镜像: AIO-3399J-docker-UBUNTU18.04-GPT-20220121-1540.img.7z
报错信息:
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.595663 19314 metadata.go:138] Error while reading product_name: open /sys/class/dmi/id/product_name: no such file or directory
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.596722 19314 metadata.go:138] Error while reading product_name: open /sys/class/dmi/id/product_name: no such file or directory
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.597917 19314 metadata.go:138] Error while reading product_name: open /sys/class/dmi/id/product_name: no such file or directory
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.598735 19314 kuberuntime_manager.go:1098] “Updating runtime config through cri with podcidr” CIDR=“10.244.0.0/16”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.600310 19314 docker_service.go:364] “Docker cri received runtime config” runtimeConfig=“&RuntimeConfig{NetworkConfig:&NetworkConfig{PodCidr:10.244.0.0/16,},}”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.601321 19314 kubelet_network.go:76] “Updating Pod CIDR” originalPodCIDR=“” newPodCIDR=“10.244.0.0/16”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602152 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/portworx-volume”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602241 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/rbd”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602288 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/aws-ebs”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602334 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/gce-pd”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602379 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/cinder”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602423 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/azure-disk”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602498 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/azure-file”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602546 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/vsphere-volume”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602622 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/empty-dir”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602667 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/git-repo”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602711 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/host-path”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602759 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/nfs”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602805 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/secret”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602861 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/iscsi”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602906 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/glusterfs”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602951 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/quobyte”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.602995 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/cephfs”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.603040 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/downward-api”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.603099 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/fc”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.603142 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/flocker”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.603188 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/configmap”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.603235 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/projected”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.603281 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/local-volume”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.603331 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/storageos”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.603455 19314 plugins.go:641] “Loaded volume plugin” pluginName=“kubernetes.io/csi”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.604230 19314 server.go:1231] “Started kubelet”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.605265 19314 server.go:150] “Starting to listen” address=“0.0.0.0” port=10250
Jan 24 06:31:21 firefly kubelet[19314]: E0124 06:31:21.608400 19314 kubelet.go:1351] “Image garbage collection failed once. Stats initialization may not have completed yet” err=“failed to get imageFs info: unable to find data in memory cache”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.609789 19314 server.go:410] “Adding debug handlers to kubelet server”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.610770 19314 fs_resource_analyzer.go:67] “Starting FS ResourceAnalyzer”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.614222 19314 volume_manager.go:289] “The desired_state_of_world populator starts”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.614294 19314 volume_manager.go:291] “Starting Kubelet Volume Manager”
Jan 24 06:31:21 firefly kubelet[19314]: E0124 06:31:21.614694 19314 server.go:166] “Failed to listen and serve” err=“open : no such file or directory”
Jan 24 06:31:21 firefly kubelet[19314]: I0124 06:31:21.614763 19314 desired_state_of_world_populator.go:147] “Desired state populator starts to run”
Jan 24 06:31:21 firefly systemd[1]: kubelet.service: Main process exited, code=exited, status=1/FAILURE
Jan 24 06:31:21 firefly systemd[1]: kubelet.service: Failed with result ‘exit-code’.
估计是缺失对应文件夹引起:
