Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: recovery (misc)
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 400000Hz
PMIC: RK8090 (on=0x14, off=0x00)
vdd_npu_vepu 800000 uV
vdd_arm 800000 uV
io-domain: OK
Can’t get crtc id, default set to id = 0
Model: Rockchip RV1126 EVB DDR3 V13 Board
Using display timing dts
dsi@ffb30000: detailed mode clock 65000 kHz, flags[a]
H: 0720 0768 0776 0828
V: 1280 1296 1302 1317
bus_format: 100e
final DSI-Link bandwidth: 480 Mbps x 4
apll 816000 KHz
dpll 462000 KHz
gpll 1188000 KHz
cpll 500000 KHz
hpll 1400000 KHz
aclk_pdbus 500000 KHz
hclk_pdbus 198000 KHz
pclk_pdbus 99000 KHz
aclk_pdphp 297000 KHz
hclk_pdphp 198000 KHz
hclk_pdaudio 148500 KHz
hclk_pdcore 198000 KHz
pclk_pdpmu 99000 KHz
Net: eth0: ethernet@ffc40000
## Booting FIT Image at 0x3ad6e380 with size 0x00c88a00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 3ad6e380 …
Using ‘conf’ configuration
optee api revision: 2.0
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x3ad87380
Data Size: 6084752 Bytes = 5.8 MiB
Architecture: ARM
OS: Linux
Load Address: 0x02008000
Entry Point: 0x02008000
Hash algo: sha256
Hash value: ff90b3fbb290d47bd2e2825f4fc3272905550f5c49dab28570ca853cbbe9c4b8
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at 3ad6e380 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0x3b354d80
Data Size: 6954706 Bytes = 6.6 MiB
Architecture: ARM
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: d20fa4f9175da342130ff69cdef3009f5482eddd3aa3eb4d5baf24867c88e1d0
Loading ramdisk from 0x3b354d80 to 0x0a200000
## Loading fdt from FIT Image at 3ad6e380 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0x3ad6eb80
Data Size: 99928 Bytes = 97.6 KiB
Architecture: ARM
Load Address: 0x08300000
Hash algo: sha256
Hash value: d88cd55b36d5d63b896812cc4f7c2f5903f701e56e9a446143fcdf1172eb3377
Loading fdt from 0x08300000 to 0x08300000
Booting using the fdt blob at 0x08300000
Loading Kernel Image from 0x3ad87380 to 0x02008000 … OK
‘reserved-memory’ ramoops@8000000: addr=8000000 size=100000
Using Device Tree in place at 08300000, end 0831b657
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x40000000 (size: 0x379b8000)
Total: 824.348 ms
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.19.111 (jojo@jojo) (rv1126_rv1109_linux_20220125.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #3 SMP PREEMPT Fri Feb 11 22:04:24 CST 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] OF: fdt: Machine model: Rockchip RV1126 EVB DDR3 V13 Board
[ 0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options ‘’)
[ 0.000000] Reserved memory: created CMA memory pool at 0x3f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x2dc00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s32140 r8192 d21108 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 259512
[ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 snd_aloop.index=7
[ 0.000000] Memory: 743852K/1046240K available (8192K kernel code, 334K rwdata, 1908K rodata, 1024K init, 270K bss, 32052K reserved, 270336K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xb0000000 - 0xf0000000 (1024 MB)
[ 0.000000] pkmap : 0xafe00000 - 0xb0000000 ( 2 MB)
[ 0.000000] modules : 0xaf000000 - 0xafe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (9184 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 335 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 271 kB)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x324/0x4a4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008070] Switching to timer-based delay loop, resolution 41ns
[ 0.015415] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.025742] pid_max: default: 4096 minimum: 301
[ 0.030547] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.037258] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.045632] CPU: Testing write buffer coherency: ok
[ 0.050968] /cpus/cpu@f00 missing clock-frequency property
[ 0.056564] /cpus/cpu@f01 missing clock-frequency property
[ 0.062134] /cpus/cpu@f02 missing clock-frequency property
[ 0.067702] /cpus/cpu@f03 missing clock-frequency property
[ 0.073254] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.079771] Setting up static identity map for 0x100000 - 0x100060
[ 0.086194] rcu: Hierarchical SRCU implementation.
[ 0.091703] smp: Bringing up secondary CPUs …
[ 0.104901] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.113645] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.122313] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.122451] smp: Brought up 1 node, 4 CPUs
[ 0.144049] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.150922] CPU: All CPU(s) started in SVC mode.
[ 0.156409] devtmpfs: initialized
[ 0.187567] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.187854] Unpacking initramfs…
[ 0.196125] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.209678] futex hash table entries: 16 (order: -2, 1024 bytes)
[ 0.216428] pinctrl core: initialized pinctrl subsystem
[ 0.223355] NET: Registered protocol family 16
[ 0.228802] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.238294] cpuidle: using governor menu
[ 0.242636] Registered FIQ tty driver
[ 0.247191] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.255931] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.264817] console [pstore-1] enabled
[ 0.269235] pstore: Registered ramoops as persistent store backend
[ 0.276023] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[ 0.328424] cryptd: max_cpu_qlen set to 1000
[ 0.334083] fiq debugger fiq mode enabled
[[ 0.338900] console [ttyFIQ0] enabled
[ 0.346593] bootconsole [uart8250] disabled
[ 0.351434] Registered fiq debugger ttyFIQ0
[ 0.352101] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 0.355235] rk_iommu ffb00f00.iommu: version = 1
[ 0.355967] rk_iommu ffb20800.iommu: version = 1
[ 0.356443] rk_iommu ffb60e00.iommu: version = 1
[ 0.357033] rk_iommu ffb80480.iommu: version = 1
[ 0.357459] rk_iommu ffb90800.iommu: version = 1
[ 0.357941] rk_iommu ffbb0f00.iommu: version = 1
[ 0.358910] SCSI subsystem initialized
[ 0.359255] usbcore: registered new interface driver usbfs
[ 0.359360] usbcore: registered new interface driver hub
[ 0.359504] usbcore: registered new device driver usb
[ 0.359616] media: Linux media interface: v0.10
[ 0.359701] videodev: Linux video capture interface: v2.00
[ 0.359776] pps_core: LinuxPPS API ver. 1 registered
[ 0.359800] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.359843] PTP clock support registered
[ 0.361376] Advanced Linux Sound Architecture Driver Initialized.
[ 0.362082] Bluetooth: Core ver 2.22
[ 0.362176] NET: Registered protocol family 31
[ 0.362201] Bluetooth: HCI device and connection manager initialized
[ 0.362233] Bluetooth: HCI socket layer initialized
[ 0.362260] Bluetooth: L2CAP socket layer initialized
[ 0.362319] Bluetooth: SCO socket layer initialized
[ 0.362809] rockchip-cpuinfo cpuinfo: SoC : 11260000
[ 0.362845] rockchip-cpuinfo cpuinfo: Serial : 27f1133b1a533fff
[ 0.363803] clocksource: Switched to clocksource arch_sys_counter
[ 0.366556] NET: Registered protocol family 2
[ 0.367512] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.367574] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.367731] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.367934] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.368103] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.368182] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.368433] NET: Registered protocol family 1
[ 0.370249] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.372882] Initialise system trusted keyrings
[ 0.373177] workingset: timestamp_bits=29 max_order=18 bucket_order=0
[ 0.380820] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.383639] Key type asymmetric registered
[ 0.383677] Asymmetric key parser ‘x509’ registered
[ 0.383757] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.383778] io scheduler noop registered
[ 0.383844] io scheduler deadline registered
[ 0.384026] io scheduler cfq registered (default)
[ 0.384047] io scheduler mq-deadline registered
[ 0.384071] io scheduler kyber registered
[ 0.384234] io scheduler bfq registered
[ 0.388561] phy phy-ff4c0000.usb2-phy.1: Failed to get VBUS supply regulator
[ 0.390610] rockchip-usb2phy-naneng ff4c8000.usb2-phy: failed to create phy
[ 0.392235] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.392364] pwm-backlight backlight: Linked as a consumer to regulator.0
[ 0.392762] mpp_service mpp-srv: 92c80ddf68f6 author: Yandong Lin 2021-08-10 video: rockchip: mpp: workaround patch for rv1126 iommu issue
[ 0.392800] mpp_service mpp-srv: probe start
[ 0.393780] iommu: Adding device ffb80000.rkvdec to group 3
[ 0.393887] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[ 0.394102] mpp_rkvdec ffb80000.rkvdec: probing start
[ 0.394794] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[ 0.394829] rkvdec_init:1190: No niu aclk reset resource define
[ 0.394858] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[ 0.394880] rkvdec_init:1193: No niu hclk reset resource define
[ 0.395202] mpp_rkvdec ffb80000.rkvdec: probing finish
[ 0.396010] iommu: Adding device ffbb0000.rkvenc to group 5
[ 0.396072] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[ 0.396394] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.397027] mpp_rkvenc ffbb0000.rkvenc: venc regulator not ready, retry
[ 0.397069] rkvenc_init:1202: failed to add venc devfreq
[ 0.398191] iommu: Adding device ffb90400.vdpu to group 4
[ 0.398253] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[ 0.398366] mpp_vdpu2 ffb90400.vdpu: probe device
[ 0.398903] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.398953] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.399249] mpp_vdpu2 ffb90400.vdpu: probing finish
[ 0.399846] iommu: Adding device ffb90000.vepu to group 4
[ 0.399908] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[ 0.400041] mpp_vepu2 ffb90000.vepu: probe device
[ 0.400610] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.400653] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.400910] mpp_vepu2 ffb90000.vepu: probing finish
[ 0.401445] iommu: Adding device ffb20000.iep to group 1
[ 0.401505] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[ 0.401622] mpp-iep2 ffb20000.iep: probe device
[ 0.402313] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[ 0.402539] mpp-iep2 ffb20000.iep: probing finish
[ 0.402837] mpp_service mpp-srv: probe success
[ 0.408123] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.408174] dma-pl330 ff4e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.410220] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.411163] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.412093] ff560000.serial: ttyS0 at MMIO 0xff560000 (irq = 32, base_baud = 1500000) is a 16550A
[ 0.414216] random: fast init done
[ 0.414603] random: crng init done
[ 0.415077] iommu: Adding device ffb00000.vop to group 0
[ 0.415141] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[ 0.419173] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[ 0.420219] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[ 0.421551] rockchip-drm display-subsystem: devfreq is not set
[ 0.422037] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093bf80)
[ 0.422113] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] ERROR Failed to find panel or bridge: -517
[ 0.422152] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb09426ac): -517
[ 0.422418] rockchip-drm display-subsystem: master bind failed: -517
[ 0.427420] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.1
[ 0.427489] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[ 0.427589] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[ 0.427636] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[ 0.429008] zram: Added device: zram0
[ 0.431167] libphy: Fixed MDIO Bus: probed
[ 0.433110] rk_gmac-dwmac ffc40000.ethernet: no regulator found
[ 0.433155] rk_gmac-dwmac ffc40000.ethernet: clock input or output? (input).
[ 0.433185] rk_gmac-dwmac ffc40000.ethernet: TX delay(0x11).
[ 0.433212] rk_gmac-dwmac ffc40000.ethernet: RX delay(0x11).
[ 0.433241] rk_gmac-dwmac ffc40000.ethernet: integrated PHY? (no).
[ 0.433326] rk_gmac-dwmac ffc40000.ethernet: clock input from PHY
[ 0.438376] rk_gmac-dwmac ffc40000.ethernet: i
