1、dmesg | grep gc20 没有任何信息
2、脚本更改了,报错:
Rga built version:06fc7c4
Setting pipeline to PAUSED …
ERROR: Pipeline doesn’t want to pause.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Cannot identify device ‘/dev/video14’.
Additional debug info:
v4l2_calls.c(609): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
system error: No such file or directory
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device ‘/dev/video5’ is not a capture device.
v4l2_calls.c(631): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Capabilities: 0x4202000
Setting pipeline to NULL …
Freeing pipeline …
Freeing pipeline …
root@firefly:/home/firefly# dmesg | grep gc20
[ 2.014470] gc2053 4-0037: driver version: 00.01.01
[ 2.014525] gc2053 4-0037: Failed to get reset-gpios
[ 2.014598] gc2053 4-0037: Looking up dovdd-supply from device tree
[ 2.014610] gc2053 4-0037: Looking up dovdd-supply property in node /i2c@fe5d0000/gc2053@37 failed
[ 2.014647] gc2053 4-0037: 4-0037 supply dovdd not found, using dummy regulator
[ 2.014751] gc2053 4-0037: Linked as a consumer to regulator.0
[ 2.014772] gc2053 4-0037: Looking up avdd-supply from device tree
[ 2.014834] gc2053 4-0037: Linked as a consumer to regulator.11
[ 2.014853] gc2053 4-0037: Looking up dvdd-supply from device tree
[ 2.014864] gc2053 4-0037: Looking up dvdd-supply property in node /i2c@fe5d0000/gc2053@37 failed
[ 2.014885] gc2053 4-0037: 4-0037 supply dvdd not found, using dummy regulator
[ 2.014943] gc2053 4-0037: lane_num(2) pixel_rate(118800000)
[ 2.014966] gc2053 4-0037: could not get default pinstate
[ 2.014981] gc2053 4-0037: could not get sleep pinstate
[ 2.020876] gc2053 4-0037: Detected GC2053 sensor
[ 2.020945] rockchip-csi2-dphy csi2-dphy1: dphy1 matches m00_b_gc2053 4-0037:bus type 4
[ 2.021967] gc2093 4-007e: driver version: 00.01.01
[ 2.022054] gc2093 4-007e: Failed to get reset-gpios
[ 2.022110] gc2093 4-007e: Looking up dovdd-supply from device tree
[ 2.022121] gc2093 4-007e: Looking up dovdd-supply property in node /i2c@fe5d0000/gc2093b@7e failed
[ 2.022155] gc2093 4-007e: 4-007e supply dovdd not found, using dummy regulator
[ 2.022238] gc2093 4-007e: Linked as a consumer to regulator.0
[ 2.022259] gc2093 4-007e: Looking up avdd-supply from device tree
[ 2.022328] gc2093 4-007e: Linked as a consumer to regulator.11
[ 2.022346] gc2093 4-007e: Looking up dvdd-supply from device tree
[ 2.022356] gc2093 4-007e: Looking up dvdd-supply property in node /i2c@fe5d0000/gc2093b@7e failed
[ 2.022375] gc2093 4-007e: 4-007e supply dvdd not found, using dummy regulator
[ 2.043758] gc2093 4-007e: Detected GC2093 sensor
[ 2.043864] rockchip-csi2-dphy csi2-dphy2: dphy2 matches m01_f_gc2093 4-007e:bus type 4
