aio3399 ubuntu版本运行没进入到文件系统问题
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc56bc3a030 #cjw (Feb 12 2022 - 22:58:37 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbeb000, fdt: 7bddf4d8
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
Android header version 0
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1100000 uV
In: serial
Out: serial
Err: serial
Model: AIO-3399J Board (Linux Opensource)
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 22341 KiB
RAM disk load addr 0x0a200000 size 6740 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
Using Device Tree in place at 0000000008300000, end 000000000831c42c
No file: logo_kernel.bmp
Total: 2681.750 ms
[ 0.000000] Linux version 4.4.194-g50f0a60241aa-dirty (cjw@cjw-virtual-machine) (firefly: 50f0a60241aa6c9af65d5bdbdaae40df4cd77be3) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #2 SMP Sat Feb 12 22:59:26 CST 2022
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee0000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=2c710c1c32fc3096 ro rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0x7fe98000-0x7fed8000] (0MB)
[ 0.000000] Memory: 1995220K/2064384K available (13950K kernel code, 1796K rwdata, 5308K rodata, 1216K init, 2009K bss, 69164K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009360000 - 0xffffff8009490000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008e20000 ( 13952 KB)
[ 0.000000] .rodata : 0xffffff8008e20000 - 0xffffff8009360000 ( 5376 KB)
[ 0.000000] .data : 0xffffff8009490000 - 0xffffff8009651008 ( 1797 KB)
[ 0.000000] ITS: allocated 65536 Devices @7d480000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007d410000
[ 0.000000] CPU0: using LPI pending table @0x000000007d420000
[ 0.002262] Console: colour dummy device 80x25
[ 0.002703] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003690] pid_max: default: 32768 minimum: 301
[ 0.004211] Security Framework initialized
[ 0.004672] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005312] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006672] Initializing cgroup subsys io
[ 0.007078] Initializing cgroup subsys memory
[ 0.007518] Initializing cgroup subsys devices
[ 0.007948] Initializing cgroup subsys freezer
[ 0.008387] Initializing cgroup subsys perf_event
[ 0.008840] Initializing cgroup subsys net_prio
[ 0.009276] Initializing cgroup subsys pids
[ 0.009706] ftrace: allocating 50498 entries in 198 pages
[ 0.130335] sched-energy: Sched-energy-costs installed from DT
[ 0.130900] CPU0: update cpu_capacity 401
[ 0.131338] ASID allocator initialised with 32768 entries
[ 0.135076] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.136434] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.138719] Detected VIPT I-cache on CPU1
[ 0.138754] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.138785] CPU1: using LPI pending table @0x000000007d6c0000
[ 0.138838] CPU1: update cpu_capacity 401
[ 0.138842] CPU1: Booted secondary processor [410fd034]
[ 0.139635] Detected VIPT I-cache on CPU2
[ 0.139666] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.139696] CPU2: using LPI pending table @0x000000007d6f0000
[ 0.139745] CPU2: update cpu_capacity 401
[ 0.139748] CPU2: Booted secondary processor [410fd034]
[ 0.140531] Detected VIPT I-cache on CPU3
[ 0.140562] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.140591] CPU3: using LPI pending table @0x000000007d740000
[ 0.140638] CPU3: update cpu_capacity 401
[ 0.140642] CPU3: Booted secondary processor [410fd034]
[ 0.141426] Detected PIPT I-cache on CPU4
[ 0.141449] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.141484] CPU4: using LPI pending table @0x000000007d770000
[ 0.141518] CPU4: update cpu_capacity 1024
[ 0.141522] CPU4: Booted secondary processor [410fd082]
[ 0.142192] Detected PIPT I-cache on CPU5
[ 0.142217] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.142251] CPU5: using LPI pending table @0x000000007d7b0000
[ 0.142285] CPU5: update cpu_capacity 1024
[ 0.142288] CPU5: Booted secondary processor [410fd082]
[ 0.142382] Brought up 6 CPUs
[ 0.154728] SMP: Total of 6 processors activated.
[ 0.155178] CPU features: detected feature: GIC system register CPU interface
[ 0.155865] CPU features: detected feature: 32-bit EL0 Support
[ 0.156423] CPU: All CPU(s) started at EL2
[ 0.156851] alternatives: patching kernel code
[ 0.158645] devtmpfs: initialized
[ 0.177814] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.178768] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.179829] xor: measuring software checksum speed
[ 0.189605] 8regs : 2856.000 MB/sec
[ 0.199661] 8regs_prefetch: 2564.000 MB/sec
[ 0.209714] 32regs : 3204.000 MB/sec
[ 0.219769] 32regs_prefetch: 2848.000 MB/sec
[ 0.220218] xor: using function: 32regs (3204.000 MB/sec)
[ 0.220750] pinctrl core: initialized pinctrl subsystem
[ 0.222972] Failed to find legacy iommu devices
[ 0.223777] NET: Registered protocol family 16
[ 0.229435] cpuidle: using governor ladder
[ 0.233444] cpuidle: using governor menu
[ 0.233837] Registered FIQ tty driver
[ 0.234728] vdso: 2 pages (1 code @ ffffff8008e26000, 1 data @ ffffff8009494000)
[ 0.235463] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.236525] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.260376] console [pstore-1] enabled
[ 0.260748] pstore: Registered ramoops as persistent store backend
[ 0.261342] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.264324] console [ttyFIQ0] enabled
[ 0.265013] bootconsole [uart0] disabled
[ 0.265945] Registered fiq debugger ttyFIQ0
[ 0.317400] raid6: int64x1 gen() 468 MB/s
[ 0.334499] raid6: int64x1 xor() 412 MB/s
[ 0.351580] raid6: int64x2 gen() 675 MB/s
[ 0.368649] raid6: int64x2 xor() 595 MB/s
[ 0.385735] raid6: int64x4 gen() 964 MB/s
[ 0.402836] raid6: int64x4 xor() 667 MB/s
[ 0.419947] raid6: int64x8 gen() 781 MB/s
[ 0.437003] raid6: int64x8 xor() 626 MB/s
[ 0.454112] raid6: neonx1 gen() 964 MB/s
[ 0.471207] raid6: neonx1 xor() 664 MB/s
[ 0.488266] raid6: neonx2 gen() 1273 MB/s
[ 0.505379] raid6: neonx2 xor() 996 MB/s
[ 0.522477] raid6: neonx4 gen() 1726 MB/s
[ 0.539553] raid6: neonx4 xor() 1177 MB/s
[ 0.556648] raid6: neonx8 gen() 1691 MB/s
[ 0.573750] raid6: neonx8 xor() 1257 MB/s
[ 0.574140] raid6: using algorithm neonx4 gen() 1726 MB/s
[ 0.574615] raid6: … xor() 1177 MB/s, rmw enabled
[ 0.575056] raid6: using intx1 recovery algorithm
[ 0.579983] iommu: Adding device ff650000.vpu_service to group 0
[ 0.580605] iommu: Adding device ff660000.rkvdec to group 1
[ 0.581208] iommu: Adding device ff8f0000.vop to group 2
[ 0.581777] iommu: Adding device ff900000.vop to group 3
[ 0.582336] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.582933] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.583908] rk_iommu ff650800.iommu: can’t get sclk
[ 0.584595] rk_iommu ff660480.iommu: can’t get sclk
[ 0.585241] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.585830] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.586428] rk_iommu ff914000.iommu: can’t get sclk
[ 0.587017] rk_iommu ff924000.iommu: can’t get sclk
[ 0.587807] SCSI subsystem initialized
[ 0.588496] usbcore: registered new interface driver usbfs
[ 0.589022] usbcore: registered new interface driver hub
[ 0.589584] usbcore: registered new device driver usb
[ 0.590099] media: Linux media interface: v0.10
[ 0.590547] Linux video capture interface: v2.00
[ 0.591027] pps_core: LinuxPPS API ver. 1 registered
[ 0.591469] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.592297] PTP clock support registered
[ 0.593796] Advanced Linux Sound Architecture Driver Initialized.
[ 0.594811] Bluetooth: Core ver 2.21
[ 0.595148] NET: Registered protocol family 31
[ 0.595556] Bluetooth: HCI device and connection manager initialized
[ 0.596128] Bluetooth: HCI socket layer initialized
[ 0.596570] Bluetooth: L2CAP socket layer initialized
[ 0.597055] Bluetooth: SCO socket layer initialized
[ 0.597984] nfc: nfc_init: NFC Core ver 0.1
[ 0.598396] NET: Registered protocol family 39
[ 0.598916] rockchip-cpuinfo cpuinfo: Serial : 2c710c1c32fc3096
[ 0.600264] clocksource: Switched to clocksource arch_sys_counter
[ 0.651969] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.652891] NET: Registered protocol family 2
[ 0.653697] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.654481] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.655532] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.656185] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.656806] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.657649] NET: Registered protocol family 1
[ 0.658331] RPC: Registered named UNIX socket transport module.
[ 0.658854] RPC: Registered udp transport module.
[ 0.659284] RPC: Registered tcp transport module.
[ 0.659703] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.660947] Trying to unpack rootfs image as initramfs…
[ 1.031572] Freeing initrd memory: 6736K
[ 1.032669] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.033492] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.037523] Initialise system trusted keyring
[ 1.045786] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.047073] NFS: Registering the id_resolver key type
[ 1.047559] Key type id_resolver registered
[ 1.047933] Key type id_legacy registered
[ 1.048314] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.049576] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.050350] fuse init (API version 7.23)
[ 1.051032] SGI XFS with security attributes, no debug enabled
[ 1.056873] NET: Registered protocol family 38
[ 1.057311] Key type asymmetric registered
[ 1.057680] Asymmetric key parser ‘x509’ registered
[ 1.058277] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.059075] io scheduler noop registered
[ 1.059446] io scheduler deadline registered
[ 1.059864] io scheduler cfq registered (default)
[ 1.061791] phy phy-ff770000.syscon:usb2-phy@e450.1: Failed to get VBUS supply regulator
[ 1.063396] phy phy-ff770000.syscon:usb2-phy@e460.3: Failed to get VBUS supply regulator
[ 1.068755] ace test_init function.
[ 1.069239] ace test_init end.ret=0
[ 1.069943] radar end.ret=0
[ 1.072701] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.073313] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.073906] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.074474] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 1.075083] PCI host bridge /pcie@f8000000 ranges:
[ 1.075534] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 1.075991] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 1.618324] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.618938] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.619676] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.621213] Module initialized.
[ 1.621971] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.622831] rk-vcodec ff650000.vpu_service: probe device
[ 1.623565] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.624708] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.625343] rk-vcodec ff650000.vpu_service: init success
[ 1.626107] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.627061] rk-vcodec ff660000.rkvdec: probe device
[ 1.627695] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.628638] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.629220] rk-vcodec ff660000.rkvdec: init success
[ 1.631092] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.631782] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.634048] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.634749] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.636630] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.637856] pwm-regulator: supplied by vcc5v0_sys
[ 1.638964] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.640131] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 1.642735] [drm] Initialized drm 1.1.0 20060810
[ 1.646921] [drm] Rockchip DRM driver version: v1.0.1
[ 1.647709] rockchip-drm display-subsystem: dmc is disabled
[ 1.648510] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.649332] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008ee3cf0)
[ 1.650081] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.650838] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008ee3cf0)
[ 1.651798] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.652400] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.653182] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.654857] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ed8548)
[ 1.655616] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.656207] [drm] No driver support for vblank timestamp query.
[ 1.656990] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.657714] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.658361] rockchip-drm display-subsystem: failed to show loader logo
[ 1.659110] Freeing drm_logo memory: 616K
[ 1.659494] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.660202] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.672481] Console: switching to colour frame buffer device 128x48
[ 1.680047] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.688778] mali ff9a0000.gpu: Failed to get regulator
[ 1.689234] mali ff9a0000.gpu: Power control initialization failed
[ 1.690176] Unable to detect cache hierarchy for CPU 0
[ 1.691396] brd: module loaded
[ 1.696906] loop: module loaded
[ 1.697784] zram: Added device: zram0
[ 1.698412] lkdtm: No crash points registered, enable through debugfs
[ 1.699367] Loading dl1825 driver
[ 1.701241] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.702679] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.873585] wk2xxx_probe() GENA = 0xFF
[ 1.873925] spi driver error!!!
[ 1.874236] wk2xxxspi: probe of spi32766.0 failed with error 1
[ 1.874788] register spi return v = :0
[ 1.875621] tun: Universal TUN/TAP device driver, 1.6
[ 1.876075] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.877562] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.878285] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.878914] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.879424] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.879939] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.880663] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.881286] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.886838] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.887454] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.887906] Ring mode enabled
[ 1.888187] DMA HW capability register supported
[ 1.888601] Normal descriptors
[ 1.888907] RX Checksum Offload Engine supported (type 2)
[ 1.889400] Wake-Up On Lan supported
[ 1.889761] Enable RX Mitigation via HW Watchdog Timer
[ 2.002756] libphy: stmmac: probed
[ 2.003076] eth%d: PHY ID 0000ffff at 0 IRQ POLL (stmmac-0:00) active
[ 2.003661] eth%d: PHY ID 0000ffff at 1 IRQ POLL (stmmac-0:01)
[ 2.004185] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 2.004723] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 2.005246] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 2.005778] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 2.006310] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 2.006833] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 2.007367] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 2.007890] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 2.008422] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 2.008946] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 2.009478] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 2.010002] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 2.010534] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 2.011057] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 2.011589] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 2.012113] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 2.012645] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 2.013168] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 2.013701] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 2.014224] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 2.014756] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 2.015288] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 2.015812] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 2.016344] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 2.016867] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 2.017400] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 2.017923] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 2.018455] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 2.018978] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 2.019510] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 2.022198] usbcore: registered new interface driver rtl8192cu
[ 2.022800] usbcore: registered new interface driver rndis_wlan
[ 2.023609] usbcore: registered new interface driver mt7601u
[ 2.024219] Rockchip WiFi SYS interface (V1.00) …
[ 2.024812] usbcore: registered new interface driver rtl8150
[ 2.025384] usbcore: registered new interface driver r8152
[ 2.025931] usbcore: registered new interface driver asix
[ 2.026476] usbcore: registered new interface driver ax88179_178a
[ 2.027065] usbcore: registered new interface driver cdc_ether
[ 2.027647] usbcore: registered new interface driver rndis_host
[ 2.028247] usbcore: registered new interface driver cdc_ncm
[ 2.028815] usbcore: registered new interface driver qmi_wwan
[ 2.029387] usbcore: registered new interface driver cdc_mbim
[ 2.134134] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 2.234758] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 2.335377] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 2.435997] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 2.536615] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 2.537178] phy phy-ff7c0000.phy.6: phy poweron failed → -110
[ 2.537809] dwc3 fe800000.dwc3: failed to initialize core
[ 2.538381] dwc3: probe of fe800000.dwc3 failed with error -110
[ 2.539011] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 2.545054] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 2.547383] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.547981] ehci-pci: EHCI PCI platform driver
[ 2.548479] ehci-platform: EHCI generic platform driver
[ 2.552757] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.553527] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 2.554374] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.560297] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.561065] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.561691] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.562342] usb usb1: Product: EHCI Host Controller
[ 2.562776] usb usb1: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty ehci_hcd
[ 2.563427] usb usb1: SerialNumber: fe380000.usb
[ 2.564461] hub 1-0:1.0: USB hub found
[ 2.564833] hub 1-0:1.0: 1 port detected
[ 2.569345] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.570093] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 2.570918] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.577304] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.578048] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.578671] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.579323] usb usb2: Product: EHCI Host Controller
[ 2.579757] usb usb2: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty ehci_hcd
[ 2.580407] usb usb2: SerialNumber: fe3c0000.usb
[ 2.581439] hub 2-0:1.0: USB hub found
[ 2.581810] hub 2-0:1.0: 1 port detected
[ 2.583003] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.583583] ohci-platform: OHCI generic platform driver
[ 2.584494] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.585368] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 2.586161] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.641485] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.642092] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.642746] usb usb3: Product: Generic Platform OHCI controller
[ 2.643283] usb usb3: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty ohci_hcd
[ 2.643922] usb usb3: SerialNumber: fe3a0000.usb
[ 2.644935] hub 3-0:1.0: USB hub found
[ 2.645327] hub 3-0:1.0: 1 port detected
[ 2.646404] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.647249] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 2.648051] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.703464] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.704071] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.704726] usb usb4: Product: Generic Platform OHCI controller
[ 2.705251] usb usb4: Manufacturer: Linux 4.4.194-g50f0a60241aa-dirty ohci_hcd
[ 2.705902] usb usb4: SerialNumber: fe3e0000.usb
[ 2.706902] hub 4-0:1.0: USB hub found
[ 2.707310] hub 4-0:1.0: 1 port detected
[ 2.709162] usbcore: registered new interface driver cdc_acm
[ 2.709678] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.710450] usbcore: registered new interface driver cdc_wdm
[ 2.711007] usbcore: registered new interface driver uas
[ 2.711650] usbcore: registered new interface driver usb-storage
[ 2.712299] usbcore: registered new interface driver usbserial
[ 2.712865] usbcore: registered new interface driver usbserial_generic
[ 2.713488] usbserial: USB Serial support registered for generic
[ 2.714073] usbcore: registered new interface driver ch341
[ 2.714602] usbserial: USB Serial support registered for ch341-uart
[ 2.715210] usbcore: registered new interface driver cp210x
[ 2.715750] usbserial: USB Serial support registered for cp210x
[ 2.716376] usbcore: registered new interface driver ftdi_sio
[ 2.716915] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.717836] usbcore: registered new interface driver keyspan
[ 2.718379] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.719099] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.719787] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.720478] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.721182] usbcore: registered new interface driver option
[ 2.721723] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.722692] usbcore: registered new interface driver oti6858
[ 2.723220] usbserial: USB Serial support registered for oti6858
[ 2.723819] usbcore: registered new interface driver pl2303
[ 2.724360] usbserial: USB Serial support registered for pl2303
[ 2.724947] usbcore: registered new interface driver qcserial
[ 2.725500] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.726199] usbcore: registered new interface driver sierra
[ 2.726744] usbserial: USB Serial support registered for Sierra USB modem
[ 2.728885] usbcore: registered new interface driver usbtouchscreen
[ 2.729927] .. rk pwm remotectl v1.1 init
[ 2.730630] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.731845] sensor_register_slave:mma8452,id=17
[ 2.732280] sensor_register_slave:lis3dh,id=7
[ 2.732683] sensor_register_slave:mma7660,id=18
[ 2.733098] sensor_register_slave:lsm303d,id=22
[ 2.733525] sensor_register_slave:gs_mc3230,id=23
[ 2.733943] [Gsensor] gsensor_init
[ 2.734288] sensor_register_slave:mpu6880_acc,id=24
[ 2.734726] sensor_register_slave:mpu6500_acc,id=25
[ 2.735164] sensor_register_slave:lsm330_acc,id=26
[ 2.735613] sensor_register_slave:akm8975,id=30
[ 2.736027] sensor_register_slave:akm8963,id=31
[ 2.736452] sensor_register_slave:l3g4200d,id=45
[ 2.736877] sensor_register_slave:l3g20d,id=46
[ 2.737294] sensor_register_slave:ewtsa,id=47
[ 2.737687] sensor_register_slave:lsm330_gyro,id=51
[ 2.738124] sensor_register_slave:cm3217,id=53
[ 2.738539] sensor_register_slave:cm3218,id=54
[ 2.739561] i2c /dev entries driver
[ 2.741765] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.742501] fan53555-reg: supplied by vcc5v0_sys
停留在上面这个位置
