valgrind不显示行号
如下,t是我编写的一个存在内存泄露的小程序,用valgrind成功检测到了,但是没有显示行号,在3399的ubuntu系统和buildroot系统下均是如此:
root@firefly:~# valgrind --leak-check=full ./t
==2693== Memcheck, a memory error detector
==2693== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==2693== Using Valgrind-3.13.0 and LibVEX; rerun with -h for copyright info
==2693== Command: ./t
==2693==
hi
==2693==
==2693== HEAP SUMMARY:
==2693==     in use at exit: 1 bytes in 1 blocks
==2693==   total heap usage: 2 allocs, 1 frees, 1,025 bytes allocated
==2693==
==2693== 1 bytes in 1 blocks are definitely lost in loss record 1 of 1
==2693==    at 0x4845BFC: malloc (in /usr/lib/valgrind/vgpreload_memcheck-arm64-linux.so)
==2693==
==2693== LEAK SUMMARY:
==2693==    definitely lost: 1 bytes in 1 blocks
==2693==    indirectly lost: 0 bytes in 0 blocks
==2693==      possibly lost: 0 bytes in 0 blocks
==2693==    still reachable: 0 bytes in 0 blocks
==2693==         suppressed: 0 bytes in 0 blocks
==2693==
==2693== For counts of detected and suppressed errors, rerun with: -v
==2693== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
root@firefly:~#
而检测相同的程序t,在x86下就会显示行号,如下:
==17689== Memcheck, a memory error detector
==17689== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==17689== Using Valgrind-3.13.0 and LibVEX; rerun with -h for copyright info
==17689== Command: ./t
==17689==
hi
==17689==
==17689== HEAP SUMMARY:
==17689==     in use at exit: 1 bytes in 1 blocks
==17689==   total heap usage: 2 allocs, 1 frees, 1,025 bytes allocated
==17689==
==17689== 1 bytes in 1 blocks are definitely lost in loss record 1 of 1
==17689==    at 0x4C2FB0F: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==17689==    by 0x10869B: main (t.c:6)
==17689==
==17689== LEAK SUMMARY:
==17689==    definitely lost: 1 bytes in 1 blocks
==17689==    indirectly lost: 0 bytes in 0 blocks
==17689==      possibly lost: 0 bytes in 0 blocks
==17689==    still reachable: 0 bytes in 0 blocks
==17689==         suppressed: 0 bytes in 0 blocks
==17689==
==17689== For counts of detected and suppressed errors, rerun with: -v
==17689== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
