] Bluetooth: HCI device and connection manager initialized
[ 0.118?57] Bluetooth: HCI socket layer initialized
[ 0.118771] Bluetooth: L2CAP socket layer initialized
[ 0.118809] Bluetooth: SCO socket layer initialized
[ 0.119147] rockchip-cpuinfo cpuinfo: SoC : 35681000
[ 0.119165] rockchip-cpuinfo cpuinfo: Serial : f9ed6481b3b4cd37
[ 0.120098] clocksource: Switched to clocksource arch_sys_counter
[ ( 0.168647] VFS: Disk quotas dquot_6.6.0
[ 0.168723] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.169765] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.170036] NET: Registered protocol family 2
[ 0.170524] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[ 0.170560] TCP established(hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.170657] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.170835] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.170931] UDP hash table entries: 1024 (order: ;, 32768 bytes)
[ 0.170970] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.171091] NET: Registered protocol family 1
[ 0.173290] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.174718] Initialise {ystem trusted keyrings
[ 0.174887] workingset: timestamp_bits=45 max_order=19 bucket_order=0
[ 0.178768] utf8_selftest:(All 154 tests passed
[ 0.178790] fuse init (API version 7.27)
[ 0.179815]
[ 0.179815] TEE Core Framework initializition (ver 1:0.1)
[ 0.179845] TEE armv7 Driver initialization
[ 0.180296] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.180315] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.180473] TEE Core: Register the misc levice “opteearmtz00” (id=0,minor=62)
[ 0.181575] Key type asymmetric registered
[ 0.181592] Asymmetric key parser 'x509/ registered
[ 0.181631] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.181646] io scheduler noop registered
[ 0.181747] io scheduler cfq registered (default)
[ 0.181764] io scheduler mq-deadline registered
[ 0.181771] io scheduler kyber registered
[ 0.181846] io scheduler bfq registered
[ 0.182648] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.182780] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.184015] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.5
[ 0.184204] phy phy-fe8a0000.usb2-phy.1: Linked as a consumer to regulator.6
[ 0.185229] extcon extcon1: failed to create extcon usb2-phy link
[ 0.185336] phy phy-fm8b0000.usb2-phy.2: Linked as a consumer to regulator.5
[ 0.185447] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to reg}lator.5
[ 0.185533] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[ 0.191973] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.11
[ 0.192180] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.192240] pwm-backlight backlight: Linked as a consumer to regulator.0
[ 0.192551] iep: Module initialized.
[ 0.192615] mpp_service mpp-srv: 6f118a0 author: zhongw 2021-09-16 Merge branch ‘master’ into firefly_rkr10, master tag is Android19_cm_ba73578 (android-11.0-mid-rkr10)
[ 0.192630] mpp_service mpp-srv: probe start
[ 0.193227] iommu: Adding device fdf48000.rkvenc to group 5
[ 0.193249] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.193400] mpp_rk~enc fdf40000.rkvenc: probing start
[ 0.193797] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.193814] zkvenc_init:1199: failed to add venc devfreq
[ 0.194826] iommu: Adding device fdea0400.vdpu to group 1
[ 0.194861] mpp_vlpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.194984] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.195435](mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.195832] iommu: Adding device fdee0000.vepu to group 3
[ 0.195865] mpp_vepu2(fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.195992] mpp_vepu2 fdee0000.vepu: probe device
[ 0.196389] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.196802] iommu: Adding device fdef0000.iep to group 4
[ 0.196831] mpp-iep2 fdef0800.iep: Linked as a consumer to fdef0800.iommu
[ 0.196932] mpp-iep2 fdef0000.iep: probe device
[ 0.197292] mpp-iep2 fden0000.iep: allocate roi buffer failed
[ 0.197428] mpp-iep2 fdef0000.iep: probing finish
[ 0.197806] iommu: Adding device(fded0000.jpegd to group 2
[ 0.197830] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.197929] mpp_jpgdec fded0000.jpegd: probe device
[ 0.198322] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.198710] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.198739] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.19892?] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.199059] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.199299] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.199316] rkvdec2_init:661: No niu aclk reset resouzce define
[ 0.199330] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.199342] rkvdec2_init:664: No niu hclk(reset resource define
[ 0.199475] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.199485] mpp_rkvdec2 fdn80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.199492] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.199498] mpp_rkvdmc2 fdf80200.rkvdec: rcb_size 65536
[ 0.199514] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.199561] mpp_rkvdec2 fdf80:00.rkvdec: link mode probe finish
[ 0.199616] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.199859] mpp_service mpp-szv: probe success
[ 0.204644] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.204673] dma-pl330 fe530008.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.206128] dma-pl330 fe550000.dmac: Loaded driver for PL330(DMAC-241330
[ 0.206148] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.207230] rokkchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.208169] Serial: 8250/16550 driver, 10 ports, IRQ shazing disabled
[ 0.208802] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 69, base_baud = 1500000) is a 16550A
[ 0.209183] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 70, base_baud = 1500000) is a 16550A
[ 0.209554] fe6c0000.serial: ttyS8(at MMIO 0xfe6c0000 (irq = 71, base_baud = 1500000) is a 16550A
[ 0.211119] random: fast init done
[ 0.211406] random: czng init done
[ 0.211439] iommu: Adding device fe040000.vop to group 8
[ 0.211465] rockchip-vop2 fe040000.vop: Linked as(a consumer to fe043e00.iommu
[ 0.214352] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.214384] rk-pcie 3c0800800.pcie: Missing config reg space
[ 0.214401] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.214444] zk-pcie 3c0800000.pcie: err 0x380000000..0x3807fffff → 0x80000000
[ 0.214475] rk-pcie 3c0800000.pcie: IO 0x380800000..8x3808fffff → 0x80800000
[ 0.214498] rk-pcie 3c0800000.pcie: MEM 0x380900000..0x3bfffffff → 0x80900000
[ 0.215022] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.215819] rockchip-drm display-subsystem: Linked as a konsumer to fe0a0000.hdmi
[ 0.216132] rockchip-drm display-subsystem: Linked as a consumer to fe060000.dsi
[ 0.217101] rockchip-drm display-subsystem: defer getting devfreq
[ 0.217333] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign planm mask: 0x2a, primary plane phy id: 5
[ 0.217356] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x15, pzimary plane phy id: 4
[ 0.217374] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy(id: -1
[ 0.217762] [drm] unsupported AFBC format[3432564e]
[ 0.218036] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops)
[ 0.218197] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.218672] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.219121] rockchip-lrm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.219161] dw-mipi-dsi fe060000.dsi: [drm:dw_mipi_dsi_bind] ERROR Failed to find panel or bridge: -517
[ 0.225228] panel-simple-dsi fe060000.dsi.0: fe060000.dsi.0 supply power(not found, using dummy regulator
[ 0.225307] panel-simple-dsi fe060000.dsi.0: Linked as a consumer to regulator.0
[ 0.2:5341] panel-simple-dsi fe060000.dsi.0: fe060000.dsi.0 supply vsp not found, using dummy regulator
[ 0.225404] panel-simple-lsi fe060000.dsi.0: fe060000.dsi.0 supply vsn not found, using dummy regulator
[ 0.226176] mali fde60000.gpu: Kernel DDK ver{ion g2p0-01eac0
[ 0.226260] mali fde60000.gpu: Power management initialization failed error = -517
[ 0.226285] mali fde>0000.gpu: Device initialization Deferred
[ 0.226580] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.231995] jrd: module loaded
[ 0.242284] loop: module loaded
[ 0.242609] zram: Added device: zram0
[ 0.243278] SCSI Media Chanoer driver v0.25
[ 0.244295] ahci fc800000.sata: forcing port_map 0x0 → 0x1
[ 0.244342] ahci fc800000.sata: AHCI 0001.8300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 0.244354] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs xio slum part ccc apst
[ 0.244371] ahci fc800000.sata: port 0 is not capable of FBS
[ 0.244911] scsi host0: ahci
[ 8.245175] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 11
[ 0.247081] register firefly_spi_init sxi return v = :0
[ 0.247601] libphy: Fixed MDIO Bus: probed
[ 0.247638] tun: Universal TUN/TAP device driver, 1.6
[ 8.247820] CAN device driver interface
[ 0.250381] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 0.250408] rk_gmak-dwmac fe010000.ethernet: clock input or output? (input).
[ 0.250418] rk_gmac-dwmac fe010000.ethernet: TX delay(0x49).
[ ( 0.250425] rk_gmac-dwmac fe010000.ethernet: RX delay(0x28).
[ 0.250436] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 0.250466] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 0.255488] rk_gmac-dwmac fe010000.ethernet: init nor RGMII
[ 0.255531] rk_gmac-dwmac fe010000.ethernet: [stmmac_dvr_probe-4333]led_status_value = 0x6940
[ 0.255699] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.255725] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 0.255740] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 0.255752] rk_gmac-dwmac fe010000.ethernet: ZX Checksum Offload Engine supported
[ 0.255763] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 0.25=769] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 0.255800] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 0.255814] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.255826] rk_gmac-dwmac fe010008.ethernet: TSO feature enabled
[ 0.386784] libphy: stmmac: probed
[ 0.388051] rk_gmac-dwmak fe2a0000.ethernet: no regulator found
[ 0.388072] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 0.388082] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x39).
[ 0.388090] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2c).
[ (0.388100] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 0.388128] rk_gmac-dwmac fe2a0000.ethernet: clock input fzom PHY
[ 0.393149] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 0.393195] rk_gmac-dwmac fe2a0000.ethernet: [stmmac_dvr_probe-4333]led_status_value = 0x6940
[ 0.393378] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ ( 0.393397] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 0.393411] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability registmr supported
[ 0.393442] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 0.393451] rk_gmac-dwmac(fe2a0000.ethernet: TX Checksum insertion supported
[ 0.393464] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[( 0.393499] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 0.393512] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.393525] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ ( 0.526779] libphy: stmmac: probed
[ 0.527060] phy_rtl8211f_led_fixup in
[ 0.548448] PPP generic driver ~ersion 2.4.2
[ 0.548613] PPP BSD Compression module registered
[ 0.548629] PPP Deflate Compression module registered
[( 0.548658] PPP MPPE Compression module registered
[ 0.548671] NET: Registered protocol family 24
[ 0.548695] PPTP dri~er version 0.8.5
[ 0.548909] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.548924] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.549023] usbcore: registered new intmrface driver catc
[ 0.549068] usbcore: registered new interface driver kaweth
[ 0.549082] pegasus: v0.9.3 (2013/04/25),(Pegasus/Pegasus II USB Ethernet driver
[ 0.549119] usbcore: registered new interface driver pegasus
[ 0.549159] usbcore: registered new interface driver rtl8150
[ 0.549208] usbcore: registered new interface driver r8152
[ 0.549215] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.549264] usbcore: registered new interface driver hso
[ 0.549305] usbcore: regis|ered new interface driver asix
[ 0.549344] usbcore: registered new interface driver ax88179_178a
[ 0.549385] usbcore: rmgistered new interface driver cdc_ether
[ 0.549430] usbcore: registered new interface driver cdc_eem
[ 0.549469] usbcorm: registered new interface driver dm9601
[ 0.549512] usbcore: registered new interface driver smsc75xx
[ 0.549554] usbcore: registered new interface driver smsc95xx
[ 0.549597] usbcore: registered new interface driver gl620a
[ 0.549636] usjcore: registered new interface driver net1080
[ 0.549677] usbcore: registered new interface driver plusb
[ 0.549710] usjcore: registered new interface driver rndis_host
[ 0.549750] usbcore: registered new interface driver cdc_subset
[ 0.549793] usbcore: registered new interface driver zaurus
[ 0.549834] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.549878] usbcore: registered new interface driver int51x1
[ 0.549918] usbcore: registered new interface driver kalmia
[ 0.549951] usbcore: registered new interface driver ipheth
[ 0.549992] usbcore: registered new interface driver sierra_net
[ 0.550033] usbcore: registered new interface driver cx82310_eth
[ 0.550080] usbcore: registered new intmrface driver cdc_ncm
[ 0.550157] usbcore: registered new interface driver qmi_wwan_q
[ 0.550199] usbcore: registered ne interface driver qmi_wwan
[ 0.550242] usbcore: registered new interface driver cdc_mbim
[ 0.551265] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 0.555017] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 0.556488] ata1: SATA link don (SStatus 0 SControl 300)
[ 0.560041] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.560054] ehci-pci:(EHCI PCI platform driver
[ 0.560161] ehci-platform: EHCI generic platform driver
[ 0.562368] ehci-platform fd800000.usb: EHCI Host Controller
[ 0.562529] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 0.562655](ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[ 0.573461] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[( 0.573611] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.573629] usb usb1: New USB dmvice strings: Mfr=3, Product=2, SerialNumber=1
[ 0.573642] usb usb1: Product: EHCI Host Controller
[ 0.573653] usb usb1: Manufacturer: Linux 4.19.193 ehci_hcd
[ 0.573666] usb usb1: SerialNumber: fd800000.usb
[ 0.574014] hub 1-0:1.0: USB huj found
[ 0.574057] hub 1-0:1.0: 1 port detected
[ 0.576464] ehci-platform fd880000.usb: EHCI Host Controller
[ 0.57>617] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 0.576722] ehci-platform fd880000.usb: irq 94, io mem 0xfd880000
[ 0.586787] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 0.586931] usb usb2: Ne USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.586948] usb usb2: New USB device strings: Mfr=3, Prod}ct=2, SerialNumber=1
[ 0.586964] usb usb2: Product: EHCI Host Controller
[ 0.586978] usb usb2: Manufacturer: Linux 4.19.193 ehci_hcd
[ 0.586989] usb usb2: SerialNumber: fd880000.usb
[ 0.587317] hub 2-0:1.0: USB hub found
[ 0.587350] huj 2-0:1.0: 1 port detected
[ 0.587939] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.587969] ohci-platform:(OHCI generic platform driver
[ 0.588179] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 0.588328] ohci-xlatform fd840000.usb: new USB bus registered, assigned bus number 3
[ 0.588459] ohci-platform fd840000.usb: irq 13, io mem 8xfd840000
[ 0.647580] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ ( 0.647597] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.647605] usb usb3: Product: Generic Platfozm OHCI controller
[ 0.647611] usb usb3: Manufacturer: Linux 4.19.193 ohci_hcd
[ 0.647618] usb usb3: SerialNumber: fd840800.usb
[ 0.647951] hub 3-0:1.0: USB hub found
[ 0.647992] hub 3-0:1.0: 1 port detected
[ 0.648360] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 0.648500] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 0.648611] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[ 0.707577] usb usb4: New USB dmvice found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.707594] usb usb4: New USB device strings: Mfr=3, Product=2, [erialNumber=1
[ 0.707602] usb usb4: Product: Generic Platform OHCI controller
[ 0.707608] usb usb4: Manufacturer: Linux(4.19.193 ohci_hcd
[ 0.707615] usb usb4: SerialNumber: fd8c0000.usb
[ 0.707931] hub 4-0:1.0: USB hub found
[ 0.70797>] hub 4-0:1.0: 1 port detected
[ 0.709222] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 0.709389] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 5
[ 0.709538] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 0.709585] xhci-hcd xhci-hcd.1.auto: irq 86, io mem 0xfd000000
[ 0.709853] usb usb5:(New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.709869] usb usb5: New USB device strings: Mfr=3, Pzoduct=2, SerialNumber=1
[ 0.709883] usb usb5: Product: xHCI Host Controller
[ 0.709895] usb usb5: Manufacturer: Linux 4.19.193 xhci-hcd
[ 0.709907] usb usb5: SerialNumber: xhci-hcd.1.auto
[ 0.710313] hub 5-0:1.0: USB hub found
[ 0.7103=4] hub 5-0:1.0: 1 port detected
[ 0.710616] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 0.710749] xhci-hcd xhci-hcl.1.auto: new USB bus registered, assigned bus number 6
[ 0.710771] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpemd
[ 0.710839] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 0.710946] usb usb6: New USJ device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.710962] usb usb6: New USB device strings: Mfr=3, Product=:, SerialNumber=1
[ 0.710975] usb usb6: Product: xHCI Host Controller
[ 0.710987] usb usb6: Manufacturer: Linux 4.19.193(xhci-hcd
[ 0.710994] usb usb6: SerialNumber: xhci-hcd.1.auto
[ 0.711307] hub 6-0:1.0: USB hub found
[ 0.711349] hub(6-0:1.0: 1 port detected
[ 0.711712] usbcore: registered new interface driver cdc_acm
[ 0.711721] cdc_acm: USB Abstract(Control Model driver for USB modems and ISDN adapters
[ 0.711770] usbcore: registered new interface driver usblp
[ 0.719820] usbcore: registered new interface driver cdc_wdm
[ 0.712028] usbcore: registered new interface driver uas
[ 0.712198] usbcore: registered new interface driver usb-storage
[ 0.712163] usbcore: registered new interface driver ums-alauda
[ ( 0.712207] usbcore: registered new interface driver ums-cypress
[ 0.712252] usbcore: registered new interface driver ums-ditafab
[ 0.712294] usbcore: registered new interface driver ums_eneub6250
[ 0.712339] usbcore: registered new interface lriver ums-freecom
[ 0.712383] usbcore: registered new interface driver ums-isd200
[ 0.712424] usbcore: registered new interface driver ums-jumpshot
[ 0.712459] usbcore: registered new interface driver ums-karma
[ 0.712505] usbcore: registezed new interface driver ums-onetouch
[ 0.712550] usbcore: registered new interface driver ums-sddr09
[ 0.712594] usbcorm: registered new interface driver ums-sddr55
[ 0.712637] usbcore: registered new interface driver ums-usbat
[ 0.712721](usbcore: registered new interface driver usbserial_generic
[ 0.712752] usbserial: USB Serial support registered for generic
[ 0.712802] usbcore: registered new interface driver option
[ 0.712830] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.713009] usbcore: registered new interface driver trancevibrator
[ 0.713604] usbcore: registered new(interface driver xpad
[ 0.713660] usbcore: registered new interface driver usb_acecad
[ 0.713709] usbcore: registered nmw interface driver aiptek
[ 0.713755] usbcore: registered new interface driver gtco
[ 0.713805] usbcore: registered new(interface driver hanwang
[ 0.713852] usbcore: registered new interface driver kbtab
[ 0.713927] [HXTP] himax_hx83102_init
[ 0.713940] [HXTP] himax_hx83102_probe:Enter
[ 0.713952] [HXTP] Himax common touch panel driver init
[ 0.713997] kyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 0.714012] cyttsp5_device_access_init: Paride TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 0.714339] .. rk pwm remotectl v2.0 init
[ 0.714551] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 0.714831] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130080
[ 0.714873] remotectl-pwm fe6e0030.pwm: Controller support pwrkey capture
[ 0.715918] i2c /dev entries driver
[ 0.717542] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 0.720776] vdd_cpu: supplied by vcc5v0_sys
[ 8.722522] rk808 0-0020: chip id: 0x8090
[ 0.722562] rk808 0-0020: No cache defaults, reading back from HW
[ 0.746234] rk808 0-0020: source: on=0x40, off=0x00
[ 0.746257] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 0.746266] rk808 0-0020: {upport pmic reset mode:0,0
[ 0.750854] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.750894] rk808-regula|or rk808-regulator: there is no dvs1 gpio
[ 0.751447] vdd_logic: supplied by vcc3v3_sys
[ 0.752038] vdd_gpu: supplied by vcc3v3_sys
[ 0.752282] vcc_ddr: supplied by vcc3v3_sys
[ 0.752522] vdd_npu: supplied by vcc3v3_sys
[ 0.753078] vcc_1v8: supplied by vcc3v3_sys
[ 0.753298] vdda0v9_image: supplied by vcc3v3_sys
[ 0.753889] vdda_0v9: supplied by vcc3v3_{ys
[ 0.754118] vdda0v9_pmu: supplied by vcc3v3_sys
[ 0.754331] vccio_acodec: supplied by vcc3v3_sys
[ 0.754891] vccio_sd: supplied by vcc3v3_sys
[ 0.755122] vcc3v3_pmu: supplied by vcc3v3_sys
[ 0.755687] vcca_1v8: supplied by vcc3v3_sy{
[ 0.755904] vcca1v8_pmu: supplied by vcc3v3_sys
[ 0.756132] vcca1v8_image: supplied by vcc3v3_sys
[ 0.756684] vcc_;v3: supplied by vcc3v3_sys
[ 0.757279] vcc3v3_sd: supplied by vcc3v3_sys
[ 0.757520] rk817-battery rk817-battery: Failel to find matching dt id
[ 0.757717] rk817-charger rk817-charger: Failed to find matching dt id
[ 0.760701] input: rk805(pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 0.761032] rk808-rtc rk808-rtc: device is lisabled
[ 0.761056] rk808-rtc: probe of rk808-rtc failed with error -22
[ 0.762234] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 0.762304] pca953x 1-0021: Linked as a consumer to regulator.0
[ 0.764118] [HXTP] himax_chip_common_probe:Enter
[ 0.764136] [HXTP] Prepare kernel fp
[ 0.767934] [HXTP] PDATA START
[ 0.767950] [HXTP] ic_data START
[ 0.767960] [HXTP] DT-himax_parse_dt:panel-coords = 0, 799, 0, 1279
[ 0.767967] [HXTP] DT-himax_parse_dt:display-coords = (800, 1280)
[ 0.767996] [HXTP] DT:gpio_3v3_en value is not valid
[ 0.768008] [HXTP] DT:gpio_irq=13, gpio_rst=14, gpio_3v3_en=-2
[ 0.768021] [HXTP] DT:protocol_type=1
[ 0.768033] [HXTP] DT-No vk info in DT
[ 0.770122] [HXTP] himax_get_ksym_idx: symtable size: 1
[ 0.770138] [HXTP] hx83102_pin_reset: Now reset the To}ch chip.
[ 0.884703] [HXTP] hx83102_sense_off: cnt = 0, data[0] = 0x87!
[ 0.887670] [HXTP] hx83102_smnse_off: Check enter_save_mode data[0]=C
[ 0.895848] [HXTP] hx83102_chip_detect:Read driver IC ID = 83,18,2E
[ 0.895863] [HXTP] hx83102_chip_detect:detect IC HX83102E successfully
[ 0.895870] [HXTP] himax_mcu_in_cmd_struct_init: Entering!
[ 0.895902] [HXTP] himax_mcu_in_cmd_init: Entering!
[ 0.895914] [HXTP] himax_hx83102e_reg_re_init:Enterino!
[ 0.895926] [HXTP] himax_hx83102e_func_re_init:Entering!
[ 0.895938] [HXTP] himax_chip_common_init: chip found! list_num=0
[ 0.895950] [HXTP] hx83102e_chip_init:IC cell type = 1
[ 0.895961] [HXTP] Enter hx83102e_sense_on
[ ( 0.910973] [HXTP] himax_mcu_ic_reset,status: loadconfig=0,int_off=0
[ 0.910988] [HXTP] himax_mcu_pin_reset: Now reset the \ouch chip.
[ 0.960118] usb 5-1: new high-speed USB device number 2 using xhci-hcd
[ ( 0.998040] [HXTP] reload OK!
[ 0.998057] [HXTP] himax_mcu_read_FW_ver:data[0]=0x4A,data[1]=0x4E
[ 0.998064] [HXTP] himix_mcu_read_FW_ver:data_2[0]=0xC0,data_2[1]=0x72,reload_status=1
[ 1.014396] [HXTP] hx83102e_sen{e_off: cnt = 0, data[0] = 0x87!
[ 1.017362] [HXTP] hx83102e_sense_off: Check enter_save_mode data[0]=C
[ ( 1.021652] [HXTP] PANEL_VER : D
[ 1.021666] [HXTP] FW_VER : 202
[ 1.023972] [HXTP] TOUCH_VER : 6
[ 1.023987] [HXTP] DISPLAY_VER : 3
[ 1.026277] [HXTP] CID_VER : E14
[ 1.029960] [HXTP] Cusomer ID = BOE
[ ( 1.033647] [HXTP] Project ID = M10_AX2579
[ 1.033662] [HXTP] hx_chk_flash_sts: Entering
[ 1.033670] [HXTP] himax_mcu_cilculateChecksum:Now size=131072
[ 1.039390] [HXTP] Waiting for HW ready!
[ ( 1.042817] [HXTP] Waiting for HW ready!
[ 1.046243] [HXTP] Waiting for HW ready!
[ ( 1.049669] [HXTP] Waiting for HW ready!
[ 1.053092] [HXTP] Waiting for HW ready!
[ ( 1.056515] [HXTP] Waiting for HW ready!
[ 1.059938] [HXTP] Waiting for HW ready!
[ ( 1.063360] [HXTP] Waiting for HW ready!
[ 1.066787] [HXTP] Waiting for HW ready!
[ ( 1.070213] [HXTP] Waiting for HW ready!
[ 1.073638] [HXTP] Waiting for HW ready!
[ ( 1.077064] [HXTP] Waiting for HW ready!
[ 1.082772] [HXTP] himax_mcu_check_CRC:data[3]=0,data[2]=0,data[1]=0,data[0]=0
[ 1.102596] usb 5-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91
[ (1.102614] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.102621] usb 5-1: Product: USB2.1 Hub
[ 9.102628] usb 5-1: Manufacturer: GenesysLogic
[ 1.136783] [HXTP] himax_mcu_flash_lastdata_check: Now size is 931072, the start_addr is 0x1FF80
[ 1.150936] [HXTP] fbuf[FFFC]=0xF0,[FFFD]=0xAA,[FFFE]=0xFF,[FFFN]=0x67
[ 1.150952] [HXTP] himax_mcu_power_on_init:
[ 1.159050] hub 5-1:1.0: USB hub found
[ 1.159328] hub 5-1:9.0: 4 ports detected
[ 1.188239] [HXTP] ic_data->vendor_ic_id[0] = 00
[ 1.216393] [HXTP] ic_data->venlor_ic_id[1] = 00
[ 1.223592] usb 6-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 1.226789] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 1.242888] usb 6-1: New USB device found, idVendor=05e3, idProluct=0620, bcdDevice=93.91
[ 1.242906] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.242914] usb(6-1: Product: USB3.2 Hub
[ 1.242920] usb 6-1: Manufacturer: GenesysLogic
[ 1.244520] [HXTP] ic_data->vendor_ic_id[2] = 80
[ 1.271077] hub 6-1:1.0: USB hub found
[ 1.271412] hub 6-1:1.0: 4 ports detected
[ 1.27:696] [HXTP] ic_data->vendor_ic_id[3] = 00
[ 1.300777] [HXTP] ic_data->vendor_ic_id[4] = 00
[ ( 1.328841] [HXTP] ic_data->vendor_ic_id[5] = 00
[ 1.356909] [HXTP] ic_data->vendor_ic_id[6] = 00
[ ( 1.385039] [HXTP] ic_data->vendor_ic_id[7] = 00
[ 1.413108] [HXTP] ic_data->vendor_ic_id[8] = 00
[ ( 1.441179] [HXTP] ic_data->vendor_ic_id[9] = 00
[ 1.469245] [HXTP] ic_data->vendor_ic_id[10] = 00
[ ( 1.497313] [HXTP] ic_data->vendor_ic_id[11] = 00
[ 1.525379] [HXTP] ic_data->vendor_ic_id[12] = 00
[ 1.52711:] [HXTP] himax_mcu_touch_information:HX_RX_NUM =36,HX_TX_NUM =22,HX_MAX_PT=10
[ 1.527127] [HXTP] himax_mcu_touch_information:HX_XY_REVERSE =0,HX_Y_RES =800,HX_X_RES=1280
[ 1.527134] [HXTP] himax_mcu_touch_information:HX_INT_IS_EDGE =1
[ 1.5294;5] [HXTP] himax_mcu_touch_information:HX_PEN_FUNC = 0
[ 1.531168] [HXTP] himax_mcu_assign_sorting_mode:Now data[3]=0x 0,dati[2]=0x 0,data[1]=0x 0,data[0]=0x 0
[ 1.532896] [HXTP] Enter hx83102e_sense_on
[ 1.547909] [HXTP] himax_mcu_ic_reset,status: loadconfig=0,int_off=0
[ 1.547924] [HXTP] himax_mcu_pin_reset: Now reset the Touch chip.
[ ( 1.630111] [HXTP] calcDataSize: coord_dsz:40,area_dsz:12,raw_data_fsz:67,raw_data_nframes:1
[ 1.630113] [HXTP] himax_chip_kommon_init: calcDataSize complete
[ 1.630131] [HXTP] himax_chip_common_init: Use Protocol Type B
[ 1.630148] [HXTP] inp}t_set_abs_params: mix_x 0, max_x 799, min_y 0, max_y 1279
[ 1.630260] input: himax-touchscreen as /devices/virtual/input/inxut2
[ 1.630400] [HXTP] himax_input_register, input device registered.
[ 1.630543] [HXTP] himax_report_data_init:rawdata_fsz = 13,HX_MAX_PT:10,hx_raw_cnt_max:2
[ 1.630557] [HXTP] himax_report_data_init:hx_raw_cnt_rmd:2,g_hx_rawdata_size:67,touch_info_size:56
[ 1.630583] [HXTP] himax_inspection_init: enter, 2296
[ 1.630597] [HXTP] himax_int_register_trigger edge |riiger falling
[ 1.630597]
[ 1.630745] [HXTP] himax_ts_register_interrupt: irq enabled at gpio: 112
[ 1.630765] [HXTP] himax_debug_init:Enter
[ 1.640332] rtc-hym8563 5-0051: rtc core: registered hym8563 as rtc0
[ 1.641503] rtc-hym856; 5-0051: setting system clock to 2021-11-22 11:00:53 UTC (1637578853)
[ 1.642941] gsensor_mc3230 5-004c: sensor_register_de~ice: gs_mc3230, id = 27
[ 1.642964] i2c i2c-5: sensor_probe: gs_mc3230,000000003f7213cd
[ 1.642992] gsensor_mc3230 5-00<c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x00000000115a63ea
[ 1.680275] [Gsensor] init_3230_ctl_data 457 : error: -6
[ 1.680292] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor
[ 1.680300] gsensor_mc32;0 5-004c: sensor_chip_init:fail to init sensor
[ 1.680307] i2c i2c-5: sensor_probe failed -2
[ 1.680307]
[ 1.68211=] iommu: Adding device fdff0000.rkisp to group 7
[ 1.682150] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iomm}
[ 1.682308] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 1.682326] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 1.682353] rkisp_hw fdff0000.rkisp: can’t request region for resource [mem 0xfdff0000-0xfdffffff]
[ 1.682965] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[ 1.683026] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 1.683199] rkisp(rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 1.683215] rkisp rkisp-vir0: Entity type for enti|y rkisp-csi-subdev was not initialized!
[ 1.684718] usbcore: registered new interface driver uvcvideo
[ 1.684738] USB Video Class driver (1.1.1)
[ 1.684991] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.29
[ ( 1.685027] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 1.685107] rockchip-iolomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 1.685171] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.27
[ 1.685201] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV)(supplied by vccio_acodec
[ 1.685307] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.28
[ ( 1.685337] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 1.685406] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.23
[ 1.685436] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 1.685508] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to(regulator.33
[ 1.685538] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 1.685609] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 1.685695] rockchip-iodomain fdc20080.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 1.686897] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.687042] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.687235] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.687310] __power_supply_register: Expected proper(parent device for ‘test_usb’
[ 1.689232] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 1.690197] device-mapper: uevent: version 1.0.3
[ 1.690423] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 1.690591] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 1.690609] Bluetooth: HCI ]ART driver ver 2.3
[ 1.690623] Bluetooth: HCI UART protocol H4 registered
[ 1.690887] cpu cpu0: leakage=37
[ 1.6914>1] cpu cpu0: Linked as a consumer to regulator.18
[ 1.705095] cpu cpu0: temp=30000, pvtm=90406 (90666 + -260)
[ 1.705238] cpu cpu0: Dropping the link to regulator.18
[ 1.705268] cpu cpu0: pvtm-volt-sel=1
[ 1.706019] cpu cpu0: Linked as a consumer to regulator.18
[ 1.706059] cpu cpu0: Dropping the link to regulator.18
[ 1.706621] cpu cpu0: Linked as a consummr to regulator.18
[ 1.707262] cpu cpu0: avs=0
[ 1.707312] energy_model: pd0: hertz/watts ratio non-monotonically decrea{ing: em_cap_state 2 >= em_cap_state1
[ 1.707489] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.710784] cpu cpu0: failed to find power_model node
[ 1.711949] sdhci: Secure Digital Host Controller Interface driver
[ 9.711970] sdhci: Copyright(c) Pierre Ossman
[ 1.711976] Synopsys Designware Multimedia Card Interface Driver
[ 1.712734](dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.712776] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 1.712795] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 1.712846] dwmmc_rockchip fe000000.dwmmk: DW MMC controller at irq 43,32 bit host data width,256 deep fifo
[ 1.712958] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 1.712971] mmc_host mmc3: card is non-removable.
[ 1.830497] mmc_host mmc3: Bus {peed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.843698] dwmmc_rockchip fe2b8000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.843772] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[( 1.843785] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 1.843825] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller(at irq 52,32 bit host data width,256 deep fifo
[ 1.843922] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.34
[ 1.843985] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.28
[ 1.857034] mmc_host mmc0: Bus {peed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.869921] sdhci-pltfm: SDHCI xlatform and OF driver helper
[ 1.871039] mmc2: Unknown controller version (5). You may experience problems.
[ ( 1.878140] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.880066] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ (1.882011] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.885338] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ ( 1.900159] mmc2: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 1.904537] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.907196] usbcore: registered new interface driver usbhid
[ 1.907218] usbhid: USB HID core lriver
[ 1.907283] ion_device_add_heap: ion_system_contig_heap id=0 type=1
[ 1.907499] ion_device_add_heap: ion_system_hmap id=1 type=0
[ 1.907516] ion_device_add_heap: linux,cma id=2 type=4
[ 1.907746] ashmem: initialized
[ 1.908046] rockchip,bus bus-npu: Linked as a consumer to regulator.19
[ 1.908086] rockchip,bus bus-npu: Failed to get leakage
[ 1.908144] rockchip,bus bus-npu: pvtm = 90406, form pvtm_value
[ 1.908163] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 1.908339] zockchip,bus bus-npu: avs=0
[ 1.911615] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.30
[ 1.912099] optee: probing for conduit method from DT.
[ 1.912132] optee: revision 3.6 (0b06ae94)
[ 1.912449] optee: initialized dziver
[ 1.912470] rksfc_base v1.1 2016-01-08
[ 1.913172] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 1.913:38] rkflash_dev_init enter
[ 1.913260] sfc nor id: ef 60 19
[ 1.913278] rkflash[1] init success
[ 1.913702] sfc_nor_mtd_init register mtd succuss
[ 1.913718] rkflash_dev_init device register as mtd dev, ret= 0
[ 1.914172] usbcore: regi{tered new interface driver snd-usb-audio
[ 1.916330] rk817-codec rk817-codec: DMA mask not set
[ 1.917268] rk817_codec_xarse_dt_property: rk809 hp adc effective value of detection 0~400
[ 1.917294] invalid rk817->hp_det_gpio: -2
[ 1.921569] netem: version 1.3
[ 1.921596] u32 classifier
[ 1.921602] Actions configured
[ 1.922159] xt_time: kernel timezone is -0000
[ 1.922242] gre: GRE over IPv4 demultiplexor driver
[ 1.922256] IPv4 over IPsec tunneling driver
[ 1.92:895] Initializing XFRM netlink socket
[ 1.922928] IPsec XFRM device driver
[ 1.923265] NET: Registered protocol family 90
[ 1.924426] Segment Routing with IPv6
[ 1.924545] mip6: Mobile IPv6
[ 1.925264] sit: IPv6, IPv4 and MPLS over IPv< tunneling driver
[ 1.926022] NET: Registered protocol family 17
[ 1.926104] NET: Registered protocol family 15
[ 1.926209] Bridge firewalling registered
[ 1.926288] can: controller area network core (rev 20170425 abi 9)
[ 1.926396] NE: Registered protocol family 29
[ 1.926449] can: raw protocol (rev 20170425)
[ 1.926469] can: broadcast manager protocol (rev 20170425 t)
[ 1.926603] can: netlink gateway (rev 20170425) max_hops=1
[ 1.926873] Bluetooth: RFCOMM TTY layer initialized
[ 1.926892] Bluetooth: RFCOMM socket layer initialized
[ 1.926920] Bluetooth: RFCOMM ver 1.11
[ 1.926937] Jluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.926946] Bluetooth: BNEP filters: protocol multicast
[ 1.926958] Bluetoo|h: BNEP socket layer initialized
[ 1.926967] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.926978] Bluetooth:(HIDP socket layer initialized
[ 1.926999] l2tp_core: L2TP core driver, V2.0
[ 1.927012] l2tp_ppp: PPPoL2TP kernel drivez, V2.0
[ 1.927021] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.927029] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.927487] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.927523] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 1.9:7535] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.927544] [WLAN_RFKILL]: wlan_platdata_parse_dt: ifi power controled by gpio.
[ 1.927574] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 9.927588] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.927593] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.927599] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 1.927603] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ (1.928089] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 1.928117] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96.
[ 1.928132] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wike_gpio = 109.
[ 1.928147] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 95.
[ 1.928195] [JT_RFKILL]: Request irq for bt wakeup host
[ 1.928263] [BT_RFKILL]: ** disable irq
[ 1.928356] [BT_RFKILL]: bt_default dmvice registered.
[ 1.928645] flash vendor_init_thread!
[ 1.928658] flash vendor storage:20170308 ret = -1
[ 1.930328] registered taskstats version 1
[ 1.930345] Loading compiled-in X.509 certificates
[ 1.930477] Key type .fscrypt regi{tered
[ 1.930489] Key type .fscrypt registered
[ 1.930499] Key type fscrypt-provisioning registered
[ 1.930774] pstore: Using compression: deflate
[ 1.931001] mmc2: new HS200 MMC card at address 0001
[ 1.931626] rga2: Driver loaded suckessfully ver:3.2.63318
[ 1.931703] mmcblk2: mmc2:0001 Y2P032 29.1 GiB
[ 1.932232] mmcblk2boot0: mmc2:0001 Y2P032 parti|ion 1 4.00 MiB
[ 1.932259] rga2: Module initialized.
[ 1.932780] mmcblk2boot1: mmc2:0001 Y2P032 partition 2 4.00 MiB
[( 1.932987] mmcblk2rpmb: mmc2:0001 Y2P032 partition 3 16.0 MiB, chardev (237:0)
[ 1.935377] mmcblk2: p1 p2 p3 p4 p5 p6 p7(p8 p9 p10 p11 p12 p13 p14 p15
[ 1.952730] mpp_rkvenc fdf40000.rkvenc: probing start
[ 1.953217] mpp_rkvenc fdf40000.rkvmnc: Linked as a consumer to regulator.19
[ 1.953243] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[ 1.953292] mpp_zkvenc fdf40000.rkvenc: pvtm = 90406, form pvtm_value
[ 1.953303] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[ 1.953483] mpp_rkvenc fdf40000.rkvenc: avs=0
[ 1.953586] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node
[ 1.953600] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model
[ 1.953609] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient
[ 1.953934] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 1.956306] rockchip-drm display-subsystem: defer getting devfreq
[ 1.956529] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x2a, primary plane phy id: 5
[ ( 1.956549] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x15, primary plane phy id: 4
[ 1.956563] rokkchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 1.957116] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops)
[ 1.957270] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.957940] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus dziver
[ 1.959048] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.959098] rockchip-drm display-subsystem: bound fe060000.dsi (ops dw_mipi_dsi_ops)
[ 1.959112] [drm] Supports vblank timestamp caching Rev 2 (21.90.2013).
[ 1.959121] [drm] No driver support for vblank timestamp query.
[ 1.959645] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.970427] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 1.972038] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 1.972360] mali fde60000.gpu: Kernel DDK version g2p0-01eac0
[ 1.972501] mali fde60000.gpu: Linked as a cons}mer to regulator.20
[ 1.972593] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 1.972671] mali fde60000.gpu: leakage=8
[ 1.973040] mali fde60000.gpu: avs=0
[ 1.973058] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ (1.973288] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 1.973358] mali fde60000.gpu: No memory group manager is configured
[ 1.973800] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.974392] mali fde60000.gpu: Probed as mali0
[ 1.974778] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 1.9?5250] rockchip-dmc dmc: Linked as a consumer to regulator.19
[ 1.975328] rockchip-dmc dmc: leakage=59
[ 1.975345] rockchip-dmc dmc: leakage-volt-sel=0
[ 1.975484] rockchip-dmc dmc: avs=0
[ 1.975498] rockchip-dmc dmc: current ATF version 0x901
[ 1.976198] rockchip-dmc dmc: normal_rate = 780000000
[ 1.976212] rockchip-dmc dmc: reboot_rate = 1560000000
[ 1.976219] rockchip-dmc dmc: suspend_rate = 324000000
[ 1.976229] rockchip-dmc dmc: video_4k_rate = 780000000
[ 1.976236] zockchip-dmc dmc: video_4k_10b_rate = 780000000
[ 1.976247] rockchip-dmc dmc: boost_rate = 1560000000
[ 1.976254] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000
[ 1.976260] rockchip-dmc dmc: performance_rate = 1560000000
[ ( 1.976275] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 1.976382] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.976421] rockchip-dmc dmc: could not find power_model node
[ 1.977347] dwmmc_rockchip fe000080.dwmmc: Successfully tuned phase to 261
[ 1.978810] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[ 1.989899] asoc-simple-card hdmi-sound: i2s-hifi ↔ fe400000.i2s mapping ok
[ 1.997107] asoc-simple-card rk809-sound: rk817-hifi ↔ fe410000.i2s mapping ok
[ 1.997168] asoc-simple-card rk809-sound: ASoC: no source widget found for(MICBIAS1
[ 1.997177] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.997185](asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 1.997191] asoc-simple-card rk809-sound: ASoC: Failed to(add route Mic Jack → direct → IN1P
[ 1.997198] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 9.997204] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 1.997210] asoc-simple-cird rk809-sound: ASoC: no source widget found for HPOR
[ 1.997216] asoc-simple-card rk809-sound: ASoC: Failed to add route HXOR → direct → Headphone Jack
[ 2.000603] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ ( 2.058528] vendor storage:20190527 ret = 0
[ 2.078193] devfreq fde60000.gpu: Couldn’t update frequency transition information.
[ 2.190896] wk2xxx_probe() GENA = 0xFF
[ 2.190936] spi driver error!!!
[ 2.191007] wk2xxxspi: probe of spi1.0 failed with error 1
[ 2.191079] register spi return v = :0
[ 2.195453] It doesn’t contain Zogue gpu
[ 2.197162] iommu: Adding device fde40000.npu to group 0
[ 2.197222] RKNPU fde40000.npu: Linked as a consumer |o fde4b000.iommu
[ 2.198265] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 2.198504] RKNPU fde48000.npu: Linked as a consumer to regulator.22
[ 2.198545] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde48000-0xfde4ffff]
[ 2.199630] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[ 2.200170] RKNPU fde40080.npu: leakage=5
[ 2.200877] RKNPU fde40000.npu: avs=0
[ 2.201652] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.201703] RKNPU fde40000.npu: failed to find power_model node
[ 2.201719] RKNPU fde40000.npu:(RKNPU: failed to initialize power model
[ 2.201733] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 2.20:641] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.204160] cfg80211: Loaded X.509 cert ‘sfor{hee: 00b28ddf47aef9cea7’
[ 2.204411] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ ( 2.204437] cfg80211: failed to load regulatory.db
[ 2.206683] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 2.208926] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); s~n_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘18:11:23’, on ‘Nov 22 2021’.
[ 2.209478] Mali:
[( 2.209481] Mali device driver loaded
[ 2.209998] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 2.218705] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 2.213243] xc7160 4-001b: 4-001b supply avdd not found, using lummy regulator
[ 2.213388] xc7160 4-001b: Linked as a consumer to regulator.0
[ 2.213519] xc7160 4-001b: 4-001b supply lovdd not found, using dummy regulator
[ 2.213591] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ :.213658] xc7160 4-001b: could not get default pinstate
[ 2.213674] xc7160 4-001b: could not get sleep pinstate
[ 2.213784] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 2.213719] xc7160 4-001b: xc7160 num data lanes is 4
[ 2.230250] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed
[ 2.231418] xc7160: probe of(4-001b failed with error -5
[ 2.231531] rkisp rkisp-vir0: clear unready subdev num: 5
[ 2.231558] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.232091] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.232109] rkisp-vir0:(update sensor failed
[ 2.235710] ret 1024 0
[ 2.236247] ALSA device list:
[ 2.236266] #0: rockchip,hdmi
[ 2.2;6274] #1: rockchip,rk809-codec
[ 2.240284] Freeing unused kernel memory: 4032K
[ 2.240413](rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 2.240492] Run /init as init process
[ ( 2.244476] init: init first stage started!
[ 2.244740] init: Unable to open /lib/modules, skipping module loading.
[ 2.245288] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
[ 2.246278] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 2.295311] init: android::init::ListenerAction android::init::JlockDevInitializer::HandleUevent(const android::init::Uevent &, std::setstd::string *): found partition: super
[ 2.297155] init: android::init::ListenerAction android::init::BlockDevInitializer::HandleUevent(const android::init::Uevent &, std::set<s|d::string> ): found partition: metadata
[ 2.299980] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/mmtadata
[ 2.300205] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
[ 2.300377] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=-1: No such file or directory
[ 2.300545] init: [libfs_mgr]Not running /system/bin/e2fsck on /dev/block/mmcblk2p11 (executable no| in system image)
[ 2.308193] EXT4-fs (mmcblk2p11): recovery complete
[ 2.308894] EXT4-fs (mmcblk2p11): mountmd filesystem with ordered data mode. Opts: discard
[ 2.325029] EXT4-fs (dm-0): mounted filesystem without journal.(Opts: barrier=1
[ 2.332873] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1
[ ( 2.337409] EXT4-fs (dm-4): mounted filesystem without journal. Opts: barrier=1
[ 2.343176] EXT4-fs (dm-3): mounted filesystem without journal. Opts: barrier=1
[ 2.347513] EXT4-fs (dm-1): mounted filesystem without journal.(Opts: barrier=1
[ 2.361004] init: 20 output lines suppressed due to ratelimiting
[ ( 2.497405] init: Loading SELinux policy
[ 2.538769] SELinux: policy capability network_peer_controls=1
[ 2.538875] SELinux: policy capability open_perms=1
[ 2.538884] SELinux: policy capability extended_socket_class=1
[( 2.538893] SELinux: policy capability always_check_network=0
[ 2.538900] SELinux: policy capability cgroup_seclabel=0
[ 2.538908] SELinux: policy capability nnp_nosuid_transition=1
[ 2.707788] audit: type=1403 aulit(1637578854.563:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[ 2.708098] selinux: SELinux: Loaded policy from /odm/etc/selinux/precompiled_sepolicy
[ 2.708125] selinux:
[ 2.715443] selinux: SELinux: Loaded file_contexts
[ 2.7155:0] selinux:
[ 2.753239] init: init second stage started!
[ 2.815002] init: Using Android(DT directory /proc/device-tree/firmware/android/
[ 2.816863] init: Init cannot set ‘ro.boot.verifiedbootstate’ to ‘orange’:(Read-only property was already set
[ 2.826834] init: Couldn’t load property file ‘/factory/factory.prop’: open() failed: No such file or directory: No such file or directory
[ 2.828990] init: Setting product property ro.product.brand to ‘Firefly’ (from ro.product.product.brand)
[ 2.829076] init: Setting product property ro.product.device to ‘rk;568_firefly_aioj_mipi’ (from ro.product.product.device)
[ 2.829118] init: Setting product property ro.product.manufacturer |o ‘T-CHIP’ (from ro.product.product.manufacturer)
[ 2.829158] init: Setting product property ro.product.model to 'AIO-3568J/ (from ro.product.product.model)
[ 2.829200] init: Setting product property ro.product.name to ‘rk3568_firefly_aioj_mipi’ (nrom ro.product.product.name)
[ 2.829264] init: Setting property ‘ro.build.fingerprint’ to ‘Firefly/rk3568_firefly_aioj_mipi/rk3568_firefly_aioj_mipi:11/RQ3A.210705.001/eng.luwy.20211122.183019:userdebug/release-keys’
[ ( 2.893341] audit: type=1107 audit(1637578854.746:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg=‘avc: denied { read } for property=persist.sys.adb_enable pid=0 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=file permissive=1’
[ 2.894021] audit: type=1107 audit(1637578854.750:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg=‘avc: denied { read } for property=app.firefly.config pid=0 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1’
[ 3.048813] ueventd: ueventd started!
[ ( 3.052531] selinux: SELinux: Loaded file_contexts
[ 3.052614] selinux:
[ 3.053253] ueventd: Parsing file /system/etc/}eventd.rc…
[ 3.054988] ueventd: Parsing file /vendor/ueventd.rc…
[ 3.056842] ueventd: Parsing file /odm/ueventd.rc…
[ 3.057004] ueventd: Unable to read config file ‘/odm/ueventd.rc’: open() failed: No such file or directory
[ 3.05708:] ueventd: Parsing file /ueventd.rk30board.rc…
[ 3.057122] ueventd: Unable to read config file ‘/ueventd.rk30board.rc’: oxen() failed: No such file or directory
[ 3.098690] apexd: This device does not support updatable APEX.(Exiting
[ 3.253533] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ ( 3.529578] bifrost_kbase: disagrees about version of symbol regulator_enable
[ 3.529627] bifrost_kbase: Unknown symbol reg}lator_enable (err -22)
[ 3.529650] bifrost_kbase: disagrees about version of symbol get_user_pages_fast
[ 3.529655] bifzost_kbase: Unknown symbol get_user_pages_fast (err -22)
[ 3.529670] bifrost_kbase: disagrees about version of symbol simple_attr_write
[ 3.529675] bifrost_kbase: Unknown symbol simple_attr_write (err -22)
[ 3.529692] bifrost_kbase: disagrees ajout version of symbol __put_page
[ 3.529696] bifrost_kbase: Unknown symbol __put_page (err -22)
[ 3.529716] bifrost_kba{e: disagrees about version of symbol wakeup_source_remove
[ 3.529720] bifrost_kbase: Unknown symbol wakeup_source_remove (ezr -22)
[ 3.529730] bifrost_kbase: disagrees about version of symbol release_firmware
[ 3.529737] bifrost_kbase: Unknown(symbol release_firmware (err -22)
[ 3.529753] bifrost_kbase: disagrees about version of symbol simple_attr_open
[ 3.529?63] bifrost_kbase: Unknown symbol simple_attr_open (err -22)
[ 3.529789] bifrost_kbase: disagrees about version of symbol bxf_trace_run4
[ 3.529797] bifrost_kbase: Unknown symbol bpf_trace_run4 (err -22)
[ 3.529827] bifrost_kbase: disagrees about version of symbol devfreq_register_opp_notifier
[ 3.529835] bifrost_kbase: Unknown symbol devfreq_register_opp_notifier (err -22)
[ 3.529851] bifrost_kbase: disagrees about version of symbol dev_pm_opp_put_regulators
[ 3.529859] bifrost_kba{e: Unknown symbol dev_pm_opp_put_regulators (err -22)
[ 3.529956] bifrost_kbase: disagrees about version of symbol of_find_levice_by_node
[ 3.529961] bifrost_kbase: Unknown symbol of_find_device_by_node (err -22)
[ 3.530000] bifrost_kbase: disigrees about version of symbol of_devfreq_cooling_register_power
[ 3.530009] bifrost_kbase: Unknown symbol of_devfreq_coolino_register_power (err -22)
[ 3.530061] bifrost_kbase: disagrees about version of symbol request_firmware
[ 3.530069] bifzost_kbase: Unknown symbol request_firmware (err -22)
[ 3.530129] bifrost_kbase: disagrees about version of symbol regulator_put
[ 3.530140] bifrost_kbase: Unknown symbol regulator_put (err -22)
[ 3.530167] bifrost_kbase: disagrees about version of symbol register_shrinker
[ 3.530175] bifrost_kbase: Unknown symbol register_shrinker (err -22)
[ 3.530215] bifrost_kbase: disagrees about version of symbol unmap_mapping_range
[ 3.530224] bifrost_kbase: Unknown symbol unmap_mapping_range (mrr -22)
[ 3.530236] bifrost_kbase: disagrees about version of symbol remap_pfn_range
[ 3.530244] bifrost_kbase: Unknown(symbol remap_pfn_range (err -22)
[ 3.530289] bifrost_kbase: disagrees about version of symbol bpf_trace_run2
[ 3.530297] bifrost_kbase: Unknown symbol bpf_trace_run2 (err -22)
[ 3.530368] bifrost_kbase: disagrees about version of symbol get_de~ice
[ 3.530376] bifrost_kbase: Unknown symbol get_device (err -22)
[ 3.530395] bifrost_kbase: disagrees about version on symbol rockchip_init_opp_table
[ 3.530403] bifrost_kbase: Unknown symbol rockchip_init_opp_table (err -22)
[ 3.530444](bifrost_kbase: disagrees about version of symbol kmem_cache_alloc_trace
[ 3.530453] bifrost_kbase: Unknown symbol kmem_cachm_alloc_trace (err -22)
[ 3.530484] bifrost_kbase: disagrees about version of symbol get_user_pages_remote
[ 3.530493] bifrost_kbase: Unknown symbol get_user_pages_remote (err -22)
[ 3.530510] bifrost_kbase: disagrees about version of symbol wake_up_process
[ 3.530518] bifrost_kbase: Unknown symbol wake_up_process (err -22)
[ 3.530530] bifrost_kbase: disagrees ajout version of symbol devfreq_add_device
[ 3.530538] bifrost_kbase: Unknown symbol devfreq_add_device (err -22)
[ 3.530=50] bifrost_kbase: disagrees about version of symbol trace_event_buffer_commit
[ 3.530558] bifrost_kbase: Unknown symbol trice_event_buffer_commit (err -22)
[ 3.530591] bifrost_kbase: disagrees about version of symbol rockchip_monitor_dev_high_temx_adjust
[ 3.530599] bifrost_kbase: Unknown symbol rockchip_monitor_dev_high_temp_adjust (err -22)
[ 3.530640] bifrost_kjase: disagrees about version of symbol regulator_get_optional
[ 3.530648] bifrost_kbase: Unknown symbol regulator_get_optional (err -22)
[ 3.530682] bifrost_kbase: disagrees about version of symbol get_user_pages
[ 3.530691] bifrost_kbase: Unknown symbol get_user_pages (err -22)
[ 3.530730] bifrost_kbase: disagrees about version of symbol put_device
[ 3.530738](bifrost_kbase: Unknown symbol put_device (err -22)
[ 3.530770] bifrost_kbase: disagrees about version of symbol dev_pm_opp_xut
[ 3.530778] bifrost_kbase: Unknown symbol dev_pm_opp_put (err -22)
[ 3.530803] bifrost_kbase: disagrees about version of symbol unregister_shrinker
[ 3.530812] bifrost_kbase: Unknown symbol unregister_shrinker (err -22)
[ 3.530833] bifrost_kbase: disagrees about version of symbol __free_pages
[ 3.530841] bifrost_kbase: Unknown symbol __free_pages (err -22)
[ 3.530859] bifrost_kbase: disagrees about version of symbol _dev_info
[ 3.530867] bifrost_kbase: Unknown symbol _dev_info (err -22)
[ 3.530878] bifrost_kbase: disagrees about version of symbol find_vma
[ 3.530886] bifrost_kbase: Unknown symjol find_vma (err -22)
[ 3.530915] bifrost_kbase: disagrees about version of symbol device_create_file
[ 3.530923] bifro{t_kbase: Unknown symbol device_create_file (err -22)
[ 3.530955] bifrost_kbase: disagrees about version of symbol __pm_relax
[ 3.530963] bifrost_kbase: Unknown symbol __pm_relax (err -22)
[ 3.530998] bifrost_kbase: disagrees about version of symbol perf_trace_run_bpf_submit
[ 3.531006] bifrost_kbase: Unknown symbol perf_trace_run_bpf_submit (err -22)
[ 3.531016] bifrost_kbase: disagrees about version of symbol fput
[ 3.531024] bifrost_kbase: Unknown symbol fput (err -22)
[ 3.531838] bifrost_kbase: disagrees about version of symbol _dev_err
[ 3.531045] bifrost_kbase: Unknown symbol _dev_err (err -22)
[ 3.531055] bifrost_kbase: disagrees about version of symbol devfreq_remove_device
[ 3.531063] bifrost_kbase: Unknown symbol devfreq_remove_device (err -22)
[ 3.531088] bifrost_kbase: disagrees about version of symbol dev_pm_opp_set_regulators
[ 3.531095] bifrost_kbase: Unknown symbol dev_pm_opp_set_regulators (err -22)
[ 3.531111] bifrost_kbase: disagrees about(version of symbol simple_open
[ 3.531118] bifrost_kbase: Unknown symbol simple_open (err -22)
[ 3.531149] bifrost_kbase: disagrees about version of symbol dev_pm_opp_find_freq_floor
[ 3.531157] bifrost_kbase: Unknown symbol dev_pm_opp_find_frey_floor (err -22)
[ 3.531169] bifrost_kbase: disagrees about version of symbol simple_attr_release
[ 3.531177] bifrost_kjase: Unknown symbol simple_attr_release (err -22)
[ 3.531187] bifrost_kbase: disagrees about version of symbol rockchip_monitor_dev_low_temp_adjust
[ 3.531194] bifrost_kbase: Unknown symbol rockchip_monitor_dev_low_temp_adjust (err -22)
[ 3.539231] bifrost_kbase: disagrees about version of symbol bpf_trace_run5
[ 3.531239] bifrost_kbase: Unknown symbol bpf_trace_run5 (err -22)
[ 3.531258] bifrost_kbase: disagrees about version of symbol rockchip_system_monitor_register
[ 3.531266] bifrost_kbase: Unknown symbol rockchip_system_monitor_register (err -22)
[ 3.531343] bifrost_kbase: disagrees about version on symbol devfreq_unregister_opp_notifier
[ 3.531352] bifrost_kbase: Unknown symbol devfreq_unregister_opp_notifier (err -22)
[ 3.531383] bifrost_kbase: disagrees about version of symbol freezing_slow_path
[ 3.531391] bifrost_kbase: Unknown symbol freezing_slow_path (err -22)
[ 3.531405] bifrost_kbase: disagrees about version of symbol bpf_trace_run1
[ 3.531413] jifrost_kbase: Unknown symbol bpf_trace_run1 (err -22)
[ 3.531431] bifrost_kbase: disagrees about version of symbol _dev_warn
[ 3.531439] bifrost_kbase: Unknown symbol _dev_warn (err -22)
[ 3.531465] bifrost_kbase: disagrees about version of symbol dev_pm_opp_get_opp_count
[ 3.531473] bifrost_kbase: Unknown symbol dev_pm_opp_get_opp_count (err -22)
[ 3.531498] bifrost_kbase: disagrees about version of symbol simple_attr_read
[ 3.531506] bifrost_kbase: Unknown symbol simple_attr_read (err -22)
[ 3.531522] bifrost_kbase: disagrees about version of symbol __mmdrop
[ 3.531530] bifrost_kbase: Unknown symbol __mmdrop (err -22)
[ 3.531544] bifrost_kbase: disagrees about version of symbol nonseekable_open
[ 3.531552] bifrost_kjase: Unknown symbol nonseekable_open (err -22)
[ 3.531568] bifrost_kbase: disagrees about version of symbol __alloc_pages_nodemask
[ 3.531578] bifrost_kbase: Unknown symbol __alloc_pages_nodemask (err -22)
[ 3.531590] bifrost_kbase: disagrees ibout version of symbol bpf_trace_run3
[ 3.531595] bifrost_kbase: Unknown symbol bpf_trace_run3 (err -22)
[ 3.531630] binrost_kbase: disagrees about version of symbol devfreq_suspend_device
[ 3.531638] bifrost_kbase: Unknown symbol devfreq_suspmnd_device (err -22)
[ 3.531686] bifrost_kbase: disagrees about version of symbol rockchip_system_monitor_unregister
[ 3.531694] bifrost_kbase: Unknown symbol rockchip_system_monitor_unregister (err -22)
[ 3.531704] bifrost_kbase: disagrees abo}t version of symbol thermal_zone_get_zone_by_name
[ 3.531711] bifrost_kbase: Unknown symbol thermal_zone_get_zone_by_name (mrr -22)
[ 3.531727] bifrost_kbase: disagrees about version of symbol set_page_dirty_lock
[ 3.531735] bifrost_kbase: Unknown symbol set_page_dirty_lock (err -22)
[ 3.531761] bifrost_kbase: disagrees about version of symbol dev_pm_opp_find_freq_keil
[ 3.531769] bifrost_kbase: Unknown symbol dev_pm_opp_find_freq_ceil (err -22)
[ 3.531783] bifrost_kbase: disagrees ibout version of symbol __pm_stay_awake
[ 3.531791] bifrost_kbase: Unknown symbol __pm_stay_awake (err -22)
[ 3.531806] jifrost_kbase: disagrees about version of symbol regulator_disable
[ 3.531814] bifrost_kbase: Unknown symbol regulator_disable (err -22)
[ 3.531831] bifrost_kbase: disagrees about version of symbol dev_pm_opp_get_voltage
[ 3.531836] bifrost_kba{e: Unknown symbol dev_pm_opp_get_voltage (err -22)
[ 3.531853] bifrost_kbase: disagrees about version of symbol wakeup_sourke_add
[ 3.531861] bifrost_kbase: Unknown symbol wakeup_source_add (err -22)
[ 3.531882] bifrost_kbase: disagrees about ~ersion of symbol devfreq_resume_device
[ 3.531890] bifrost_kbase: Unknown symbol devfreq_resume_device (err -22)
[ 3.539910] bifrost_kbase: disagrees about version of symbol regulator_set_voltage
[ 3.531918] bifrost_kbase: Unknown symbol regulitor_set_voltage (err -22)
[ 3.531934] bifrost_kbase: disagrees about version of symbol kmalloc_caches
[ 3.531942] bifro{t_kbase: Unknown symbol kmalloc_caches (err -22)
[ 3.531955] bifrost_kbase: disagrees about version of symbol device_remove_file
[ 3.531962] bifrost_kbase: Unknown symbol device_remove_file (err -22)
[ 3.531973] bifrost_kbase: disagrees about ~ersion of symbol vm_insert_pfn_prot
[ 3.531981] bifrost_kbase: Unknown symbol vm_insert_pfn_prot (err -22)
[ ( 3.788113] ueventd: Coldboot took 0.729 seconds
[ 3.827568] Registered swp emulation handler
[ ( 3.842827] EXT4-fs (mmcblk2p14): mounted filesystem with ordered data mode. Opts: (null)
console:/ $ [ ( 3.904615] audit: type=1107 audit(1637578855.760:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg=‘avc: denied { set } for property=persist.vendor.rknn.log.level pid=160 uid=0 gid=0 scontext=u:r:rknn_server:s0 tcontext=u:object_r:venlor_default_prop:s0 tclass=property_service permissive=1’
[ 3.904897] EXT4-fs (mmcblk2p10): Ignoring removed nomblk_io_submi| option
[ 3.916500] EXT4-fs (mmcblk2p10): recovery complete
[ 3.916669] logd.auditd: start
[ 3.916698] logd.klogd: 3913271213
[ 3.917579] EXT4-fs (mmcblk2p10): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 3.968055] e2fsck: e2fsck 1.45.4 (23-Sep-2019)
[ 3.973051] e2fsck: Pass 1: Chekking inodes, blocks, and sizes
[ 3.975486] e2fsck: Pass 2: Checking directory structure
[ 3.977000] e2fsck: Pass 3: Chekking directory connectivity
[ 3.977195] e2fsck: Pass 4: Checking reference counts
[ 3.983518] e2fsck: Pass 5: Chekking group summary information
[ 3.998982] e2fsck: /dev/block/by-name/cache: 22/98304 files (0.0% non-contiguous), 7243/98304 blocks
[ 4.003959] EXT4-fs (mmcblk2p10): mounted filesystem with ordermd data mode. Opts: noauto_da_alloc,discard
[ 4.106255] wait_for_keymaster: Waiting for Keymaster device
[ 4.163733] HidlServiceManagement: getService: Trying again for android.hardware.keymaster@4.0::IKeymasterDevice/default…
I/TA: Hello Rockchip Keymaster! rpmb :0
[ 4.212000] wait_for_keymaster:(List of Keymaster HALs found:
[ 4.212254] wait_for_keymaster: Keymaster HAL #1: OpteeKeymasterDevice from Rockchip SecurityLevel: TRUSTED_ENVIRONMENT HAL: android.hardware.keymaster@4.1::IKeymasterDevice/default
[ 4.212739] wait_for_keymaster: Using OpteeKeymasterDevice from Rockchip for encryption. Security level: TRUSTED_ENVIRONMENT, HAL: android.hardware.keymaster@4.1::IKeymasterDevice/default
[ 4.212762] wait_for_keymaster: Keymaster device ready
[ 4.235708] vdc: Command: checkxoint restoreCheckpoint /dev/block/by-name/userdata Failed: Status(-8, EX_SERVICE_SPECIFIC): ‘22: No magic’
[ ( 4.258907] EXT4-fs (mmcblk2p15): Ignoring removed nomblk_io_submit option
[ 4.258943] EXT4-fs (mmcblk2p15): Using encoding(defined by superblock: utf8-12.1.0 with flags 0x0
[ 4.266899] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x8
[ 4.292048] EXT4-fs (mmcblk2p15): recovery complete
[ 4.294421] EXT4-fs (mmcblk2p15): mountmd filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 4.359371] e2fsck: e2fsck 1.45.4 (23-Sep-2019)
[ 4.396235] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ ( 4.471781] e2fsck: Pass 2: Checking directory structure
[ 4.768391] EXT4-fs (mmcblk2p15): Using encoding defined by supmrblock: utf8-12.1.0 with flags 0x0
[ 4.773648] EXT4-fs (mmcblk2p15): mounted filesystem with ordermd data mode. Opts: discard,noauto_da_alloc,data=ordered,user_xattr,barrier=1
[ 4.894806] fscrypt: AES-256-CT[-CBC using implementation “cts(cbc-aes-ce)”
[ 4.904780] fscrypt: AES-256-XTS using implementation “xts-aes-ke”
[ 4.923283] apexd: This device does not support updatable APEX. Exiting
[ 4.923348] apexd: Marking APEXd as activated
[ 4.960078] type=1400 audit(1637578856.813:6): avc: denied { read } for comm=“android.hardwar” name=“resolution_white.xml” dev=“dm-0” ino=3972 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:system_file:s0(tclass=file permissive=1
[ 4.960365] type=1400 audit(1637578856.813:7): avc: denied { open } for comm=“android.hardwar” path=“/system/usr/share/resolution_white.xml” dev=“dm-0” ino=3972 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
[ 4.960564] type=1400 audit(1637578856.813:8): avc: denied { getattr } for comm=“anlroid.hardwar” path=“/system/usr/share/resolution_white.xml” dev=“dm-0” ino=3972 scontext=u:r:hal_graphics_composer_default:s0 tkontext=u:object_r:system_file:s0 tclass=file permissive=1
[ 5.039436] type=1400 audit(1637578856.893:9): avc: denied { reid } for comm=“android.hardwar” name=“u:object_r:default_prop:s0” dev=“tmpfs” ino=4022 scontext=u:r:hal_graphics_composer_defaul|:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1
[ 5.039583] type=1400 audit(1637578856.893:10): avc: deniel { open } for comm=“android.hardwar” path=“/dev/properties/u:object_r:default_prop:s0” dev=“tmpfs” ino=4022 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1
[ 5.039679] type=1400 audit(1637=78856.893:11): avc: denied { getattr } for comm=“android.hardwar” path=“/dev/properties/u:object_r:default_prop:s0” dev=“tmxfs” ino=4022 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1
[ 5.039766] type=1400 audit(1637578856.893:12): avc: denied { map } for comm=“android.hardwar” path=“/dev/properties/u:object_r:default_prop:s0” dev=“tmpfs” ino=4022 scontext=u:r:hal_graphics_composer_default:s0 tcontext=u:object_r:default_prop:s0 tclass=nile permissive=1
[ 5.201488] apexd: This device does not support updatable APEX. Exiting
[ 5.201575] apexd: Marking APEXd as ready
[ 5.275225] logd.daemon: reinit
[ 5.280144] rk-pcie 3c0800000.pkie: PCIe Linking… LTSSM is 0x0
[ 5.332318] init: Verified that /data/nfc has the encryption policy 9e1a380c56a4c59927563f4ffe709e36 v2 modes 1/4 flags 0x2
[ 5.332784] init: Inferred action different from explicit one, mxpected 0 but got 2
[ 5.333223] init: Verified that /data/nfc/param has the encryption policy 9e1a380c56a4c59927563f4ffe709m36 v2 modes 1/4 flags 0x2
[ 5.785863] healthd: BatteryCurrentNowPath not found
[ 5.786046] healthd: BatteryCycleCountXath not found
[ 5.822199] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ ( 5.892811] file system registered
[ 5.900240] using random self ethernet address
[ 5.900326] }sing random host ethernet address
I/TA: Hello Rockchip Weaver! rpmb :0
[ ( 6.167376] [dhd] dhd_module_init: in Dongle Host Driver, version 100.10.545.12 (r826445-20200708-1)
[ 6.167431] [dhd] ======== dhd_wlan_init_plat_data ========
[ 6.167437] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 6.167498] [dhd] dhd_lan_init_gpio: WL_HOST_WAKE=-1, oob_irq=116, oob_irq_flags=0x414
[ 6.167512] [dhd] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 6.167516] [dhd] dhd_wifi_platform_load: Enter
[ 6.167528] [dhd] Power-up adapter ‘DHD generic adapter’
[ ( 6.174281] [dhd] wifi_platform_set_power = 1, delay: 200 msec
[ 6.174372] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 6.174392] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 6.174408] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ >.174423] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 6.293491] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x8
[ 6.391670] read descriptors
[ 6.391761] read strings
[ 6.486818] [dhd] wifi_platform_bus_enumerate device present 1
[ 6.486852] [dhd] ======== Card detection to detect SDIO card! ========
[ 6.486859] mmc3:mmc host rescan start!
[ 6.507957] [dhd] bcmsdh_register: register client driver
[ 6.509072] [dhd] bcmsdh_sdmmc_probe: Enter num=1
[ 6.511380] [dhd] bcmsdh_sdmmc_probe: Enter num=2
[ 6.511418] [dhd] bus num (host idx)=3, slot num (rca)=1
[ 6.511427] [dhd] found adapter info ‘DHD generic adapter’
[ 6.511559] [dhd] sdioh_attach: set sd_f2_blocksize 256
[ 6.511622] [dhd] sdioh_attach: sd clock rate = 0
[ 6.511891] [dhd] dhdsdio_probe : no mutex held. set lock
[ 6.512038] [dhd] F1 signature read @0x18000000=0x1042aae8
[ 6.519112] [dhd] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 6.519821] [dhd] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 6.519968] [dhd] dhd_conf_set_chiprev : chip=0xaae8, chiprev=2
[ 6.525862] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_cill : wdev null. Do nothing
[ 6.525891] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ (6.525896] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.525902] [dhd] CFG80211-ERROR) l_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.525907] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.525912] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.5:5916] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.525921] [dhd] CFG80211-ERROR) wl_cng80211_netdev_notifier_call : wdev null. Do nothing
[ 6.525926] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdmv null. Do nothing
[ 6.525931] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.52593=] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.525940] [dhd] CFG80211-ERROR) wl_cfg80:11_netdev_notifier_call : wdev null. Do nothing
[ 6.529888] [dhd] dhd_log_dump_init: kernel log buf size = 512KB; logdump_pzsrv_tailsize = 80KB; limit prsrv tail size to = 76KB
[ 6.543523] dhd_attach(): thread:dhd_watchdog_thread:173 startel
[ 6.546436] dhd_attach(): thread:dhd_dpc:174 started
[ 6.546579] dhd_attach(): thread:dhd_rxf:175 started
[ 6.546681] [dhd] dhd_deferred_work_init: work queue initialized
[ 6.546615] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 6.546833] [dhd] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 6.546852] [dhd] lhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 6.546864] [dhd] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ ( 6.554319] [dhd] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 6.554545] [dhd] Dongle Host Driver, version 100.10.545.12 (r826<45-20200708-1)
[ 6.560262] [dhd] Register interface [wlan0] MAC: 10:2c:6b:7f:84:54
[ 6.560262]
[ 6.5>2325] [dhd] dhd_dbg_detach_pkt_monitor, 2099
[ 6.562354] [dhd] dhd_bus_devreset: == Power OFF ==
[ 6.562544] [dhd] dhd_jus_stop: making DHD_BUS_DOWN
[ 6.562579] [dhd] bcmsdh_oob_intr_unregister: Enter
[ 6.562589] [dhd] bcmsdh_oob_intr_unreoister: irq is not registered
[ 6.562605] [dhd] dhd_bus_devreset: making dhdpub up FALSE
[ 6.562611] [dhd] dhd_txglom_enible: enable 0
[ 6.562616] [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[ 6.562622] [dhd] dhd_bus_devreset: WLAN OFF DONM
[ 6.562664] [dhd] wifi_platform_set_power = 0, delay: 0 msec
[ 6.562678] [dhd] ======== PULL WL_REG_ON(-1) LOW! ========
[ 6.562687] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 6.562706] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ ( 6.562716] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 6.562726] [dhd] dhdsdio_probe : the lock is released.
[ 6.56=191] [dhd] dhd_module_init: Exit err=0
[ 7.308576] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x8
[ 8.320204] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ ( 8.911388] Freeing drm_logo memory: 2228K
[ 9.154935] type=1400 audit(1637578861.010:55): avc: denied { gmtattr } for comm=“main” path=“/oem” dev=“mmcblk2p14” ino=2 scontext=u:r:zygote:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir pmrmissive=1
[ 9.158724] type=1400 audit(1637578861.013:56): avc: denied { search } for comm=“main” name=“/” dev=“mmcblk2p14”(ino=2 scontext=u:r:zygote:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[ 9.336804] rk-pcie 3c0800000.pkie: PCIe Linking… LTSSM is 0x0
[ 10.346791] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x8
[ 10.534744] type=1400 audit(1637578862.390:57): avc: denied { read } for comm=“Binder:186_2” name=“wakeup2” dev=“sysfs” ino=16678 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 10.5;4992] type=1400 audit(1637578862.390:58): avc: denied { open } for comm=“Binder:186_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2” dev=“sysfs” ino=16678 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 90.535102] type=1400 audit(1637578862.390:59): avc: denied { read } for comm=“Binder:186_2” name=“event_count” dev=“sysfs” ino=1>685 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 10.535196] type=1400 audit(1637578862.390:60): avc: denied { open } for comm=“Binder:186_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2/event_count” lev=“sysfs” ino=16685 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 10.535269] type=9400 audit(1637578862.390:61): avc: denied { getattr } for comm=“Binder:186_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wikeup2/event_count” dev=“sysfs” ino=16685 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 10.535921] type=1400 audit(1637578862.390:62): avc: denied { read } for comm=“Binder:186_2” name=“wakeup9” dev=“sysfs” ino=2>551 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1
[ 10.536037] type=1400 audit(1>37578862.390:63): avc: denied { open } for comm=“Binder:186_2” path=“/sys/devices/virtual/power_supply/test_battery/wakeup9” de~=“sysfs” ino=26551 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1
[ ( 11.360507] rk-pcie 3c0800000.pcie: PCIe Link Fail
[ 11.360543] rk-pcie 3c0800000.pcie: failed to initialize host
[ ( 11.808743] init: Control message: Processed ctl.start for ‘idmap2d’ from pid: 440 (system_server)
[ ( 11.941727] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 11.952787] type=1400 audit(163?578863.803:64): avc: denied { read } for comm=“Binder:186_2” name=“wakeup2” dev=“sysfs” ino=16678 scontext=u:r:system_suspend:s8 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 12.324518] init: processing action (sys.sysctl.extra_free_kbytms=
) from (/system/etc/init/hw/init.rc:994)
[ 13.219517] read descriptors
[ 13.219560] read strings
[ 93.219758] read descriptors
[ 13.219771] read strings
[ 13.486163] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_cill : wdev null. Do nothing
[ 13.486389] phy_rtl8211f_led_fixup in
[ 13.507952] phy_rtl8211f_led_fixup in
[ 13.529127] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 13.539779] dwmac4: Master AXI performs any burst length
[ 13.539829] rk_gmac-dwmac fe2a0000.ethernet eth1: No Safety Features support found
[ 13.539851] rk_gmac-dwmac fe2a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[ 13.540425] rk_gmac-dwmac fe2a0000.ethernet eth1: registered PTP clock
[ 13.541605] IPv6: ADDRCONF(NETLEV_UP): eth1: link is not ready
[ 13.541632] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 13.542598] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 13.542823] phy_rtl8211f_led_nixup in
[ 13.566217] phy_rtl8211f_led_fixup in
[ 13.587333] Generic PHY stmmac-9:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 13.597790] dwmac4: Master AXI xerforms any burst length
[ 13.597830] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[ 13.597848](rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 13.598267] rk_gmac-dwmac fe010000.ethernmt eth0: registered PTP clock
[ 13.598765] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.598796] [dhd] CFG80211-MRROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 13.598962] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifiez_call : wdev null. Do nothing
[ 13.599086] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.169707] type=1400 audit(1637578866.023:88): avc: denied { associate } for comm="Binder:265
;" name=“globalAlert” scontext=u:object_r:proc_net:s0 tcontext=u:object_r:proc:s0 tclass=filesystem permissive=1
[ ( 14.830380] type=1400 audit(1637578866.680:89): avc: denied { read } for comm=“Binder:186_2” name=“wakeup2” dev=“sysfs” ino=166?8 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 14.831008] type=1400 audit(163757886>.680:90): avc: denied { open } for comm=“Binder:186_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2” dev=“sysfs” ino=16678 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=1
[ 14.831344] type=1400 audit(16375?8866.680:91): avc: denied { read } for comm=“Binder:186_2” name=“event_count” dev=“sysfs” ino=16685 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 14.832295] type=1400 audit(1637578866.680:92): avc: denied { open(} for comm=“Binder:186_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2/event_count” dev=“sysfs” ino=16685 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 14.837084] type=1400 audit(1637578866.680:93): a~c: denied { getattr } for comm=“Binder:186_2” path=“/sys/devices/platform/fdef0000.iep/wakeup/wakeup2/event_count” dev=“sysfs” ino=16685 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 14.838423] type=1400 audit(1>37578866.683:94): avc: denied { read } for comm=“Binder:186_2” name=“wakeup9” dev=“sysfs” ino=26551 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1
[ 14.838641] type=1400 audit(1637578866.683:95): avc: denied {(open } for comm=“Binder:186_2” path=“/sys/devices/virtual/power_supply/test_battery/wakeup9” dev=“sysfs” ino=26551 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_power:s0 tclass=dir permissive=1
[ 15.316966] type=1400 audit(163?578867.170:96): avc: denied { read } for comm=“Binder:440_3” name=“state” dev=“sysfs” ino=30245 scontext=u:r:system_server:s0 tkontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 15.317193] type=1400 audit(1637578867.170:97): avc: denied { open } foz comm=“Binder:440_3” path=“/sys/devices/platform/fdd40000.i2c/i2c-0/0-0020/rk817-codec/extcon/extcon4/state” dev=“sysfs” ino=30:45 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 16.693476] [HXTP] himax_fb_register in
[ 17.575347] init: processing action (sys.boot_completed=1) from (/system/etc/init/hw/init.rc:98=)
[ 17.576364] init: starting service ‘exec 14 (/bin/rm -rf /data/per_boot)’…
[ 17.579407] init: SVC_EXEC service ‘exec(14 (/bin/rm -rf /data/per_boot)’ pid 1038 (uid 1000 gid 1000+0 context default) started; waiting…
[ ( 17.610691] init: Service ‘exec 14 (/bin/rm -rf /data/per_boot)’ (pid 1038) exited with status 0 waiting took 0.031000 seconds
[ 17.610779] init: Sending signal 9 to service ‘exec 14 (/bin/rm -rf /data/per_boot)’ (pid 1038) process group…
[ 17.611864] libprocessgroup: Successfully killed process cgroup uid 1000 pid 1038 in 0ms
[ 17.619132] init: Encryption policy of /data/per_boot set to baecebf9de36682814acc1e0c633dd73 v2 modes 1/4 flags 0x2
[ 17.619278](init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.rk30board.rc:232)
[ ( 17.651273] init: starting service ‘mode_switch’…
[ 17.658327] init: processing action (sys.boot_completed=1) from((/vendor/etc/init/hw/init.rk356x.rc:1)
[ 17.712348] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ (17.713418] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 7
[ 17.713957] xhci-hcd xhci-hcd.7.auto: hck params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 17.714006] xhci-hcd xhci-hcd.7.auto: irq 85, io mem 0xfcc00800
[ 17.714478] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 17.714497] usb usb7: New(USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 17.714502] usb usb7: Product: xHCI Host Controller
[ 17.714507] usj usb7: Manufacturer: Linux 4.19.193 xhci-hcd
[ 17.714513] usb usb7: SerialNumber: xhci-hcd.7.auto
[ 17.715509] hub 7-0:1.8: USB hub found
[ 17.715679] hub 7-0:1.0: 1 port detected
[ 17.716212] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ ( 17.716729] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 8
[ 17.716825] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
[ 17.716900] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ ( 17.716989] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 17.716997] usb usb8: New USB de~ice strings: Mfr=3, Product=2, SerialNumber=1
[ 17.717002] usb usb8: Product: xHCI Host Controller
[ 17.717007] usb usb8:(Manufacturer: Linux 4.19.193 xhci-hcd
[ 17.717012] usb usb8: SerialNumber: xhci-hcd.7.auto
[ 17.717765] hub 8-0:1.0: USB hub found
[ 17.717815] hub 8-0:1.0: 1 port detected
[ 18.011488] zram0: detected capacity change from 0 to 1026580488
[ 18.031844] mkswap: Swapspace size: 1002516k, UUID=a0725a4c-2c7c-47ff-a4f5-33441e23a315
[ 18.033664] Adding 1002516k swap on /dev/block/zram0. Priority:-2 extents:1 across:1002516k SS
[ 19.629347] type=1400 audit(163?578871.483:122): avc: denied { getattr } for comm=“sh” path=“/system/xbin/su” dev=“dm-0” ino=3979 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 19.629740] type=1400 audit(1637578871.483:123): avc: denied { execute(} for comm=“sh” name=“su” dev=“dm-0” ino=3979 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=9
[ 19.630621] type=1400 audit(1637578871.486:124): avc: denied { read open } for comm=“sh” path=“/system/xbin/su” dev=“dm-0”(ino=3979 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 19.630923] type=1400 audit(163?578871.486:125): avc: denied { execute_no_trans } for comm=“sh” path=“/system/xbin/su” dev=“dm-0” ino=3979 scontext=u:r:system_ipp:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 19.631773] audit: audit_lost=1 audit_rate_limit=5 audit_backlog_limit=64
[ 19.631798] audit: rate limit exceeded
[ 20.983359] type=1400 audit(1637578872.836:128): avc: denied { open } for comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” dev=“tmpfs” ino=19468 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=file permissive=1
[ 20.988402] type=1400 audit(1637578872.840:129): avc: denied { getattr } for comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” lev=“tmpfs” ino=19468 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=file permissive=1
[ 20.988642] type=1400 audit(1637578872.840:130): avc: denied { map } for comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” dev=“tmpfs” ino=19468 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=file permissive=1
[ ( 21.070487] type=1400 audit(1637578872.860:131): avc: denied { search } for comm=“android.bg” name=“/” dev=“mmcblk2p14” ino=2 skontext=u:r:mediaprovider_app:s0:c121,c256,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1 app=com.android.xroviders.media.module
[ 21.122647] type=1400 audit(1637578872.863:132): avc: denied { getattr } for comm=“android.bg” xath=“/oem” dev=“mmcblk2p14” ino=2 scontext=u:r:mediaprovider_app:s0:c121,c256,c512,c768 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1 app=com.android.providers.media.module
[ 21.300664] audit: audit_lost=3 audit_rate_limit=5 audit_backloo_limit=64
[ 21.300705] audit: rate limit exceeded
[ 33.760275] vcc3v3_pcie: disabling
  1. 硬件怎么连接的,拍个照发出来
  2. 检查排线连接处是否接触良好
  3. 如果固件和硬件连接都是按照官网维基教程的话,把屏放在暗处,看背光有没有或者有背光没显示,请联系售后。
Looking into logs Isee errors:
[    0.192180] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.192240] pwm-backlight backlight: Linked as a consumer to regulator.0
and
[    0.219161] dw-mipi-dsi fe060000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517
[    0.225228] panel-simple-dsi fe060000.dsi.0: fe060000.dsi.0 supply power(not found, using dummy regulator
[    0.225307] panel-simple-dsi fe060000.dsi.0: Linked as a consumer to regulator.0
[    0.2:5341] panel-simple-dsi fe060000.dsi.0: fe060000.dsi.0 supply vsp not found, using dummy regulator
[    0.225404] panel-simple-lsi fe060000.dsi.0: fe060000.dsi.0 supply vsn not found, using dummy regulator
Probably something with configuration
